Pushing keys from KMU to ECB?
Hi!
I'm storing a key in the KMU for use by the ECB.
If I set the slot's destination address to an address in RAM, the KMU pushes the key there correctly, but if I instead set the destination address to &NRF_ECU00->KEY.VALUE[0], I can't push the key.
I run this code to push they key:
    if (nrf_kmu_status_get(NRF_KMU) != NRF_KMU_STATUS_READY) {
        printf("ERROR: KMU not ready\n");
        return;
    nrf_kmu_keyslot_set(NRF_KMU, slot_id);
    nrf_kmu_event_clear(NRF_KMU, NRF_KMU_EVENT_KEYSLOT_PUSHED);
    nrf_kmu_task_trigger(NRF_KMU, NRF_KMU_TASK_PUSH_KEYSLOT);
    while (nrf_kmu_status_get(NRF_KMU) == NRF_KMU_STATUS_BUSY) {
        /* Busy wait */
    if (!nrf_kmu_event_check(NRF_KMU, NRF_KMU_EVENT_KEYSLOT_PUSHED)) {
        printf("Failed to push key\n");
        return;
I run this code in a mpsl timeslot handler.
I can write to the NRF_ECB00->KEY.VALUE[0] key registers there with the CPU.
Is there something more I have to do to be able to push they key directly to the ECB's KEY registers from the KMU?
  • I just got the information that due to hardware limitation, pushing keys directly from KMU to ECB or CCM isn't possible with the nRF54L15. I'm sorry for the bad news.
    I thought you were interleaving multiple protocols here, but do I understand right that you want to encrypt BLE packets? Is native BLE encryption insufficient for some of your use cases?
    Regarding whether to include TF-M or not, I recommend considering it. Cyber security regulations are getting stricter; think of the EU's Cybersecurity Resilience Act, for example.
    As for the time window, I think 4ms is a lot. I just picked the first AES sample available, Crypto: AES CCM, tested with the nRF54L15, and the process completed in under 2ms. Here is the log with timestamps:
    *** Booting nRF Connect SDK v2.9.1-60d0d6c8d42d ***
    *** Using Zephyr OS v3.7.99-ca954a6216c9 ***
    [00:00:00.425,943] <inf> aes_cbc: Starting AES-CBC-NO-PADDING example...
    [00:00:00.425,948] <inf> aes_cbc: Generating random AES key...
    [00:00:00.426,097] <inf> aes_cbc: AES key generated successfully!
    [00:00:00.426,103] <inf> aes_cbc: Encrypting using AES CBC MODE...
    [00:00:00.426,515] <inf> aes_cbc: Encryption successful!
    [00:00:00.426,532] <inf> aes_cbc: ---- IV (len: 16): ----
    [00:00:00.426,542] <inf> aes_cbc: Content:
                                      f3 27 c4 66 2e 4c db fb  6a ae 1d 4e e8 53 7d c4 |.'.f.L.. j..N.S}.
    [00:00:00.426,553] <inf> aes_cbc: ---- IV end  ----
    [00:00:00.426,564] <inf> aes_cbc: ---- Plaintext (len: 64): ----
    [00:00:00.426,577] <inf> aes_cbc: Content:
                                      45 78 61 6d 70 6c 65 20  73 74 72 69 6e 67 20 74 |Example  string t
                                      6f 20 64 65 6d 6f 6e 73  74 72 61 74 65 20 62 61 |o demons trate ba
                                      73 69 63 20 75 73 61 67  65 20 6f 66 20 41 45 53 |sic usag e of AES
                                      20 43 42 43 20 6d 6f 64  65 2e 00 00 00 00 00 00 | CBC mod e.......
    [00:00:00.426,588] <inf> aes_cbc: ---- Plaintext end  ----
    [00:00:00.426,599] <inf> aes_cbc: ---- Encrypted text (len: 64): ----
    [00:00:00.426,612] <inf> aes_cbc: Content:
                                      c3 8f c1 10 e0 30 20 ec  5b 81 9a 1f d0 aa b7 d9 |.....0 . [.......
                                      be b5 ec fb 4a e2 56 15  b2 d0 f7 3b 32 ce e2 be |....J.V. ...;2...
                                      c2 b5 5e 30 13 34 bb f1  53 39 61 0e ad 03 7d f8 |..^0.4.. S9a...}.
                                      92 23 08 b3 bb b7 8d 4f  4a 65 0a be 8a 42 da a9 |.#.....O Je...B..
    [00:00:00.426,623] <inf> aes_cbc: ---- Encrypted text end  ----
    [00:00:00.426,691] <inf> aes_cbc: Decrypting using AES CBC MODE...
    [00:00:00.427,064] <inf> aes_cbc: ---- Decrypted text (len: 64): ----
    [00:00:00.427,079] <inf> aes_cbc: Content:
    [00:00:00.427,090] <inf> aes_cbc: ---- Decrypted text end  ----
    [00:00:00.427,101] <inf> aes_cbc: Decryption successful!
    [00:00:00.427,226] <inf> aes_cbc: Example finished successfully!
