Low power management of external flash
my setup is the following:
- SDK 2.6.3
- nRF5340
- Low power management for external flash enabled
- Logging enabled (based on littleFS)
- external flash used to store continuously data
With this configuration i am observing an exponential increase of booting time due to the introduction of the the entry to and exit from low power of the external flash as defined in the file \v2.6.3\zephyr\drivers\flash\spi_nor.c.
The characteristic of my external flash for entry and exit the deep sleep mode are the following:
- 30us to enter in Deep Power down mode
- 10us to exit Deep Power down mode
Those values are rounded up to 1 ms each by the defines in \v2.6.3\zephyr\drivers\flash\spi_nor.c
#define T_RES1_MS DIV_ROUND_UP(DT_INST_PROP(0, t_exit_dpd), NSEC_PER_MSEC)
#define T_DP_MS DIV_ROUND_UP(DT_INST_PROP(0, t_enter_dpd), NSEC_PER_MSEC)
1. Why the need to convert in milliseconds those delays (in the specific case, causing an increase between 30 and 100 times) ?
2. For such kind of microseconds delay would not be better to use even a blocking delay like NRFX_DELAY_US ? (I have modified the spi.nor file and seems to work properly)
3. Is there a way - even i looked for but could not find it - to enable the power management for the external flash at runtime ? So in my case, it would be disabled at the boot up and once done, it gets enabled.
4. Eventually, could this change be considered in the future version of sdk ?
Thanks in advance for your support.
Kind regards
Riccardo Gaiati
  • Hi Andreas !
    thanks for the reply. I think i understand the approach of the PM APIs by giving to the user of a specific device the possibility to control the low power of the external flash. If i am not wrong, this pattern relies on the user to do the "right thing" according to its needs.
    My idea is simply to avoid spreading those apis between the users of the flash and relies only on the driver (spi_nor.c), which will create a single manager of the power management, instead of  as many as the users of it.
    Since the entry and exit time in low power are measured typically in microseconds, it is reasonable to convert them into ticks (eventually rounded them up) and use those values as input parameters for the delays. I have attached here the modifications i made in the spi_nor.c file. I did not change the wake up sequence, since i am not using (the modifications are pretty straightforward to do in case).
     * Copyright (c) 2018 Savoir-Faire Linux.
     * Copyright (c) 2020 Peter Bigot Consulting, LLC
     * Copyright (c) 2023 Intercreate, Inc.
     * This driver is heavily inspired from the spi_flash_w25qxxdv.c SPI NOR driver.
    #define DT_DRV_COMPAT jedec_spi_nor
    #include <errno.h>
    #include <zephyr/drivers/flash.h>
    #include <zephyr/drivers/spi.h>
    #include <zephyr/init.h>
    #include <string.h>
    #include <zephyr/sys_clock.h>
    #include <zephyr/pm/device.h>
    #include "spi_nor.h"
    #include "jesd216.h"
    #include "flash_priv.h"
    LOG_MODULE_REGISTER(spi_nor, CONFIG_FLASH_LOG_LEVEL);
    /* Device Power Management Notes
     * These flash devices have several modes during operation:
     * * When CSn is asserted (during a SPI operation) the device is
     *   active.
     * * When CSn is deasserted the device enters a standby mode.
     * * Some devices support a Deep Power-Down mode which reduces current
     *   to as little as 0.1% of standby.
     * The power reduction from DPD is sufficient to warrant allowing its
     * use even in cases where Zephyr's device power management is not
     * available.  This is selected through the SPI_NOR_IDLE_IN_DPD
     * Kconfig option.
     * When mapped to the Zephyr Device Power Management states:
     * * PM_DEVICE_STATE_ACTIVE covers both active and standby modes;
     * * PM_DEVICE_STATE_SUSPENDED, and PM_DEVICE_STATE_OFF all correspond to
     *   deep-power-down mode.
    #define SPI_NOR_MAX_ADDR_WIDTH 4
    #if DT_INST_NODE_HAS_PROP(0, t_enter_dpd)
    #define T_DP_US (DT_INST_PROP(0, t_enter_dpd) / NSEC_PER_USEC)
    #define T_DP_TICK (k_us_to_ticks_near32(T_DP_US))
    #else /* T_ENTER_DPD */
    #define T_DP_MS 0
    #endif /* T_ENTER_DPD */
    #if DT_INST_NODE_HAS_PROP(0, t_exit_dpd)
    #define T_RES1_US (DT_INST_PROP(0, t_exit_dpd) / NSEC_PER_USEC)
    #define T_RES1_TICK (k_us_to_ticks_near32(T_RES1_US))
    #endif /* T_EXIT_DPD */
    #if DT_INST_NODE_HAS_PROP(0, dpd_wakeup_sequence)
    #define T_DPDD_MS DIV_ROUND_UP(DT_INST_PROP_BY_IDX(0, dpd_wakeup_sequence, 0), NSEC_PER_MSEC)
    #define T_CRDP_MS DIV_ROUND_UP(DT_INST_PROP_BY_IDX(0, dpd_wakeup_sequence, 1), NSEC_PER_MSEC)
    #define T_RDP_MS DIV_ROUND_UP(DT_INST_PROP_BY_IDX(0, dpd_wakeup_sequence, 2), NSEC_PER_MSEC)
    #else /* DPD_WAKEUP_SEQUENCE */
    #define T_DPDD_MS 0
    #endif /* DPD_WAKEUP_SEQUENCE */
    #define _INST_HAS_WP_OR(inst) DT_INST_NODE_HAS_PROP(inst, wp_gpios) ||
    #define ANY_INST_HAS_WP_GPIOS DT_INST_FOREACH_STATUS_OKAY(_INST_HAS_WP_OR) 0
    #define _INST_HAS_HOLD_OR(inst) DT_INST_NODE_HAS_PROP(inst, hold_gpios) ||
    #define ANY_INST_HAS_HOLD_GPIOS DT_INST_FOREACH_STATUS_OKAY(_INST_HAS_HOLD_OR) 0
    #define DEV_CFG(_dev_) ((const struct spi_nor_config * const) (_dev_)->config)
    /* Build-time data associated with the device. */
    struct spi_nor_config {
    	/* Devicetree SPI configuration */
    	struct spi_dt_spec spi;
    #if DT_INST_NODE_HAS_PROP(0, reset_gpios)
    	const struct gpio_dt_spec reset;
    	/* Runtime SFDP stores no static configuration. */
    #ifndef CONFIG_SPI_NOR_SFDP_RUNTIME
    	/* Size of device in bytes, from size property */
    	uint32_t flash_size;
    #ifdef CONFIG_FLASH_PAGE_LAYOUT
    	/* Flash page layout can be determined from devicetree. */
    	struct flash_pages_layout layout;
    #endif /* CONFIG_FLASH_PAGE_LAYOUT */
    	/* Expected JEDEC ID, from jedec-id property */
    	uint8_t jedec_id[SPI_NOR_MAX_ID_LEN];
    #if defined(CONFIG_SPI_NOR_SFDP_MINIMAL)
    	/* Optional support for entering 32-bit address mode. */
    	uint8_t enter_4byte_addr;
    #endif /* CONFIG_SPI_NOR_SFDP_MINIMAL */
    #if defined(CONFIG_SPI_NOR_SFDP_DEVICETREE)
    	/* Length of BFP structure, in 32-bit words. */
    	uint8_t bfp_len;
    	/* Pointer to the BFP table as read from the device
    	 * (little-endian stored words), from sfdp-bfp property
    	const struct jesd216_bfp *bfp;
    #endif /* CONFIG_SPI_NOR_SFDP_DEVICETREE */
    #endif /* CONFIG_SPI_NOR_SFDP_RUNTIME */
    	/* Optional bits in SR to be cleared on startup.
    	 * This information cannot be derived from SFDP.
    	uint8_t has_lock;
    #if ANY_INST_HAS_WP_GPIOS
    	/* The write-protect GPIO (wp-gpios) */
    	const struct gpio_dt_spec *wp;
    #if ANY_INST_HAS_HOLD_GPIOS
    	/* The hold GPIO (hold-gpios) */
    	const struct gpio_dt_spec *hold;
     * struct spi_nor_data - Structure for defining the SPI NOR access
     * @sem: The semaphore to access to the flash
    struct spi_nor_data {
    	struct k_sem sem;
    #if DT_INST_NODE_HAS_PROP(0, has_dpd)
    	/* Uptime counter in ticks at which device last entered
    	 * deep power-down.
    	int64_t ts_enter_dpd;
    	/* Miscellaneous flags */
    	/* If set addressed operations should use 32-bit rather than
    	 * 24-bit addresses.
    	 * This is ignored if the access parameter to a command
    	 * explicitly specifies 24-bit or 32-bit addressing.
    	bool flag_access_32bit: 1;
    	/* Minimal SFDP stores no dynamic configuration.  Runtime and
    	 * devicetree store page size and erase_types; runtime also
    	 * stores flash size and layout.
    #ifndef CONFIG_SPI_NOR_SFDP_MINIMAL
    	struct jesd216_erase_type erase_types[JESD216_NUM_ERASE_TYPES];
    	/* Number of bytes per page */
    	uint16_t page_size;
    #ifdef CONFIG_SPI_NOR_SFDP_RUNTIME
    	/* Size of flash, in bytes */
    #ifdef CONFIG_SPI_NOR_SFDP_MINIMAL
    /* The historically supported erase sizes. */
    static const struct jesd216_erase_type minimal_erase_types[JESD216_NUM_ERASE_TYPES] = {
    		.cmd = SPI_NOR_CMD_BE,
    		.exp = 16,
    		.cmd = SPI_NOR_CMD_SE,
    		.exp = 12,
    static int spi_nor_write_protection_set(const struct device *dev,
    					bool write_protect);
    /* Get pointer to array of supported erase types.  Static const for
     * minimal, data for runtime and devicetree.
    static inline const struct jesd216_erase_type *
    dev_erase_types(const struct device *dev)
    	return minimal_erase_types;
    #else /* CONFIG_SPI_NOR_SFDP_MINIMAL */
    	const struct spi_nor_data *data = dev->data;
    	return data->erase_types;
    /* Get the size of the flash device.  Data for runtime, constant for
     * minimal and devicetree.
    static inline uint32_t dev_flash_size(const struct device *dev)
    	return data->flash_size;
    #else /* CONFIG_SPI_NOR_SFDP_RUNTIME */
    	const struct spi_nor_config *cfg = dev->config;
    	return cfg->flash_size;
    /* Get the flash device page size.  Constant for minimal, data for
     * runtime and devicetree.
    static inline uint16_t dev_page_size(const struct device *dev)
    	return DT_INST_PROP_OR(0, page_size, 256);
    	return data->page_size;
    static const struct flash_parameters flash_nor_parameters = {
    	.write_block_size = 1,
    	.erase_value = 0xff,
    /* Capture the time at which the device entered deep power-down. */
    static inline void record_entered_dpd(const struct device *const dev)
    	struct spi_nor_data *const driver_data = dev->data;
    	driver_data->ts_enter_dpd = k_uptime_ticks(); //k_uptime_get_32();
    /* Check the current time against the time DPD was entered and delay
     * until it's ok to initiate the DPD exit process.
    static inline void delay_until_exit_dpd_ok(const struct device *const dev)
    	int64_t since = (k_uptime_ticks() - driver_data->ts_enter_dpd);
    	/* If the time is negative the 32-bit counter has wrapped,
    	 * which is certainly long enough no further delay is
    	 * required.  Otherwise we have to check whether it's been
    	 * long enough taking into account necessary delays for
    	 * entering and exiting DPD.
    	if (since >= 0) {
    		/* Subtract time required for DPD to be reached */
    		since -= T_DP_TICK;
    		/* Subtract time required in DPD before exit */
    		since -= T_DPDD_MS;
    		/* If the adjusted time is negative we have to wait
    		 * until it reaches zero before we can proceed.
    		if (since < 0) {
    			k_sleep(K_TICKS((uint64_t)-since));
    #endif /* DT_INST_NODE_HAS_PROP(0, has_dpd) */
    /* Indicates that an access command includes bytes for the address.
     * If not provided the opcode is not followed by address bytes.
    #define NOR_ACCESS_ADDRESSED BIT(0)
    /* Indicates that addressed access uses a 24-bit address regardless of
     * spi_nor_data::flag_32bit_addr.
    #define NOR_ACCESS_24BIT_ADDR BIT(1)
    /* Indicates that addressed access uses a 32-bit address regardless of
    #define NOR_ACCESS_32BIT_ADDR BIT(2)
    /* Indicates that an access command is performing a write.  If not
     * provided access is a read.
    #define NOR_ACCESS_WRITE BIT(7)
     * @brief Send an SPI command
     * @param dev Device struct
     * @param opcode The command to send
     * @param access flags that determine how the command is constructed.
     *        See NOR_ACCESS_*.
     * @param addr The address to send
     * @param data The buffer to store or read the value
     * @param length The size of the buffer
     * @return 0 on success, negative errno code otherwise
    static int spi_nor_access(const struct device *const dev,
    			  uint8_t opcode, unsigned int access,
    			  off_t addr, void *data, size_t length)
    	const struct spi_nor_config *const driver_cfg = dev->config;
    	bool is_addressed = (access & NOR_ACCESS_ADDRESSED) != 0U;
    	bool is_write = (access & NOR_ACCESS_WRITE) != 0U;
    	uint8_t buf[5] = { 0 };
    	struct spi_buf spi_buf[2] = {
    			.buf = buf,
    			.len = 1,
    			.buf = data,
    			.len = length
    	buf[0] = opcode;
    	if (is_addressed) {
    		bool access_24bit = (access & NOR_ACCESS_24BIT_ADDR) != 0;
    		bool access_32bit = (access & NOR_ACCESS_32BIT_ADDR) != 0;
    		bool use_32bit = (access_32bit
    				  || (!access_24bit
    				      && driver_data->flag_access_32bit));
    		union {
    			uint32_t u32;
    			uint8_t u8[4];
    		} addr32 = {
    			.u32 = sys_cpu_to_be32(addr),
    		if (use_32bit) {
    			memcpy(&buf[1], &addr32.u8[0], 4);
    			spi_buf[0].len += 4;
    		} else {
    			memcpy(&buf[1], &addr32.u8[1], 3);
    			spi_buf[0].len += 3;
    	const struct spi_buf_set tx_set = {
    		.buffers = spi_buf,
    		.count = (length != 0) ? 2 : 1,
    	const struct spi_buf_set rx_set = {
    		.buffers = spi_buf,
    		.count = 2,
    	if (is_write) {
    		return spi_write_dt(&driver_cfg->spi, &tx_set);
    	return spi_transceive_dt(&driver_cfg->spi, &tx_set, &rx_set);
    #define spi_nor_cmd_read(dev, opcode, dest, length) \
    	spi_nor_access(dev, opcode, 0, 0, dest, length)
    #define spi_nor_cmd_addr_read(dev, opcode, addr, dest, length) \
    	spi_nor_access(dev, opcode, NOR_ACCESS_ADDRESSED, addr, dest, length)
    #define spi_nor_cmd_write(dev, opcode) \
    	spi_nor_access(dev, opcode, NOR_ACCESS_WRITE, 0, NULL, 0)
    #define spi_nor_cmd_addr_write(dev, opcode, addr, src, length) \
    	spi_nor_access(dev, opcode, NOR_ACCESS_WRITE | NOR_ACCESS_ADDRESSED, \
    		       addr, (void *)src, length)
     * @brief Wait until the flash is ready
     * @note The device must be externally acquired before invoking this
     * function.
     * This function should be invoked after every ERASE, PROGRAM, or
     * WRITE_STATUS operation before continuing.  This allows us to assume
     * that the device is ready to accept new commands at any other point
     * in the code.
     * @param dev The device structure
    static int spi_nor_wait_until_ready(const struct device *dev)
    	int ret;
    	uint8_t reg;
    	do {
    		ret = spi_nor_cmd_read(dev, SPI_NOR_CMD_RDSR, &reg, sizeof(reg));
    	} while (!ret && (reg & SPI_NOR_WIP_BIT));
    	return ret;
    #if defined(CONFIG_SPI_NOR_SFDP_RUNTIME) || defined(CONFIG_FLASH_JESD216_API)
     * @brief Read content from the SFDP hierarchy
     * function.
    static int read_sfdp(const struct device *const dev,
    	/* READ_SFDP requires a 24-bit address followed by a single
    	 * byte for a wait state.  This is effected by using 32-bit
    	 * address by shifting the 24-bit address up 8 bits.
    	return spi_nor_access(dev, JESD216_CMD_READ_SFDP,
    			      NOR_ACCESS_32BIT_ADDR | NOR_ACCESS_ADDRESSED,
    			      addr << 8, data, length);
    static int enter_dpd(const struct device *const dev)
    	int ret = 0;
    	if (IS_ENABLED(DT_INST_PROP(0, has_dpd))) {
    		ret = spi_nor_cmd_write(dev, SPI_NOR_CMD_DPD);
    		if (ret == 0) {
    			record_entered_dpd(dev);
    	return ret;
    static int exit_dpd(const struct device *const dev)
    	int ret = 0;
    		delay_until_exit_dpd_ok(dev);
    		/* Assert CSn and wait for tCRDP.
    		 * Unfortunately the SPI API doesn't allow us to
    		 * control CSn so fake it by writing a known-supported
    		 * single-byte command, hoping that'll hold the assert
    		 * long enough.  This is highly likely, since the
    		 * duration is usually less than two SPI clock cycles.
    		ret = spi_nor_cmd_write(dev, SPI_NOR_CMD_RDID);
    		/* Deassert CSn and wait for tRDP */
    		k_sleep(K_MSEC(T_RDP_MS));
    		ret = spi_nor_cmd_write(dev, SPI_NOR_CMD_RDPD);
    		if (ret == 0) {
    			k_sleep(K_TICKS(T_RES1_TICK));
    	return ret;
    /* Everything necessary to acquire owning access to the device.
     * This means taking the lock and, if necessary, waking the device
     * from deep power-down mode.
    static void acquire_device(const struct device *dev)
    	if (IS_ENABLED(CONFIG_MULTITHREADING)) {
    		k_sem_take(&driver_data->sem, K_FOREVER);
    	if (IS_ENABLED(CONFIG_SPI_NOR_IDLE_IN_DPD)) {
    		exit_dpd(dev);
    /* Everything necessary to release access to the device.
     * This means (optionally) putting the device into deep power-down
     * mode, and releasing the lock.
    static void release_device(const struct device *dev)
    		enter_dpd(dev);
    		k_sem_give(&driver_data->sem);
     * @brief Read the status register.
     * function.
     * @return the non-negative value of the status register, or an error code.
    static int spi_nor_rdsr(const struct device *dev)
    	uint8_t reg;
    	int ret = spi_nor_cmd_read(dev, SPI_NOR_CMD_RDSR, &reg, sizeof(reg));
    	if (ret == 0) {
    		ret = reg;
    	return ret;
     * @brief Write the status register.
     * function.
     * @param sr The new value of the status register
     * @return 0 on success or a negative error code.
    static int spi_nor_wrsr(const struct device *dev,
    			uint8_t sr)
    	int ret = spi_nor_cmd_write(dev, SPI_NOR_CMD_WREN);
    	if (ret == 0) {
    		ret = spi_nor_access(dev, SPI_NOR_CMD_WRSR, NOR_ACCESS_WRITE, 0, &sr,
    				     sizeof(sr));
    		spi_nor_wait_until_ready(dev);
    	return ret;
    #if DT_INST_NODE_HAS_PROP(0, mxicy_mx25r_power_mode)
     * @brief Read the configuration register.
     * function.
     * @return the non-negative value of the configuration register, or an error code.
    static int mxicy_rdcr(const struct device *dev)
    	uint16_t cr;
    	enum { CMD_RDCR = 0x15 };
    	int ret = spi_nor_cmd_read(dev, CMD_RDCR, &cr, sizeof(cr));
    	if (ret < 0) {
    		return ret;
    	return cr;
     * @brief Write the configuration register.
     * function.
     * @param cr  The new value of the configuration register
    static int mxicy_wrcr(const struct device *dev,
    			uint16_t cr)
    	/* The configuration register bytes on the Macronix MX25R devices are
    	 * written using the Write Status Register command where the configuration
    	 * register bytes are written as two extra bytes after the status register.
    	 * First read out the current status register to preserve the value.
    	int sr = spi_nor_rdsr(dev);
    	if (sr < 0) {
    		LOG_ERR("Read status register failed: %d", sr);
    		return sr;
    	if (ret == 0) {
    		uint8_t data[] = {
    			sr,
    			cr & 0xFF,	/* Configuration register 1 */
    			cr >> 8		/* Configuration register 2 */
    		ret = spi_nor_access(dev, SPI_NOR_CMD_WRSR, NOR_ACCESS_WRITE, 0, data,
    			sizeof(data));
    	return ret;
    static int mxicy_configure(const struct device *dev, const uint8_t *jedec_id)
    	/* Low-power/high perf mode is second bit in configuration register 2 */
    	enum { LH_SWITCH_BIT = 9 };
    	const uint8_t JEDEC_MACRONIX_ID = 0xc2;
    	const uint8_t JEDEC_MX25R_TYPE_ID = 0x28;
    	int current_cr, new_cr, ret;
    	/* lh_switch enum index:
    	 * 0: Ultra low power
    	 * 1: High performance mode
    	const bool use_high_perf = DT_INST_ENUM_IDX(0, mxicy_mx25r_power_mode);
    	/* Only supported on Macronix MX25R Ultra Low Power series. */
    	if (jedec_id[0] != JEDEC_MACRONIX_ID || jedec_id[1] != JEDEC_MX25R_TYPE_ID) {
    		LOG_WRN("L/H switch not supported for device id: %02x %02x %02x", jedec_id[0],
    			jedec_id[1], jedec_id[2]);
    		/* Do not return an error here because the flash still functions */
    		return 0;
    	acquire_device(dev);
    	/* Read current configuration register */
    	ret = mxicy_rdcr(dev);
    	if (ret < 0) {
    		return ret;
    	current_cr = ret;
    	LOG_DBG("Use high performance mode? %d", use_high_perf);
    	new_cr = current_cr;
    	WRITE_BIT(new_cr, LH_SWITCH_BIT, use_high_perf);
    	if (new_cr != current_cr) {
    		ret = mxicy_wrcr(dev, new_cr);
    	} else {
    		ret = 0;
    	if (ret < 0) {
    		LOG_ERR("Enable high performace mode failed: %d", ret);
    	release_device(dev);
    	return ret;
    #endif /* DT_INST_NODE_HAS_PROP(0, mxicy_mx25r_power_mode) */
    static int spi_nor_read(const struct device *dev, off_t addr, void *dest,
    			size_t size)
    	const size_t flash_size = dev_flash_size(dev);
    	int ret;
    	/* should be between 0 and flash size */
    	if ((addr < 0) || ((addr + size) > flash_size)) {
    		return -EINVAL;
    	ret = spi_nor_cmd_addr_read(dev, SPI_NOR_CMD_READ, addr, dest, size);
    	return ret;
    #if defined(CONFIG_FLASH_EX_OP_ENABLED)
    static int flash_spi_nor_ex_op(const struct device *dev, uint16_t code,
    			const uintptr_t in, void *out)
    	int ret;
    	ARG_UNUSED(in);
    	ARG_UNUSED(out);
    	switch (code) {
    	case FLASH_EX_OP_RESET:
    		ret = spi_nor_cmd_write(dev, SPI_NOR_CMD_RESET_EN);
    		if (ret == 0) {
    			ret = spi_nor_cmd_write(dev, SPI_NOR_CMD_RESET_MEM);
    		ret = -ENOTSUP;
    	return ret;
    static int spi_nor_write(const struct device *dev, off_t addr,
    			 const void *src,
    			 size_t size)
    	const uint16_t page_size = dev_page_size(dev);
    	int ret = 0;
    	if ((addr < 0) || ((size + addr) > flash_size)) {
    		return -EINVAL;
    	ret = spi_nor_write_protection_set(dev, false);
    	if (ret == 0) {
    		while (size > 0) {
    			size_t to_write = size;
    			/* Don't write more than a page. */
    			if (to_write >= page_size) {
    				to_write = page_size;
    			/* Don't write across a page boundary */
    			if (((addr + to_write - 1U) / page_size)
    			!= (addr / page_size)) {
    				to_write = page_size - (addr % page_size);
    			ret = spi_nor_cmd_addr_write(dev, SPI_NOR_CMD_PP, addr,
    						src, to_write);
    			if (ret != 0) {
    			size -= to_write;
    			src = (const uint8_t *)src + to_write;
    			addr += to_write;
    	int ret2 = spi_nor_write_protection_set(dev, true);
    	if (!ret) {
    		ret = ret2;
    	return ret;
    static int spi_nor_erase(const struct device *dev, off_t addr, size_t size)
    	int ret = 0;
    	/* erase area must be subregion of device */
    		return -EINVAL;
    	/* address must be sector-aligned */
    	if (!SPI_NOR_IS_SECTOR_ALIGNED(addr)) {
    		return -EINVAL;
    	/* size must be a multiple of sectors */
    	if ((size % SPI_NOR_SECTOR_SIZE) != 0) {
    		return -EINVAL;
    	while ((size > 0) && (ret == 0)) {
    		if (size == flash_size) {
    			/* chip erase */
    			spi_nor_cmd_write(dev, SPI_NOR_CMD_CE);
    			size -= flash_size;
    		} else {
    			const struct jesd216_erase_type *erase_types =
    				dev_erase_types(dev);
    			const struct jesd216_erase_type *bet = NULL;
    			for (uint8_t ei = 0; ei < JESD216_NUM_ERASE_TYPES; ++ei) {
    				const struct jesd216_erase_type *etp =
    					&erase_types[ei];
    				if ((etp->exp != 0)
    				    && SPI_NOR_IS_ALIGNED(addr, etp->exp)
    				    && (size >= BIT(etp->exp))
    				    && ((bet == NULL)
    					|| (etp->exp > bet->exp))) {
    					bet = etp;
    			if (bet != NULL) {
    				spi_nor_cmd_addr_write(dev, bet->cmd, addr, NULL, 0);
    				addr += BIT(bet->exp);
    				size -= BIT(bet->exp);
    			} else {
    				LOG_DBG("Can't erase %zu at 0x%lx",
    					size, (long)addr);
    				ret = -EINVAL;
    #ifdef __XCC__
    		 * FIXME: remove this hack once XCC is fixed.
    		 * Without this volatile return value, XCC would segfault
    		 * compiling this file complaining about failure in CGPREP
    		 * phase.
    		volatile int xcc_ret =
    	if (!ret) {
    		ret = ret2;
    	return ret;
    /* @note The device must be externally acquired before invoking this
     * function.
    					bool write_protect)
    	int ret;
    	if (DEV_CFG(dev)->wp && write_protect == false) {
    		gpio_pin_set_dt(DEV_CFG(dev)->wp, 0);
    	ret = spi_nor_cmd_write(dev, (write_protect) ?
    	      SPI_NOR_CMD_WRDI : SPI_NOR_CMD_WREN);
    	if (IS_ENABLED(DT_INST_PROP(0, requires_ulbpr))
    	    && (ret == 0)
    	    && !write_protect) {
    		ret = spi_nor_cmd_write(dev, SPI_NOR_CMD_ULBPR);
    	if (DEV_CFG(dev)->wp && write_protect == true) {
    		gpio_pin_set_dt(DEV_CFG(dev)->wp, 1);
    	return ret;
    #if defined(CONFIG_FLASH_JESD216_API) || defined(CONFIG_SPI_NOR_SFDP_RUNTIME)
    static int spi_nor_sfdp_read(const struct device *dev, off_t addr,
    			     void *dest, size_t size)
    	int ret = read_sfdp(dev, addr, dest, size);
    	return ret;
    #endif /* CONFIG_FLASH_JESD216_API || CONFIG_SPI_NOR_SFDP_RUNTIME */
    static int spi_nor_read_jedec_id(const struct device *dev,
    				 uint8_t *id)
    	if (id == NULL) {
    		return -EINVAL;
    	int ret = spi_nor_cmd_read(dev, SPI_NOR_CMD_RDID, id, SPI_NOR_MAX_ID_LEN);
    	return ret;
    /* Put the device into the appropriate address mode, if supported.
     * On successful return spi_nor_data::flag_access_32bit has been set
     * (cleared) if the device is configured for 4-byte (3-byte) addresses
     * for read, write, and erase commands.
     * @param dev the device
     * @param enter_4byte_addr the Enter 4-Byte Addressing bit set from
     * DW16 of SFDP BFP.  A value of all zeros or all ones is interpreted
     * as "not supported".
     * @retval -ENOTSUP if 4-byte addressing is supported but not in a way
     * that the driver can handle.
     * @retval negative codes if the attempt was made and failed
     * @retval 0 if the device is successfully left in 24-bit mode or
     *         reconfigured to 32-bit mode.
    static int spi_nor_set_address_mode(const struct device *dev,
    				    uint8_t enter_4byte_addr)
    	int ret = 0;
    	/* Do nothing if not provided (either no bits or all bits
    	 * set).
    	if ((enter_4byte_addr == 0)
    	    || (enter_4byte_addr == 0xff)) {
    		return 0;
    	LOG_DBG("Checking enter-4byte-addr %02x", enter_4byte_addr);
    	/* This currently only supports command 0xB7 (Enter 4-Byte
    	 * Address Mode), with or without preceding WREN.
    	if ((enter_4byte_addr & 0x03) == 0) {
    		return -ENOTSUP;
    	if ((enter_4byte_addr & 0x02) != 0) {
    		/* Enter after WREN. */
    	if (ret == 0) {
    		ret = spi_nor_cmd_write(dev, SPI_NOR_CMD_4BA);
    	if (ret == 0) {
    		data->flag_access_32bit = true;
    	return ret;
    static int spi_nor_process_bfp(const struct device *dev,
    			       const struct jesd216_param_header *php,
    			       const struct jesd216_bfp *bfp)
    	struct jesd216_erase_type *etp = data->erase_types;
    	const size_t flash_size = jesd216_bfp_density(bfp) / 8U;
    	LOG_INF("%s: %u MiBy flash", dev->name, (uint32_t)(flash_size >> 20));
    	/* Copy over the erase types, preserving their order.  (The
    	 * Sector Map Parameter table references them by index.)
    	memset(data->erase_types, 0, sizeof(data->erase_types));
    	for (uint8_t ti = 1; ti <= ARRAY_SIZE(data->erase_types); ++ti) {
    		if (jesd216_bfp_erase(bfp, ti, etp) == 0) {
    			LOG_DBG("Erase %u with %02x", (uint32_t)BIT(etp->exp), etp->cmd);
    		++etp;
    	data->page_size = jesd216_bfp_page_size(php, bfp);
    	data->flash_size = flash_size;
    	if (flash_size != dev_flash_size(dev)) {
    		LOG_ERR("BFP flash size mismatch with devicetree");
    		return -EINVAL;
    	LOG_DBG("Page size %u bytes", data->page_size);
    	/* If 4-byte addressing is supported, switch to it. */
    	if (jesd216_bfp_addrbytes(bfp) != JESD216_SFDP_BFP_DW1_ADDRBYTES_VAL_3B) {
    		struct jesd216_bfp_dw16 dw16;
    		int rc = 0;
    		if (jesd216_bfp_decode_dw16(php, bfp, &dw16) == 0) {
    			rc = spi_nor_set_address_mode(dev, dw16.enter_4ba);
    		if (rc != 0) {
    			LOG_ERR("Unable to enter 4-byte mode: %d\n", rc);
    			return rc;
    	return 0;
    static int spi_nor_process_sfdp(const struct device *dev)
    	int rc;
    	/* For runtime we need to read the SFDP table, identify the
    	 * BFP block, and process it.
    	const uint8_t decl_nph = 2;
    	union {
    		/* We only process BFP so use one parameter block */
    		uint8_t raw[JESD216_SFDP_SIZE(decl_nph)];
    		struct jesd216_sfdp_header sfdp;
    	} u_header;
    	const struct jesd216_sfdp_header *hp = &u_header.sfdp;
    	rc = spi_nor_sfdp_read(dev, 0, u_header.raw, sizeof(u_header.raw));
    	if (rc != 0) {
    		LOG_ERR("SFDP read failed: %d", rc);
    		return rc;
    	uint32_t magic = jesd216_sfdp_magic(hp);
    	if (magic != JESD216_SFDP_MAGIC) {
    		LOG_ERR("SFDP magic %08x invalid", magic);
    		return -EINVAL;
    	LOG_INF("%s: SFDP v %u.%u AP %x with %u PH", dev->name,
    		hp->rev_major, hp->rev_minor, hp->access, 1 + hp->nph);
    	const struct jesd216_param_header *php = hp->phdr;
    	const struct jesd216_param_header *phpe = php + MIN(decl_nph, 1 + hp->nph);
    	while (php != phpe) {
    		uint16_t id = jesd216_param_id(php);
    		LOG_INF("PH%u: %04x rev %u.%u: %u DW @ %x",
    			(php - hp->phdr), id, php->rev_major, php->rev_minor,
    			php->len_dw, jesd216_param_addr(php));
    		if (id == JESD216_SFDP_PARAM_ID_BFP) {
    			union {
    				uint32_t dw[MIN(php->len_dw, 20)];
    				struct jesd216_bfp bfp;
    			} u_param;
    			const struct jesd216_bfp *bfp = &u_param.bfp;
    			rc = spi_nor_sfdp_read(dev, jesd216_param_addr(php),
    				u_param.dw, sizeof(u_param.dw));
    			if (rc == 0) {
    				rc = spi_nor_process_bfp(dev, php, bfp);
    			if (rc != 0) {
    				LOG_INF("SFDP BFP failed: %d", rc);
    		++php;
    #elif defined(CONFIG_SPI_NOR_SFDP_DEVICETREE)
    	/* For devicetree we need to synthesize a parameter header and
    	 * process the stored BFP data as if we had read it.
    	struct jesd216_param_header bfp_hdr = {
    		.len_dw = cfg->bfp_len,
    	rc = spi_nor_process_bfp(dev, &bfp_hdr, cfg->bfp);
    #else
    #error Unhandled SFDP choice
    	return rc;
    #if defined(CONFIG_FLASH_PAGE_LAYOUT)
    static int setup_pages_layout(const struct device *dev)
    	int rv = 0;
    	const uint32_t layout_page_size = CONFIG_SPI_NOR_FLASH_LAYOUT_PAGE_SIZE;
    	uint8_t exp = 0;
    	/* Find the smallest erase size. */
    	for (size_t i = 0; i < ARRAY_SIZE(data->erase_types); ++i) {
    		const struct jesd216_erase_type *etp = &data->erase_types[i];
    		if ((etp->cmd != 0)
    		    && ((exp == 0) || (etp->exp < exp))) {
    			exp = etp->exp;
    	if (exp == 0) {
    		return -ENOTSUP;
    	uint32_t erase_size = BIT(exp);
    	/* Error if layout page size is not a multiple of smallest
    	 * erase size.
    	if ((layout_page_size % erase_size) != 0) {
    		LOG_ERR("layout page %u not compatible with erase size %u",
    			layout_page_size, erase_size);
    		return -EINVAL;
    	/* Warn but accept layout page sizes that leave inaccessible
    	 * space.
    	if ((flash_size % layout_page_size) != 0) {
    		LOG_INF("layout page %u wastes space with device size %zu",
    			layout_page_size, flash_size);
    	data->layout.pages_size = layout_page_size;
    	data->layout.pages_count = flash_size / layout_page_size;
    	LOG_DBG("layout %u x %u By pages", data->layout.pages_count, data->layout.pages_size);
    	const struct flash_pages_layout *layout = &cfg->layout;
    	size_t layout_size = layout->pages_size * layout->pages_count;
    	if (flash_size != layout_size) {
    		LOG_ERR("device size %u mismatch %zu * %zu By pages",
    			flash_size, layout->pages_count, layout->pages_size);
    		return -EINVAL;
    	return rv;
     * @brief Configure the flash
     * @param dev The flash device structure
     * @param info The flash info structure
    static int spi_nor_configure(const struct device *dev)
    	int rc;
    	/* Validate bus and CS is ready */
    	if (!spi_is_ready_dt(&cfg->spi)) {
    		return -ENODEV;
    	if (!gpio_is_ready_dt(&cfg->reset)) {
    		LOG_ERR("Reset pin not ready");
    		return -ENODEV;
    	if (gpio_pin_configure_dt(&cfg->reset, GPIO_OUTPUT_ACTIVE)) {
    		LOG_ERR("Couldn't configure reset pin");
    		return -ENODEV;
    	rc = gpio_pin_set_dt(&cfg->reset, 0);
    	if (rc) {
    		return rc;
    	/* After a soft-reset the flash might be in DPD or busy writing/erasing.
    	 * Exit DPD and wait until flash is ready.
    	rc = exit_dpd(dev);
    	if (rc < 0) {
    		LOG_ERR("Failed to exit DPD (%d)", rc);
    		return -ENODEV;
    	rc = spi_nor_rdsr(dev);
    	if (rc > 0 && (rc & SPI_NOR_WIP_BIT)) {
    		LOG_WRN("Waiting until flash is ready");
    	/* now the spi bus is configured, we can verify SPI
    	 * connectivity by reading the JEDEC ID.
    	rc = spi_nor_read_jedec_id(dev, jedec_id);
    	if (rc != 0) {
    		LOG_ERR("JEDEC ID read failed: %d", rc);
    		return -ENODEV;
    	/* For minimal and devicetree we need to check the JEDEC ID
    	 * against the one from devicetree, to ensure we didn't find a
    	 * device that has different parameters.
    	if (memcmp(jedec_id, cfg->jedec_id, sizeof(jedec_id)) != 0) {
    		LOG_ERR("Device id %02x %02x %02x does not match config %02x %02x %02x",
    			jedec_id[0], jedec_id[1], jedec_id[2],
    			cfg->jedec_id[0], cfg->jedec_id[1], cfg->jedec_id[2]);
    		return -EINVAL;
    	/* Check for block protect bits that need to be cleared.  This
    	 * information cannot be determined from SFDP content, so the
    	 * devicetree node property must be set correctly for any device
    	 * that powers up with block protect enabled.
    	if (cfg->has_lock != 0) {
    		/* Only clear if RDSR worked and something's set. */
    		if (rc > 0) {
    			rc = spi_nor_wrsr(dev, rc & ~cfg->has_lock);
    		if (rc != 0) {
    			LOG_ERR("BP clear failed: %d\n", rc);
    			return -ENODEV;
    	/* For minimal we support some overrides from specific
    	 * devicertee properties.
    	if (cfg->enter_4byte_addr != 0) {
    		rc = spi_nor_set_address_mode(dev, cfg->enter_4byte_addr);
    		if (rc != 0) {
    			return -ENODEV;
    	/* For devicetree and runtime we need to process BFP data and
    	 * set up or validate page layout.
    	rc = spi_nor_process_sfdp(dev);
    	if (rc != 0) {
    		return -ENODEV;
    	rc = setup_pages_layout(dev);
    	if (rc != 0) {
    		LOG_ERR("layout setup failed: %d", rc);
    		return -ENODEV;
    	/* Do not fail init if setting configuration register fails */
    	(void) mxicy_configure(dev, jedec_id);
    	    && (enter_dpd(dev) != 0)) {
    		return -ENODEV;
    	return 0;
    #ifdef CONFIG_PM_DEVICE
    static int spi_nor_pm_control(const struct device *dev, enum pm_device_action action)
    	int rc = 0;
    	switch (action) {
    #ifdef CONFIG_SPI_NOR_IDLE_IN_DPD
    	case PM_DEVICE_ACTION_SUSPEND:
    	case PM_DEVICE_ACTION_RESUME:
    #else
    		rc = enter_dpd(dev);
    		rc = exit_dpd(dev);
    #endif /* CONFIG_SPI_NOR_IDLE_IN_DPD */
    	case PM_DEVICE_ACTION_TURN_ON:
    		/* Coming out of power off */
    		rc = spi_nor_configure(dev);
    	case PM_DEVICE_ACTION_TURN_OFF:
    		rc = -ENOSYS;
    	return rc;
    #endif /* CONFIG_PM_DEVICE */
     * @brief Initialize and configure the flash
     * @param name The flash name
    static int spi_nor_init(const struct device *dev)
    		k_sem_init(&driver_data->sem, 1, K_SEM_MAX_LIMIT);
    	if (DEV_CFG(dev)->wp) {
    		if (!device_is_ready(DEV_CFG(dev)->wp->port)) {
    			LOG_ERR("Write-protect pin not ready");
    			return -ENODEV;
    		if (gpio_pin_configure_dt(DEV_CFG(dev)->wp, GPIO_OUTPUT_ACTIVE)) {
    			LOG_ERR("Write-protect pin failed to set active");
    			return -ENODEV;
    #endif /* ANY_INST_HAS_WP_GPIOS */
    	if (DEV_CFG(dev)->hold) {
    		if (!device_is_ready(DEV_CFG(dev)->hold->port)) {
    			LOG_ERR("Hold pin not ready");
    			return -ENODEV;
    		if (gpio_pin_configure_dt(DEV_CFG(dev)->hold, GPIO_OUTPUT_INACTIVE)) {
    			LOG_ERR("Hold pin failed to set inactive");
    			return -ENODEV;
    #endif /* ANY_INST_HAS_HOLD_GPIOS */
    	return spi_nor_configure(dev);
    static void spi_nor_pages_layout(const struct device *dev,
    				 const struct flash_pages_layout **layout,
    				 size_t *layout_size)
    	/* Data for runtime, const for devicetree and minimal. */
    	*layout = &data->layout;
    	*layout_size = 1;
    static const struct flash_parameters *
    flash_nor_get_parameters(const struct device *dev)
    	ARG_UNUSED(dev);
    	return &flash_nor_parameters;
    static const struct flash_driver_api spi_nor_api = {
    	.read = spi_nor_read,
    	.write = spi_nor_write,
    	.erase = spi_nor_erase,
    	.get_parameters = flash_nor_get_parameters,
    	.page_layout = spi_nor_pages_layout,
    	.sfdp_read = spi_nor_sfdp_read,
    	.read_jedec_id = spi_nor_read_jedec_id,
    	.ex_op = flash_spi_nor_ex_op,
    /* We need to know the size and ID of the configuration data we're
     * using so we can disable the device we see at runtime if it isn't
     * compatible with what we're taking from devicetree or minimal.
    BUILD_ASSERT(DT_INST_NODE_HAS_PROP(0, jedec_id),
    	     "jedec,spi-nor jedec-id required for non-runtime SFDP");
    /* For devicetree or minimal page layout we need to know the size of
     * the device.  We can't extract it from the raw BFP data, so require
     * it to be present in devicetree.
    BUILD_ASSERT(DT_INST_NODE_HAS_PROP(0, size),
    	     "jedec,spi-nor size required for non-runtime SFDP page layout");
    /* instance 0 size in bytes */
    #define INST_0_BYTES (DT_INST_PROP(0, size) / 8)
    BUILD_ASSERT(SPI_NOR_IS_SECTOR_ALIGNED(CONFIG_SPI_NOR_FLASH_LAYOUT_PAGE_SIZE),
    	     "SPI_NOR_FLASH_LAYOUT_PAGE_SIZE must be multiple of 4096");
    /* instance 0 page count */
    #define LAYOUT_PAGES_COUNT (INST_0_BYTES / CONFIG_SPI_NOR_FLASH_LAYOUT_PAGE_SIZE)
    BUILD_ASSERT((CONFIG_SPI_NOR_FLASH_LAYOUT_PAGE_SIZE * LAYOUT_PAGES_COUNT)
    	     == INST_0_BYTES,
    	     "SPI_NOR_FLASH_LAYOUT_PAGE_SIZE incompatible with flash size");
    #ifdef CONFIG_SPI_NOR_SFDP_DEVICETREE
    BUILD_ASSERT(DT_INST_NODE_HAS_PROP(0, sfdp_bfp),
    	     "jedec,spi-nor sfdp-bfp required for devicetree SFDP");
    static const __aligned(4) uint8_t bfp_data_0[] = DT_INST_PROP(0, sfdp_bfp);
    #if DT_INST_NODE_HAS_PROP(0, has_lock)
    /* Currently we only know of devices where the BP bits are present in
     * the first byte of the status register.  Complain if that changes.
    BUILD_ASSERT(DT_INST_PROP(0, has_lock) == (DT_INST_PROP(0, has_lock) & 0xFF),
    	     "Need support for lock clear beyond SR1");
    #define INST_HAS_WP_GPIO(idx) DT_INST_NODE_HAS_PROP(idx, wp_gpios)
    #define INST_WP_GPIO_SPEC(idx)        \
    	IF_ENABLED(INST_HAS_WP_GPIO(idx), (static const struct gpio_dt_spec wp_##idx =             \
    						   GPIO_DT_SPEC_INST_GET(idx, wp_gpios);))
    #define INST_HAS_HOLD_GPIO(idx) DT_INST_NODE_HAS_PROP(idx, hold_gpios)
    #define INST_HOLD_GPIO_SPEC(idx)        \
    	IF_ENABLED(INST_HAS_HOLD_GPIO(idx), (static const struct gpio_dt_spec hold_##idx =         \
    						     GPIO_DT_SPEC_INST_GET(idx, hold_gpios);))
    INST_WP_GPIO_SPEC(0)
    INST_HOLD_GPIO_SPEC(0)
    static const struct spi_nor_config spi_nor_config_0 = {
    	.spi = SPI_DT_SPEC_INST_GET(0, SPI_WORD_SET(8),
    				    CONFIG_SPI_NOR_CS_WAIT_DELAY),
    	.reset = GPIO_DT_SPEC_INST_GET(0, reset_gpios),
    #if !defined(CONFIG_SPI_NOR_SFDP_RUNTIME)
    	.layout = {
    		.pages_count = LAYOUT_PAGES_COUNT,
    		.pages_size = CONFIG_SPI_NOR_FLASH_LAYOUT_PAGE_SIZE,
    #undef LAYOUT_PAGES_COUNT
    	.flash_size = DT_INST_PROP(0, size) / 8,
    	.jedec_id = DT_INST_PROP(0, jedec_id),
    	.has_lock = DT_INST_PROP(0, has_lock),
    #if defined(CONFIG_SPI_NOR_SFDP_MINIMAL)		\
    	&& DT_INST_NODE_HAS_PROP(0, enter_4byte_addr)
    	.enter_4byte_addr = DT_INST_PROP(0, enter_4byte_addr),
    	.bfp_len = sizeof(bfp_data_0) / 4,
    	.bfp = (const struct jesd216_bfp *)bfp_data_0,
    #if DT_INST_NODE_HAS_PROP(0, wp_gpios)
    	.wp = &wp_0,
    #if DT_INST_NODE_HAS_PROP(0, hold_gpios)
    	.hold = &hold_0,
    static struct spi_nor_data spi_nor_data_0;
    PM_DEVICE_DT_INST_DEFINE(0, spi_nor_pm_control);
    DEVICE_DT_INST_DEFINE(0, &spi_nor_init, PM_DEVICE_DT_INST_GET(0),
    		 &spi_nor_data_0, &spi_nor_config_0,
    		 POST_KERNEL, CONFIG_SPI_NOR_INIT_PRIORITY,
    		 &spi_nor_api);
    Kind regards
    Riccardo
  • Hi Riccardo,
    I see. The approach your going for seems right/possible to implement your own custom solution for power power management. I can't quite see why it shouldn't work given that you design the solution so that it handles the typical edge cases for your product.
    Let me know if your testing results in something different,
    Andreas
