Timeout exit from the boot loader
I am developing an application that uses NCS2.8.0.
For FW updates, the nRF52833 USB ACM bootloader is enabled.
However, there are some problem.
My device has a battery but no reset button, so the application cannot start unless I reset it with mcumgr.
Since we do not want to unnecessarily expose the bootloader to users, bootloader startup cannot be used at any time.
The bootloader timeout seems to only be effective if the bootloader always starts after a reset.
CONFIG_BOOT_SERIAL_WAIT_FOR_DFU=y
CONFIG_BOOT_SERIAL_WAIT_FOR_DFU_TIMEOUT=2000
Is it possible to only enable the bootloader timeout?
Or can I exit the bootloader by other means (e.g. user switch)?
  • Thank you for the update. I will report this internally for review and to (re)consider what the expected behavior should be. I think it makes sense to fall back to the application, or at least provide the option to do so, even in cases where serial recovery mode has been entered but then stopped (for example with an inactivity timer). Allowing the WD to be started from the bootloader could also be something to consider.
    EDIT: I see someone already contributed a solution for setting up the WD in the bootloader here: https://github.com/mcu-tools/mcuboot/pull/2566/commits
  • The scenario is where the device is in the hands of an end customer and they have limited ability to troubleshoot or do anything technical. When enough devices are manufactured, all possible error states do occur.
    If the end customer has managed to get the device into a dead-end state (e.g. reset while holding the recovery button, with a USB plugged in, which has been observed to half-trigger the DFU.) it needs to recover in the most sensible way.
    I think being able to enable the watchdog from mcuboot Kconfig flags (and set the timeout) is the most sensible approach that solves requirements for a number of different cases, and also being able to choose whether mcuboot feeds the watchdog, or not. This would allow the device to reset if mcuboot ended up waiting for DFU bytes forever. It also protects against other unforseen future niche bugs with mcuboot.
    EDIT: Noted that a WD update has been created. We'll integrate this once it reaches the nrf SDK.
  • I agree with your points. In case you didn't see it, I updated my previous about WDT setup in bootloader already being supported in upstream mcuboot which should be included in our next SDK release.
