Unused pins on the nRF9161 DK and nRF7002 DK?
Do we have documentation anywhere detailing which pin is used or not in the 9161 DK and 7002 DK? I see docs like this:
Board control
Buttons and LEDs
I selected pin 21 thinking it's unused, but I think it's actually set to the value of a button or something else, so I'm unable to use it. I have this set to I/O expander thinking it would at least free up some pins:
However that does not work at all, as some of those pins still hold the value of the buttons/LED states or something else.
The short of it is I'm trying to set up UART1 on this device (9161 DK), and I've got a device tree like so (trying various pins):
&uart3 {
    status = "disabled";
&spi3 {
    gd25wb256: gd25wb256e3ir@1 {
    status = "okay";
    pinctrl-0 = <&spi3_default>;
    pinctrl-1 = <&spi3_sleep>;
    cs-gpios = <&gpio0 10 GPIO_ACTIVE_LOW>;
    sdhc0: sdhc@0 {
        compatible = "zephyr,sdhc-spi-slot";
        reg = <0>;
        status = "okay";
        mmc {
            compatible = "zephyr,sdmmc-disk";
            status = "okay";
            label = "SDMMC";
        spi-max-frequency = <25000000>;
&pinctrl {
    uart1_default_alt: uart1_default_alt {
        group1 {
            psels = <NRF_PSEL(UART_TX, 0, 26)>,
                <NRF_PSEL(UART_RX, 0, 28)>,
                <NRF_PSEL(UART_RTS, 0, 25)>,
                <NRF_PSEL(UART_CTS, 0, 27)>;
    uart1_sleep_alt: uart1_sleep_alt {
        group1 {
            low-power-enable;
&uart1 {
    status = "okay";
    current-speed = <115200>;
    pinctrl-0 = <&uart1_default_alt>;
    pinctrl-1 = <&uart1_sleep_alt>;
    hw-flow-control;
I am using pins 10-13 for my SD card, pins 30-31 for another peripheral, and those work fine. I've been trying to see what other pins I can use for UART1, tried various pins and I keep getting conflicts.
Is there a comprehensive doc somewhere showing which pins are actually free to use on this board?
  • Hi
    Regarding the  undefined reference to __device_dts_ord_140, I can't say what this is without looking in your build folder. You can do this yourself. Make sure that you check the log from your latest build, as the number may change, and open the file: build\zephyr\include\generated\devicetree_generated.h. In there, you should see a long list of drivers. What does it say next to 140?
    As for your latest issues, where does these errors come from exactly, as the "UART RX stopped unexpectedly" messages aren't anywhere to be found in the nRF Connect SDK, and what do these error codes refer to on your end?
    If you're new to the nRF Connect SDK I strongly recommend checking out the Nordic DevAcademy and nRF Connect SDK courses which gives an easier learning curve to get into the Zephyr RTOS based SDK environment.
    Simon
  • Thanks. I'm not sure what happened, but these errors resolved themselves as we were trying to use different pins. I'll add that in the device tree we were using the wrong pin numbers (P0.00 instead P1.00 for example).
  • I see. Glad you were able to solve this then. Let me know if there are any follow-ups. If not I'll close this case.
