nRF5340 + 7002EK: rpu_validate_comms() check fails for SPI frequency of 16 MHz
Hello DevZone,
I have an nRF5340 devkit along with an nRF7002EK, and I'm looking to upgrade from SDK version 2.6.1 to 2.6.4. However, I'm facing an issue. In version 2.6.2, a new check was introduced in nrf\drivers\wifi\nrf700x\src\qspi\src\rpu_hw_if.c, specifically the rpu_validate_comms() function added to rpu_enable(). This check fails for me when I use an SPI frequency other than 8 MHz for communication with the nRF7002-EK.
To change the frequency I use the following property of nrf700x node in my device tree overlay: spi-max-frequency = <DT_FREQ_M(16)>
Is this intended behavior, or could it be a bug?
Also, I'm attaching a screenshot of the above mentioned failure:
Many thanks!
Ladivin
  • Hello Håkon,
    Again, thanks for your answer.
    This is very interesting. Actually, we've been using the 7002 on 16 MHz for some time now on SDK 2.9 and it seem to work fine even without the PR you shared. But I guess that we might have been just lucky and the RPU wakeup is not reliable on 16 MHz without that PR?
    Also, previously, you mentioned, that each device sharing an SPI bus can have its own frequency. What confuses me is, that when I go to Nordic's device three visual editor, I can see the following hint on SPI's max frequency:
    If I understand it correctly, this implies that the maximal SPI frequency the frequency of the slowest device?
    Ladivin
  • Hi Ladivin,
    There has been work done to improve robustness, by adding retries and "RPU lockup detection" functionality that was introduced under-the-hood for the wifi ready library, as shown in the STA sample:
    https://github.com/nrfconnect/sdk-nrf/blob/main/samples/wifi/sta/src/main.c#L59
    This could explain why it works more stable in newer versions.
    That sentence is indeed a bit misleading, I will bring this up with the vscode plugin team. The maximum frequency of the slave is one parameter, and the maximum frequency of the master is another. The masters maximum frequency will always be set as the ceiling, then the slave max-freq will be considered next. However, even if a SPIM device is capable of higher frequencies does not automatically mean that it will work. Drive strength and timing parameters must in general not be violated.
    Instances in zephyr can switch the frequency based on each individual sensors max frequency set in device tree.
    What will need to be taken into account is that the overall capacitance and impedance will be a direct component of how many devices are connected to a physical SPI bus. Even if all other sensors are off, there will still be a bit of capacitance in each pad and PCB trace for instance.
    Håkon
