At_commands application
Hello, I want to write an applicatin that gets at_coammnds from the terminal via uart, sends the command to the modem and then sends the respond back via uart.
I have two option to achieve this:
1. adding the functionality to an already existing uart application that I have.
2. using the at_client application.
in both cases,right now I run in the same problem, the code doesn't compile because the nrf_modem.h file isn't found by the compiler.
I see that this file is located at nrfxlib\nrf_modem\include\nrf_modem.h
so it seems that Mr application doesn't compile nrfxlib, but I cant fins what configuration files I need to add to my prjconf file in order for it to compile.
thanks in advance,
shlomo
