osdp control_panel example not work with sdk V2.8.0
I used the nRF52840 board with SDK v2.8.0.
When we tried to build this example code, we encountered the following error:
v2.8.0/zephyr/include/zephyr/device.h:92:41: error: '__device_dts_ord_DT_CHOSEN_zephyr_osdp_uart_ORD' undeclared (first use in this function)
92 | #define DEVICE_NAME_GET(dev_id) _CONCAT(__device_, dev_id)
    Sorry by mistake *** Booting nRF Connect SDK v2.5.1 *** pest in this file.
    I'm sorry, I don't understand this. Could you expand upon what is causing this?
    Andreas
    Below is the new log for the OSDP,please check that we receive the card data without encryption.
    [00:00:00.249,603] <inf> osdp: OSDP init okay!
    17:03:26.434 -> *** Booting nRF Connect SDK v2.8.0-a2386bfc8401 ***
    17:03:26.434 -> *** Using Zephyr OS v3.7.99-0bc3393fb112 ***
    17:03:26.933 -> [00:00:00.500,213] <dbg> osdp: cp_send_command: bytes sent
    17:03:26.933 -> [00:00:00.500,274] <dbg> osdp: osdp_dump: ⸮k
    17:03:26.933 ->                                ff 53 7e 09 00 05 61 00  cf 94                   |.S~...a. ..
    17:03:26.966 -> [00:00:00.550,384] <dbg> osdp: cp_process_reply: bytes received
    17:03:26.966 -> [00:00:00.550,415] <dbg> osdp: osdp_dump: ⸮k
    17:03:26.966 ->                                ff 53 fe 14 00 05 45 00  06 8e 01 01 b2 54 80 29 |.S....E. .....T.)
    17:03:26.966 ->                                05 51 00 0a db                                   |.Q...
    17:03:26.999 -> [00:00:00.550,415] <dbg> osdp: cp_decode_response: CMD(61) REPLY(45)
    17:03:26.999 -> [00:00:00.650,634] <dbg> osdp: cp_send_command: bytes sent
    17:03:26.999 -> [00:00:00.650,665] <dbg> osdp: osdp_dump: ⸮k
    17:03:26.999 ->                                ff 53 7e 09 00 06 62 00  cc 98                   |.S~...b. ..
    17:03:27.032 -> [00:00:00.700,805] <dbg> osdp: cp_process_reply: bytes received
    17:03:27.032 -> [00:00:00.700,836] <dbg> osdp: osdp_dump: ⸮k
    17:03:27.032 ->                                ff 53 fe 35 00 06 46 01  00 00 02 00 00 03 01 00 |.S.5..F. ........
    17:03:27.032 ->                                04 04 01 05 02 01 06 00  00 07 00 00 08 01 00 09 |........ ........
    17:03:27.065 ->                                01 01 0a                                         |...
    17:03:27.065 -> [00:00:00.750,946] <dbg> osdp: cp_process_reply: bytes received
    17:03:27.099 -> [00:00:00.750,976] <dbg> osdp: osdp_dump: ⸮k
    17:03:27.099 ->                                ff 53 fe 35 00 06 46 01  00 00 02 00 00 03 01 00 |.S.5..F. ........
    17:03:27.099 ->                                04 04 01 05 02 01 06 00  00 07 00 00 08 01 00 09 |........ ........
    17:03:27.099 ->                                01 01 0a 92 03 0b 92 03  0c 00 00 0e 00 00 0f 00 |........ ........
    17:03:27.132 ->                                00 10 01 00 09 b3                                |......
    17:03:27.132 -> [00:00:00.751,007] <dbg> osdp: cp_decode_response: CMD(62) REPLY(46)
    17:03:27.132 -> [00:00:00.901,428] <dbg> osdp: cp_send_command: bytes sent
    17:03:27.132 -> [00:00:00.901,458] <dbg> osdp: osdp_dump: ⸮k
    17:03:27.132 ->                                ff 53 7e 13 00 0f 03 11  01 76 1d f7 7a 36 dd 88 |.S~..... .v..z6..
    17:03:27.165 ->                                e2 43 ba f4                                      |.C..
    17:03:27.597 -> [00:00:01.051,788] <dbg> osdp: cp_process_reply: bytes received
    17:03:27.597 -> [00:00:01.051,818] <dbg> osdp: osdp_dump: ⸮k
    17:03:27.597 ->                                ff 53 fe 2b 00 0f 03 12  01 76 00 06 8e 01 01 54 |.S.+.... .v.....T
    17:03:27.597 ->                                80 29 9e c0 aa fc c7 a5  57 00 ea                |.)...... W..
    17:03:27.631 -> [00:00:01.101,928] <dbg> osdp: cp_process_reply: bytes received
    17:03:27.631 -> [00:00:01.101,959] <dbg> osdp: osdp_dump: ⸮k
    17:03:27.631 ->                                ff 53 fe 2b 00 0f 03 12  01 76 00 06 8e 01 01 54 |.S.+.... .v.....T
    17:03:27.631 ->                                80 29 9e c0 aa fc c7 a5  57 00 ea 62 7b 12 81 a1 |.)...... W..b{...
    17:03:27.631 ->                                43 cf ba e9 57 39 2d 19  45 36 a3 d1             |C...W9-. E6..
    17:03:27.664 -> [00:00:01.103,118] <dbg> osdp: cp_decode_response: CMD(76) REPLY(76)
    17:03:27.664 -> [00:00:01.203,430] <dbg> osdp: cp_send_command: bytes sent
    17:03:27.664 -> [00:00:01.203,460] <dbg> osdp: osdp_dump: ⸮k
    17:03:27.664 ->                                ff 53 7e 1b 00 0d 03 13  01 77 9a dc b8 8d 13 58 |.S~..... .w.....X
    17:03:27.697 ->                                ec 40 24 7f 92 7c bf c2  04 0c 6a 87             |.@$..|.. ..j.
    17:03:27.697 -> [00:00:01.353,759] <dbg> osdp: cp_process_reply: bytes received
    17:03:27.697 -> [00:00:01.353,790] <dbg> osdp: osdp_dump: ⸮k
    17:03:27.697 ->                                ff 53 fe 1b 00 0d 03 14  01 78 4c 51 57 2e 27 b0 |.S...... .xLQW.'.
    17:03:27.697 ->                                8e b9 93 bb 22 25 09 f5                          |...."%..
    17:03:27.730 -> [00:00:01.403,900] <dbg> osdp: cp_process_reply: bytes received
    17:03:27.730 -> [00:00:01.403,930] <dbg> osdp: osdp_dump: ⸮k
    17:03:27.730 ->                                ff 53 fe 1b 00 0d 03 14  01 78 4c 51 57 2e 27 b0 |.S...... .xLQW.'.
    17:03:27.730 ->                                8e b9 93 bb 22 25 09 f5  2f 45 91 ac             |...."%.. /E..
    17:03:27.774 -> [00:00:01.403,961] <dbg> osdp: cp_decode_response: CMD(77) REPLY(78)
    17:03:27.774 -> [00:00:01.454,040] <inf> osdp: SC Active
    17:03:49.097 -> CP PD[0] card read - fmt: 1 len: 26 card_data: [ 0x32 0x40 0x4a 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0xe5 0x58 0x00 0x00 0x21 0x55 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 ]
    17:05:37.030 -> CP PD[0] card read - fmt: 1 len: 26 card_data: [ 0x32 0x40 0x46 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0xe5 0x58 0x00 0x00 0x21 0x55 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 ]
    Have you checked if the sample enables encryption? The documentation only states that OSDP supports encryption, and nothing more.
    Andreas
    can you please suggest how i can check that encryption is enable?
