I am not able to compile any application
Dear Nordic company,
                                    I am not able to compile any of my applications I was able to compile. Yesterday, everything works, but today, it doesn't work. I tried older version of SDK and tollchain, but these changes don't work.
This is bulid configuration for Serial LTE modem example.
I didn't change anything. Is problem inside Visual studio.
Kind regards
Jaroslav Havel
  • No, it does not work.  Whenever I want to copy/paste the output of VS Code compile, the webgui of devzone complains and says something has gone wrong.  I have used Firefox and Chrome, both fail.
    // IMPORTANT: The following data can contain sensitive or confidential information about your environment.
    // If you do not want others to see this information, make sure to remove it before sharing the data.
    Below is the support info.
    // For help and support, visit Nordic Semiconductor's DevZone at   Nordic DevZone .
    "platform": {
    "os": "win32",
    "osVersion": "Windows 10 Pro N",
    "osKernel": "10.0.19045",
    "vscode": "1.101.0",
    "electron": "35.5.1",
    "node": "v22.15.1"
    "system": {
    "date": "2025-06-19T20:08:03.470Z",
    "vscodeRoot": "c:\\Users\\Harley\\AppData\\Local\\Programs\\Microsoft VS Code\\resources\\app",
    "vscodeUptime": "00:11:31",
    "osUptime": "01:23:57",
    "cpu": "AMD Ryzen 5 2600 Six-Core Processor"
    "workspace": {
    "name": "blinky_pwm_A",
    "workspaceFile": null,
    "folders": [
    "c:\\Nordic\\blinky_pwm_A"
    "sdks": [
    "version": "v3.0.2",
    "path": "c:\\ncs\\v3.0.2"
    "version": "v2.9.99",
    "path": "c:\\NCS_Projects\\NCS-Project"
    "version": "v2.9.0",
    "path": "c:\\ncs\\v2.9.0"
    "version": "v2.7.0",
    "path": "c:\\ncs\\v2.7.0"
    "activeBuild": "c:\\Nordic\\blinky_pwm_A\\build_1",
    "apps": [
    "workspace": "c:\\Nordic\\blinky_pwm_A",
    "uri": "c:\\Nordic\\blinky_pwm_A",
    "buildConfigurations": [
    "id": "c:\\Nordic\\blinky_pwm_A\\build",
    "name": "build",
    "boardId": "nrf9151dk/nrf9151/ns",
    "type": "Sysbuild",
    "isChild": false,
    "isStale": false,
    "taskBindings": {
    "build": [],
    "pristineBuild": [],
    "flash": [],
    "eraseAndFlash": []
    "sdk": "c:\\ncs\\v3.0.2",
    "toolchain": "nRF Connect SDK Toolchain v3.0.2"
    "id": "c:\\Nordic\\blinky_pwm_A\\build_1",
    "name": "build_1",
    "type": "Sysbuild",
    "isChild": false,
    "isStale": false,
    "taskBindings": {
    "build": [],
    "flash": [],
    "eraseAndFlash": []
    "toolchains": [
    "version": "3.0.2",
    "path": "c:\\ncs\\toolchains\\0b393f9e1b"
    "version": "2.9.0",
    "path": "c:\\ncs\\toolchains\\b620d30767"
    "version": "2.7.0",
    "path": "c:\\ncs\\toolchains\\ce3b5ff664"
    "version": "2.6.0",
    "path": "c:\\ncs\\toolchains\\cf2149caf2"
    "version": "2.5.2",
    "path": "c:\\ncs\\toolchains\\c57af46cb7"
    "version": "0.16.8",
    "path": "c:\\Users\\Harley\\zephyr-sdk-0.16.8"
    "connectedDevices": [
    "serialNumber": "001051259329"
    "tools": {
    "C:\\ncs\\toolchains\\0b393f9e1b\\opt\\zephyr-sdk\\arm-zephyr-eabi\\bin\\arm-zephyr-eabi-gcc.exe": "0.17.0",
    "C:\\Program Files\\SEGGER\\JLink\\JLink.exe": "8.42",
    "C:\\Program Files\\Nordic Semiconductor\\nrf-command-line-tools\\bin\\nrfjprog.exe": "10.24.2",
    "C:\\Nordic_tools\\nrfutil.exe": "7.7.1",
    "C:\\ncs\\toolchains\\0b393f9e1b\\cmake": "3.21.0",
    "C:\\ncs\\toolchains\\0b393f9e1b\\opt\\bin\\Scripts\\west.exe": "1.2.0",
    "C:\\ncs\\toolchains\\0b393f9e1b\\opt\\bin\\python.exe": "3.12.4",
    "C:\\ncs\\toolchains\\0b393f9e1b\\opt\\bin\\ninja.exe": "1.10.2",
    "C:\\ncs\\toolchains\\0b393f9e1b\\opt\\bin\\gperf.exe": "3.1",
    "C:\\ncs\\toolchains\\0b393f9e1b\\opt\\bin\\dtc.exe": "1.4.7",
    "C:\\ncs\\toolchains\\0b393f9e1b\\opt\\bin\\gn.exe": "2223",
    "C:\\ncs\\toolchains\\0b393f9e1b\\mingw64\\bin\\git.exe": "2.37.3.windows.1",
    "arm-gdbPath": "c:\\ncs\\toolchains\\0b393f9e1b\\opt\\zephyr-sdk\\arm-zephyr-eabi\\bin\\arm-zephyr-eabi-gdb.exe",
    "riscv-gdbPath": "C:\\ncs\\toolchains\\0b393f9e1b\\opt\\zephyr-sdk\\riscv64-zephyr-elf\\bin\\riscv64-zephyr-elf-gdb.exe"
    "nrfutil": {
    "nrfutil-device": {
    "version": "2.8.8",
    "binPath": "c:\\Users\\Harley\\.vscode\\extensions\\nordic-semiconductor.nrf-connect-2025.5.152-win32-x64\\platform\\nrfutil\\bin\\nrfutil-device",
    "jlinkInfo": {
    "description": "This version of SEGGER J-Link is different from the J-Link version that was used to test nrfutil device commands",
    "expectedVersion": {
    "version": "JLink_V8.18",
    "versionFormat": "string"
    "name": "JlinkARM",
    "version": "JLink_V8.42",
    "nrfutil-sdk-manager": {
    "version": "1.3.0",
    "binPath": "c:\\Users\\Harley\\.vscode\\extensions\\nordic-semiconductor.nrf-connect-2025.5.152-win32-x64\\platform\\nrfutil\\bin\\nrfutil-sdk-manager"
    "environment": {
    "westEnv": {
    "HOME": "C:\\Users\\Harley",
    "HOMEDRIVE": "C:",
    "HOMEPATH": "\\Users\\Harley",
    "PATH": "C:\\ncs\\toolchains\\0b393f9e1b;C:\\ncs\\toolchains\\0b393f9e1b\\mingw64\\bin;C:\\ncs\\toolchains\\0b393f9e1b\\bin;C:\\ncs\\toolchains\\0b393f9e1b\\opt\\bin;C:\\ncs\\toolchains\\0b393f9e1b\\opt\\bin\\Scripts;C:\\ncs\\toolchains\\0b393f9e1b\\opt\\nanopb\\generator-bin;C:\\ncs\\toolchains\\0b393f9e1b\\opt\\zephyr-sdk\\arm-zephyr-eabi\\bin;C:\\ncs\\toolchains\\0b393f9e1b\\opt\\zephyr-sdk\\riscv64-zephyr-elf\\bin;c:\\Users\\Harley\\.vscode\\extensions\\nordic-semiconductor.nrf-connect-2025.5.152-win32-x64\\platform\\nrfutil\\lib\\nrfutil-sdk-manager;C:\\Python311\\Scripts\\;C:\\Python311\\;C:\\Program Files (x86)\\Common Files\\Oracle\\Java\\java8path;C:\\Program Files (x86)\\Common Files\\Oracle\\Java\\javapath;C:\\Program Files\\Nordic Semiconductor;C:\\Program Files (x86)\\STMicroelectronics\\st_toolset\\asm;C:\\Windows\\system32;C:\\Windows;C:\\Windows\\System32\\Wbem;\"C:\\Windows\\System32\\WindowsPowerShell\\v1.0\\;C:\\Python312\\Scripts\";C:\\Windows\\System32\\OpenSSH\\;C:\\Nordic_tools;C:\\CooCox\\CoIDE_V2Beta\\bin;C:\\Program Files\\nodejs\\;C:\\CooCox\\CoIDE_V2Beta\\gcc\\bin;C:\\WINDOWS\\system32;C:\\WINDOWS;C:\\WINDOWS\\System32\\Wbem;C:\\WINDOWS\\System32\\WindowsPowerShell\\v1.0\\;C:\\WINDOWS\\System32\\OpenSSH\\;C:\\Program Files (x86)\\Mercurial;C:\\Program Files\\Mercurial\\;C:\\Program Files\\Mu\\bin;C:\\Program Files\\Microchip\\xc8\\v2.31\\bin;C:\\Program Files (x86)\\AOMEI\\AOMEI Backupper\\6.7.0;C:\\Program Files (x86)\\STMicroelectronics\\STM32 ST-LINK Utility\\ST-LINK Utility;C:\\Program Files\\Nordic Semiconductor\\nrf-command-line-tools\\bin\\;C:\\Users\\Harley\\AppData\\Roaming\\Microsoft\\Windows\\Start Menu\\Programs\\Python 3.12;c:\\ffmpeg\\bin;C:\\Program Files\\dotnet\\;C:\\Program Files\\Go\\bin;C:\\Program Files\\PuTTY\\;C:\\Program Files\\Calibre2\\;C:\\Program Files\\WinGet\\Links;C:\\ProgramData\\chocolatey\\bin;C:\\Program Files\\CMake\\bin;C:\\Program Files\\Git\\cmd;C:\\Program Files (x86)\\Arm GNU Toolchain arm-none-eabi\\13.3 rel1\\bin;C:\\Users\\Harley\\AppData\\Local\\Programs\\Python\\Python313\\Scripts\\;C:\\Users\\Harley\\AppData\\Local\\Programs\\Python\\Python313\\;c:\\bin\\ffmpeg;C:\\Users\\Harley\\AppData\\Local\\Microsoft\\WindowsApps.;C:\\Users\\Harley\\go\\bin;C:\\Users\\Harley\\AppData\\Local\\GitHubDesktop\\bin;C:\\Users\\Harley\\AppData\\Local\\Programs\\Microsoft VS Code\\bin",
    "ZEPHYR_BASE": "c:\\ncs\\v3.0.2\\zephyr",
    "ZEPHYR_SDK_INSTALL_DIR": "C:\\ncs\\toolchains\\0b393f9e1b\\opt\\zephyr-sdk",
    "PYTHONPATH": "C:\\ncs\\toolchains\\0b393f9e1b\\opt\\bin;C:\\ncs\\toolchains\\0b393f9e1b\\opt\\bin\\Lib;C:\\ncs\\toolchains\\0b393f9e1b\\opt\\bin\\Lib\\site-packages"
    "inherited": {
    "HOMEDRIVE": "C:",
    "Path": "C:\\Python311\\Scripts\\;C:\\Python311\\;C:\\Program Files (x86)\\Common Files\\Oracle\\Java\\java8path;C:\\Program Files (x86)\\Common Files\\Oracle\\Java\\javapath;C:\\Program Files\\Nordic Semiconductor;C:\\Program Files (x86)\\STMicroelectronics\\st_toolset\\asm;C:\\Windows\\system32;C:\\Windows;C:\\Windows\\System32\\Wbem;\"C:\\Windows\\System32\\WindowsPowerShell\\v1.0\\;C:\\Python312\\Scripts\";C:\\Windows\\System32\\OpenSSH\\;C:\\Nordic_tools;C:\\CooCox\\CoIDE_V2Beta\\bin;C:\\Program Files\\nodejs\\;C:\\CooCox\\CoIDE_V2Beta\\gcc\\bin;C:\\WINDOWS\\system32;C:\\WINDOWS;C:\\WINDOWS\\System32\\Wbem;C:\\WINDOWS\\System32\\WindowsPowerShell\\v1.0\\;C:\\WINDOWS\\System32\\OpenSSH\\;C:\\Program Files (x86)\\Mercurial;C:\\Program Files\\Mercurial\\;C:\\Program Files\\Mu\\bin;C:\\Program Files\\Microchip\\xc8\\v2.31\\bin;C:\\Program Files (x86)\\AOMEI\\AOMEI Backupper\\6.7.0;C:\\Program Files (x86)\\STMicroelectronics\\STM32 ST-LINK Utility\\ST-LINK Utility;C:\\Program Files\\Nordic Semiconductor\\nrf-command-line-tools\\bin\\;C:\\Users\\Harley\\AppData\\Roaming\\Microsoft\\Windows\\Start Menu\\Programs\\Python 3.12;c:\\ffmpeg\\bin;C:\\Program Files\\dotnet\\;C:\\Program Files\\Go\\bin;C:\\Program Files\\PuTTY\\;C:\\Program Files\\Calibre2\\;C:\\Program Files\\WinGet\\Links;C:\\ProgramData\\chocolatey\\bin;C:\\Program Files\\CMake\\bin;C:\\Program Files\\Git\\cmd;C:\\Program Files (x86)\\Arm GNU Toolchain arm-none-eabi\\13.3 rel1\\bin;C:\\Users\\Harley\\AppData\\Local\\Programs\\Python\\Python313\\Scripts\\;C:\\Users\\Harley\\AppData\\Local\\Programs\\Python\\Python313\\;c:\\bin\\ffmpeg;C:\\Users\\Harley\\AppData\\Local\\Microsoft\\WindowsApps.;C:\\Users\\Harley\\go\\bin;C:\\Users\\Harley\\AppData\\Local\\GitHubDesktop\\bin;C:\\Users\\Harley\\AppData\\Local\\Programs\\Microsoft VS Code\\bin",
    "PATH": "C:\\Python311\\Scripts\\;C:\\Python311\\;C:\\Program Files (x86)\\Common Files\\Oracle\\Java\\java8path;C:\\Program Files (x86)\\Common Files\\Oracle\\Java\\javapath;C:\\Program Files\\Nordic Semiconductor;C:\\Program Files (x86)\\STMicroelectronics\\st_toolset\\asm;C:\\Windows\\system32;C:\\Windows;C:\\Windows\\System32\\Wbem;\"C:\\Windows\\System32\\WindowsPowerShell\\v1.0\\;C:\\Python312\\Scripts\";C:\\Windows\\System32\\OpenSSH\\;C:\\Nordic_tools;C:\\CooCox\\CoIDE_V2Beta\\bin;C:\\Program Files\\nodejs\\;C:\\CooCox\\CoIDE_V2Beta\\gcc\\bin;C:\\WINDOWS\\system32;C:\\WINDOWS;C:\\WINDOWS\\System32\\Wbem;C:\\WINDOWS\\System32\\WindowsPowerShell\\v1.0\\;C:\\WINDOWS\\System32\\OpenSSH\\;C:\\Program Files (x86)\\Mercurial;C:\\Program Files\\Mercurial\\;C:\\Program Files\\Mu\\bin;C:\\Program Files\\Microchip\\xc8\\v2.31\\bin;C:\\Program Files (x86)\\AOMEI\\AOMEI Backupper\\6.7.0;C:\\Program Files (x86)\\STMicroelectronics\\STM32 ST-LINK Utility\\ST-LINK Utility;C:\\Program Files\\Nordic Semiconductor\\nrf-command-line-tools\\bin\\;C:\\Users\\Harley\\AppData\\Roaming\\Microsoft\\Windows\\Start Menu\\Programs\\Python 3.12;c:\\ffmpeg\\bin;C:\\Program Files\\dotnet\\;C:\\Program Files\\Go\\bin;C:\\Program Files\\PuTTY\\;C:\\Program Files\\Calibre2\\;C:\\Program Files\\WinGet\\Links;C:\\ProgramData\\chocolatey\\bin;C:\\Program Files\\CMake\\bin;C:\\Program Files\\Git\\cmd;C:\\Program Files (x86)\\Arm GNU Toolchain arm-none-eabi\\13.3 rel1\\bin;C:\\Users\\Harley\\AppData\\Local\\Programs\\Python\\Python313\\Scripts\\;C:\\Users\\Harley\\AppData\\Local\\Programs\\Python\\Python313\\;c:\\bin\\ffmpeg;C:\\Users\\Harley\\AppData\\Local\\Microsoft\\WindowsApps.;C:\\Users\\Harley\\go\\bin;C:\\Users\\Harley\\AppData\\Local\\GitHubDesktop\\bin;C:\\Users\\Harley\\AppData\\Local\\Programs\\Microsoft VS Code\\bin"
    "terminal": {
    "defaultProfile": null
    "config": {
    "topdir": "${nrf-connect.sdk:2.6.1}",
    "toolchain": {
    "path": "${nrf-connect.toolchain:2.6.1}"
    "ozonePath": "",
    "applications": [],
    "applicationOptions": {},
    "kconfig": {
    "interface": "guiconfig"
    "west": {
    "env": {
    "$base": "terminal"
    "boardRoots": [],
    "taskBindings": {},
    "buildTerminal": {
    "condensedProgress": true
    "debugging": {
    "flash": true,
    "bindings": {},
    "justMyCode": false
    "flash": {
    "softreset": false,
    "erase": false,
    "recover": false
    "enableTelemetry": true,
    "thirdpartyIntegration": {},
    "toolchainManager": {
    "indexURL": null,
    "installDirectory": null
    "nrfutil": {
    "home": null
    "defaultOpenAction": "ask",
    "terminalProfile": {
    "shell": null
    "welcome": {
    "showOnStartup": false
    "terminalMode": "character"
    "marus25.cortex-debug": {
    "variableUseNaturalFormat": true,
    "liveWatchRefreshRate": "300",
    "armToolchainPath": null,
    "armToolchainPrefix": "arm-none-eabi",
    "gdbPath": null,
    "objdumpPath": null,
    "JLinkGDBServerPath": null,
    "openocdPath": null,
    "pyocdPath": null,
    "PEGDBServerPath": null,
    "stutilPath": null,
    "stlinkPath": null,
    "stm32cubeprogrammer": null,
    "dbgServerLogfile": null
    "extensions": {
    "internal": {
    "version": "2025.5.152",
    "path": "c:\\Users\\Harley\\.vscode\\extensions\\nordic-semiconductor.nrf-connect-2025.5.152-win32-x64",
    "isActive": true
    "version": "2024.9.14",
    "path": "c:\\Users\\Harley\\.vscode\\extensions\\nordic-semiconductor.nrf-terminal-2024.9.14",
    "isActive": true
    "version": "2025.4.22",
    "path": "c:\\Users\\Harley\\.vscode\\extensions\\nordic-semiconductor.nrf-devicetree-2025.4.22",
    "isActive": true
    "version": "2025.4.26",
    "path": "c:\\Users\\Harley\\.vscode\\extensions\\nordic-semiconductor.nrf-kconfig-2025.4.26",
    "isActive": true
    "external": {
    "marus25.cortex-debug": "1.12.1",
    "ms-vscode.cpptools": "1.25.3",
    "ms-vscode.js-debug": "1.100.1",
    "batisteo.vscode-django": "1.15.0",
    "cschlosser.doxdocgen": "1.4.0",
    "DavidAnson.vscode-markdownlint": "0.60.0",
    "donjayamanne.python-environment-manager": "1.2.7",
    "donjayamanne.python-extension-pack": "1.7.0",
    "espressif.esp-idf-extension": "1.10.1",
    "GitHub.vscode-pull-request-github": "0.110.0",
    "jeff-hykin.better-cpp-syntax": "1.27.1",
    "KevinRose.vsc-python-indent": "1.21.0",
    "mcu-debug.debug-tracker-vscode": "0.0.15",
    "mcu-debug.memory-view": "0.0.25",
    "mcu-debug.peripheral-viewer": "1.4.6",
    "mcu-debug.rtos-views": "0.0.7",
    "ms-python.debugpy": "2025.8.0",
    "ms-python.python": "2025.8.0",
    "ms-python.vscode-pylance": "2025.6.1",
    "ms-toolsai.jupyter": "2025.5.0",
    "ms-toolsai.jupyter-keymap": "1.1.2",
    "ms-toolsai.jupyter-renderers": "1.1.0",
    "ms-toolsai.vscode-jupyter-cell-tags": "0.1.9",
    "ms-toolsai.vscode-jupyter-slideshow": "0.1.6",
    "ms-vscode-remote.remote-containers": "0.417.0",
    "ms-vscode-remote.remote-ssh": "0.120.0",
    "ms-vscode-remote.remote-ssh-edit": "0.87.0",
    "ms-vscode-remote.remote-wsl": "0.99.0",
    "ms-vscode.cmake-tools": "1.20.53",
    "ms-vscode.cpptools-extension-pack": "1.3.1",
    "ms-vscode.makefile-tools": "0.12.17",
    "ms-vscode.powershell": "2025.0.0",
    "ms-vscode.remote-explorer": "0.5.0",
    "ms-vscode.vscode-serial-monitor": "0.13.1",
    "njpwerner.autodocstring": "0.6.1",
    "paulober.pico-w-go": "4.2.2",
    "platformio.platformio-ide": "3.3.4",
    "Pycom.pymakr": "2.22.5",
    "raspberry-pi.raspberry-pi-pico": "0.17.6",
    "sr-team.cmake-tools-build-wrapper": "0.0.4",
    "twxs.cmake": "0.0.17",
    "VisualStudioExptTeam.intellicode-api-usage-examples": "0.2.9",
    "VisualStudioExptTeam.vscodeintellicode": "1.3.2",
    "wholroyd.jinja": "0.0.8"
  • I've now atleast put your support info in codebox here.
    Elfving said:
    Oh that is odd. Could you show me the error you got there?
    mdede439 said:
    The error I get is the same as this ticket was opened for, 'CMAKE_OBJCOPY-NOTFOUND' is not recognized as an internal or external command
    I was btw thinking of what error the website gave you. You not being able to create a devzone ticket is a more limiting problem I would say - it would best to get that solved first.
    I would assume atleast that a pastebin like this should work: https://pastebin.com/, just give me the resulting link.
    Elfving
