SoftDevice with Zephyr : Scanning extended advertisement packets crash the application
Context
We are working on a project that implies advertising and scanning extended advertised packets.
details :
  • NRF52840
  • Zephyr SDK 17.0
  • Zephyr 4.0.99
  • NRF SDK v3.0.0-preview1
Issue description
Our application freeze after a few seconds of scanning. The logs show that the bt hci driver generates a large number of BT_HCI_EVT_LE_EXT_ADVERTISING_REPORT (0x0d) events (the number of events before the crash is not constant) and then we get an error, either mpsl_init: MPSL ASSERT: 112, 1984, or bt_sdc_hci_driver: SoftDevice Controller ASSERT: 50. Both cases it leads to an OS Hard fault. We are working in an office with a lot of devices advertising, so we tried to put the device in a Faraday box and observed that the bug happens immediately when we open the box and not before.
Theory
We think this might be a configuration issue and we spent some time trying to play with different buffer sizes but no relevant results.
More contexts:
BLE related configuration :
# Bluetooth Configuration
CONFIG_BT=y
CONFIG_BT_PERIPHERAL=y
CONFIG_BT_CTLR=n
CONFIG_BT_EXT_ADV=y
CONFIG_BT_EXT_ADV_MAX_ADV_SET=2
CONFIG_BT_BROADCASTER=y
CONFIG_BT_CTLR=y
CONFIG_BT_CTLR_ADV_EXT=y
CONFIG_BT_HCI=y
CONFIG_BT_LL_SOFTDEVICE=y
CONFIG_BT_CTLR_ADV_DATA_CHAIN=n
CONFIG_BT_CTLR_ADV_DATA_LEN_MAX=1500
CONFIG_BT_OBSERVER=y
Scan enable function (return 0, and bt_enable(NULL) has returned 0 before that)
static int ble_scan_start()
    struct bt_le_scan_param scan_param = {
        .type = BT_HCI_LE_SCAN_PASSIVE,
        .options = BT_LE_SCAN_OPT_NONE,
        .interval = 37 / 0.625,
        .window = 25 / 0.625,
    int err = bt_le_scan_start(&scan_param, scan_cb);
    return r;
Our scan cb is empty, proving that the issue do directly come from the application but from on of the lower layer.
Captured logs:
  • Great, thank you! That seems to have resolved the issue. Setting CONFIG_COUNTER=n appears to prevent the SoftDevice from asserting in our application. And yes, in general, just enabling CONFIG_COUNTER=y in the Bluetooth Central sample causes the SoftDevice to assert.
    It might be beneficial to include a build-time warning or error when this configuration combination is detected, to help avoid similar issues in the future.
