DFU OTA suddenly fails on "non secure" bootloaders but works on "secure" bootloaders.
Suddenly DFU OTA fails most of the time while trying to update units with code & "not secure" bootloader that has been working for years. The FW upload stops at 2% to 8% but if i restart my phone sometimes it reaches 15% and on happy days I can update the unit after rebooting the phone.
With the same DFU app DFU update works well with another unit with "secure" bootloader.
I am NOT trying to update a unit with "not secure" bootloader with code made for units with "secure bootloader" and vice versa.
What can suddenly be the problem?
Phone: Samsung Galaxy S21 Ultra 5G
Android version: 14
DFU app version: 2.9.0 (build 24123065)
  • In this log file, The app says that 11% of the FW was uploaded.
    nRF Connect, 2025-04-02
    Dfu_V2.0 (F5:9A:55:96:A5:6B)
    D 09:55:04.233 [Broadcast] Action received: android.bluetooth.device.action.ACL_CONNECTED
    V 09:55:04.529 Connecting to F5:9A:55:96:A5:6B...
    D 09:55:04.530 gatt = device.connectGatt(autoConnect = false, TRANSPORT_LE, preferred PHY = LE 1M)
    D 09:55:04.548 [Callback] Connection state changed with status: 0 and new state: CONNECTED (2)
    I 09:55:04.548 Connected to F5:9A:55:96:A5:6B
    V 09:55:04.550 Discovering services...
    D 09:55:04.550 gatt.discoverServices()
    I 09:55:04.660 Connection parameters updated (interval: 30.0ms, latency: 0, timeout: 4000ms)
    I 09:55:04.908 Connection parameters updated (interval: 7.5ms, latency: 0, timeout: 5000ms)
    D 09:55:05.052 [Callback] Services discovered with status: 0
    I 09:55:05.052 Services discovered
    V 09:55:05.059 Generic Access (0x1800)
    - Device Name [R W] (0x2A00)
    - Appearance [R] (0x2A01)
    - Peripheral Preferred Connection Parameters [R] (0x2A04)
    Generic Attribute (0x1801)
    - Service Changed [I] (0x2A05)
       Client Characteristic Configuration (0x2902)
    Device Firmware Update Service (00001530-1212-efde-1523-785feabcd123)
    - DFU Packet [WNR] (00001532-1212-efde-1523-785feabcd123)
    - DFU Control Point [N W] (00001531-1212-efde-1523-785feabcd123)
    - DFU Version [R] (00001534-1212-efde-1523-785feabcd123)
    D 09:55:05.059 gatt.setCharacteristicNotification(00002a05-0000-1000-8000-00805f9b34fb, true)
    I 09:55:05.136 Connection parameters updated (interval: 30.0ms, latency: 0, timeout: 4000ms)
    I 09:55:05.624 Connection parameters updated (interval: 30.0ms, latency: 0, timeout: 4000ms)
    I 09:55:07.110 Connection parameters updated (interval: 15.0ms, latency: 0, timeout: 5000ms)
    D 09:55:13.093 [Callback] Connection state changed with status: 8 and new state: DISCONNECTED (0)
    E 09:55:13.093 Error 8 (0x8): GATT CONN TIMEOUT
    I 09:55:13.093 Disconnected
    D 09:55:13.128 [Broadcast] Action received: android.bluetooth.device.action.ACL_DISCONNECTED
  • Is it possible to see if the app tries to send "Large MTU" or "Small MTU"?
  • As I said below, when you start DFU and the phone is reconnecting to the device in DFU mode nRF Connect will open a second tab (it detects it as a new connection, as the MAC is different). Please switch back to the previous tab where you had the DFU graph, and when DFU fails you'll see logs with entries starting with [DFU]. The above one doesn't say much besides the timeout.
  • I just realized, that you may be doing DFU from nRF DFU but trying to collect logs in nRF Connect.
    There are 2 options that you may do:
    1. Just do the DFU in nRF Connect - when you connect you your device you'll see a DFU button in the top right corner. Please tap it, select Distribution Packet (ZIP), select the file and you should see the DFU logs in nRF Connect.
    2. When you're using nRF DFU app, it is logging to nRF Logger (if you have it installed). You'd have to open nRF Logger after the DFU fails, open the menu on the left, select DFU app to see logs from that app and select the most recent log session.
  • Yes, you are correct. I have tried to DFu as I have always done before using nRF DFU and recently collecting logs in nRF Connect.
    Now I have got a log using nRF Connect, it still fails but perhaps gives more info then before.
    Log file below
    V 11:22:16.411 Connecting to F5:9A:55:96:A5:6B...
    D 11:22:16.411 gatt = device.connectGatt(autoConnect = false, TRANSPORT_LE, preferred PHY = LE 1M)
    D 11:22:16.675 [Callback] Connection state changed with status: 0 and new state: CONNECTED (2)
    I 11:22:16.675 Connected to F5:9A:55:96:A5:6B
    V 11:22:16.687 Discovering services...
    D 11:22:16.687 gatt.discoverServices()
    D 11:22:16.893 [Broadcast] Action received: android.bluetooth.device.action.ACL_CONNECTED
    I 11:22:17.181 Connection parameters updated (interval: 30.0ms, latency: 0, timeout: 4000ms)
    I 11:22:17.430 Connection parameters updated (interval: 7.5ms, latency: 0, timeout: 5000ms)
    D 11:22:17.573 [Callback] Services discovered with status: 0
    I 11:22:17.573 Services discovered
    V 11:22:17.580 Generic Access (0x1800)
    D 11:22:17.581 gatt.setCharacteristicNotification(00002a05-0000-1000-8000-00805f9b34fb, true)
    I 11:22:17.646 Connection parameters updated (interval: 30.0ms, latency: 0, timeout: 4000ms)
    I 11:22:18.167 Connection parameters updated (interval: 30.0ms, latency: 0, timeout: 4000ms)
    V 11:22:29.130 [DFU] DFU service started
    V 11:22:29.130 [DFU] Opening file...
    I 11:22:29.141 [DFU] Firmware file opened successfully
    V 11:22:29.141 [DFU] Connecting to DFU target...
    D 11:22:29.141 [DFU] gatt = device.connectGatt(autoConnect = false, TRANSPORT_LE, preferredPhy = LE_1M | LE_2M)
    I 11:22:29.154 [DFU] Connected to F5:9A:55:96:A5:6B
    V 11:22:29.154 [DFU] Discovering services...
    D 11:22:29.154 [DFU] gatt.discoverServices()
    I 11:22:29.156 [DFU] Services discovered
    V 11:22:29.181 [DFU] Reading DFU version number...
    D 11:22:29.181 [DFU] gatt.readCharacteristic(00001534-1212-efde-1523-785feabcd123)
    I 11:22:29.234 [DFU] Read Response received from 00001534-1212-efde-1523-785feabcd123, value (0x): 08-00
    A 11:22:29.234 [DFU] Version number read: 0.8
    V 11:22:29.234 [DFU] Requesting new MTU...
    D 11:22:29.234 [DFU] gatt.requestMtu(517)
    I 11:22:29.295 [DFU] MTU changed to: 23
    V 11:22:29.295 [DFU] Enabling notifications for 00001531-1212-efde-1523-785feabcd123
    D 11:22:29.295 [DFU] gatt.setCharacteristicNotification(00001531-1212-efde-1523-785feabcd123, true)
    D 11:22:29.295 [DFU] gatt.writeDescriptor(00002902-0000-1000-8000-00805f9b34fb, value=0x01-00)
    I 11:22:29.354 [DFU] Data written to descr.00001531-1212-efde-1523-785feabcd123
    V 11:22:29.354 [DFU] Notifications enabled for 00001531-1212-efde-1523-785feabcd123
    A 11:22:29.354 [DFU] Notifications enabled
    V 11:22:29.354 [DFU] Writing to characteristic 00001531-1212-efde-1523-785feabcd123, value (0x): 01-04
    D 11:22:29.354 [DFU] gatt.writeCharacteristic(00001531-1212-efde-1523-785feabcd123, value=0x01-04, WRITE_TYPE_DEFAULT)
    I 11:22:29.414 [DFU] Data written to 00001531-1212-efde-1523-785feabcd123
    A 11:22:29.414 [DFU] DFU Start sent (Op Code = 1, Upload Mode = 4)
    V 11:22:29.414 [DFU] Writing to characteristic 00001532-1212-efde-1523-785feabcd123, value (0x): 00-00-00-00-00-00-00-00-C0-7F-00-00
    D 11:22:29.414 [DFU] gatt.writeCharacteristic(00001532-1212-efde-1523-785feabcd123, value=00-00-00-00-00-00-00-00-C0-7F-00-00, WRITE_TYPE_NO_RESPONSE)
    I 11:22:29.415 [DFU] Data written to 00001532-1212-efde-1523-785feabcd123
    A 11:22:29.415 [DFU] Firmware image size sent (0b, 0b, 32704b)
    I 11:22:31.065 [DFU] Notification received from 00001531-1212-efde-1523-785feabcd123, value (0x): 10-01-01
    A 11:22:31.066 [DFU] Response received (Op Code = 1 Status = 1)
    V 11:22:31.066 [DFU] Requesting high connection priority...
    D 11:22:31.066 [DFU] gatt.requestConnectionPriority(HIGH)
    A 11:22:31.070 [DFU] Writing Initialize DFU Parameters...
    V 11:22:31.070 [DFU] Writing to characteristic 00001531-1212-efde-1523-785feabcd123, value (0x): 02-00
    D 11:22:31.070 [DFU] gatt.writeCharacteristic(00001531-1212-efde-1523-785feabcd123, value=0x02-00, WRITE_TYPE_DEFAULT)
    I 11:22:31.155 [DFU] Data written to 00001531-1212-efde-1523-785feabcd123
    V 11:22:31.156 [DFU] Writing to characteristic 00001532-1212-efde-1523-785feabcd123 value (0x): FF-FF-FF-FF-FF-FF-FF-FF-01-00-FE-FF-4B-5E
    D 11:22:31.156 [DFU] gatt.writeCharacteristic(00001532-1212-efde-1523-785feabcd123, value=0xFF-FF-FF-FF-FF-FF-FF-FF-01-00-FE-FF-4B-5E, WRITE_TYPE_NO_RESPONSE)
    I 11:22:31.159 [DFU] Data written to 00001532-1212-efde-1523-785feabcd123
    V 11:22:31.159 [DFU] Writing to characteristic 00001531-1212-efde-1523-785feabcd123, value (0x): 02-01
    D 11:22:31.159 [DFU] gatt.writeCharacteristic(00001531-1212-efde-1523-785feabcd123, value=0x02-01, WRITE_TYPE_DEFAULT)
    I 11:22:31.215 [DFU] Data written to 00001531-1212-efde-1523-785feabcd123
    A 11:22:31.215 [DFU] Initialize DFU Parameters completed
    I 11:22:31.215 [DFU] Notification received from 00001531-1212-efde-1523-785feabcd123, value (0x): 10-02-01
    A 11:22:31.215 [DFU] Response received (Op Code = 2, Status = 1)
    V 11:22:31.215 [DFU] Writing to characteristic 00001531-1212-efde-1523-785feabcd123, value (0x): 03
    D 11:22:31.215 [DFU] gatt.writeCharacteristic(00001531-1212-efde-1523-785feabcd123, value=0x03, WRITE_TYPE_DEFAULT)
    I 11:22:31.274 [DFU] Data written to 00001531-1212-efde-1523-785feabcd123
    A 11:22:31.275 [DFU] Receive Firmware Image request sent
    A 11:22:31.290 [DFU] Uploading firmware...
    V 11:22:31.290 [DFU] Sending firmware to characteristic 00001532-1212-efde-1523-785feabcd123...
    I 11:22:31.318 Connection parameters updated (interval: 15.0ms, latency: 0, timeout: 5000ms)
    I 11:22:31.363 [DFU] Notification received from 00001531-1212-efde-1523-785feabcd123, value (0x): 10-03-06
    I 11:22:31.363 [DFU] Data written to 00001532-1212-efde-1523-785feabcd123
    A 11:22:31.363 [DFU] Response received (Op Code = 3, Status = 6)
    E 11:22:31.364 [DFU] Remote DFU error: OPERATION FAILED
    V 11:22:31.364 [DFU] Writing to characteristic 00001531-1212-efde-1523-785feabcd123, value (0x): 06
    D 11:22:31.364 [DFU] gatt.writeCharacteristic(00001531-1212-efde-1523-785feabcd123, value=0x06, WRITE_TYPE_DEFAULT)
    D 11:22:36.452 [Callback] Connection state changed with status: 8 and new state: DISCONNECTED (0)
    E 11:22:36.453 Error 8 (0x8): GATT CONN TIMEOUT
    I 11:22:36.453 Disconnected
    A 11:22:36.461 [DFU] Reset request sent
    D 11:22:36.461 [DFU] gatt.refresh() (hidden)
    D 11:22:36.461 [DFU] gatt.disconnect()
    D 11:22:36.464 [DFU] gatt.close()
    D 11:22:36.468 [DFU] wait(600)
    D 11:22:36.500 [Broadcast] Action received: android.bluetooth.device.action.ACL_DISCONNECTED
    D 11:22:36.501 [DFU] [Broadcast] Action received: android.bluetooth.device.action.ACL_DISCONNECTED
    D 11:22:37.071 gatt.close()
    D 11:22:37.074 wait(200)
    V 11:22:37.274 Connecting to F5:9A:55:96:A5:6B...
    D 11:22:37.274 gatt = device.connectGatt(autoConnect = false, TRANSPORT_LE, preferred PHY = LE 1M)
    D 11:22:47.290 [Callback] Connection state changed with status: 133 and new state: DISCONNECTED (0)
    E 11:22:47.290 Error 133 (0x85): GATT ERROR
    I 11:22:47.290 Disconnected
