CONFIG_CHIP_DFU_OVER_BT_SMP not work
We use NCS2.9.0 and NRF54L15-DK do the matter development, and we use template demo, just enable CONFIG_CHIP_DFU_OVER_BT_SMP in root prj.conf, then we do the ota test:
Matter over thread ota is ok, but smp ota cannot work, here is my andriod nrfconnect app log:
Should I config any other params?
  • This is ok, but cmd build get the same error, I use an older nrf connect for mobile app, and this is the log:
    nRF Connect, 2025-04-03
    No name (CF:FD:17:C2:42:0D)
    V16:54:43.608Connecting to CF:FD:17:C2:42:0D...
    D16:54:43.608gatt = device.connectGatt(autoConnect = false, TRANSPORT_LE, preferred PHY = LE 1M)
    D16:54:43.906[Callback] Connection state changed with status: 0 and new state: CONNECTED (2)
    I16:54:43.906Connected to CF:FD:17:C2:42:0D
    V16:54:43.908Discovering services...
    D16:54:43.908gatt.discoverServices()
    D16:54:43.918[Broadcast] Action received: android.bluetooth.device.action.ACL_CONNECTED
    I16:54:44.239Connection parameters updated (interval: 7.5ms, latency: 0, timeout: 5000ms)
    D16:54:44.495[Callback] Services discovered with status: 0
    I16:54:44.496Services discovered
    V16:54:44.500Generic Attribute (0x1801)
    - Service Changed [I] (0x2A05)
       Client Characteristic Configuration (0x2902)
    Generic Access (0x1800)
    - Device Name [R] (0x2A00)
    - Appearance [R] (0x2A01)
    - Peripheral Preferred Connection Parameters [R] (0x2A04)
    SMP Service (8d53dc1d-1db7-4cd3-868b-8a527460aa84)
    - SMP Characteristic [N WNR] (da2e7828-fbce-4e01-ae9e-261174997c48)
    Unknown Service (0000fff6-0000-1000-8000-00805f9b34fb)
    - Unknown Characteristic [W WNR] (18ee2ef5-263d-4559-959f-4f9c429f9d11)
    - Unknown Characteristic [I] (18ee2ef5-263d-4559-959f-4f9c429f9d12)
    D16:54:44.500gatt.setCharacteristicNotification(00002a05-0000-1000-8000-00805f9b34fb, true)
    D16:54:44.503gatt.setCharacteristicNotification(18ee2ef5-263d-4559-959f-4f9c429f9d12, true)
    I16:54:44.569Connection parameters updated (interval: 30.0ms, latency: 0, timeout: 5000ms)
    I16:54:45.006Connection parameters updated (interval: 45.0ms, latency: 0, timeout: 5000ms)
    V16:54:52.945[McuMgr] Connecting...
    D16:54:52.949[McuMgr] gatt = device.connectGatt(autoConnect = false, TRANSPORT_LE, LE 1M)
    D16:54:52.969[McuMgr] [Callback] Connection state changed with status: 0 and new state: 2 (CONNECTED)
    I16:54:52.972[McuMgr] Connected to CF:FD:17:C2:42:0D
    D16:54:52.974[McuMgr] wait(300)
    V16:54:53.276[McuMgr] Discovering services...
    D16:54:53.285[McuMgr] gatt.discoverServices()
    I16:54:53.298[McuMgr] Services discovered
    V16:54:53.302[McuMgr] Primary service found
    V16:54:53.306[McuMgr] Requesting new MTU...
    D16:54:53.308[McuMgr] gatt.requestMtu(515)
    I16:54:53.383[McuMgr] MTU changed to: 498
    D16:54:53.390[McuMgr] gatt.setCharacteristicNotification(da2e7828-fbce-4e01-ae9e-261174997c48, true)
    V16:54:53.394[McuMgr] Enabling notifications for da2e7828-fbce-4e01-ae9e-261174997c48
    D16:54:53.397[McuMgr] gatt.writeDescriptor(00002902-0000-1000-8000-00805f9b34fb, value=0x01-00)
    I16:54:53.556[McuMgr] Data written to descr. 00002902-0000-1000-8000-00805f9b34fb, value: (0x) 01-00
    I16:54:53.564[McuMgr] Notifications enabled
    V16:54:53.570[McuMgr] Writing characteristic da2e7828-fbce-4e01-ae9e-261174997c48 (WRITE COMMAND)
    D16:54:53.572[McuMgr] gatt.writeCharacteristic(da2e7828-fbce-4e01-ae9e-261174997c48)
    I16:54:53.579[McuMgr] Data written to da2e7828-fbce-4e01-ae9e-261174997c48, value: (0x) 00-00-00-02-00-01-00-00-BF-FF
    A16:54:53.585[McuMgr] "Operation: READ
    Flags: 0
    Length: 2
    Group Id: 1 (IMAGE)
    Sequence Num: 0
    Command Id: 0 (STATE)
    Message: {}" sent
    I16:54:53.653[McuMgr] Notification received from da2e7828-fbce-4e01-ae9e-261174997c48, value: (0x) 01-00-00-F0-00-01-00-00-A2-66-69-6D-61-67-65-73-82-A8-64-73-6C-6F-74-00-67-76-65-72-73-69-6F-6E-65-31-2E-39-2E-30-64-68-61-73-68-58-20-A5-94-EF-0F-44-56-D8-57-A4-04-5D-66-00-F5-B2-BA-AA-FC-76-89-1D-9C-51-3B-A3-A5-4A-39-6C-06-F0-68-68-62-6F-6F-74-61-62-6C-65-F5-67-70-65-6E-64-69-6E-67-F4-69-63-6F-6E-66-69-72-6D-65-64-F5-66-61-63-74-69-76-65-F5-69-70-65-72-6D-61-6E-65-6E-74-F4-A8-64-73-6C-6F-74-01-67-76-65-72-73-69-6F-6E-65-31-2E-30-2E-30-64-68-61-73-68-58-20-50-84-65-C3-81-0A-47-B4-C8-40-B6-78-9C-98-14-1A-C1-81-8F-BE-B4-B1-67-0B-F8-7A-8D-FD-E5-F1-9F-27-68-62-6F-6F-74-61-62-6C-65-F5-67-70-65-6E-64-69-6E-67-F4-69-63-6F-6E-66-69-72-6D-65-64-F4-66-61-63-74-69-76-65-F4-69-70-65-72-6D-61-6E-65-6E-74-F4-6B-73-70-6C-69-74-53-74-61-74-75-73-00
    A16:54:53.664[McuMgr] "{"images":[{"slot":0,"version":"1.9.0","hash":"pZTvD0RW2FekBF1mAPWyuqr8dokdnFE7o6VKOWwG8Gg=","bootable":true,"pending":false,"confirmed":true,"active":true,"permanent":false},{"slot":1,"version":"1.0.0","hash":"UIRlw4EKR7TIQLZ4nJgUGsGBj760sWcL+HqN/eXxnyc=","bootable":true,"pending":false,"confirmed":false,"active":false,"permanent":false}],"splitStatus":0}" received
    V16:54:53.671[McuMgr] Uploading firmware...
    To me, it looks like the version has updated between slot 0 and slot1 here, from 1.0.0 to 1.9.0.
    If the version update worked, what is the problem then?
  • How do you set this version?
    Do you set the version for both network and application core?
  • I just set the version in VERSION file:
    VERSION_MAJOR = 2
    VERSION_MINOR = 3
