Help with TLS Socket Creation on Thingy53 - ENOMEM (Error 23)
I'm working on a Thingy53 project with Zephyr RTOS that requires TLS connections, but I'm encountering persistent "Failed to create TLS socket: 23" errors (ENOMEM - out of memory). I've implemented several memory optimizations and error handling strategies but still face issues with TLS socket creation.
  1. Initial Problem Identification
    • Thingy53 device experiencing ENOMEM errors during TLS socket creation
    • Memory allocation test function using undefined k_malloc_free_get
  2. Configuration Optimization
    • Consolidated duplicate definitions in prj.conf
    • Increased heap memory (CONFIG_HEAP_MEM_POOL_SIZE=180000)
    • Increased mbedTLS heap (CONFIG_MBEDTLS_HEAP_SIZE=80000)
    • Restored GPIO and WiFi management configurations
  3. TLS Cipher Configuration Issues
    • Identified problematic CONFIG_MBEDTLS_SSL_CIPHERSUITES configuration
    • Attempted various syntax fixes (removing quotes, escaping quotes)
    • Ultimately removed the problematic configuration to allow builds to proceed
  4. First Socket Implementation Approach
    • Tried incremental approach: TCP socket → Connect → TLS upgrade
    • Failed with ENOBUFS (error 109) when setting TLS_SEC_TAG_LIST
  5. Second Socket Implementation Approach
    • Created TLS socket directly using IPPROTO_TLS_1_2
    • Set all TLS options before connecting
    • Eliminated socket reconfiguration to allow proper resource allocation
  6. Memory Management Improvements
    • Implemented socket tracking system to prevent resource leaks
    • Added retry mechanism with increasing delays
    • Added specific ENOMEM error handling with resource cleanup
    • Improved TLS configuration sequence (hostname before security tags)
  7. Current Status
    • Despite improvements, still encountering ENOMEM (error 23)
    • Memory allocation test succeeds but TLS socket creation fails
    • Implemented more aggressive resource management with k_yield() and socket tracking
static int create_tls_socket(const char *hostname, struct sockaddr_in *server_addr)
    int sock;
    int ret;
    int retry_count = 0;
    const int retry_delay_ms = 1000;
    /* Check memory status before attempting socket creation */
    check_memory_status("before TLS socket creation");
    /* We'll try a different approach if the previous one keeps failing with ENOMEM */
    while (retry_count < MAX_SOCKET_RETRIES) {
        /* First, ensure any previous socket resources are fully released */
        k_sleep(K_MSEC(retry_delay_ms));
        k_yield();  /* Allow other threads to run and potentially free resources */
        /* Create TLS socket */
        sock = socket(AF_INET, SOCK_STREAM, IPPROTO_TLS_1_2);
        if (sock < 0) {
            if (errno == ENOMEM) {
                LOG_ERR("Failed to create TLS socket: Out of memory (ENOMEM)");
                /* Try to release memory by forcing a garbage collection */
                close_all_sockets();
                retry_count++;
                continue;
            } else {
                LOG_ERR("Failed to create TLS socket: %d", errno);
                retry_count++;
                continue;
        LOG_INF("TLS socket created successfully");
        track_socket(sock);
        /* Set TLS socket options */
        sec_tag_t sec_tag_list[] = {
            CA_CERT_TAG,
        /* Set receive and send timeout to avoid blocking indefinitely */
        struct timeval timeout = {
            .tv_sec = 10,
            .tv_usec = 0,
        ret = setsockopt(sock, SOL_SOCKET, SO_RCVTIMEO, &timeout, sizeof(timeout));
        if (ret < 0) {
            LOG_ERR("Failed to set socket receive timeout: %d", errno);
            close(sock);
            untrack_socket(sock);
            retry_count++;
            continue;
        // [Additional socket option settings omitted for brevity]
        /* All options set successfully */
        LOG_INF("TLS socket configured successfully");
        return sock;
    LOG_ERR("Failed to create TLS socket after %d attempts", MAX_SOCKET_RETRIES);
    return -ENOMEM;
I'm tracking sockets and cleaning them up:
void track_socket(int sock)
// Track socket for potential cleanup
void untrack_socket(int sock)
// Remove socket from tracking
void close_all_sockets(void)
// Close all tracked sockets to free resources
I've made the following memory optimizations in prj.conf:
Increase heap memory pool size
CONFIG_HEAP_MEM_POOL_SIZE=200000
CONFIG_HEAP_MEM_POOL_IGNORE_MIN=y
TLS Configuration
CONFIG_MBEDTLS=y
CONFIG_MBEDTLS_BUILTIN=y
CONFIG_MBEDTLS_ENABLE_HEAP=y
CONFIG_MBEDTLS_HEAP_SIZE=85000
CONFIG_MBEDTLS_SSL_MAX_CONTENT_LEN=1536
Reduce TLS resource usage
CONFIG_NET_SOCKETS_TLS_MAX_CONTEXTS=2
CONFIG_NET_SOCKETS_TLS_MAX_CREDENTIALS=2
CONFIG_NET_CONTEXT_MAX_CONN=4
Are there additional memory optimizations I should be making for TLS on constrained devices like the Thingy53?
Could there be any memory leaks or resource allocation issues that I'm missing in my implementation?
Are there specific mbedTLS configurations I should be adjusting to reduce memory usage further?
Is there a way to debug exactly what's happening during TLS socket creation that's causing the ENOMEM error?
Should I be implementing a different approach for TLS on this device?
  • static int connect_to_server(const char *hostname, const char *port_str, bool use_tls)
        int err;
        int sock;
        int port;
        struct zsock_addrinfo hints = {0};
        struct zsock_addrinfo *result;
        struct zsock_addrinfo *addr;
        struct zsock_pollfd fds;
        int flags;
        int ret;
        bool is_connected = false;
        struct timeval timeout;
        /* Check if WiFi is connected before attempting socket operations */
        if (!context.connected) {
            LOG_ERR("WiFi not connected, cannot create socket");
            return -ENETUNREACH;
        /* Convert port string to integer */
        port = atoi(port_str);
        if (port <= 0 || port > 65535) {
            LOG_ERR("Invalid port number: %s", port_str);
            return -EINVAL;
        /* Clean up any unhealthy sockets before creating a new one */
        cleanup_unhealthy_sockets();
        /* Set up hints for getaddrinfo */
        hints.ai_family = AF_INET;  /* IPv4 only for now */
        hints.ai_socktype = SOCK_STREAM;
        /* Resolve the hostname */
        LOG_INF("Resolving hostname: %s", hostname);
        err = zsock_getaddrinfo(hostname, port_str, &hints, &result);
        if (err) {
            LOG_ERR("Failed to resolve hostname %s: %d", hostname, err);
            return -EHOSTUNREACH;
        /* Try each address until we successfully connect */
        for (addr = result; addr != NULL; addr = addr->ai_next) {
            /* Create socket */
            retry_count = 0;
                sock = zsock_socket(addr->ai_family, addr->ai_socktype, addr->ai_protocol);
                if (sock < 0) {
                    LOG_ERR("Failed to create socket, attempt %d/%d: %d",
                            retry_count + 1, MAX_SOCKET_RETRIES, errno);
                    consecutive_socket_failures++;
                    if (consecutive_socket_failures >= MAX_CONSECUTIVE_FAILURES) {
                        LOG_ERR("Too many consecutive socket failures, forcing cleanup");
                        force_socket_cleanup();
                    retry_count++;
                    k_sleep(K_MSEC(500));  /* Wait before retrying */
                    continue;
                /* Track the socket immediately after creation */
                track_socket(sock);
                /* Set socket options */
                /* Set SO_REUSEADDR option */
                int reuse = 1;
                ret = zsock_setsockopt(sock, SOL_SOCKET, SO_REUSEADDR, &reuse, sizeof(reuse));
                if (ret < 0) {
                    LOG_WRN("Failed to set SO_REUSEADDR: %d", errno);
                    /* Continue anyway, not critical */
                /* Set receive timeout */
                timeout.tv_sec = SOCKET_RECV_TIMEOUT_SEC;
                timeout.tv_usec = 0;
                ret = zsock_setsockopt(sock, SOL_SOCKET, SO_RCVTIMEO, &timeout, sizeof(timeout));
                if (ret < 0) {
                    if (errno == ENOTSUP) {
                        LOG_WRN("Socket receive timeout not supported on this platform");
                    } else {
                        LOG_WRN("Failed to set receive timeout: %d", errno);
                /* Set send timeout */
                timeout.tv_sec = SOCKET_SEND_TIMEOUT_SEC;
                ret = zsock_setsockopt(sock, SOL_SOCKET, SO_SNDTIMEO, &timeout, sizeof(timeout));
                if (ret < 0) {
                        LOG_WRN("Socket send timeout not supported on this platform");
                    } else {
                        LOG_WRN("Failed to set send timeout: %d", errno);
                /* Set up TLS if requested */
                if (use_tls) {
                    ret = setup_tls_credentials();
                    if (ret < 0) {
                        LOG_ERR("Failed to set up TLS credentials: %d", ret);
                        close(sock);
                        zsock_freeaddrinfo(result);
                        return ret;
                    /* Set TLS options */
                    int tls_options = TLS_PEER_VERIFY_REQUIRED;
                    ret = zsock_setsockopt(sock, SOL_TLS, TLS_PEER_VERIFY, &tls_options, sizeof(tls_options));
                    if (ret < 0) {
                        LOG_ERR("Failed to set TLS peer verification: %d", errno);
                        close(sock);
                        return -EIO;
                    /* Set TLS certificate */
                    struct tls_credential cert = {
                        .type = TLS_CREDENTIAL_CA_CERTIFICATE,
                        .tag = CA_CERT_TAG
                    ret = zsock_setsockopt(sock, SOL_TLS, TLS_CREDENTIAL, &cert, sizeof(cert));
                    if (ret < 0) {
                        LOG_ERR("Failed to set TLS certificate: %d", errno);
                        close(sock);
                        return -EIO;
                    LOG_INF("Proceeding with TLS connection");
                /* Connect to server with timeout */
                LOG_INF("Connecting to %s:%s...", hostname, port_str);
                /* Set socket to non-blocking mode for connect with timeout */
                flags = zsock_fcntl(sock, ZSOCK_F_GETFL, 0);
                zsock_fcntl(sock, ZSOCK_F_SETFL, flags | ZSOCK_O_NONBLOCK);
                /* Initiate connection */
                ret = zsock_connect(sock, addr->ai_addr, addr->ai_addrlen);
                if (ret < 0 && errno != EINPROGRESS) {
                    LOG_ERR("Failed to initiate connection: %d", errno);
                    close(sock);
                    retry_count++;
                    continue;
                /* Wait for connection to complete or timeout */
                fds.fd = sock;
                fds.events = ZSOCK_POLLOUT;
                int timeout_ms = use_tls ?
                    TLS_SOCKET_CONNECT_TIMEOUT_SEC * 1000 :
                    SOCKET_CONNECT_TIMEOUT_SEC * 1000;
                ret = zsock_poll(&fds, 1, timeout_ms);
                if (ret <= 0) {
                    if (ret == 0) {
                        LOG_ERR("Connection timed out");
                    } else {
                        LOG_ERR("Poll error: %d", errno);
                    close(sock);
                    retry_count++;
                    continue;
                /* Check if connection was successful */
                if (fds.revents & ZSOCK_POLLOUT) {
                    /* Socket is writable, but we need to check for errors */
                    int err_code;
                    socklen_t err_len = sizeof(err_code);
                    ret = zsock_getsockopt(sock, SOL_SOCKET, SO_ERROR, &err_code, &err_len);
                    if (ret < 0 || err_code != 0) {
                        LOG_ERR("Connection failed with error: %d", err_code);
                        close(sock);
                        retry_count++;
                        continue;
                    /* Connection successful */
                    is_connected = true;
                } else {
                    /* Socket has error condition */
                    LOG_ERR("Connection failed with revents: 0x%x", fds.revents);
                    close(sock);
                    retry_count++;
                    continue;
                /* Set socket back to blocking mode */
                zsock_fcntl(sock, ZSOCK_F_SETFL, flags);
                /* If we got here, we successfully connected */
                if (is_connected) {
                    LOG_INF("Successfully connected to %s:%s", hostname, port_str);
                    consecutive_socket_failures = 0;  /* Reset failure counter on success */
                    return sock;
            /* If we've exhausted all retry attempts for this address, try the next one */
            LOG_WRN("Failed to connect using current address after %d attempts, trying next", MAX_SOCKET_RETRIES);
        /* If we get here, we failed to connect to any address */
        LOG_ERR("Failed to connect to %s:%s after trying all available addresses", hostname, port_str);
        return -ECONNREFUSED;
  • Hi
    I've had to ask about this internally as I have not been able to get anywhere with this I'm afraid. Thank you for you patience. I will get back to you when I hear back from the devs. At the latest/least on Friday with a status update.
    Simon
  • Hi
    I got some input from the developers on this today.
    First off, can you upload logs with CONFIG_NET_SOCKETS_LOG_LEVEL_DBG=y set in your project?
    For the send/recv timeout setting errors we see here, support might be lacking for these but you can enable that in Kconfig with CONFIG_NET_CONTEXT_RCVTIMEO=y
    and CONFIG_NET_CONTEXT_SNDTIMEO=y.
    It might also be helpful for us to see your full config file to review that everything seems as it should be.
    You can also try following the Azure IoT Hub setup/configuration guide and make sure you've added the right modules described there.
    Simon
