SHT4x interface with nRF52840
I am trying to integrate Sensirion SHT40 sensor with nRF52840. I am using the sensor sample app from 2.9.0 SDK. I am building with 2.6.1 SDK with toolchain 2.6.1.  The build is ok, but when the app starts, it just get stuck as I can see in the console as follows.
[00:00:00.003,143] <inf> ieee802154_nrf5: nRF5 802154 radio initialized
[00:00:00.003,173] <dbg> temp_nrf5_mpsl: temp_nrf5_mpsl_init:
[00:00:00.009,490] <inf> fs_nvs: 8 Sectors of 4096 bytes
[00:00:00.
Then I added CONFIG_COAP_CLIENT=y to prj.conf and I get the following.
[00:00:00.[00:00[00:00:00.003,326] <dbg> temp_nrf5_mpsl: temp_nrf5_mpsl_init:
[00:00:00.009,643] <inf> fs_nvs: 8 Sectors of 4096 bytes
[00:00:00.009,643] <inf> fs_nvs: alloc wra: 0, e00
[00:00:00.009,674] <inf> fs_nvs: data wra: 0, 810
*** Booting nRF Connect SDK v3.5.99-ncs1-1 ***
ASSERTION FAIL @ WEST_TOPDIR/zephyr/kernel/thread.c:601
        invalid priority (15); allowed range: 14 to -16
[00:00:00.038,909] <dbg> temp_nrf5_mpsl: temp_nrf5_mpsl_sample_fetch: sample: 96
[00:00:00.038,940] <dbg> temp_nrf5_mpsl: temp_nrf5_mpsl_channel_get: Temperature:24,0
[00:00:00.039,031] <err> os: r0/a1:  0x00000004  r1/a2:  0x00000259  r2/a3:  0x00000009
[00:00:00.039,062] <err> os: r3/a4:  0x20001a40 r12/ip:  0x00000014 r14/lr:  0x00022321
[00:00:00.039,062] <err> os:  xpsr:  0x41000000
[00:00:00.039,093] <err> os: s[ 0]:  0x00000001  s[ 1]:  0x20003f10  s[ 2]:  0x20002bf8  s[ 3]:  0x0003b379
[00:00:00.039,093] <err> os: s[ 4]:  0x00000000  s[ 5]:  0x00000000  s[ 6]:  0x000539d0  s[ 7]:  0x20015744
[00:00:00.039,123] <err> os: s[ 8]:  0x20002bf8  s[ 9]:  0x0003ac5d  s[10]:  0x000539d0  s[11]:  0x20015744
[00:00:00.039,154] <err> os: s[12]:  0x0000000e  s[13]:  0x00022317  s[14]:  0x000539d0  s[15]:  0x0000000f
[00:00:00.039,154] <err> os: fpscr:  0x0000000e
[00:00:00.039,154] <err> os: Faulting instruction address (r15/pc): 0x0003ac4a
[00:00:00.039,215] <err> os: >>> ZEPHYR FATAL ERROR 4: Kernel panic on CPU 0
[00:00:00.039,245] <err> os: Current thread: 0x20003f10 (main)
I have attached my prj.conf and overlay file.
87304.prj.conf
6366.nrf52840dk_nrf52840.overlay
I haven't modified any thread priority. I tried searching for where this priorities are assigned, but couldn't find that either.
Please help.
Cheers,
Kaushalya
  • ok managed to solve it by increasing the SGP40 test wait time from 250mS to 400mS. But this is not a good way of solving this as I am modifying the files in the SDK. I cant think of any way to do it in my code as this initialization is happening even before my code is executed.
    I can see from SGP40 datasheet Figure 9 shows that the wait from send self test command to read the result should be 320mS, but the 'SGP40_TEST_WAIT_MS' is 250mS. This explains why it works when I increase this time to 400mS. If this is correct, probably this is a bug in the driver code timing definitions.
    Any thoughts?
  • I'm not sure if you saw my previous comment. Anyway, this does appear to be an obvious bug. If you want, you can submit a PR to Zephyr to fix the delay.
    Is self-testing something you want to be performed on every boot? The datasheet suggests using during production tests. If not, you can remove the  enable-selftest; property from the node in your DT and reduce the startup time of your app.
