Hello Nordic team!
I am currently encountiering such a problem. During the production process, factory data is downloaded to the designated area in advanced through the following command:
PS D:\Factory> python .\matter\scripts\tools\nrfconnect\generate_nrfconnect_chip_factory_data.py ` >> --sn 11223344556677889900 ` >> --vendor_id 65521 ` >> --product_id 32774 ` >> --vendor_name "Nordic Semiconductor ASA" ` >> --product_name "Matter Test Device" ` >> --date 2023-01-01 ` >> --hw_ver 1 ` >> --hw_ver_str v1.0 ` >> --dac_cert .\Chip-DAC-Cert.der ` >> --dac_key .\Chip-DAC-Key.der ` >> --pai_cert .\Chip-PAI-Cert.der ` >> --spake2_it 1000 ` >> --spake2_salt U1BBS0UyUCBLZXkgU2FsdA== ` >> --discriminator 0xF00 ` >> --passcode 20252050 ` >> --generate_onboarding ` >> --out .\build ` >> --offset 0x172000 ` >> --size 0x1000 ` >> --schema .\matter\scripts\tools\nrfconnect\nrfconnect_factory_data.schema
You can see:
>> --offset 0x172000 `
>> --size 0x1000 `
The specified download area has been provided, which is obtained in pm_static_nrf54l15_cpuapp.yml:
mcuboot_primary_app: orig_span: &id002 - app span: *id002 address: 0xD800 region: flash_primary size: 0x164800 factory_data: address: 0x172000 region: flash_primary size: 0x1000 settings_storage: address: 0x173000 region: flash_primary size: 0xA000
Then I used:
nrfutil device program --firmware .\build.hex --serial-number
Successfully downloaded:
PS D:\Factory> nrfutil device program --firmware .\build.hex --serial-number xxxxxxxx
[00:00:01] ###### 100% [2/2 xxxxxxxx] Programmed
THen the problem came, I found that in vscode, I always faied to download when I cliked Flash, as long as the generated factory hex file was downloaded before:
[10/10] Generating ../matter.ota -- west flash: using runner nrfutil -- runners.nrfutil: mass erase requested -- runners.nrfutil: reset after flashing requested -- runners.nrfutil: Flashing file: D:\Code\matter-samples\light_switch_1\build\merged.hex Error: One or more batch tasks failed: * 1057775460: [Probe] Failed to attach to target: The Application core access port is protected (All) (NotAvailableBecauseProtection) The operation was unavailable for some of the devices because they had readback protection enabled. These devices might be possible to unlock using the `recover` subcommand. See `nrfutil device recover --help` for more information. ERROR: runners.nrfutil: Flashing failed because the target must be recovered. To fix, run "west flash --recover" instead. Note: this will recover and erase all flash memory prior to reflashing. FATAL ERROR: command exited with status 24: nrfutil --json device x-execute-batch --batch-path 'D:\Code\matter-samples\light_switch_1\build\generated_nrfutil_batch.json' --serial-number 1057775460 * The terminal process terminated with exit code: 24. * Terminal will be reused by tasks, press any key to close it.
According to prompts, then I executed west flash --recover, which was downloaded successfully, but the result was to overwrite the previously downloaded factory data hex file.
There are two case here, I don't do any configuration, just west flash --recover and the uart print the vendor information and defualt certificate provided by Nordic for each matter sample.
In the second case, I set SB_CONFIG_MATTER_FACTORY_DATA_GENERATE = n in sysbuild.conf, although no factory data is generated at compile time. But with west flash --recover, I found that the factory data was still overwritten, because the serial output told me:uart:~$ *** Booting My Application v2.9.0-46e3bca3919f ***
*** Using nRF Connect SDK v2.9.0-7787b2649840 ***
*** Using Zephyr OS v3.7.99-1f8f3dc29142 ***
I: 1433 [DL]BLE address: C9:E8:4E:4E:29:60
I: 1440 [DL]CHIP task running
I: Init CHIP stack
I: 1445 [DL]OpenThread started: OK
I: 1448 [DL]Setting OpenThread device type to SLEEPY END DEVICE
E: 1454 [DL]Failed to parse factory data
E: FactoryDataProvider::Init() failed [Error: 160]
E: Exited with code a0
Why is this so important? In out production process, the certificate and vendor information are combined into a factory data hex file through a python script, wich is downloaded to the product in advance. Than I have to make sure that my product firmware does not overwrite the location of this factory data hex file.
ncs version v2.9
I followed the post titled "Flashing firmware without erasing factory data - Nordic Q&A - Nordic DevZone - Nordic DevZone" and tried it out, but it failed. I learned from the forum's AI that the CONFIG_CHIP_FACTORY_DATA_BUILD has been deprecated, so I used SB_CONFIG_MATTER_FACTORY_DATA_GENERATE instead, but the resualt was the same. If factory data exists beforehand, I have to use west flash --revocer, which ends up overwriting the factory data. If there's existing firmware, falshing the factory data will overwrite the firmware...
