nRF Fuel gauge SOC calculation issue
Hi!
I'm testing the application with the custom Battery pofile I generated with nPM PowerUP app.
During testing I found the issue with the SOC value calcultation depending on the charger connection state.
In case the MCU (nRF5340) is reset while USB is connected (with active charger), the SOC is calculated as follows (using the nPM1300 sample from the SDK, NCS v2.6.2):
*** Booting nRF Connect SDK v3.5.99-ncs1-3 ***
nRF Fuel Gauge version: 0.9.2
PMIC device ok
V: 4.116, I: -0.163, T: 25.41, SoC: 7.56, TTE: nan, TTF: nan
V: 4.116, I: -0.162, T: 25.41, SoC: 7.57, TTE: nan, TTF: nan
V: 4.121, I: -0.162, T: 25.41, SoC: 7.59, TTE: nan, TTF: nan
V: 4.121, I: -0.162, T: 25.41, SoC: 7.60, TTE: nan, TTF: nan
Yet in case the MCU is reset with USB disconnected, I get correct SOC predictions:
PMIC device ok
V: 4.057, I: 0.007, T: 25.41, SoC: 100.00, TTE: nan, TTF: nan
V: 4.062, I: 0.007, T: 25.41, SoC: 100.00, TTE: nan, TTF: nan
V: 4.067, I: 0.007, T: 25.41, SoC: 100.00, TTE: nan, TTF: nan
V: 4.140, I: -0.163, T: 25.41, SoC: 100.00, TTE: nan, TTF: nan
V: 4.140, I: -0.163, T: 25.31, SoC: 100.00, TTE: nan, TTF: nan
V: 4.135, I: -0.163, T: 25.41, SoC: 100.00, TTE: nan, TTF: nan
V: 4.145, I: -0.163, T: 25.41, SoC: 100.00, TTE: nan, TTF: nan
V: 4.145, I: -0.163, T: 25.41, SoC: 100.00, TTE: nan, TTF: 9963
As you can see, according the the current direction in the log above, I've connected charger after the MCU reset and SOC value remains correct.
This issue leads to the incorrect device behavior during the OTA process, since it requires power supply to be connected (business logic) and perfroms reset to boot new FW.
Is there some bug of the algorithm or should I disable charger to call
nrf_fuel_gauge_init();
and enable it again after that?
Anton
  • Hi Tharaka,
    Thanks for the reply and the explanations related to the battery model.
    This also explains wrong SOC (with my model it shows 100% at around 4.05V) while LP model you suggested shows 88.7% which I believe is more accurate.
    As for the issue with the MCU reset while charger is connected, the reasom is other.
    I did some more testing and found out that the first reading I get from the nPM1300 through Zephyr driver gives me voltage and current as if charger was active, so the model is not able to estimate battery level properly.
    This might also be a bug in the example for the nPM1300.
    As a workaround, at the initialization stage of the Fuel gauge algorithm, I disabled charging functinality and did two readings from the nPM1300 so as to "flush" first voltage/current values from it.
    Please check the following log (MCU is reset with charger connected):
    [00:00:02.196,228] <inf> app: *****:: nRF Fuel Gauge version: 0.9.2
    [00:00:02.197,631] <inf> app: *****:: Charger init (regs: SET: 0x1; CLR: 0x1)
    [00:00:02.199,645] <inf> app: *****:: Charger disabled (regs: SET: 0x0; CLR: 0x0)
    [00:00:02.704,589] <wrn> app: *****:: (init) NPM1300 data: 4.042000V, -0.471000A, 25.102783°C
    [00:00:03.209,533] <wrn> app: *****:: (init) NPM1300 data: 3.857000V, 0.000000A, 25.205627°C
    [00:00:03.214,752] <inf> app: *****:: Charger enabled (regs: SET: 0x1; CLR: 0x1)
    [00:00:03.219,848] <inf> app: *****:: NPM1300 data: 3.862000V, 0.000000A, 25.205627°C, 52.964569%
    [00:00:04.224,975] <inf> app: *****:: NPM1300 data: 3.862000V, -0.046000A, 25.102783°C, 52.964569%
    [00:00:05.230,102] <inf> app: *****:: NPM1300 data: 4.047000V, -0.467000A, 25.102783°C, 52.964569%
    [00:00:06.235,229] <inf> app: *****:: NPM1300 data: 4.047000V, -0.467000A, 25.102783°C, 52.980389%
    [00:00:07.240,356] <inf> app: *****:: NPM1300 data: 4.042000V, -0.467000A, 25.102783°C, 52.995975%
    As you can see, first reading from the nPM1300 after disabling charger shows incorrect values.
    I guess that it might be related to the Automatic measurements during charging.
    So, with such modification I'm now able to get more accurate SOC when restarting MCU with connected charger.
    Anton
  • Glad that you have found a workaround for MCU reset and everything is working properly now.
    Good luck with your project !!
    Regards
    Tharaka
