Wakeup from sleep with GPIO
Hi, I would like to put a nrf51822 device into system off mode and wake it up with a GPIO transition from high to low. I would like to measure the press time of the button after wake up but it seems that software doesn't run properly until the button is pressed. So, does the software run normally after the reset transition even if the button is still pressed? I hope it is clear. Thanks.
  • Hi, I did other tests and I can confirm that the software doesn't run during the button is pressed (low pin state started with a high to low transition). It will start to run at the consecutive release event (low to high transition). The button is configure as follow: nrf_gpio_cfg_sense_input(BUTTON_PIN_NUMBER, NRF_GPIO_PIN_PULLUP, NRF_GPIO_PIN_SENSE_LOW);
