Setup nRF52 dongle as a Central BLE device and relay all the data from the peripheral to the PC via USb port
As per the title, I am trying to use the nRF52 dongle to interface with our device which uses nRF52 based module. The idea is to communicate with the dongle over USB port and send data to our device and receive data back.
Essentially, the nRF52 dongle is replacing the PC's built in Bluetooth which can be sometimes unreliable. Also enables us to have multiple dongles connected to communicate with multiple BLE devices simultaneously.
So I downloaded the Bluetooth: CENTRAL UART WITH USB_CDC_ACM source from github.
https://github.com/WesC-sys/usb_dongle
As suggested in this older ticket.
 Using the nRF52840 Dongle (PCA10059) as a USB serial-to-BLE port
The issue I face is that the USBD write to the PC is not buffered and drops bytes. Is there a reliable way to implement what I am trying to achieving with high data throughput as out device uses data length extensions and transmits 200 bytes every 30 milliseconds.
Would it better to use a nrf52 DK and a USB UART to achieve the above?
Regards
    Does this mean that nrf_ble_desktop is the PC application?
    Ble Connectivity firmware is already being programmed by nRF Connect on the dongle.
    I will ask a different question, as your response does not clearly state how to achieve my objective.
    I want to know how and what commands need to be sent to the ble connectivity firmware so I can create a PC app using any programming language to open a USBD virtual com port, and send commands to scan, connect and communicate with the peripheral.
  • Let me describe how I experimented:
    nRF peripheral: heart rate example
    nRF central (dongle): connectivity HEX files firmware
    PC: running github.com/.../main.c
    This main.c program will communicate with the nRF central (dongle) to scan, connect, and read heart rate values from the nRF peripheral (TARGET_DEV_NAME "Nordic_HRM").
    PC <-- USB_CDC_ACM --> nRF central          <------ BLE packet --->  nRF peripheral.
    Apologies if my experiment differs from your requirements.
    exsurgo_ankit said:
    Thank you for the suggestions. Why would you avoid the old soft device? Our product has been developed on the old soft device and has been running well for over 5 years. It does not use USB CDC. Is the USB CDC not reliable?
    I am sorry for the confusion. By assumption when reading the initial post was that this was a new project, if you are modifying an existing nRF5 SDK project that is no problem. But if the PC side dongle is a new product, and it is the other end that is old, I would still consdier nRF Connect SDK on the (new) PC side dongle.
    exsurgo_ankit said:
    When I use the Bluetooth Low Energy app in nRF Connect for Desktop, it programs the dongle and I can control it just the way I need to. The issue, is that I can't find the firmware source for the application and the Electron JS source for the desktop app seems difficult to traverse for me to understand what commands are being sent.
    The BLE app is based on the pc-ble-driver as commented. But please note that this is no longer maintained, as it is based on the old SoftDevice. So I would advice against this as well (based on the same rationale as advising against nRF5 SDK for new products in general).
    It seems that the my question has been evaded through all these responses. I will ask it in one line.
    Is there a document or a code file in the source repo that list the commands that are sent to the dongle to scan, connect and communicate with the peripheral?
    I can do the rest if I have this information.
    Do you refer to this old old unofficial repo that you linked to initially? If so, no. It is not designed like that, but provide a simple data tunnel using the Nordic UART service.
