Failed to enable tracking in Net subsys.
I'm working on a project where we would like to track system performance using Segger Systemview.
I'm building with the following RTT configs:
CONFIG_USE_SEGGER_RTT=y
CONFIG_DEBUG_OPTIMIZATIONS=n
CONFIG_DEBUG_THREAD_INFO=y
CONFIG_TRACING=y
CONFIG_SEGGER_SYSTEMVIEW=y
CONFIG_SEGGER_SYSTEMVIEW_BOOT_ENABLE=n
CONFIG_SEGGER_SYSVIEW_POST_MORTEM_MODE=n
and I'm getting the following errors:
/home/<user>/ncs/v2.9.0/zephyr/include/zephyr/tracing/tracing_macros.h:43:9: warning: implicit declaration of function 'sys_port_trace_net_tx_time' [-Wimplicit-function-declaration]
   43 |         sys_port_trace_ ## name ## _ ## func
/home/<user>/ncs/v2.9.0/zephyr/include/zephyr/sys/util_internal.h:72:26: note: in definition of macro '__DEBRACKET'
   72 | #define __DEBRACKET(...) __VA_ARGS__
/home/<user>/ncs/v2.9.0/zephyr/include/zephyr/sys/util_internal.h:64:9: note: in expansion of macro '__GET_ARG2_DEBRACKET'
   64 |         __GET_ARG2_DEBRACKET(one_or_two_args _if_code, _else_code)
/home/<user>/ncs/v2.9.0/zephyr/include/zephyr/sys/util_internal.h:59:9: note: in expansion of macro '__COND_CODE'
   59 |         __COND_CODE(_XXXX##_flag, _if_1_code, _else_code)
/home/<user>/ncs/v2.9.0/zephyr/include/zephyr/sys/util_macro.h:180:9: note: in expansion of macro 'Z_COND_CODE_1'
  180 |         Z_COND_CODE_1(_flag, _if_1_code, _else_code)
/home/<user>/ncs/v2.9.0/zephyr/include/zephyr/tracing/tracing_macros.h:211:9: note: in expansion of macro 'COND_CODE_1'
  211 |         COND_CODE_1(_SYS_PORT_TRACE_IS_DISABLED(type), (),                                         \
/home/<user>/ncs/v2.9.0/zephyr/include/zephyr/tracing/tracing_macros.h:212:22: note: in expansion of macro '_SYS_PORT_TRACE_WRAP'
  212 |                     (_SYS_PORT_TRACE_WRAP(func, __VA_ARGS__)))
/home/<user>/ncs/v2.9.0/zephyr/include/zephyr/tracing/tracing_macros.h:236:9: note: in expansion of macro '_SYS_PORT_TRACE_IF_NOT_DISABLED'
  236 |         _SYS_PORT_TRACE_IF_NOT_DISABLED(type, _SYS_PORT_TRACING_FUNC(type, func), __VA_ARGS__)
/home/<user>/ncs/v2.9.0/zephyr/include/zephyr/tracing/tracing_macros.h:236:47: note: in expansion of macro '_SYS_PORT_TRACING_FUNC'
/home/<user>/ncs/v2.9.0/zephyr/subsys/net/ip/net_if.c:281:25: note: in expansion of macro 'SYS_PORT_TRACING_FUNC'
  281 |                         SYS_PORT_TRACING_FUNC(net, tx_time, pkt, end_tick);
I have tried to add these configs as well but without any luck:
CONFIG_TRACING_NET_CORE=n
CONFIG_TRACING_NET_SOCKETS=n
Forgot to add:
Nordic SDK: 2.9.0
SiP: nrf9160
Modem FW version: 1.3.7
  • Edit:
    Okay just by adding CONFIG_NETWORKING=y to the tracing sample the issue is present.
    Old:
    My bad thought I used the correct prj.conf file.
    Issue can be replicated when combining the tracing sample and azure_iot_hub sample:
    Here is a snippet from the .config from the tracing sample:
    # Tracing Configuration
    CONFIG_TRACING_SYSCALL=y
    CONFIG_TRACING_THREAD=y
    CONFIG_TRACING_WORK=y
    CONFIG_TRACING_ISR=y
    CONFIG_TRACING_SEMAPHORE=y
    CONFIG_TRACING_MUTEX=y
    CONFIG_TRACING_CONDVAR=y
    CONFIG_TRACING_QUEUE=y
    CONFIG_TRACING_FIFO=y
    CONFIG_TRACING_LIFO=y
    CONFIG_TRACING_STACK=y
    CONFIG_TRACING_MESSAGE_QUEUE=y
    CONFIG_TRACING_MAILBOX=y
    CONFIG_TRACING_PIPE=y
    CONFIG_TRACING_HEAP=y
    CONFIG_TRACING_MEMORY_SLAB=y
    CONFIG_TRACING_TIMER=y
    CONFIG_TRACING_EVENT=y
    CONFIG_TRACING_POLLING=y
    CONFIG_TRACING_PM=y
    # CONFIG_TRACING_NETWORKING is not set
    # end of Tracing Configuration
    and here is for the tracing sample where azure_iot_hub sample has been merged:
    CONFIG_TRACING_PM=y
    CONFIG_TRACING_NETWORKING=y
    CONFIG_TRACING_NET_SOCKETS=y
    CONFIG_TRACING_NET_CORE=y
    Note the difference in network tracing in the bottom of the configs.
