some problems about AES CCM
1st problem:
There are some failed case when i run  \v2.9.1\modules\bsim_hw_models\nrf_hw_models\tests\zephyr_apps\54_aar_ccm_ecb\src\test_ccm.c
2nd problem:
If I reduce the amount of encrypted data in test_ccm_12b_encr_ble_255b_w_adata_nomac, the encryption process gets stuck.
  • Have you considered encrypting the package in the application before sending it, instead of doing it using the CCM
    I need to encrypt packets on-the-fly in radio transmit mode later, so I need to know the reason for the failure.
  • It is easy to reproduce the problem using my method. I don't care about the first question now. I want to know the answer to the second question: whether the method in the example supports encryption of data packets of different lengths.
  • ZTEST(nrf_ccm_tests, test_ccm_12c_encr_ble_0_255b_w_adata_nomac)
    	printk("Encrypt 0-255 byte payload with adata and no MAC in BLE mode\n");
    	uint8_t K[16] = {0x99, 0xAD, 0x1B, 0x52, 0x26, 0xA3, 0x7E, 0x3E, 0x05, 0x8E, 0x3B, 0x8E, 0x27, 0xC2, 0xC6, 0x66};
    	uint8_t N[16] = {0x00, 0x00, 0x00, 0x01, 0x00, 0x00, 0x00, 0x80, 0x24, 0xAB, 0xDC, 0xBA, 0xBE, 0xBA, 0xAF, 0xDE};
    	uint8_t A[] = {0x0E};
    	uint8_t P[] = {0x0,  0x1,  0x2,  0x3,  0x4,  0x5,  0x6,  0x7,  0x8,  0x9, 0xa, 0xb,  0xc,  0xd,  0xe,  0xf,  0x10,
    			0x11, 0x12, 0x13, 0x14, 0x15, 0x16, 0x17, 0x18, 0x19, 0x1a, 0x1b, 0x1c, 0x1d, 0x1e, 0x1f, 0x20, 0x21,
    			0x22, 0x23, 0x24, 0x25, 0x26, 0x27, 0x28, 0x29, 0x2a, 0x2b, 0x2c, 0x2d, 0x2e, 0x2f, 0x30, 0x31, 0x32,
    			0x33, 0x34, 0x35, 0x36, 0x37, 0x38, 0x39, 0x3a, 0x3b, 0x3c, 0x3d, 0x3e, 0x3f, 0x40, 0x41, 0x42, 0x43,
    			0x44, 0x45, 0x46, 0x47, 0x48, 0x49, 0x4a, 0x4b, 0x4c, 0x4d, 0x4e, 0x4f, 0x50, 0x51, 0x52, 0x53, 0x54,
    			0x55, 0x56, 0x57, 0x58, 0x59, 0x5a, 0x5b, 0x5c, 0x5d, 0x5e, 0x5f, 0x60, 0x61, 0x62, 0x63, 0x64, 0x65,
    			0x66, 0x67, 0x68, 0x69, 0x6a, 0x6b, 0x6c, 0x6d, 0x6e, 0x6f, 0x70, 0x71, 0x72, 0x73, 0x74, 0x75, 0x76,
    			0x77, 0x78, 0x79, 0x7a, 0x7b, 0x7c, 0x7d, 0x7e, 0x7f, 0x80, 0x81, 0x82, 0x83, 0x84, 0x85, 0x86, 0x87,
    			0x88, 0x89, 0x8a, 0x8b, 0x8c, 0x8d, 0x8e, 0x8f, 0x90, 0x91, 0x92, 0x93, 0x94, 0x95, 0x96, 0x97, 0x98,
    			0x99, 0x9a, 0x9b, 0x9c, 0x9d, 0x9e, 0x9f, 0xa0, 0xa1, 0xa2, 0xa3, 0xa4, 0xa5, 0xa6, 0xa7, 0xa8, 0xa9,
    			0xaa, 0xab, 0xac, 0xad, 0xae, 0xaf, 0xb0, 0xb1, 0xb2, 0xb3, 0xb4, 0xb5, 0xb6, 0xb7, 0xb8, 0xb9, 0xba,
    			0xbb, 0xbc, 0xbd, 0xbe, 0xbf, 0xc0, 0xc1, 0xc2, 0xc3, 0xc4, 0xc5, 0xc6, 0xc7, 0xc8, 0xc9, 0xca, 0xcb,
    			0xcc, 0xcd, 0xce, 0xcf, 0xd0, 0xd1, 0xd2, 0xd3, 0xd4, 0xd5, 0xd6, 0xd7, 0xd8, 0xd9, 0xda, 0xdb, 0xdc,
    			0xdd, 0xde, 0xdf, 0xe0, 0xe1, 0xe2, 0xe3, 0xe4, 0xe5, 0xe6, 0xe7, 0xe8, 0xe9, 0xea, 0xeb, 0xec, 0xed,
    			0xee, 0xef, 0xf0, 0xf1, 0xf2, 0xf3, 0xf4, 0xf5, 0xf6, 0xf7, 0xf8, 0xf9, 0xfa};
    	uint8_t C[] = {
    			0x6D, 0x71, 0xB7, 0x03, 0x74, 0x41, 0x0C, 0x9D, 0x0A, 0x74, 0xE2, 0xFD, 0x67, 0x67, 0x64, 0x26, 0x0A, 0xF6, 0x76,
    			0x6F, 0x59, 0x4B, 0x7B, 0xBC, 0xC6, 0xDF, 0x18, 0x5B, 0x50, 0x2D, 0x3D, 0x5E, 0xD9, 0xAF, 0xF6, 0xB8, 0xFE, 0x86,
    			0xC5, 0x23, 0x3A, 0xA8, 0x35, 0xE4, 0xE6, 0xA0, 0xB6, 0xC9, 0x48, 0xFF, 0xFF, 0xF5, 0xA0, 0xC0, 0x19, 0x32, 0x71,
    			0x60, 0x61, 0x0C, 0x1B, 0xE5, 0x43, 0xCE, 0xB5, 0xBC, 0x9E, 0x3A, 0x3D, 0x85, 0xB7, 0xAA, 0x65, 0x64, 0x2E, 0x38,
    			0x82, 0x27, 0x3D, 0xA4, 0x13, 0xFE, 0xE5, 0x89, 0x1F, 0x2F, 0x0E, 0x9B, 0x02, 0x0B, 0x10, 0xCD, 0xA8, 0xCD, 0xBA,
    			0xA6, 0xD0, 0x40, 0x44, 0xD0, 0x75, 0x37, 0xBB, 0x06, 0x16, 0x54, 0x04, 0x7F, 0x8A, 0x0C, 0x2E, 0x7E, 0xB8, 0x06,
    			0x06, 0x63, 0x3F, 0x4A, 0x08, 0xFF, 0x21, 0x28, 0x6C, 0x8F, 0x65, 0xB6, 0x29, 0xE5, 0xFC, 0x58, 0x29, 0x7D, 0x55,
    			0xFE, 0xA8, 0x24, 0xDE, 0xE5, 0xB1, 0x8C, 0x9B, 0xAF, 0xD3, 0x78, 0xCE, 0x87, 0x92, 0x07, 0x4F, 0x40, 0x75, 0xE6,
    			0xA7, 0x61, 0x09, 0x73, 0xBE, 0x0A, 0x29, 0x05, 0x3F, 0xF7, 0xBD, 0xD8, 0x9C, 0xC7, 0xDA, 0x4B, 0xAC, 0xE9, 0xC2,
    			0xE4, 0xD7, 0x4C, 0x2C, 0x26, 0x8C, 0x00, 0xE4, 0xE6, 0xBE, 0x05, 0x0E, 0xC2, 0xDA, 0x1E, 0xA7, 0xAE, 0xD7, 0x35,
    			0xA8, 0x26, 0xCD, 0xF8, 0x93, 0x93, 0x26, 0x0C, 0xD5, 0x47, 0x9B, 0x7C, 0x35, 0x62, 0x7D, 0xFB, 0xCF, 0xAD, 0x78,
    			0x91, 0xA6, 0x0C, 0xC8, 0x5C, 0xBF, 0x05, 0xBF, 0x7E, 0xE4, 0x0C, 0x4A, 0x9E, 0xC9, 0xD2, 0x9F, 0x75, 0x7A, 0x58,
    			0x84, 0x9B, 0xD4, 0x9A, 0x2B, 0x51, 0xB2, 0x4A, 0x3A, 0x45, 0xEB, 0x58, 0x33, 0x86, 0x53, 0xC5, 0xBA, 0x63, 0x73,
    			0xB6, 0x89, 0x25, 0xD7,
    	unsigned mac_len = 0;
    	uint8_t adata_mask = 0xE3;
    	for (uint8_t len = 0; len <= 255; len++)
    		build_ccm_test_case_and_run(K, N, P, len, len, A, sizeof(A), C, len, mac_len, adata_mask, false,
    				false, ENCRYPT, BLE_MODE, NULL, false);
    I wrote an example of encrypting data of different lengths according to test_ccm_12b, but it got stuck when len=36.
  • Could this be Errata [1] CCM: MAC error is returned if MDATA size is slightly larger than MLEN?
    Try to set MLEN (len) to a lot higher than sizeof(P), as suggested in the workaround
  • Thanks for your reply.
    I tried this method but it doesn't work. My problem seems to be different from this one.
