How to use nrf54L15-dk with external host through hci uart application
I am trying to build an application using the nrf54L15-dk board and want to use the board as a controller. I run the application on the external host but got an error as controller responsive. Can you provide the details steps so that board can be use with external host.
  • Update i skipped the part to read remote FAE table .. and directly called the Create Cs config command. Still facing same issue while creating config ? The following are the command parameters.
    cmd->conn_handle = 2fd
    cmd->config_id = 0
    cmd->create_context = 0
    cmd->main_mode_type = 1
    cmd->sub_mode_type = 1
    cmd->min_main_mode_steps = 2
    cmd->max_main_mode_steps = 5
    cmd->main_mode_repetition = 0
    cmd->mode_0_steps = 3
    cmd->role = 0
    cmd->rtt_type = 0
    cmd->cs_sync_phy = 1
    cmd->channel_map_repetition = 3
    cmd->channel_selection_type = 0
    cmd->ch3c_shape = 0
    cmd->ch3c_jump = 2
  • I guess this configuration might be invalid due to
    Because the Bluetooth Core Spec 6.0 doesn't allow this combination of modes. It is described in the Core Specification 6.0, Vol. 6, Part H, 4.4.2 CS subevent structure, table 4.11.
    Can you try to set sub_mode_type to "Unused" and check if it helps?
  • I tried setting sub_mode to 0, but it didn't help. Is there a way to trace a controller code and check what exactly is falling, or is it a black box to debug?
    I tried all combinations of main mode and submode, including unset ( that is 0xFF to sub mode), but it didn't help..  Parameters for the command are as follows. Also, i modified the proj.conf but it didn't work.
    cmd->conn_handle = 1e
    cmd->config_id = 0
    cmd->create_context = 1
    cmd->sub_mode_type = ff
    cmd->mode_0_steps = ff
    cmd->role = 0
    cmd->rtt_type = 0
    cmd->channel_map_repetition = 0
    cmd->ch3c_shape = 0
    cmd->ch3c_jump = 2
    Below is the latest proj.conf
    CONFIG_CONSOLE=n
    CONFIG_STDOUT_CONSOLE=n
    CONFIG_UART_CONSOLE=n
    CONFIG_GPIO=y
    CONFIG_SERIAL=y
    CONFIG_BT=y
    CONFIG_BT_HCI_RAW=y
    CONFIG_BT_HCI_RAW_H4=y
    CONFIG_BT_HCI_RAW_H4_ENABLE=y
    CONFIG_BT_BUF_ACL_RX_SIZE=255
    CONFIG_BT_BUF_CMD_TX_SIZE=255
    CONFIG_BT_BUF_EVT_DISCARDABLE_SIZE=255
    CONFIG_BT_CTLR_ASSERT_HANDLER=y
    CONFIG_BT_MAX_CONN=16
    CONFIG_BT_CTLR_DTM_HCI=y
    CONFIG_BT_CTLR_ADV_EXT=y
    CONFIG_BT_CTLR_CHANNEL_SOUNDING=y
    CONFIG_SYSTEM_WORKQUEUE_STACK_SIZE=512
    CONFIG_BT_RAS_MODE_3_SUPPORTED=n
    CONFIG_BT_RAS_MAX_ANTENNA_PATHS=1
    CONFIG_BT_CTLR_SDC_CS_MAX_ANTENNA_PATHS=1
    CONFIG_BT_CTLR_SDC_CS_NUM_ANTENNAS=1
    CONFIG_BT_CTLR_SDC_CS_STEP_MODE3=n
    CONFIG_BT_CHANNEL_SOUNDING_REASSEMBLY_BUFFER_SIZE=1920
    CONFIG_BT_L2CAP_TX_MTU=498
    CONFIG_BT_BUF_ACL_TX_SIZE=502
    CONFIG_BT_BUF_ACL_RX_SIZE=502
    CONFIG_BT_ATT_PREPARE_COUNT=3
    CONFIG_BT_CTLR_DATA_LENGTH_MAX=251
    # Workaround: Unable to allocate command buffer when using K_NO_WAIT since
    # Host number of completed commands does not follow normal flow control.
    CONFIG_BT_BUF_CMD_TX_COUNT=10
    CONFIG_BT_TRANSMIT_POWER_CONTROL=y
    CONFIG_BT_CS_DE=y
    CONFIG_BT_CS_DE_512_NFFT=y
  • Bluetooth controller (SDC) is closed-source static library so there is no way to debug it.
