nrf_delay_ms() is not available for usbd communication (usbd_cdc_acm)
Hello, World
Please note that the following questions may be difficult to read as the text was created using a translation tool.
I have downloaded version 17.0.2 of the nrf sdk and obtained the directory nRF5_SDK_17.0.2_d674dde. Then, open examples/peripheral/usbd_cdc_acm/pca10056/blank/ses/usbd_cdc_acm_pca10056.emProject in the directory with SEGGER Embedded Studio for ARM 5.10a The main.c was written to nordic's development kit nRF52840 DK. Then I connected it to a PC via USB and got usb output from the kit. When I wrote the main.c code as downloaded, I was able to confirm that pressing the button on the kit outputs a string as expected.
 I wanted to add a 100 ms delay after the usbd process, so I modified part of the program as follows. This modification adds a 100 ms delay by nrf_delay_ms(100) after the usbd process by while (app_usbd_event_queue_process()){}. I wrote this modified code and tried to run it, but communication by usb was not possible (I could not check the usb port with the ls command).
 Can I use some other function with delay, sleep, wait, etc., to do the behaviour I expect - a 100 ms delay after the usbd process? Incidentally, I have confirmed that if the delay time is less than 16 ms, it works as I expect.
Thanks!
while (true)
// Nothing to do
nrf_delay_ms(100); //Delay added
if(m_send_flag)
static int frame_counter;
size_t size = sprintf(m_tx_buffer, "Hello USB CDC FA demo: %u\r\n", frame_counter);
ret = app_usbd_cdc_acm_write(&m_app_cdc_acm, m _tx_buffer, size);
if (ret == NRF_SUCCESS)
++frame_counter;
Translated with DeepL.com (free version)
  • Hi, Vidar
    Thank you for helping me.
    "The delay function you added doesn't explain why the USB is no longer enumerating on your PC. Does it also fail when you try loading the precompiled HEX file located in /examples/peripheral/usbd_cdc_acm/hex/usbd_cdc_acm_pca10056.hex?"
    I too wondered why just adding nrf_delay_ms() stopped enumerating on the PC. Writing the unmodified usbd_cdc_acm_pca10056.hex allows usb communication without any problems. Also, I build and run the unmodified usbd_cdc_acm_pca10056.emProject, usb communication is available.
    Again, as in the first question, usb communication is not possible by simply adding nrf_delay_ms(x) in the infinite loop.
    "That said, if you want to perform a task every 100 ms, it would be much more efficient to create a periodic app timer instance that calls a timeout handler every 100 ms that you can perform your task in. You can use the ble_peripheral/ble_app_hrs example as a reference for how you can use the app timer."
    I will try to use app timer based on ble_peripheral/ble_app_hrs example.
    Rion
  • Hi Rion,
    The delay function will delay processing of the USB events and impact the USB performance, but I don't see how it causes the enumeration to fail. I added the same delay here and was not able to reproduce the issue on my side. Anyway, using the app timer will hopefully fix the issue for you.
    Vidar
