How can I evaluate that AGPS data downloaded and been processed?
I’m trying to understand exactly how the location module works in the Assert Tracker V2 application. I want to see the NMEA data in the logs, but I’m not sure how to enable it or if that’s even possible. My main goal is to confirm that the AGPS data downloaded by the library has been processed. It’s easy to see this in the GNSS sample, but you don’t see the same information in the Assert Tracker’s PVT data.
  • Hi Roman
    Sorry about the lacking replies here, but we have been somewhat short on staff as we're in the middle of Easter here in Norway.
    I just had another chat with the developer today, and there seems some more location library changes are needed. As just hooking in the asset tracker's location library isn't enough. You will also need to expect the event, forward it to the asset tracker in a callback and handle it correctly there.
    Can you upload the exact changes you've made tot he location library at this point so we can take a look at it?
    Simon
    I only changed the ncs\v2.9.0\nrf\lib\location\method_gnss.c
     * Copyright (c) 2021 Nordic Semiconductor ASA
    #include <stdio.h>
    #include <zephyr/kernel.h>
    #include <modem/location.h>
    #include <modem/lte_lc.h>
    #include <nrf_modem_at.h>
    #include <nrf_modem_gnss.h>
    #include <nrf_errno.h>
    #include "location_core.h"
    #include "location_utils.h"
    #if defined(CONFIG_NRF_CLOUD_AGNSS)
    #include "scan_cellular.h"
    #include <net/nrf_cloud_rest.h>
    #include <net/nrf_cloud_agnss.h>
    #include <stdlib.h>
    #if defined(CONFIG_NRF_CLOUD_PGPS)
    #include <net/nrf_cloud_pgps.h>
    #if defined(CONFIG_NRF_CLOUD_COAP)
    #include <net/nrf_cloud_coap.h>
    #if defined(CONFIG_LOCATION_SERVICE_NRF_CLOUD_GNSS_POS_SEND)
    #include <net/nrf_cloud_codec.h>
    #include <zephyr/sys/timeutil.h>
    #include <time.h>
    LOG_MODULE_DECLARE(location, CONFIG_LOCATION_LOG_LEVEL);
    #if defined(CONFIG_NRF_CLOUD_AGNSS) || defined(CONFIG_NRF_CLOUD_PGPS)
    /* Verify that MQTT, REST, CoAP or external service is enabled */
    BUILD_ASSERT(IS_ENABLED(CONFIG_NRF_CLOUD_MQTT) || IS_ENABLED(CONFIG_NRF_CLOUD_REST) ||
    		     IS_ENABLED(CONFIG_NRF_CLOUD_COAP) ||
    		     IS_ENABLED(CONFIG_LOCATION_SERVICE_EXTERNAL),
    	     "CONFIG_NRF_CLOUD_MQTT, CONFIG_NRF_CLOUD_REST, CONFIG_NRF_CLOUD_COAP or "
    	     "CONFIG_LOCATION_SERVICE_EXTERNAL must be enabled");
    /* Maximum waiting time before proceeding regardless of RRC or PSM state [min]. This prevents
     * Location library from getting stuck indefinitely if the application keeps LTE connection
     * constantly active.
    #define SLEEP_WAIT_BACKSTOP 2
    #if !defined(CONFIG_NRF_CLOUD_AGNSS)
    /* range 10240-3456000000 ms, see AT command %XMODEMSLEEP */
    #define MIN_SLEEP_DURATION_FOR_STARTING_GNSS 10240
    #define AT_MDM_SLEEP_NOTIF_START	     "AT%%XMODEMSLEEP=1,%d,%d"
    #if (defined(CONFIG_NRF_CLOUD_AGNSS) || defined(CONFIG_NRF_CLOUD_PGPS))
    #define AGNSS_REQUEST_RECV_BUF_SIZE	     3500
    #define AGNSS_REQUEST_HTTPS_RESP_HEADER_SIZE 400
    /* Minimum time between two A-GNSS data requests in seconds. */
    #define AGNSS_REQUEST_MIN_INTERVAL	     (60 * 60)
    /* A-GNSS data expiration threshold in minutes before requesting fresh data. An 80 minute threshold
     * is used because it leaves enough time to try again after an hour if fetching of A-GNSS data fails
     * once. Also, because of overlapping ephemeris validity times, fresh ephemerides are
     * needed on average every two hours with both 80 minute and shorter expiration thresholds.
    #define AGNSS_EXPIRY_THRESHOLD		     (80)
    /* P-GPS data expiration threshold is zero minutes, because there is no overlap between
     * predictions.
    #define PGPS_EXPIRY_THRESHOLD		     0
    /* A-GNSS minimum number of expired ephemerides to request all ephemerides. */
    #define AGNSS_EPHE_MIN_COUNT		     3
    /* P-GPS minimum number of expired ephemerides to trigger injection of a prediction.
     * With P-GPS, ephemerides are not available for all satellites, especially when
     * predictions are made further into the future, so it is natural that ephemerides are
     * missing for some of the satellites.
    #define PGPS_EPHE_MIN_COUNT		     12
    /* A-GNSS minimum number of expired almanacs to request all almanacs. */
    #define AGNSS_ALM_MIN_COUNT		     3
    /* PRN of the first QZSS satellite. The range for QZSS PRNs is 193...202. */
    #define FIRST_QZSS_PRN			     193
    #define VISIBILITY_DETECTION_EXEC_TIME CONFIG_LOCATION_METHOD_GNSS_VISIBILITY_DETECTION_EXEC_TIME
    #define VISIBILITY_DETECTION_SAT_LIMIT CONFIG_LOCATION_METHOD_GNSS_VISIBILITY_DETECTION_SAT_LIMIT
    static struct k_work method_gnss_prepare_work;
    static struct k_work method_gnss_start_work;
    static struct k_work method_gnss_pvt_work;
    static struct k_work method_gnss_nmea_work;
    static int64_t agnss_req_timestamp;
    #if !defined(CONFIG_LOCATION_SERVICE_EXTERNAL) &&                                                  \
    	(defined(CONFIG_NRF_CLOUD_REST) || defined(CONFIG_NRF_CLOUD_COAP)) &&                      \
    	!defined(CONFIG_NRF_CLOUD_MQTT)
    static char agnss_rest_data_buf[AGNSS_REQUEST_RECV_BUF_SIZE];
    static struct k_work method_gnss_pgps_request_work;
    static struct k_work method_gnss_inject_pgps_work;
    static struct k_work method_gnss_notify_pgps_work;
    static struct nrf_cloud_pgps_prediction *prediction;
    static struct gps_pgps_request pgps_request;
    static bool running;
    static struct location_gnss_config gnss_config;
    static K_SEM_DEFINE(entered_psm_mode, 0, 1);
    static K_SEM_DEFINE(entered_rrc_idle, 1, 1);
    static struct nrf_modem_gnss_agnss_data_frame agnss_request;
    static struct nrf_modem_gnss_agnss_data_frame pgps_agnss_request = {
    	/* Inject current time by default. */
    	.data_flags = NRF_MODEM_GNSS_AGNSS_GPS_SYS_TIME_AND_SV_TOW_REQUEST,
    	.system_count = 1,
    	/* Ephe mask for GPS is initially all set, because event PGPS_EVT_AVAILABLE may be received
    	 * before the assistance request from GNSS. If ephe mask would be zero, no prediction
    	 * would be injected.
    	.system[0].system_id = NRF_MODEM_GNSS_SYSTEM_GPS,
    	.system[0].sv_mask_ephe = 0xffffffff,
    	.system[0].sv_mask_alm = 0x00000000,
    #if defined(CONFIG_NRF_CLOUD_REST) && !defined(CONFIG_NRF_CLOUD_MQTT)
    #if (defined(CONFIG_NRF_CLOUD_AGNSS) && !defined(CONFIG_LOCATION_SERVICE_EXTERNAL)) ||             \
    	(defined(CONFIG_NRF_CLOUD_PGPS) && !defined(CONFIG_LOCATION_SERVICE_EXTERNAL))
    static char rest_api_recv_buf[CONFIG_NRF_CLOUD_REST_FRAGMENT_SIZE +
    			      AGNSS_REQUEST_HTTPS_RESP_HEADER_SIZE];
    #if defined(CONFIG_LOCATION_SERVICE_EXTERNAL) && defined(CONFIG_NRF_CLOUD_PGPS)
    static struct k_work method_gnss_pgps_ext_work;
    static void method_gnss_pgps_ext_work_fn(struct k_work *item);
    /* Count of consecutive NRF_MODEM_GNSS_PVT_FLAG_NOT_ENOUGH_WINDOW_TIME flags in PVT data. Used for
     * triggering GNSS priority mode if enabled.
    static int insuf_timewin_count;
    static int fixes_remaining;
    static bool visibility_detection_done;
    #if defined(CONFIG_LOCATION_DATA_DETAILS)
    static struct location_data_details_gnss location_data_details_gnss;
    static int64_t elapsed_time_gnss_start_timestamp;
    static void method_gnss_inject_pgps_work_fn(struct k_work *work)
    	ARG_UNUSED(work);
    	int err;
    	LOG_DBG("Sending prediction to modem (ephe: 0x%08x)...",
    		(uint32_t)pgps_agnss_request.system[0].sv_mask_ephe);
    	err = nrf_cloud_pgps_inject(prediction, &pgps_agnss_request);
    	if (err) {
    		LOG_ERR("Failed to send prediction to modem, error: %d", err);
    void method_gnss_pgps_handler(struct nrf_cloud_pgps_event *event)
    	LOG_DBG("P-GPS event type: %d", event->type);
    	if (event->type == PGPS_EVT_READY) {
    		/* P-GPS has finished downloading predictions; request the current prediction. */
    		k_work_submit_to_queue(location_core_work_queue_get(),
    				       &method_gnss_notify_pgps_work);
    	} else if (event->type == PGPS_EVT_AVAILABLE) {
    		/* Inject the specified prediction into the modem. */
    		prediction = event->prediction;
    				       &method_gnss_inject_pgps_work);
    	} else if (event->type == PGPS_EVT_REQUEST) {
    		memcpy(&pgps_request, event->request, sizeof(pgps_request));
    		k_work_submit_to_queue(location_core_work_queue_get(), &method_gnss_pgps_ext_work);
    #else
    				       &method_gnss_pgps_request_work);
    static void method_gnss_notify_pgps_work_fn(struct k_work *work)
    	ARG_UNUSED(work);
    	int err = nrf_cloud_pgps_notify_prediction();
    	if (err) {
    		LOG_ERR("Failed to request prediction, error: %d", err);
    void method_gnss_lte_ind_handler(const struct lte_lc_evt *const evt)
    	switch (evt->type) {
    	case LTE_LC_EVT_MODEM_SLEEP_ENTER:
    		if (evt->modem_sleep.type == LTE_LC_MODEM_SLEEP_PSM) {
    			/* Allow GNSS operation once LTE modem is in power saving mode. */
    			k_sem_give(&entered_psm_mode);
    	case LTE_LC_EVT_MODEM_SLEEP_EXIT:
    		/* Prevent GNSS from starting while LTE is active. */
    		k_sem_reset(&entered_psm_mode);
    	case LTE_LC_EVT_PSM_UPDATE:
    		/* If PSM becomes disabled e.g. due to network change, allow GNSS to be started
    		 * in case there was a pending position request waiting for the sleep to start. If
    		 * PSM becomes enabled, block GNSS until the modem enters PSM by taking the
    		 * semaphore.
    		if (evt->psm_cfg.active_time == -1) {
    		} else if (evt->psm_cfg.active_time > 0) {
    			k_sem_take(&entered_psm_mode, K_NO_WAIT);
    	case LTE_LC_EVT_RRC_UPDATE:
    		if (evt->rrc_mode == LTE_LC_RRC_MODE_CONNECTED) {
    			/* Prevent GNSS from starting while RRC is in connected mode. */
    			k_sem_reset(&entered_rrc_idle);
    		} else if (evt->rrc_mode == LTE_LC_RRC_MODE_IDLE) {
    			/* Allow GNSS operation once RRC is in idle mode. */
    			k_sem_give(&entered_rrc_idle);
    #if defined(CONFIG_NRF_CLOUD_AGNSS) && !defined(CONFIG_LOCATION_SERVICE_EXTERNAL)
    #if defined(CONFIG_NRF_CLOUD_MQTT)
    static void method_gnss_nrf_cloud_agnss_request(void)
    	int err = nrf_cloud_agnss_request(&agnss_request);
    	if (err) {
    		LOG_ERR("nRF Cloud A-GNSS request failed, error: %d", err);
    		return;
    	LOG_DBG("A-GNSS data requested");
    #elif defined(CONFIG_NRF_CLOUD_REST) || defined(CONFIG_NRF_CLOUD_COAP)
    	int err;
    	const char *jwt_buf;
    	struct nrf_cloud_rest_context rest_ctx = {.connect_socket = -1,
    						  .keep_alive = false,
    						  .timeout_ms = NRF_CLOUD_REST_TIMEOUT_NONE,
    						  .rx_buf = rest_api_recv_buf,
    						  .rx_buf_len = sizeof(rest_api_recv_buf),
    						  .fragment_size = 0};
    	jwt_buf = location_utils_nrf_cloud_jwt_generate();
    	if (jwt_buf == NULL) {
    		return;
    	rest_ctx.auth = (char *)jwt_buf;
    	struct nrf_cloud_rest_agnss_request request = {NRF_CLOUD_REST_AGNSS_REQ_CUSTOM,
    						       &agnss_request, NULL, false, 0};
    	struct lte_lc_cells_info net_info = {0};
    	struct lte_lc_cells_info *scan_results;
    	/* Get network info for the A-GNSS location request.
    	 * Timeout value is just some number that should be big enough.
    	scan_cellular_execute(5000, 0);
    	scan_results = scan_cellular_results_get();
    	if (scan_results == NULL) {
    		LOG_WRN("Requesting A-GNSS data without location assistance");
    	} else {
    		net_info.current_cell.mcc = scan_results->current_cell.mcc;
    		net_info.current_cell.mnc = scan_results->current_cell.mnc;
    		net_info.current_cell.id = scan_results->current_cell.id;
    		net_info.current_cell.tac = scan_results->current_cell.tac;
    		net_info.current_cell.phys_cell_id = scan_results->current_cell.phys_cell_id;
    		net_info.current_cell.rsrp = scan_results->current_cell.rsrp;
    		request.net_info = &net_info;
    	struct nrf_cloud_rest_agnss_result result = {agnss_rest_data_buf,
    						     sizeof(agnss_rest_data_buf), 0};
    	err = nrf_cloud_rest_agnss_data_get(&rest_ctx, &request, &result);
    #elif defined(CONFIG_NRF_CLOUD_COAP)
    	err = nrf_cloud_coap_agnss_data_get(&request, &result);
    	if (err) {
    		return;
    	err = nrf_cloud_agnss_process(result.buf, result.agnss_sz);
    	if (err) {
    		LOG_ERR("A-GNSS data processing failed, error: %d", err);
    		return;
    	LOG_DBG("A-GNSS data processed");
    	if (err) {
    #endif /* #elif defined(CONFIG_NRF_CLOUD_REST) || defined(CONFIG_NRF_CLOUD_COAP) */
    #endif /* defined(CONFIG_NRF_CLOUD_AGNSS) && !defined(CONFIG_LOCATION_SERVICE_EXTERNAL) */
    #if defined(CONFIG_NRF_CLOUD_PGPS) && !defined(CONFIG_NRF_CLOUD_MQTT) &&                           \
    static void method_gnss_pgps_request_work_fn(struct k_work *item)
    	int err;
    	struct nrf_cloud_rest_pgps_request request = {.pgps_req = &pgps_request};
    		return;
    	err = nrf_cloud_rest_pgps_data_get(&rest_ctx, &request);
    	struct nrf_cloud_pgps_result file_location = {0};
    	static char host[64];
    	static char path[128];
    	memset(host, 0, sizeof(host));
    	memset(path, 0, sizeof(path));
    	file_location.host = host;
    	file_location.host_sz = sizeof(host);
    	file_location.path = path;
    	file_location.path_sz = sizeof(path);
    	err = nrf_cloud_coap_pgps_url_get(&request, &file_location);
    	if (err) {
    		nrf_cloud_pgps_request_reset();
    		LOG_ERR("nRF Cloud P-GPS request failed, error: %d", err);
    		return;
    	LOG_DBG("P-GPS data requested");
    	err = nrf_cloud_pgps_process(rest_ctx.response, rest_ctx.response_len);
    	err = nrf_cloud_pgps_update(&file_location);
    	if (err) {
    		LOG_ERR("P-GPS data processing failed, error: %d", err);
    		return;
    	LOG_DBG("P-GPS data processed");
    	if (err) {
    	} else {
    		LOG_DBG("P-GPS prediction requested");
    static bool method_gnss_agnss_required(void)
    	int32_t time_since_agnss_req;
    	bool ephe_or_alm_required = false;
    	/* Check if A-GNSS data is needed. */
    	for (int i = 0; i < agnss_request.system_count; i++) {
    		if (agnss_request.system[i].sv_mask_ephe != 0 ||
    		    agnss_request.system[i].sv_mask_alm != 0) {
    			ephe_or_alm_required = true;
    	if (agnss_request.data_flags == 0 && !ephe_or_alm_required) {
    		LOG_DBG("No A-GNSS data types requested");
    		return false;
    	/* A-GNSS data is needed, check if enough time has passed since the last A-GNSS data
    	 * request.
    	if (agnss_req_timestamp != 0) {
    		time_since_agnss_req = k_uptime_get() - agnss_req_timestamp;
    		if (time_since_agnss_req < (AGNSS_REQUEST_MIN_INTERVAL * MSEC_PER_SEC)) {
    			LOG_DBG("Skipping A-GNSS request, time since last request: %d s",
    				time_since_agnss_req / 1000);
    			return false;
    	return true;
    #endif /* CONFIG_NRF_CLOUD_AGNSS */
    #if defined(CONFIG_LOG)
    static const char *get_system_string(uint8_t system_id)
    	switch (system_id) {
    	case NRF_MODEM_GNSS_SYSTEM_INVALID:
    		return "invalid";
    	case NRF_MODEM_GNSS_SYSTEM_GPS:
    		return "GPS";
    	case NRF_MODEM_GNSS_SYSTEM_QZSS:
    		return "QZSS";
    		return "unknown";
    #endif /* CONFIG_LOG */
    /* Triggers A-GNSS data request and/or injection of a P-GPS prediction.
     * Before this function is called, the assistance data need from GNSS must be stored into
     * 'agnss_request'.
     * There are three possible assistance configurations with different behavior:
     * A-GNSS only:
     * Ephemerides, almanacs and additional assistance data is handled by A-GNSS.
     * If any additional assistance data (UTC, Klobuchar, GPS time, integrity or position) is needed,
     * all additional assistance is requested at the same time.
     * A-GNSS and P-GPS:
     * GPS ephemerides are handled by P-GPS.
     * GPS almanacs are handled by A-GNSS, but only if the downloaded P-GPS prediction set is longer
     * than one week.
     * Additional assistance data is handled by A-GNSS.
     * P-GPS only:
     * Ephemerides are handled by P-GPS.
     * Almanacs are not used.
     * GPS time and position assistance are handled by P-GPS.
     * The frequency of A-GNSS data requests is limited to avoid requesting data repeatedly, for
     * example in case the server is down.
     * Almanacs are not used with P-GPS prediction sets up to one week in length, because GNSS always
     * has valid (and more accurate) ephemerides available. With longer prediction sets, the number of
     * satellite ephemerides in the later prediction periods decreases due to accumulated errors,
     * so having almanacs may be beneficial.
    static void method_gnss_assistance_request(void)
    	/* GPS ephemerides come from P-GPS. */
    	pgps_agnss_request.system[0].sv_mask_ephe = agnss_request.system[0].sv_mask_ephe;
    	pgps_agnss_request.data_flags = agnss_request.data_flags;
    	agnss_request.system[0].sv_mask_ephe = 0;
    	if (CONFIG_NRF_CLOUD_PGPS_NUM_PREDICTIONS <= 42) {
    		/* GPS almanacs not needed in this configuration. */
    		agnss_request.system[0].sv_mask_alm = 0;
    	if (IS_ENABLED(CONFIG_NRF_CLOUD_AGNSS)) {
    		/* Time and position come from A-GNSS. */
    		pgps_agnss_request.data_flags = 0;
    	LOG_DBG("P-GPS request sv_mask_ephe: 0x%08x, data_flags 0x%02x",
    		(uint32_t)pgps_agnss_request.system[0].sv_mask_ephe, pgps_agnss_request.data_flags);
    #endif /* CONFIG_NRF_CLOUD_PGPS */
    	if (agnss_request.data_flags != 0) {
    		/* With A-GNSS, if any of the flags in the data_flags field is set, it is
    		 * feasible to request everything at the same time, because of the small amount
    		 * of data.
    		agnss_request.data_flags = NRF_MODEM_GNSS_AGNSS_GPS_UTC_REQUEST |
    					   NRF_MODEM_GNSS_AGNSS_KLOBUCHAR_REQUEST |
    					   NRF_MODEM_GNSS_AGNSS_NEQUICK_REQUEST |
    					   NRF_MODEM_GNSS_AGNSS_GPS_SYS_TIME_AND_SV_TOW_REQUEST |
    					   NRF_MODEM_GNSS_AGNSS_INTEGRITY_REQUEST |
    					   NRF_MODEM_GNSS_AGNSS_POSITION_REQUEST;
    	/* QZSS needs special handling because QZSS ephemerides are valid for a shorter time
    	 * than GPS ephemerides, there are only a few QZSS satellites and GNSS reports unused
    	 * QZSS satellites always as expired.
    	if (agnss_request.system_count > 1) {
    		if (agnss_request.data_flags != 0 || agnss_request.system[0].sv_mask_ephe != 0 ||
    		    agnss_request.system[0].sv_mask_alm != 0) {
    			/* QZSS ephemerides are requested always when other assistance data is
    			 * needed.
    			agnss_request.system[1].sv_mask_ephe = 0x3ff;
    		} else {
    			/* No other assistance is needed. Request QZSS ephemerides anyway if
    			 * all QZSS ephemerides are expired and QZSS assistance is prioritized.
    			if (!(agnss_request.system[1].sv_mask_ephe == 0x3ff &&
    			      IS_ENABLED(CONFIG_LOCATION_METHOD_GNSS_PRIORITIZE_QZSS_ASSISTANCE))) {
    				agnss_request.system[1].sv_mask_ephe = 0x0;
    		/* QZSS almanacs are requested whenever GPS almanacs are requested. */
    		if (agnss_request.system[0].sv_mask_alm != 0) {
    			agnss_request.system[1].sv_mask_alm = 0x3ff;
    		} else {
    			agnss_request.system[1].sv_mask_alm = 0x0;
    #if defined(CONFIG_LOG) /* Flagged to get get_system_string() out of coverage metrics */
    	LOG_DBG("A-GNSS request: data_flags: 0x%02x", agnss_request.data_flags);
    		LOG_DBG("A-GNSS request: %s sv_mask_ephe: 0x%llx, sv_mask_alm: 0x%llx",
    			get_system_string(agnss_request.system[i].system_id),
    			agnss_request.system[i].sv_mask_ephe, agnss_request.system[i].sv_mask_alm);
    	/* Check if A-GNSS data should be requested. If A-GNSS request is not needed, jump to
    	 * P-GPS (if enabled).
    	if (method_gnss_agnss_required()) {
    		enum lte_lc_nw_reg_status reg_status = LTE_LC_NW_REG_NOT_REGISTERED;
    		lte_lc_nw_reg_status_get(&reg_status);
    		if (reg_status == LTE_LC_NW_REG_REGISTERED_HOME ||
    		    reg_status == LTE_LC_NW_REG_REGISTERED_ROAMING) {
    			/* Only store the timestamp when LTE is connected, otherwise it is not
    			 * very likely that the A-GNSS request succeeds.
    			agnss_req_timestamp = k_uptime_get();
    		location_core_event_cb_agnss_request(&agnss_request);
    #else
    		method_gnss_nrf_cloud_agnss_request();
    	if (pgps_agnss_request.system[0].sv_mask_ephe != 0) {
    		/* When A-GNSS is used, the nRF Cloud library also calls this function after
    		 * A-GNSS data has been processed. However, the call happens too late to trigger
    		 * the initial P-GPS data download at the correct stage.
    		if (err) {
    #endif /* defined(CONFIG_NRF_CLOUD_AGNSS) || defined(CONFIG_NRF_CLOUD_PGPS) */
    void method_gnss_event_handler(int event)
    	switch (event) {
    	case NRF_MODEM_GNSS_EVT_PVT:
    		k_work_submit_to_queue(location_core_work_queue_get(), &method_gnss_pvt_work);
    	case NRF_MODEM_GNSS_EVT_NMEA:
    		k_work_submit_to_queue(location_core_work_queue_get(), &method_gnss_nmea_work);
    int method_gnss_cancel(void)
    	int err = nrf_modem_gnss_stop();
    	int sleeping;
    	int rrc_idling;
    	if (elapsed_time_gnss_start_timestamp != 0) {
    		location_data_details_gnss.elapsed_time_gnss =
    			(uint32_t)(k_uptime_get() - elapsed_time_gnss_start_timestamp);
    	if ((err != 0) && (err != -NRF_EPERM)) {
    		LOG_ERR("Failed to stop GNSS, error: %d", err);
    	running = false;
    	/* Cancel any work that has not been started yet */
    	(void)k_work_cancel(&method_gnss_prepare_work);
    	(void)k_work_cancel(&method_gnss_start_work);
    	/* If we are currently not in PSM, i.e., LTE is running, reset the semaphore to unblock
    	 * method_gnss_start_work_fn() and allow the ongoing location request to terminate.
    	 * Otherwise, don't reset the semaphore in order not to lose information about the current
    	 * sleep state.
    	sleeping = k_sem_count_get(&entered_psm_mode);
    	if (!sleeping) {
    	/* If we are currently in RRC connected mode, reset the semaphore to unblock
    	 * RRC state.
    	rrc_idling = k_sem_count_get(&entered_rrc_idle);
    	if (!rrc_idling) {
    	int ret;
    	ret = nrf_cloud_pgps_preemptive_updates();
    	if (ret) {
    		LOG_ERR("Error requesting P-GPS pre-emptive updates: %d", ret);
    	return err;
    int method_gnss_timeout(void)
    	if (insuf_timewin_count == -1 && gnss_config.priority_mode == false) {
    		LOG_WRN("GNSS timed out possibly due to too short GNSS time windows");
    	return method_gnss_cancel();
    static bool method_gnss_psm_enabled(void)
    	int ret = 0;
    	int tau;
    	int active_time;
    	ret = lte_lc_psm_get(&tau, &active_time);
    	if (ret < 0) {
    		LOG_ERR("Cannot get PSM config: %d. Starting GNSS right away.", ret);
    		return false;
    	LOG_DBG("LTE active time: %d seconds", active_time);
    	if (active_time >= 0) {
    		return true;
    	return false;
    static bool method_gnss_entered_psm(void)
    	LOG_DBG("%s", k_sem_count_get(&entered_psm_mode) == 0 ? "Waiting for LTE to enter PSM..."
    							      : "LTE already in PSM");
    	/* Wait for the PSM to start. If semaphore is reset during the waiting
    	 * period, the position request was canceled.
    	if (k_sem_take(&entered_psm_mode, K_MINUTES(SLEEP_WAIT_BACKSTOP)) == -EAGAIN) {
    		if (!running) { /* Location request was cancelled */
    			return false;
    		/* We're still running, i.e., the wait for PSM timed out */
    		LOG_WRN("PSM is configured, but modem did not enter PSM "
    			"in %d minutes. Starting GNSS anyway.",
    			SLEEP_WAIT_BACKSTOP);
    	return true;
    static void method_gnss_modem_sleep_notif_subscribe(uint32_t threshold_ms)
    	int err;
    	err = nrf_modem_at_printf(AT_MDM_SLEEP_NOTIF_START, 0, threshold_ms);
    	if (err) {
    		LOG_ERR("Cannot subscribe to modem sleep notifications, error: %d", err);
    	} else {
    		LOG_DBG("Subscribed to modem sleep notifications");
    #endif /* !CONFIG_NRF_CLOUD_AGNSS */
    static bool method_gnss_allowed_to_start(void)
    	enum lte_lc_system_mode mode;
    	if (lte_lc_system_mode_get(&mode, NULL) != 0) {
    		/* Failed to get system mode, try to start GNSS anyway */
    		return true;
    	/* Don't care about LTE state if we are in GNSS only mode */
    	if (mode == LTE_LC_SYSTEM_MODE_GPS) {
    		return true;
    	LOG_DBG("%s", k_sem_count_get(&entered_rrc_idle) == 0
    		? "Waiting for the RRC connection release for " STRINGIFY(SLEEP_WAIT_BACKSTOP) " minutes..."
    		: "RRC already in idle mode");
    	if (k_sem_take(&entered_rrc_idle, K_MINUTES(SLEEP_WAIT_BACKSTOP)) == -EAGAIN) {
    		/* Semaphore was reset during the waiting period, the position request was canceled.
    		 * Alternatively, timeout occurred and we didn't get to RRC idle mode.
    		return false;
    	/* If A-GNSS is used, a GNSS fix can be obtained fast even in RRC idle mode (without PSM).
    	 * Without A-GNSS, it's practical to wait for the modem to sleep before attempting a fix.
    	if (method_gnss_psm_enabled()) {
    		return method_gnss_entered_psm();
    	return true;
    static uint8_t method_gnss_tracked_satellites(const struct nrf_modem_gnss_pvt_data_frame *pvt_data)
    	uint8_t tracked = 0;
    	for (uint32_t i = 0; i < NRF_MODEM_GNSS_MAX_SATELLITES; i++) {
    		if (pvt_data->sv[i].sv == 0) {
    		tracked++;
    	return tracked;
    static uint8_t method_gnss_satellites_used(const struct nrf_modem_gnss_pvt_data_frame *pvt_data)
    	uint8_t used = 0;
    		if (pvt_data->sv[i].flags & NRF_MODEM_GNSS_SV_FLAG_USED_IN_FIX) {
    			used++;
    	return used;
    static void method_gnss_print_nmea(const struct nrf_modem_gnss_nmea_data_frame *nmea)
    	char local_nmea[NRF_MODEM_GNSS_NMEA_MAX_LEN + 1];
    	strncpy(local_nmea, nmea->nmea_str, NRF_MODEM_GNSS_NMEA_MAX_LEN);
    	local_nmea[NRF_MODEM_GNSS_NMEA_MAX_LEN] = '\0';
    	for (int i = 0; i < NRF_MODEM_GNSS_NMEA_MAX_LEN; i++) {
    		if (local_nmea[i] == '\r' || local_nmea[i] == '\n') {
    			local_nmea[i] = '\0';
    	LOG_WRN("GNSS: NMEA: %s", local_nmea);
    static void method_gnss_print_pvt(const struct nrf_modem_gnss_pvt_data_frame *pvt_data)
    	LOG_DBG("Tracked satellites: %d, fix valid: %s, insuf. time window: %s, "
    		"deadline missed: %s",
    		method_gnss_tracked_satellites(pvt_data),
    		pvt_data->flags & NRF_MODEM_GNSS_PVT_FLAG_FIX_VALID ? "true" : "false",
    		pvt_data->flags & NRF_MODEM_GNSS_PVT_FLAG_NOT_ENOUGH_WINDOW_TIME ? "true" : "false",
    		pvt_data->flags & NRF_MODEM_GNSS_PVT_FLAG_DEADLINE_MISSED ? "true" : "false");
    	/* Print details for each satellite */
    		const struct nrf_modem_gnss_sv *sv_data = &pvt_data->sv[i];
    		LOG_DBG("PRN: %3d, C/N0: %4.1f, in fix: %d, unhealthy: %d", sv_data->sv,
    			sv_data->cn0 / 10.0,
    			sv_data->flags & NRF_MODEM_GNSS_SV_FLAG_USED_IN_FIX ? 1 : 0,
    			sv_data->flags & NRF_MODEM_GNSS_SV_FLAG_UNHEALTHY ? 1 : 0);
    #if defined(CONFIG_NRF_CLOUD_MQTT) || defined(CONFIG_NRF_CLOUD_REST)
    static int method_gnss_nrf_cloud_json_send(char *body)
    	int err;
    	struct nrf_cloud_tx_data mqtt_msg = {
    		.data.ptr = body,
    		.data.len = strlen(body),
    		.qos = MQTT_QOS_1_AT_LEAST_ONCE,
    		.topic_type = NRF_CLOUD_TOPIC_MESSAGE,
    	err = nrf_cloud_send(&mqtt_msg);
    	if (err) {
    		LOG_ERR("MQTT: location data sending failed: %d", err);
    #define REST_DETAILS_RX_BUF_SZ 300 /* No payload in a response, "just" headers */
    	static char rx_buf[REST_DETAILS_RX_BUF_SZ];
    	static char device_id[NRF_CLOUD_CLIENT_ID_MAX_LEN + 1];
    	static struct nrf_cloud_rest_context rest_ctx = {.connect_socket = -1,
    							 .rx_buf = rx_buf,
    							 .rx_buf_len = sizeof(rx_buf),
    	err = nrf_cloud_client_id_get(device_id, sizeof(device_id));
    	if (err == 0) {
    		err = nrf_cloud_rest_send_device_message(&rest_ctx, device_id, body, false, NULL);
    		if (err) {
    			LOG_ERR("REST: location data sending failed: %d", err);
    	} else {
    		LOG_ERR("Failed to get device ID, error: %d", err);
    	return err;
    static void method_gnss_nrf_cloud_pos_send(struct nrf_modem_gnss_pvt_data_frame *pvt_data)
    #define CLOUD_GNSS_HEADING_ACC_LIMIT (float)60.0
    	int err = 0;
    	struct nrf_cloud_gnss_data gnss_data = {
    		.type = NRF_CLOUD_GNSS_TYPE_PVT,
    		.pvt = {
    			.lat = pvt_data->latitude,
    			.lon = pvt_data->longitude,
    			.accuracy = pvt_data->accuracy,
    			.alt = pvt_data->altitude,
    			.speed = pvt_data->speed,
    			.heading = pvt_data->heading,
    			.has_alt = 1,
    			.has_speed = pvt_data->flags & NRF_MODEM_GNSS_PVT_FLAG_VELOCITY_VALID,
    			.has_heading =
    				pvt_data->heading_accuracy < CLOUD_GNSS_HEADING_ACC_LIMIT ? 1 : 0,
    	const struct tm time = {
    		.tm_year = pvt_data->datetime.year - 1900,
    		.tm_mon = pvt_data->datetime.month - 1,
    		.tm_mday = pvt_data->datetime.day,
    		.tm_hour = pvt_data->datetime.hour,
    		.tm_min = pvt_data->datetime.minute,
    		.tm_sec = pvt_data->datetime.seconds,
    	gnss_data.ts_ms = timeutil_timegm64(&time) * 1000 + pvt_data->datetime.ms;
    	char *json_str = NULL;
    	cJSON *gnss_data_obj = NULL;
    	gnss_data_obj = cJSON_CreateObject();
    	if (gnss_data_obj == NULL) {
    		LOG_ERR("Failed to encode GNSS position data, out of memory");
    		err = -ENOMEM;
    		goto cleanup;
    	/* Encode the GNSS location data */
    	err = nrf_cloud_gnss_msg_json_encode(&gnss_data, gnss_data_obj);
    	if (err) {
    		LOG_ERR("Failed to encode GNSS data to json");
    		goto cleanup;
    	json_str = cJSON_PrintUnformatted(gnss_data_obj);
    	if (json_str == NULL) {
    		err = -ENOMEM;
    		goto cleanup;
    	LOG_DBG("Sending acquired GNSS location to nRF Cloud, body: %s", json_str);
    	method_gnss_nrf_cloud_json_send(json_str);
    cleanup:
    	if (gnss_data_obj) {
    		cJSON_Delete(gnss_data_obj);
    	if (json_str) {
    		cJSON_free(json_str);
    	/* CoAP is handled differently because we are sending CBOR instead of JSON data */
    	LOG_DBG("Sending acquired GNSS location to nRF Cloud with CoAP");
    	err = nrf_cloud_coap_location_send(&gnss_data, true);
    	if (err) {
    		LOG_ERR("CoAP: location data sending failed, %d", err);
    static void method_gnss_nmea_work_fn(struct k_work *item)
    	struct nrf_modem_gnss_nmea_data_frame nmea_data;
    	if (!running) {
    		/* Cancel has already been called, so ignore the notification. */
    		return;
    	if (nrf_modem_gnss_read(&nmea_data, sizeof(nmea_data), NRF_MODEM_GNSS_DATA_NMEA) != 0) {
    		LOG_ERR("Failed to read NMEA data from GNSS");
    		return;
    	method_gnss_print_nmea(&nmea_data);
    static void method_gnss_pvt_work_fn(struct k_work *item)
    	struct nrf_modem_gnss_pvt_data_frame pvt_data;
    	static struct location_data location_result = {0};
    	if (!running) {
    		return;
    	if (nrf_modem_gnss_read(&pvt_data, sizeof(pvt_data), NRF_MODEM_GNSS_DATA_PVT) != 0) {
    		LOG_ERR("Failed to read PVT data from GNSS");
    		location_core_event_cb_error();
    		return;
    	method_gnss_print_pvt(&pvt_data);
    	location_data_details_gnss.pvt_data = pvt_data;
    	location_data_details_gnss.satellites_tracked = method_gnss_tracked_satellites(&pvt_data);
    	location_data_details_gnss.satellites_used = method_gnss_satellites_used(&pvt_data);
    	/* Store fix data only if we get a valid fix. Thus, the last valid data is always kept
    	 * in memory and it is not overwritten in case we get an invalid fix.
    	if (pvt_data.flags & NRF_MODEM_GNSS_PVT_FLAG_FIX_VALID) {
    		fixes_remaining--;
    		location_result.latitude = pvt_data.latitude;
    		location_result.longitude = pvt_data.longitude;
    		location_result.accuracy = pvt_data.accuracy;
    		location_result.datetime.valid = true;
    		location_result.datetime.year = pvt_data.datetime.year;
    		location_result.datetime.month = pvt_data.datetime.month;
    		location_result.datetime.day = pvt_data.datetime.day;
    		location_result.datetime.hour = pvt_data.datetime.hour;
    		location_result.datetime.minute = pvt_data.datetime.minute;
    		location_result.datetime.second = pvt_data.datetime.seconds;
    		location_result.datetime.ms = pvt_data.datetime.ms;
    		if (fixes_remaining <= 0) {
    			/* We are done, stop GNSS and publish the fix. */
    			location_core_event_cb(&location_result);
    			method_gnss_nrf_cloud_pos_send(&pvt_data);
    	} else if (gnss_config.visibility_detection && !visibility_detection_done &&
    		   pvt_data.execution_time >= VISIBILITY_DETECTION_EXEC_TIME) {
    		if (method_gnss_tracked_satellites(&pvt_data) < VISIBILITY_DETECTION_SAT_LIMIT) {
    			LOG_DBG("GNSS visibility obstructed, canceling");
    		visibility_detection_done = true;
    	/* Trigger GNSS priority mode if GNSS indicates that it is not getting long enough time
    	 * windows for 5 consecutive epochs. If the priority mode option is not enabled, a trace
    	 * is output in case of a timeout to warn that GNSS may be getting too short time windows
    	 * to get a fix.
    	if ((pvt_data.flags & NRF_MODEM_GNSS_PVT_FLAG_NOT_ENOUGH_WINDOW_TIME) &&
    	    (insuf_timewin_count >= 0)) {
    		insuf_timewin_count++;
    		if (insuf_timewin_count == 5) {
    			if (gnss_config.priority_mode) {
    				LOG_DBG("GNSS is not getting long enough time windows. "
    					"Triggering GNSS priority mode.");
    				int err = nrf_modem_gnss_prio_mode_enable();
    				if (err) {
    					LOG_ERR("Unable to trigger GNSS priority mode.");
    			/* Special value -1 indicates that the condition has been already triggered.
    			 * Allow triggering priority mode only once in order to not block LTE
    			 * operation excessively.
    			insuf_timewin_count = -1;
    	} else if (insuf_timewin_count > 0) {
    		/* GNSS must indicate that it is not getting long enough time windows for 5
    		 * consecutive epochs to trigger priority mode.
    		insuf_timewin_count = 0;
    	location_core_event_cb_pgps_request(&pgps_request);
    static void method_gnss_pgps_init(void)
    	int err;
    	static bool initialized;
    	if (!initialized) {
    		struct nrf_cloud_pgps_init_param param = {
    			.event_handler = method_gnss_pgps_handler,
    			/* storage is defined by CONFIG_NRF_CLOUD_PGPS_STORAGE */
    			.storage_base = 0u,
    			.storage_size = 0u};
    		err = nrf_cloud_pgps_init(&param);
    		if (err) {
    			LOG_ERR("Failed to initialize P-GPS, error: %d", err);
    		} else {
    			initialized = true;
    /* Processes A-GNSS expiry data from nrf_modem_gnss_agnss_expiry_get() function.
     * This function is only used with modem firmware v1.3.2 or later. With older modem firmware
     * versions, the logic in this function is handled by GNSS.
     * GNSS gives the expiration times in seconds, so logic is needed to process the expiration times
     * and to determine which data (if any) should be requested.
     * Ephemerides:
     * Each satellite has its own ephemeris expiration time. The code goes though all satellites and
     * checks whether its ephemeris has expired or is going to expire. If there are enough satellites
     * with expired ephemerides, ephemerides for all satellites are requested. The time when an
     * ephemeris is considered expired and the threshold for the number of expired satellites is
     * different with A-GNSS and P-GPS. The used constants are described in the beginning of the file.
     * Almanacs:
     * Each satellite has its own almanac expiration time. The code goes though all satellites and
     * checks whether its almanac has expired or is going to expire. If there are enough satellites
     * with expired almanacs, almanacs for all satellites are requested.
     * Other assistance data:
     * For other assistance data, the same A-GNSS expiration threshold is used if expiry time is
     * provided by GNSS. For some data, there is only a flag indicating whether the data is needed or
     * not.
    static void method_gnss_agnss_expiry_process(const struct nrf_modem_gnss_agnss_expiry *agnss_expiry)
    	uint16_t ephe_expiry_threshold;
    	uint8_t expired_ephes_min_count;
    	uint8_t expired_gps_ephes = 0;
    	uint8_t expired_gps_alms = 0;
    	bool qzss_supported = false;
    	uint32_t expired_qzss_ephe_mask = 0;
    	uint32_t expired_qzss_alm_mask = 0;
    	memset(&agnss_request, 0, sizeof(agnss_request));
    	if (IS_ENABLED(CONFIG_NRF_CLOUD_PGPS)) {
    		ephe_expiry_threshold = PGPS_EXPIRY_THRESHOLD;
    	} else {
    		ephe_expiry_threshold = AGNSS_EXPIRY_THRESHOLD;
    	for (int i = 0; i < agnss_expiry->sv_count; i++) {
    		if (agnss_expiry->sv[i].system_id == NRF_MODEM_GNSS_SYSTEM_GPS) {
    			if (agnss_expiry->sv[i].ephe_expiry <= ephe_expiry_threshold) {
    				expired_gps_ephes++;
    			if (agnss_expiry->sv[i].alm_expiry <= AGNSS_EXPIRY_THRESHOLD) {
    				expired_gps_alms++;
    		if (agnss_expiry->sv[i].system_id == NRF_MODEM_GNSS_SYSTEM_QZSS) {
    			qzss_supported = true;
    			/* GNSS supports QZSS PRNs 193...202. Only part of these are currently
    			 * deployed, so even after all available QZSS ephemerides and almanancs
    			 * have been injected, GNSS reports the unused ones as expired.
    			/* QZSS ephemerides are valid for a maximum of two hours, so no expiry
    			 * is used here.
    			if (agnss_expiry->sv[i].ephe_expiry == 0) {
    				expired_qzss_ephe_mask |=
    					1 << (agnss_expiry->sv[i].sv_id - FIRST_QZSS_PRN);
    			if (agnss_expiry->sv[i].alm_expiry < AGNSS_EXPIRY_THRESHOLD) {
    				expired_qzss_alm_mask |=
    		expired_ephes_min_count = PGPS_EPHE_MIN_COUNT;
    	} else {
    		expired_ephes_min_count = AGNSS_EPHE_MIN_COUNT;
    	agnss_request.system_count = 1;
    	agnss_request.system[0].system_id = NRF_MODEM_GNSS_SYSTEM_GPS;
    	if (expired_gps_ephes >= expired_ephes_min_count) {
    		agnss_request.system[0].sv_mask_ephe = 0xffffffff;
    	if (expired_gps_alms >= AGNSS_ALM_MIN_COUNT) {
    		agnss_request.system[0].sv_mask_alm = 0xffffffff;
    	if (agnss_expiry->utc_expiry <= AGNSS_EXPIRY_THRESHOLD) {
    		agnss_request.data_flags |= NRF_MODEM_GNSS_AGNSS_GPS_UTC_REQUEST;
    	if (agnss_expiry->klob_expiry <= AGNSS_EXPIRY_THRESHOLD) {
    		agnss_request.data_flags |= NRF_MODEM_GNSS_AGNSS_KLOBUCHAR_REQUEST;
    	if (agnss_expiry->neq_expiry <= AGNSS_EXPIRY_THRESHOLD) {
    		agnss_request.data_flags |= NRF_MODEM_GNSS_AGNSS_NEQUICK_REQUEST;
    	if (agnss_expiry->data_flags & NRF_MODEM_GNSS_AGNSS_GPS_SYS_TIME_AND_SV_TOW_REQUEST) {
    		agnss_request.data_flags |= NRF_MODEM_GNSS_AGNSS_GPS_SYS_TIME_AND_SV_TOW_REQUEST;
    	if (agnss_expiry->integrity_expiry <= AGNSS_EXPIRY_THRESHOLD) {
    		agnss_request.data_flags |= NRF_MODEM_GNSS_AGNSS_INTEGRITY_REQUEST;
    	/* Position is reported as being valid for 2h. The uncertainty increases with time,
    	 * but in practice the position remains usable for a longer time. Because of this no
    	 * margin is used when checking if position assistance is needed.
    	 * Position is only requested when also some other assistance data is needed.
    	if (agnss_expiry->position_expiry == 0 &&
    	    (agnss_request.system[0].sv_mask_ephe != 0 ||
    	     agnss_request.system[0].sv_mask_alm != 0 || agnss_request.data_flags != 0)) {
    		agnss_request.data_flags |= NRF_MODEM_GNSS_AGNSS_POSITION_REQUEST;
    	if (qzss_supported) {
    		agnss_request.system_count = 2;
    		agnss_request.system[1].system_id = NRF_MODEM_GNSS_SYSTEM_QZSS;
    		agnss_request.system[1].sv_mask_ephe = expired_qzss_ephe_mask;
    		agnss_request.system[1].sv_mask_alm = expired_qzss_alm_mask;
    	LOG_DBG("GPS: Expired ephemerides: %d, almanacs: %d", expired_gps_ephes, expired_gps_alms);
    	LOG_DBG("A-GNSS data need: data_flags: 0x%02x", agnss_request.data_flags);
    		LOG_DBG("A-GNSS data need: %s sv_mask_ephe: 0x%llx, sv_mask_alm: 0x%llx",
    /* Queries assistance data need from GNSS. */
    static void method_gnss_assistance_data_need_get(void)
    	int err;
    	struct nrf_modem_gnss_agnss_expiry agnss_expiry;
    	err = nrf_modem_gnss_agnss_expiry_get(&agnss_expiry);
    	if (err) {
    		LOG_ERR("nrf_modem_gnss_agnss_expiry_get() failed, error: %d", err);
    		return;
    	method_gnss_agnss_expiry_process(&agnss_expiry);
    static void method_gnss_prepare_work_fn(struct k_work *work)
    	/* P-GPS is only initialized here because initialization may trigger P-GPS data request
    	 * which would fail if the device is not registered to a network.
    	method_gnss_pgps_init();
    	method_gnss_assistance_data_need_get();
    	/* Request assistance data if needed. */
    	method_gnss_assistance_request();
    	if (!running) {
    		/* Location request has been cancelled. */
    		return;
    	/* GNSS start work is injected into the work queue only after GNSS assistance data need
    	 * has been handled to ensure correct execution order in the work queue. If necessary,
    	 * the library should emit both LOCATION_EVT_GNSS_ASSISTANCE_REQUEST and
    	 * LOCATION_EVT_GNSS_PREDICTION_REQUEST events before the GNSS start work gets to execute.
    	k_work_submit_to_queue(location_core_work_queue_get(), &method_gnss_start_work);
    static void method_gnss_start_work_fn(struct k_work *work)
    	int err = 0;
    	/* Configure GNSS to continuous tracking mode */
    	err = nrf_modem_gnss_fix_interval_set(1);
    	if (err == -NRF_EACCES) {
    		LOG_WRN("Modem's system or functional mode doesn't allow GNSS usage");
    #if defined(CONFIG_NRF_CLOUD_AGNSS_ELEVATION_MASK)
    	err |= nrf_modem_gnss_elevation_threshold_set(CONFIG_NRF_CLOUD_AGNSS_ELEVATION_MASK);
    	/* By default we take the first fix. */
    	fixes_remaining = 1;
    	visibility_detection_done = false;
    	uint8_t use_case = NRF_MODEM_GNSS_USE_CASE_MULTIPLE_HOT_START;
    	switch (gnss_config.accuracy) {
    	case LOCATION_ACCURACY_LOW:
    		use_case |= NRF_MODEM_GNSS_USE_CASE_LOW_ACCURACY;
    	case LOCATION_ACCURACY_NORMAL:
    	case LOCATION_ACCURACY_HIGH:
    		/* In high accuracy mode, use the configured fix count. */
    		fixes_remaining = gnss_config.num_consecutive_fixes;
    	err |= nrf_modem_gnss_use_case_set(use_case);
    	if (err) {
    		LOG_ERR("Failed to configure GNSS");
    		running = false;
    		return;
    	if (!method_gnss_allowed_to_start()) {
    		/* Location request was cancelled while waiting for RRC idle or PSM.
    		 * Alternatively, RRC idle waiting time expired and we will not try to get
    		 * GNSS fix as it will not succeed and we can still do a fallback to other
    		 * methods.
    		if (running) {
    			LOG_WRN("GNSS not allowed to start");
    			running = false;
    		return;
    	err = nrf_modem_gnss_start();
    	if (err) {
    		LOG_ERR("Failed to start GNSS, error: %d", err);
    		running = false;
    		return;
    	elapsed_time_gnss_start_timestamp = k_uptime_get();
    	location_core_timer_start(gnss_config.timeout);
    int method_gnss_location_get(const struct location_request_info *request)
    	int err;
    	gnss_config = *request->gnss;
    	memset(&location_data_details_gnss, 0, sizeof(location_data_details_gnss));
    	elapsed_time_gnss_start_timestamp = 0;
    	/* GNSS event handler is already set once in method_gnss_init(). If no other thread is
    	 * using GNSS, setting it again is not needed.
    	err = nrf_modem_gnss_event_handler_set(method_gnss_event_handler);
    	if (err) {
    		LOG_ERR("Failed to set GNSS event handler, error: %d", err);
    		return err;
    	running = true;
    	k_work_submit_to_queue(location_core_work_queue_get(), &method_gnss_prepare_work);
    	return 0;
    void method_gnss_details_get(struct location_data_details *details)
    	details->gnss = location_data_details_gnss;
    int method_gnss_init(void)
    	int err;
    	running = false;
    	if (err) {
    		return err;
    	k_work_init(&method_gnss_pvt_work, method_gnss_pvt_work_fn);
    	k_work_init(&method_gnss_nmea_work, method_gnss_nmea_work_fn);
    	k_work_init(&method_gnss_prepare_work, method_gnss_prepare_work_fn);
    	k_work_init(&method_gnss_start_work, method_gnss_start_work_fn);
    	k_work_init(&method_gnss_pgps_ext_work, method_gnss_pgps_ext_work_fn);
    #if !defined(CONFIG_NRF_CLOUD_MQTT) && !defined(CONFIG_LOCATION_SERVICE_EXTERNAL)
    	k_work_init(&method_gnss_pgps_request_work, method_gnss_pgps_request_work_fn);
    	k_work_init(&method_gnss_inject_pgps_work, method_gnss_inject_pgps_work_fn);
    	k_work_init(&method_gnss_notify_pgps_work, method_gnss_notify_pgps_work_fn);
    	/* Subscribe to sleep notification to monitor when modem enters power saving mode */
    	method_gnss_modem_sleep_notif_subscribe(MIN_SLEEP_DURATION_FOR_STARTING_GNSS);
    	lte_lc_register_handler(method_gnss_lte_ind_handler);
    #if !defined(CONFIG_LOCATION_METHOD_CELLULAR) && defined(CONFIG_NRF_CLOUD_AGNSS)
    	/* Cellular location method is disabled, but GNSS method uses the cellular scan
    	 * functionality for A-GNSS request. The module needs to be initialized explicitly, because
    	 * init is not called by core.
    	scan_cellular_init();
    	return 0;
  • Hi
    Okay, another developer came back form Easter holiday this week, and thinks we should have another go at enabling all NMEA messages in the application. Try enabling NMEAs like the following:
    /* Enable all supported NMEA messages. */
      uint16_t nmea_mask = NRF_MODEM_GNSS_NMEA_RMC_MASK |
               NRF_MODEM_GNSS_NMEA_GGA_MASK |
               NRF_MODEM_GNSS_NMEA_GLL_MASK |
               NRF_MODEM_GNSS_NMEA_GSA_MASK |
               NRF_MODEM_GNSS_NMEA_GSV_MASK;
      if (nrf_modem_gnss_nmea_mask_set(nmea_mask) != 0) {
        LOG_ERR("Failed to set GNSS NMEA mask");
        return -1;
    Simon
  • In one of the init functions before you start the radio/modem.
    Simon
