Crypto operations to generate key pair when TFM profile is set to minimal.
Hi, I am using NRF connect sdk 2.6.1 and I am wondering what is the best way to run crypto operations when using TFM profile type minimal and building for nrf9160_ns. TFM_PROFILE_TYPE_NOT_SET takes up too much space but it seems there is no way to generate keys pair without it.
https://docs.nordicsemi.com/bundle/ncs-2.3.0/page/tfm/technical_references/design_docs/profiles/tfm_profile_small.html
This says that the minimal profile supports:
Symmetric cipher only
Cipher suite for symmetric-key algorithms based protocols, such as cipher suites defined in TLS pre-shared key (TLS-PSK) [1].
    Advanced Encryption Standard (AES) as symmetric crypto algorithm
    SHA256 as Hash function
    HMAC as Message Authentication Code algorithm
while the full profile supports:
        Support both symmetric ciphers and asymmetric ciphers
        Asymmetric key based cipher suites defined in TLS 1.2 [5] to support direct secure connection to major CSPs, including
                Authenticated Encryption with Associated Data (AEAD) algorithm
                Asymmetric key algorithm based signature and verification
                Public-key cryptography based key exchange
                Hash function
                HMAC for default Pseudorandom Function (PRF)
        Asymmetric digital signature and verification for Initial Attestation Token (IAT)
        Asymmetric algorithms for firmware image signature verification
        Key derivation
I have tried to generate the key pair using only mbedtls library but it seems like there is a lot missing in the nrf implementation. I am not able to use entropy at all, when i enable it with CONFIG_MBEDTLS_ENTROPY_C=y
i get:
warning: MBEDTLS_ENTROPY_C (defined at
ncs/v2.6.1/nrf/subsys/net/openthread/Kconfig.defconfig:138,
ncs/v2.6.1/nrf/subsys/nrf_security/Kconfig.legacy:350) was assigned the value 'y' but
got the value 'n'. Check these unsatisfied dependencies: (NET_L2_OPENTHREAD ||
(!MBEDTLS_PSA_CRYPTO_EXTERNAL_RNG && MBEDTLS_LEGACY_CRYPTO_C && NRF_SECURITY)) (=n). See
http://docs.zephyrproject.org/latest/kconfig.html#CONFIG_MBEDTLS_ENTROPY_C and/or look up
MBEDTLS_ENTROPY_C in the menuconfig/guiconfig interface. The Application Development Primer, Setting
Configuration Values, and Kconfig - Tips and Best Practices sections of the manual might be helpful
too.
and that makes it impossible to use this:
github.com/.../gen_key.c
Is there any other recommended way to do it or samples that i could look at?
Or is there any sample that describes a way to get a minimal working example with the profile set to NOT_SET?
  • Hi sorry for the late response but i also went with the software AES (for now), i could not find any other way to get it to work without wasting ram memory.
  • But if i use TFM_PROFILE_TYPE_MINIMAL and then set:
    CONFIG_TFM_PARTITION_PROTECTED_STORAGE=y
    CONFIG_TFM_PARTITION_CRYPTO=y
    i get:
    warning: TFM_PARTITION_PROTECTED_STORAGE (defined at /home/marcus/ncs/v2.6.1/nrf/modules/trusted-
    firmware-m/Kconfig.tfm.defconfig:69, modules/trusted-firmware-m/Kconfig.tfm.partitions:8,
    modules/trusted-firmware-m/Kconfig.tfm.partitions:8) was assigned the value 'y' but got the value
    'n'. See http://docs.zephyrproject.org/latest/kconfig.html#CONFIG_TFM_PARTITION_PROTECTED_STORAGE
    and/or look up TFM_PARTITION_PROTECTED_STORAGE in the menuconfig/guiconfig interface. The
    Application Development Primer, Setting Configuration Values, and Kconfig - Tips and Best Practices
    sections of the manual might be helpful too.
    and this:
    psa_status_t status = psa_crypto_init();
    psa_set_key_usage_flags(&key_attributes, PSA_KEY_USAGE_ENCRYPT);
    psa_set_key_algorithm(&key_attributes, PSA_ALG_ECB_NO_PADDING);
    psa_set_key_type(&key_attributes, PSA_KEY_TYPE_AES);
    psa_set_key_bits(&key_attributes, 16 * 8);
    status = psa_import_key(&key_attributes, p_key, 16, &key_id);
        if (status != PSA_SUCCESS) {
            LOG_ERR("Failed to import key: %d", status);
            return;
    still returns -134
    so what is it that is possible to configure?
  • The missing information is a fine grained table, which shows, how much ram/flash is required for each functions/profiles. Without such a table it's then left to the user, to find that out. Unfortunately, as this thread shows, this comes with a larger working time and unsatisfying results. Maybe it requires even more time, to get better results, but as this thread also shows, plain software solutions aren't that bad.
  • CONFIG_TFM_PROFILE_TYPE_NOT_SET=y
    CONFIG_TFM_PARTITION_PLATFORM=n
    CONFIG_TFM_PARTITION_CRYPTO=n
    CONFIG_TFM_PARTITION_PROTECTED_STORAGE=n
    CONFIG_TFM_PARTITION_INTERNAL_TRUSTED_STORAGE=n
    with this configuration i get:
    fatal error: tfm_ioctl_api.h: No such file or directory
       10 | #include "tfm_ioctl_api.h"
    if i then set:
    CONFIG_TFM_PARTITION_PLATFORM=y
    i get:
    /ncs/toolchains/2be090971e/opt/zephyr-sdk/arm-zephyr-eabi/bin/../lib/gcc/arm-zephyr-eabi/12.2.0/../../../../arm-zephyr-eabi/bin/ld: platform/libplatform_s.a(flash_otp_nv_counters_backend.o): in function `erase_flash_region':
    /ncs/v2.6.1/modules/tee/tf-m/trusted-firmware-m/platform/ext/common/template/flash_otp_nv_counters_backend.c:251: undefined reference to `Driver_FLASH0'
    /ncs/toolchains/2be090971e/opt/zephyr-sdk/arm-zephyr-eabi/bin/../lib/gcc/arm-zephyr-eabi/12.2.0/../../../../arm-zephyr-eabi/bin/ld: platform/libplatform_s.a(flash_otp_nv_counters_backend.o): in function `copy_flash_region':
    /ncs/v2.6.1/modules/tee/tf-m/trusted-firmware-m/platform/ext/common/template/flash_otp_nv_counters_backend.c:277: undefined reference to `Driver_FLASH0'
    /ncs/toolchains/2be090971e/opt/zephyr-sdk/arm-zephyr-eabi/bin/../lib/gcc/arm-zephyr-eabi/12.2.0/../../../../arm-zephyr-eabi/bin/ld: platform/libplatform_s.a(flash_otp_nv_counters_backend.o): in function `read_otp_nv_counters_flash':
    /ncs/v2.6.1/modules/tee/tf-m/trusted-firmware-m/platform/ext/common/template/flash_otp_nv_counters_backend.c:139: undefined reference to `Driver_FLASH0'
    /ncs/toolchains/2be090971e/opt/zephyr-sdk/arm-zephyr-eabi/bin/../lib/gcc/arm-zephyr-eabi/12.2.0/../../../../arm-zephyr-eabi/bin/ld: platform/libplatform_s.a(flash_otp_nv_counters_backend.o): in function `copy_data_into_block':
    /ncs/v2.6.1/modules/tee/tf-m/trusted-firmware-m/platform/ext/common/template/flash_otp_nv_counters_backend.c:330: undefined reference to `Driver_FLASH0'
    /ncs/toolchains/2be090971e/opt/zephyr-sdk/arm-zephyr-eabi/bin/../lib/gcc/arm-zephyr-eabi/12.2.0/../../../../arm-zephyr-eabi/bin/ld: platform/libplatform_s.a(flash_otp_nv_counters_backend.o): in function `init_otp_nv_counters_flash':
    /ncs/v2.6.1/modules/tee/tf-m/trusted-firmware-m/platform/ext/common/template/flash_otp_nv_counters_backend.c:213: undefined reference to `Driver_FLASH0'
    if i also set:
    CONFIG_TFM_PARTITION_INTERNAL_TRUSTED_STORAGE=y
    i get:
    /ncs/toolchains/2be090971e/opt/zephyr-sdk/arm-zephyr-eabi/bin/../lib/gcc/arm-zephyr-eabi/12.2.0/../../../../arm-zephyr-eabi/bin/ld.bfd: zephyr/drivers/entropy/libdrivers__entropy.a(entropy_psa_crypto.c.obj): in function `entropy_psa_crypto_rng_get_entropy':
    ncs/v2.6.1/zephyr/drivers/entropy/entropy_psa_crypto.c:35: undefined reference to `psa_generate_random'
    /ncs/toolchains/2be090971e/opt/zephyr-sdk/arm-zephyr-eabi/bin/../lib/gcc/arm-zephyr-eabi/12.2.0/../../../../arm-zephyr-eabi/bin/ld.bfd: zephyr/drivers/entropy/libdrivers__entropy.a(entropy_psa_crypto.c.obj): in function `entropy_psa_crypto_rng_init':
    /ncs/v2.6.1/zephyr/drivers/entropy/entropy_psa_crypto.c:19: undefined reference to `psa_crypto_init'
    collect2: error: ld returned 1 exit status
    if i also set:
    it builds and now i get:
    [194/198] Linking C executable bin/tfm_s.axf
               FLASH:       64916 B       256 KB     24.76%
                 RAM:       45928 B        88 KB     50.97%
    [336/338] Linking C executable zephyr/zephyr.elf
               FLASH:      127852 B       704 KB     17.74%
                 RAM:       39376 B     154264 B     25.53%
            IDT_LIST:          0 GB        32 KB      0.00%
    Is this the smallest i can get that still lets me use psa crypto operations and trusted storage?
    CONFIG_TFM_CMAKE_BUILD_TYPE_MINSIZEREL=y
    CONFIG_TFM_PARTITION_INITIAL_ATTESTATION=n
    CONFIG_TFM_SECURE_UART0=n
    CONFIG_TFM_LOG_LEVEL_SILENCE=y
    CONFIG_TFM_EXCEPTION_INFO_DUMP=n
    CONFIG_TFM_ITS_STACK_SIZE=0x400
    CONFIG_TFM_CRYPTO_PARTITION_STACK_SIZE=0x400
    #CONFIG_TFM_ITS_STACK_SIZE=0x400
    #CONFIG_TFM_CRYPTO_PARTITION_STACK_SIZE=0x400
    CONFIG_TFM_CRYPTO_BUILTIN_KEYS=n
    CONFIG_TFM_CRYPTO_CONC_OPER_NUM=4
    CONFIG_TFM_CRYPTO_IOVEC_BUFFER_SIZE=2048
    CONFIG_TFM_CRYPTO_ENGINE_BUF_SIZE=2048
    CONFIG_ASSERT=n
    CONFIG_ASSERT_VERBOSE=n
    CONFIG_NRF_SECURITY=y
    CONFIG_PSA_CRYPTO_DRIVER_CC3XX=y
    CONFIG_PSA_CRYPTO_DRIVER_OBERON=n
    # Entropy
    CONFIG_ENTROPY_GENERATOR=y
    # Enable AES
    CONFIG_PSA_WANT_KEY_TYPE_AES=y
    CONFIG_PSA_WANT_AES_KEY_SIZE_128=y
    # Enable ECB
    CONFIG_PSA_WANT_ALG_ECB_NO_PADDING=y
    # Disable everything else
    CONFIG_PSA_WANT_ALG_CBC_MAC=n
    CONFIG_PSA_WANT_KEY_TYPE_ECC_KEY_PAIR=n
    CONFIG_PSA_WANT_KEY_TYPE_HMAC=n
    CONFIG_PSA_WANT_KEY_TYPE_DERIVE=n
    CONFIG_PSA_WANT_ALG_CBC_NO_PADDING=n
    CONFIG_PSA_WANT_ALG_CTR=n
    CONFIG_PSA_WANT_ALG_GCM=n
    CONFIG_PSA_WANT_ALG_CCM=n
    CONFIG_PSA_WANT_ALG_CFB=n
    CONFIG_PSA_WANT_ALG_OFB=n
    CONFIG_PSA_WANT_ALG_CMAC=n
    CONFIG_PSA_WANT_ALG_HMAC=n
    CONFIG_PSA_WANT_ALG_SHA_1=n
    CONFIG_PSA_WANT_ALG_SHA_256=n
    CONFIG_PSA_WANT_ALG_SHA_384=n
    CONFIG_PSA_WANT_ALG_SHA_512=n
    CONFIG_PSA_WANT_ALG_RSA_PKCS1V15_SIGN_RAW=n
    CONFIG_PSA_WANT_ALG_RSA_PSS=n
    CONFIG_PSA_WANT_ALG_RSA_OAEP=n
    CONFIG_PSA_WANT_ALG_ECDSA=n
    CONFIG_PSA_WANT_ALG_DETERMINISTIC_ECDSA=n
    CONFIG_PSA_WANT_ALG_STREAM_CIPHER=n
    CONFIG_PSA_WANT_KEY_TYPE_RAW_DATA=n
    CONFIG_PSA_WANT_ALG_TLS12_PSK_TO_MS=n
    CONFIG_PSA_WANT_KEY_TYPE_CHACHA20=n
    CONFIG_PSA_WANT_ALG_CHACHA20_POLY1305=n
    with these configs i am able to get it down to:
               FLASH:       64356 B      97792 B     65.81%
                 RAM:       19436 B        48 KB     39.54%
    It would be nice to be able to loose 356 bytes of flash memory so that I can shrink the static configuration but i have not find a way to get it lower.
