High current consumption with LDO regulator mode on nRF54L SoC
We developed a custom board based on the nRF54L15 SoC. We realized many current consumption tests with regulator configured in DC/DC mode. These measurements are in line with the SoC datasheet. Then we decided to switch the regulator in LDO mode since this configuration will be used in the final version as we cannot embed large inductors in our design. At this point we noticed that the current consumption is really high during sleep mode.
In order to confirm this, I did the same comparative on a nRF54L15DK evaluation kit. To realize good measurement in low power mode, I performed the followings steps :
  • First I disabled the VCOM0, VCOM1 and LEDs power using the nRF Connect Board Configurator application.
  • I set up the DK, accordingly to the user guide, using a Power Profiler kit configured in ampere meter.
  • For the firmware part, I started from the code example provided in the Lesson 2 - Exercise 2 of the Bluetooth Low Energy Fundamentals course that starts a simple advertising process. I just removed all the part relative to the management of LEDs and button.
  • I updated the prj.conf file to disable the console and the log trace :
CONFIG_LOG=n
CONFIG_CONSOLE=n
CONFIG_UART_CONSOLE=n
CONFIG_RTT_CONSOLE=n
  • Finally I disabled useless peripherals by applying a device tree overlay to the default setup :
&uart20 {
    status = "disabled";
&spi00 {
In this case, the SoC still configured in DCDC mode. As depicted by the following current profile, the consumption in sleep mode (measured between 2 advertising sequences) fits with the datasheet {~3 uA).
Then I add the following lines in the device tree overlay to switch the regulator in LDO mode :
(by the way, it seems that no dedicated Kconfig setting is required now for nRF54L15 SoC to switch the regulator mode. But I am not 100% sure)
&vregmain {
      status = "okay";
      regulator-initial-mode = <NRF5X_REG_MODE_LDO>;
In this condition, we can observe the current consumption during the sleep mode is quite high (> 90 uA), while I was expecting something similar !
I would like to understand this is due to a bad project setting, or if I missed something important in the nRF54L15 datasheet or errata concerning the current consumption in LDO mode ?
Strangely, it appears that the Online Power Profiler tool provided on the Nordic DevZone avoids the user to deselect the DCDC regulator option to perform simulations, unlike the others nRF SoC !
    nRF54L15 is not designed to run in LDO mode. DCDC should always be used.
    That's why. we call it LDO only mode, when DCDC is enabled, the regulator is automatically switching between LDO and DCDC depending on current consumption.
     So, in DCDC mode, both LDO mode and DCDC mode is being used.
     You don't need to set LDO mode exclusively in the devicetree file.
    I am really surprised. The LDO powering mode seems to be supported by the nRF54L datasheet (Here an extract ($ 5.7 Regulators). Nevertheless, this is true the datasheet doesn't provide any reference circuit without inductor !
    The power supply consists of a number of LDO and DC/DC regulators that maximize the system's power efficiency. All system components are powered from the main on-chip voltage regulator, VREGMAIN. The regulator converts the voltage supplied on VDD to internal voltage.
    The main supply voltage is connected to the VDD pin.
    After reset and device start up, VREGMAIN is enabled and operates in LDO mode. As soon as the device starts, the DC/DC regulator can be enabled using register VREGMAIN.DCDCEN on page 105.
    5.7.1 VREGMAIN — Main regulator
    VREGMAIN is the main regulator of the system
    After reset and device start up, VREGMAIN is enabled and operates in LDO mode. As soon as the device starts, the DC/DC regulator can be enabled using register VREGMAIN.DCDCEN on page 105.. When enabling the DC/ DC regulator, the device checks if an inductor is connected to the DCC pin. If an inductor is not detected, the device remains in LDO mode. Register VREGMAIN.INDUCTORDET on page 105 reports the inductor detection status and is used to detect inductor failure.
    I received an additional feedback from my local Nordic field application engineer that confirms the nRF54L family is not designed to support the LDO power supply mode.Sob
    Means the nRF54L15 is not the good target and I have to switch back to a nRF52 SoC instead.
    You can have both DCDC and LDO functions under DCDC mode. May I know why you don't want DCDC? Is it because of extra component required, or that it causes more noise?
    On this project, we have strong integration constraints. Basically all electronic components shall have a thickness less than 350µm. Means we cannot use SMD inductors of few µH that are usually provided in 0603 package.
