mesh sensor observer sample on nrf52840 USB dongle
I am developing a mesh solution when the nrf52840 USB dongle will act as an observer.
I am using the mesh sensor observer sample. I am able to build and flash it to the device.
But I am unable to make the USB connection stable.
I am adding this to the prj.conf (otherwise I am using the default prj.conf in the sample - and I am using SDK2.9)
CONFIG_GPIO=y
CONFIG_USB_DEVICE_STACK=y
CONFIG_USB_DEVICE_PRODUCT="My USB Stick"
CONFIG_USB_DEVICE_MANUFACTURER="My company"
CONFIG_USB_DEVICE_SN="0001"
CONFIG_USB_CDC_ACM=y
CONFIG_USB_DEVICE_INITIALIZE_AT_BOOT=y
CONFIG_SERIAL=y
CONFIG_CONSOLE=y
CONFIG_UART_CONSOLE=y
CONFIG_CJSON_LIB=y
and needed to add this to main file in order for the usb stick to show up at all.
	usb_enable(NULL);
    printk("USB enabled\n");
	uint32_t start = k_uptime_get();
	while (k_uptime_get() - start < 20000) {  // 20 seconds = 20000 ms
		k_sleep(K_SECONDS(1));
		printk("Printing before enabling BLE! %d\n", k_uptime_get_32());
	printk("Starting...\n");
	int err;
	printk("Initializing...\n");
	err = bt_enable(bt_ready);
	if (err) {
		printk("Bluetooth init failed (err %d)\n", err);
	return 0;
The output (I use python to read out from the USB port - pyserial) is:
📡 Connected to COM17 at 115200 baud
🔹 *** Booting Mesh Sensor Observer v2.9.0-54e858a1d142 ***
🔹 *** Using nRF Connect SDK v2.9.0-7787b2649840 ***
🔹 *** Using Zephyr OS v3.7.99-1f8f3dc29142 ***
🔹 USB enabled
🔹 uart:~$ Printing before enabling BLE! 1003
🔹 Printing before enabling BLE! 2004
🔹 Printing before enabling BLE! 3004
🔹 Printing before enabling BLE! 4004
🔹 Printing before enabling BLE! 5005
🔹 Printing before enabling BLE! 6005
🔹 Printing before enabling BLE! 7005
🔹 Printing before enabling BLE! 8006
🔹 Printing before enabling BLE! 9006
🔹 Printing before enabling BLE! 10006
🔹 Printing before enabling BLE! 11007
🔹 Printing before enabling BLE! 12007
🔹 Printing before enabling BLE! 13007
🔹 Printing before enabling BLE! 14008
🔹 Printing before enabling BLE! 15008
🔹 Printing before enabling BLE! 16009
🔹 Printing before enabling BLE! 17009
🔹 Printing before enabling BLE! 18009
🔹 Printing before enabling BLE! 19010
🔹 Printing before enabling BLE! 20010
🔹 Starting...
⚠️ Serial error: ClearCommError failed (PermissionError(13, 'The device does not recognize the command.', None, 22))
So BLE conflicts with the USB - but how to fix this?
    Sorry for the late reply. It seems like whatever sample you were starting from was not supporting the nRF52840 dongle board.
    I have a dongle that I have soldered on a 10-pin header, so that I can attach an external debugger to it (but I always flash it using the pre-programmed bootloader. I use the debugger only for debugging and RTT logging). I changed all your printk() to LOG_INF(), and enabled RTT logging in prj.conf, and saw that it faulted in some storage related stuff (nvs = non-volatile storage):
    00> *** Booting nRF Connect SDK v2.9.1-60d0d6c8d42d ***
    00> *** Using Zephyr OS v3.7.99-ca954a6216c9 ***
    00> [00:00:00.000,366] <inf> app: Initializing...
    00>
    00> [00:00:00.000,488] <inf> app: ✅ USB enabled
    00>
    00> [00:00:00.004,302] <inf> fs_nvs: No GC Done marker found: restarting gc
    00> [00:00:00.004,669] <err> os: ***** BUS FAULT *****
    00> [00:00:00.004,669] <err> os:   Imprecise data bus error
    00> [00:00:00.004,669] <err> os: r0/a1:  0x200062bc  r1/a2:  0x00000000  r2/a3:  0x00000000
    00> [00:00:00.004,699] <err> os: r3/a4:  0x00000000 r12/ip:  0x20004580 r14/lr:  0x0003626b
    00> [00:00:00.004,699] <err> os:  xpsr:  0x41000000
    00> [00:00:00.004,699] <err> os: Faulting instruction address (r15/pc): 0x00032f6a
    00> [00:00:00.004,760] <err> os: >>> ZEPHYR FATAL ERROR 26: Unknown error on CPU 0
    00> [00:00:00.004,791] <err> os: Current thread: 0x20004580 (unknown)
    00> [00:00:00.340,454] <err> os: Halting system
    So this triggered when it tried to spin up the BLE stack, because it is dependent on storing some things in flash.
    I thought these were default settings for the board files for the dongle, but apparently it is not. So I found another sample that looked like it was actually tested on the nRF52840 dongle. The sample:
    ncs\nrf\samples\bluetooth\mesh\light_dimmer. If you look in that sample, you can see the file pm_static_nrf52840dongle_nrf52840.yml. It holds information about the nRF5 SDK bootloader that is pre-programmed in the dongle, and tells it where to put the NCS application's settings partition and so on.
    If you copy that file into your sample it should work. But for reference, I'll upload what I used to test as well, in case you want to try to attach a debugger for RTT logging. When you see asserts like these, the USB will stop working, and it is not possible to monitor the log about the crash information.
    mesh_provisioner_usb_2.zip
    Edvin
