Matter 4.3.1.8. Device Type (DT) TXT key
This function is optional, but what if I want to turn it on on the DUT side?
Hiroki
  • Hi Hiroki,
    Just a status update to let you know I'm waiting for some input from the Matter team.
    Thank you for your patience
    Andreas
  • Hi again Hiroki
    I got some input from R&D. Since the Device Type TXT Key is not something that the sample supports out of the box, you will have to add support for this in the application before testing it in the TH. You only need to change MCORE.DD.TXT_KEY_DT to true in the Base.xml PICS file used to certification.
    Let me know if this works and I'll get back to you
    Andreas
  • Hi,Andreas
    Thank you for reply.
    I would like to know how to add this or set it in my application.
    I believe this PICS setting is at the discretion of the certification body to decide whether or not to perform certification testing. I do not believe that simply enabling this setting will change the settings of the device being tested.
    Hiroki
  • Hello Hiroki,
    Apologies for the long response time. I had to clarify the details with the Matter team because I did misunderstand something.
    Here's what they said:
    If you want to enable testing the DT TXT KEy in certfication you should state that in the PICS. However setting PICS does not affect the DUT implementation (PICS are information for CSA/Certification about supported features to know what to test and what to expect).
    If the client want to enable the DT TXT key in commissionable service in the DUT implementation, the prj.conf need to be update to enable following configs:
    CONFIG_CHIP_COMMISSIONABLE_DEVICE_TYPE=y
    CONFIG_CHIP_DEVICE_TYPE=<int value of device type e.g. 257>
    It should enable the additional txt key in the commissionable service.
    https://github.com/nrfconnect/sdk-connectedhomeip/blob/master/config/zephyr/Kconfig#L264
    https://github.com/nrfconnect/sdk-connectedhomeip/blob/master/config/zephyr/Kconfig#L162
    Let me know if this makes more sense
    Andreas
  • Hi,Andreas
    I agree with the above.
    This is the answer I was hoping for.
    I'm sorry, but I have an additional question.
    In the matter specfication, there are also 4.3.1.9. TXT key for device name and 4.3.1.10. TXT key for rotating device identifier (RI). Can these also be enabled in prj.conf?
    If so, please tell me how to do this.
    If the above can be resolved, we will close this issue.
    Hiroki
