CMake/build errors when applying minimal config to nsib and mcuboot
I am using NCS v2.9.1 and trying to enable a bootloader chain with NSIB and MCUboot. The regular setup works fine, however if I try to enable the minimal configuration, I get a build errors (for NSIB) and CMake error (for MCUboot). I am using the instructions on this page of the docs.
The issue can be reproduced using the hello_world sample and using the following command:
west build -b nrf52840dk/nrf52840 zephyr/samples/hello_world -- \
-DSB_CONFIG_SECURE_BOOT_APPCORE=y \
-Db0_FILE_SUFFIX=minimal
This results in the following error:
FAILED: zephyr/zephyr_pre0.elf zephyr/zephyr_pre0.map /opt/nordic/ncs/v2.9.1/build/b0/zephyr/zephyr_pre0.map
: && ccache /opt/nordic/ncs/toolchains/b8efef2ad5/opt/zephyr-sdk/arm-zephyr-eabi/bin/arm-zephyr-eabi-gcc -Os -DNDEBUG -gdwarf-4 -gdwarf-4 zephyr/CMakeFiles/zephyr_pre0.dir/misc/empty_file.c.obj -o zephyr/zephyr_pre0.elf  zephyr/CMakeFiles/offsets.dir/./arch/arm/core/offsets/offsets.c.obj  -T  zephyr/linker_zephyr_pre0.cmd  -Wl,-Map=/opt/nordic/ncs/v2.9.1/build/b0/zephyr/zephyr_pre0.map  -Wl,--whole-archive  app/libapp.a  zephyr/libzephyr.a  zephyr/arch/common/libarch__common.a  zephyr/arch/arch/arm/core/libarch__arm__core.a  zephyr/arch/arch/arm/core/cortex_m/libarch__arm__core__cortex_m.a  zephyr/lib/libc/picolibc/liblib__libc__picolibc.a  zephyr/lib/libc/common/liblib__libc__common.a  zephyr/soc/soc/nrf52840/libsoc__nordic.a  modules/nrf/lib/fprotect/lib..__nrf__lib__fprotect.a  modules/nrf/subsys/bootloader/bl_boot/lib..__nrf__subsys__bootloader__bl_boot.a  modules/nrf/subsys/bootloader/bl_crypto/lib..__nrf__subsys__bootloader__bl_crypto.a  modules/nrf/subsys/bootloader/bl_validation/lib..__nrf__subsys__bootloader__bl_validation.a  modules/nrf/subsys/bootloader/bl_storage/lib..__nrf__subsys__bootloader__bl_storage.a  modules/nrf/subsys/fw_info/lib..__nrf__subsys__fw_info.a  modules/nrf/drivers/hw_cc3xx/lib..__nrf__drivers__hw_cc3xx.a  modules/hal_nordic/nrfx/libmodules__hal_nordic__nrfx.a  -Wl,--no-whole-archive  zephyr/kernel/libkernel.a  -L/opt/nordic/ncs/v2.9.1/build/b0/zephyr  zephyr/arch/common/libisr_tables.a  /opt/nordic/ncs/v2.9.1/nrfxlib/crypto/nrf_oberon/lib/cortex-m4/hard-float/liboberon_3.0.15.a  /opt/nordic/ncs/v2.9.1/nrfxlib/crypto/nrf_cc310_bl/lib/cortex-m4/hard-float/no-interrupts/libnrf_cc310_bl_0.9.12.a  -mcpu=cortex-m4  -mthumb  -mabi=aapcs  -mfpu=fpv4-sp-d16  -mfloat-abi=hard  -mfp16-format=ieee  -mtp=soft  -fuse-ld=bfd  -Wl,--gc-sections  -Wl,--build-id=none  -Wl,--sort-common=descending  -Wl,--sort-section=alignment  -Wl,-u,_OffsetAbsSyms  -Wl,-u,_ConfigAbsSyms  -nostdlib  -static  -Wl,-X  -Wl,-N  -Wl,--orphan-handling=warn  -Wl,-no-pie  -specs=picolibc.specs  -DPICOLIBC_DOUBLE_PRINTF_SCANF  /opt/nordic/ncs/v2.9.1/nrfxlib/crypto/nrf_cc310_platform/lib/cortex-m4/hard-float/no-interrupts/libnrf_cc310_platform_0.9.19.a -L"/opt/nordic/ncs/toolchains/b8efef2ad5/opt/zephyr-sdk/arm-zephyr-eabi/bin/../lib/gcc/arm-zephyr-eabi/12.2.0/thumb/v7e-m+fp/hard" -lc -lgcc && cd /opt/nordic/ncs/v2.9.1/build/b0/zephyr && /opt/homebrew/Cellar/cmake/3.29.0/bin/cmake -E true
/opt/nordic/ncs/toolchains/b8efef2ad5/opt/zephyr-sdk/arm-zephyr-eabi/bin/../lib/gcc/arm-zephyr-eabi/12.2.0/../../../../arm-zephyr-eabi/bin/ld.bfd: zephyr/zephyr_pre0.elf section `text' will not fit in region `FLASH'
/opt/nordic/ncs/toolchains/b8efef2ad5/opt/zephyr-sdk/arm-zephyr-eabi/bin/../lib/gcc/arm-zephyr-eabi/12.2.0/../../../../arm-zephyr-eabi/bin/ld.bfd: region `FLASH' overflowed by 5032 bytes
collect2: error: ld returned 1 exit status
[24/38] cd /opt/nordic/ncs/v2.9.1/build/_sysbuild && /opt/homebrew/Cellar/cmake/3.29.0/bin/cmake -E true
FAILED: modules/nrf/b0-prefix/src/b0-stamp/b0-build /opt/nordic/ncs/v2.9.1/build/modules/nrf/b0-prefix/src/b0-stamp/b0-build
cd /opt/nordic/ncs/v2.9.1/build/b0 && /opt/homebrew/Cellar/cmake/3.29.0/bin/cmake --build .
FATAL ERROR: command exited with status 1: /opt/homebrew/bin/cmake --build /opt/nordic/ncs/v2.9.1/build
When trying the minimal MCUboot configuration I get a CMake error:
Parsing /opt/nordic/ncs/v2.9.1/bootloader/mcuboot/boot/zephyr/Kconfig
Loaded configuration '/opt/nordic/ncs/v2.9.1/zephyr/boards/nordic/nrf52840dk/nrf52840dk_nrf52840_defconfig'
Merged configuration '/opt/nordic/ncs/v2.9.1/bootloader/mcuboot/boot/zephyr/prj_minimal.conf'
Merged configuration '/opt/nordic/ncs/v2.9.1/bootloader/mcuboot/boot/zephyr/boards/nrf52840dk_nrf52840.conf'
Merged configuration '/opt/nordic/ncs/v2.9.1/build/mcuboot/zephyr/.config.sysbuild'
error: Aborting due to Kconfig warnings
CMake Error at /opt/nordic/ncs/v2.9.1/zephyr/cmake/modules/kconfig.cmake:396 (message):
  command failed with return code: 1
  /opt/nordic/ncs/v2.9.1/nrf/cmake/modules/kconfig.cmake:29 (include)
  /opt/nordic/ncs/v2.9.1/zephyr/cmake/modules/zephyr_default.cmake:133 (include)
  /opt/nordic/ncs/v2.9.1/zephyr/share/zephyr-package/cmake/ZephyrConfig.cmake:66 (include)
  /opt/nordic/ncs/v2.9.1/zephyr/share/zephyr-package/cmake/ZephyrConfig.cmake:92 (include_boilerplate)
  CMakeLists.txt:12 (find_package)
CMake Error at cmake/modules/sysbuild_extensions.cmake:514 (message):
  CMake configure failed for Zephyr project: mcuboot
  Location: /opt/nordic/ncs/v2.9.1/bootloader/mcuboot/boot/zephyr
  cmake/modules/sysbuild_images.cmake:20 (ExternalZephyrProject_Cmake)
  cmake/modules/sysbuild_default.cmake:20 (include)
  /opt/nordic/ncs/v2.9.1/zephyr/share/zephyr-package/cmake/ZephyrConfig.cmake:75 (include)
  /opt/nordic/ncs/v2.9.1/zephyr/share/sysbuild-package/cmake/SysbuildConfig.cmake:8 (include)
  template/CMakeLists.txt:10 (find_package)
Do you have any pointers what is going wrong here?
  • I have very similar problem , i am using nRFConnect v3.0.1
    first nsib i encounter the same flash size issue ,
    then i encounter configuration not define issue
    west build ^
    --build-dir build_mcu_minimal c:/ncs/sourcecode/hello_world ^
    --board nrf52840dk/nrf52840 ^
    -Db0_FILE_SUFFIX=minimal ^
    -Db0_CONFIG_B0_MIN_PARTITION_SIZE=n ^
    -Db0_CONFIG_PM_PARTITION_SIZE_B0_IMAGE=0x6000 ^
    -Dmcuboot_FILE_SUFFIX=minimal ^
    -Dmcuboot_EXTRA_CONF_FILE=external_crypto.conf ^
    -Dmcuboot_CONFIG_BOOT_USE_MIN_PARTITION_SIZE=n ^
    -Dmcuboot_CONFIG_PM_PARTITION_SIZE_MCUBOOT=0x5e00
    C:/ncs/v3.0.1/bootloader/mcuboot/boot/zephyr/prj_minimal.conf:30: warning: attempt to assign the value 'n' to the undefined symbol MINIMAL_LIBC_CALLOC
    C:/ncs/v3.0.1/bootloader/mcuboot/boot/zephyr/prj_minimal.conf:31: warning: attempt to assign the value 'n' to the undefined symbol MINIMAL_LIBC_MALLOC
    Parsing C:/ncs/v3.0.1/bootloader/mcuboot/boot/zephyr/Kconfig
    C:/ncs/v3.0.1/bootloader/mcuboot/boot/zephyr/prj_minimal.conf:32: warning: attempt to assign the value 'n' to the undefined symbol MINIMAL_LIBC_REALLOCARRAYLoaded configuration 'C:/ncs/v3.0.1/zephyr/boards/nordic/nrf52840dk/nrf52840dk_nrf52840_defconfig'
    Merged configuration 'C:/ncs/v3.0.1/bootloader/mcuboot/boot/zephyr/prj_minimal.conf'
    Merged configuration 'C:/ncs/v3.0.1/bootloader/mcuboot/boot/zephyr/boards/nrf52840dk_nrf52840.conf'
    Merged configuration 'C:/ncs/v3.0.1/bootloader/mcuboot/boot/zephyr/external_crypto.conf'
    Merged configuration 'C:/ncs/v3.0.1/nrf/subsys/bootloader/image/log_minimal.conf'
    Merged configuration 'C:/ncs/sourcecode/hello_world/build_mcu_minimal/mcuboot/zephyr/misc/generated/extra_kconfig_options.conf'
    Merged configuration 'C:/ncs/sourcecode/hello_world/build_mcu_minimal/mcuboot/zephyr/.config.sysbuild'
    CMake Error at C:/ncs/v3.0.1/zephyr/cmake/modules/kconfig.cmake:396 (message):
      C:/ncs/v3.0.1/nrf/cmake/modules/kconfig.cmake:36 (include)
      C:/ncs/v3.0.1/zephyr/cmake/modules/zephyr_default.cmake:133 (include)
      C:/ncs/v3.0.1/zephyr/share/zephyr-package/cmake/ZephyrConfig.cmake:66 (include)
      C:/ncs/v3.0.1/zephyr/share/zephyr-pack-- Configuring incomplete, errors occurred!
      CMakeLists.txt:18 (find_package)
      Location: C:/ncs/v3.0.1/bootloader/mcuboot/boot/zephyr/
      cmake/modules/sysbuild_images.cmake:43 (ExternalZephyrProject_Cmake)
      cmake/modules/sysbuild_default.cmake:21 (include)
      C:/ncs/v3.0.1/zephyr/share/zephyr-package/cmake/ZephyrConfig.cmake:75 (include)
      C:/ncs/v3.0.1/zephyr/share/zephyr-package/cmake/ZephyrConfig.cmake:97 (include_boilerplate)
      C:/ncs/v3.0.1/zephyr/share/sysbuild-package/cmake/SysbuildConfig.cmake:8 (include)
    See also "C:/ncs/sourcecode/hello_world/build_mcu_minimal/CMakeFiles/CMakeOutput.log".
    FATAL ERROR: command exited with status 1: 'C:\ncs\toolchains\0b393f9e1b\opt\bin\cmake.EXE' -DWEST_PYTHON=C:/ncs/toolchains/0b393f9e1b/opt/bin/python.exe '-BC:\ncs\sourcecode\hello_world\build_mcu_minimal' -GNinja -Db0_FILE_SUFFIX=minimal -Db0_CONFIG_B0_MIN_PARTITION_SIZE=n -Db0_CONFIG_PM_PARTITION_SIZE_B0_IMAGE=0x6000 -Dmcuboot_FILE_SUFFIX=minimal -Dmcuboot_EXTRA_CONF_FILE=external_crypto.conf -Dmcuboot_FILE_SUFFIX=minimal -Dmcuboot_CONFIG_BOOT_USE_MIN_PARTITION_SIZE=n -Dmcuboot_CONFIG_PM_PARTITION_SIZE_MCUBOOT=0x5e00 '-SC:\ncs\v3.0.1\zephyr\share\sysbuild' '-DAPP_DIR:PATH=c:\ncs\sourcecode\hello_world'
