Issue Launching ZAP GUI with Custom Cluster in NCS v3.0.0-preview2
Hello Team,
I’m working on creating a custom Matter cluster using the instructions provided in the Nordic documentation: https://docs.nordicsemi.com/bundle/ncs-latest/page/nrf/protocols/matter/getting_started/custom_clusters.html#ug-matter-creating-custom-cluster
I’m currently using NCS v3.0.0-preview2 and have successfully completed Step 1 using the following command:
1.west zap-append /home/rahul/Downloads/MyCluster.xml \
-b /home/rahul/ncs/v3.0.0-preview2/modules/lib/matter/src/app/zap-templates/zcl/zcl.json \
-o ~/nrf/template/zcl.json
This correctly created the zcl.json file at ~/nrf/template/zcl.json, which includes both standard and my custom cluster.
However, when I proceed to Step 2 and try launching the ZAP GUI with the following command:
cd ~/nrf/template
2.west zap-gui -j ./zcl.json --clusters /home/rahul/Downloads/MyCluster.xml
I encounter an error.
I also tried running just:
But that also results in an error. Unfortunately, the documentation doesn’t specify what the exact requirements are for this version of NCS, or how to troubleshoot west zap-gui issues.
Could you please help me understand how to resolve this? Is there a known issue with west zap-gui in v3.0.0-preview2, or is there an alternative method I should try?
Please let me know what logs or details would be helpful to share further.
Thanks in advance,
Rahul Chauhan
  • Hi  ,
    I am trying to open zap-gui tool for manufacturer_specific sample using below command
    west zap-gui -j ./src/default_zap/zcl.json
    but getting below error
    Errro:
    rahul@rahul-H510M-H-V2:~/nrf/manufacturer_specific$ west zap-gui -j ./src/default_zap/zcl.json
    Using ZAP file: /home/rahul/nrf/manufacturer_specific/src/default_zap/manufacturer_specific.zap
    Using ZCL file: /home/rahul/nrf/manufacturer_specific/src/default_zap/zcl.json
    Using app templates: /home/rahul/ncs/v3.0.0/modules/lib/matter/src/app/zap-templates/app-templates.json
    ZAP installation directory: /home/rahul/ncs/v3.0.0/modules/lib/matter/.zap-install
    Found ZAP 2024.8.14 (up to date)
    🔧 Using temporary state directory: /tmp/zap.Ax6DuA
    [121749:0429/172609.960302:ERROR:bus.cc(407)] Failed to connect to the bus: '=' character not found or has no value following it
    [121749:0429/172609.960336:ERROR:bus.cc(407)] Failed to connect to the bus: '=' character not found or has no value following it
    [121749:0429/172609.960346:ERROR:bus.cc(407)] Failed to connect to the bus: '=' character not found or has no value following it
    [121749:0429/172609.960353:ERROR:bus.cc(407)] Failed to connect to the bus: '=' character not found or has no value following it
    Xlib:  extension "NV-GLX" missing on display ":0".
    [121781:0429/172610.066499:ERROR:viz_main_impl.cc(196)] Exiting GPU process due to errors during initialization
    Error:
    Unknown cluster "Access Control" in attributeAccessInterfaceAttributes
        at loadZclJsonOrProperties (/home/rahul/ncs/v3.0.0/modules/lib/matter/.zap-install/resources/app.asar/dist/src-electron/zcl/zcl-loader-silabs.js:2066:27)
        at loadZclMetaFilesCommon (/home/rahul/ncs/v3.0.0/modules/lib/matter/.zap-install/resources/app.asar/dist/src-electron/zcl/zcl-loader.js:63:19)
        at Object.loadZclMetafiles (/home/rahul/ncs/v3.0.0/modules/lib/matter/.zap-install/resources/app.asar/dist/src-electron/zcl/zcl-loader.js:150:28)
        at startNormal (/home/rahul/ncs/v3.0.0/modules/lib/matter/.zap-install/resources/app.asar/dist/src-electron/main-process/startup.js:62:9)
        at Object.startUpMainInstance (/home/rahul/ncs/v3.0.0/modules/lib/matter/.zap-install/resources/app.asar/dist/src-electron/main-process/startup.js:744:20)
    FATAL ERROR: Error::ThrowAsJavaScriptException napi_throw
    FATAL ERROR: command exited with status -6: /home/rahul/ncs/v3.0.0/modules/lib/matter/.zap-install/zap /home/rahul/nrf/manufacturer_specific/src/default_zap/manufacturer_specific.zap --zcl /home/rahul/nrf/manufacturer_specific/src/default_zap/zcl.json --gen /home/rahul/ncs/v3.0.0/modules/lib/matter/src/app/zap-templates/app-templates.json --tempState
    We will try with the template sample if its working for it or not.
    BR,
    Rahul
  • Hi Rahul,
    Has anything changed on your end since last week? If not, could you try to follow the steps that resolved this case  Failedto customize Cluster as per document ?
    Andreas
  • Hi  ,
    I am able to add custom cluster with one boolean attribute in matter template application. The XML file generated through "nRF Connect Matter Manufacturer Cluster Editor tool" is buggy, I have to fix that manually. After that I have to add stub call back function in the zcl_callbacks.cpp file as I was getting undefined reference error.
    I want to add attribute with struct type in my custom cluster. Through the editor tool it is not generating data in XML file. So I have manually added data in XML file which I don't know correct or not.
    My structure type:
    struct MyStruct
    uint8_t width;
    uint8_t length;
    uint8_t height;
    My XML File:
    <?xml version="1.0" encoding="UTF-8" standalone="yes"?>
    <configurator>
       <struct name="MyStruct" isFabricScoped="true">
          <cluster code="0xFFF1FC01"/>
          <item fieldId="1" name="width" type="int8u" min="0" max="10" isFabricSensitive="true"/>
          <item fieldId="2" name="length" type="int8u" min="0" max="10" isFabricSensitive="true"/>
          <item fieldId="3" name="height" type="int8u" min="0" max="10" isFabricSensitive="true"/>
       </struct>
       <cluster>
          <domain>General</domain>
          <name>Mangoe</name>
          <code>0xFFF1FC01</code>
          <define>MANGOE</define>
          <description>The MyNewCluster cluster showcases a cluster manufacturer extensions</description>
          <attribute side="server" code="0xFFF10000" define="MY_ATTRIBUTE" type="boolean" writable="true" default="false" optional="false">MyAttribute</attribute>
          <attribute side="server" code="0xFFF10001" define="MY_STRUCT_ATTRIBUTE" type="MyStruct" length="1" writable="true" optional="false">MyStructAttribute</attribute>
          <command source="client" code="0xFFF10000" name="MyCommand" optional="false">
             <description>Command that takes two uint8 arguments and returns their sum.</description>
             <arg name="arg1" type="int8u"/>
             <arg name="arg2" type="int8u"/>
          </command>
          <event side="server" code="0xFFF10000" name="MyEvent" priority="info" optional="false">
             <description>Event that is generated by the server.</description>
          </event>
       </cluster>
    </configurator>
    zap-gui command works fine, I am able to see my cluster and attribute in the gui tool.
    west zap-gui -j zcl.json --cluster ./MyCluster.xml
    After that west zap-generate --full failed with below error:
    rahul@rahul-H510M-H-V2:~/nrf/template_bh$ west zap-generate --full
    Searching for zcl file from /home/rahul/nrf/template_bh/src/default_zap/template.zap
    🔧 Using temporary state directory: /tmp/zapb5bbfdmw/zap.jK6eJ7
    🤖 ZAP generation started:
        🔍 input files: /home/rahul/nrf/template_bh/src/default_zap/template.zap
        🔍 output pattern: /home/rahul/nrf/template_bh/src/default_zap/zap-generated
        🔍 using templates: /home/rahul/ncs/v3.0.0/modules/lib/matter/src/app/zap-templates/app-templates.json
        🔍 using zcl data: /home/rahul/nrf/template_bh/zcl.json
        🔍 zap version: ver. 2024.8.14, featureLevel 103, commit: dca1ad01b8affd07eae1a6ca23afc284067c151c from 2024-08-14T15:52:25.000Z, mode: binary, exe: /home/rahul/ncs/v3.0.0/modules/lib/matter/.zap-install/zap-cli
    🕐 Setup time: 14s 91ms
    👉 using input file: /home/rahul/nrf/template_bh/src/default_zap/template.zap
    Application is failing the Device Type Specification as follows:
      - ⚠ Check Device Type Compliance on endpoint: 0, device type: MA-rootdevice, cluster: Localization Configuration, attribute: ActiveLocale needs to be enabled
      - ⚠ Check Device Type Compliance on endpoint: 0, device type: MA-rootdevice, cluster: Localization Configuration, attribute: SupportedLocales needs to be enabled
    Application is failing the Cluster Specification as follows:
    👉 using output destination: /home/rahul/nrf/template_bh/src/default_zap/zap-generated
    🕐 File loading time: 520ms
    Error in endpoint_config helper: ERROR: Unknown size for non-external attribute: MyStructAttribute / 4293984257
    🤖 Generating files:
        ✍  /home/rahul/nrf/template_bh/src/default_zap/zap-generated/callback-stub.cpp
        ✍  /home/rahul/nrf/template_bh/src/default_zap/zap-generated/gen_config.h
        ✍  /home/rahul/nrf/template_bh/src/default_zap/zap-generated/IMClusterCommandHandler.cpp
        ✍  /home/rahul/nrf/template_bh/src/default_zap/zap-generated/PluginApplicationCallbacks.h
        ✍  /home/rahul/nrf/template_bh/src/default_zap/zap-generated/access.h
    ⚠️  Errors:
        👎  /home/rahul/nrf/template_bh/src/default_zap/zap-generated/endpoint_config.h: ⛔ TypeError: Cannot read properties of undefined (reading 'toHTML')
    Stack trace:
        at replacePlaceholdersRecursivelyIn (/snapshot/zap/node_modules/promised-handlebars/lib/markers.js:96:31)
        at /snapshot/zap/node_modules/promised-handlebars/lib/markers.js:106:22
        at /snapshot/zap/node_modules/promised-handlebars/lib/replaceP.js:44:47
        at String.replace (<anonymous>)
        at replaceP (/snapshot/zap/node_modules/promised-handlebars/lib/replaceP.js:37:14)
        at replacePlaceholdersRecursivelyIn (/snapshot/zap/node_modules/promised-handlebars/lib/markers.js:102:20)
        at /snapshot/zap/node_modules/promised-handlebars/lib/markers.js:111:18
        at produceContent (/snapshot/zap/dist/src-electron/generator/template-engine.js:152:19)
        at generateSingleTemplate (/snapshot/zap/dist/src-electron/generator/generation-engine.js:540:27)
        at async Promise.all (index 5)
    🕐 Generation time: 335ms
    {"endpoint_config.h":{}}
    Error: Generation failed: /home/rahul/nrf/template_bh/src/default_zap/template.zap
        at generateSingleFile (/snapshot/zap/dist/src-electron/main-process/startup.js:496:19)
        at startGeneration (/snapshot/zap/dist/src-electron/main-process/startup.js:551:5)
    Zap generation error: Error: Generation failed: /home/rahul/nrf/template_bh/src/default_zap/template.zap
      File "/home/rahul/ncs/v3.0.0/modules/lib/matter/scripts/tools/zap/generate.py", line 404, in <module>
        main()
      File "/home/rahul/ncs/v3.0.0/modules/lib/matter/scripts/tools/zap/generate.py", line 382, in main
        runGeneration(cmdLineArgs)
      File "/home/rahul/ncs/v3.0.0/modules/lib/matter/scripts/tools/zap/generate.py", line 240, in runGeneration
        tool.run('generate', *args)
      File "/home/rahul/ncs/v3.0.0/modules/lib/matter/scripts/tools/zap/zap_execution.py", line 109, in run
        subprocess.check_call(
      File "/home/rahul/ncs/toolchains/7cbc0036f4/usr/local/lib/python3.12/subprocess.py", line 413, in check_call
        raise CalledProcessError(retcode, cmd)
    subprocess.CalledProcessError: Command '['/home/rahul/ncs/v3.0.0/modules/lib/matter/.zap-install/zap-cli', 'generate', '-z', '/home/rahul/nrf/template_bh/zcl.json', '-g', '/home/rahul/ncs/v3.0.0/modules/lib/matter/src/app/zap-templates/app-templates.json', '-o', '/home/rahul/nrf/template_bh/src/default_zap/zap-generated', '-i', '/home/rahul/nrf/template_bh/src/default_zap/template.zap', '--tempState']' returned non-zero exit status 1.
    FATAL ERROR: command exited with status 1: /home/rahul/ncs/toolchains/7cbc0036f4/usr/local/bin/python3.12 /home/rahul/ncs/v3.0.0/modules/lib/matter/scripts/tools/zap/generate.py /home/rahul/nrf/template_bh/src/default_zap/template.zap -o /home/rahul/nrf/template_bh/src/default_zap/zap-generated -t /home/rahul/ncs/v3.0.0/modules/lib/matter/src/app/zap-templates/app-templates.json
    Can you please provide some guidance here.
    NCS version: v3.0.0
    Board: nrf54l15dk
    BR,
    Rahul
  • Hi Rahul,
    Looks like the tool complains about multiple things,
    • Application is failing the Device Type Specification as follows:
    -  Check Device Type Compliance on endpoint: 0, device type: MA-rootdevice, cluster: Localization Configuration, attribute: ActiveLocale needs to be enabled
    -  Check Device Type Compliance on endpoint: 0, device type: MA-rootdevice, cluster: Localization Configuration, attribute: SupportedLocales needs to be enabled
    •  Length of your custom struct:
    Clock1 File loading time: 520ms
    • Reading the zap-generated endpoint.config.h
    ️ Errors:
     /home/rahul/nrf/template_bh/src/default_zap/zap-generated/endpoint_config.h: No entry TypeError: Cannot read properties of undefined (reading 'toHTML')
    Are you able to resolve these errors? I assume they refer to your configurations of your custom clusters that's causing htis
    Andreas
