BLE stream communication LOG errs
Hi all,
I've been developing a BLE application on my laptop to communicate with the 52840. I manage to understand how to create and run a BLE connection through the really nice tutorial that has been posted a couple of years ago on youtube.
https://www.youtube.com/watch?v=hY_tDext6zA
Maybe this is nothing or maybe I'm using the system wrong, but I created a specific characteristic for stream data. Whenever I activate it, my terminal gets flooded with the messages in the attached pic.
My question is, are those only related to the Loggin framework and I should not be (at a certain level) worried? is this an issue about streaming too fast? If the latter, maybe this BLE is not indicated for data streams?
thank you all
[EDIT]
some extra info that may be of use.
I am streaming data out from a worker that runs at 1ms and sends a single uint16 packet over a dedicated characteristic. This error occurs when I enable such stream. Writing/reading single characteristics with manual inputs (using the evk buttons) does not give any issues. Ideally I'd like to stream an array of 16 uint16 elements.
This is my current configuration file
CONFIG_GPIO=y
CONFIG_SPI=y
CONFIG_FPU=y
CONFIG_NEWLIB_LIBC=y
CONFIG_CBPRINTF_FP_SUPPORT=y
# Set CONFIG_NEWLIB_LIBC_FLOAT_PRINTF if printf should be able to print float
# Enable DK LED and Buttons library
CONFIG_DK_LIBRARY=y
# Configure logger
CONFIG_LOG=y
CONFIG_LOG_MODE_MINIMAL=n
CONFIG_USE_SEGGER_RTT=n
CONFIG_LOG_BACKEND_RTT=n
CONFIG_LOG_BACKEND_UART=y
CONFIG_LOG_DEFAULT_LEVEL=3
CONFIG_LOG_PRINTK=y
CONFIG_LOG_MODE_DEFERRED=y
# Configure Bluetooth
CONFIG_BT=y
CONFIG_BT_PERIPHERAL=y
CONFIG_BT_DEVICE_NAME="XYZ"
CONFIG_BT_DEVICE_APPEARANCE=0
CONFIG_BT_MAX_CONN=1
CONFIG_BT_LL_SOFTDEVICE=y
CONFIG_ASSERT=y
  • Hi Sigurd,
    I mistakenly debugged the err value and it actually returns -12 (ENOMEM).
    I'm trying the sniffer but I have issues on filtering through wireshark since I cannot see the UUID.
  • here's also the log of the captured stream.
    the UUID of the characteristic used for streaming is (0xf26200f3, 0xbcb8, 0x4366, 0x9a9b, 0xa757edad68dc)
    3617.capture.pcapng
    I see holes in the actual stream too.
  • After searching around and testing different solutions, I still haven't found anything useful unfortunately.
    I tested my worked and found out that can reach 25 ms stream (sill using a 16 element u16 array since this will be my actual output structure). below 25 ms the errors will start to arise.
    Any help would be much appreciated.
  • Following a possible different approach, I decided to transmit burst of data every x ms with  1khz amount of data.
    I change the code to accommodate an array of 16 u16_t times the streaming in millisecond
    #define RHD_MAX_CH_NUMBER 16
    #define RHD_TIMER_FREQ_MS 25
    int send_stream_notification(struct bt_conn *conn, u16_t* value, size_t len)
        int err = 0;
        struct bt_gatt_notify_params params = {0};
        const struct bt_gatt_attr *attr = &rhxRemoteService.attrs[4];
        params.attr = attr;
        params.data = value;
        params.len = sizeof(u16_t) * len;
        params.func = on_stream;
        err = bt_gatt_notify_cb(conn, &params);
        return err;
    void RHD_handler(struct k_work *work)
            u16_t RAMP[RHD_MAX_CH_NUMBER * RHD_TIMER_FREQ_MS];
            static u16_t count = 0;
            u8_t j = 0;
            for (j = 0; j < RHD_TIMER_FREQ_MS; j++) {
                    for (u8_t i = 0; i < RHD_MAX_CH_NUMBER; i++) {
                            RAMP[j * RHD_MAX_CH_NUMBER + i] = count;
                    count = (count + 1) % 1000;
            if (isStreamEnabled())
                    int err = send_stream_notification(current_conn, RAMP, RHD_MAX_CH_NUMBER * RHD_TIMER_FREQ_MS);
                    if (err)
                            LOG_ERR("couldn't send notification (err: %d)", err);
    With this approach I get an error about the inability of correctly negotiate the MTU
    my current prj.conf
    CONFIG_GPIO=y
    CONFIG_SPI=y
    CONFIG_DK_LIBRARY=y
    # Configure logger
    CONFIG_LOG=y
    CONFIG_LOG_PRINTK=y
    CONFIG_LOG_BUFFER_SIZE=4096
    CONFIG_BT=y
    CONFIG_BT_BUF_ACL_TX_COUNT=100
    CONFIG_BT_L2CAP_TX_MTU=247
    CONFIG_BT_BUF_ACL_TX_SIZE=251
    CONFIG_BT_BUF_ACL_RX_SIZE=251
    CONFIG_BT_CTLR_DATA_LENGTH_MAX=251
    CONFIG_BT_CTLR_PHY_2M=y
    CONFIG_BT_CTLR_SDC_MAX_CONN_EVENT_LEN_DEFAULT=30000
    Trying to change CONFIG_BT_L2CAP_TX_MTU didn't improve the situation.
  • Hi!
    At the start of the connection event, you as the peripheral have packets queued up, and the MD bit is set. But after a sending a few packets, the packet queue is empty, you don't have more data to send, and the connection event ends. Then you need to wait until the next connect event starts to send data. The connection interval is 45ms. Maybe you can try requesting a lower connection interval.
