How to software-switch between ESB and BLE on a nrf5340 net-core?
I am working on a sensor device that requires very accurate timing on the sensing and sensor signal algorithm side. This device needs a low latency and low jitter radio transmission in one use case (A) sending very low volume of data (send to receive < 1ms) and another use case (B) with a lot higher data volume but less strict requirements on latency and jitter. The device should be able to switch back and forth between these two use cases via a push button on the device.
I chose nrf5340 for this device, because with its two cores I can keep my sensor-algo on the app core and (almost) independently have all radio operation on the net core.
My implementation keeps all app core (sensor) code the same for both use cases, sending messages to the net core via IPC. All difference between (A) and (B) is implemented in the software running on the net-core. Aside from some small part of the code processing the IPC-messages use case specific, the main difference is, that use case (A) uses ESB (Enhanced Shock Burst) for radio transmission and use case (B) uses BLE.
Currently I have successfully implemented use case (A) and use case (B) - but I only can build and successfully run the code for use case (A) by using one set of config parameters and (B) by using a different set of config parameters and select the code to be compiled by #if statements depending on config parameters.
As soon as I try to enable BLE and ESB at the same time, I need to activate MPSL and dynamic interrupt config parameters - as in the unofficial sample code for using both protocols concurrently. This, however, leads to interrupt problems with operating IPC or build problems, that I am not able to solve - and especially, that I do not understand the need for.
My question: Is there a way to build and run for BLE- and ESB-use alternatively instead of concurrently, while being able to switch between these protocols without restarting or reflashing the device... and, if possible, without the need for MPSL or dynamic interrupts?
To really keep the lowest possible jitter and latency, my pure ESB-implementation, which currently runs with latency far below 1 ms, should be able to run while BLE completely is inactive for use case (A). When the button is pressed, the device should completely switch off ESB and start BLE-operation and vice versa.
I have seen some questions similar to mine, but was not able to find a simple and solid solution without the use of MPSL and dynamic interrupts etc...keeping the great latency performance of IPC + ESB in my critical use case (A).
Thank you very much for any advice you can give me.
Jens
