Enabling Wifi on nRF7002
Hello everyone,
I'm trying to set up the Wifi stack on the nRF7002 and use it with MicroPython, but encountering a lot of difficulty with it. I cropped up a network_wlan.c file and added it to the build. I configured the CMakeLists.txt, prj.conf and nrf7002dk_nrf5340_cpuapp_ns.conf to the best of my knowledge (based on the given wifi samples) but I've hit a roadblock.
Since I've got no prior experience with this board or Zephyr, I decided to start by just enabling the Wifi_scan functionality.
Right now I can "choose" which error I'd like to see:
1). Given this "main_scan()" function which I'm calling via REPL to use in microPy:
STATIC mp_obj_t main_scan(void)
	scan_result = 0U;
	 net_mgmt_init_event_callback(&wifi_shell_mgmt_cb,
					  wifi_mgmt_event_handler,
					  WIFI_SHELL_MGMT_EVENTS);
	 net_mgmt_add_event_callback(&wifi_shell_mgmt_cb);
	 k_sleep(K_SECONDS(1));
	 printk("Starting %s with CPU frequency: %d MHz\n", CONFIG_BOARD, SystemCoreClock / MHZ(1));
	 if (net_if_get_default() == NULL) {
		printk("Bad!!! \n");
		return 0;
	 if (!is_mac_addr_set(net_if_get_default())) {
		printk("0000\n");
		 struct net_if *iface = net_if_get_default();
		 int ret;
		 struct ethernet_req_params params;
		 /* Set a local MAC address with Nordic OUI */
		 if (net_if_is_admin_up(iface)) {
			 ret = net_if_down(iface);
			 if (ret < 0 && ret != -EALREADY) {
				 LOG_ERR("Cannot bring down iface (%d)", ret);
				 printk("11111\n");
				 return ret;
		 ret = net_bytes_from_str(params.mac_address.addr, sizeof(CONFIG_WIFI_MAC_ADDRESS),
					  CONFIG_WIFI_MAC_ADDRESS);
		 if (ret) {
			 LOG_ERR("Failed to parse MAC address: %s (%d)",
				 CONFIG_WIFI_MAC_ADDRESS, ret);
				 printk("2222\n");
			 return ret;
		 net_mgmt(NET_REQUEST_ETHERNET_SET_MAC_ADDRESS, iface,
			  &params, sizeof(params));
		 ret = net_if_up(iface);
			 LOG_ERR("Cannot bring up iface (%d)", ret);
			 return ret;
		 LOG_INF("OTP not programmed, proceeding with local MAC: %s", net_sprint_ll_addr(
							 net_if_get_link_addr(iface)->addr,
							 net_if_get_link_addr(iface)->len));
	 while (1) {
		 wifi_scan();
		 printk("Scanning\n");
		 k_sleep(K_SECONDS(CONFIG_WIFI_SCAN_INTERVAL_S));
	 return 0;
 static MP_DEFINE_CONST_FUN_OBJ_1(scan_obj, main_scan);
When I try to invoke it via these commands, I get a Secure Fault:
>>> [00:00:00.000,000] <dbg> counteMicroPython c44a93be3-dirty on 2025-04-18; zephyr-nrf7002dk with nrf5340
Type "help()" for more information.
>>> import network
>>> w = network.WLAN(network.AP_IF)
>>> w.scanwifi()
r_rtc.0: init_rtc: Initialized
--- 99 messages dropped ---
[00:00:00.473,236] <dbg> os: z_impl_k_mutex_lock: 0x20032370 took mutex 0x20030d64, count: 1, orig prio: 0
[00:00:00.473,266] <dbg> os: z_impl_k_mutex_unlock: mutex 0x20030d64 lock_count: 1
[00:00:00.473,297] <dbg> os: z_impl_k_mutex_unlock: new owner of mutex 0x20030d64: (nil) (prio: -1000)
[00:00:00.473,480] <inf> wifi_supplicant: wpa_supplicant initialized
[00:00:00.474,151] <dbg> os: z_impl_k_mutex_lock: 0x20032370 took mutex 0x20030d64, count: 1, orig prio: 0
[00:00:00.474,182] <dbg> os: z_impl_k_mutex_unlock: mutex 0x20030d64 lock_count: 1
[00:00:00.474,212] <dbg> os: z_impl_k_mutex_unlock: new owner of mutex 0x20030d64: (nil) (prio: -1000)
[00:00:00.474,914] <dbg> os: z_impl_k_mutex_lock: 0x20032370 took mutex 0x20030d64, count: 1, orig prio: 0
[00:00:00.474,945] <dbg> os: z_impl_k_mutex_unlock: mutex 0x20030d64 lock_count: 1
[00:00:00.474,975] <dbg> os: z_impl_k_mutex_unlock: new owner of mutex 0x20030d64: (nil) (prio: -1000)
[00:00:00.475,280] <dbg> os: z_impl_k_mutex_lock: 0x20032370 took mutex 0x200300e8, count: 1, orig prio: 0
[00:00:00.475,341] <dbg> os: z_impl_k_mutex_unlock: mutex 0x200300e8 lock_count: 1
[00:00:00.475,372] <dbg> os: z_impl_k_mutex_unlock: new owner of mutex 0x200300e8: (nil) (prio: -1000)
[00:00:00.475,402] <dbg> os: z_impl_k_mutex_lock: 0x20032370 took mutex 0x20030178, count: 1, orig prio: 0
[00:00:00.475,433] <dbg> os: z_impl_k_mutex_unlock: mutex 0x20030178 lock_count: 1
[00:00:00.475,463] <dbg> os: z_impl_k_mutex_unlock: new owner of mutex 0x20030178: (nil) (prio: -1000)
[00:00:10.473,632] <dbg> os: z_impl_k_mutex_lock: 0x20032370 took mutex 0x200300e8, count: 1, orig prio: 0
[00:00:10.473,663] <dbg> os: z_impl_k_mutex_unlock: mutex 0x200300e8 lock_count: 1
[00:00:10.473,693] <dbg> os: z_impl_k_mutex_unlock: new owner of mutex 0x200300e8: (nil) (prio: -1000)
[00:00:10.473,724] <dbg> os: z_impl_k_mutex_lock: 0x20032370 took mutex 0x20030178, count: 1, orig prio: 0
[00:00:10.473,785] <dbg> os: z_impl_k_mutex_unlock: mutex 0x20030178 lock_count: 1
[00:00:10.473,815] <dbg> os: z_impl_k_mutex_unlock: new owner of mutex 0x20030178: (nil) (prio: -1000)
[00:00:10.473,907] <dbg> os: z_impl_k_mutex_lock: 0x20032370 took mutex 0x200300e8, count: 1, orig prio: 0
[00:00:10.473,937] <dbg> os: z_impl_k_mutex_unlock: mutex 0x200300e8 lock_count: 1
[00:00:10.473,968] <dbg> os: z_impl_k_mutex_unlock: new owner of mutex 0x200300e8: (nil) (prio: -1000)
[00:00:10.473,999] <dbg> os: z_impl_k_mutex_lock: 0x20032370 took mutex 0x20030178, count: 1, orig prio: 0
[00:00:10.474,060] <dbg> os: z_impl_k_mutex_unlock: mutex 0x20030178 lock_count: 1
[00:00:10.474,090] <dbg> os: z_impl_k_mutex_unlock: new owner of mutex 0x20030178: (nil) (prio: -1000)
[00:00:20.473,999] <dbg> os: z_impl_k_mutex_lock: 0x20032370 took mutex 0x200300e8, count: 1, orig prio: 0
[00:00:20.474,029] <dbg> os: z_impl_k_mutex_unlock: mutex 0x200300e8 lock_count: 1
[00:00:20.474,060] <dbg> os: z_impl_k_mutex_unlock: new owner of mutex 0x200300e8: (nil) (prio: -1000)
[00:00:20.474,090] <dbg> os: z_impl_k_mutex_lock: 0x20032370 took mutex 0x20030178, count: 1, orig prio: 0
[00:00:20.474,151] <dbg> os: z_impl_k_mutex_unlock: mutex 0x20030178 lock_count: 1
[00:00:20.474,182] <dbg> os: z_impl_k_mutex_unlock: new owner of mutex 0x20030178: (nil) (prio: -1000)
[00:00:20.474,273] <dbg> os: z_impl_k_mutex_lock: 0x20032370 took mutex 0x200300e8, count: 1, orig prio: 0
[00:00:20.474,304] <dbg> os: z_impl_k_mutex_unlock: mutex 0x200300e8 lock_count: 1
[00:00:20.474,334] <dbg> os: z_impl_k_mutex_unlock: new owner of mutex 0x200300e8: (nil) (prio: -1000)
[00:00:20.474,365] <dbg> os: z_impl_k_mutex_lock: 0x20032370 took mutex 0x20030178, count: 1, orig prio: 0
[00:00:20.474,426] <dbg> os: z_impl_k_mutex_unlock: mutex 0x20030178 lock_count: 1
[00:00:20.474,456] <dbg> os: z_impl_k_mutex_unlock: new owner of mutex 0x20030178: (nil) (prio: -1000)
[00:00:30.474,365] <dbg> os: z_impl_k_mutex_lock: 0x20032370 took mutex 0x200300e8, count: 1, orig prio: 0
[00:00:30.474,426] <dbg> os: z_impl_k_mutex_unlock: mutex 0x200300e8 lock_count: 1
[00:00:30.474,456] <dbg> os: z_impl_k_mutex_unlock: new owner of mutex 0x200300e8: (nil) (prio: -1000)
[00:00:30.474,487] <dbg> os: z_impl_k_mutex_lock: 0x20032370 took mutex 0x20030178, count: 1, orig prio: 0
[00:00:30.474,517] <dbg> os: z_impl_k_mutex_unlock: mutex 0x20030178 lock_count: 1
[00:00:30.474,548] <dbg> os: z_impl_k_mutex_unlock: new owner of mutex 0x20030178: (nil) (prio: -1000)
[00:00:30.474,670] <dbg> os: z_impl_k_mutex_lock: 0x20032370 took mutex 0x200300e8, count: 1, orig prio: 0
[00:00:30.474,700] <dbg> os: z_impl_k_mutex_unlock: mutex 0x200300e8 lock_count: 1
[00:00:30.474,731] <dbg> os: z_impl_k_mutex_unlock: new owner of mutex 0x200300e8: (nil) (prio: -1000)
[00:00:30.474,761] <dbg> os: z_impl_k_mutex_lock: 0x20032370 took mutex 0x20030178, count: 1, orig prio: 0
[00:00:30.474,792] <dbg> os: z_impl_k_mutex_unlock: mutex 0x20030178 lock_count: 1
[00:00:30.474,822] <dbg> os: z_impl_k_mutex_unlock: new owner of mutex 0x20030178: (nil) (prio: -1000)
[00:00:40.474,792] <dbg> os: z_impl_k_mutex_lock: 0x20032370 took mutex 0x200300e8, count: 1, orig prio: 0
[00:00:40.474,822] <dbg> os: z_impl_k_mutex_unlock: mutex 0x200300e8 lock_count: 1
[00:00:40.474,853] <dbg> os: z_impl_k_mutex_unlock: new owner of mutex 0x200300e8: (nil) (prio: -1000)
[00:00:40.474,884] <dbg> os: z_impl_k_mutex_lock: 0x20032370 took mutex 0x20030178, count: 1, orig prio: 0
[00:00:40.474,914] <dbg> os: z_impl_k_mutex_unlock: mutex 0x20030178 lock_count: 1
[00:00:40.474,945] <dbg> os: z_impl_k_mutex_unlock: new owner of mutex 0x20030178: (nil) (prio: -1000)
[00:00:40.475,067] <dbg> os: z_impl_k_mutex_lock: 0x20032370 took mutex 0x200300e8, count: 1, orig prio: 0
[00:00:40.475,097] <dbg> os: z_impl_k_mutex_unlock: mutex 0x200300e8 lock_count: 1
[00:00:40.475,128] <dbg> os: z_impl_k_mutex_unlock: new owner of mutex 0x200300e8: (nil) (prio: -1000)
[00:00:40.475,158] <dbg> os: z_impl_k_mutex_lock: 0x20032370 took mutex 0x20030178, count: 1, orig prio: 0
[00:00:40.475,189] <dbg> os: z_impl_k_mutex_unlock: mutex 0x20030178 lock_count: 1
[00:00:40.475,219] <dbg> os: z_impl_k_mutex_unlock: new owner of mutex 0x20030178: (nil) (prio: -1000)
[00:00:50.475,128] <dbg> os: z_impl_k_mutex_lock: 0x20032370 took mutex 0x200300e8, count: 1, orig prio: 0
[00:00:50.475,189] <dbg> os: z_impl_k_mutex_unlock: mutex 0x200300e8 lock_count: 1
[00:00:50.475,219] <dbg> os: z_impl_k_mutex_unlock: new owner of mutex 0x200300e8: (nil) (prio: -1000)
[00:00:50.475,250] <dbg> os: z_impl_k_mutex_lock: 0x20032370 took mutex 0x20030178, count: 1, orig prio: 0
[00:00:50.475,280] <dbg> os: z_impl_k_mutex_unlock: mutex 0x20030178 lock_count: 1
[00:00:50.475,311] <dbg> os: z_impl_k_mutex_unlock: new owner of mutex 0x20030178: (nil) (prio: -1000)
[00:00:50.475,402] <dbg> os: z_impl_k_mutex_lock: 0x20032370 took mutex 0x200300e8, count: 1, orig prio: 0
[00:00:50.475,463] <dbg> os: z_impl_k_mutex_unlock: mutex 0x200300e8 lock_count: 1
[00:00:50.475,494] <dbg> os: z_impl_k_mutex_unlock: new owner of mutex 0x200300e8: (nil) (prio: -1000)
[00:00:50.475,524] <dbg> os: z_impl_k_mutex_lock: 0x20032370 took mutex 0x20030178, count: 1, orig prio: 0
[00:00:50.475,555] <dbg> os: z_impl_k_mutex_unlock: mutex 0x20030178 lock_count: 1
[00:00:50.475,585] <dbg> os: z_impl_k_mutex_unlock: new owner of mutex 0x20030178: (nil) (prio: -1000)
[00:01:00.475,524] <dbg> os: z_impl_k_mutex_lock: 0x20032370 took mutex 0x200300e8, count: 1, orig prio: 0
[00:01:00.475,555] <dbg> os: z_impl_k_mutex_unlock: mutex 0x200300e8 lock_count: 1
[00:01:00.475,585] <dbg> os: z_impl_k_mutex_unlock: new owner of mutex 0x200300e8: (nil) (prio: -1000)
[00:01:00.475,616] <dbg> os: z_impl_k_mutex_lock: 0x20032370 took mutex 0x20030178, count: 1, orig prio: 0
[00:01:00.475,646] <dbg> os: z_impl_k_mutex_unlock: mutex 0x20030178 lock_count: 1
[00:01:00.475,677] <dbg> os: z_impl_k_mutex_unlock: new owner of mutex 0x20030178: (nil) (prio: -1000)
[00:01:00.475,799] <dbg> os: z_impl_k_mutex_lock: 0x20032370 took mutex 0x200300e8, count: 1, orig prio: 0
[00:01:00.475,830] <dbg> os: z_impl_k_mutex_unlock: mutex 0x200300e8 lock_count: 1
[00:01:00.475,860] <dbg> os: z_impl_k_mutex_unlock: new owner of mutex 0x200300e8: (nil) (prio: -1000)
[00:01:00.475,891] <dbg> os: z_impl_k_mutex_lock: 0x20032370 took mutex 0x20030178, count: 1, orig prio: 0
[00:01:00.475,921] <dbg> os: z_impl_k_mutex_unlock: mutex 0x20030178 lock_count: 1
[00:01:00.475,952] <dbg> os: z_impl_k_mutex_unlock: new owner of mutex 0x20030178: (nil) (prio: -1000)
[00:01:06.882,568] <dbg> os: z_impl_k_mutex_lock: 0x200336f8 took mutex 0x20030e04, count: 1, orig prio: 0
[00:01:06.882,598] <dbg> os: z_impl_k_mutex_unlock: mutex 0x20030e04 lock_count: 1
[00:01:06.882,629] <dbg> os: z_impl_k_mutex_unlock: new owner of mutex 0x20030e04: (nil) (prio: -1000)
[00:01:06.882,659] <dbg> os: z_tick_sleep: thread 0x200336f8 for 32768 ticks
[00:01:06.882,720] <dbg> os: z_impl_k_mutex_lock: 0x20032228 took mutex 0x20030e04, count: 1, orig prio: 7
[00:01:06.882,751] <dbg> os: z_impl_k_mutex_unlock: mutex 0x20030e04 lock_count: 1
[00:01:06.882,781] <dbg> os: z_impl_k_mutex_unlock: new owner of mutex 0x20030e04: (nil) (prio: -1000)
[00:01:07.770,935] <dbg> os: z_impl_k_mutex_lock: 0x20032b88 took mutex 0x20030d64, count: 1, orig prio: 14
[00:01:07.770,965] <dbg> os: z_impl_k_mutex_unlock: mutex 0x20030d64 lock_count: 1
[00:01:07.770,996] <dbg> os: z_impl_k_mutex_unlock: new owner of mutex 0x20030d64: (nil) (prio: -1000)
[00:01:07.771,026] <dbg> os: z_impl_k_mutex_lock: 0x20032b88 took mutex 0x20030d78, count: 1, orig prio: 14
[00:01:07.771,057] <dbg> os: z_impl_k_mutex_unlock: mutex 0x20030d78 lock_count: 1
[00:01:07.771,057] <dbg> os: z_impl_k_mutex_unlock: new owner of mutex 0x20030d78: (nil) (prio: -1000)
[00:01:07.771,087] <dbg> os: z_impl_k_mutex_lock: 0x20032b88 took mutex 0x200301a8, count: 1, orig prio: 14
[00:01:07.771,118] <dbg> os: z_impl_k_mutex_unlock: mutex 0x200301a8 lock_count: 1
[00:01:07.771,118] <dbg> os: z_impl_k_mutex_unlock: new owner of mutex 0x200301a8: (nil) (prio: -1000)
Starting nrf7002dk with CPU frequency: 64 MHz
Bad!!!
[00:01:07.885,375] <err> os: ***** SECURE FAULT *****
[00:01:07.885,375] <err> os: Address: 0x0
[00:01:07.885,375] <err> os: Attribution unit violation
[00:01:07.885,406] <err> os: r0/a1: 0x00000000 r1/a2: 0x00000000 r2/a3: 0x00000001
[00:01:07.885,437] <err> os: r3/a4: 0x00000000 r12/ip: 0x000beffb r14/lr: 0x0008189b
[00:01:07.885,437] <err> os: xpsr: 0x45000c00
[00:01:07.885,467] <err> os: s[ 0]: 0x200335d0 s[ 1]: 0x00000000 s[ 2]: 0x200335a8 s[ 3]: 0x00042813
[00:01:07.885,467] <err> os: s[ 4]: 0x00000000 s[ 5]: 0x000bcb7b s[ 6]: 0x00000000 s[ 7]: 0x00000000
[00:01:07.885,498] <err> os: s[ 8]: 0x00000002 s[ 9]: 0x00000020 s[10]: 0x00000000 s[11]: 0x00000000
[00:01:07.885,528] <err> os: s[12]: 0x0021e2b5 s[13]: 0x0007f9db s[14]: 0x20033818 s[15]: 0x0007f987
[00:01:07.885,528] <err> os: fpscr: 0x20033818
[00:01:07.885,528] <err> os: Faulting instruction address (r15/pc): 0x00081876
[00:01:07.885,589] <err> os: >>> ZEPHYR FATAL ERROR 41: Unknown error on CPU 0
[00:01:07.885,620] <err> os: Current thread: 0x200336f8 (mp_main)
[00:01:08.084,197] <err> os: Halting system
Which lead me to the suspicion that the network interface is not initialized and "net_if_get_default()" (line 19 in the above function) is returning NULL.
2). So I decided to see if I can do a "net_if_set_default()" via the "active" function:
STATIC mp_obj_t wlan_active(size_t n_args, const mp_obj_t *args) {
    wlan_obj_t *self = MP_OBJ_TO_PTR(args[0]);
    if (n_args == 1) {
        return mp_obj_new_bool(self->is_active);
    } else {
        self->is_active = mp_obj_is_true(args[1]);
        if (self->is_active) {
            if (self->iface == NULL) {
                // const struct device *dev = DEVICE_DT_GET(DT_NODELABEL(wifi0));
				// const struct device *dev = DEVICE_DT_GET_ONE(nordic_nrf700x);
				const struct device *dev = DEVICE_DT_GET(DT_CHOSEN(zephyr_wifi));
				struct net_if *wifi_iface = net_if_lookup_by_dev(dev);
				/* As both are Ethernet, we need to set specific interface*/
				net_if_set_default(wifi_iface);
				net_config_init_app(dev, "Initializing network");
				/* TODO: Add proper synchronization to wait for WPA supplicant initialization */
				k_sleep(K_SECONDS(2));
                if (!device_is_ready(dev)) {
                    mp_raise_msg(&mp_type_RuntimeError, MP_ERROR_TEXT("Wi-Fi device not ready"));
                struct net_if *iface = net_if_lookup_by_dev(dev);
                if (!iface) {
                    mp_raise_msg(&mp_type_RuntimeError, MP_ERROR_TEXT("No network interface for Wi-Fi"));
                self->iface = iface;
                net_if_set_default(self->iface);  // make net_if_get_default() work
            // Bring the interface up if needed
            if (!net_if_is_up(self->iface)) {
                net_if_up(self->iface);
        } else {
            if (self->iface && net_if_is_up(self->iface)) {
                net_if_down(self->iface);
        return mp_const_none;
But this brings its own predicaments since the project won't build with this function; giving the error:
[16/20] Linking C executable zephyr/zephyr_pre0.elf
FAILED: zephyr/zephyr_pre0.elf zephyr/zephyr_pre0.map /Users/tudor/Documents/GitHub/micropython_nRF/ports/zephyr/build/zephyr/zephyr/zephyr_pre0.map
: && ccache /opt/nordic/ncs/toolchains/b8efef2ad5/opt/zephyr-sdk/arm-zephyr-eabi/bin/arm-zephyr-eabi-gcc -Os -DNDEBUG -gdwarf-4 -gdwarf-4 zephyr/CMakeFiles/zephyr_pre0.dir/misc/empty_file.c.obj -o zephyr/zephyr_pre0.elf zephyr/CMakeFiles/offsets.dir/./arch/arm/core/offsets/offsets.c.obj tfm/api_ns/interface/lib/s_veneers.o -T zephyr/linker_zephyr_pre0.cmd -Wl,-Map=/Users/tudor/Documents/GitHub/micropython_nRF/ports/zephyr/build/zephyr/zephyr/zephyr_pre0.map -Wl,--whole-archive app/libapp.a zephyr/libzephyr.a zephyr/arch/common/libarch__common.a zephyr/arch/arch/arm/core/libarch__arm__core.a zephyr/arch/arch/arm/core/cortex_m/libarch__arm__core__cortex_m.a zephyr/arch/arch/arm/core/cortex_m/cmse/libarch__arm__core__cortex_m__cmse.a zephyr/arch/arch/arm/core/mpu/libarch__arm__core__mpu.a zephyr/lib/libc/newlib/liblib__libc__newlib.a zephyr/lib/libc/common/liblib__libc__common.a zephyr/lib/posix/options/liblib__posix__options.a zephyr/lib/net_buf/liblib__net_buf.a zephyr/lib/os/zvfs/liblib__os__zvfs.a zephyr/soc/soc/nrf5340/libsoc__nordic.a zephyr/subsys/fs/libsubsys__fs.a zephyr/subsys/random/libsubsys__random.a zephyr/subsys/net/libsubsys__net.a zephyr/subsys/net/l2/offloaded_netdev/libsubsys__net__l2__offloaded_netdev.a zephyr/subsys/net/l2/ethernet/libsubsys__net__l2__ethernet.a zephyr/subsys/net/l2/wifi/libsubsys__net__l2__wifi.a zephyr/subsys/net/ip/libsubsys__net__ip.a zephyr/subsys/net/lib/config/libsubsys__net__lib__config.a zephyr/subsys/net/lib/dhcpv4/libsubsys__net__lib__dhcpv4.a zephyr/subsys/net/lib/dns/libsubsys__net__lib__dns.a zephyr/subsys/net/conn_mgr/libsubsys__net__conn_mgr.a zephyr/drivers/clock_control/libdrivers__clock_control.a zephyr/drivers/console/libdrivers__console.a zephyr/drivers/counter/libdrivers__counter.a zephyr/drivers/entropy/libdrivers__entropy.a zephyr/drivers/flash/libdrivers__flash.a zephyr/drivers/gpio/libdrivers__gpio.a zephyr/drivers/mbox/libdrivers__mbox.a zephyr/drivers/pinctrl/libdrivers__pinctrl.a zephyr/drivers/pwm/libdrivers__pwm.a zephyr/drivers/serial/libdrivers__serial.a zephyr/drivers/spi/libdrivers__spi.a zephyr/drivers/timer/libdrivers__timer.a zephyr/drivers/watchdog/libdrivers__watchdog.a modules/nrf/subsys/nrf_security/src/zephyr/libmbedtls_zephyr.a modules/nrf/subsys/net/lib/wifi_ready/libWIFI_READY_LIB.a modules/nrf/subsys/net/l2_wifi_if_conn/lib..__nrf__subsys__net__l2_wifi_if_conn.a modules/nrf/modules/trusted-firmware-m/lib..__nrf__modules__trusted-firmware-m.a modules/nrf/modules/trusted-firmware-m/libtfm_api_nrf.a modules/trusted-firmware-m/libtfm_api.a modules/hal_nordic/nrfx/libmodules__hal_nordic__nrfx.a -Wl,--no-whole-archive zephyr/kernel/libkernel.a -L/Users/tudor/Documents/GitHub/micropython_nRF/ports/zephyr/build/zephyr/zephyr libmicropython.a zephyr/kernel/libkernel.a zephyr/arch/common/libisr_tables.a -mcpu=cortex-m33 -mthumb -mabi=aapcs -mfpu=fpv5-sp-d16 -mfloat-abi=hard -mfp16-format=ieee -fuse-ld=bfd -Wl,--gc-sections -Wl,--build-id=none -Wl,--sort-common=descending -Wl,--sort-section=alignment -Wl,-u,_OffsetAbsSyms -Wl,-u,_ConfigAbsSyms -nostdlib -static -Wl,-X -Wl,-N -Wl,--orphan-handling=warn -Wl,-no-pie -L"/opt/nordic/ncs/toolchains/b8efef2ad5/opt/zephyr-sdk/arm-zephyr-eabi/arm-zephyr-eabi"/lib/thumb/v8-m.main+fp/hard -specs=nano.specs modules/nrf/subsys/nrf_security/src/libmbedtls.a modules/nrf/subsys/nrf_security/src/libmbedx509.a modules/nrf/subsys/nrf_security/src/libmbedcrypto.a modules/nrf/subsys/nrf_security/src/libmbedcrypto_base.a modules/nrf/subsys/nrf_security/src/libnrf_security_utils.a zephyr/kernel/libkernel.a /opt/nordic/ncs/v2.9.1/nrfxlib/crypto/nrf_oberon/lib/cortex-m33/hard-float/liboberon_mbedtls_3.0.15.a /opt/nordic/ncs/v2.9.1/nrfxlib/crypto/nrf_oberon/lib/cortex-m33/hard-float/liboberon_3.0.15.a -lc -L"/opt/nordic/ncs/toolchains/b8efef2ad5/opt/zephyr-sdk/arm-zephyr-eabi/bin/../lib/gcc/arm-zephyr-eabi/12.2.0/thumb/v8-m.main+fp/hard" -lm -lc -lgcc -lc && cd /Users/tudor/Documents/GitHub/micropython_nRF/ports/zephyr/build/zephyr/zephyr && /opt/homebrew/bin/cmake -E true
/opt/nordic/ncs/toolchains/b8efef2ad5/opt/zephyr-sdk/arm-zephyr-eabi/bin/../lib/gcc/arm-zephyr-eabi/12.2.0/../../../../arm-zephyr-eabi/bin/ld.bfd: libmicropython.a(modnetwork.c.obj): in function `wlan_active':
/Users/tudor/Documents/GitHub/micropython_nRF/ports/zephyr/../../ports/zephyr/network_wlan.c:165: undefined reference to `__device_dts_ord_135'
collect2: error: ld returned 1 exit status
FAILED: _sysbuild/sysbuild/images/zephyr-prefix/src/zephyr-stamp/zephyr-build /Users/tudor/Documents/GitHub/micropython_nRF/ports/zephyr/build/_sysbuild/sysbuild/images/zephyr-prefix/src/zephyr-stamp/zephyr-build
cd /Users/tudor/Documents/GitHub/micropython_nRF/ports/zephyr/build/zephyr && /opt/homebrew/bin/cmake --build .
FATAL ERROR: command exited with status 1: /opt/homebrew/bin/cmake --build /Users/tudor/Documents/GitHub/micropython_nRF/ports/zephyr/build
Where network_wlan.c:169: undefined reference to `__device_dts_ord_135' points to this line of code inside the "wlan_active()" function:
A bit of digging (github.com/.../41677) leads to the hypothesis that a few lines above, the definition of the Wifi interface doesn't actually work/ isn't instantiated and returns NULL:
Not sure if it makes a difference but: I'm using an Apple M1 MacBook.
I can provide any of the above files (or others) if needed, to be able to solve this mistery. I'm sure it's something trivial, but can't figure out what. -.-
Does anyone have any idea what might be causing these issues and what's the correct way of moving forward to be able to do a correct "wifi scan"? Thank you in advance and I hope you have a wonderful day!
  • You can refer to the Memory footprint optimization to reduce the size, and try to add CONFIG_WIFI_CREDENTIALS=y in the prj.conf to fix the undefined reference to `net_mgmt_NET_REQUEST_WIFI_CONNECT_STORED'.
  • I tried following the guides in here: https://docs.nordicsemi.com/bundle/ncs-latest/page/zephyr/develop/optimizations/tools.html
    and here: https://docs.nordicsemi.com/bundle/ncs-latest/page/zephyr/build/sysbuild/index.html#sysbuild-dedicated-image-build-targets
    When building the rom_report using the command "west build -d build/mcuboot -t rom_report", but I get one of two errors.
    1).
    root@MacBookAir zephyr # west build -d build/mcuboot -t rom_report
    ERROR: Cached board not defined, please provide it (provide --board, set default with "west config build.board <BOARD>", or set BOARD in the environment)
    FATAL ERROR: refusing to proceed without --force due to above error
    2).
    WARNING: This looks like a fresh build and BOARD is unknown; so it probably won't work. To fix, use --board=<your-board>.
    Note: to silence the above message, run 'west config build.board_warn false'
    Loading Zephyr module(s) (Zephyr base): sysbuild_default
    -- Found Python3: /Library/Developer/CommandLineTools/usr/bin/python3 (found suitable version "3.9.6", minimum required is "3.8") found components: Interpreter
    -- Cache files will be written to: /Users/tudor/Library/Caches/zephyr
    -- Found west (found suitable version "1.3.0", minimum required is "0.14.0")
    CMake Error at /opt/nordic/ncs/v2.9.1/zephyr/cmake/modules/extensions.cmake:3457 (message):
      BOARD is not being defined on the CMake command-line, in the environment or
      by the app.
      /opt/nordic/ncs/v2.9.1/zephyr/cmake/modules/boards.cmake:61 (zephyr_check_cache)
      cmake/modules/sysbuild_default.cmake:15 (include)
      /opt/nordic/ncs/v2.9.1/zephyr/share/zephyr-package/cmake/ZephyrConfig.cmake:75 (include)
      /opt/nordic/ncs/v2.9.1/zephyr/share/zephyr-package/cmake/ZephyrConfig.cmake:92 (include_boilerplate)
      /opt/nordic/ncs/v2.9.1/zephyr/share/sysbuild-package/cmake/SysbuildConfig.cmake:8 (include)
      template/CMakeLists.txt:10 (find_package)
    When trying to build using "west build -t rom_report", I get:
    root@MacBookAir zephyr # west build -t rom_report
    -- west build: running target rom_report
    ninja: error: unknown target 'rom_report'
    FATAL ERROR: command exited with status 1: /opt/homebrew/bin/cmake --build /Users/tudor/Documents/GitHub/micropython_nRF/ports/zephyr/build --target rom_report
    Edit:
    I forgot to add that "add CONFIG_WIFI_CREDENTIALS=y in the prj.conf to fix the undefined reference to `net_mgmt_NET_REQUEST_WIFI_CONNECT_STORED'." worked like a charm! Thank you very much Amanda!
    The overflowing ROM and RAM are the only things that remain.
    Edit 2:
    Is it possible to do a call so that we can quickly solve this issue?
    Do you build your application with mcuboot? Did you have the build/mcuboot folder? That command would analyze the RAM usage for mcuboot.
    If you want to analyze your application, you should run
    west build -d ./build/Your_App_Name -t ram_report
  • Managed to make everything fit by minimising TFM:
    CONFIG_TFM_PROFILE_TYPE_MINIMAL=y
    # CONFIG_TFM_PROFILE_TYPE_NOT_SET=y
    Resulting in a much smaller ROM footprint:
    -- open-amp version: 1.6.1 (/opt/nordic/ncs/v2.9.1/modules/lib/open-amp/open-amp)
    -- Host:    Darwin/arm64
    -- Target:  Generic/arm
    -- Machine: arm
    -- C_FLAGS :  -Wall -Wextra
    -- Using ccache: /opt/nordic/ncs/toolchains/ef4fc6722e/bin/ccache
    -- Found Python3: /opt/nordic/ncs/toolchains/ef4fc6722e/bin/python3 (found version "3.12.4") found components: Interpreter
    -- Configuring done (5.7s)
    -- Generating done (0.4s)
    -- Build files have been written to: /Users/tudor/Documents/GitHub/micropython_nRF/ports/zephyr/build/zephyr
    [0/219] Performing build step for 'tfm'
    [38/42] Linking C executable bin/tfm_s.axf
               FLASH:       32100 B        32 KB     97.96%
                 RAM:       10692 B        32 KB     32.63%
    [42/42] Linking C static library secure_fw/libtfm_s_veneers.a
    [5/14] Performing install step for 'tfm'
    -- Install configuration: "MinSizeRel"
    -- Installing: /Users/tudor/Documents/GitHub/micropython_nRF/ports/zephyr/build/zephyr/tfm/api_ns/bin/tfm_s.axf
    -- Installing: /Users/tudor/Documents/GitHub/micropython_nRF/ports/zephyr/build/zephyr/tfm/api_ns/bin/tfm_s.bin
    -- Installing: /Users/tudor/Documents/GitHub/micropython_nRF/ports/zephyr/build/zephyr/tfm/api_ns/bin/tfm_s.hex
    -- Installing: /Users/tudor/Documents/GitHub/micropython_nRF/ports/zephyr/build/zephyr/tfm/api_ns/bin/tfm_s.elf
    -- Installing: /Users/tudor/Documents/GitHub/micropython_nRF/ports/zephyr/build/zephyr/tfm/api_ns/bin/tfm_s.map
    -- Installing: /Users/tudor/Documents/GitHub/micropython_nRF/ports/zephyr/build/zephyr/tfm/api_ns/interface/lib/s_veneers.o
    -- Installing: /Users/tudor/Documents/GitHub/micropython_nRF/ports/zephyr/build/zephyr/tfm/api_ns/interface/include/nrf-config.h
    -- Installing: /Users/tudor/Documents/GitHub/micropython_nRF/ports/zephyr/build/zephyr/tfm/api_ns/interface/include/nrf-psa-crypto-config.h
    ----- Installing platform NS -----
    [14/14] Linking C executable zephyr/zephyr.elf
               FLASH:      811104 B       960 KB     82.51%
                 RAM:      301140 B       416 KB     70.69%
            IDT_LIST:          0 GB        32 KB      0.00%
    Generating files from /Users/tudor/Documents/GitHub/micropython_nRF/ports/zephyr/build/zephyr/zephyr/zephyr.elf for board: nrf7002dk
    [5/5] Generating ../merged.hex
    Normally the command we run is:
     west build -b nrf7002dk/nrf5340/cpuapp/ns
    Adapting your suggestion to our command (west build -d nrf7002dk/nrf5340/cpuapp/ns -t ram_report) results in:
    root@MacBookAir zephyr # west build -d nrf7002dk/nrf5340/cpuapp/ns -t ram_report
      by the app.
    FATAL ERROR: command exited with status 1: /opt/homebrew/bin/cmake -DWEST_PYTHON=/Library/Developer/CommandLineTools/usr/bin/python3 -B/Users/tudor/Documents/GitHub/micropython_nRF/ports/zephyr/nrf7002dk/nrf5340/cpuapp/ns -GNinja -S/opt/nordic/ncs/v2.9.1/zephyr/share/sysbuild -DAPP_DIR:PATH=/Users/tudor/Documents/GitHub/micropython_nRF/ports/zephyr
    Edit:
    I tried specifying the board also in the build command. I did a -- pristine, then a normal build, then a -t ram_report build and got:
    root@MacBookAir zephyr # west build -b nrf7002dk/nrf5340/cpuapp/ns -d ./build/nrf7002dk/nrf5340/cpuapp/ns -t ram_report
    -- west build: running target ram_report
    ninja: error: unknown target 'ram_report'
    FATAL ERROR: command exited with status 1: /opt/homebrew/bin/cmake --build /Users/tudor/Documents/GitHub/micropython_nRF/ports/zephyr/build/nrf7002dk/nrf5340/cpuapp/ns --target ram_report
  • Good to know you find the configs to reduce the image size.
    As I explained, you executed the ram_report command for your application as: west build -d ./build/zephyr  -t ram_report
