problems with forwarding read rssi values to the wifi module through serial port
Hello. I am using nrf52832 for Ble-based positioning. currently i am tackling with establishment of an anchor measuring rssi values and sending them to a central center (a PC) through an additional wifi module. i am sending data from nrf52832 to the wifi module through serial (UART) connection. to this end, i combined a simple UART example with a blincky-c example of nrf5sdk. doing so, i receive a couple of rssi values and then the transmission to pc stocks. i tried chaning the priority of the UART transmission from lowest to highest and it seems to work. i wonder to know whether my job was ok or this change of priority may cause other problems...
Moreover, i have tried combining the libuarte example to the ble central blincky which is expected to handle my above problem, but it did not work (send data on serial) due to an unkown reason.
best regards,
  • I am using the board xl52832, containing nrf52832. all nrf52832 pins are accessible through its pins.
  • Hi
    Okay, can you confirm what you mean by changing the UART transmission priority from "lowest" to "highest" means? There are 8 priority levels in the nRF52832, from 0-7 where 0 is highest. Priority levels 0, 1, 3, and 4 are reserved for the SoftDevice, so the highest available priority you can set a user configured peripheral to would be priority 2. If you're not setting the UART to use one of the SoftDevice reserved priorities, it should be perfectly fine to use if that solves your problem.
    Simon
  • Hi
    & thanks a lot for your precise hints. here is my code:
    i have set it in this function:
    static void uart_init(void)
    ret_code_t err_code;
    .rx_pin_no = RX_PIN_NUMBER,
    .tx_pin_no = TX_PIN_NUMBER,
    .rts_pin_no = RTS_PIN_NUMBER,
    .cts_pin_no = CTS_PIN_NUMBER,
    .use_parity = false,
    .baud_rate = UART_BAUDRATE_BAUDRATE_Baud115200
    UART_RX_BUF_SIZE,
    UART_TX_BUF_SIZE,
    uart_error_handle,
    APP_IRQ_PRIORITY_HIGHEST,
    err_code);
    and the term is defined in 'app_util_platform" as :
    //lint -save -e113 -e452
    /**@brief The interrupt priorities available to the application while the SoftDevice is active. */
    typedef enum
    #ifndef SOFTDEVICE_PRESENT
    APP_IRQ_PRIORITY_HIGHEST = _PRIO_SD_HIGH,
    #else
    APP_IRQ_PRIORITY_HIGHEST = _PRIO_APP_HIGH,
    APP_IRQ_PRIORITY_HIGH = _PRIO_APP_HIGH,
    APP_IRQ_PRIORITY_MID = _PRIO_SD_LOW,
    #else
    APP_IRQ_PRIORITY_MID = _PRIO_APP_MID,
    APP_IRQ_PRIORITY_LOW_MID = _PRIO_APP_LOW_MID,
    APP_IRQ_PRIORITY_LOW = _PRIO_APP_LOW,
    APP_IRQ_PRIORITY_LOWEST = _PRIO_APP_LOWEST,
    APP_IRQ_PRIORITY_THREAD = _PRIO_THREAD /**< "Interrupt level" when running in Thread Mode. */
    } app_irq_priority_t;
    //lint -restore
    it seems to be one of those reserved, yes?
  • Hi Ali
    As long as the project is defined for an CORTEX_M4 it seems like PRIO_APP_HIGH refers to priority 2 (see app_util_platform.h in the SDK), which is not reserved for SoftDevice functions, so that should be fine to use here. If that works for you it's okay to use.
    Simon
  • Hi dear Simon,
    I am really thankful for your help.
    Ali
