Hello Everyone,
I try to develop Nuvoton + NRF24L01 SPI communicate each other. And I don't understand why MISO bus has 0x0E after I send Write_Command 0x20?
void NRF24_AdressTX(uint8_t reg, uint8_t *dataa)
SPI_send_byte(0x20 | reg);
SPI_send_byte(dataa[0]);
SPI_send_byte(dataa[1]);
SPI_send_byte(dataa[2]);
SPI_send_byte(dataa[3]);
SPI_send_byte(dataa[4]);
void NRF24_Init() //NRF24L01 CONFIGURATIONS
nrf24_WriteReg(CONFIG, 0x02);
nrf24_WriteReg(EN_AA, 0x00);
nrf24_WriteReg(EN_RXADDR, 0x01);
nrf24_WriteReg(SETUP_AW, 0x03);
nrf24_WriteReg(SETUP_RETR, 0x00);
nrf24_WriteReg(RF_CH, 0x00);
nrf24_WriteReg(RF_SETUP, 0x0E);
NRF24_AdressTX(TX_ADDR, TxAddr);
And I send these configurations to MOSI bus as you can see in the picture. Is it correct way?
while(1)
NRF24_Transmit(0x01);
delayMS(500);
After configurations datas, I send 0xA0(PAYLOAD) and 0x01(MY DATA). I still get 0x0E, Why MISO Bus return 0x0E every write command?
NOTE: This code works as only transmitter. Not Reciever.
Questions
1) Is it correct way to control NRF24L01? If I am not what is the correct way for it?
2) My SCK Delay is 15us HIGH 15us LOW, is it enough?
3) When I Triggered CE pins HIGH TO LOW, I started to write period and send 1 byte data as well, but Is CE Pin need to be HIGH to finished sending all data? Or CE trigger is okay as you can see at above the picture.
