How to know that the device disconnected due to an authentication failure
I configured for using security BT_SECURITY_L2 for a device that I had previously configured for using BT_SECURITY_L4. When I try to connect with an Android phone that was previously paired when configured for BT_SECURITY_L4, it prints "SMP does not allow a pairing failure at this point. Known issue. Disconnecting instead." to the log and then disconnects.
From this question [here], for solving this issue I need to call bt_unpair(...) to erase bonding information.
How can I know, inside the callback disconnected, that the connection was closed with BT_HCI_ERR_AUTH_FAIL? I always receive reason 22 (BT_HCI_ERR_LOCALHOST_TERM_CONN).
BR
  • None of those options seemed to make a change in behaviour.
    Could you, please, point me to a working example for LE Secure Connections pairing using Level 2, Just Works?
    I configured the characteristics for using READ/WRITE with BT_GATT_PERM_READ_ENCRYPT/BT_GATT_PERM_WRITE_ENCRYPT, called bt_conn_set_security(conn, BT_SECURITY_L2); in the connected callback.
    Should I add any configuration option in prj.conf to indicate the Android device it should not try to pair with the device using a PIN or KEY?
    BR
  • Please make a sniffer log if you are not able to make this work by removing the device from the phone (and BT off/on to clear cache) and a full erase of the peripheral (e.g. eraseall or recover).
    Kenneth
