Framing Errors seen on nRF54L15 UART. Is it super sensitive to stop bit timing?
I am getting framing error notifications from the nrfx uarte driver on a zephyr platform when receiving data from a certain external device, but only when there are large bursts of data.
The data is at 115200bps, 8 bit, no parity, so not particularly fast.
The device I am receiving from has very tight timing (the stop bit is exactly one bit time well within tolerance), and often sends large (multiple hundreds of bytes) streams with no idle time between stop bit and following start bit. This device cannot have its serial settings modified (to increase the number of stop bits to 2 for example).
Looking at the data with both an oscilloscope and a very oversampled logic analyser (which will report formatting problems), the actual data on the line seems fine, but I can't be sure that it is consistent.
When I look at the data received from the driver, I generally just see missing bytes, rather than bad data (with a few exceptions), which seem to come from the data being dropped when the driver cancels the rx, and I suspect that I can't re-enable it fast enough.
As far as I can tell, I have the external oscillator enabled, and constant latency mode enabled, but I am not sure if there is any interplay with the nordic/zephyr code that may be altering this.
I am using the zephyr async API, with a slab buffer with 8 128 byte receive buffers handled, which seems to me to be the highest performing approach.
I have previously seen some UARTs which required ever so slightly more than a single bit time for the STOP before a new START bit, with very similar symptoms to what I have seen here.
My questions are:
  • Is the baud rate divisor in SDK 2.9.1 for 115200 bps still correct? I have noticed that there are forum posts that state that this shouldn't be modified, but also that it doesn't line up with the formula also reported on the forums. Is the special adjusted baud rate divisor only for running from internal RC oscillator (and therefore tuned to it)?
  • Is there a surefire way to disable any change on clock source/latency settings so that I can be sure that I am testing under the correct conditions?
My concern is that effectively the same code was talking to a cellular modem at a much high baud rate with total reliability, suggesting to me that the UARTE hardware might be a bit fussy about stop bit length.
Nathan Boyd
  • I had a similar issue (I think, I may be wrong in my understanding of your issue) where using the asynchronous UART driver I would get missed and corrupted bytes received.
    I stumbled on a solution to my issue in some sample code.
    While using async UART API:
    CONFIG_UART_ASYNC_API=y
    CONFIG_UART_INTERRUPT_DRIVEN=n
    I would see corrupted and missed Rx bytes intermittently.
    I found that the issue went away if I added the following:
    CONFIG_UART_0_ASYNC=y
    CONFIG_UART_0_INTERRUPT_DRIVEN=n
    CONFIG_UART_0_NRF_HW_ASYNC=y
    CONFIG_UART_0_NRF_HW_ASYNC_TIMER=2
    CONFIG_NRFX_TIMER2=y
    CONFIG_UART_1_ASYNC=y
    CONFIG_UART_1_INTERRUPT_DRIVEN=n
    CONFIG_UART_1_NRF_HW_ASYNC=y
    CONFIG_UART_1_NRF_HW_ASYNC_TIMER=3
    CONFIG_NRFX_TIMER3=y
    In my use case, I am using both uart0 and uart1.
