SPIM Receive data is always 1bit shift Thingy91
Hello, I searched the forum for similar issues and found a few, such as  SPIM Recevie data is allways 1bit shift
I am currently implementing a PSRAM is66wvs4m8 on the Thingy 91 via SPI, using SPIM3.
The problem I'm facing is that the data I read is shifted. I’ve attached a ZIP file containing the project and some logs that show the issue.
When I write the same value to multiple memory addresses and read them back, the logic analyzer shows the correct value repeating (similar to a PWM signal), but the data is misaligned with the clock, causing parsing errors.
I’ve tried different SPI modes (only mode 0 seems to work, matching the PSRAM datasheet) and various clock frequencies, but the issue persists.
Any advice or suggestions?
Thanks in advance!
START - test_psram
Set up CS 8 at gpio@842500 pin 8
Set up CS 7 at gpio@842500 pin 7
CE pin 10
D: dest[0]: 0x00
D: dest[1]: 0x00
D: dest[2]: 0x00
D: dest[3]: 0x00
D: dest[4]: 0x31
D: dest[5]: 0x85
D: dest[6]: 0x00
D: dest[7]: 0x30
D: dest[8]: 0x08
D: dest[9]: 0x09
D: dest[10]: 0x8c
D: dest[11]: 0x28
D: Manufacturer ID: 0x31
D: KGD: 0x85
D: Device Density: 8 Mb
E: Error: Manufacturer ID does not match expected value of 0x9d
E: Error: Could not read vendor id
D: memc_is66wvs4m8_init: -5
D: Data: 0 0x00 0b00000000
D: Writing 16 bytes to address 0x000000
D: SPI TX[0]:   2       0x02    0b00000010
D: SPI TX[1]:   0       0x00    0b00000000
D: SPI TX[2]:   0       0x00    0b00000000
D: SPI TX[3]:   0       0x00    0b00000000
D: SPI TX[4]:   0       0x00    0b00000000
D: SPI TX[5]:   0       0x00    0b00000000
D: SPI TX[6]:   0       0x00    0b00000000
D: SPI TX[7]:   0       0x00    0b00000000
D: SPI TX[8]:   0       0x00    0b00000000
D: SPI TX[9]:   0       0x00    0b00000000
D: SPI TX[10]:  0       0x00    0b00000000
D: SPI TX[11]:  0       0x00    0b00000000
D: SPI TX[12]:  0       0x00    0b00000000
D: SPI TX[13]:  0       0x00    0b00000000
D: SPI TX[14]:  0       0x00    0b00000000
D: SPI TX[15]:  0       0x00    0b00000000
D: SPI TX[16]:  0       0x00    0b00000000
D: SPI TX[17]:  0       0x00    0b00000000
D: SPI TX[18]:  0       0x00    0b00000000
D: SPI TX[19]:  0       0x00    0b00000000
D: memc_is66wvs4m8_write: 0
D: Reading 16 bytes from address 0x00000000
D: SPI RX[0]:   0       0x00    0b00000000
D: SPI RX[1]:   0       0x00    0b00000000
D: SPI RX[2]:   0       0x00    0b00000000
D: SPI RX[3]:   0       0x00    0b00000000
D: SPI RX[4]:   0       0x00    0b00000000
D: SPI RX[5]:   0       0x00    0b00000000
D: SPI RX[6]:   0       0x00    0b00000000
D: SPI RX[7]:   0       0x00    0b00000000
D: SPI RX[8]:   0       0x00    0b00000000
D: SPI RX[9]:   0       0x00    0b00000000
D: SPI RX[10]:  0       0x00    0b00000000
D: SPI RX[11]:  0       0x00    0b00000000
D: SPI RX[12]:  0       0x00    0b00000000
D: SPI RX[13]:  0       0x00    0b00000000
D: SPI RX[14]:  0       0x00    0b00000000
D: SPI RX[15]:  0       0x00    0b00000000
D: SPI RX[16]:  0       0x00    0b00000000
D: SPI RX[17]:  0       0x00    0b00000000
D: SPI RX[18]:  0       0x00    0b00000000
D: SPI RX[19]:  0       0x00    0b00000000
D: memc_is66wvs4m8_read: 0
D: Data: 17 0x11 0b00010001
D: Writing 16 bytes to address 0x000400
D: SPI TX[2]:   4       0x04    0b00000100
D: SPI TX[4]:   17      0x11    0b00010001
D: SPI TX[5]:   17      0x11    0b00010001
D: SPI TX[6]:   17      0x11    0b00010001
D: SPI TX[7]:   17      0x11    0b00010001
D: SPI TX[8]:   17      0x11    0b00010001
D: SPI TX[9]:   17      0x11    0b00010001
D: SPI TX[10]:  17      0x11    0b00010001
D: SPI TX[11]:  17      0x11    0b00010001
D: SPI TX[12]:  17      0x11    0b00010001
D: SPI TX[13]:  17      0x11    0b00010001
D: SPI TX[14]:  17      0x11    0b00010001
D: SPI TX[15]:  17      0x11    0b00010001
D: SPI TX[16]:  17      0x11    0b00010001
D: SPI TX[17]:  17      0x11    0b00010001
D: SPI TX[18]:  17      0x11    0b00010001
D: SPI TX[19]:  17      0x11    0b00010001
D: Reading 16 bytes from address 0x00000400
D: SPI RX[16]:  2       0x02    0b00000010
D: SPI RX[17]:  30      0x1e    0b00011110
D: SPI RX[18]:  3       0x03    0b00000011
D: SPI RX[19]:  253     0xfd    0b11111101
D: Data: 34 0x22 0b00100010
D: Writing 16 bytes to address 0x000800
D: SPI TX[2]:   8       0x08    0b00001000
D: SPI TX[4]:   34      0x22    0b00100010
D: SPI TX[5]:   34      0x22    0b00100010
D: SPI TX[6]:   34      0x22    0b00100010
D: SPI TX[7]:   34      0x22    0b00100010
D: SPI TX[8]:   34      0x22    0b00100010
D: SPI TX[9]:   34      0x22    0b00100010
D: SPI TX[10]:  34      0x22    0b00100010
D: SPI TX[11]:  34      0x22    0b00100010
D: SPI TX[12]:  34      0x22    0b00100010
D: SPI TX[13]:  34      0x22    0b00100010
D: SPI TX[14]:  34      0x22    0b00100010
D: SPI TX[15]:  34      0x22    0b00100010
D: SPI TX[16]:  34      0x22    0b00100010
D: SPI TX[17]:  34      0x22    0b00100010
D: SPI TX[18]:  34      0x22    0b00100010
D: SPI TX[19]:  34      0x22    0b00100010
D: Reading 16 bytes from address 0x00000800
D: SPI RX[16]:  4       0x04    0b00000100
D: SPI RX[17]:  104     0x68    0b01101000
D: SPI RX[18]:  15      0x0f    0b00001111
D: SPI RX[19]:  246     0xf6    0b11110110
D: Data: 51 0x33 0b00110011
D: Writing 16 bytes to address 0x000c00
D: SPI TX[2]:   12      0x0c    0b00001100
D: SPI TX[4]:   51      0x33    0b00110011
D: SPI TX[5]:   51      0x33    0b00110011
D: SPI TX[6]:   51      0x33    0b00110011
D: SPI TX[7]:   51      0x33    0b00110011
D: SPI TX[8]:   51      0x33    0b00110011
D: SPI TX[9]:   51      0x33    0b00110011
D: SPI TX[10]:  51      0x33    0b00110011
D: SPI TX[11]:  51      0x33    0b00110011
D: SPI TX[12]:  51      0x33    0b00110011
D: SPI TX[13]:  51      0x33    0b00110011
D: SPI TX[14]:  51      0x33    0b00110011
D: SPI TX[15]:  51      0x33    0b00110011
D: SPI TX[16]:  51      0x33    0b00110011
D: SPI TX[17]:  51      0x33    0b00110011
D: SPI TX[18]:  51      0x33    0b00110011
D: SPI TX[19]:  51      0x33    0b00110011
D: Reading 16 bytes from address 0x00000c00
D: SPI RX[4]:   36      0x24    0b00100100
D: SPI RX[5]:   146     0x92    0b10010010
D: SPI RX[6]:   73      0x49    0b01001001
D: SPI RX[7]:   36      0x24    0b00100100
D: SPI RX[8]:   146     0x92    0b10010010
D: SPI RX[9]:   73      0x49    0b01001001
D: SPI RX[10]:  36      0x24    0b00100100
D: SPI RX[11]:  146     0x92    0b10010010
D: SPI RX[12]:  73      0x49    0b01001001
D: SPI RX[13]:  36      0x24    0b00100100
D: SPI RX[14]:  146     0x92    0b10010010
D: SPI RX[15]:  73      0x49    0b01001001
D: SPI RX[16]:  130     0x82    0b10000010
D: SPI RX[17]:  62      0x3e    0b00111110
D: Data: 68 0x44 0b01000100
D: Writing 16 bytes to address 0x001000
D: SPI TX[2]:   16      0x10    0b00010000
D: SPI TX[4]:   68      0x44    0b01000100
D: SPI TX[5]:   68      0x44    0b01000100
D: SPI TX[6]:   68      0x44    0b01000100
D: SPI TX[7]:   68      0x44    0b01000100
D: SPI TX[8]:   68      0x44    0b01000100
D: SPI TX[9]:   68      0x44    0b01000100
D: SPI TX[10]:  68      0x44    0b01000100
D: SPI TX[11]:  68      0x44    0b01000100
D: SPI TX[12]:  68      0x44    0b01000100
D: SPI TX[13]:  68      0x44    0b01000100
D: SPI TX[14]:  68      0x44    0b01000100
D: SPI TX[15]:  68      0x44    0b01000100
D: SPI TX[16]:  68      0x44    0b01000100
D: SPI TX[17]:  68      0x44    0b01000100
D: SPI TX[18]:  68      0x44    0b01000100
D: SPI TX[19]:  68      0x44    0b01000100
D: Reading 16 bytes from address 0x00001000
D: SPI RX[17]:  40      0x28    0b00101000
D: Data: 85 0x55 0b01010101
D: Writing 16 bytes to address 0x001400
D: SPI TX[2]:   20      0x14    0b00010100
D: SPI TX[4]:   85      0x55    0b01010101
D: SPI TX[5]:   85      0x55    0b01010101
D: SPI TX[6]:   85      0x55    0b01010101
D: SPI TX[7]:   85      0x55    0b01010101
D: SPI TX[8]:   85      0x55    0b01010101
D: SPI TX[9]:   85      0x55    0b01010101
D: SPI TX[10]:  85      0x55    0b01010101
D: SPI TX[11]:  85      0x55    0b01010101
D: SPI TX[12]:  85      0x55    0b01010101
D: SPI TX[13]:  85      0x55    0b01010101
D: SPI TX[14]:  85      0x55    0b01010101
D: SPI TX[15]:  85      0x55    0b01010101
D: SPI TX[16]:  85      0x55    0b01010101
D: SPI TX[17]:  85      0x55    0b01010101
D: SPI TX[18]:  85      0x55    0b01010101
D: SPI TX[19]:  85      0x55    0b01010101
D: Reading 16 bytes from address 0x00001400
D: SPI RX[12]:  2       0x02    0b00000010
D: SPI RX[13]:  30      0x1e    0b00011110
D: SPI RX[14]:  3       0x03    0b00000011
D: SPI RX[15]:  253     0xfd    0b11111101
D: SPI RX[16]:  176     0xb0    0b10110000
D: SPI RX[17]:  47      0x2f    0b00101111
D: SPI RX[18]:  195     0xc3    0b11000011
D: SPI RX[19]:  241     0xf1    0b11110001
D: Data: 102 0x66 0b01100110
D: Writing 16 bytes to address 0x001800
D: SPI TX[2]:   24      0x18    0b00011000
D: SPI TX[4]:   102     0x66    0b01100110
D: SPI TX[5]:   102     0x66    0b01100110
D: SPI TX[6]:   102     0x66    0b01100110
D: SPI TX[7]:   102     0x66    0b01100110
D: SPI TX[8]:   102     0x66    0b01100110
D: SPI TX[9]:   102     0x66    0b01100110
D: SPI TX[10]:  102     0x66    0b01100110
D: SPI TX[11]:  102     0x66    0b01100110
D: SPI TX[12]:  102     0x66    0b01100110
D: SPI TX[13]:  102     0x66    0b01100110
D: SPI TX[14]:  102     0x66    0b01100110
D: SPI TX[15]:  102     0x66    0b01100110
D: SPI TX[16]:  102     0x66    0b01100110
D: SPI TX[17]:  102     0x66    0b01100110
D: SPI TX[18]:  102     0x66    0b01100110
D: SPI TX[19]:  102     0x66    0b01100110
D: Reading 16 bytes from address 0x00001800
D: SPI RX[4]:   73      0x49    0b01001001
D: SPI RX[5]:   36      0x24    0b00100100
D: SPI RX[6]:   146     0x92    0b10010010
D: SPI RX[7]:   73      0x49    0b01001001
D: SPI RX[8]:   36      0x24    0b00100100
D: SPI RX[9]:   146     0x92    0b10010010
D: SPI RX[10]:  73      0x49    0b01001001
D: SPI RX[11]:  36      0x24    0b00100100
D: SPI RX[12]:  146     0x92    0b10010010
D: SPI RX[13]:  73      0x49    0b01001001
D: SPI RX[14]:  36      0x24    0b00100100
D: SPI RX[15]:  146     0x92    0b10010010
D: SPI RX[17]:  60      0x3c    0b00111100
D: SPI RX[18]:  7       0x07    0b00000111
D: SPI RX[19]:  251     0xfb    0b11111011
D: Data: 119 0x77 0b01110111
D: Writing 16 bytes to address 0x001c00
D: SPI TX[2]:   28      0x1c    0b00011100
D: SPI TX[4]:   119     0x77    0b01110111
D: SPI TX[5]:   119     0x77    0b01110111
D: SPI TX[6]:   119     0x77    0b01110111
D: SPI TX[7]:   119     0x77    0b01110111
D: SPI TX[8]:   119     0x77    0b01110111
D: SPI TX[9]:   119     0x77    0b01110111
D: SPI TX[10]:  119     0x77    0b01110111
D: SPI TX[11]:  119     0x77    0b01110111
D: SPI TX[12]:  119     0x77    0b01110111
D: SPI TX[13]:  119     0x77    0b01110111
D: SPI TX[14]:  119     0x77    0b01110111
D: SPI TX[15]:  119     0x77    0b01110111
D: SPI TX[16]:  119     0x77    0b01110111
D: SPI TX[17]:  119     0x77    0b01110111
D: SPI TX[18]:  119     0x77    0b01110111
D: SPI TX[19]:  119     0x77    0b01110111
D: Reading 16 bytes from address 0x00001c00
D: SPI RX[4]:   109     0x6d    0b01101101
D: SPI RX[5]:   182     0xb6    0b10110110
D: SPI RX[6]:   219     0xdb    0b11011011
D: SPI RX[7]:   109     0x6d    0b01101101
D: SPI RX[8]:   182     0xb6    0b10110110
D: SPI RX[9]:   219     0xdb    0b11011011
D: SPI RX[10]:  109     0x6d    0b01101101
D: SPI RX[11]:  182     0xb6    0b10110110
D: SPI RX[12]:  219     0xdb    0b11011011
D: SPI RX[13]:  109     0x6d    0b01101101
D: SPI RX[14]:  182     0xb6    0b10110110
D: SPI RX[15]:  219     0xdb    0b11011011
D: Data: 136 0x88 0b10001000
D: Writing 16 bytes to address 0x002000
D: SPI TX[2]:   32      0x20    0b00100000
D: SPI TX[4]:   136     0x88    0b10001000
D: SPI TX[5]:   136     0x88    0b10001000
D: SPI TX[6]:   136     0x88    0b10001000
D: SPI TX[7]:   136     0x88    0b10001000
D: SPI TX[8]:   136     0x88    0b10001000
D: SPI TX[9]:   136     0x88    0b10001000
D: SPI TX[10]:  136     0x88    0b10001000
D: SPI TX[11]:  136     0x88    0b10001000
D: SPI TX[12]:  136     0x88    0b10001000
D: SPI TX[13]:  136     0x88    0b10001000
D: SPI TX[14]:  136     0x88    0b10001000
D: SPI TX[15]:  136     0x88    0b10001000
D: SPI TX[16]:  136     0x88    0b10001000
D: SPI TX[17]:  136     0x88    0b10001000
D: SPI TX[18]:  136     0x88    0b10001000
D: SPI TX[19]:  136     0x88    0b10001000
D: Reading 16 bytes from address 0x00002000
D: SPI RX[17]:  124     0x7c    0b01111100
D: Data: 153 0x99 0b10011001
D: Writing 16 bytes to address 0x002400
D: SPI TX[2]:   36      0x24    0b00100100
D: SPI TX[4]:   153     0x99    0b10011001
D: SPI TX[5]:   153     0x99    0b10011001
D: SPI TX[6]:   153     0x99    0b10011001
D: SPI TX[7]:   153     0x99    0b10011001
D: SPI TX[8]:   153     0x99    0b10011001
D: SPI TX[9]:   153     0x99    0b10011001
D: SPI TX[10]:  153     0x99    0b10011001
D: SPI TX[11]:  153     0x99    0b10011001
D: SPI TX[12]:  153     0x99    0b10011001
D: SPI TX[13]:  153     0x99    0b10011001
D: SPI TX[14]:  153     0x99    0b10011001
D: SPI TX[15]:  153     0x99    0b10011001
D: SPI TX[16]:  153     0x99    0b10011001
D: SPI TX[17]:  153     0x99    0b10011001
D: SPI TX[18]:  153     0x99    0b10011001
D: SPI TX[19]:  153     0x99    0b10011001
D: Reading 16 bytes from address 0x00002400
D: Data: 170 0xaa 0b10101010
D: Writing 16 bytes to address 0x002800
D: SPI TX[2]:   40      0x28    0b00101000
D: SPI TX[4]:   170     0xaa    0b10101010
D: SPI TX[5]:   170     0xaa    0b10101010
D: SPI TX[6]:   170     0xaa    0b10101010
D: SPI TX[7]:   170     0xaa    0b10101010
D: SPI TX[8]:   170     0xaa    0b10101010
D: SPI TX[9]:   170     0xaa    0b10101010
D: SPI TX[10]:  170     0xaa    0b10101010
D: SPI TX[11]:  170     0xaa    0b10101010
D: SPI TX[12]:  170     0xaa    0b10101010
D: SPI TX[13]:  170     0xaa    0b10101010
D: SPI TX[14]:  170     0xaa    0b10101010
D: SPI TX[15]:  170     0xaa    0b10101010
D: SPI TX[16]:  170     0xaa    0b10101010
D: SPI TX[17]:  170     0xaa    0b10101010
D: SPI TX[18]:  170     0xaa    0b10101010
D: SPI TX[19]:  170     0xaa    0b10101010
D: Reading 16 bytes from address 0x00002800
D: SPI RX[12]:  4       0x04    0b00000100
D: SPI RX[13]:  124     0x7c    0b01111100
D: SPI RX[14]:  7       0x07    0b00000111
D: SPI RX[15]:  251     0xfb    0b11111011
D: SPI RX[16]:  96      0x60    0b01100000
D: SPI RX[17]:  95      0x5f    0b01011111
D: SPI RX[18]:  135     0x87    0b10000111
D: SPI RX[19]:  227     0xe3    0b11100011
D: Data: 187 0xbb 0b10111011
D: Writing 16 bytes to address 0x002c00
D: SPI TX[2]:   44      0x2c    0b00101100
D: SPI TX[4]:   187     0xbb    0b10111011
D: SPI TX[5]:   187     0xbb    0b10111011
D: SPI TX[6]:   187     0xbb    0b10111011
D: SPI TX[7]:   187     0xbb    0b10111011
D: SPI TX[8]:   187     0xbb    0b10111011
D: SPI TX[9]:   187     0xbb    0b10111011
D: SPI TX[10]:  187     0xbb    0b10111011
D: SPI TX[11]:  187     0xbb    0b10111011
D: SPI TX[12]:  187     0xbb    0b10111011
D: SPI TX[13]:  187     0xbb    0b10111011
D: SPI TX[14]:  187     0xbb    0b10111011
D: SPI TX[15]:  187     0xbb    0b10111011
D: SPI TX[16]:  187     0xbb    0b10111011
D: SPI TX[17]:  187     0xbb    0b10111011
D: SPI TX[18]:  187     0xbb    0b10111011
D: SPI TX[19]:  187     0xbb    0b10111011
D: Reading 16 bytes from address 0x00002c00
D: SPI RX[16]:  36      0x24    0b00100100
D: Data: 204 0xcc 0b11001100
D: Writing 16 bytes to address 0x003000
D: SPI TX[2]:   48      0x30    0b00110000
D: SPI TX[4]:   204     0xcc    0b11001100
D: SPI TX[5]:   204     0xcc    0b11001100
D: SPI TX[6]:   204     0xcc    0b11001100
D: SPI TX[7]:   204     0xcc    0b11001100
D: SPI TX[8]:   204     0xcc    0b11001100
D: SPI TX[9]:   204     0xcc    0b11001100
D: SPI TX[10]:  204     0xcc    0b11001100
D: SPI TX[11]:  204     0xcc    0b11001100
D: SPI TX[12]:  204     0xcc    0b11001100
D: SPI TX[13]:  204     0xcc    0b11001100
D: SPI TX[14]:  204     0xcc    0b11001100
D: SPI TX[15]:  204     0xcc    0b11001100
D: SPI TX[16]:  204     0xcc    0b11001100
D: SPI TX[17]:  204     0xcc    0b11001100
D: SPI TX[18]:  204     0xcc    0b11001100
D: SPI TX[19]:  204     0xcc    0b11001100
D: Reading 16 bytes from address 0x00003000
D: SPI RX[4]:   146     0x92    0b10010010
D: SPI RX[5]:   73      0x49    0b01001001
D: SPI RX[6]:   36      0x24    0b00100100
D: SPI RX[7]:   146     0x92    0b10010010
D: SPI RX[8]:   73      0x49    0b01001001
D: SPI RX[9]:   36      0x24    0b00100100
D: SPI RX[10]:  146     0x92    0b10010010
D: SPI RX[11]:  73      0x49    0b01001001
D: SPI RX[12]:  36      0x24    0b00100100
D: SPI RX[13]:  146     0x92    0b10010010
D: SPI RX[14]:  73      0x49    0b01001001
D: SPI RX[15]:  36      0x24    0b00100100
D: Data: 221 0xdd 0b11011101
D: Writing 16 bytes to address 0x003400
D: SPI TX[2]:   52      0x34    0b00110100
D: SPI TX[4]:   221     0xdd    0b11011101
D: SPI TX[5]:   221     0xdd    0b11011101
D: SPI TX[6]:   221     0xdd    0b11011101
D: SPI TX[7]:   221     0xdd    0b11011101
D: SPI TX[8]:   221     0xdd    0b11011101
D: SPI TX[9]:   221     0xdd    0b11011101
D: SPI TX[10]:  221     0xdd    0b11011101
D: SPI TX[11]:  221     0xdd    0b11011101
D: SPI TX[12]:  221     0xdd    0b11011101
D: SPI TX[13]:  221     0xdd    0b11011101
D: SPI TX[14]:  221     0xdd    0b11011101
D: SPI TX[15]:  221     0xdd    0b11011101
D: SPI TX[16]:  221     0xdd    0b11011101
D: SPI TX[17]:  221     0xdd    0b11011101
D: SPI TX[18]:  221     0xdd    0b11011101
D: SPI TX[19]:  221     0xdd    0b11011101
D: Reading 16 bytes from address 0x00003400
D: SPI RX[4]:   182     0xb6    0b10110110
D: SPI RX[5]:   219     0xdb    0b11011011
D: SPI RX[6]:   109     0x6d    0b01101101
D: SPI RX[7]:   182     0xb6    0b10110110
D: SPI RX[8]:   219     0xdb    0b11011011
D: SPI RX[9]:   109     0x6d    0b01101101
D: SPI RX[10]:  182     0xb6    0b10110110
D: SPI RX[11]:  219     0xdb    0b11011011
D: SPI RX[12]:  109     0x6d    0b01101101
D: SPI RX[13]:  182     0xb6    0b10110110
D: SPI RX[14]:  219     0xdb    0b11011011
D: SPI RX[15]:  109     0x6d    0b01101101
D: Data: 238 0xee 0b11101110
D: Writing 16 bytes to address 0x003800
D: SPI TX[2]:   56      0x38    0b00111000
D: SPI TX[4]:   238     0xee    0b11101110
D: SPI TX[5]:   238     0xee    0b11101110
D: SPI TX[6]:   238     0xee    0b11101110
D: SPI TX[7]:   238     0xee    0b11101110
D: SPI TX[8]:   238     0xee    0b11101110
D: SPI TX[9]:   238     0xee    0b11101110
D: SPI TX[10]:  238     0xee    0b11101110
D: SPI TX[11]:  238     0xee    0b11101110
D: SPI TX[12]:  238     0xee    0b11101110
D: SPI TX[13]:  238     0xee    0b11101110
D: SPI TX[14]:  238     0xee    0b11101110
D: SPI TX[15]:  238     0xee    0b11101110
D: SPI TX[16]:  238     0xee    0b11101110
D: SPI TX[17]:  238     0xee    0b11101110
D: SPI TX[18]:  238     0xee    0b11101110
D: SPI TX[19]:  238     0xee    0b11101110
D: Reading 16 bytes from address 0x00003800
D: SPI RX[4]:   219     0xdb    0b11011011
D: SPI RX[5]:   109     0x6d    0b01101101
D: SPI RX[6]:   182     0xb6    0b10110110
D: SPI RX[7]:   219     0xdb    0b11011011
D: SPI RX[8]:   109     0x6d    0b01101101
D: SPI RX[9]:   182     0xb6    0b10110110
D: SPI RX[10]:  219     0xdb    0b11011011
D: SPI RX[11]:  109     0x6d    0b01101101
D: SPI RX[12]:  182     0xb6    0b10110110
D: SPI RX[13]:  219     0xdb    0b11011011
D: SPI RX[14]:  109     0x6d    0b01101101
D: SPI RX[15]:  182     0xb6    0b10110110
D: Data: 255 0xff 0b11111111
D: Writing 16 bytes to address 0x003c00
D: SPI TX[2]:   60      0x3c    0b00111100
D: SPI TX[4]:   255     0xff    0b11111111
D: SPI TX[5]:   255     0xff    0b11111111
D: SPI TX[6]:   255     0xff    0b11111111
D: SPI TX[7]:   255     0xff    0b11111111
D: SPI TX[8]:   255     0xff    0b11111111
D: SPI TX[9]:   255     0xff    0b11111111
D: SPI TX[10]:  255     0xff    0b11111111
D: SPI TX[11]:  255     0xff    0b11111111
D: SPI TX[12]:  255     0xff    0b11111111
D: SPI TX[13]:  255     0xff    0b11111111
D: SPI TX[14]:  255     0xff    0b11111111
D: SPI TX[15]:  255     0xff    0b11111111
D: SPI TX[16]:  255     0xff    0b11111111
D: SPI TX[17]:  255     0xff    0b11111111
D: SPI TX[18]:  255     0xff    0b11111111
D: SPI TX[19]:  255     0xff    0b11111111
D: Reading 16 bytes from address 0x00003c00
D: SPI RX[4]:   255     0xff    0b11111111
D: SPI RX[5]:   255     0xff    0b11111111
D: SPI RX[6]:   255     0xff    0b11111111
D: SPI RX[7]:   255     0xff    0b11111111
D: SPI RX[8]:   255     0xff    0b11111111
D: SPI RX[9]:   255     0xff    0b11111111
D: SPI RX[10]:  255     0xff    0b11111111
D: SPI RX[11]:  255     0xff    0b11111111
D: SPI RX[12]:  255     0xff    0b11111111
D: SPI RX[13]:  255     0xff    0b11111111
D: SPI RX[14]:  255     0xff    0b11111111
D: SPI RX[15]:  255     0xff    0b11111111
D: SPI RX[16]:  255     0xff    0b11111111
D: SPI RX[17]:  255     0xff    0b11111111
D: SPI RX[18]:  255     0xff    0b11111111
D: SPI RX[19]:  255     0xff    0b11111111
psram.zip
    I tried it with a different microcontroller (RP2040) with a 3v3 PSRAM instead of 1.8v, and it works with the same SPI mode and 500KHz. The only difference that I can imagine is related with the clock signal. Here, it stops between each byte, and in the NRF not. What do you think? How can I fix it in the Thingy91?
    That should not have an impact, unless the IC has very unusual timing requirements.
    Could you confirm the pins that you use? Is it P0.10 for CSN?
    If yes, then this is by default connected to the RESET pin of the nRF52 device on thingy91:
    Meaning that SB14 needs to be cut in order to use this as a normal GPIO.
    Håkon
    I think I found the issue.
    If you look at the compiled zephyr.dts file in build/psram/zephyr/zephyr.dts folder, you can see that the spi3 node looks like this:
    			spi3: spi@b000 {
    				#address-cells = < 0x1 >;
    				#size-cells = < 0x0 >;
    				reg = < 0xb000 0x1000 >;
    				interrupts = < 0xb 0x1 >;
    				max-frequency = < 0x7a1200 >;
    				easydma-maxcnt-bits = < 0xd >;
    				status = "okay";
    				cs-gpios = < &gpio0 0xa 0x1 >;
    				pinctrl-0 = < &spi3_default >;
    				pinctrl-1 = < &spi3_sleep >;
    				adxl362: adxl362@0 {
    					compatible = "adi,adxl362";
    					spi-max-frequency = < 0x7a1200 >;
    					reg = < 0x0 >;
    					int1-gpios = < &gpio0 0x9 0x0 >;
    				adxl372: adxl372@1 {
    					compatible = "adi,adxl372";
    					reg = < 0x1 >;
    					int1-gpios = < &gpio0 0x6 0x0 >;
    				reg_my_spi_master: spi-dev-a@0 {
    					reg = < 0x0 >;
    It looks like the adxl and reg_my_spi_master points to index 0 of the "cs-gpios" structure, which will cause some adxl-specific commands to be sent to your PSRAM IC.
    In your overlay, declare the other cs-gpios, to ensure that they are inactive and change the reg to point to '2', as done here:
    &spi3 {
        status = "okay";
        cs-gpios = <&gpio0 8 GPIO_ACTIVE_LOW>, <&gpio0 7 GPIO_ACTIVE_LOW>, <&gpio0 10 GPIO_ACTIVE_LOW>;
        pinctrl-0 = <&spi3_default>;
        pinctrl-1 = <&spi3_sleep>;
        reg_my_spi_master: spi-dev-a@2 {
    		reg = <2>;
    If the other CS pins are floating, the other sensors can start shifting data out on the MISO line, causing corruption/collision on the bus.
    Håkon
    I'm investigating this today and making these changes. However, I actually set since the beginning the ADXL chip selects to 1 during test initialization. With your changes, SPI behavior doesn't change. Could you please review the ZIP file? Maybe I'm missing something.
    2654.psram.zip
