I can't use mcuboot to boot a firmware on my external flash
I am trying to use mcuboot to load a version that is stored in my external flash, and I cannot get it to boot. My project is being built using sysbuild and my target is an nrf9161 with an external flash connected through SPI. Tests have been made where the flash could be read from the main application, so physical connections between the memory and the processor should not be an issue for this problem. The SDK version I am using is still the 2.9.1.
The process I am following is that I am building a version which I code using the VERSION file with a version higher than the program I plan to run on the processor. I generate the zephyr.signed.bin file like that and I write it on the flash.
Then, I build another version with a lower version number coded in the VERSION file, and I flash the merged.hex on the processor.
Each version has a print at the beginning where I check if the version that is running is the flashed one or the one that I wrote on the flash, and all the time I am seeing the one that I actively flash on the processor directly. The external flash does have the version because I could read the flash with my J-Link and I could confirm that the version was stored.
I have used the following configuration out of the devacademy examples.
sysbuild.conf:
# Activate the MCUBOOT bootloader for sysbuild
SB_CONFIG_BOOTLOADER_MCUBOOT=y
# STEP 3.1 - MCUboot should use external flash
SB_CONFIG_PM_EXTERNAL_FLASH_MCUBOOT_SECONDARY=y
# STEP 3.1 - For SPI, we need to set this
SB_CONFIG_PM_OVERRIDE_EXTERNAL_DRIVER_CHECK=y
SB_CONFIG_BOOT_SIGNATURE_TYPE_RSA=y
SB_CONFIG_MCUBOOT_MODE_OVERWRITE_ONLY=y
SB_CONFIG_PARTITION_MANAGER=y
sysbuild/mcuboot/prj.conf:
CONFIG_PM=n
CONFIG_MAIN_STACK_SIZE=10240
CONFIG_MBEDTLS_CFG_FILE="mcuboot-mbedtls-cfg.h"
CONFIG_BOOT_SWAP_SAVE_ENCTLV=n
CONFIG_BOOT_ENCRYPT_IMAGE=n
CONFIG_BOOT_UPGRADE_ONLY=n
CONFIG_BOOT_BOOTSTRAP=n
# Configurations added for mcuboot
CONFIG_MCUBOOT_DOWNGRADE_PREVENTION=n
CONFIG_PM_EXTERNAL_FLASH_BASE=0x0
CONFIG_GPIO=y
CONFIG_FLASH=y
CONFIG_SPI=y
CONFIG_SPI_NOR=y
CONFIG_SPI_NOR_SFDP_DEVICETREE=y
CONFIG_NORDIC_QSPI_NOR=n
# required by SPI driver
CONFIG_MULTITHREADING=y
CONFIG_FPROTECT=y
# This must be increased to accommodate the bigger images.
CONFIG_BOOT_MAX_IMG_SECTORS=256
CONFIG_LOG=y
CONFIG_MCUBOOT_UTIL_LOG_LEVEL_DBG=y
### Decrease footprint by ~4 KB in comparison to CBPRINTF_COMPLETE=y
CONFIG_CBPRINTF_NANO=y
CONFIG_NRF_RTC_TIMER_USER_CHAN_COUNT=0
### Use the minimal C library to reduce flash usage
CONFIG_MINIMAL_LIBC=y
# Increase the monotonic firmware version before building a firmware update
CONFIG_FW_INFO=y
CONFIG_FW_INFO_FIRMWARE_VERSION=1
I also added to the sysbuild/mcuboot/app.overlay the external flash:
// The external flash must be added to the mcuboot overlay
&spi_main {
    ext_flash: w25q16@1 {
        compatible = "jedec,spi-nor";
        status = "okay";
        reg = <1>;
        spi-max-frequency = <800000>;
        size = <16777216>;
        has-dpd;
        t-enter-dpd = <10000>;
        t-exit-dpd = <35000>;
    chosen {
        zephyr,code-partition = &boot_partition;
        nordic,pm-ext-flash = &ext_flash;
I also tried to use it without the &spi_main definition here and just adding the flash to the chosen and the behavior was the same.
When I generate both the merged.hex as the zephyr.signed.bin I also use this config in the main application to sign the firmwares:
CONFIG_MCUBOOT_SIGNATURE_KEY_FILE="bootloader/mcuboot/root-rsa-2048.pem"
I am also trying to make debug prints on the mcuboot files to try to find out if there is any problem while trying to authenticate, but I have not been able to make any newer logging prints on my console.
There is probably something on the overall configuration that I am missing or any step that I unconsciously missed, so any advice can be useful.
Thank you very much,
Daniel
  • I have tried building my version without any pm_static for the board and I got the following result in the partitions.yml file:
    EMPTY_0:
      address: 0x1c000
      end_address: 0x20000
      placement:
        before:
        - s1_pad
      region: flash_primary
    EMPTY_1:
      address: 0x34000
      end_address: 0x38000
      placement:
        before:
        - mcuboot_pad
    EMPTY_2:
      address: 0xfa000
      end_address: 0x100000
      placement:
        after:
        - settings_storage
    app:
      address: 0x40000
      end_address: 0xf8000
    app_image:
      address: 0x38200
      orig_span: &id001
      - tfm
      - app
      span: *id001
    b0:
      address: 0x0
      end_address: 0x8000
      placement:
        after:
        - start
    b0_container:
      address: 0x0
      end_address: 0x8000
      orig_span: &id002
      - b0
      span: *id002
    external_flash:
      address: 0xc0000
      end_address: 0x200000
      region: external_flash
    mcuboot:
      address: 0x8200
      end_address: 0x1c000
      placement:
        align:
          end: 0x1000
        before:
        - mcuboot_primary
      sharers: 0x1
    mcuboot_pad:
      address: 0x38000
      end_address: 0x38200
      placement:
        align:
          start: 0x8000
        before:
        - mcuboot_primary_app
      sharers: 0x2
    mcuboot_primary:
      address: 0x38000
      orig_span: &id003
      - app
      - tfm
      - mcuboot_pad
      span: *id003
    mcuboot_primary_app:
      address: 0x38200
      orig_span: &id004
      - app
      - tfm
      span: *id004
    mcuboot_secondary:
      address: 0x0
      device: DT_CHOSEN(nordic_pm_ext_flash)
      end_address: 0xc0000
      placement:
        align:
          start: 0x4
      share_size:
      - mcuboot_primary
    mcuboot_sram:
      address: 0x20000000
      end_address: 0x20008000
      orig_span: &id005
      - tfm_sram
      region: sram_primary
      span: *id005
    nonsecure_storage:
      address: 0xf8000
      end_address: 0xfa000
      orig_span: &id006
      - settings_storage
      span: *id006
    nrf_modem_lib_ctrl:
      address: 0x20008000
      end_address: 0x200084e8
      inside:
      - sram_nonsecure
      placement:
        after:
        - tfm_sram
        - start
    nrf_modem_lib_rx:
      address: 0x2000a568
      end_address: 0x2000c568
      inside:
      - sram_nonsecure
      placement:
        after:
        - nrf_modem_lib_tx
    nrf_modem_lib_sram:
      address: 0x20008000
      orig_span: &id007
      - nrf_modem_lib_ctrl
      - nrf_modem_lib_tx
      - nrf_modem_lib_rx
      span: *id007
    nrf_modem_lib_tx:
      address: 0x200084e8
      end_address: 0x2000a568
      inside:
      - sram_nonsecure
      placement:
        after:
    otp:
      address: 0xff8388
      end_address: 0xff83fc
      region: otp
    provision:
      address: 0xff8108
      end_address: 0xff8388
      region: otp
    s0:
      address: 0x8000
      orig_span: &id008
      - mcuboot
      - s0_pad
      span: *id008
    s0_image:
      address: 0x8200
      orig_span: &id009
      - mcuboot
      span: *id009
    s0_pad:
      address: 0x8000
      end_address: 0x8200
      placement:
        after:
        - b0_container
        align:
          start: 0x8000
      share_size:
      - mcuboot_pad
    s1:
      address: 0x20000
      end_address: 0x34000
      orig_span: &id010
      - s1_pad
      - s1_image
      span: *id010
    s1_image:
      address: 0x20200
      placement:
        after:
        - s1_pad
        - s0
      share_size:
      - mcuboot
    s1_pad:
      address: 0x20000
      end_address: 0x20200
      placement:
        after:
        - s0
        align:
          start: 0x8000
      share_size:
      - mcuboot_pad
    settings_storage:
      address: 0xf8000
      inside:
      - nonsecure_storage
      placement:
        align:
          start: 0x8000
        before:
        - end
    sram_nonsecure:
      address: 0x20008000
      end_address: 0x20040000
      orig_span: &id011
      - sram_primary
      - nrf_modem_lib_tx
      - nrf_modem_lib_rx
      span: *id011
    sram_primary:
      address: 0x2000c568
    sram_secure:
      address: 0x20000000
      orig_span: &id012
      - tfm_sram
      span: *id012
    tfm:
      address: 0x38200
      end_address: 0x40000
      inside:
      placement:
        before:
        - app
    tfm_nonsecure:
      address: 0x40000
      orig_span: &id013
      - app
      span: *id013
    tfm_secure:
      address: 0x38000
      orig_span: &id014
      - mcuboot_pad
      - tfm
      span: *id014
    tfm_sram:
      address: 0x20000000
      inside:
      - sram_secure
      placement:
        after:
        - start
    But when trying to boot I did not get my mcuboot to boot the secondary.
    I made the logging level higher to include debugging messages and this is what my log starts like:
    *** Booting nRF Connect SDK v2.9.1-60d0d6c8d42d ***
    *** Using Zephyr OS v3.7.99-ca954a6216c9 ***
    Booting from slot 0.
    s0_info is 0x8400
    s1_info is 0x20400
    s0_info version 1
    s1_info version 1
    Attempting to boot slot 0.
    Attempting to boot from address 0x8200.
    I: Trying to get Firmware version
    I: Verifying signature against key 0.
    I: Hash: 0x50...e3
    I: Firmware signature verified.
    Firmware version 1
    I: Setting monotonic counter (version: 1, slot: 0)
    About to boot the bl_boot
    D: stack 0x20005318 for thread 0x20000298: obj_size=2048 buf_start=0x20005318  buf_size 2048 stack_ptr=0x20005b18
    D: stack 0x200051d8 for thread 0x20000218: obj_size=320 buf_start=0x200051d8  buf_size 320 stack_ptr=0x20005318
    D: lfclk: Clock started
    D: tx_bufs 0x20005a18 - rx_bufs 0x20005a20 - 1
    D: current_tx 0x20005a28 (2), current_rx 0x20005a28 (2), tx buf/len 0x20005a10/1, rx buf/len 0x20005a10/1
    D: tx buf/len 0x20005a5f/1
    D: rx buf/len 0x20005a5f/1
    D: tx buf/len (nil)/0
    D: rx buf/len (nil)/0
    D: Transaction finished with status 0
    D: tx_bufs 0x20005a30 - rx_bufs 0x20005a38 - 1
    D: current_tx 0x20005a40 (2), current_rx 0x20005a40 (2), tx buf/len 0x20005a28/1, rx buf/len 0x20005a28/1
    D: tx buf/len 0x20005a88/3
    D: rx buf/len 0x20005a88/3
    D: current_tx 0x20005a40 (2), current_rx 0x20005a40 (2), tx buf/len 0x20005a28/5, rx buf/len 0x20005a28/5
    D: tx buf/len 0x20005a90/24
    D: rx buf/len 0x20005a90/24
    I: w25q16@1: SFDP v 1.6 AP ff with 2 PH
    I: PH0: ff00 rev 1.6: 16 DW @ 80
    D: tx_bufs 0x200059f0 - rx_bufs 0x200059f8 - 1
    D: current_tx 0x20005a00 (2), current_rx 0x20005a00 (2), tx buf/len 0x200059e8/5, rx buf/len 0x200059e8/5
    D: tx buf/len 0x20005a38/64
    D: rx buf/len 0x20005a38/64
    I: w25q16@1: 2 MiBy flash
    D: Erase 4096 with 20
    D: Erase 32768 with 52
    D: Erase 65536 with d8
    D: Page size 256 bytes
    I: PH1: ff84 rev 1.0: 2 DW @ d0
    D: layout 512 x 4096 By pages
    *** Booting My Application v2.1.0-dev-12e5ee106034 ***
    *** Using nRF Connect SDK v2.9.1-60d0d6c8d42d ***
    D: scheduler unlocked (0x20000298:0)
    I: Starting bootloader
    D: Checking for bootable image
    D: thread 0x20000298 for 328 ticks
    D: boot_go() bootutil
    D: tx_bufs 0x200059b8 - rx_bufs 0x200059c0 - 1
    D: current_tx 0x200059c8 (2), current_rx 0x200059c8 (2), tx buf/len 0x200059b0/4, rx buf/len 0x200059b0/4
    D: tx buf/len 0x200027e8/32
    D: rx buf/len 0x200027e8/32
    D: using boot swap type multi
    D: tx_bufs 0x20005970 - rx_bufs 0x20005978 - 1
    D: current_tx 0x20005980 (2), current_rx 0x20005980 (2), tx buf/len 0x20005968/4, rx buf/len 0x20005968/4
    D: tx buf/len 0x200059d0/16
    D: rx buf/len 0x200059d0/16
    D: tx buf/len 0x200059cf/1
    D: rx buf/len 0x200059cf/1
    D: tx_bufs 0x20005960 - rx_bufs 0x20005968 - 1
    D: current_tx 0x20005970 (2), current_rx 0x20005970 (2), tx buf/len 0x20005958/4, rx buf/len 0x20005958/4
    D: tx buf/len 0x20005a1a/1
    D: rx buf/len 0x20005a1a/1
    D: tx buf/len 0x20005a1b/1
    D: rx buf/len 0x20005a1b/1
    D: 0: magic_primary_slot=0x4, magic_secondary_slot=0x1, image_ok_primary_slot=0x4, image_ok_secondary_slot=0x3, copy_done_primary_slot=0x4
    D: 1: magic_primary_slot=0x4, magic_secondary_slot=0x1, image_ok_primary_slot=0x4, image_ok_secondary_slot=0x1, copy_done_primary_slot=0x4
    D: 2: magic_primary_slot=0x1, magic_secondary_slot=0x3, image_ok_primary_slot=0x3, image_ok_secondary_slot=0x4, copy_done_primary_slot=0x1
    I: Image index: 0, Swap type: none
    D: tx buf/len 0x20002840/32
    D: rx buf/len 0x20002840/32
    I: Image index: 1, Swap type: none
    D: boot_go() returned 0
    I: Bootloader chainload address offset: 0x38000
    All pins have been configured as non-secure
    Booting TF-M v2.1.0
    [Sec Thread] Secure image initializing!
    TF-M Float ABI: Hard
    Lazy stacking enabled
    I also added a couple of messages like D: boot_go() returned 0 where I return
    BOOT_LOG_DBG("boot_go() returned %d", rsp.br_flash_dev_id);
    after the command
    FIH_CALL(boot_go, fih_rc, &rsp);
    in the main.c from mcuboot is done.
    There are also a couple of things that I am not very sure about whether I am doing correctly or not.
    I am not calling any function calling for a boot. I am just letting the mcuboot boot the secondary because it has a higher version number than the primary.
    I am reading further about how to use the mcuboot and I am not very sure about whether I have to decide on a swap method and how do I pick them. They are not configs, but documented as defined macros. Does the mcuboot pick them itself because of other selected configs?
    Thank you for your help!
  • We could eventually solve the problem.
    We needed to place the secondary in the external flash using the pm_static.yml and make sure that the size was the same as that of the primary.
    The biggest problem though, was that the .bin file written on the flash was corrupt because of our custom board design. After fixing that and adding the VERSION file and making sure the secondary was on the external flash, the mcuboot could boot the secondary and trasnfer it to the primary correctly
  • I'm glad to hear that it works now, thank you for the update! I was planning to configure a test here to see if I could reproduce the log output you got but I didn't get that far.
