I am working on a project using the nRF52840 SoC with both Zigbee and BLE enabled, along with Mbed TLS and JSON libraries. Due to memory constraints, the firmware binary exceeds the available space allocated for a single image slot in the default dual-slot MCUboot configuration.
To optimize flash usage, I would like to remove the second partition (slot-1
) and use a single-application-slot configuration. However, despite modifying the devicetree and disabling related Kconfig symbols, the second partition still appears in the build or fails with memory overflow errors.
Could you please guide me on the correct and officially supported method to:
Disable or remove the second image partition (
slot-1
Reclaim the memory space for use in the primary application slot (
slot-0
) using either overlay orpm_static.yml
Syam
