Can't detect the custom device after uploading ble_app_beacon example (nRF52810)
I developed a custom board with nRF52810. Here is my schematic:
Layout:
I can succesfully upload the "ble_app_beacon" example in SDK17.1.0 with softdevice112 using Segger Embedded Studio.
I power my device with STLink and use JTAG to program it. I connected the GND of STLink and JTAG to achive this.
I can debug too.
Dont mind the commented lines. I tried to toggle a LED in order to make sure that i can program the device correctly and it worked.
The problem is device is not detectable. I dont think the BLE works properly. Here is my setup. I connected an external 2.4GHz antenna in case my PCB antenna is not good.
I dont know what to do.
Any help would be great.
Mert
  • Hi Håkon,
    For now I only have a xtal with CL of 12pF. I bought a new one and waiting for it to replace.
    I ran the same project with new code included and there was no problem. The beacon still works without getting stuck at while loop.
    But when i observe the crystal with my oscilloscope, i still dont see any clock signal.
    the breakpoint also works.
    I made some research and seems like it is good to have lf crystal to save power.
    Why do you think i dont see any signal on oscilloscope?
    Mert
    If the firmware is not stuck in the loop, and your BT link works, the LFCLK is setup correctly.
    SoftDevice has a dependency on the LFCLK as well as the HFXO, so without those it will not advertise.
    Loading the xtal with a probe will highly likely change the amplitude of the signal, so it will go down to < 100 mVpp.
    Setup a app_timer instance, with a known interval, and toggle a pin in the handler instead. This will give you a indicator of the accuracy of the LFCLK.
    Håkon
  • Hi Håkon
    Thank you for your help. I solved all my problems.
    Mert
