SC field in AuthReq pairing response
Hi, I noticed that I can't bond successfully with my device using iOs 9.1 with Nrf Master control panel iOs app. When I insert the PINCODE, the device immediatly disconnects, and debugging it seems that iOs sends a diconnection command (BLE_GAP_EVT_DISCONNECTED). I read that this problem is due to the fact that iOS 9 is now using the new LE Secure Connections pairing model, and the SC bit is set to 1 in the pairing request. (stackoverflow.com/.../ios-9-1-ble-connects-and-immediately-disconnects)
I checked in the bluetooth core V 4.2 specs that in bonding procedure there is that bitfield in the octect 3 of pairing response called AuthReq, but I couldn't find any way to set it with softdevice 8.0.0.0. I guess the problem could be that one, but I couldn't find a way to test it. So is it possible to change that bit or do you have any information about that problem? I know S110 8.0.0.0 is compliant to V4.1 bluetooth specs, but I have this problem and I don't know how to fix it.
Thank you
  • Yes, I've always checked the error, since that version of iOs I've never had any problem. The connection is not broken from my device, the reason is always remote user.
  • I'd recommend using the device manager module to handle bonding if you're not already. This will handle all the necessary pairing events, which means that you can remove all handling in your application if any.
1 2 3
