Issues migrating from v2.5.0 to v2.9.1
Hey,
I am working with the Matter light bulb sample from the 2.9.1 SDK, which I have modified to support the occupancy cluster. (nRF-52840 and nRF-52840DK)
This worked fine on version 2.5.0, so I tried to follow the migration guides and implement my custom changes to the new SDK.
While the image builds successfully, there is no Bluetooth beacon, serial communication or any functionality at all. The debugger gets stuck in this IRQ-lock function:
FUNC_NORETURN __weak void arch_system_halt(unsigned int reason)
	ARG_UNUSED(reason);
	/* TODO: What's the best way to totally halt the system if SMP
	 * is enabled?
	(void)arch_irq_lock();
	for (;;) {
		/* Spin endlessly */
The only interrupt related change I made is in SensorMeasureHandler() for the occupancy functionality in the apptask.cpp:
 * Copyright (c) 2021 Nordic Semiconductor ASA
#include "app_task.h"
#include <app-common/zap-generated/attributes/Accessors.h>
#include "BGT60.h"
#include "zephyr/drivers/gpio.h"
#ifdef CONFIG_AWS_IOT_INTEGRATION
#include "aws_iot_integration.h"
#include "app/matter_init.h"
#include "app/task_executor.h"
#if defined(CONFIG_PWM)
#include "pwm/pwm_device.h"
#ifdef CONFIG_CHIP_OTA_REQUESTOR
#include "dfu/ota/ota_util.h"
#include <app/DeferredAttributePersistenceProvider.h>
#include <app/clusters/identify-server/identify-server.h>
#include <app/server/OnboardingCodesUtil.h>
#include <app/server/Server.h>
LOG_MODULE_DECLARE(app, CONFIG_CHIP_APP_LOG_LEVEL);
using namespace ::chip;
using namespace ::chip::app;
using namespace ::chip::DeviceLayer;
namespace
constexpr EndpointId kLightEndpointId = 1;
constexpr uint8_t kDefaultMinLevel = 0;
constexpr uint8_t kDefaultMaxLevel = 254;
constexpr uint16_t kTriggerEffectTimeout = 5000;
constexpr uint16_t kTriggerEffectFinishTimeout = 1000;
constexpr uint16_t kOccupancyOccupiedToUnoccupiedTransitionTimeMs = 15 * 1000; // milliseconds
constexpr uint8_t kOccupancyEndpointId = 2;
/* Sensor */
k_timer sTriggerEffectTimer;
k_timer sSensorTimer;
BGT60 bgt60;
const struct device *dev = device_get_binding("GPIO_0");
struct gpio_callback cb_data;
/* End Sensor */
Identify sIdentify = { kLightEndpointId, AppTask::IdentifyStartHandler, AppTask::IdentifyStopHandler,
		       Clusters::Identify::IdentifyTypeEnum::kVisibleIndicator, AppTask::TriggerIdentifyEffectHandler };
bool sIsTriggerEffectActive = false;
const struct pwm_dt_spec sLightPwmDevice = PWM_DT_SPEC_GET(DT_ALIAS(pwm_led1));
// Define a custom attribute persister which makes actual write of the CurrentLevel attribute value
// to the non-volatile storage only when it has remained constant for 5 seconds. This is to reduce
// the flash wearout when the attribute changes frequently as a result of MoveToLevel command.
// DeferredAttribute object describes a deferred attribute, but also holds a buffer with a value to
// be written, so it must live so long as the DeferredAttributePersistenceProvider object.
DeferredAttribute gCurrentLevelPersister(ConcreteAttributePath(kLightEndpointId, Clusters::LevelControl::Id,
							       Clusters::LevelControl::Attributes::CurrentLevel::Id));
DeferredAttributePersistenceProvider gDeferredAttributePersister(Server::GetInstance().GetDefaultAttributePersister(),
								 Span<DeferredAttribute>(&gCurrentLevelPersister, 1),
								 System::Clock::Milliseconds32(5000));
#define APPLICATION_BUTTON_MASK DK_BTN2_MSK
} /* namespace */
/* Start Occupancy specific code */
void SensorTimerHandler(k_timer *timer)
        Nrf::PostTask([] { AppTask::SensorMeasureHandler(); });
void StartSensorTimer(uint32_t aTimeoutMs)
        k_timer_start(&sSensorTimer, K_MSEC(aTimeoutMs), K_MSEC(aTimeoutMs));
void StopSensorTimer()
        k_timer_stop(&sSensorTimer);
void AppTask::SensorActivateHandler()
  StartSensorTimer(500);
void AppTask::SensorDeactivateHandler()
  StopSensorTimer();
void AppTask::SensorMeasureHandler()
  uint64_t now = k_uptime_get();
  uint64_t motion_time = bgt60.GetLastTdTime();
    // Waiting for the hold-up time to expire
	if (now - motion_time < kOccupancyOccupiedToUnoccupiedTransitionTimeMs)
		// Set Occupancy true
		chip::app::Clusters::OccupancySensing::Attributes::Occupancy::Set(kOccupancyEndpointId, chip::app::Clusters::OccupancySensing::OccupancyBitmap::kOccupied);
    // Checking the logic level after hold-up time expires (is it inactive?)
	else if (bgt60.GetTd() == false)
		// Set Occupancy false
		chip::app::Clusters::OccupancySensing::Attributes::Occupancy::Set(kOccupancyEndpointId, 0x00);
		// Reset the hold-up time
		uint32_t pins = BIT(td.pin); // Sensor TD pin number
		::td_activated(dev, &cb_data, pins);
/* end occ */
void AppTask::IdentifyStartHandler(Identify *)
	Nrf::PostTask(
		[] { Nrf::GetBoard().GetLED(Nrf::DeviceLeds::LED2).Blink(Nrf::LedConsts::kIdentifyBlinkRate_ms); });
void AppTask::IdentifyStopHandler(Identify *)
	Nrf::PostTask([] {
		Nrf::GetBoard().GetLED(Nrf::DeviceLeds::LED2).Set(false);
		Instance().mPWMDevice.ApplyLevel();
void AppTask::TriggerEffectTimerTimeoutCallback(k_timer *timer)
	LOG_INF("Identify effect completed");
void AppTask::TriggerIdentifyEffectHandler(Identify *identify)
	switch (identify->mCurrentEffectIdentifier) {
	/* Just handle all effects in the same way. */
	case Clusters::Identify::EffectIdentifierEnum::kBlink:
	case Clusters::Identify::EffectIdentifierEnum::kBreathe:
	case Clusters::Identify::EffectIdentifierEnum::kOkay:
	case Clusters::Identify::EffectIdentifierEnum::kChannelChange:
		LOG_INF("Identify effect identifier changed to %d",
			static_cast<uint8_t>(identify->mCurrentEffectIdentifier));
		k_timer_stop(&sTriggerEffectTimer);
		k_timer_start(&sTriggerEffectTimer, K_MSEC(kTriggerEffectTimeout), K_NO_WAIT);
		Instance().mPWMDevice.SuppressOutput();
	case Clusters::Identify::EffectIdentifierEnum::kFinishEffect:
		LOG_INF("Identify effect finish triggered");
		k_timer_start(&sTriggerEffectTimer, K_MSEC(kTriggerEffectFinishTimeout), K_NO_WAIT);
	case Clusters::Identify::EffectIdentifierEnum::kStopEffect:
		if (sIsTriggerEffectActive) {
		LOG_ERR("Received invalid effect identifier.");
void AppTask::LightingActionEventHandler(const LightingEvent &event)
	Nrf::PWMDevice::Action_t action = Nrf::PWMDevice::INVALID_ACTION;
	int32_t actor = 0;
	if (event.Actor == LightingActor::Button) {
		action = Instance().mPWMDevice.IsTurnedOn() ? Nrf::PWMDevice::OFF_ACTION : Nrf::PWMDevice::ON_ACTION;
		actor = static_cast<int32_t>(event.Actor);
	if (action == Nrf::PWMDevice::INVALID_ACTION || !Instance().mPWMDevice.InitiateAction(action, actor, NULL)) {
		LOG_INF("An action could not be initiated.");
#else
	Nrf::GetBoard().GetLED(Nrf::DeviceLeds::LED2).Set(!Nrf::GetBoard().GetLED(Nrf::DeviceLeds::LED2).GetState());
void AppTask::ButtonEventHandler(Nrf::ButtonState state, Nrf::ButtonMask hasChanged)
	if ((APPLICATION_BUTTON_MASK & hasChanged) & state) {
		Nrf::PostTask([] {
			LightingEvent event;
			event.Actor = LightingActor::Button;
			LightingActionEventHandler(event);
bool AppTask::AWSIntegrationCallback(struct aws_iot_integration_cb_data *data)
	LOG_INF("Attribute change requested from AWS IoT: %d", data->value);
	Protocols::InteractionModel::Status status;
	VerifyOrDie(data->error == 0);
	if (data->attribute_id == ATTRIBUTE_ID_ONOFF) {
		/* write the new on/off value */
		status = Clusters::OnOff::Attributes::OnOff::Set(kLightEndpointId, data->value);
		if (status != Protocols::InteractionModel::Status::Success) {
			LOG_ERR("Updating on/off cluster failed: %x", to_underlying(status));
			return false;
	} else if (data->attribute_id == ATTRIBUTE_ID_LEVEL_CONTROL) {
		/* write the current level */
		status = Clusters::LevelControl::Attributes::CurrentLevel::Set(kLightEndpointId, data->value);
			LOG_ERR("Updating level cluster failed: %x", to_underlying(status));
			return false;
	return true;
#endif /* CONFIG_AWS_IOT_INTEGRATION */
void AppTask::ActionInitiated(Nrf::PWMDevice::Action_t action, int32_t actor)
	if (action == Nrf::PWMDevice::ON_ACTION) {
		LOG_INF("Turn On Action has been initiated");
	} else if (action == Nrf::PWMDevice::OFF_ACTION) {
		LOG_INF("Turn Off Action has been initiated");
	} else if (action == Nrf::PWMDevice::LEVEL_ACTION) {
		LOG_INF("Level Action has been initiated");
void AppTask::ActionCompleted(Nrf::PWMDevice::Action_t action, int32_t actor)
		LOG_INF("Turn On Action has been completed");
		LOG_INF("Turn Off Action has been completed");
		LOG_INF("Level Action has been completed");
	if (actor == static_cast<int32_t>(LightingActor::Button)) {
		Instance().UpdateClusterState();
#endif /* CONFIG_PWM */
void AppTask::UpdateClusterState()
	SystemLayer().ScheduleLambda([this] {
		Protocols::InteractionModel::Status status =
			Clusters::OnOff::Attributes::OnOff::Set(kLightEndpointId, mPWMDevice.IsTurnedOn());
#else
		Protocols::InteractionModel::Status status = Clusters::OnOff::Attributes::OnOff::Set(
			kLightEndpointId, Nrf::GetBoard().GetLED(Nrf::DeviceLeds::LED2).GetState());
		status = Clusters::LevelControl::Attributes::CurrentLevel::Set(kLightEndpointId, mPWMDevice.GetLevel());
#else
		if (Nrf::GetBoard().GetLED(Nrf::DeviceLeds::LED2).GetState()) {
			status = Clusters::LevelControl::Attributes::CurrentLevel::Set(kLightEndpointId, 100);
		} else {
			status = Clusters::LevelControl::Attributes::CurrentLevel::Set(kLightEndpointId, 0);
void AppTask::InitPWMDDevice()
	/* Initialize lighting device (PWM) */
	uint8_t minLightLevel = kDefaultMinLevel;
	Clusters::LevelControl::Attributes::MinLevel::Get(kLightEndpointId, &minLightLevel);
	uint8_t maxLightLevel = kDefaultMaxLevel;
	Clusters::LevelControl::Attributes::MaxLevel::Get(kLightEndpointId, &maxLightLevel);
	Clusters::LevelControl::Attributes::CurrentLevel::TypeInfo::Type currentLevel;
	Clusters::LevelControl::Attributes::CurrentLevel::Get(kLightEndpointId, currentLevel);
	int ret =
		mPWMDevice.Init(&sLightPwmDevice, minLightLevel, maxLightLevel, currentLevel.ValueOr(kDefaultMaxLevel));
	if (ret != 0) {
		LOG_ERR("Failed to initialize PWD device.");
	mPWMDevice.SetCallbacks(ActionInitiated, ActionCompleted);
CHIP_ERROR AppTask::Init()
	/* Initialize Matter stack */
	ReturnErrorOnFailure(Nrf::Matter::PrepareServer(Nrf::Matter::InitData{ .mPostServerInitClbk = [] {
		app::SetAttributePersistenceProvider(&gDeferredAttributePersister);
		return CHIP_NO_ERROR;
	if (!Nrf::GetBoard().Init(ButtonEventHandler)) {
		LOG_ERR("User interface initialization failed.");
		return CHIP_ERROR_INCORRECT_STATE;
	/* Register Matter event handler that controls the connectivity status LED based on the captured Matter network
	 * state. */
	ReturnErrorOnFailure(Nrf::Matter::RegisterEventHandler(Nrf::Board::DefaultMatterEventHandler, 0));
	int retAws = aws_iot_integration_register_callback(AWSIntegrationCallback);
	if (retAws) {
		LOG_ERR("aws_iot_integration_register_callback() failed");
		return chip::System::MapErrorZephyr(retAws);
	/* Initialize trigger effect timer */
	k_timer_init(&sTriggerEffectTimer, &AppTask::TriggerEffectTimerTimeoutCallback, nullptr);
	/* Occupancy specific code */
	k_timer_init(&sSensorTimer, &SensorTimerHandler, nullptr);
    k_timer_user_data_set(&sSensorTimer, this);
	/* Initialize radar sensor */
    bgt60 = BGT60::Instance();
    bgt60.Init();
    if (bgt60.IsReady())
        LOG_INF("BGT60 initialized: ready.");
        LOG_ERR("BGT60 initialization failed.");
        return CHIP_ERROR_INTERNAL;
	return Nrf::Matter::StartServer();
CHIP_ERROR AppTask::StartApp()
	ReturnErrorOnFailure(Init());
	while (true) {
		Nrf::DispatchNextTask();
This is the BGT60.cpp file, covering the functions for the sensor. td_activated() mainly resets the timer:
 * BGT60.cpp
 * Simple 'driver'/access class for the Infineon BGT60LTR11 Radar Shield2Go
 * Copyright (c) 2023 dxcfl
#include "zephyr/kernel.h"
#include "zephyr/device.h"
#include "zephyr/devicetree.h"
#include "BGT60.h"
#define TD_NODE DT_ALIAS(targetd)
#define PD_NODE DT_ALIAS(phased)
const struct gpio_dt_spec td = GPIO_DT_SPEC_GET(TD_NODE, gpios);
const struct gpio_dt_spec pd = GPIO_DT_SPEC_GET(PD_NODE, gpios);
static bool ready = false;
static uint64_t last_td_time = 0;
static bool last_pd = false;
static struct gpio_callback td_cb_data;
void td_activated(const struct device *dev, struct gpio_callback *cb, uint32_t pins)
    bool pd_pin = gpio_pin_get_dt(&pd);
    last_td_time = now;
    last_pd = pd_pin;
void BGT60::Init()
    int ret;
    printk("BGT60: Init ...\n\r");
    if (!device_is_ready(td.port))
        printk("BGT60: Target detection port (TD) not available ...\n\r");
        return;
    if (!device_is_ready(pd.port))
        printk("BGT60: Phase detection port (PD) not available ...\n\r");
        return;
    ret = gpio_pin_configure_dt(&td, GPIO_INPUT);
    if (ret < 0)
        printk("BGT60: Target detection port (TD) not available for input ...\n\r");
        return;
    ret = gpio_pin_configure_dt(&pd, GPIO_INPUT);
    if (ret < 0)
        printk("BGT60: Phase detection port (PD) not available for input ...\n\r");
        return;
    ret = gpio_pin_interrupt_configure_dt(&td, GPIO_INT_EDGE_BOTH);
    if (ret < 0)
        printk("BGT60: Could not configure ISR for TD ...\n\r");
        return;
    gpio_init_callback(&td_cb_data, td_activated, BIT(td.pin));
    gpio_add_callback(td.port, &td_cb_data);
    ready = true;
bool BGT60::IsReady()
    return ready;
uint64_t BGT60::GetLastTdTime()
    return last_td_time;
bool BGT60::GetLastPd()
    return last_pd;
bool BGT60::GetTd() {
    return gpio_pin_get_dt(&td);
bool BGT60::GetPd() {
    return gpio_pin_get_dt(&pd);
BGT60.h:
 * BGT60.h
#pragma once
#include <zephyr/kernel.h>
void td_activated(const struct device *dev, struct gpio_callback *cb, uint32_t pins);
extern const struct gpio_dt_spec td;
class BGT60
public:
    static BGT60 &Instance()
        static BGT60 instance;
        return instance;
    static void Init();
    static bool IsReady();
    static uint64_t GetLastTdTime();
    static bool GetLastPd();
    static bool GetTd();
    static bool GetPd();
    static void Reoccupy();
This worked fine with the old SDK, but I can't see what needs to be changed. I appreciate any help.
  • Hello Maria,
    Thank you for your help. After some testing, I found that SDK v2.5 works fine.
    However, the SDK v2.9.1 version of my firmware (and the unmodified light bulb sample) works well on the devkit but does not boot properly on the PAN1780. The Panasonic module uses the nRF-52840 and the same flash memory as the devkit. Building for the standard board files with some overlay changes has worked until now. The blinky sample does not have this problem.
    Do you have any findings on your end?
    Best regards
    Apologies, I don't have anything yet.
    This finding that the unchanged light bulb sample does not run on the PAN1780 is interesting. Could you do one (or both) of the following?
    • Share your PAN1780 overlay and board specific .conf you use for the unchanged light bulb sample.
    • Build the light bulb sample for both PAN1780 and nRF52840 DK and compare the generated .config files between the two builds.
    I took a quick look at the board files for PAN1780 here, but I did not find any obvious nodes missing.
    Maria
  • I forgot to clarify, I never built for the PAN1780 Evalboard. The base configuration is always nrf52840dk/nrf52840. I just have an overlay file that maps some IO's differently for my custom boards, but this is not in use right now so it can be ignored.
    So if I build the unmodified light bulb sample, these are my observations:
    • In SDK v2.5 I can take the same hex file and flash it to the nRF52840-DK and my PAN1780. Both of them will boot and have a BLE beacon.
    • In SDK v2.9.1 flashing the hex file boots on the nRF52840-DK but does not work on the PAN1780
    I tried using the PAN1780_EVB board files, but I receive this error during the build:
    /home/entwicklung/ncs/v2.9.1/bootloader/mcuboot/boot/zephyr/include/sysflash/pm_sysflash.h: In function '__flash_area_ids_for_slot':
    /home/entwicklung/ncs/v2.9.1/bootloader/mcuboot/boot/zephyr/include/sysflash/pm_sysflash.h:19:60: error: 'PM_MCUBOOT_SECONDARY_ID' undeclared (first use in this function); did you mean 'PM_MCUBOOT_PRIMARY_ID'?
       19 | #define FLASH_AREA_IMAGE_0_SLOTS    PM_MCUBOOT_PRIMARY_ID, PM_MCUBOOT_SECONDARY_ID,
  • Thank you for your patience.
    rwahidi said:
    Still no luck unfortunately, maybe someone can check my custom overlay for compatibility with the hardware model v2?
    I see that in the HWMv2 board files, gpio-reserved-ranges includes <8, 3>, so &gpio0 8 can't be used.
    My apologies for suggesting this. The PAN1780 EVB does not have external flash, so this result is expected when building a Matter application with FOTA functionality.
    I do recommend that you build the application with your board as the target. This way you are sure that the firmware is meant for the board hardware.
    Since you don't build for your board, am I right to assume that you don't have board files for your custom board? These can be created through our nRF Connect for VS Code extension. Since your board is quite similar to the nRF52840 DK, you should be able to use the board files for the DK as a reference when populating the generated board files with relevant configurations.
    Lesson 3 in the nRF Connect SDK Intermediate course also covers adding custom board support.
    Maria
