light switch binding with light bulb questions
        Hello, I can commission bulb and switch pass, then I refer this link(acl and bind) to write ACL and binding both, eventually I can use switch to control bulb!
        But I have some questions and I have not found answer in this link:
        Q1: Can I unbind the bulb and switch that has been bound before?
        Q2: I want to check multi-dev case:
                 e.g., one switch to multi bulbs, above link has mentioned below:
  • If you are using more than one light bulb device, connect all devices to the multicast group by running the following command for each device, including the light switch:
               chip-tool tests TestGroupDemoConfig --nodeId <node_ID>
  • For groupcast binding to bind the light switch with multiple light bulbs:
               chip-tool binding write binding '[{"fabricIndex": 1, "group": 257}]' <light_switch_node_ID> 1
        But how can I test one bulb to multi switches? Besides, does one switch can control different bulb? e.g. press button1 in switch control bulb A, press button2 in the same switch control bulb B
            Thanks for your prompt response!
            May I know this answer?
            Besides, can I use this command to get my purpose?
    Usage:
    ./chip-tool groups command_name [param1 param2 ...]
    | Commands: |
    | * add-group |
    | * add-group-if-identifying |
    | * get-group-membership |
    | * remove-all-groups |
    | * remove-group |
    | * view-group |
    | * discover |
    | * read |
            If yes, is there any introduction about it in nrf web?
    You can use groups to send groupcast commands. For that, you send an AddGroup command to each device you want to add to the group:
    chip-tool groups add-group <group_id> <group_name> <light_bulb_node_id> <endpoint_id>
    After this, commands can be sent using the group ID instead of the individual device's node IDs.
    To send commands to groups using chip-tool, you send the command as usual, replacing the node ID with the group ID and omitting the endpoint ID from the command, for example:
    chip-tool onoff on <group_id>
    The light switch sample is implemented to use the binding table and not groups, so you must change the code if you want it to send commands using groups instead of bindings.
    You can find information about the Groups cluster in the Matter Application Clusters specification, which can be downloaded from CSA's website: https://csa-iot.org/developer-resource/specifications-download-request/.
    Marte
            Thanks, I'll have a try!
            May I know how to do this?(Hope you can give a demo)
            "so you must change the code if you want it to send commands using groups instead of bindings."
             Good news!
             I can use one switch to control two bulbs at the same time successfully by your advise!
             Now I want to continue to next test: 2 switches control one bulb, can you give me the command about writing ACL and binding?
             Looking forward to your response!
    BR
    Chuan
