Issue combining sample that uses CONFIG_NRF_SECURITY and CONFIG_MBEDTLS_BUILTIN
I have two projects, project MQTT, that was built around the Secure MQTT Sensor/Actuator sample and project CRYPTO, that was built around the Crypto AES-CCM sample. I am trying to combine both codebases into a single project. But when I append the prj.conf from project CRYPTO to project MQTT and build, there are build errors. It seems to be related to the fact that the CRYPTO project uses `CONFIG_NRF_SECURITY=y` which selects `DISABLE_MBEDTLS_BUILTIN `, whereas the MQTT sets `CONFIG_MBEDTLS_BUILTIN=y`. My code does not directly call mbedtls functions, but it uses Zephyr's MQTT library with TLS (e.g.: `client->transport.type = MQTT_TRANSPORT_SECURE;`).
Here's the combined proj.conf file:
######## MQTT PROJECT CONFIG ###########
# Enable network stack
CONFIG_NETWORKING=y
# CONFIG_NET_LOG=y
# Enable IPv4
CONFIG_NET_IPV4=y
# Enable IPv6
CONFIG_NET_IPV6=n
# Enable TCP
CONFIG_NET_TCP=y
# Enable DHCP
# CONFIG_NET_DHCPV4=y
# Enable Sockets (used by MQTT lib)
CONFIG_NET_SOCKETS=y
CONFIG_NET_SOCKETS_SOCKOPT_TLS=y
# Enable MQTT
CONFIG_MQTT_LIB=y
CONFIG_MQTT_LIB_TLS=y
# CONFIG_MODEM_A767X_APN="internet.ideasclaro.com.do"
CONFIG_MODEM_A767X_APN="internet"
# CONFIG_MODEM_A767X_APN="internet"
# CONFIG_NET_LOG=y
# CONFIG_NET_L2_PPP_LOG_LEVEL_DBG=y
# see if that fixes the issue with the modem
# CONFIG_NET_L2_PPP_OPTION_SERVE_DNS=n
# CONFIG_NET_L2_PPP_OPTION_SERVE_IP=n
# CONFIG_NET_L2_PPP_OPTION_MRU=n
CONFIG_MODEM_CELLULAR=n
CONFIG_NET_L2_PPP_PAP=n
# Enable Mbed TLS
CONFIG_MBEDTLS=y
CONFIG_MBEDTLS_ENABLE_HEAP=y
CONFIG_MBEDTLS_HEAP_SIZE=60000
CONFIG_MBEDTLS_SSL_MAX_CONTENT_LEN=16384
CONFIG_MBEDTLS_PEM_CERTIFICATE_FORMAT=y
CONFIG_MBEDTLS_SERVER_NAME_INDICATION=y
# Enable JSON
CONFIG_JSON_LIBRARY=y
# Enable net conn manager
CONFIG_NET_CONNECTION_MANAGER=y
# Enable device hostname
CONFIG_NET_HOSTNAME_ENABLE=y
# Enable Posix API functionality
CONFIG_POSIX_API=y
# Enable sensor API
CONFIG_SENSOR=y
# Enable LED API
CONFIG_LED=y
# Custom:
# Insecure MQTT
CONFIG_NET_SAMPLE_MQTT_BROKER_HOSTNAME="sandbox.mymqttserver.io"
# CONFIG_NET_SAMPLE_MQTT_BROKER_PORT="1883"
CONFIG_NET_SAMPLE_MQTT_BROKER_PORT="8883"
# Enable MQTT with TLS
# Disable MQTT with TLS
# CONFIG_MQTT_LIB_TLS=n
# MQTT Authentication
CONFIG_REVVIT_MQTT_USER_NAME="myuser"
CONFIG_REVVIT_MQTT_PASSWORD="mypass"
CONFIG_NET_SAMPLE_MQTT_PUB_TOPIC="zephyr/cellular/data"
CONFIG_NET_SAMPLE_MQTT_SUB_TOPIC_CMD="zephyr/cellular/command"
CONFIG_NET_SAMPLE_MQTT_PUBLISH_INTERVAL=10
CONFIG_LOG=y
CONFIG_MODEM_LOG_LEVEL_DBG=y
CONFIG_MODEM_MODULES_LOG_LEVEL_DBG=y
CONFIG_MODEM_CMUX_LOG_LEVEL_DBG=y
CONFIG_MODEM_CMUX_WORK_BUFFER_SIZE=1500
# Increase buffers
CONFIG_MAIN_STACK_SIZE=4096
CONFIG_SYSTEM_WORKQUEUE_STACK_SIZE=4096
CONFIG_NET_TX_STACK_SIZE=4096
CONFIG_NET_RX_STACK_SIZE=4096
CONFIG_LOG_BUFFER_SIZE=4096
CONFIG_NET_MGMT_EVENT_STACK_SIZE=4096
# Increase Rx net buffers
CONFIG_NET_BUF_RX_COUNT=100
# necessary to print floating numbers
CONFIG_NEWLIB_LIBC=y
# Enable shell
CONFIG_SHELL=y
CONFIG_SHELL_WILDCARD=n
CONFIG_MODEM_AT_SHELL=y
######## CRYPTO PROJECT CONFIG ###########
# Using hardware crypto accelerator
CONFIG_PSA_CRYPTO_DRIVER_OBERON=n
CONFIG_PSA_CRYPTO_DRIVER_CC3XX=y
# Mbedtls configuration
CONFIG_MBEDTLS_HEAP_SIZE=8192
# Enable logging system to USB
CONFIG_LOG=y
# <BLE>
CONFIG_BT=y
CONFIG_BT_PERIPHERAL=y
CONFIG_BT_DEVICE_NAME="bale module"
# Allow multiple devices to connect at once
CONFIG_BT_MAX_CONN=6
CONFIG_BT_BUF_ACL_RX_COUNT=7
# we need min. 65 (ECDH_PUBLIC_KEY_SIZE) + 3 (ATT HEADER) = 68 bytes
# to be able to write to the pubkey characteristic
CONFIG_BT_L2CAP_TX_MTU=247
CONFIG_BT_BUF_ACL_TX_SIZE=251
CONFIG_BT_BUF_ACL_RX_SIZE=251
# CONFIG_BT_LOG_LEVEL_DBG=y
# Enable Security Management Protocol
# CONFIG_BT_GATT_DYNAMIC_DB=y
# </BLE>
# Needed for LEDs
CONFIG_DK_LIBRARY=y
CONFIG_BT_HCI_ERR_TO_STR=y
# <CRYPTO>
# Enable nordic security backend and PSA APIs
CONFIG_MBEDTLS_PSA_CRYPTO_C=y
CONFIG_PSA_WANT_ALG_ECDH=y
CONFIG_PSA_WANT_KEY_TYPE_ECC_KEY_PAIR_GENERATE=y
CONFIG_PSA_WANT_KEY_TYPE_ECC_KEY_PAIR_IMPORT=y
CONFIG_PSA_WANT_KEY_TYPE_ECC_KEY_PAIR_EXPORT=y
CONFIG_PSA_WANT_ECC_SECP_R1_256=y
# For key generation
CONFIG_PSA_WANT_GENERATE_RANDOM=y
# For AES-CCM
CONFIG_PSA_WANT_KEY_TYPE_AES=y
CONFIG_PSA_WANT_ALG_CCM=y
CONFIG_SYS_CLOCK_TICKS_PER_SEC=1000
# CONFIG_MBEDTLS_HEAP_SIZE=16384
CONFIG_MAIN_STACK_SIZE=8192
# CONFIG_MAIN_STACK_SIZE=4096
CONFIG_HEAP_MEM_POOL_SIZE=8192
CONFIG_BT_HCI_TX_STACK_SIZE=4096
CONFIG_BT_RX_STACK_SIZE=4096
# </CRYPTO>
Build error:
 *  Executing task: nRF Connect: Build [pristine]: myproj-firmware/build
Building myproj-firmware
west build --build-dir /Users/redacted/code/redacted/myproj/myproj-firmware/build /Users/redacted/code/redacted/myproj/myproj-firmware --pristine --board nrf52840dk/nrf52840 --sysbuild -- -DNCS_TOOLCHAIN_VERSION=NONE -DBOARD_ROOT=/Users/redacted/code/nordic/myboards;/Users/redacted/code/redacted/myproj/myproj-firmware
Loading Zephyr module(s) (Zephyr base): sysbuild_default
-- Found Python3: /opt/nordic/ncs/toolchains/b8efef2ad5/opt/[email protected]/bin/python3.12 (found suitable version "3.12.4", minimum required is "3.8") found components: Interpreter
-- Cache files will be written to: /Users/redacted/Library/Caches/zephyr
-- Board: nrf52840dk, qualifiers: nrf52840
Parsing /opt/nordic/ncs/v2.9.1/zephyr/share/sysbuild/Kconfig
Loaded configuration '/Users/redacted/code/redacted/myproj/myproj-firmware/build/_sysbuild/empty.conf'
Merged configuration '/Users/redacted/code/redacted/myproj/myproj-firmware/build/_sysbuild/empty.conf'
Configuration saved to '/Users/redacted/code/redacted/myproj/myproj-firmware/build/zephyr/.config'
Kconfig header saved to '/Users/redacted/code/redacted/myproj/myproj-firmware/build/_sysbuild/autoconf.h'
   * Running CMake for myproj-firmware *
-- Application: /Users/redacted/code/redacted/myproj/myproj-firmware
-- CMake version: 3.21.0
-- Found Python3: /opt/nordic/ncs/toolchains/b8efef2ad5/bin/python (found suitable version "3.12.4", minimum required is "3.8") found components: Interpreter
-- Zephyr version: 3.7.99 (/opt/nordic/ncs/v2.9.1/zephyr)
-- Found host-tools: zephyr 0.17.0 (/opt/nordic/ncs/toolchains/b8efef2ad5/opt/zephyr-sdk)
-- Found toolchain: zephyr 0.17.0 (/opt/nordic/ncs/toolchains/b8efef2ad5/opt/zephyr-sdk)
-- Found Dtc: /opt/nordic/ncs/toolchains/b8efef2ad5/bin/dtc (found suitable version "1.6.1", minimum required is "1.4.6")
-- Found BOARD.dts: /opt/nordic/ncs/v2.9.1/zephyr/boards/nordic/nrf52840dk/nrf52840dk_nrf52840.dts
-- Found devicetree overlay: /Users/redacted/code/redacted/myproj/myproj-firmware/boards/nrf52840dk_nrf52840.overlay
-- Generated zephyr.dts: /Users/redacted/code/redacted/myproj/myproj-firmware/build/myproj-firmware/zephyr/zephyr.dts
-- Generated devicetree_generated.h: /Users/redacted/code/redacted/myproj/myproj-firmware/build/myproj-firmware/zephyr/include/generated/zephyr/devicetree_generated.h
-- Including generated dts.cmake file: /Users/redacted/code/redacted/myproj/myproj-firmware/build/myproj-firmware/zephyr/dts.cmake
warning: BT_HCI_TX_STACK_SIZE (defined at
/opt/nordic/ncs/v2.9.1/nrf/subsys/bluetooth/controller/Kconfig:80, subsys/bluetooth/host/Kconfig:43,
subsys/bluetooth/host/Kconfig:43) was assigned the value '4096' but got the value '1536'. See
http://docs.zephyrproject.org/latest/kconfig.html#CONFIG_BT_HCI_TX_STACK_SIZE and/or look up
BT_HCI_TX_STACK_SIZE in the menuconfig/guiconfig interface. The Application Development Primer,
Setting Configuration Values, and Kconfig - Tips and Best Practices sections of the manual might be
helpful too.
warning: MBEDTLS_PEM_CERTIFICATE_FORMAT (defined at modules/mbedtls/Kconfig.tls-generic:405,
modules/mbedtls/Kconfig.tls-generic:405) was assigned the value 'y' but got the value 'n'. Check
these unsatisfied dependencies: ((MBEDTLS_BUILTIN && MBEDTLS_CFG_FILE = "config-tls-generic.h" &&
MBEDTLS) || (MBEDTLS_BUILTIN && MBEDTLS_CFG_FILE = "config-tls-generic.h" && MBEDTLS && 0)) (=n).
See http://docs.zephyrproject.org/latest/kconfig.html#CONFIG_MBEDTLS_PEM_CERTIFICATE_FORMAT and/or
look up MBEDTLS_PEM_CERTIFICATE_FORMAT in the menuconfig/guiconfig interface. The Application
Development Primer, Setting Configuration Values, and Kconfig - Tips and Best Practices sections of
the manual might be helpful too.
warning: MBEDTLS_SERVER_NAME_INDICATION (defined at modules/mbedtls/Kconfig.tls-generic:464,
modules/mbedtls/Kconfig.tls-generic:464) was assigned the value 'y' but got the value 'n'. Check
See http://docs.zephyrproject.org/latest/kconfig.html#CONFIG_MBEDTLS_SERVER_NAME_INDICATION and/or
look up MBEDTLS_SERVER_NAME_INDICATION in the menuconfig/guiconfig interface. The Application
warning: MBEDTLS_SSL_MAX_CONTENT_LEN (defined at modules/mbedtls/Kconfig:72,
modules/hostap/Kconfig:310, modules/hostap/Kconfig:310, modules/hostap/Kconfig:310,
modules/mbedtls/Kconfig:72) was assigned the value '16384' but got the value ''. Check these
unsatisfied dependencies: ((MBEDTLS_BUILTIN && MBEDTLS) || (WIFI_NM_WPA_SUPPLICANT_CRYPTO_ENTERPRISE
&& WIFI_NM_WPA_SUPPLICANT) || (WIFI_NM_WPA_SUPPLICANT_CRYPTO_ENTERPRISE && WIFI_NM_WPA_SUPPLICANT)
|| (WIFI_NM_WPA_SUPPLICANT_CRYPTO_ENTERPRISE && WIFI_NM_WPA_SUPPLICANT && 0) || (MBEDTLS_BUILTIN &&
MBEDTLS && 0)) (=n). See
http://docs.zephyrproject.org/latest/kconfig.html#CONFIG_MBEDTLS_SSL_MAX_CONTENT_LEN and/or look up
MBEDTLS_SSL_MAX_CONTENT_LEN in the menuconfig/guiconfig interface. The Application Development
Primer, Setting Configuration Values, and Kconfig - Tips and Best Practices sections of the manual
warning: The choice symbol MBEDTLS_BUILTIN (defined at modules/mbedtls/Kconfig:29,
modules/mbedtls/Kconfig:29) was selected (set =y), but MBEDTLS_LIBRARY_NRF_SECURITY (defined at
/opt/nordic/ncs/v2.9.1/nrf/subsys/nrf_security/Kconfig:249) ended up as the choice selection. See
http://docs.zephyrproject.org/latest/kconfig.html#CONFIG_MBEDTLS_BUILTIN and/or look up
MBEDTLS_BUILTIN in the menuconfig/guiconfig interface. The Application Development Primer, Setting
Configuration Values, and Kconfig - Tips and Best Practices sections of the manual might be helpful
too.
warning: Experimental symbol POSIX_ASYNCHRONOUS_IO is enabled.
warning: Experimental symbol POSIX_DEVICE_IO is enabled.
warning: Experimental symbol POSIX_FD_MGMT is enabled.
warning: Experimental symbol POSIX_MULTI_PROCESS is enabled.
warning: Experimental symbol POSIX_REALTIME_SIGNALS is enabled.
warning: Experimental symbol POSIX_SIGNALS is enabled.
warning: Experimental symbol BT_HCI_ERR_TO_STR is enabled.
warning: Experimental symbol MODEM_MODULES is enabled.
warning: Experimental symbol NET_SOCKETS_SERVICE is enabled.
warning: Experimental symbol NET_CONNECTION_MANAGER is enabled.
Parsing /Users/redacted/code/redacted/myproj/myproj-firmware/Kconfig
Loaded configuration '/opt/nordic/ncs/v2.9.1/zephyr/boards/nordic/nrf52840dk/nrf52840dk_nrf52840_defconfig'
Merged configuration '/Users/redacted/code/redacted/myproj/myproj-firmware/prj.conf'
Merged configuration '/Users/redacted/code/redacted/myproj/myproj-firmware/boards/nrf52840dk_nrf52840.conf'
Merged configuration '/Users/redacted/code/redacted/myproj/myproj-firmware/build/myproj-firmware/zephyr/.config.sysbuild'
Configuration saved to '/Users/redacted/code/redacted/myproj/myproj-firmware/build/myproj-firmware/zephyr/.config'
Kconfig header saved to '/Users/redacted/code/redacted/myproj/myproj-firmware/build/myproj-firmware/zephyr/include/generated/zephyr/autoconf.h'
-- Found GnuLd: /opt/nordic/ncs/toolchains/b8efef2ad5/opt/zephyr-sdk/arm-zephyr-eabi/arm-zephyr-eabi/bin/ld.bfd (found version "2.38")
-- Found assembler: /opt/nordic/ncs/toolchains/b8efef2ad5/opt/zephyr-sdk/arm-zephyr-eabi/bin/arm-zephyr-eabi-gcc
=========== Generating psa_crypto_config ===============
Backup: CONFIG_MBEDTLS_PSA_CRYPTO_SPM: False
Backup: CONFIG_MBEDTLS_PSA_CRYPTO_C: True
Backup: CONFIG_MBEDTLS_PSA_CRYPTO_KEY_ID_ENCODES_OWNER: False
Backup: CONFIG_MBEDTLS_PLATFORM_SETUP_TEARDOWN_ALT: True
Backup: CONFIG_MBEDTLS_THREADING: False
Backup: CONFIG_MBEDTLS_THREADING_ALT: True
=========== Checkpoint: backup ===============
Restore: CONFIG_MBEDTLS_PSA_CRYPTO_SPM: False
Restore: CONFIG_MBEDTLS_PSA_CRYPTO_C: True
Restore: CONFIG_MBEDTLS_PSA_CRYPTO_KEY_ID_ENCODES_OWNER: False
Restore: CONFIG_MBEDTLS_PLATFORM_SETUP_TEARDOWN_ALT: True
Restore: CONFIG_MBEDTLS_THREADING: False
Restore: CONFIG_MBEDTLS_THREADING_ALT: True
=========== End psa_crypto_config ===============
=========== Generating psa_crypto_library_config ===============
Backup: CONFIG_MBEDTLS_USE_PSA_CRYPTO: True
Backup: CONFIG_MBEDTLS_PLATFORM_PRINTF_ALT: False
Restore: CONFIG_MBEDTLS_USE_PSA_CRYPTO: True
Restore: CONFIG_MBEDTLS_PLATFORM_PRINTF_ALT: False
=========== End psa_crypto_library_config ===============
-- Setting build type to 'MinSizeRel' as none was specified.
-- Using ccache: /opt/nordic/ncs/toolchains/b8efef2ad5/bin/ccache
-- Configuring done
-- Generating done
-- Build files have been written to: /Users/redacted/code/redacted/myproj/myproj-firmware/build/myproj-firmware
-- Configuring done
-- Generating done
[1/396] Preparing syscall dependency handling
[6/396] Generating include/generated/zephyr/version.h
-- Zephyr version: 3.7.99 (/opt/nordic/ncs/v2.9.1/zephyr), build: v3.7.99-ncs2-1-1-gdd31bcfcb2d2
[247/396] Building C object zephyr/subsys/net/CMakeFiles/subsys__net.dir/lib/sockets/sockets_tls.c.obj
/opt/nordic/ncs/v2.9.1/zephyr/subsys/net/lib/sockets/sockets_tls.c: In function 'tls_session_store':
/opt/nordic/ncs/v2.9.1/zephyr/subsys/net/lib/sockets/sockets_tls.c:680:15: warning: implicit declaration of function 'mbedtls_ssl_get_session'; did you mean 'mbedtls_ssl_get_version'? [-Wimplicit-function-declaration]
  680 |         ret = mbedtls_ssl_get_session(&context->ssl, &session);
/opt/nordic/ncs/v2.9.1/zephyr/subsys/net/lib/sockets/sockets_tls.c: In function 'tls_session_restore':
/opt/nordic/ncs/v2.9.1/zephyr/subsys/net/lib/sockets/sockets_tls.c:716:15: warning: implicit declaration of function 'mbedtls_ssl_set_session'; did you mean 'mbedtls_ssl_get_version'? [-Wimplicit-function-declaration]
  716 |         ret = mbedtls_ssl_set_session(&context->ssl, &session);
[391/396] Linking C executable zephyr/zephyr_pre0.elf
FAILED: zephyr/zephyr_pre0.elf zephyr/zephyr_pre0.map /Users/redacted/code/redacted/myproj/myproj-firmware/build/myproj-firmware/zephyr/zephyr_pre0.map
: && ccache /opt/nordic/ncs/toolchains/b8efef2ad5/opt/zephyr-sdk/arm-zephyr-eabi/bin/arm-zephyr-eabi-gcc -Os -DNDEBUG -gdwarf-4 -gdwarf-4 zephyr/CMakeFiles/zephyr_pre0.dir/misc/empty_file.c.obj -o zephyr/zephyr_pre0.elf  zephyr/CMakeFiles/offsets.dir/./arch/arm/core/offsets/offsets.c.obj  -T  zephyr/linker_zephyr_pre0.cmd  -Wl,-Map=/Users/redacted/code/redacted/myproj/myproj-firmware/build/myproj-firmware/zephyr/zephyr_pre0.map  -Wl,--whole-archive  app/libapp.a  zephyr/libzephyr.a  zephyr/arch/common/libarch__common.a  zephyr/arch/arch/arm/core/libarch__arm__core.a  zephyr/arch/arch/arm/core/cortex_m/libarch__arm__core__cortex_m.a  zephyr/arch/arch/arm/core/mpu/libarch__arm__core__mpu.a  zephyr/lib/libc/newlib/liblib__libc__newlib.a  zephyr/lib/libc/common/liblib__libc__common.a  zephyr/lib/posix/options/liblib__posix__options.a  zephyr/lib/net_buf/liblib__net_buf.a  zephyr/lib/os/zvfs/liblib__os__zvfs.a  zephyr/soc/soc/nrf52840/libsoc__nordic.a  zephyr/subsys/fs/libsubsys__fs.a  zephyr/subsys/random/libsubsys__random.a  zephyr/subsys/bluetooth/common/libsubsys__bluetooth__common.a  zephyr/subsys/bluetooth/host/libsubsys__bluetooth__host.a  zephyr/subsys/modem/libsubsys__modem.a  zephyr/subsys/modem/backends/libsubsys__modem__backends.a  zephyr/subsys/net/libsubsys__net.a  zephyr/subsys/net/l2/ppp/libsubsys__net__l2__ppp.a  zephyr/subsys/net/ip/libsubsys__net__ip.a  zephyr/subsys/net/lib/mqtt/libsubsys__net__lib__mqtt.a  zephyr/subsys/net/lib/dns/libsubsys__net__lib__dns.a  zephyr/subsys/net/conn_mgr/libsubsys__net__conn_mgr.a  zephyr/drivers/clock_control/libdrivers__clock_control.a  zephyr/drivers/console/libdrivers__console.a  zephyr/drivers/entropy/libdrivers__entropy.a  zephyr/drivers/gpio/libdrivers__gpio.a  zephyr/drivers/led/libdrivers__led.a  zephyr/drivers/modem/libdrivers__modem.a  zephyr/drivers/pinctrl/libdrivers__pinctrl.a  zephyr/drivers/serial/libdrivers__serial.a  zephyr/drivers/timer/libdrivers__timer.a  modules/nrf/lib/dk_buttons_and_leds/lib..__nrf__lib__dk_buttons_and_leds.a  modules/nrf/lib/multithreading_lock/lib..__nrf__lib__multithreading_lock.a  modules/nrf/subsys/bluetooth/controller/lib..__nrf__subsys__bluetooth__controller.a  modules/nrf/subsys/nrf_security/src/zephyr/libmbedtls_zephyr.a  modules/nrf/subsys/mpsl/init/lib..__nrf__subsys__mpsl__init.a  modules/nrf/subsys/mpsl/fem/lib..__nrf__subsys__mpsl__fem.a  modules/nrf/drivers/hw_cc3xx/lib..__nrf__drivers__hw_cc3xx.a  modules/nrf/drivers/mpsl/clock_control/lib..__nrf__drivers__mpsl__clock_control.a  modules/nrf/drivers/mpsl/temp_nrf5/lib..__nrf__drivers__mpsl__temp_nrf5.a  modules/hal_nordic/nrfx/libmodules__hal_nordic__nrfx.a  modules/segger/libmodules__segger.a  -Wl,--no-whole-archive  zephyr/kernel/libkernel.a  -L/Users/redacted/code/redacted/myproj/myproj-firmware/build/myproj-firmware/zephyr  zephyr/arch/common/libisr_tables.a  /opt/nordic/ncs/v2.9.1/nrfxlib/crypto/nrf_oberon/lib/cortex-m4/soft-float/liboberon_3.0.15.a  -mcpu=cortex-m4  -mthumb  -mabi=aapcs  -mfp16-format=ieee  -fuse-ld=bfd  -Wl,--gc-sections  -Wl,--build-id=none  -Wl,--sort-common=descending  -Wl,--sort-section=alignment  -Wl,-u,_OffsetAbsSyms  -Wl,-u,_ConfigAbsSyms  -nostdlib  -static  -Wl,-X  -Wl,-N  -Wl,--orphan-handling=warn  -Wl,-no-pie  -L"/opt/nordic/ncs/toolchains/b8efef2ad5/opt/zephyr-sdk/arm-zephyr-eabi/arm-zephyr-eabi"/lib/thumb/v7e-m/nofp  -u_printf_float  -specs=nano.specs  modules/nrf/subsys/nrf_security/src/libmbedcrypto.a  modules/nrf/subsys/nrf_security/src/core/nrf_oberon/liboberon_psa_core.a  /opt/nordic/ncs/v2.9.1/nrfxlib/crypto/nrf_cc310_mbedcrypto/lib/cortex-m4/soft-float/no-interrupts/libnrf_cc310_psa_crypto_0.9.19.a  /opt/nordic/ncs/v2.9.1/nrfxlib/crypto/nrf_cc310_mbedcrypto/lib/cortex-m4/soft-float/no-interrupts/libnrf_cc310_legacy_crypto_0.9.19.a  /opt/nordic/ncs/v2.9.1/nrfxlib/crypto/nrf_cc310_mbedcrypto/lib/cortex-m4/soft-float/no-interrupts/libnrf_cc310_core_0.9.19.a  /opt/nordic/ncs/v2.9.1/nrfxlib/crypto/nrf_cc310_platform/lib/cortex-m4/soft-float/no-interrupts/libnrf_cc310_platform_0.9.19.a  modules/nrf/subsys/nrf_security/src/libmbedcrypto_base.a  -lc  modules/nrf/subsys/nrf_security/src/libnrf_security_utils.a  zephyr/kernel/libkernel.a  -lc  /opt/nordic/ncs/v2.9.1/nrfxlib/softdevice_controller/lib/nrf52/soft-float/libsoftdevice_controller_peripheral.a  /opt/nordic/ncs/v2.9.1/nrfxlib/mpsl/fem/common/lib/nrf52/soft-float/libmpsl_fem_common.a  /opt/nordic/ncs/v2.9.1/nrfxlib/mpsl/fem/nrf21540_gpio/lib/nrf52/soft-float/libmpsl_fem_nrf21540_gpio.a  /opt/nordic/ncs/v2.9.1/nrfxlib/mpsl/fem/nrf21540_gpio_spi/lib/nrf52/soft-float/libmpsl_fem_nrf21540_gpio_spi.a  /opt/nordic/ncs/v2.9.1/nrfxlib/mpsl/fem/nrf2220/lib/nrf52/soft-float/libmpsl_fem_nrf2220.a  /opt/nordic/ncs/v2.9.1/nrfxlib/mpsl/fem/nrf2240/lib/nrf52/soft-float/libmpsl_fem_nrf2240.a  /opt/nordic/ncs/v2.9.1/nrfxlib/mpsl/fem/nrf22xx/lib/nrf52/soft-float/libmpsl_fem_nrf22xx.a  /opt/nordic/ncs/v2.9.1/nrfxlib/mpsl/fem/simple_gpio/lib/nrf52/soft-float/libmpsl_fem_simple_gpio.a  /opt/nordic/ncs/v2.9.1/nrfxlib/mpsl/lib/nrf52/soft-float/libmpsl.a -L"/opt/nordic/ncs/toolchains/b8efef2ad5/opt/zephyr-sdk/arm-zephyr-eabi/bin/../lib/gcc/arm-zephyr-eabi/12.2.0/thumb/v7e-m/nofp" -lm -lc -lgcc -lc && cd /Users/redacted/code/redacted/myproj/myproj-firmware/build/myproj-firmware/zephyr && /opt/nordic/ncs/toolchains/b8efef2ad5/Cellar/cmake/3.21.0/bin/cmake -E true
/opt/nordic/ncs/toolchains/b8efef2ad5/opt/zephyr-sdk/arm-zephyr-eabi/bin/../lib/gcc/arm-zephyr-eabi/12.2.0/../../../../arm-zephyr-eabi/bin/ld.bfd: zephyr/subsys/net/libsubsys__net.a(sockets_tls.c.obj): in function `tls_release':
/opt/nordic/ncs/v2.9.1/zephyr/subsys/net/lib/sockets/sockets_tls.c:537: undefined reference to `mbedtls_ssl_config_free'
/opt/nordic/ncs/toolchains/b8efef2ad5/opt/zephyr-sdk/arm-zephyr-eabi/bin/../lib/gcc/arm-zephyr-eabi/12.2.0/../../../../arm-zephyr-eabi/bin/ld.bfd: /opt/nordic/ncs/v2.9.1/zephyr/subsys/net/lib/sockets/sockets_tls.c:538: undefined reference to `mbedtls_ssl_free'
/opt/nordic/ncs/toolchains/b8efef2ad5/opt/zephyr-sdk/arm-zephyr-eabi/bin/../lib/gcc/arm-zephyr-eabi/12.2.0/../../../../arm-zephyr-eabi/bin/ld.bfd: zephyr/subsys/net/libsubsys__net.a(sockets_tls.c.obj): in function `tls_mbedtls_reset':
/opt/nordic/ncs/v2.9.1/zephyr/subsys/net/lib/sockets/sockets_tls.c:1166: undefined reference to `mbedtls_ssl_session_reset'
/opt/nordic/ncs/toolchains/b8efef2ad5/opt/zephyr-sdk/arm-zephyr-eabi/bin/../lib/gcc/arm-zephyr-eabi/12.2.0/../../../../arm-zephyr-eabi/bin/ld.bfd: zephyr/subsys/net/libsubsys__net.a(sockets_tls.c.obj): in function `ztls_poll_update_pollin':
/opt/nordic/ncs/v2.9.1/zephyr/subsys/net/lib/sockets/sockets_tls.c:3141: undefined reference to `mbedtls_ssl_get_bytes_avail'
/opt/nordic/ncs/toolchains/b8efef2ad5/opt/zephyr-sdk/arm-zephyr-eabi/bin/../lib/gcc/arm-zephyr-eabi/12.2.0/../../../../arm-zephyr-eabi/bin/ld.bfd: zephyr/subsys/net/libsubsys__net.a(sockets_tls.c.obj): in function `ztls_socket_data_check':
/opt/nordic/ncs/v2.9.1/zephyr/subsys/net/lib/sockets/sockets_tls.c:3088: undefined reference to `mbedtls_ssl_read'
/opt/nordic/ncs/toolchains/b8efef2ad5/opt/zephyr-sdk/arm-zephyr-eabi/bin/../lib/gcc/arm-zephyr-eabi/12.2.0/../../../../arm-zephyr-eabi/bin/ld.bfd: /opt/nordic/ncs/v2.9.1/zephyr/subsys/net/lib/sockets/sockets_tls.c:3131: undefined reference to `mbedtls_ssl_get_bytes_avail'
/opt/nordic/ncs/toolchains/b8efef2ad5/opt/zephyr-sdk/arm-zephyr-eabi/bin/../lib/gcc/arm-zephyr-eabi/12.2.0/../../../../arm-zephyr-eabi/bin/ld.bfd: zephyr/subsys/net/libsubsys__net.a(sockets_tls.c.obj): in function `tls_mbedtls_init':
/opt/nordic/ncs/v2.9.1/zephyr/subsys/net/lib/sockets/sockets_tls.c:1299: undefined reference to `mbedtls_ssl_set_bio'
/opt/nordic/ncs/toolchains/b8efef2ad5/opt/zephyr-sdk/arm-zephyr-eabi/bin/../lib/gcc/arm-zephyr-eabi/12.2.0/../../../../arm-zephyr-eabi/bin/ld.bfd: /opt/nordic/ncs/v2.9.1/zephyr/subsys/net/lib/sockets/sockets_tls.c:1310: undefined reference to `mbedtls_ssl_config_defaults'
/opt/nordic/ncs/toolchains/b8efef2ad5/opt/zephyr-sdk/arm-zephyr-eabi/bin/../lib/gcc/arm-zephyr-eabi/12.2.0/../../../../arm-zephyr-eabi/bin/ld.bfd: /opt/nordic/ncs/v2.9.1/zephyr/subsys/net/lib/sockets/sockets_tls.c:1386: undefined reference to `mbedtls_ssl_conf_authmode'
/opt/nordic/ncs/toolchains/b8efef2ad5/opt/zephyr-sdk/arm-zephyr-eabi/bin/../lib/gcc/arm-zephyr-eabi/12.2.0/../../../../arm-zephyr-eabi/bin/ld.bfd: /opt/nordic/ncs/v2.9.1/zephyr/subsys/net/lib/sockets/sockets_tls.c:1390: undefined reference to `mbedtls_ssl_conf_rng'
/opt/nordic/ncs/toolchains/b8efef2ad5/opt/zephyr-sdk/arm-zephyr-eabi/bin/../lib/gcc/arm-zephyr-eabi/12.2.0/../../../../arm-zephyr-eabi/bin/ld.bfd: /opt/nordic/ncs/v2.9.1/zephyr/subsys/net/lib/sockets/sockets_tls.c:1402: undefined reference to `mbedtls_ssl_conf_ciphersuites'
/opt/nordic/ncs/toolchains/b8efef2ad5/opt/zephyr-sdk/arm-zephyr-eabi/bin/../lib/gcc/arm-zephyr-eabi/12.2.0/../../../../arm-zephyr-eabi/bin/ld.bfd: /opt/nordic/ncs/v2.9.1/zephyr/subsys/net/lib/sockets/sockets_tls.c:1428: undefined reference to `mbedtls_ssl_setup'
/opt/nordic/ncs/toolchains/b8efef2ad5/opt/zephyr-sdk/arm-zephyr-eabi/bin/../lib/gcc/arm-zephyr-eabi/12.2.0/../../../../arm-zephyr-eabi/bin/ld.bfd: zephyr/subsys/net/libsubsys__net.a(sockets_tls.c.obj): in function `tls_alloc':
/opt/nordic/ncs/v2.9.1/zephyr/subsys/net/lib/sockets/sockets_tls.c:467: undefined reference to `mbedtls_ssl_init'
/opt/nordic/ncs/toolchains/b8efef2ad5/opt/zephyr-sdk/arm-zephyr-eabi/bin/../lib/gcc/arm-zephyr-eabi/12.2.0/../../../../arm-zephyr-eabi/bin/ld.bfd: /opt/nordic/ncs/v2.9.1/zephyr/subsys/net/lib/sockets/sockets_tls.c:468: undefined reference to `mbedtls_ssl_config_init'
/opt/nordic/ncs/toolchains/b8efef2ad5/opt/zephyr-sdk/arm-zephyr-eabi/bin/../lib/gcc/arm-zephyr-eabi/12.2.0/../../../../arm-zephyr-eabi/bin/ld.bfd: zephyr/subsys/net/libsubsys__net.a(sockets_tls.c.obj): in function `ztls_poll_prepare_pollin':
/opt/nordic/ncs/v2.9.1/zephyr/subsys/net/lib/sockets/sockets_tls.c:2976: undefined reference to `mbedtls_ssl_get_bytes_avail'
/opt/nordic/ncs/toolchains/b8efef2ad5/opt/zephyr-sdk/arm-zephyr-eabi/bin/../lib/gcc/arm-zephyr-eabi/12.2.0/../../../../arm-zephyr-eabi/bin/ld.bfd: /opt/nordic/ncs/v2.9.1/zephyr/subsys/net/lib/sockets/sockets_tls.c:2976: undefined reference to `mbedtls_ssl_get_bytes_avail'
/opt/nordic/ncs/toolchains/b8efef2ad5/opt/zephyr-sdk/arm-zephyr-eabi/bin/../lib/gcc/arm-zephyr-eabi/12.2.0/../../../../arm-zephyr-eabi/bin/ld.bfd: zephyr/subsys/net/libsubsys__net.a(sockets_tls.c.obj): in function `tls_mbedtls_handshake':
/opt/nordic/ncs/v2.9.1/zephyr/subsys/net/lib/sockets/sockets_tls.c:1199: undefined reference to `mbedtls_ssl_handshake'
/opt/nordic/ncs/toolchains/b8efef2ad5/opt/zephyr-sdk/arm-zephyr-eabi/bin/../lib/gcc/arm-zephyr-eabi/12.2.0/../../../../arm-zephyr-eabi/bin/ld.bfd: zephyr/subsys/net/libsubsys__net.a(sockets_tls.c.obj): in function `ztls_close_ctx':
/opt/nordic/ncs/v2.9.1/zephyr/subsys/net/lib/sockets/sockets_tls.c:2118: undefined reference to `mbedtls_ssl_close_notify'
/opt/nordic/ncs/toolchains/b8efef2ad5/opt/zephyr-sdk/arm-zephyr-eabi/bin/../lib/gcc/arm-zephyr-eabi/12.2.0/../../../../arm-zephyr-eabi/bin/ld.bfd: zephyr/subsys/net/libsubsys__net.a(sockets_tls.c.obj): in function `tls_session_restore':
/opt/nordic/ncs/v2.9.1/zephyr/subsys/net/lib/sockets/sockets_tls.c:708: undefined reference to `mbedtls_ssl_session_init'
/opt/nordic/ncs/toolchains/b8efef2ad5/opt/zephyr-sdk/arm-zephyr-eabi/bin/../lib/gcc/arm-zephyr-eabi/12.2.0/../../../../arm-zephyr-eabi/bin/ld.bfd: zephyr/subsys/net/libsubsys__net.a(sockets_tls.c.obj): in function `tls_session_get':
/opt/nordic/ncs/v2.9.1/zephyr/subsys/net/lib/sockets/sockets_tls.c:652: undefined reference to `mbedtls_ssl_session_load'
/opt/nordic/ncs/v2.9.1/zephyr/subsys/net/lib/sockets/sockets_tls.c:722: undefined reference to `mbedtls_ssl_session_free'
/opt/nordic/ncs/toolchains/b8efef2ad5/opt/zephyr-sdk/arm-zephyr-eabi/bin/../lib/gcc/arm-zephyr-eabi/12.2.0/../../../../arm-zephyr-eabi/bin/ld.bfd: zephyr/subsys/net/libsubsys__net.a(sockets_tls.c.obj): in function `tls_session_store':
/opt/nordic/ncs/v2.9.1/zephyr/subsys/net/lib/sockets/sockets_tls.c:678: undefined reference to `mbedtls_ssl_session_init'
/opt/nordic/ncs/toolchains/b8efef2ad5/opt/zephyr-sdk/arm-zephyr-eabi/bin/../lib/gcc/arm-zephyr-eabi/12.2.0/../../../../arm-zephyr-eabi/bin/ld.bfd: /opt/nordic/ncs/v2.9.1/zephyr/subsys/net/lib/sockets/sockets_tls.c:680: undefined reference to `mbedtls_ssl_get_session'
/opt/nordic/ncs/toolchains/b8efef2ad5/opt/zephyr-sdk/arm-zephyr-eabi/bin/../lib/gcc/arm-zephyr-eabi/12.2.0/../../../../arm-zephyr-eabi/bin/ld.bfd: zephyr/subsys/net/libsubsys__net.a(sockets_tls.c.obj): in function `tls_session_save':
/opt/nordic/ncs/v2.9.1/zephyr/subsys/net/lib/sockets/sockets_tls.c:610: undefined reference to `mbedtls_ssl_session_save'
/opt/nordic/ncs/toolchains/b8efef2ad5/opt/zephyr-sdk/arm-zephyr-eabi/bin/../lib/gcc/arm-zephyr-eabi/12.2.0/../../../../arm-zephyr-eabi/bin/ld.bfd: /opt/nordic/ncs/v2.9.1/zephyr/subsys/net/lib/sockets/sockets_tls.c:618: undefined reference to `mbedtls_ssl_session_save'
/opt/nordic/ncs/v2.9.1/zephyr/subsys/net/lib/sockets/sockets_tls.c:692: undefined reference to `mbedtls_ssl_session_free'
/opt/nordic/ncs/v2.9.1/zephyr/subsys/net/lib/sockets/sockets_tls.c:716: undefined reference to `mbedtls_ssl_set_session'
/opt/nordic/ncs/toolchains/b8efef2ad5/opt/zephyr-sdk/arm-zephyr-eabi/bin/../lib/gcc/arm-zephyr-eabi/12.2.0/../../../../arm-zephyr-eabi/bin/ld.bfd: zephyr/subsys/net/libsubsys__net.a(sockets_tls.c.obj): in function `send_tls':
/opt/nordic/ncs/v2.9.1/zephyr/subsys/net/lib/sockets/sockets_tls.c:2294: undefined reference to `mbedtls_ssl_write'
/opt/nordic/ncs/toolchains/b8efef2ad5/opt/zephyr-sdk/arm-zephyr-eabi/bin/../lib/gcc/arm-zephyr-eabi/12.2.0/../../../../arm-zephyr-eabi/bin/ld.bfd: zephyr/subsys/net/libsubsys__net.a(sockets_tls.c.obj): in function `recv_tls':
/opt/nordic/ncs/v2.9.1/zephyr/subsys/net/lib/sockets/sockets_tls.c:2589: undefined reference to `mbedtls_ssl_read'
/opt/nordic/ncs/toolchains/b8efef2ad5/opt/zephyr-sdk/arm-zephyr-eabi/bin/../lib/gcc/arm-zephyr-eabi/12.2.0/../../../../arm-zephyr-eabi/bin/ld.bfd: zephyr/subsys/net/libsubsys__net.a(sockets_tls.c.obj): in function `tls_opt_ciphersuite_list_get':
/opt/nordic/ncs/v2.9.1/zephyr/subsys/net/lib/sockets/sockets_tls.c:1571: undefined reference to `mbedtls_ssl_list_ciphersuites'
/opt/nordic/ncs/toolchains/b8efef2ad5/opt/zephyr-sdk/arm-zephyr-eabi/bin/../lib/gcc/arm-zephyr-eabi/12.2.0/../../../../arm-zephyr-eabi/bin/ld.bfd: zephyr/subsys/net/libsubsys__net.a(sockets_tls.c.obj): in function `tls_opt_ciphersuite_used_get':
/opt/nordic/ncs/v2.9.1/zephyr/subsys/net/lib/sockets/sockets_tls.c:1599: undefined reference to `mbedtls_ssl_get_ciphersuite'
/opt/nordic/ncs/toolchains/b8efef2ad5/opt/zephyr-sdk/arm-zephyr-eabi/bin/../lib/gcc/arm-zephyr-eabi/12.2.0/../../../../arm-zephyr-eabi/bin/ld.bfd: /opt/nordic/ncs/v2.9.1/zephyr/subsys/net/lib/sockets/sockets_tls.c:1604: undefined reference to `mbedtls_ssl_get_ciphersuite_id'
/opt/nordic/ncs/toolchains/b8efef2ad5/opt/zephyr-sdk/arm-zephyr-eabi/bin/../lib/gcc/arm-zephyr-eabi/12.2.0/../../../../arm-zephyr-eabi/bin/ld.bfd: zephyr/subsys/net/libsubsys__net.a(sockets_tls.c.obj): in function `tls_opt_ciphersuite_list_set':
/opt/nordic/ncs/v2.9.1/zephyr/subsys/net/lib/sockets/sockets_tls.c:1553: undefined reference to `mbedtls_ssl_conf_ciphersuites'
collect2: error: ld returned 1 exit status
FAILED: _sysbuild/sysbuild/images/myproj-firmware-prefix/src/myproj-firmware-stamp/myproj-firmware-build /Users/redacted/code/redacted/myproj/myproj-firmware/build/_sysbuild/sysbuild/images/myproj-firmware-prefix/src/myproj-firmware-stamp/myproj-firmware-build
cd /Users/redacted/code/redacted/myproj/myproj-firmware/build/myproj-firmware && /opt/nordic/ncs/toolchains/b8efef2ad5/Cellar/cmake/3.21.0/bin/cmake --build .
FATAL ERROR: command exited with status 1: /opt/nordic/ncs/toolchains/b8efef2ad5/bin/cmake --build /Users/redacted/code/redacted/myproj/myproj-firmware/build
 *  The terminal process terminated with exit code: 1.
Any idea how to fix this?
  • I managed to get it to compile by adding "CONFIG_NORDIC_SECURITY_BACKEND=y" but there's now a runtime bug (can't connect to the MQTT server, -22 error). Firmware logs:
    [00:01:30.294,036] <err> app_mqtt: MQTT Connect failed [-22]
    [00:01:31.448,455] <err> app_mqtt: MQTT Connect failed [-22]
    [00:01:32.577,087] <err> app_mqtt: MQTT Connect failed [-22]
    [00:01:33.725,738] <err> app_mqtt: MQTT Connect failed [-22]
    [00:01:34.864,746] <err> app_mqtt: MQTT Connect failed [-22]
    Server logs:
    1747267341: Client connection from 190.80.164.156 failed: error:0A000126:SSL routines::unexpected eof while reading.
    1747267342: Client connection from 190.80.164.156 failed: error:0A000126:SSL routines::unexpected eof while reading.
    1747267343: Client connection from 190.80.164.156 failed: error:0A000126:SSL routines::unexpected eof while reading.
    1747267345: New connection from 190.80.164.156:58322 on port 8883.
    1747267345: OpenSSL Error[0]: error:0A000126:SSL routines::unexpected eof while reading
    1747267345: Client <unknown> disconnected: Protocol error.
    1747267346: Client connection from 190.80.164.156 failed: error:0A000126:SSL routines::unexpected eof while reading.
    1747267347: New connection from 190.80.164.156:4126 on port 8883.
    1747267347: OpenSSL Error[0]: error:0A000126:SSL routines::unexpected eof while reading
    1747267347: Client <unknown> disconnected: Protocol error.
    1747267348: New connection from 190.80.164.156:3462 on port 8883.
    1747267348: OpenSSL Error[0]: error:0A000126:SSL routines::unexpected eof while reading
    1747267348: Client <unknown> disconnected: Protocol error.
    I published the repo on GitHub: https://github.com/olalonde/mqtt-tls-sample/
    I'm using a simcom a7672sa modem but it shouldn't be too hard to replicate using one of the officially supported modems.
  • In my experience, -22 is failed authentication.
    Can you try the certificate and webpage from another HTTPS client, to verify that they work?
    If they work, then it can (more likely) be that the algorithms that is required for this certificate is not enabled in configuration.
  • I opened a new thread and ended up solving the issue. It was a mix of that and also using a 4096 bit cert instead of a 2048 one.
