NOR Flash becomes gradually slow over time
I'm developing my app on nRF52840, NCS2.7.0 on VS Code 1.100.0.
My application needs to save settings data (4 x int32_t ) to external the NOR Flash (mx25r64) in `settings_storage` partition defined in pm_static.yml (in the attached zip file) before system reboots.
I use this snippet to read the saved settings:
static int direct_loader_immediate_value(const char *name, size_t len,
										 settings_read_cb read_cb, void *cb_arg,
										 void *param)
	const char *next;
	size_t name_len;
	int rc;
	struct direct_immediate_value *one_value =
		(struct direct_immediate_value *)param;
	name_len = settings_name_next(name, &next);
	if (name_len == 0)
		if (len == one_value->len)
			rc = read_cb(cb_arg, one_value->dest, len);
			if (rc >= 0)
				one_value->fetched = 1;
				LOG_INF("immediate load: OK.");
				return 0;
			printk(FAIL_MSG, rc);
			return rc;
		return -EINVAL;
	/* other keys aren't served by the callback
	 * Return success in order to skip them
	 * and keep storage processing.
	return 0;
int load_immediate_value(const char *name, void *dest, size_t len)
	int rc;
	struct direct_immediate_value dov;
	dov.fetched = 0;
	dov.len = len;
	dov.dest = dest;
	rc = settings_load_subtree_direct(name, direct_loader_immediate_value,
									  (void *)&dov);
	if (rc == 0)
		if (!dov.fetched)
			rc = -ENOENT;
	return rc;
int main()
	int my_var= 0;
	(void)load_immediate_value("dfu", &my_var, sizeof(dfu_mode));
	printk("my_var: %d\\n", my_var);
and this to write:
void save_params()
		int some_var = 5
    settings_save_one("some_var", &some_var, sizeof(some_var));
    // and some more vars
    settings_save();
    LOG_INF("saved: %d", some_var);
I noticed that after ~100 times of writing, flash accessing (both reading and writing) becomes gradually slow: It can take up to 5-6 seconds to read 1 record of 4 bytes.
Erasing the settings partition in the NOR flash DOES help it recover, i.e. reading/writing becomes fast: 50-60 millisecond to read a record.
Is there something wrong in my snippets causing the external NOR flash getting slower over time? Why and how to fix this issue?
Quan
1643.Archive.zip
  • HI Susheel,
    Currently, we are having 16KiB `settings_storage` partition defined in pm_static.yml as I had updated with you in the previous thread. System log prints out confirming that we have 4 sectors:
    [00:00:00.734,405] <inf> fs_nvs: 4 Sectors of 4096 bytes
    [00:00:00.740,539] <inf> fs_nvs: alloc wra: 0, f08
    [00:00:00.746,124] <inf> fs_nvs: data wra: 0, 354
    The GC will be triggered automatically by the system? How, when will it be triggered? When triggered, how does it affect our application?
    Unfortunately, I cannot give you the full source code of our project, but I can give you an overview of how my application reboots when it receives reboot event:
    1. Reboot event is put to the work queue so that it will be processed later.
    2. Once processed, it will proceed the following procedure:
    static void reboot(uint8_t reason)
        disconnect_ecg_bluetooth("util");
        deinit_ecg_bluetooth();
        stop_data_thread();
        if (reason == ECG_REBOOT_REASON_BOND_DELETED_BY_APP ||
            reason == ECG_REBOOT_REASON_BOND_DELETED_BY_BUTTON)
            erase_nor();
            settings_save_one(KEY_REBOOT_REASON, &reason, sizeof(reason));
            save_params();
        k_sleep(K_SECONDS(2));
        LOG_INF("Rebooting... with reason: %d", reason);
        sys_reboot(SYS_REBOOT_COLD);
    void save_params()
        settings_save_one("NAddr", &NAND_Addr, sizeof(NAND_Addr)); // 4 bytes
        settings_save_one("PktNum", &Pkt_num, sizeof(Pkt_num)); // 4 bytes
        settings_save_one("NMode", &NAND_mode, sizeof(NAND_mode)); // 4 bytes
        if (NAND_mode == 1)
            settings_save_one("NLen", &NOff_len, sizeof(NOff_len)); // 4 bytes
        settings_save();
        LOG_INF("NAND params updated: 0x%04x %d %d %d",
                NAND_Addr,
                NAND_mode,
                NOff_len,
                Pkt_num);
    As you may observe, we don't do anything special, we just save app's parameters to the external NOR flash at `settings_storage` partition.
    Over time, NOR flash access is getting slower and slower. I created a test version, which I reboots the system ~2000 times using the reboot flow above, reading flash increases from ~40ms to ~400ms. 400ms is much better than 3s when I started this ticket, maybe because I have made 2 changes:
    1. Apply your suggestion in `return 1` to prevent the driver from searching more. (Thanks a lot for this point)
    2. Shrink the `settings_storage` partition from 2MiB down to 16KiB. Since it's smaller, GC has better "chance" to trigger itself to do its job?
    Due to the nature of NOR flash key-value writing, getting slower over time is inevitable?
    Quan
  • Hi Susheel,
    Have you got any updates about my case? Please update me.
    Thanks.
    Quan
  • Sorry Quan for the late reply
    This is inevitable on how the Zephyr settings works on raw NOR flash.
    Each call to settings_save_one() appends a new record; old values remain as “stale” entries. As you accumulate hundreds or thousands of updates, reads must scan through every stale record to find the latest value, which becomes increasingly time-consuming. The garbage collection can be expensive in these settings. With only 16 KiB (four 4 KiB sectors), the FS_NVS backend fills up quickly and triggers GC often. Garbage collection pauses writes while it copies live entries, erases old sectors, and then resumes appending and adding further delays.
    I suggest you trying to use CONFIG_SETTINGS_FCB=y instead of NVS as the backend to achieve better performance. I have to admit that I have not done any benchmarking on this and is only knowledge gained from other discussions. so please take this suggestion with a pinch of salt.
