nrf54l15-dk zms +setting
Hi,Team,
I'm using the nrf54l15-dk to develop zms to save custom configurations without affecting the pairing information of ble.
So I have a few questions:
1.Is the storage_partition in the flash_map_pm.h file the same as that in the nrf54l15_cpuapp_common.dtsi file? If the same, does this mean that the size of settings_storage is 36K?  Is settings_storage the area used to store ble configuration information?
2. My nrf54l15-dk has some errors. Why is that? network/info, hub/info and first_run/check are custom configurations. I save them using settings_save_one and then reset the device, and an error E: set-value failure occurs.
[14:28:53.898]收←◆*** Booting nRF Connect SDK v2.8.0-a2386bfc8401 ***
*** Using Zephyr OS v3.7.99-0bc3393fb112 ***
I: 2 Sectors of 4096 bytes
I: alloc wra: 0, d70
I: data wra: 0, 280
D: Initialized
I: SoftDevice Controller build revision:
I: fe 2c f9 6a 7f 36 22 2e |.,.j.6".
I: a0 79 c0 40 be 2c 03 20 |.y.@.,.
I: 40 c2 f3 32             |@..2
I: HW Platform: Nordic Semiconductor (0x0002)
I: HW Variant: nRF54Lx (0x0005)
I: Firmware: Standard Bluetooth controller (0x00) Version 254.63788 Build 573996906
I: No ID address. App must call settings_load()
settings subsys initialization: OK.
D: set-value OK. key: bt/sc/4c569d0e17280
D: set-value OK. key: bt/keys/4c569d0e17280
D: set-value OK. key: bt/ccc/4c569d0e17280
D: set-value OK. key: bt/cf/30243273688c0
D: set-value OK. key: bt/ccc/30243273688c0
D: set-value OK. key: bt/keys/30243273688c0
E: set-value failure. key: network/info error(17)
E: set-value failure. key: hub/info error(62)
E: set-value failure. key: first_run/check error(4)
D: set-value OK. key: bt/hash
I: Identity: EB:DE:45:CF:A5:B5 (random)
I: HCI: version 6.0 (0x0e) revision 0x304e, manufacturer 0x0059
I: LMP: version 6.0 (0x0e) subver 0x304e
3. Through the error in the second one, I think both the custom configuration and the saved ble configuration information were saved in storage_partition, resulting in the error. So I want to ask whether storage_partition can be divided into the pairing information area of ble and the user-defined configuration information area.
Thanks.
  • Hi dede,
    In your project overlay file which you can change the default partition size for partition at start address 0X15C000 as below to change from 36KB to say 64KB
    &cpuapp_rram {
      partitions {
        storage_partition: partition@15c000 {
          label = "storage";
          /* bump from 36 KB up to, say, 64 KB */
          reg = <0x15c000 0x10000>;
    	chosen {
    		zephyr,settings-partition = &storage_partition;
    &storage_partition {
    	label = "chosen_partition";
