Can' get modem trace from custom board
6175.trace-2025-05-13T14-12-36.978Z.mtrace
I have a custom board build with an nrf9151. Right now I'd like to have the possibilty ti get modem trace. But it's look like I got crypted/corrupted data from UART1. So in my project I created an overlay file like this:
    chosen {
        nordic,modem-trace-uart = &uart1;
&i2c1 {
    status = "disabled";
&uart1 {
    current-speed = <1000000>;
    pinctrl-0 = <&uart1_default>;
    pinctrl-1 = <&uart1_sleep>;
Here is my board comon-pinctrl
&pinctrl {
	uart0_default: uart0_default {
		group1 {
			psels = <NRF_PSEL(UART_TX, 0, 6)>,
				<NRF_PSEL(UART_RX, 0, 5)>;
	uart0_sleep: uart0_sleep {
		group1 {
			low-power-enable;
	uart1_default: uart1_default {
		group1 {
			psels = <NRF_PSEL(UART_TX, 0, 23)>,
				<NRF_PSEL(UART_RX, 0, 24)>;
	uart1_sleep: uart1_sleep {
		group1 {
			low-power-enable;
	i2c1_default: i2c1_default {
		group1 {
			psels = <NRF_PSEL(TWIM_SDA, 0, 26)>,
				<NRF_PSEL(TWIM_SCL, 0, 27)>;
	i2c1_sleep: i2c1_sleep {
		group1 {
			low-power-enable;
in my common file
&adc {
	status = "okay";
&gpiote {
	status = "okay";
&gpio0 {
	status = "okay";
&uart0 {
	status = "okay";
	current-speed = <115200>;
	pinctrl-0 = <&uart0_default>;
	pinctrl-1 = <&uart0_sleep>;
&i2c1 {
	status = "okay";
	pinctrl-0 = <&i2c1_default>;
	pinctrl-1 = <&i2c1_sleep>;
So I think my board def and overlay are good...
In my prj.conf
CONFIG_GPIO=y
CONFIG_I2C=y
CONFIG_LOG=y
CONFIG_DEBUG=y
CONFIG_ASSERT=y
CONFIG_NRF_MODEM_LOG=y
CONFIG_SERIAL=y
CONFIG_AT_HOST_LIBRARY=y
CONFIG_NRF_MODEM_LIB_TRACE=y
Ok so with all this configuration I'm able to send AT command via serial (UART0) example if I send `AT+CGMR` I got mfw_nrf91x1_2.0.2. and when my custom board boot I have serial terminal showing this:
*** Booting nRF Connect SDK v3.5.99-ncs1-1 ***
[00:00:00.308,868] <inf> LOG: Sample started.
[00:00:00.308,990] <inf> nrf_modem: Initializing libmodem 2.6.1-lte-11b6ed4846a8
[00:00:00.556,304] <inf> nrf_modem: RPC ready
[00:00:00.556,671] <inf> nrf_modem_lib_trace: Trace thread ready
[00:00:00.558,258] <inf> nrf_modem_lib_trace: Trace level override: 2
[00:00:00.689,941] <inf> LOG: Waiting for LTE connect event.
So I presume UART0 works well and my firmware also. Right now I want to get modem trace so I plugged an CP2102 to my UART1, when my board boot I can see Rx led on my cp2102 blinking rapidly, so I presume lot of data coming to this UART1.
I open Cellular monitor and I select my cp2102 plug on UART1 and I let modem trace database in autoselect, in this configuration, cellular monitor never checked in green number 1 TRACE step. So after I try to specify my databse (v2.02 like AT+CGMR return mfw_nrf91x1_2.0.2) and now I have a mtrace file but all data inside look corrupted or crypted (I've attached an example with my post). I managed lot of test, always same prblem, even if I try to reset my board during cellular monitor detect phase.
Any thoughts?
  • We have checked the modem trace file, and the file is perfectly intact and we are able to decode it. The contents also look normal.
  • Ok good news, how did you do that? Because on my Mac I'm not able to convert and open it with wireshark for example.
    And if I try to use :
    /nrfutil trace lte --input-file ../Documents/rtt.bin --output-pcapng out.pcapng
    I got an error:
    [00:00:00] ------   0% [Fixed tracing] Tracing failed
    Error: Failed to detect trace database (error code 100)
    If I use celullar monitor -> open trace file in wireshark it's look like parse ok, detect trace DB, but when wireshark open, I have nothing on my screen, and I can't find /Users/xxxx/Downloads/test_rtt.bin to pcap on my Mac
    11:58:24.865	Getting serial port options from the persistent store for 0001.pc-nrfconnect-cellularmonitor
    11:58:36.328	Started converting /Users/xxxx/Downloads/test_rtt.bin to pcap.
    11:58:36.497	Detected trace DB: /Users/xxxx/Library/Application Support/nrfconnect/pc-nrfconnect-cellularmonitor/trace_db_cache/nRF91x1/2.0.2-FOTA/320176d5-9f40-45fc-923b-2661ec18d547/mfw_nrf91x1_2.0.2_trace-db.json
    11:58:36.810	Successfully converted /Users/xxxx/Downloads/test_rtt.bin to pcap
    But it's work if I use cellular monitor -> load trace file and selectect trace 2.0.2
    So I'll close this ticket and open a new one for my base issue, thanks.
