Build configuration stale AGAIN (unrecoverable)
This happens quite often, I simply has to create a new build configuration and in worse cases simply a new application and copy all my sourcefiles over to the new project.
This time I have a little info on what actually happened.
I have been working on this project for the last days, without any problem. Everything is latest version SDK, toolchain, VS code etc.
My project is under git control so I can see what is changed!
 - I did a small mistake when modifying the device tree which is in a seperate boards directory and also in git. This caused the application project to not build because of DTS problem.
 - I immediately fixed the problem but when trying to build my application VS Code terminal kept telling me that a build was already active so I could not start a build. I waited, tried to clean the build configuration and other things for 30 minutes. Unable to get out of the state that the system thought there was an active build in progress.
 - So finally I exited VS Code and restarted.
 - Now it opens with "The build configuration is stale. Run a prestine build". But this is not possible i get the following:
.... <next message>
For some reason it is impossible to get my project back in working condition.
I can see that there is a CMake warning followed by the error that configuration is incomplete!
There are no changes to my code or makefiles for the project.
This must be something in the build directory (that is excluded from git...) and it happens caused by a build error.
I am reporting this in the hope that Nordic some day will look at the unstable environment issue. This is something that happens way too often and I see others writing about it also. This is propably just an example of what can go wrong. In this case I think that making a new build configuration will solve the problem, but it is not nice. I have projects with many "dead" build configurations and I loose development time, every time it happens.
    As I want to replicate your problem, can you please provide additional more specific details about the problem? Which project did you use as a starting point, what exactly you changed and which error you got? Please provide detailed steps, relevant logs and possibly screenshots.
    Dejan
  • Hi
    I'm new to nrfConnect and installed V3.0 on a Linux Mint.I'm struggling with the definition of my custom board and the problem description fits my observations. Sometimes I'm just stuck with my board, sometimes even the build vanishes from Nordic extension view of the project (the build directory still exists but project does not show the build anymore).
    One easy way to demonstrate part of the problem:
    a) create a new application from hello world sample
    b) build it for nrf52840DK - everything is fine
    c) add the following lines to prj.conf (yes, we will get errors, this is important)
    CONFIG_GPIO=y
    CONFIG_I2C=y
    CONFIG_SPI=y
    CONFIG_USB_DEVICE_STACK=y
    CONFIG_USB_CDC_ACM=y
    CONFIG_USB_CDC_ACM_LOG_LEVEL_INF=n
    CONFIG_USB_DEVICE_LOG_LEVEL_INF=n
    CONFIG_SERIAL=y
    CONFIG_UART_CONSOLE=n
    CONFIG_USB_UART_CONSOLE=n
    CONFIG_SHELL_BACKEND_SERIAL=n
    CONFIG_LOG_BACKEND=n
    CONFIG_USB_DEVICE_PRODUCT="Heureka CDC ACM sample"
    CONFIG_USB_DEVICE_PID=0x0001
    start a "Pristine Build" and we get the expected FATAL ERROR.
    The point is: the spinning icon left of the build stops.
    start a second "Pristine Build" and we get the expected FATAL ERROR again.
    But this time the icon left of the build keeps spinning.
    I start a third "Pristine Build" and in the terminal I get:
    > Another task is currently building this configuration, closing.
    I'm afraid we might have overlapping issues which make it hard to pinpoint the cause.
    But I guess this phenomenon might be part of the problem.
    I can confirm that using the dialog to edit the build configuration helps a lot as does
    - stop VS code
    - remove build directory
    - restart VS code and create a new build
    hope this helps
    Peter
  • Trying to build on v3.0.1 and having similar issues, Have to close down and setup build from scratch to rebuild...
    looking for a solution...
  • Sorry - what do you mean by that? Can you explain why you want us to look at the supported OS page?
