Enabling the TLS layer to get a HTTPS connection going.
7343.nrf7002dk_nrf5340_cpuapp_ns.conf3124.prj.confHello everyone.
WE're trying to make a https connection with google.com and execute a GET request.
Wifi connection is working; DHCP seems to be working (my personal assumption given the log message we get: "Resolved: [(1, 1, 6, '', ('142.250.201.206', 443))]" which indicates that getaddrinfo() works); but when trying to initiate the socket via TLS, something strange happens: we get the error "OSError: 109".
Inserting some debug prints inside subsys/net/lib/sockets/, we found the culprit to be the function "int zsock_setsockopt_ctx(struct net_context *ctx, int level, int optname, const void *optval, socklen_t optlen)".
The function call that triggers error 109 is:  res = setsockopt(socket->ctx, SOL_TLS, TLS_PEER_VERIFY, &verify, sizeof(verify));
No matter what other option we try to set via setsockopt(), it will fail with the 109 error since the implementation for setsockopt() is somehow set to sockets_inet.c (whose implementation does not recognise SOL_TLS as a valid in its switches) instead of sockets_tls.c (which has handling for SOL_TLS in its switches). My personal hunch is that the config options set in the project are somehow wrong. Can someone please take a look over our .conf files? Maybe we can find the culprit. :)
We can provide any extra code snippets that are necessary for debugging and/ or run any tests. Have a great day and hope to hear from you soon!
    Good catch. That might be the problem.
    You can test that theory if you run a "nrfjprog --recover", then flash the .hex that I shared.
    Håkon
  • WORKED LIKE A CHARM Håkon!:
    *** Booting nRF Connect SDK v3.0.2-89ba1294ac9b ***
    *** Using Zephyr OS v4.0.99-f791c49f492c ***
    HTTPS client sample started
    Bringing network interface up
    Provisioning certificate
    Connecting to the network
    uart:~$
    uart:~$
    uart:~$
    uart:~$
    uart:~$ wifi cred add -s TP-Link_7474 -k 1 -p 55920322
    uart:~$ wifi cred auto_connect
    Connected
    Network connectivity established and IP address assigned
    Looking up google.com
    Resolved 142.250.180.238 (AF_INET)
    Connecting to google.com:443
    Sent 60 bytes
    Received 631 bytes
    >        HTTP/1.1 301 Moved Permanently
    Finished, closing socket.
    Disconnected
    Network connectivity lost
    Disconnected from the network
    uart:~$
    Edit: trying to translate it towards our project now.
  • Sadly, it didn't work:
    [00:00:00.520,965] <inf> wifi_nrf: Configuring SLEEP CTRL GPIO control register
    [00:00:00.657,867] <dbg> net_dns_resolve: dns_resolve_init_locked: (main): [0] 8.8.8.8
    [00:00:00.666,290] <dbg> net_dns_resolve: dns_resolve_init_locked: (main): [1] 8.8.4.4
    [00:00:00.675,079] <dbg> net_sock: zsock_socket_internal: (main): socket: ctx=0x2000a9a0, fd=3
    [00:00:00.684,265] <dbg> net_sock_svc: socket_service_thread: (net_socket_service): Service WEST_TOPDIR/zephyr/subsys/net/lib/dhcpv4/dhcpv4_server.c:1535 has 1 pollable sockets
    [00:00:00.700,500] <dbg> net_sock_svc: socket_service_thread: (net_socket_service): Service WEST_TOPDIR/zephyr/subsys/net/lib/dns/resolve.c:41 has 2 pollable sockets
    [00:00:00.715,820] <dbg> net_sock_svc: socket_service_thread: (net_socket_service): Monitoring 3 socket entries
    [00:00:00.726,837] <dbg> net_sock: zsock_socket_internal: (main): socket: ctx=0x2000aa50, fd=5
    *** Booting nRF Connect SDK v3.0.0-3bfc46578e42 ***
    *** Using Zephyr OS v4.0.99-a0e545cb437a ***
    [00:00:00.745,635] <inf> net_config: Initializing network
    [00:00:00.751,464] <inf> net_config: Waiting interface 1 (0x20008e00) to be up...
    [00:00:00.760,437] <inf> wifi_supplicant: wpa_supplicant initialized
    [00:00:00.767,669] <inf> net_config: IPv4 address: 192.168.1.1
    [00:00:00.773,956] <inf> net_config: Running dhcpv4 client...
    MicroPython v1.24.0-preview.467.g9ea566c69.dirty on 2025-06-05; zephyr-nrf7002dk with nrf5340
    Type "help()" for more information.
    >>> import sock_test
    >>> sock_test.step_1()
    Starting nrf7002dk with CPU frequency: 64 MHz
    Scan requested
    Num  | SSID                             (len) | Chan | RSSI | Security | BSSID
    1    | TP-Link_7474                     12    | 4    | -47  | WPA2-PSK | 40:ED:00:CD:74:73
    2    |                                  0     | 4    | -49  | WPA2-PSK | 62:ED:00:CD:74:73
    3    | DIGI-jZ3Y                        9     | 1    | -54  | WPA2-PSK | 68:B8:6B:51:04:01
    4    |                                  0     | 44   | -56  | WPA2-PSK | 62:ED:00:CD:74:72
    5    | TP-Link_7474                     12    | 44   | -56  | WPA2-PSK | 40:ED:00:CD:74:72
    6    | DIRECT-CE-HP Smart Tank 580-590  31    | 4    | -67  | WPA2-PSK | 00:04:EA:B0:61:C3
    7    | DIGI-3twM                        9     | 6    | -69  | WPA2-PSK | 74:31:AF:14:25:D1
    8    | DIGI-4TYa                        9     | 11   | -73  | WPA2-PSK | AC:CC:36:55:68:E1
    9    |                                  0     | 44   | -79  | WPA2-PSK | AE:CC:36:55:68:E1
    10   | DIGI-4TYa                        9     | 44   | -79  | WPA2-PSK | AC:CC:36:55:68:E9
    11   |                                  0     | 48   | -80  | WPA2-PSK | 6A:B8:6B:51:04:01
    12   | DIGI-jZ3Y                        9     | 48   | -80  | WPA2-PSK | 68:B8:6B:51:04:09
    13   | NIA                              3     | 7    | -83  | WPA2-PSK | 7C:F1:7E:78:C7:0F
    14   |                                  30    | 36   | -84  | WPA2-PSK | 72:A4:B7:09:10:E4
    15   | NIA                              3     | 48   | -85  | WPA2-PSK | 7C:F1:7E:78:C7:11
    16   | TP-Link_10E4_5G                  15    | 36   | -85  | WPA2-PSK | 72:A4:B7:09:10:E3
    17   | AG                               2     | 11   | -86  | WPA2-PSK | 04:95:E6:FF:42:02
    Scan request done
    Found 17 networks.
    Network ID: TP-Link_7474 & Network MAC: 40:ED:00:CD:74:73
    Network ID:  & Network MAC: 62:ED:00:CD:74:73
    Network ID: DIGI-jZ3Y & Network MAC: 68:B8:6B:51:04:01
    Network ID:  & Network MAC: 62:ED:00:CD:74:72
    Network ID: TP-Link_7474 & Network MAC: 40:ED:00:CD:74:72
    Network ID: DIRECT-CE-HP Smart Tank 580-590 & Network MAC: 00:04:EA:B0:61:C3
    Network ID: DIGI-3twM & Network MAC: 74:31:AF:14:25:D1
    Network ID: DIGI-4TYa & Network MAC: AC:CC:36:55:68:E1
    Network ID:  & Network MAC: AE:CC:36:55:68:E1
    Network ID: DIGI-4TYa & Network MAC: AC:CC:36:55:68:E9
    Network ID:  & Network MAC: 6A:B8:6B:51:04:01
    Network ID: DIGI-jZ3Y & Network MAC: 68:B8:6B:51:04:09
    Network ID: NIA & Network MAC: 7C:F1:7E:78:C7:0F
    Network ID:  & Network MAC: 72:A4:B7:09:10:E4
    Network ID: NIA & Network MAC: 7C:F1:7E:78:C7:11
    Network ID: TP-Link_10E4_5G & Network MAC: 72:A4:B7:09:10:E3
    Network ID: AG & Network MAC: 04:95:E6:FF:42:02
    MAC: F4:CE:36:00:1C:F4
    [00:01:09.523,193] <inf> wifimod: Connection requested
    [00:01:09.528,808] <inf> wifimod: ==================
    [00:01:09.534,851] <inf> wifimod: State: SCANNING
    [00:01:09.540,069] <inf> wifimod: Net If state: 5
    [00:01:09.845,397] <inf> wifimod: ==================
    [00:01:09.850,769] <inf> wifimod: State: AUTHENTICATING
    [00:01:09.856,506] <inf> wifimod: Net If state: 5
    [00:01:10.082,519] <dbg> net_sock_packet: zpacket_received_cb: (rx_q[0]): ctx=0x2000ab00, pkt=0x2005eb90, st=0, user_data=(nil)
    [00:01:10.110,717] <dbg> net_sock_packet: zpacket_received_cb: (rx_q[0]): ctx=0x2000ab00, pkt=0x2005eb50, st=0, user_data=(nil)
    [00:01:10.137,176] <inf> wifimod: Wi-Fi connect result: status...
    [00:01:10.143,676] <inf> wifimod: Connected
    Waiting for IP address...
    [00:01:10.265,411] <dbg> net_sock: zsock_close_ctx: (rx_q[0]): close: ctx=0x2000a9a0, fd=3
    [00:01:10.274,261] <dbg> net_sock: zsock_close_ctx: (rx_q[0]): close: ctx=0x2000aa50, fd=5
    [00:01:10.283,447] <dbg> net_sock: zsock_socket_internal: (rx_q[0]): socket: ctx=0x2000a9a0, fd=3
    [00:01:10.293,273] <dbg> net_sock: zsock_socket_internal: (rx_q[0]): socket: ctx=0x2000aa50, fd=5
    [00:01:10.304,168] <dbg> net_sock_svc: socket_service_thread: (net_socket_service): Received restart event.
    [00:01:10.336,395] <inf> net_dhcpv4: Received: 192.168.0.250
    [00:01:10.342,620] <inf> net_config: IPv4 address: 192.168.0.250
    [00:01:10.349,029] <inf> net_config: Lease time: 7200 seconds
    [00:01:10.355,285] <inf> net_config: Subnet: 255.255.255.0
    [00:01:10.361,206] <inf> net_config: Router: 192.168.0.1
    [00:01:10.367,065] <inf> wifimod: Net MGMT: Got IP via DHCP
    DHCP IP address: 192.168.0.250
    Resolving google.com...
    Using system DNS resolver...
    Querying DNS for google.com (type 1)...
    [00:01:12.186,981] <dbg> net_dns_resolve: dns_write: (mp_main): [0] submitting work to server idx 0 for id 3337 hash 59079
    semaphore wait...1
    [00:01:12.448,394] <dbg> net_sock: zsock_received_cb: (rx_q[0]): ctx=0x2000a9a0, pkt=0x2005eb50, st=0, user_data=(nil)
    DNS CALLBACK: status=-100
    DNS CALLBACK: status=-103
    Giving semaphore on info == NULL
    something...1
    Success!
    Trying to initialize socket...
    Family: 1, socktype: 1, proto: 259
    [00:01:12.481,628] <dbg> net_sock_tls: tls_alloc: (mp_main): Allocated TLS context, 0x20009c38
    [00:01:12.491,363] <dbg> net_sock: zsock_socket_internal: (mp_main): socket: ctx=0x2000abb0, fd=16
    Returned value: 15
    Done initializing socket!
    Performing TLS setup...
    Trying 1...42
    1 is done
    2 is done
    3 is done
    TLS setup complete.
    Connecting to: ('142.250.201.206', 443)
    [00:01:14.559,051] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_tls.c:1331: The SSL configuration is tls12 only.
    [00:01:14.578,002] <wrn> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_tls.c:4661: => handshake
    [00:01:14.588,317] <wrn> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:2354: => flush output
    [00:01:14.598,907] <wrn> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:2363: <= flush output
    [00:01:14.609,497] <wrn> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_tls.c:4580: client state: MBEDTLS_SSL_HELLO_REQUEST
    [00:01:14.622,161] <wrn> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:2354: => flush output
    [00:01:14.632,751] <wrn> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:2363: <= flush output
    [00:01:14.643,371] <wrn> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_tls.c:4580: client state: MBEDTLS_SSL_CLIENT_HELLO
    [00:01:14.655,944] <wrn> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_client.c:0921: => write client hello
    [00:01:14.667,755] <inf> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_client.c:0487: dumping 'client hello, random bytes' (32 bytes)
    [00:01:14.681,365] <inf> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_client.c:0487: 0000:  b0 96 9f f4 1c 28 01 54 3a d6 0a df b7 e9 f4 c0  .....(.T:.......
    [00:01:14.697,174] <inf> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_client.c:0487: 0010:  52 49 64 5a 1e f3 e6 94 c4 1a d1 99 77 58 4d 55  RIdZ........wXMU
    [00:01:14.712,738] <inf> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_client.c:0512: dumping 'session id' (0 bytes)
    [00:01:14.724,670] <inf> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_client.c:0370: client hello, add ciphersuite: c024, TLS-ECDHE-ECDSA-WITH-AES-256-CBC-SHA384
    [00:01:14.740,631] <inf> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_client.c:0370: client hello, add ciphersuite: c028, TLS-ECDHE-RSA-WITH-AES-256-CBC-SHA384
    [00:01:14.756,408] <inf> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_client.c:0370: client hello, add ciphersuite: 006b, TLS-DHE-RSA-WITH-AES-256-CBC-SHA256
    [00:01:14.772,003] <inf> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_client.c:0370: client hello, add ciphersuite: c00a, TLS-ECDHE-ECDSA-WITH-AES-256-CBC-SHA
    [00:01:14.787,689] <inf> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_client.c:0370: client hello, add ciphersuite: c014, TLS-ECDHE-RSA-WITH-AES-256-CBC-SHA
    [00:01:14.803,192] <inf> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_client.c:0370: client hello, add ciphersuite: 0039, TLS-DHE-RSA-WITH-AES-256-CBC-SHA
    [00:01:14.818,542] <inf> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_client.c:0370: client hello, add ciphersuite: c023, TLS-ECDHE-ECDSA-WITH-AES-128-CBC-SHA256
    [00:01:14.834,503] <inf> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_client.c:0370: client hello, add ciphersuite: c027, TLS-ECDHE-RSA-WITH-AES-128-CBC-SHA256
    [00:01:14.850,280] <inf> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_client.c:0370: client hello, add ciphersuite: 0067, TLS-DHE-RSA-WITH-AES-128-CBC-SHA256
    [00:01:14.865,875] <inf> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_client.c:0370: client hello, add ciphersuite: c009, TLS-ECDHE-ECDSA-WITH-AES-128-CBC-SHA
    [00:01:14.881,530] <inf> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_client.c:0370: client hello, add ciphersuite: c013, TLS-ECDHE-RSA-WITH-AES-128-CBC-SHA
    [00:01:14.897,033] <inf> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_client.c:0370: client hello, add ciphersuite: 0033, TLS-DHE-RSA-WITH-AES-128-CBC-SHA
    [00:01:14.912,414] <inf> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_client.c:0370: client hello, add ciphersuite: 003d, TLS-RSA-WITH-AES-256-CBC-SHA256
    [00:01:14.927,642] <inf> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_client.c:0370: client hello, add ciphersuite: 0035, TLS-RSA-WITH-AES-256-CBC-SHA
    [00:01:14.942,626] <inf> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_client.c:0370: client hello, add ciphersuite: c02a, TLS-ECDH-RSA-WITH-AES-256-CBC-SHA384
    [00:01:14.958,312] <inf> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_client.c:0370: client hello, add ciphersuite: c00f, TLS-ECDH-RSA-WITH-AES-256-CBC-SHA
    [00:01:14.973,754] <inf> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_client.c:0370: client hello, add ciphersuite: c026, TLS-ECDH-ECDSA-WITH-AES-256-CBC-SHA384
    [00:01:14.989,593] <inf> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_client.c:0370: client hello, add ciphersuite: c005, TLS-ECDH-ECDSA-WITH-AES-256-CBC-SHA
    [00:01:15.005,187] <inf> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_client.c:0370: client hello, add ciphersuite: 003c, TLS-RSA-WITH-AES-128-CBC-SHA256
    [00:01:15.020,446] <inf> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_client.c:0370: client hello, add ciphersuite: 002f, TLS-RSA-WITH-AES-128-CBC-SHA
    [00:01:15.035,430] <inf> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_client.c:0370: client hello, add ciphersuite: c029, TLS-ECDH-RSA-WITH-AES-128-CBC-SHA256
    [00:01:15.051,116] <inf> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_client.c:0370: client hello, add ciphersuite: c00e, TLS-ECDH-RSA-WITH-AES-128-CBC-SHA
    [00:01:15.066,528] <inf> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_client.c:0370: client hello, add ciphersuite: c025, TLS-ECDH-ECDSA-WITH-AES-128-CBC-SHA256
    [00:01:15.082,397] <inf> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_client.c:0370: client hello, add ciphersuite: c004, TLS-ECDH-ECDSA-WITH-AES-128-CBC-SHA
    [00:01:15.097,991] <inf> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_client.c:0388: adding EMPTY_RENEGOTIATION_INFO_SCSV
    [00:01:15.110,382] <inf> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_client.c:0397: client hello, got 25 cipher suites
    [00:01:15.122,650] <inf> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_client.c:0041: client hello, adding server name extension: google.com
    [00:01:15.136,627] <inf> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_client.c:0231: client hello, adding supported_groups extension
    [00:01:15.150,024] <inf> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_client.c:0250: got supported group(001d)
    [00:01:15.161,468] <inf> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_client.c:0282: NamedGroup: x25519 ( 1d )
    [00:01:15.172,943] <inf> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_client.c:0250: got supported group(0017)
    [00:01:15.184,387] <inf> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_client.c:0282: NamedGroup: secp256r1 ( 17 )
    [00:01:15.196,136] <inf> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_client.c:0302: dumping 'Supported groups extension' (6 bytes)
    [00:01:15.209,564] <inf> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_client.c:0302: 0000:  00 04 00 1d 00 17                                ......
    [00:01:15.224,243] <inf> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_tls.c:9503: adding signature_algorithms extension
    [00:01:15.236,511] <inf> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_tls.c:9523: got signature scheme [603] ecdsa_secp521r1_sha512
    [00:01:15.249,816] <inf> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_tls.c:9532: sent signature scheme [603] ecdsa_secp521r1_sha512
    [00:01:15.263,214] <inf> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_tls.c:9523: got signature scheme [601] rsa_pkcs1_sha512
    [00:01:15.275,970] <inf> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_tls.c:9532: sent signature scheme [601] rsa_pkcs1_sha512
    [00:01:15.288,848] <inf> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_tls.c:9523: got signature scheme [503] ecdsa_secp384r1_sha384
    [00:01:15.302,154] <inf> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_tls.c:9532: sent signature scheme [503] ecdsa_secp384r1_sha384
    [00:01:15.315,521] <inf> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_tls.c:9523: got signature scheme [501] rsa_pkcs1_sha384
    [00:01:15.328,308] <inf> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_tls.c:9532: sent signature scheme [501] rsa_pkcs1_sha384
    [00:01:15.341,156] <inf> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_tls.c:9523: got signature scheme [403] ecdsa_secp256r1_sha256
    [00:01:15.354,461] <inf> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_tls.c:9532: sent signature scheme [403] ecdsa_secp256r1_sha256
    [00:01:15.367,828] <inf> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_tls.c:9523: got signature scheme [401] rsa_pkcs1_sha256
    [00:01:15.380,615] <inf> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_tls.c:9532: sent signature scheme [401] rsa_pkcs1_sha256
    [00:01:15.393,463] <inf> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_tls12_client.c:0105: client hello, adding supported_point_formats extension
    [00:01:15.407,958] <inf> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_tls12_client.c:0150: client hello, adding ecjpake_kkpp extension
    [00:01:15.421,508] <inf> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_tls12_client.c:0165: generating new ecjpake parameters
    [00:01:15.533,020] <inf> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_tls12_client.c:0338: client hello, adding extended_master_secret extension
    [00:01:15.547,454] <inf> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_tls12_client.c:0372: client hello, adding session ticket extension
    [00:01:15.561,187] <inf> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_client.c:0689: client hello, total extension length: 395
    [00:01:15.574,066] <inf> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_client.c:0691: dumping 'client hello extensions' (395 bytes)
    [00:01:15.587,524] <inf> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_client.c:0691: 0000:  01 8b 00 00 00 0f 00 0d 00 00 0a 67 6f 6f 67 6c  ...........googl
    [00:01:15.603,332] <inf> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_client.c:0691: 0010:  65 2e 63 6f 6d 00 0a 00 06 00 04 00 1d 00 17 00  e.com...........
    [00:01:15.619,171] <inf> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_client.c:0691: 0020:  0d 00 0e 00 0c 06 03 06 01 05 03 05 01 04 03 04  ................
    [00:01:15.634,979] <inf> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_client.c:0691: 0030:  01 00 0b 00 02 01 00 01 00 01 4a 41 04 bd 77 32  ..........JA..w2
    [00:01:15.650,787] <inf> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_client.c:0691: 0040:  3c 61 d1 1b 98 ed c1 49 24 45 9e cd d0 df 38 1d  <a.....I$E....8.
    [00:01:15.666,595] <inf> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_client.c:0691: 0050:  4c b5 35 6b da 9a a7 dc 83 72 cd d5 68 43 9d 97  L.5k.....r..hC..
    [00:01:15.682,434] <inf> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_client.c:0691: 0060:  58 0d 10 88 90 1e 0f 99 52 f5 a0 ca 85 76 27 f1  X.......R....v'.
    [00:01:15.698,242] <inf> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_client.c:0691: 0070:  aa e5 95 34 8a 7f 9c 24 cd da a0 e7 8f 41 04 e7  ...4...$.....A..
    [00:01:15.714,050] <inf> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_client.c:0691: 0080:  7e 01 d1 c1 5e 47 10 0a a2 36 e6 3a 38 d1 d3 89  ~...^G...6.:8...
    [00:01:15.729,858] <inf> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_client.c:0691: 0090:  3f 16 7c 89 b9 42 45 40 35 72 19 8c d5 b2 49 df  ?.|[email protected].
    [00:01:15.745,666] <inf> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_client.c:0691: 00a0:  b4 b9 b1 2f f3 8e e2 ba 2d cc a8 83 a5 90 81 b3  .../....-.......
    [00:01:15.761,474] <inf> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_client.c:0691: 00b0:  06 88 8c 1c 3d 99 d4 d7 6d f1 35 36 0c db e7 20  ....=...m.56...
    [00:01:15.777,282] <inf> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_client.c:0691: 00c0:  d1 85 86 0d 01 be ff 85 5e 2d 6f 6f ab d1 27 ef  ........^-oo..'.
    [00:01:15.793,090] <inf> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_client.c:0691: 00d0:  d4 e1 e6 4d 28 c5 77 79 07 ee 3e 37 c7 7b 6a e7  ...M(.wy..>7.{j.
    [00:01:15.808,898] <inf> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_client.c:0691: 00e0:  41 04 7c 2f c8 6d 51 a8 92 af ed da ba 9f ee 07  A.|/.mQ.........
    [00:01:15.824,707] <inf> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_client.c:0691: 00f0:  83 e7 1e e9 4c de af 78 64 76 6f 83 1a c6 01 5f  ....L..xdvo...._
    [00:01:15.840,515] <inf> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_client.c:0691: 0100:  54 6f 92 c4 a1 00 f9 c1 39 b9 99 91 d3 c9 3b 50  To......9.....;P
    [00:01:15.856,323] <inf> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_client.c:0691: 0110:  19 5b b5 f3 92 c0 a7 ee ff 66 63 38 08 47 46 c9  .[.......fc8.GF.
    [00:01:15.872,131] <inf> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_client.c:0691: 0120:  7b 28 41 04 12 95 f3 c1 e4 89 64 ff 13 ca 43 8d  {(A.......d...C.
    [00:01:15.887,939] <inf> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_client.c:0691: 0130:  fb c5 85 6f 9b 94 bf 61 7b 69 bf 8a a6 56 b9 5d  ...o...a{i...V.]
    [00:01:15.903,747] <inf> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_client.c:0691: 0140:  1b db dc f6 c6 bd 7d 40 5e fa 00 f7 58 ad 36 ff  ......}@^...X.6.
    [00:01:15.919,555] <inf> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_client.c:0691: 0150:  a1 6f bc 35 88 3f a8 cc f0 f4 d4 5b 82 68 8c b1  .o.5.?.....[.h..
    [00:01:15.935,363] <inf> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_client.c:0691: 0160:  70 46 f8 8b 20 e5 3d 08 db a5 9d ac 0f ae d0 a5  pF.. .=.........
    [00:01:15.951,171] <inf> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_client.c:0691: 0170:  8a 32 d4 5f 71 81 72 ff 5f ab 65 3b 26 4d 02 0a  .2._q.r._.e;&M..
    [00:01:15.966,918] <inf> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_client.c:0691: 0180:  25 d6 59 f7 a1 00 17 00 00 00 23                 %.Y.......#
    [00:01:15.983,245] <wrn> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:2784: => write handshake message
    [00:01:15.994,750] <wrn> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:2944: => write record
    [00:01:16.005,401] <inf> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3028: output record: msgtype = 22, version = [3:3], msglen = 490
    [00:01:16.019,500] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3033: dumping 'output record sent to network' (495 bytes)
    [00:01:16.035,156] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3033: 0000:  16 03 03 01 ea 01 00 01 e6 03 03 b0 96 9f f4 1c  ................
    [00:01:16.052,612] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3033: 0010:  28 01 54 3a d6 0a df b7 e9 f4 c0 52 49 64 5a 1e  (.T:.......RIdZ.
    [00:01:16.070,098] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3033: 0020:  f3 e6 94 c4 1a d1 99 77 58 4d 55 00 00 32 c0 24  .......wXMU..2.$
    [00:01:16.087,554] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3033: 0030:  c0 28 00 6b c0 0a c0 14 00 39 c0 23 c0 27 00 67  .(.k.....9.#.'.g
    [00:01:16.105,041] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3033: 0040:  c0 09 c0 13 00 33 00 3d 00 35 c0 2a c0 0f c0 26  .....3.=.5.*...&
    [00:01:16.122,528] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3033: 0050:  c0 05 00 3c 00 2f c0 29 c0 0e c0 25 c0 04 00 ff  ...<./.)...%....
    [00:01:16.139,984] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3033: 0060:  01 00 01 8b 00 00 00 0f 00 0d 00 00 0a 67 6f 6f  .............goo
    [00:01:16.157,470] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3033: 0070:  67 6c 65 2e 63 6f 6d 00 0a 00 06 00 04 00 1d 00  gle.com.........
    [00:01:16.174,957] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3033: 0080:  17 00 0d 00 0e 00 0c 06 03 06 01 05 03 05 01 04  ................
    [00:01:16.192,443] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3033: 0090:  03 04 01 00 0b 00 02 01 00 01 00 01 4a 41 04 bd  ............JA..
    [00:01:16.209,899] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3033: 00a0:  77 32 3c 61 d1 1b 98 ed c1 49 24 45 9e cd d0 df  w2<a.....I$E....
    [00:01:16.227,386] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3033: 00b0:  38 1d 4c b5 35 6b da 9a a7 dc 83 72 cd d5 68 43  8.L.5k.....r..hC
    [00:01:16.244,842] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3033: 00c0:  9d 97 58 0d 10 88 90 1e 0f 99 52 f5 a0 ca 85 76  ..X.......R....v
    [00:01:16.262,298] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3033: 00d0:  27 f1 aa e5 95 34 8a 7f 9c 24 cd da a0 e7 8f 41  '....4...$.....A
    [00:01:16.279,785] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3033: 00e0:  04 e7 7e 01 d1 c1 5e 47 10 0a a2 36 e6 3a 38 d1  ..~...^G...6.:8.
    [00:01:16.297,241] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3033: 00f0:  d3 89 3f 16 7c 89 b9 42 45 40 35 72 19 8c d5 b2  ..?.|..BE@5r....
    [00:01:16.314,697] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3033: 0100:  49 df b4 b9 b1 2f f3 8e e2 ba 2d cc a8 83 a5 90  I..../....-.....
    [00:01:16.332,183] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3033: 0110:  81 b3 06 88 8c 1c 3d 99 d4 d7 6d f1 35 36 0c db  ......=...m.56..
    [00:01:16.349,639] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3033: 0120:  e7 20 d1 85 86 0d 01 be ff 85 5e 2d 6f 6f ab d1  . ........^-oo..
    [00:01:16.367,126] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3033: 0130:  27 ef d4 e1 e6 4d 28 c5 77 79 07 ee 3e 37 c7 7b  '....M(.wy..>7.{
    [00:01:16.384,582] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3033: 0140:  6a e7 41 04 7c 2f c8 6d 51 a8 92 af ed da ba 9f  j.A.|/.mQ.......
    [00:01:16.402,069] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3033: 0150:  ee 07 83 e7 1e e9 4c de af 78 64 76 6f 83 1a c6  ......L..xdvo...
    [00:01:16.419,555] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3033: 0160:  01 5f 54 6f 92 c4 a1 00 f9 c1 39 b9 99 91 d3 c9  ._To......9.....
    [00:01:16.437,011] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3033: 0170:  3b 50 19 5b b5 f3 92 c0 a7 ee ff 66 63 38 08 47  ;P.[.......fc8.G
    [00:01:16.454,467] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3033: 0180:  46 c9 7b 28 41 04 12 95 f3 c1 e4 89 64 ff 13 ca  F.{(A.......d...
    [00:01:16.471,954] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3033: 0190:  43 8d fb c5 85 6f 9b 94 bf 61 7b 69 bf 8a a6 56  C....o...a{i...V
    [00:01:16.489,410] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3033: 01a0:  b9 5d 1b db dc f6 c6 bd 7d 40 5e fa 00 f7 58 ad  .]......}@^...X.
    [00:01:16.506,896] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3033: 01b0:  36 ff a1 6f bc 35 88 3f a8 cc f0 f4 d4 5b 82 68  6..o.5.?.....[.h
    [00:01:16.524,353] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3033: 01c0:  8c b1 70 46 f8 8b 20 e5 3d 08 db a5 9d ac 0f ae  ..pF.. .=.......
    [00:01:16.541,809] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3033: 01d0:  d0 a5 8a 32 d4 5f 71 81 72 ff 5f ab 65 3b 26 4d  ...2._q.r._.e;&M
    [00:01:16.559,295] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3033: 01e0:  02 0a 25 d6 59 f7 a1 00 17 00 00 00 23 00 00     ..%.Y.......#..
    [00:01:16.576,385] <wrn> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3081: <= write record
    [00:01:16.586,975] <wrn> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:2905: <= write handshake message
    [00:01:16.598,541] <wrn> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_client.c:1014: <= write client hello
    [00:01:16.609,893] <wrn> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:2354: => flush output
    [00:01:16.620,513] <wrn> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:2368: message length: 495, out_left: 495
    [00:01:16.633,453] <wrn> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:2375: ssl->f_send() returned 495 (-0xfffffe11)
    [00:01:16.646,179] <wrn> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:2402: <= flush output
    [00:01:16.656,799] <wrn> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_tls.c:4580: client state: MBEDTLS_SSL_SERVER_HELLO
    [00:01:16.669,372] <wrn> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_tls12_client.c:1196: => parse server hello
    [00:01:16.681,243] <wrn> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4298: => read record
    [00:01:16.691,741] <wrn> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:2156: => fetch input
    [00:01:16.702,270] <wrn> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:2296: in_left: 0, nb_want: 5
    [00:01:16.713,500] <wrn> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:2316: in_left: 0, nb_want: 5
    [00:01:16.724,639] <wrn> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_tls.c:4672: <= handshake
    [00:01:16.780,975] <dbg> net_sock: zsock_received_cb: (rx_q[0]): ctx=0x2000abb0, pkt=0x2005eb90, st=0, user_data=(nil)
    [00:01:16.792,572] <wrn> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_tls.c:4661: => handshake
    [00:01:16.802,856] <wrn> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:2354: => flush output
    [00:01:16.813,446] <wrn> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:2363: <= flush output
    [00:01:16.824,035] <wrn> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_tls.c:4580: client state: MBEDTLS_SSL_SERVER_HELLO
    [00:01:16.836,639] <wrn> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_tls12_client.c:1196: => parse server hello
    [00:01:16.848,510] <wrn> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4298: => read record
    [00:01:16.859,008] <wrn> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:2156: => fetch input
    [00:01:16.869,537] <wrn> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:2296: in_left: 0, nb_want: 5
    [00:01:16.880,767] 01:16.884,490] <dbg> net_sock: zsock_received_cb: (rx_q[0]): ctx=0x2000abb0, pkt=0x2005ebd0, st=0, user_data=(nil)
    [1;33m<wrn> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:2316: in_left: 0, nb_want: 5
    [00:01:16.905,517] <wrn> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:2319: ssl->f_recv(_timeout)() returned 5 (-0xfffffffb)
    [00:01:16.918,945] <wrn> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:2341: <= fetch input
    [00:01:16.929,504] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3964: dumping 'input record header' (5 bytes)
    [00:01:16.943,969] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3964: 0000:  16 03 03 00 3f                                   ....?
    [00:01:16.960,266] <inf> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3966: input record: msgtype = 22, version = [0x303], msglen = 63
    [00:01:16.974,304] <wrn> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:2156: => fetch input
    [00:01:16.985,198] <wrn> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:2296: in_left: 5, nb_want: 68
    [00:01:16.996,520] <wrn> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:2316: in_left: 5, nb_want: 68
    [00:01:17.007,812] <wrn> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:2319: ssl->f_recv(_timeout)() returned 63 (-0xffffffc1)
    [00:01:17.021,331] <wrn> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:2341: <= fetch input
    [00:01:17.031,890] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: dumping 'input record from network' (68 bytes)
    [00:01:17.047,088] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 0000:  16 03 03 00 3f 02 00 00 3b 03 03 68 41 a7 85 d6  ....?...;..hA...
    [00:01:17.064,575] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 0010:  40 a5 ee ef bb f8 f5 27 29 93 bd 70 19 93 ba 6e  @......')..p...n
    [00:01:17.082,061] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 0020:  14 8b 41 44 4f 57 4e 47 52 44 01 00 c0 09 00 00  ..ADOWNGRD......
    [00:01:17.099,517] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 0030:  13 00 17 00 00 ff 01 00 01 00 00 0b 00 02 01 00  ................
    [00:01:17.116,882] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 0040:  00 23 00 00                                      .#..
    [00:01:17.133,087] <inf> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3239: handshake message: msglen = 63, type = 2, hslen = 63
    [00:01:17.146,667] <inf> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3328: sole handshake fragment: 63, 0..63 of 63
    [00:01:17.159,210] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: dumping 'reassembled record' (68 bytes)
    [00:01:17.173,797] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 0000:  16 03 03 00 3f 02 00 00 3b 03 03 68 41 a7 85 d6  ....?...;..hA...
    [00:01:17.191,253] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 0010:  40 a5 ee ef bb f8 f5 27 29 93 bd 70 19 93 ba 6e  @......')..p...n
    [00:01:17.208,740] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 0020:  14 8b 41 44 4f 57 4e 47 52 44 01 00 c0 09 00 00  ..ADOWNGRD......
    [00:01:17.226,867] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 0030:  13 00 17 00 00 ff 01 00 01 00 00 0b 00 02 01 00  ................
    [00:01:17.244,293] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 0040:  00 23 00 00                                      .#..
    [00:01:17.260,803] <wrn> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4370: <= read record
    [00:01:17.271,301] <inf> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_tls12_client.c:1270: dumping 'server hello, version' (2 bytes)
    [00:01:17.284,759] <inf> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_tls12_client.c:1270: 0000:  03 03                                            ..
    [00:01:17.299,621] <inf> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_tls12_client.c:1291: server hello, current time: 1749133189
    [00:01:17.312,774] <inf> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_tls12_client.c:1301: dumping 'server hello, random bytes' (32 bytes)
    [00:01:17.326,904] <inf> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_tls12_client.c:1301: 0000:  68 41 a7 85 d6 40 a5 ee ef bb f8 f5 27 29 93 bd  hA...@......')..
    [00:01:17.343,261] <inf> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_tls12_client.c:1301: 0010:  70 19 93 ba 6e 14 8b 41 44 4f 57 4e 47 52 44 01  p...n..ADOWNGRD.
    [00:01:17.359,313] <inf> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_tls12_client.c:1363: server hello, session id len.: 0
    [00:01:17.371,948] <inf> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_tls12_client.c:1364: dumping 'server hello, session id' (0 bytes)
    [00:01:17.385,559] <inf> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_tls12_client.c:1388: no session has been resumed
    [00:01:17.397,735] <inf> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_tls12_client.c:1391: server hello, chosen ciphersuite: c009
    [00:01:17.410,858] <inf> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_tls12_client.c:1392: server hello, compress alg.: 0
    [00:01:17.423,309] <inf> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_tls12_client.c:1427: server hello, chosen ciphersuite: TLS-ECDHE-ECDSA-WITH-AES-128-CBC-SHA
    [00:01:17.439,208] <wrn> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_tls12_client.c:1448: server hello, total extension length: 19
    [00:01:17.452,758] <inf> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_tls12_client.c:1518: found extended_master_secret extension
    [00:01:17.465,881] <inf> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_tls12_client.c:1466: found renegotiation extension
    [00:01:17.478,210] <inf> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_tls12_client.c:1545: found supported_point_formats extension
    [00:01:17.491,424] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_tls12_client.c:0844: point format selected: 0
    [00:01:17.505,249] <inf> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_tls12_client.c:1531: found session_ticket extension
    [00:01:17.517,669] <wrn> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_tls12_client.c:1662: <= parse server hello
    [00:01:17.529,571] <wrn> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:2354: => flush output
    [00:01:17.540,161] <wrn> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:2363: <= flush output
    [00:01:17.551,391] <wrn> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_tls.c:4580: client state: MBEDTLS_SSL_SERVER_CERTIFICATE
    [00:01:17.564,575] <wrn> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_tls.c:8093: => parse certificate
    [00:01:17.575,592] <wrn> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4298: => read record
    [00:01:17.586,090] <wrn> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:2156: => fetch input
    [00:01:17.596,618] <wrn> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:2296: in_left: 0, nb_want: 5
    [00:01:17.607,849] <wrn> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:2316: in_left: 0, nb_want: 5
    [00:01:17.619,079] <wrn> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:2319: ssl->f_recv(_timeout)() returned 5 (-0xfffffffb)
    [00:01:17.632,507] <wrn> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:2341: <= fetch input
    [00:01:17.643,737] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3964: dumping 'input record header' (5 bytes)
    [00:01:17.658,264] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3964: 0000:  16 03 03 18 b6                                   .....
    [00:01:17.674,560] <inf> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3966: input record: msgtype = 22, version = [0x303], msglen = 6326
    [00:01:17.688,781] <wrn> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:2156: => fetch input
    [00:01:17.699,310] <wrn> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:2296: in_left: 5, nb_want: 6331
    [00:01:17.711,334] <wrn> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:2316: in_left: 5, nb_want: 6331
    [00:01:17.722,808] <wrn> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:2319: ssl->f_recv(_timeout)() returned 1291 (-0xfffffaf5)
    [00:01:17.736,572] <wrn> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:2316: in_left: 1296, nb_want: 6331
    [00:01:17.748,260] <wrn> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_tls.c:4672: <= handshake
    [00:01:17.784,179] <dbg> net_sock: zsock_received_cb: (rx_q[0]): ctx=0x2000abb0, pkt=0x2005ebd0, st=0, user_data=(nil)
    [00:01:17.795,776] <wrn> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_tls.c:4661: => handshake
    [00:01:17.806,060] <wrn> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:2354: => flush output
    [00:01:17.816,650] <wrn> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:2363: <= flush output
    [00:01:17.827,270] <wrn> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_tls.c:4580: client state: MBEDTLS_SSL_SERVER_CERTIFICATE
    [00:01:17.840,362] <wrn> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_tls.c:8093: => parse certificate
    [00:01:17.851,379] <wrn> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4298: => read record
    [00:01:17.861,877] <wrn> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:2156: => fetch input
    [00:01:17.872,406] <wrn> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:2296: in_left: 1296, nb_want: 5
    [00:01:17.883,850] 00:01:17.887,756] <dbg> net_sock: zsock_received_cb: (rx_q[0]): ctx=0x2000abb0, pkt=0x2005eb90, st=0, user_data=(nil)
    1;33m<wrn> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:2341: <= fetch input
    [00:01:17.907,958] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3964: dumping 'input record header' (5 bytes)
    [00:01:17.922,454] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3964: 0000:  16 03 03 18 b6                                   .....
    [00:01:17.938,751] <inf> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3966: input record: msgtype = 22, version = [0x303], msglen = 6326
    [00:01:17.952,972] <wrn> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:2156: => fetch input
    [00:01:17.963,500] <wrn> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:2296: in_left: 1296, nb_want: 6331
    [00:01:17.975,830] <wrn> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:2316: in_left: 1296, nb_want: 6331
    [00:01:17.987,579] <wrn> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:2319: ssl->f_recv(_timeout)() returned 1364 (-0xfffffaac)
    [00:01:18.001,342] <wrn> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:2316: in_left: 2660, nb_want: 6331
    [00:01:18.013,031] <wrn> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_tls.c:4672: <= handshake
    [00:01:18.052,398] <dbg> net_sock: zsock_received_cb: (rx_q[0]): ctx=0x2000abb0, pkt=0x2005eb90, st=0, user_data=(nil)
    [00:01:18.063,995] <wrn> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_tls.c:4661: => handshake
    [00:01:18.074,310] <wrn> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:2354: => flush output
    [00:01:18.084,899] <wrn> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:2363: <= flush output
    [00:01:18.095,520] <wrn> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_tls.c:4580: client state: MBEDTLS_SSL_SERVER_CERTIFICATE
    [00:01:18.108,612] <wrn> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_tls.c:8093: => parse certificate
    [00:01:18.119,628] <wrn> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4298: => read record
    [00:01:18.130,126] <wrn> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:2156: => fetch input
    [00:01:18.140,655] <wrn> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:2296: in_left: 2660, nb_want: 5
    [00:01:18.152,099] 00:01:18.156,005] <dbg> net_sock: zsock_received_cb: (rx_q[0]): ctx=0x2000abb0, pkt=0x2005ebd0, st=0, user_data=(nil)
    [00:01:18.176,147] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3964: dumping 'input record header' (5 bytes)
    [00:01:18.190,612] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3964: 0000:  16 03 03 18 b6                                   .....
    [00:01:18.206,909] <inf> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3966: input record: msgtype = 22, version = [0x303], msglen = 6326
    [00:01:18.221,130] <wrn> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:2156: => fetch input
    [00:01:18.231,689] <wrn> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:2296: in_left: 2660, nb_want: 6331
    [00:01:18.243,988] <wrn> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:2316: in_left: 2660, nb_want: 6331
    [00:01:18.255,737] <wrn> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:2319: ssl->f_recv(_timeout)() returned 1364 (-0xfffffaac)
    [00:01:18.269,500] <wrn> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:2316: in_left: 4024, nb_want: 6331
    [00:01:18.281,188] <wrn> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_tls.c:4672: <= handshake
    [00:01:18.320,800] <dbg> net_sock: zsock_received_cb: (rx_q[0]): ctx=0x2000abb0, pkt=0x2005ebd0, st=0, user_data=(nil)
    [00:01:18.332,397] <wrn> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_tls.c:4661: => handshake
    [00:01:18.342,681] <wrn> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:2354: => flush output
    [00:01:18.353,271] <wrn> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:2363: <= flush output
    [00:01:18.363,891] <wrn> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_tls.c:4580: client state: MBEDTLS_SSL_SERVER_CERTIFICATE
    [00:01:18.376,983] <wrn> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_tls.c:8093: => parse certificate
    [00:01:18.388,000] <wrn> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4298: => read record
    [00:01:18.398,498] <wrn> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:2156: => fetch input
    [00:01:18.409,027] <wrn> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:2296: in_left: 4024, nb_want: 5
    [00:01:18.420,471] 00:01:18.424,407] <dbg> net_sock: zsock_received_cb: (rx_q[0]): ctx=0x2000abb0, pkt=0x2005eb90, st=0, user_data=(nil)
    [00:01:18.444,549] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3964: dumping 'input record header' (5 bytes)
    [00:01:18.459,014] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3964: 0000:  16 03 03 18 b6                                   .....
    [00:01:18.475,982] <inf> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3966: input record: msgtype = 22, version = [0x303], msglen = 6326
    [00:01:18.490,264] <wrn> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:2156: => fetch input
    [00:01:18.500,793] <wrn> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:2296: in_left: 4024, nb_want: 6331
    [00:01:18.513,092] <wrn> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:2316: in_left: 4024, nb_want: 6331
    [00:01:18.524,841] <wrn> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:2319: ssl->f_recv(_timeout)() returned 1364 (-0xfffffaac)
    [00:01:18.538,604] <wrn> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:2316: in_left: 5388, nb_want: 6331
    [00:01:18.550,292] <wrn> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_tls.c:4672: <= handshake
    [00:01:18.590,393] <dbg> net_sock: zsock_received_cb: (rx_q[0]): ctx=0x2000abb0, pkt=0x2005eb90, st=0, user_data=(nil)
    [00:01:18.601,989] <wrn> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_tls.c:4661: => handshake
    [00:01:18.612,274] <wrn> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:2354: => flush output
    [00:01:18.622,863] <wrn> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:2363: <= flush output
    [00:01:18.633,483] <wrn> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_tls.c:4580: client state: MBEDTLS_SSL_SERVER_CERTIFICATE
    [00:01:18.646,575] <wrn> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_tls.c:8093: => parse certificate
    [00:01:18.657,592] <wrn> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4298: => read record
    [00:01:18.668,090] <wrn> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:2156: => fetch input
    [00:01:18.678,619] <wrn> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:2296: in_left: 5388, nb_want: 5
    [00:01:18.690,032] 00:01:18.693,939] <dbg> net_sock: zsock_received_cb: (rx_q[0]): ctx=0x2000abb0, pkt=0x2005ebd0, st=0, user_data=(nil)
    [00:01:18.714,111] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3964: dumping 'input record header' (5 bytes)
    [00:01:18.728,576] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3964: 0000:  16 03 03 18 b6                                   .....
    [00:01:18.744,873] <inf> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3966: input record: msgtype = 22, version = [0x303], msglen = 6326
    [00:01:18.759,094] <wrn> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:2156: => fetch input
    [00:01:18.769,622] <wrn> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:2296: in_left: 5388, nb_want: 6331
    [00:01:18.781,860] <wrn> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:2316: in_left: 5388, nb_want: 6331
    [00:01:18.793,609] <wrn> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:2319: ssl->f_recv(_timeout)() returned 943 (-0xfffffc51)
    [00:01:18.807,220] <wrn> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:2341: <= fetch input
    [00:01:18.817,779] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: dumping 'input record from network' (6331 bytes)
    [00:01:18.833,160] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 0000:  16 03 03 18 b6 0b 00 18 b2 00 18 af 00 0e 31 30  ..............10
    [00:01:18.850,616] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 0010:  82 0e 2d 30 82 0d 15 a0 03 02 01 02 02 10 66 86  ..-0..........f.
    [00:01:18.868,103] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 0020:  f0 7e 70 d7 df c2 09 4c b8 5a 34 d6 e3 d8 30 0d  .~p....L.Z4...0.
    [00:01:18.885,589] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 0030:  06 09 2a 86 48 86 f7 0d 01 01 0b 05 00 30 3b 31  ..*.H........0;1
    [00:01:18.903,076] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 0040:  0b 30 09 06 03 55 04 06 13 02 55 53 31 1e 30 1c  .0...U....US1.0.
    [00:01:18.920,532] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 0050:  06 03 55 04 0a 13 15 47 6f 6f 67 6c 65 20 54 72  ..U....Google Tr
    [00:01:18.938,018] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 0060:  75 73 74 20 53 65 72 76 69 63 65 73 31 0c 30 0a  ust Services1.0.
    [00:01:18.955,505] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 0070:  06 03 55 04 03 13 03 57 52 32 30 1e 17 0d 32 35  ..U....WR20...25
    [00:01:18.972,991] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 0080:  30 35 31 32 30 38 34 32 35 38 5a 17 0d 32 35 30  0512084258Z..250
    [00:01:18.990,447] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 0090:  38 30 34 30 38 34 32 35 37 5a 30 17 31 15 30 13  804084257Z0.1.0.
    [00:01:19.007,934] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 00a0:  06 03 55 04 03 0c 0c 2a 2e 67 6f 6f 67 6c 65 2e  ..U....*.google.
    [00:01:19.025,421] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 00b0:  63 6f 6d 30 59 30 13 06 07 2a 86 48 ce 3d 02 01  com0Y0...*.H.=..
    [00:01:19.042,907] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 00c0:  06 08 2a 86 48 ce 3d 03 01 07 03 42 00 04 0a a6  ..*.H.=....B....
    [00:01:19.060,363] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 00d0:  db af e0 06 99 b8 6f 52 89 c4 25 83 94 32 5c 27  ......oR..%..2\'
    [00:01:19.077,850] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 00e0:  b9 94 42 1d 87 49 f5 1d c7 c8 2e 2f 3b 23 d2 df  ..B..I...../;#..
    [00:01:19.095,306] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 00f0:  e9 8c 33 79 94 86 0e 25 80 b3 ae 8e 72 22 5d ba  ..3y...%....r"].
    [00:01:19.112,792] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 0100:  ef ce 7c 6f 30 55 e7 6c 1d 4b 02 70 fa 9d a3 82  ..|o0U.l.K.p....
    [00:01:19.130,279] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 0110:  0c 1a 30 82 0c 16 30 0e 06 03 55 1d 0f 01 01 ff  ..0...0...U.....
    [00:01:19.147,766] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 0120:  04 04 03 02 07 80 30 13 06 03 55 1d 25 04 0c 30  ......0...U.%..0
    [00:01:19.165,222] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 0130:  0a 06 08 2b 06 01 05 05 07 03 01 30 0c 06 03 55  ...+.......0...U
    [00:01:19.182,708] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 0140:  1d 13 01 01 ff 04 02 30 00 30 1d 06 03 55 1d 0e  .......0.0...U..
    [00:01:19.200,195] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 0150:  04 16 04 14 ad 60 2e a1 68 d6 19 19 03 fa a3 0e  .....`..h.......
    [00:01:19.217,681] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 0160:  ad d6 24 d8 fa 28 88 3e 30 1f 06 03 55 1d 23 04  ..$..(.>0...U.#.
    [00:01:19.235,168] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 0170:  18 30 16 80 14 de 1b 1e ed 79 15 d4 3e 37 24 c3  .0.......y..>7$.
    [00:01:19.252,655] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 0180:  21 bb ec 34 39 6d 42 b2 30 30 58 06 08 2b 06 01  !..49mB.00X..+..
    [00:01:19.270,141] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 0190:  05 05 07 01 01 04 4c 30 4a 30 21 06 08 2b 06 01  ......L0J0!..+..
    [00:01:19.287,597] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 01a0:  05 05 07 30 01 86 15 68 74 74 70 3a 2f 2f 6f 2e  ...0...http://o.
    [00:01:19.305,084] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 01b0:  70 6b 69 2e 67 6f 6f 67 2f 77 72 32 30 25 06 08  pki.goog/wr20%..
    [00:01:19.322,570] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 01c0:  2b 06 01 05 05 07 30 02 86 19 68 74 74 70 3a 2f  +.....0...http:/
    [00:01:19.340,026] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 01d0:  2f 69 2e 70 6b 69 2e 67 6f 6f 67 2f 77 72 32 2e  /i.pki.goog/wr2.
    [00:01:19.357,513] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 01e0:  63 72 74 30 82 09 f0 06 03 55 1d 11 04 82 09 e7  crt0.....U......
    [00:01:19.375,671] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 01f0:  30 82 09 e3 82 0c 2a 2e 67 6f 6f 67 6c 65 2e 63  0.....*.google.c
    [00:01:19.393,249] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 0200:  6f 6d 82 16 2a 2e 61 70 70 65 6e 67 69 6e 65 2e  om..*.appengine.
    [00:01:19.410,736] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 0210:  67 6f 6f 67 6c 65 2e 63 6f 6d 82 09 2a 2e 62 64  google.com..*.bd
    [00:01:19.428,192] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 0220:  6e 2e 64 65 76 82 15 2a 2e 6f 72 69 67 69 6e 2d  n.dev..*.origin-
    [00:01:19.445,648] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 0230:  74 65 73 74 2e 62 64 6e 2e 64 65 76 82 12 2a 2e  test.bdn.dev..*.
    [00:01:19.463,134] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 0240:  63 6c 6f 75 64 2e 67 6f 6f 67 6c 65 2e 63 6f 6d  cloud.google.com
    [00:01:19.480,590] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 0250:  82 18 2a 2e 63 72 6f 77 64 73 6f 75 72 63 65 2e  ..*.crowdsource.
    [00:01:19.498,870] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 0260:  67 6f 6f 67 6c 65 2e 63 6f 6d 82 18 2a 2e 64 61  google.com..*.da
    [00:01:19.516,357] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 0270:  74 61 63 6f 6d 70 75 74 65 2e 67 6f 6f 67 6c 65  tacompute.google
    [00:01:19.533,813] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 0280:  2e 63 6f 6d 82 0b 2a 2e 67 6f 6f 67 6c 65 2e 63  .com..*.google.c
    [00:01:19.551,300] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 0290:  61 82 0b 2a 2e 67 6f 6f 67 6c 65 2e 63 6c 82 0e  a..*.google.cl..
    [00:01:19.568,756] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 02a0:  2a 2e 67 6f 6f 67 6c 65 2e 63 6f 2e 69 6e 82 0e  *.google.co.in..
    [00:01:19.586,242] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 02b0:  2a 2e 67 6f 6f 67 6c 65 2e 63 6f 2e 6a 70 82 0e  *.google.co.jp..
    [00:01:19.603,698] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 02c0:  2a 2e 67 6f 6f 67 6c 65 2e 63 6f 2e 75 6b 82 0f  *.google.co.uk..
    [00:01:19.621,154] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 02d0:  2a 2e 67 6f 6f 67 6c 65 2e 63 6f 6d 2e 61 72 82  *.google.com.ar.
    [00:01:19.638,641] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 02e0:  0f 2a 2e 67 6f 6f 67 6c 65 2e 63 6f 6d 2e 61 75  .*.google.com.au
    [00:01:19.656,097] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 02f0:  82 0f 2a 2e 67 6f 6f 67 6c 65 2e 63 6f 6d 2e 62  ..*.google.com.b
    [00:01:19.673,553] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 0300:  72 82 0f 2a 2e 67 6f 6f 67 6c 65 2e 63 6f 6d 2e  r..*.google.com.
    [00:01:19.691,040] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 0310:  63 6f 82 0f 2a 2e 67 6f 6f 67 6c 65 2e 63 6f 6d  co..*.google.com
    [00:01:19.708,496] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 0320:  2e 6d 78 82 0f 2a 2e 67 6f 6f 67 6c 65 2e 63 6f  .mx..*.google.co
    [00:01:19.725,952] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 0330:  6d 2e 74 72 82 0f 2a 2e 67 6f 6f 67 6c 65 2e 63  m.tr..*.google.c
    [00:01:19.743,438] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 0340:  6f 6d 2e 76 6e 82 0b 2a 2e 67 6f 6f 67 6c 65 2e  om.vn..*.google.
    [00:01:19.760,894] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 0350:  64 65 82 0b 2a 2e 67 6f 6f 67 6c 65 2e 65 73 82  de..*.google.es.
    [00:01:19.778,350] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 0360:  0b 2a 2e 67 6f 6f 67 6c 65 2e 66 72 82 0b 2a 2e  .*.google.fr..*.
    [00:01:19.795,837] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 0370:  67 6f 6f 67 6c 65 2e 68 75 82 0b 2a 2e 67 6f 6f  google.hu..*.goo
    [00:01:19.813,293] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 0380:  67 6c 65 2e 69 74 82 0b 2a 2e 67 6f 6f 67 6c 65  gle.it..*.google
    [00:01:19.830,749] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 0390:  2e 6e 6c 82 0b 2a 2e 67 6f 6f 67 6c 65 2e 70 6c  .nl..*.google.pl
    [00:01:19.848,236] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 03a0:  82 0b 2a 2e 67 6f 6f 67 6c 65 2e 70 74 82 0f 2a  ..*.google.pt..*
    [00:01:19.865,692] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 03b0:  2e 67 6f 6f 67 6c 65 61 70 69 73 2e 63 6e 82 11  .googleapis.cn..
    [00:01:19.883,178] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 03c0:  2a 2e 67 6f 6f 67 6c 65 76 69 64 65 6f 2e 63 6f  *.googlevideo.co
    [00:01:19.900,665] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 03d0:  6d 82 0c 2a 2e 67 73 74 61 74 69 63 2e 63 6e 82  m..*.gstatic.cn.
    [00:01:19.918,121] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 03e0:  10 2a 2e 67 73 74 61 74 69 63 2d 63 6e 2e 63 6f  .*.gstatic-cn.co
    [00:01:19.935,577] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 03f0:  6d 82 0f 67 6f 6f 67 6c 65 63 6e 61 70 70 73 2e  m..googlecnapps.
    [00:01:19.953,063] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 0400:  63 6e 82 11 2a 2e 67 6f 6f 67 6c 65 63 6e 61 70  cn..*.googlecnap
    [00:01:19.970,520] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 0410:  70 73 2e 63 6e 82 11 67 6f 6f 67 6c 65 61 70 70  ps.cn..googleapp
    [00:01:19.988,006] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 0420:  73 2d 63 6e 2e 63 6f 6d 82 13 2a 2e 67 6f 6f 67  s-cn.com..*.goog
    [00:01:20.005,462] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 0430:  6c 65 61 70 70 73 2d 63 6e 2e 63 6f 6d 82 0c 67  leapps-cn.com..g
    [00:01:20.022,949] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 0440:  6b 65 63 6e 61 70 70 73 2e 63 6e 82 0e 2a 2e 67  kecnapps.cn..*.g
    [00:01:20.040,405] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 0450:  6b 65 63 6e 61 70 70 73 2e 63 6e 82 12 67 6f 6f  kecnapps.cn..goo
    [00:01:20.057,891] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 0460:  67 6c 65 64 6f 77 6e 6c 6f 61 64 73 2e 63 6e 82  gledownloads.cn.
    [00:01:20.075,347] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 0470:  14 2a 2e 67 6f 6f 67 6c 65 64 6f 77 6e 6c 6f 61  .*.googledownloa
    [00:01:20.092,834] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 0480:  64 73 2e 63 6e 82 10 72 65 63 61 70 74 63 68 61  ds.cn..recaptcha
    [00:01:20.110,290] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 0490:  2e 6e 65 74 2e 63 6e 82 12 2a 2e 72 65 63 61 70  .net.cn..*.recap
    [00:01:20.127,777] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 04a0:  74 63 68 61 2e 6e 65 74 2e 63 6e 82 10 72 65 63  tcha.net.cn..rec
    [00:01:20.145,233] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 04b0:  61 70 74 63 68 61 2d 63 6e 2e 6e 65 74 82 12 2a  aptcha-cn.net..*
    [00:01:20.162,719] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 04c0:  2e 72 65 63 61 70 74 63 68 61 2d 63 6e 2e 6e 65  .recaptcha-cn.ne
    [00:01:20.180,175] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 04d0:  74 82 0b 77 69 64 65 76 69 6e 65 2e 63 6e 82 0d  t..widevine.cn..
    [00:01:20.197,662] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 04e0:  2a 2e 77 69 64 65 76 69 6e 65 2e 63 6e 82 11 61  *.widevine.cn..a
    [00:01:20.215,118] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 04f0:  6d 70 70 72 6f 6a 65 63 74 2e 6f 72 67 2e 63 6e  mpproject.org.cn
    [00:01:20.232,574] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 0500:  82 13 2a 2e 61 6d 70 70 72 6f 6a 65 63 74 2e 6f  ..*.ampproject.o
    [00:01:20.250,061] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 0510:  72 67 2e 63 6e 82 11 61 6d 70 70 72 6f 6a 65 63  rg.cn..ampprojec
    [00:01:20.267,517] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 0520:  74 2e 6e 65 74 2e 63 6e 82 13 2a 2e 61 6d 70 70  t.net.cn..*.ampp
    [00:01:20.285,003] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 0530:  72 6f 6a 65 63 74 2e 6e 65 74 2e 63 6e 82 17 67  roject.net.cn..g
    [00:01:20.302,459] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 0540:  6f 6f 67 6c 65 2d 61 6e 61 6c 79 74 69 63 73 2d  oogle-analytics-
    [00:01:20.319,946] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 0550:  63 6e 2e 63 6f 6d 82 19 2a 2e 67 6f 6f 67 6c 65  cn.com..*.google
    [00:01:20.337,432] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 0560:  2d 61 6e 61 6c 79 74 69 63 73 2d 63 6e 2e 63 6f  -analytics-cn.co
    [00:01:20.354,888] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 0570:  6d 82 17 67 6f 6f 67 6c 65 61 64 73 65 72 76 69  m..googleadservi
    [00:01:20.372,344] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 0580:  63 65 73 2d 63 6e 2e 63 6f 6d 82 19 2a 2e 67 6f  ces-cn.com..*.go
    [00:01:20.389,831] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 0590:  6f 67 6c 65 61 64 73 65 72 76 69 63 65 73 2d 63  ogleadservices-c
    [00:01:20.407,318] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 05a0:  6e 2e 63 6f 6d 82 11 67 6f 6f 67 6c 65 76 61 64  n.com..googlevad
    [00:01:20.424,774] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 05b0:  73 2d 63 6e 2e 63 6f 6d 82 13 2a 2e 67 6f 6f 67  s-cn.com..*.goog
    [00:01:20.442,260] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 05c0:  6c 65 76 61 64 73 2d 63 6e 2e 63 6f 6d 82 11 67  levads-cn.com..g
    [00:01:20.459,716] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 05d0:  6f 6f 67 6c 65 61 70 69 73 2d 63 6e 2e 63 6f 6d  oogleapis-cn.com
    [00:01:20.477,203] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 05e0:  82 13 2a 2e 67 6f 6f 67 6c 65 61 70 69 73 2d 63  ..*.googleapis-c
    [00:01:20.494,689] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 05f0:  6e 2e 63 6f 6d 82 15 67 6f 6f 67 6c 65 6f 70 74  n.com..googleopt
    [00:01:20.512,878] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 0600:  69 6d 69 7a 65 2d 63 6e 2e 63 6f 6d 82 17 2a 2e  imize-cn.com..*.
    [00:01:20.530,456] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 0610:  67 6f 6f 67 6c 65 6f 70 74 69 6d 69 7a 65 2d 63  googleoptimize-c
    [00:01:20.547,943] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 0620:  6e 2e 63 6f 6d 82 12 64 6f 75 62 6c 65 63 6c 69  n.com..doublecli
    [00:01:20.565,429] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 0630:  63 6b 2d 63 6e 2e 6e 65 74 82 14 2a 2e 64 6f 75  ck-cn.net..*.dou
    [00:01:20.582,885] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 0640:  62 6c 65 63 6c 69 63 6b 2d 63 6e 2e 6e 65 74 82  bleclick-cn.net.
    [00:01:20.600,372] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 0650:  18 2a 2e 66 6c 73 2e 64 6f 75 62 6c 65 63 6c 69  .*.fls.doublecli
    [00:01:20.617,828] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 0660:  63 6b 2d 63 6e 2e 6e 65 74 82 16 2a 2e 67 2e 64  ck-cn.net..*.g.d
    [00:01:20.635,314] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 0670:  6f 75 62 6c 65 63 6c 69 63 6b 2d 63 6e 2e 6e 65  oubleclick-cn.ne
    [00:01:20.652,801] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 0680:  74 82 0e 64 6f 75 62 6c 65 63 6c 69 63 6b 2e 63  t..doubleclick.c
    [00:01:20.670,257] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 0690:  6e 82 10 2a 2e 64 6f 75 62 6c 65 63 6c 69 63 6b  n..*.doubleclick
    [00:01:20.687,744] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 06a0:  2e 63 6e 82 14 2a 2e 66 6c 73 2e 64 6f 75 62 6c  .cn..*.fls.doubl
    [00:01:20.705,200] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 06b0:  65 63 6c 69 63 6b 2e 63 6e 82 12 2a 2e 67 2e 64  eclick.cn..*.g.d
    [00:01:20.722,686] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 06c0:  6f 75 62 6c 65 63 6c 69 63 6b 2e 63 6e 82 11 64  oubleclick.cn..d
    [00:01:20.740,173] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 06d0:  61 72 74 73 65 61 72 63 68 2d 63 6e 2e 6e 65 74  artsearch-cn.net
    [00:01:20.757,629] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 06e0:  82 13 2a 2e 64 61 72 74 73 65 61 72 63 68 2d 63  ..*.dartsearch-c
    [00:01:20.775,115] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 06f0:  6e 2e 6e 65 74 82 1d 67 6f 6f 67 6c 65 74 72 61  n.net..googletra
    [00:01:20.792,572] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 0700:  76 65 6c 61 64 73 65 72 76 69 63 65 73 2d 63 6e  veladservices-cn
    [00:01:20.810,058] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 0710:  2e 63 6f 6d 82 1f 2a 2e 67 6f 6f 67 6c 65 74 72  .com..*.googletr
    [00:01:20.827,514] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 0720:  61 76 65 6c 61 64 73 65 72 76 69 63 65 73 2d 63  aveladservices-c
    [00:01:20.845,001] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 0730:  6e 2e 63 6f 6d 82 18 67 6f 6f 67 6c 65 74 61 67  n.com..googletag
    [00:01:20.862,457] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 0740:  73 65 72 76 69 63 65 73 2d 63 6e 2e 63 6f 6d 82  services-cn.com.
    [00:01:20.879,943] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 0750:  1a 2a 2e 67 6f 6f 67 6c 65 74 61 67 73 65 72 76  .*.googletagserv
    [00:01:20.897,430] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 0760:  69 63 65 73 2d 63 6e 2e 63 6f 6d 82 17 67 6f 6f  ices-cn.com..goo
    [00:01:20.915,527] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 0770:  67 6c 65 74 61 67 6d 61 6e 61 67 65 72 2d 63 6e  gletagmanager-cn
    [00:01:20.933,105] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 0780:  2e 63 6f 6d 82 19 2a 2e 67 6f 6f 67 6c 65 74 61  .com..*.googleta
    [00:01:20.950,592] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 0790:  67 6d 61 6e 61 67 65 72 2d 63 6e 2e 63 6f 6d 82  gmanager-cn.com.
    [00:01:20.968,048] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 07a0:  18 67 6f 6f 67 6c 65 73 79 6e 64 69 63 61 74 69  .googlesyndicati
    [00:01:20.985,534] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 07b0:  6f 6e 2d 63 6e 2e 63 6f 6d 82 1a 2a 2e 67 6f 6f  on-cn.com..*.goo
    [00:01:21.003,021] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 07c0:  67 6c 65 73 79 6e 64 69 63 61 74 69 6f 6e 2d 63  glesyndication-c
    [00:01:21.020,477] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 07d0:  6e 2e 63 6f 6d 82 24 2a 2e 73 61 66 65 66 72 61  n.com.$*.safefra
    [00:01:21.037,933] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 07e0:  6d 65 2e 67 6f 6f 67 6c 65 73 79 6e 64 69 63 61  me.googlesyndica
    [00:01:21.055,419] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 07f0:  74 69 6f 6e 2d 63 6e 2e 63 6f 6d 82 16 61 70 70  tion-cn.com..app
    [00:01:21.072,875] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 0800:  2d 6d 65 61 73 75 72 65 6d 65 6e 74 2d 63 6e 2e  -measurement-cn.
    [00:01:21.090,332] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 0810:  63 6f 6d 82 18 2a 2e 61 70 70 2d 6d 65 61 73 75  com..*.app-measu
    [00:01:21.107,818] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 0820:  72 65 6d 65 6e 74 2d 63 6e 2e 63 6f 6d 82 0b 67  rement-cn.com..g
    [00:01:21.125,976] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 0830:  76 74 31 2d 63 6e 2e 63 6f 6d 82 0d 2a 2e 67 76  vt1-cn.com..*.gv
    [00:01:21.143,463] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 0840:  74 31 2d 63 6e 2e 63 6f 6d 82 0b 67 76 74 32 2d  t1-cn.com..gvt2-
    [00:01:21.160,949] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 0850:  63 6e 2e 63 6f 6d 82 0d 2a 2e 67 76 74 32 2d 63  cn.com..*.gvt2-c
    [00:01:21.178,405] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 0860:  6e 2e 63 6f 6d 82 0b 32 6d 64 6e 2d 63 6e 2e 6e  n.com..2mdn-cn.n
    [00:01:21.195,892] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 0870:  65 74 82 0d 2a 2e 32 6d 64 6e 2d 63 6e 2e 6e 65  et..*.2mdn-cn.ne
    [00:01:21.213,348] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 0880:  74 82 14 67 6f 6f 67 6c 65 66 6c 69 67 68 74 73  t..googleflights
    [00:01:21.230,834] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 0890:  2d 63 6e 2e 6e 65 74 82 16 2a 2e 67 6f 6f 67 6c  -cn.net..*.googl
    [00:01:21.248,291] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 08a0:  65 66 6c 69 67 68 74 73 2d 63 6e 2e 6e 65 74 82  eflights-cn.net.
    [00:01:21.265,777] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 08b0:  0c 61 64 6d 6f 62 2d 63 6e 2e 63 6f 6d 82 0e 2a  .admob-cn.com..*
    [00:01:21.283,264] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 08c0:  2e 61 64 6d 6f 62 2d 63 6e 2e 63 6f 6d 82 14 67  .admob-cn.com..g
    [00:01:21.300,720] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 08d0:  6f 6f 67 6c 65 73 61 6e 64 62 6f 78 2d 63 6e 2e  ooglesandbox-cn.
    [00:01:21.318,176] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 08e0:  63 6f 6d 82 16 2a 2e 67 6f 6f 67 6c 65 73 61 6e  com..*.googlesan
    [00:01:21.335,662] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 08f0:  64 62 6f 78 2d 63 6e 2e 63 6f 6d 82 1e 2a 2e 73  dbox-cn.com..*.s
    [00:01:21.353,149] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 0900:  61 66 65 6e 75 70 2e 67 6f 6f 67 6c 65 73 61 6e  afenup.googlesan
    [00:01:21.370,605] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 0910:  64 62 6f 78 2d 63 6e 2e 63 6f 6d 82 0d 2a 2e 67  dbox-cn.com..*.g
    [00:01:21.388,092] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 0920:  73 74 61 74 69 63 2e 63 6f 6d 82 14 2a 2e 6d 65  static.com..*.me
    [00:01:21.405,578] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 0930:  74 72 69 63 2e 67 73 74 61 74 69 63 2e 63 6f 6d  tric.gstatic.com
    [00:01:21.423,034] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 0940:  82 0a 2a 2e 67 76 74 31 2e 63 6f 6d 82 11 2a 2e  ..*.gvt1.com..*.
    [00:01:21.440,521] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 0950:  67 63 70 63 64 6e 2e 67 76 74 31 2e 63 6f 6d 82  gcpcdn.gvt1.com.
    [00:01:21.457,977] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 0960:  0a 2a 2e 67 76 74 32 2e 63 6f 6d 82 0e 2a 2e 67  .*.gvt2.com..*.g
    [00:01:21.475,463] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 0970:  63 70 2e 67 76 74 32 2e 63 6f 6d 82 10 2a 2e 75  cp.gvt2.com..*.u
    [00:01:21.492,919] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 0980:  72 6c 2e 67 6f 6f 67 6c 65 2e 63 6f 6d 82 16 2a  rl.google.com..*
    [00:01:21.510,406] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 0990:  2e 79 6f 75 74 75 62 65 2d 6e 6f 63 6f 6f 6b 69  .youtube-nocooki
    [00:01:21.527,862] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 09a0:  65 2e 63 6f 6d 82 0b 2a 2e 79 74 69 6d 67 2e 63  e.com..*.ytimg.c
    [00:01:21.545,349] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 09b0:  6f 6d 82 0a 61 69 2e 61 6e 64 72 6f 69 64 82 0b  om..ai.android..
    [00:01:21.562,805] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 09c0:  61 6e 64 72 6f 69 64 2e 63 6f 6d 82 0d 2a 2e 61  android.com..*.a
    [00:01:21.580,291] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 09d0:  6e 64 72 6f 69 64 2e 63 6f 6d 82 13 2a 2e 66 6c  ndroid.com..*.fl
    [00:01:21.597,747] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 09e0:  61 73 68 2e 61 6e 64 72 6f 69 64 2e 63 6f 6d 82  ash.android.com.
    [00:01:21.615,234] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 09f0:  04 67 2e 63 6e 82 06 2a 2e 67 2e 63 6e 82 04 67  .g.cn..*.g.cn..g
    [00:01:21.632,690] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 0a00:  2e 63 6f 82 06 2a 2e 67 2e 63 6f 82 06 67 6f 6f  .co..*.g.co..goo
    [00:01:21.650,177] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 0a10:  2e 67 6c 82 0a 77 77 77 2e 67 6f 6f 2e 67 6c 82  .gl..www.goo.gl.
    [00:01:21.667,633] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 0a20:  14 67 6f 6f 67 6c 65 2d 61 6e 61 6c 79 74 69 63  .google-analytic
    [00:01:21.685,089] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 0a30:  73 2e 63 6f 6d 82 16 2a 2e 67 6f 6f 67 6c 65 2d  s.com..*.google-
    [00:01:21.702,575] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 0a40:  61 6e 61 6c 79 74 69 63 73 2e 63 6f 6d 82 0a 67  analytics.com..g
    [00:01:21.720,031] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 0a50:  6f 6f 67 6c 65 2e 63 6f 6d 82 12 67 6f 6f 67 6c  oogle.com..googl
    [00:01:21.737,518] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 0a60:  65 63 6f 6d 6d 65 72 63 65 2e 63 6f 6d 82 14 2a  ecommerce.com..*
    [00:01:21.754,974] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 0a70:  2e 67 6f 6f 67 6c 65 63 6f 6d 6d 65 72 63 65 2e  .googlecommerce.
    [00:01:21.772,460] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 0a80:  63 6f 6d 82 08 67 67 70 68 74 2e 63 6e 82 0a 2a  com..ggpht.cn..*
    [00:01:21.789,916] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 0a90:  2e 67 67 70 68 74 2e 63 6e 82 0a 75 72 63 68 69  .ggpht.cn..urchi
    [00:01:21.807,403] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 0aa0:  6e 2e 63 6f 6d 82 0c 2a 2e 75 72 63 68 69 6e 2e  n.com..*.urchin.
    [00:01:21.824,859] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 0ab0:  63 6f 6d 82 08 79 6f 75 74 75 2e 62 65 82 0b 79  com..youtu.be..y
    [00:01:21.842,315] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 0ac0:  6f 75 74 75 62 65 2e 63 6f 6d 82 0d 2a 2e 79 6f  outube.com..*.yo
    [00:01:21.859,802] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 0ad0:  75 74 75 62 65 2e 63 6f 6d 82 11 6d 75 73 69 63  utube.com..music
    [00:01:21.877,258] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 0ae0:  2e 79 6f 75 74 75 62 65 2e 63 6f 6d 82 13 2a 2e  .youtube.com..*.
    [00:01:21.894,744] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 0af0:  6d 75 73 69 63 2e 79 6f 75 74 75 62 65 2e 63 6f  music.youtube.co
    [00:01:21.912,200] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 0b00:  6d 82 14 79 6f 75 74 75 62 65 65 64 75 63 61 74  m..youtubeeducat
    [00:01:21.929,687] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 0b10:  69 6f 6e 2e 63 6f 6d 82 16 2a 2e 79 6f 75 74 75  ion.com..*.youtu
    [00:01:21.947,143] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 0b20:  62 65 65 64 75 63 61 74 69 6f 6e 2e 63 6f 6d 82  beeducation.com.
    [00:01:21.964,630] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 0b30:  0f 79 6f 75 74 75 62 65 6b 69 64 73 2e 63 6f 6d  .youtubekids.com
    [00:01:21.982,086] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 0b40:  82 11 2a 2e 79 6f 75 74 75 62 65 6b 69 64 73 2e  ..*.youtubekids.
    [00:01:21.999,572] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 0b50:  63 6f 6d 82 05 79 74 2e 62 65 82 07 2a 2e 79 74  com..yt.be..*.yt
    [00:01:22.017,028] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 0b60:  2e 62 65 82 1a 61 6e 64 72 6f 69 64 2e 63 6c 69  .be..android.cli
    [00:01:22.034,515] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 0b70:  65 6e 74 73 2e 67 6f 6f 67 6c 65 2e 63 6f 6d 82  ents.google.com.
    [00:01:22.052,825] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 0b80:  13 2a 2e 61 6e 64 72 6f 69 64 2e 67 6f 6f 67 6c  .*.android.googl
    [00:01:22.070,312] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 0b90:  65 2e 63 6e 82 12 2a 2e 63 68 72 6f 6d 65 2e 67  e.cn..*.chrome.g
    [00:01:22.087,799] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 0ba0:  6f 6f 67 6c 65 2e 63 6e 82 16 2a 2e 64 65 76 65  oogle.cn..*.deve
    [00:01:22.105,255] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 0bb0:  6c 6f 70 65 72 73 2e 67 6f 6f 67 6c 65 2e 63 6e  lopers.google.cn
    [00:01:22.122,741] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 0bc0:  82 15 2a 2e 61 69 73 74 75 64 69 6f 2e 67 6f 6f  ..*.aistudio.goo
    [00:01:22.140,197] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 0bd0:  67 6c 65 2e 63 6f 6d 30 13 06 03 55 1d 20 04 0c  gle.com0...U. ..
    [00:01:22.157,684] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 0be0:  30 0a 30 08 06 06 67 81 0c 01 02 01 30 36 06 03  0.0...g.....06..
    [00:01:22.175,170] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 0bf0:  55 1d 1f 04 2f 30 2d 30 2b a0 29 a0 27 86 25 68  U.../0-0+.).'.%h
    [00:01:22.192,626] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 0c00:  74 74 70 3a 2f 2f 63 2e 70 6b 69 2e 67 6f 6f 67  ttp://c.pki.goog
    [00:01:22.210,113] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 0c10:  2f 77 72 32 2f 6f 42 46 59 59 61 68 7a 67 56 49  /wr2/oBFYYahzgVI
    [00:01:22.227,569] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 0c20:  2e 63 72 6c 30 82 01 04 06 0a 2b 06 01 04 01 d6  .crl0.....+.....
    [00:01:22.245,056] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 0c30:  79 02 04 02 04 81 f5 04 81 f2 00 f0 00 76 00 12  y............v..
    [00:01:22.262,512] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 0c40:  f1 4e 34 bd 53 72 4c 84 06 19 c3 8f 3f 7a 13 f8  .N4.SrL.....?z..
    [00:01:22.279,998] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 0c50:  e7 b5 62 87 88 9c 6d 30 05 84 eb e5 86 26 3a 00  ..b...m0.....&:.
    [00:01:22.297,485] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 0c60:  00 01 96 c3 e0 5c f7 00 00 04 03 00 47 30 45 02  .....\......G0E.
    [00:01:22.314,941] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 0c70:  20 1c e0 9b 52 a9 80 66 96 5d 3c ac 95 5f 89 00   ...R..f.]<.._..
    [00:01:22.332,397] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 0c80:  56 ee ff 83 af d8 57 81 cb e1 c4 4d 54 bb 98 49  V.....W....MT..I
    [00:01:22.349,884] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 0c90:  61 02 21 00 e9 6c 7d ed 74 7d 27 7d 77 1a 50 49  a.!..l}.t}'}w.PI
    [00:01:22.367,340] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 0ca0:  71 9a be fd 48 96 d2 26 08 d1 cb 0a 61 a9 d8 19  q...H..&....a...
    [00:01:22.384,796] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 0cb0:  a9 f4 1b 3c 00 76 00 cc fb 0f 6a 85 71 09 65 fe  ...<.v....j.q.e.
    [00:01:22.402,282] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 0cc0:  95 9b 53 ce e9 b2 7c 22 e9 85 5c 0d 97 8d b6 a9  ..S...|"..\.....
    [00:01:22.419,738] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 0cd0:  7e 54 c0 fe 4c 0d b0 00 00 01 96 c3 e0 61 73 00  ~T..L........as.
    [00:01:22.437,225] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 0ce0:  00 04 03 00 47 30 45 02 21 00 a5 49 83 b5 26 2f  ....G0E.!..I..&/
    [00:01:22.454,711] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 0cf0:  0b db a4 e4 3a eb 5b 00 de 0c 11 33 0d 3a 18 5a  ....:.[....3.:.Z
    [00:01:22.472,167] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 0d00:  04 d9 d9 3e 3b 09 6e f6 f5 eb 02 20 27 dc ba ac  ...>;.n.... '...
    [00:01:22.489,654] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 0d10:  81 f1 f9 aa ce d2 ac eb 49 d4 dc 0a 69 8a 27 73  ........I...i.'s
    [00:01:22.507,110] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 0d20:  92 f0 cd b3 bf 68 08 7b 87 cc 73 19 30 0d 06 09  .....h.{..s.0...
    [00:01:22.524,597] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 0d30:  2a 86 48 86 f7 0d 01 01 0b 05 00 03 82 01 01 00  *.H.............
    [00:01:22.542,083] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 0d40:  26 13 af 72 da b9 21 65 71 d4 c0 0f 3e 95 5f 24  &..r..!eq...>._$
    [00:01:22.559,539] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 0d50:  ac 98 6f 3b 55 ac 27 0e 1b b5 a1 21 6e 77 ba dc  ..o;U.'....!nw..
    [00:01:22.577,026] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 0d60:  f6 73 1a 2c e9 93 62 bf 99 6f e1 3c 66 a6 da 60  .s.,..b..o.<f..`
    [00:01:22.594,482] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 0d70:  97 fd c9 a1 1d 8c 3e ab 60 c1 1f 87 09 ea 9d 33  ......>.`......3
    [00:01:22.611,968] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 0d80:  54 03 69 39 76 1b db 91 d1 d7 97 1a 36 3a 6c 9f  T.i9v.......6:l.
    [00:01:22.629,425] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 0d90:  01 dd 47 59 5c 47 ee 6f 12 b3 bb bd 48 da b9 4e  ..GY\G.o....H..N
    [00:01:22.646,911] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 0da0:  85 6c 62 54 a1 5e b9 2f 64 21 0b c8 30 24 1f e1  .lbT.^./d!..0$..
    [00:01:22.664,398] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 0db0:  b1 8e 0e 9f 5f d8 ed e3 72 e1 27 81 33 7f 68 ef  ...._...r.'.3.h.
    [00:01:22.681,854] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 0dc0:  6b 81 de cf 5c cd 87 7f 68 b5 af a3 7f 4a 4c 1e  k...\...h....JL.
    [00:01:22.699,340] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 0dd0:  61 74 a9 7c 35 f9 e0 35 b3 9e 91 b4 86 b1 f4 45  at.|5..5.......E
    [00:01:22.716,796] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 0de0:  4f 27 9b 5f 16 49 fe 59 e7 ac bb c3 e7 1e 73 3b  O'._.I.Y......s;
    [00:01:22.734,252] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 0df0:  af 92 17 46 15 f7 4e 44 f4 94 a8 30 f5 c1 dd f8  ...F..ND...0....
    [00:01:22.751,739] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 0e00:  62 29 26 1e a7 7f f6 d2 8c 27 22 10 40 0d ea 21  b)&......'".@..!
    [00:01:22.769,195] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 0e10:  4b f2 f1 82 2d e3 51 0d 45 a8 df 38 52 56 ba b2  K...-.Q.E..8RV..
    [00:01:22.786,682] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 0e20:  57 a5 8f 66 c4 08 4f 81 67 08 27 5e 4a 8e 2b 65  W..f..O.g.'^J.+e
    [00:01:22.804,138] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 0e30:  90 0a d4 70 e3 34 56 b9 6f 4e 43 4f 3c 5b 89 05  ...p.4V.oNCO<[..
    [00:01:22.821,624] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 0e40:  00 05 0f 30 82 05 0b 30 82 02 f3 a0 03 02 01 02  ...0...0........
    [00:01:22.839,111] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 0e50:  02 10 7f f0 05 a0 7c 4c de d1 00 ad 9d 66 a5 10  ......|L.....f..
    [00:01:22.856,567] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 0e60:  7b 98 30 0d 06 09 2a 86 48 86 f7 0d 01 01 0b 05  {.0...*.H.......
    [00:01:22.874,053] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 0e70:  00 30 47 31 0b 30 09 06 03 55 04 06 13 02 55 53  .0G1.0...U....US
    [00:01:22.891,540] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 0e80:  31 22 30 20 06 03 55 04 0a 13 19 47 6f 6f 67 6c  1"0 ..U....Googl
    [00:01:22.908,996] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 0e90:  65 20 54 72 75 73 74 20 53 65 72 76 69 63 65 73  e Trust Services
    [00:01:22.926,483] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 0ea0:  20 4c 4c 43 31 14 30 12 06 03 55 04 03 13 0b 47   LLC1.0...U....G
    [00:01:22.943,969] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 0eb0:  54 53 20 52 6f 6f 74 20 52 31 30 1e 17 0d 32 33  TS Root R10...23
    [00:01:22.961,425] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 0ec0:  31 32 31 33 30 39 30 30 30 30 5a 17 0d 32 39 30  1213090000Z..290
    [00:01:22.978,912] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 0ed0:  32 32 30 31 34 30 30 30 30 5a 30 3b 31 0b 30 09  220140000Z0;1.0.
    [00:01:22.996,368] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 0ee0:  06 03 55 04 06 13 02 55 53 31 1e 30 1c 06 03 55  ..U....US1.0...U
    [00:01:23.013,854] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 0ef0:  04 0a 13 15 47 6f 6f 67 6c 65 20 54 72 75 73 74  ....Google Trust
    [00:01:23.031,311] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 0f00:  20 53 65 72 76 69 63 65 73 31 0c 30 0a 06 03 55   Services1.0...U
    [00:01:23.048,797] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 0f10:  04 03 13 03 57 52 32 30 82 01 22 30 0d 06 09 2a  ....WR20.."0...*
    [00:01:23.066,284] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 0f20:  86 48 86 f7 0d 01 01 01 05 00 03 82 01 0f 00 30  .H.............0
    [00:01:23.083,770] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 0f30:  82 01 0a 02 82 01 01 00 a9 ff 9c 7f 45 1e 70 a8  ............E.p.
    [00:01:23.101,257] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 0f40:  53 9f ca d9 e5 0d de 46 57 57 7d bc 8f 9a 5a ac  S......FWW}...Z.
    [00:01:23.118,743] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 0f50:  46 f1 84 9a bb 91 db c9 fb 2f 01 fb 92 09 00 16  F......../......
    [00:01:23.136,230] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 0f60:  5e a0 1c f8 c1 ab f9 78 2f 4a cc d8 85 a2 d8 59  ^......x/J.....Y
    [00:01:23.153,686] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 0f70:  3c 0e d3 18 fb b1 f5 24 0d 26 ee b6 5b 64 76 7c  <......$.&..[dv|
    [00:01:23.171,173] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 0f80:  14 c7 2f 7a ce a8 4c b7 f4 d9 08 fc df 87 23 35  ../z..L.......#5
    [00:01:23.188,629] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 0f90:  20 a8 e2 69 e2 8c 4e 3f b1 59 fa 60 a2 1e b3 c9   ..i..N?.Y.`....
    [00:01:23.206,115] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 0fa0:  20 53 19 82 ca 36 53 6d 60 4d e9 00 91 fc 76 8d   S...6Sm`M....v.
    [00:01:23.223,602] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 0fb0:  5c 08 0f 0a c2 dc f1 73 6b c5 13 6e 0a 4f 7a c2  \......sk..n.Oz.
    [00:01:23.241,088] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 0fc0:  f2 02 1c 2e b4 63 83 da 31 f6 2d 75 30 b2 fb ab  .....c..1.-u0...
    [00:01:23.258,575] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 0fd0:  c2 6e db a9 c0 0e b9 f9 67 d4 c3 25 57 74 eb 05  .n......g..%Wt..
    [00:01:23.276,062] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 0fe0:  b4 e9 8e b5 de 28 cd cc 7a 14 e4 71 03 cb 4d 61  .....(..z..q..Ma
    [00:01:23.293,518] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 0ff0:  2e 61 57 c5 19 a9 0b 98 84 1a e8 79 29 d9 b2 8d  .aW........y)...
    [00:01:23.310,791] <inf> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3239: handshake message: msglen = 6326, type = 11, hslen = 6326
    [00:01:23.324,829] <inf> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3328: sole handshake fragment: 6326, 0..6326 of 6326
    [00:01:23.338,745] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: dumping 'reassembled record' (6331 bytes)
    [00:01:23.353,546] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 0000:  16 03 03 18 b6 0b 00 18 b2 00 18 af 00 0e 31 30  ..............10
    [00:01:23.371,002] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 0010:  82 0e 2d 30 82 0d 15 a0 03 02 01 02 02 10 66 86  ..-0..........f.
    [00:01:23.388,488] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 0020:  f0 7e 70 d7 df c2 09 4c b8 5a 34 d6 e3 d8 30 0d  .~p....L.Z4...0.
    [00:01:23.405,975] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 0030:  06 09 2a 86 48 86 f7 0d 01 01 0b 05 00 30 3b 31  ..*.H........0;1
    [00:01:23.423,461] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 0040:  0b 30 09 06 03 55 04 06 13 02 55 53 31 1e 30 1c  .0...U....US1.0.
    [00:01:23.440,948] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 0050:  06 03 55 04 0a 13 15 47 6f 6f 67 6c 65 20 54 72  ..U....Google Tr
    [00:01:23.458,435] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 0060:  75 73 74 20 53 65 72 76 69 63 65 73 31 0c 30 0a  ust Services1.0.
    [00:01:23.475,891] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 0070:  06 03 55 04 03 13 03 57 52 32 30 1e 17 0d 32 35  ..U....WR20...25
    [00:01:23.493,377] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 0080:  30 35 31 32 30 38 34 32 35 38 5a 17 0d 32 35 30  0512084258Z..250
    [00:01:23.510,833] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 0090:  38 30 34 30 38 34 32 35 37 5a 30 17 31 15 30 13  804084257Z0.1.0.
    [00:01:23.528,320] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 00a0:  06 03 55 04 03 0c 0c 2a 2e 67 6f 6f 67 6c 65 2e  ..U....*.google.
    [00:01:23.545,806] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 00b0:  63 6f 6d 30 59 30 13 06 07 2a 86 48 ce 3d 02 01  com0Y0...*.H.=..
    [00:01:23.563,293] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 00c0:  06 08 2a 86 48 ce 3d 03 01 07 03 42 00 04 0a a6  ..*.H.=....B....
    [00:01:23.580,780] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 00d0:  db af e0 06 99 b8 6f 52 89 c4 25 83 94 32 5c 27  ......oR..%..2\'
    [00:01:23.598,236] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 00e0:  b9 94 42 1d 87 49 f5 1d c7 c8 2e 2f 3b 23 d2 df  ..B..I...../;#..
    [00:01:23.615,722] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 00f0:  e9 8c 33 79 94 86 0e 25 80 b3 ae 8e 72 22 5d ba  ..3y...%....r"].
    [00:01:23.633,209] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 0100:  ef ce 7c 6f 30 55 e7 6c 1d 4b 02 70 fa 9d a3 82  ..|o0U.l.K.p....
    [00:01:23.650,695] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 0110:  0c 1a 30 82 0c 16 30 0e 06 03 55 1d 0f 01 01 ff  ..0...0...U.....
    [00:01:23.668,182] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 0120:  04 04 03 02 07 80 30 13 06 03 55 1d 25 04 0c 30  ......0...U.%..0
    [00:01:23.685,638] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 0130:  0a 06 08 2b 06 01 05 05 07 03 01 30 0c 06 03 55  ...+.......0...U
    [00:01:23.703,125] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 0140:  1d 13 01 01 ff 04 02 30 00 30 1d 06 03 55 1d 0e  .......0.0...U..
    [00:01:23.720,611] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 0150:  04 16 04 14 ad 60 2e a1 68 d6 19 19 03 fa a3 0e  .....`..h.......
    [00:01:23.738,067] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 0160:  ad d6 24 d8 fa 28 88 3e 30 1f 06 03 55 1d 23 04  ..$..(.>0...U.#.
    [00:01:23.755,554] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 0170:  18 30 16 80 14 de 1b 1e ed 79 15 d4 3e 37 24 c3  .0.......y..>7$.
    [00:01:23.773,040] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 0180:  21 bb ec 34 39 6d 42 b2 30 30 58 06 08 2b 06 01  !..49mB.00X..+..
    [00:01:23.790,496] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 0190:  05 05 07 01 01 04 4c 30 4a 30 21 06 08 2b 06 01  ......L0J0!..+..
    [00:01:23.807,983] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 01a0:  05 05 07 30 01 86 15 68 74 74 70 3a 2f 2f 6f 2e  ...0...http://o.
    [00:01:23.825,469] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 01b0:  70 6b 69 2e 67 6f 6f 67 2f 77 72 32 30 25 06 08  pki.goog/wr20%..
    [00:01:23.842,956] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 01c0:  2b 06 01 05 05 07 30 02 86 19 68 74 74 70 3a 2f  +.....0...http:/
    [00:01:23.860,412] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 01d0:  2f 69 2e 70 6b 69 2e 67 6f 6f 67 2f 77 72 32 2e  /i.pki.goog/wr2.
    [00:01:23.877,899] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 01e0:  63 72 74 30 82 09 f0 06 03 55 1d 11 04 82 09 e7  crt0.....U......
    [00:01:23.895,355] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 01f0:  30 82 09 e3 82 0c 2a 2e 67 6f 6f 67 6c 65 2e 63  0.....*.google.c
    [00:01:23.912,841] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 0200:  6f 6d 82 16 2a 2e 61 70 70 65 6e 67 69 6e 65 2e  om..*.appengine.
    [00:01:23.930,297] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 0210:  67 6f 6f 67 6c 65 2e 63 6f 6d 82 09 2a 2e 62 64  google.com..*.bd
    [00:01:23.947,784] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 0220:  6e 2e 64 65 76 82 15 2a 2e 6f 72 69 67 69 6e 2d  n.dev..*.origin-
    [00:01:23.965,270] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 0230:  74 65 73 74 2e 62 64 6e 2e 64 65 76 82 12 2a 2e  test.bdn.dev..*.
    [00:01:23.982,727] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 0240:  63 6c 6f 75 64 2e 67 6f 6f 67 6c 65 2e 63 6f 6d  cloud.google.com
    [00:01:24.000,213] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 0250:  82 18 2a 2e 63 72 6f 77 64 73 6f 75 72 63 65 2e  ..*.crowdsource.
    [00:01:24.017,669] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 0260:  67 6f 6f 67 6c 65 2e 63 6f 6d 82 18 2a 2e 64 61  google.com..*.da
    [00:01:24.035,125] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 0270:  74 61 63 6f 6d 70 75 74 65 2e 67 6f 6f 67 6c 65  tacompute.google
    [00:01:24.052,612] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 0280:  2e 63 6f 6d 82 0b 2a 2e 67 6f 6f 67 6c 65 2e 63  .com..*.google.c
    [00:01:24.070,068] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 0290:  61 82 0b 2a 2e 67 6f 6f 67 6c 65 2e 63 6c 82 0e  a..*.google.cl..
    [00:01:24.087,554] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 02a0:  2a 2e 67 6f 6f 67 6c 65 2e 63 6f 2e 69 6e 82 0e  *.google.co.in..
    [00:01:24.105,010] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 02b0:  2a 2e 67 6f 6f 67 6c 65 2e 63 6f 2e 6a 70 82 0e  *.google.co.jp..
    [00:01:24.122,497] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 02c0:  2a 2e 67 6f 6f 67 6c 65 2e 63 6f 2e 75 6b 82 0f  *.google.co.uk..
    [00:01:24.139,953] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 02d0:  2a 2e 67 6f 6f 67 6c 65 2e 63 6f 6d 2e 61 72 82  *.google.com.ar.
    [00:01:24.157,409] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 02e0:  0f 2a 2e 67 6f 6f 67 6c 65 2e 63 6f 6d 2e 61 75  .*.google.com.au
    [00:01:24.174,896] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 02f0:  82 0f 2a 2e 67 6f 6f 67 6c 65 2e 63 6f 6d 2e 62  ..*.google.com.b
    [00:01:24.192,352] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 0300:  72 82 0f 2a 2e 67 6f 6f 67 6c 65 2e 63 6f 6d 2e  r..*.google.com.
    [00:01:24.209,808] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 0310:  63 6f 82 0f 2a 2e 67 6f 6f 67 6c 65 2e 63 6f 6d  co..*.google.com
    [00:01:24.227,294] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 0320:  2e 6d 78 82 0f 2a 2e 67 6f 6f 67 6c 65 2e 63 6f  .mx..*.google.co
    [00:01:24.244,781] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 0330:  6d 2e 74 72 82 0f 2a 2e 67 6f 6f 67 6c 65 2e 63  m.tr..*.google.c
    [00:01:24.262,237] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 0340:  6f 6d 2e 76 6e 82 0b 2a 2e 67 6f 6f 67 6c 65 2e  om.vn..*.google.
    [00:01:24.279,724] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 0350:  64 65 82 0b 2a 2e 67 6f 6f 67 6c 65 2e 65 73 82  de..*.google.es.
    [00:01:24.297,210] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 0360:  0b 2a 2e 67 6f 6f 67 6c 65 2e 66 72 82 0b 2a 2e  .*.google.fr..*.
    [00:01:24.314,666] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 0370:  67 6f 6f 67 6c 65 2e 68 75 82 0b 2a 2e 67 6f 6f  google.hu..*.goo
    [00:01:24.332,153] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 0380:  67 6c 65 2e 69 74 82 0b 2a 2e 67 6f 6f 67 6c 65  gle.it..*.google
    [00:01:24.349,639] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 0390:  2e 6e 6c 82 0b 2a 2e 67 6f 6f 67 6c 65 2e 70 6c  .nl..*.google.pl
    [00:01:24.367,095] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 03a0:  82 0b 2a 2e 67 6f 6f 67 6c 65 2e 70 74 82 0f 2a  ..*.google.pt..*
    [00:01:24.384,552] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 03b0:  2e 67 6f 6f 67 6c 65 61 70 69 73 2e 63 6e 82 11  .googleapis.cn..
    [00:01:24.402,038] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 03c0:  2a 2e 67 6f 6f 67 6c 65 76 69 64 65 6f 2e 63 6f  *.googlevideo.co
    [00:01:24.419,494] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 03d0:  6d 82 0c 2a 2e 67 73 74 61 74 69 63 2e 63 6e 82  m..*.gstatic.cn.
    [00:01:24.436,981] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 03e0:  10 2a 2e 67 73 74 61 74 69 63 2d 63 6e 2e 63 6f  .*.gstatic-cn.co
    [00:01:24.454,437] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 03f0:  6d 82 0f 67 6f 6f 67 6c 65 63 6e 61 70 70 73 2e  m..googlecnapps.
    [00:01:24.471,923] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 0400:  63 6e 82 11 2a 2e 67 6f 6f 67 6c 65 63 6e 61 70  cn..*.googlecnap
    [00:01:24.489,379] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 0410:  70 73 2e 63 6e 82 11 67 6f 6f 67 6c 65 61 70 70  ps.cn..googleapp
    [00:01:24.506,866] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 0420:  73 2d 63 6e 2e 63 6f 6d 82 13 2a 2e 67 6f 6f 67  s-cn.com..*.goog
    [00:01:24.524,322] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 0430:  6c 65 61 70 70 73 2d 63 6e 2e 63 6f 6d 82 0c 67  leapps-cn.com..g
    [00:01:24.541,809] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 0440:  6b 65 63 6e 61 70 70 73 2e 63 6e 82 0e 2a 2e 67  kecnapps.cn..*.g
    [00:01:24.559,265] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 0450:  6b 65 63 6e 61 70 70 73 2e 63 6e 82 12 67 6f 6f  kecnapps.cn..goo
    [00:01:24.576,751] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 0460:  67 6c 65 64 6f 77 6e 6c 6f 61 64 73 2e 63 6e 82  gledownloads.cn.
    [00:01:24.594,207] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 0470:  14 2a 2e 67 6f 6f 67 6c 65 64 6f 77 6e 6c 6f 61  .*.googledownloa
    [00:01:24.611,694] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 0480:  64 73 2e 63 6e 82 10 72 65 63 61 70 74 63 68 61  ds.cn..recaptcha
    [00:01:24.629,150] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 0490:  2e 6e 65 74 2e 63 6e 82 12 2a 2e 72 65 63 61 70  .net.cn..*.recap
    [00:01:24.646,636] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 04a0:  74 63 68 61 2e 6e 65 74 2e 63 6e 82 10 72 65 63  tcha.net.cn..rec
    [00:01:24.664,093] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 04b0:  61 70 74 63 68 61 2d 63 6e 2e 6e 65 74 82 12 2a  aptcha-cn.net..*
    [00:01:24.681,549] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 04c0:  2e 72 65 63 61 70 74 63 68 61 2d 63 6e 2e 6e 65  .recaptcha-cn.ne
    [00:01:24.699,035] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 04d0:  74 82 0b 77 69 64 65 76 69 6e 65 2e 63 6e 82 0d  t..widevine.cn..
    [00:01:24.716,491] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 04e0:  2a 2e 77 69 64 65 76 69 6e 65 2e 63 6e 82 11 61  *.widevine.cn..a
    [00:01:24.733,978] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 04f0:  6d 70 70 72 6f 6a 65 63 74 2e 6f 72 67 2e 63 6e  mpproject.org.cn
    [00:01:24.751,434] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 0500:  82 13 2a 2e 61 6d 70 70 72 6f 6a 65 63 74 2e 6f  ..*.ampproject.o
    [00:01:24.768,920] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 0510:  72 67 2e 63 6e 82 11 61 6d 70 70 72 6f 6a 65 63  rg.cn..ampprojec
    [00:01:24.786,376] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 0520:  74 2e 6e 65 74 2e 63 6e 82 13 2a 2e 61 6d 70 70  t.net.cn..*.ampp
    [00:01:24.803,863] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 0530:  72 6f 6a 65 63 74 2e 6e 65 74 2e 63 6e 82 17 67  roject.net.cn..g
    [00:01:24.821,319] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 0540:  6f 6f 67 6c 65 2d 61 6e 61 6c 79 74 69 63 73 2d  oogle-analytics-
    [00:01:24.838,806] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 0550:  63 6e 2e 63 6f 6d 82 19 2a 2e 67 6f 6f 67 6c 65  cn.com..*.google
    [00:01:24.856,262] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 0560:  2d 61 6e 61 6c 79 74 69 63 73 2d 63 6e 2e 63 6f  -analytics-cn.co
    [00:01:24.873,748] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 0570:  6d 82 17 67 6f 6f 67 6c 65 61 64 73 65 72 76 69  m..googleadservi
    [00:01:24.891,235] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 0580:  63 65 73 2d 63 6e 2e 63 6f 6d 82 19 2a 2e 67 6f  ces-cn.com..*.go
    [00:01:24.908,691] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 0590:  6f 67 6c 65 61 64 73 65 72 76 69 63 65 73 2d 63  ogleadservices-c
    [00:01:24.926,177] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 05a0:  6e 2e 63 6f 6d 82 11 67 6f 6f 67 6c 65 76 61 64  n.com..googlevad
    [00:01:24.943,634] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 05b0:  73 2d 63 6e 2e 63 6f 6d 82 13 2a 2e 67 6f 6f 67  s-cn.com..*.goog
    [00:01:24.961,120] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 05c0:  6c 65 76 61 64 73 2d 63 6e 2e 63 6f 6d 82 11 67  levads-cn.com..g
    [00:01:24.978,576] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 05d0:  6f 6f 67 6c 65 61 70 69 73 2d 63 6e 2e 63 6f 6d  oogleapis-cn.com
    [00:01:24.996,063] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 05e0:  82 13 2a 2e 67 6f 6f 67 6c 65 61 70 69 73 2d 63  ..*.googleapis-c
    [00:01:25.013,549] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 05f0:  6e 2e 63 6f 6d 82 15 67 6f 6f 67 6c 65 6f 70 74  n.com..googleopt
    [00:01:25.031,005] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 0600:  69 6d 69 7a 65 2d 63 6e 2e 63 6f 6d 82 17 2a 2e  imize-cn.com..*.
    [00:01:25.048,461] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 0610:  67 6f 6f 67 6c 65 6f 70 74 69 6d 69 7a 65 2d 63  googleoptimize-c
    [00:01:25.065,948] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 0620:  6e 2e 63 6f 6d 82 12 64 6f 75 62 6c 65 63 6c 69  n.com..doublecli
    [00:01:25.083,404] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 0630:  63 6b 2d 63 6e 2e 6e 65 74 82 14 2a 2e 64 6f 75  ck-cn.net..*.dou
    [00:01:25.100,891] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 0640:  62 6c 65 63 6c 69 63 6b 2d 63 6e 2e 6e 65 74 82  bleclick-cn.net.
    [00:01:25.118,347] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 0650:  18 2a 2e 66 6c 73 2e 64 6f 75 62 6c 65 63 6c 69  .*.fls.doublecli
    [00:01:25.135,833] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 0660:  63 6b 2d 63 6e 2e 6e 65 74 82 16 2a 2e 67 2e 64  ck-cn.net..*.g.d
    [00:01:25.153,289] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 0670:  6f 75 62 6c 65 63 6c 69 63 6b 2d 63 6e 2e 6e 65  oubleclick-cn.ne
    [00:01:25.170,776] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 0680:  74 82 0e 64 6f 75 62 6c 65 63 6c 69 63 6b 2e 63  t..doubleclick.c
    [00:01:25.188,262] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 0690:  6e 82 10 2a 2e 64 6f 75 62 6c 65 63 6c 69 63 6b  n..*.doubleclick
    [00:01:25.205,718] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 06a0:  2e 63 6e 82 14 2a 2e 66 6c 73 2e 64 6f 75 62 6c  .cn..*.fls.doubl
    [00:01:25.223,205] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 06b0:  65 63 6c 69 63 6b 2e 63 6e 82 12 2a 2e 67 2e 64  eclick.cn..*.g.d
    [00:01:25.240,661] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 06c0:  6f 75 62 6c 65 63 6c 69 63 6b 2e 63 6e 82 11 64  oubleclick.cn..d
    [00:01:25.258,148] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 06d0:  61 72 74 73 65 61 72 63 68 2d 63 6e 2e 6e 65 74  artsearch-cn.net
    [00:01:25.275,604] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 06e0:  82 13 2a 2e 64 61 72 74 73 65 61 72 63 68 2d 63  ..*.dartsearch-c
    [00:01:25.293,090] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 06f0:  6e 2e 6e 65 74 82 1d 67 6f 6f 67 6c 65 74 72 61  n.net..googletra
    [00:01:25.310,546] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 0700:  76 65 6c 61 64 73 65 72 76 69 63 65 73 2d 63 6e  veladservices-cn
    [00:01:25.328,033] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 0710:  2e 63 6f 6d 82 1f 2a 2e 67 6f 6f 67 6c 65 74 72  .com..*.googletr
    [00:01:25.345,489] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 0720:  61 76 65 6c 61 64 73 65 72 76 69 63 65 73 2d 63  aveladservices-c
    [00:01:25.362,976] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 0730:  6e 2e 63 6f 6d 82 18 67 6f 6f 67 6c 65 74 61 67  n.com..googletag
    [00:01:25.380,432] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 0740:  73 65 72 76 69 63 65 73 2d 63 6e 2e 63 6f 6d 82  services-cn.com.
    [00:01:25.397,918] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 0750:  1a 2a 2e 67 6f 6f 67 6c 65 74 61 67 73 65 72 76  .*.googletagserv
    [00:01:25.415,374] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 0760:  69 63 65 73 2d 63 6e 2e 63 6f 6d 82 17 67 6f 6f  ices-cn.com..goo
    [00:01:25.432,830] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 0770:  67 6c 65 74 61 67 6d 61 6e 61 67 65 72 2d 63 6e  gletagmanager-cn
    [00:01:25.450,317] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 0780:  2e 63 6f 6d 82 19 2a 2e 67 6f 6f 67 6c 65 74 61  .com..*.googleta
    [00:01:25.467,773] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 0790:  67 6d 61 6e 61 67 65 72 2d 63 6e 2e 63 6f 6d 82  gmanager-cn.com.
    [00:01:25.485,260] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 07a0:  18 67 6f 6f 67 6c 65 73 79 6e 64 69 63 61 74 69  .googlesyndicati
    [00:01:25.502,716] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 07b0:  6f 6e 2d 63 6e 2e 63 6f 6d 82 1a 2a 2e 67 6f 6f  on-cn.com..*.goo
    [00:01:25.520,202] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 07c0:  67 6c 65 73 79 6e 64 69 63 61 74 69 6f 6e 2d 63  glesyndication-c
    [00:01:25.537,658] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 07d0:  6e 2e 63 6f 6d 82 24 2a 2e 73 61 66 65 66 72 61  n.com.$*.safefra
    [00:01:25.555,145] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 07e0:  6d 65 2e 67 6f 6f 67 6c 65 73 79 6e 64 69 63 61  me.googlesyndica
    [00:01:25.572,601] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 07f0:  74 69 6f 6e 2d 63 6e 2e 63 6f 6d 82 16 61 70 70  tion-cn.com..app
    [00:01:25.590,087] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 0800:  2d 6d 65 61 73 75 72 65 6d 65 6e 74 2d 63 6e 2e  -measurement-cn.
    [00:01:25.607,543] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 0810:  63 6f 6d 82 18 2a 2e 61 70 70 2d 6d 65 61 73 75  com..*.app-measu
    [00:01:25.625,030] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 0820:  72 65 6d 65 6e 74 2d 63 6e 2e 63 6f 6d 82 0b 67  rement-cn.com..g
    [00:01:25.642,486] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 0830:  76 74 31 2d 63 6e 2e 63 6f 6d 82 0d 2a 2e 67 76  vt1-cn.com..*.gv
    [00:01:25.659,942] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 0840:  74 31 2d 63 6e 2e 63 6f 6d 82 0b 67 76 74 32 2d  t1-cn.com..gvt2-
    [00:01:25.677,429] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 0850:  63 6e 2e 63 6f 6d 82 0d 2a 2e 67 76 74 32 2d 63  cn.com..*.gvt2-c
    [00:01:25.694,885] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 0860:  6e 2e 63 6f 6d 82 0b 32 6d 64 6e 2d 63 6e 2e 6e  n.com..2mdn-cn.n
    [00:01:25.712,371] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 0870:  65 74 82 0d 2a 2e 32 6d 64 6e 2d 63 6e 2e 6e 65  et..*.2mdn-cn.ne
    [00:01:25.729,827] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 0880:  74 82 14 67 6f 6f 67 6c 65 66 6c 69 67 68 74 73  t..googleflights
    [00:01:25.747,314] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 0890:  2d 63 6e 2e 6e 65 74 82 16 2a 2e 67 6f 6f 67 6c  -cn.net..*.googl
    [00:01:25.764,770] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 08a0:  65 66 6c 69 67 68 74 73 2d 63 6e 2e 6e 65 74 82  eflights-cn.net.
    [00:01:25.782,257] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 08b0:  0c 61 64 6d 6f 62 2d 63 6e 2e 63 6f 6d 82 0e 2a  .admob-cn.com..*
    [00:01:25.799,713] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 08c0:  2e 61 64 6d 6f 62 2d 63 6e 2e 63 6f 6d 82 14 67  .admob-cn.com..g
    [00:01:25.817,199] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 08d0:  6f 6f 67 6c 65 73 61 6e 64 62 6f 78 2d 63 6e 2e  ooglesandbox-cn.
    [00:01:25.834,655] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 08e0:  63 6f 6d 82 16 2a 2e 67 6f 6f 67 6c 65 73 61 6e  com..*.googlesan
    [00:01:25.852,142] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 08f0:  64 62 6f 78 2d 63 6e 2e 63 6f 6d 82 1e 2a 2e 73  dbox-cn.com..*.s
    [00:01:25.869,598] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 0900:  61 66 65 6e 75 70 2e 67 6f 6f 67 6c 65 73 61 6e  afenup.googlesan
    [00:01:25.887,084] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 0910:  64 62 6f 78 2d 63 6e 2e 63 6f 6d 82 0d 2a 2e 67  dbox-cn.com..*.g
    [00:01:25.904,541] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 0920:  73 74 61 74 69 63 2e 63 6f 6d 82 14 2a 2e 6d 65  static.com..*.me
    [00:01:25.921,997] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 0930:  74 72 69 63 2e 67 73 74 61 74 69 63 2e 63 6f 6d  tric.gstatic.com
    [00:01:25.939,483] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 0940:  82 0a 2a 2e 67 76 74 31 2e 63 6f 6d 82 11 2a 2e  ..*.gvt1.com..*.
    [00:01:25.956,939] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 0950:  67 63 70 63 64 6e 2e 67 76 74 31 2e 63 6f 6d 82  gcpcdn.gvt1.com.
    [00:01:25.974,426] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 0960:  0a 2a 2e 67 76 74 32 2e 63 6f 6d 82 0e 2a 2e 67  .*.gvt2.com..*.g
    [00:01:25.991,882] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 0970:  63 70 2e 67 76 74 32 2e 63 6f 6d 82 10 2a 2e 75  cp.gvt2.com..*.u
    [00:01:26.009,338] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 0980:  72 6c 2e 67 6f 6f 67 6c 65 2e 63 6f 6d 82 16 2a  rl.google.com..*
    [00:01:26.026,824] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 0990:  2e 79 6f 75 74 75 62 65 2d 6e 6f 63 6f 6f 6b 69  .youtube-nocooki
    [00:01:26.044,311] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 09a0:  65 2e 63 6f 6d 82 0b 2a 2e 79 74 69 6d 67 2e 63  e.com..*.ytimg.c
    [00:01:26.061,767] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 09b0:  6f 6d 82 0a 61 69 2e 61 6e 64 72 6f 69 64 82 0b  om..ai.android..
    [00:01:26.079,254] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 09c0:  61 6e 64 72 6f 69 64 2e 63 6f 6d 82 0d 2a 2e 61  android.com..*.a
    [00:01:26.096,740] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 09d0:  6e 64 72 6f 69 64 2e 63 6f 6d 82 13 2a 2e 66 6c  ndroid.com..*.fl
    [00:01:26.114,196] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 09e0:  61 73 68 2e 61 6e 64 72 6f 69 64 2e 63 6f 6d 82  ash.android.com.
    [00:01:26.131,683] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 09f0:  04 67 2e 63 6e 82 06 2a 2e 67 2e 63 6e 82 04 67  .g.cn..*.g.cn..g
    [00:01:26.149,139] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 0a00:  2e 63 6f 82 06 2a 2e 67 2e 63 6f 82 06 67 6f 6f  .co..*.g.co..goo
    [00:01:26.166,625] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 0a10:  2e 67 6c 82 0a 77 77 77 2e 67 6f 6f 2e 67 6c 82  .gl..www.goo.gl.
    [00:01:26.184,082] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 0a20:  14 67 6f 6f 67 6c 65 2d 61 6e 61 6c 79 74 69 63  .google-analytic
    [00:01:26.201,568] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 0a30:  73 2e 63 6f 6d 82 16 2a 2e 67 6f 6f 67 6c 65 2d  s.com..*.google-
    [00:01:26.219,024] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 0a40:  61 6e 61 6c 79 74 69 63 73 2e 63 6f 6d 82 0a 67  analytics.com..g
    [00:01:26.236,480] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 0a50:  6f 6f 67 6c 65 2e 63 6f 6d 82 12 67 6f 6f 67 6c  oogle.com..googl
    [00:01:26.253,967] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 0a60:  65 63 6f 6d 6d 65 72 63 65 2e 63 6f 6d 82 14 2a  ecommerce.com..*
    [00:01:26.271,423] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 0a70:  2e 67 6f 6f 67 6c 65 63 6f 6d 6d 65 72 63 65 2e  .googlecommerce.
    [00:01:26.288,909] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 0a80:  63 6f 6d 82 08 67 67 70 68 74 2e 63 6e 82 0a 2a  com..ggpht.cn..*
    [00:01:26.306,365] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 0a90:  2e 67 67 70 68 74 2e 63 6e 82 0a 75 72 63 68 69  .ggpht.cn..urchi
    [00:01:26.323,822] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 0aa0:  6e 2e 63 6f 6d 82 0c 2a 2e 75 72 63 68 69 6e 2e  n.com..*.urchin.
    [00:01:26.341,308] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 0ab0:  63 6f 6d 82 08 79 6f 75 74 75 2e 62 65 82 0b 79  com..youtu.be..y
    [00:01:26.358,764] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 0ac0:  6f 75 74 75 62 65 2e 63 6f 6d 82 0d 2a 2e 79 6f  outube.com..*.yo
    [00:01:26.376,220] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 0ad0:  75 74 75 62 65 2e 63 6f 6d 82 11 6d 75 73 69 63  utube.com..music
    [00:01:26.393,707] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 0ae0:  2e 79 6f 75 74 75 62 65 2e 63 6f 6d 82 13 2a 2e  .youtube.com..*.
    [00:01:26.411,163] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 0af0:  6d 75 73 69 63 2e 79 6f 75 74 75 62 65 2e 63 6f  music.youtube.co
    [00:01:26.428,649] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 0b00:  6d 82 14 79 6f 75 74 75 62 65 65 64 75 63 61 74  m..youtubeeducat
    [00:01:26.446,105] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 0b10:  69 6f 6e 2e 63 6f 6d 82 16 2a 2e 79 6f 75 74 75  ion.com..*.youtu
    [00:01:26.463,592] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 0b20:  62 65 65 64 75 63 61 74 69 6f 6e 2e 63 6f 6d 82  beeducation.com.
    [00:01:26.481,048] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 0b30:  0f 79 6f 75 74 75 62 65 6b 69 64 73 2e 63 6f 6d  .youtubekids.com
    [00:01:26.498,535] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 0b40:  82 11 2a 2e 79 6f 75 74 75 62 65 6b 69 64 73 2e  ..*.youtubekids.
    [00:01:26.515,991] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 0b50:  63 6f 6d 82 05 79 74 2e 62 65 82 07 2a 2e 79 74  com..yt.be..*.yt
    [00:01:26.533,447] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 0b60:  2e 62 65 82 1a 61 6e 64 72 6f 69 64 2e 63 6c 69  .be..android.cli
    [00:01:26.550,933] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 0b70:  65 6e 74 73 2e 67 6f 6f 67 6c 65 2e 63 6f 6d 82  ents.google.com.
    [00:01:26.568,420] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 0b80:  13 2a 2e 61 6e 64 72 6f 69 64 2e 67 6f 6f 67 6c  .*.android.googl
    [00:01:26.585,876] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 0b90:  65 2e 63 6e 82 12 2a 2e 63 68 72 6f 6d 65 2e 67  e.cn..*.chrome.g
    [00:01:26.603,363] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 0ba0:  6f 6f 67 6c 65 2e 63 6e 82 16 2a 2e 64 65 76 65  oogle.cn..*.deve
    [00:01:26.620,819] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 0bb0:  6c 6f 70 65 72 73 2e 67 6f 6f 67 6c 65 2e 63 6e  lopers.google.cn
    [00:01:26.638,305] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 0bc0:  82 15 2a 2e 61 69 73 74 75 64 69 6f 2e 67 6f 6f  ..*.aistudio.goo
    [00:01:26.655,761] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 0bd0:  67 6c 65 2e 63 6f 6d 30 13 06 03 55 1d 20 04 0c  gle.com0...U. ..
    [00:01:26.673,248] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 0be0:  30 0a 30 08 06 06 67 81 0c 01 02 01 30 36 06 03  0.0...g.....06..
    [00:01:26.690,704] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 0bf0:  55 1d 1f 04 2f 30 2d 30 2b a0 29 a0 27 86 25 68  U.../0-0+.).'.%h
    [00:01:26.708,190] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 0c00:  74 74 70 3a 2f 2f 63 2e 70 6b 69 2e 67 6f 6f 67  ttp://c.pki.goog
    [00:01:26.725,646] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 0c10:  2f 77 72 32 2f 6f 42 46 59 59 61 68 7a 67 56 49  /wr2/oBFYYahzgVI
    [00:01:26.743,133] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 0c20:  2e 63 72 6c 30 82 01 04 06 0a 2b 06 01 04 01 d6  .crl0.....+.....
    [00:01:26.760,620] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 0c30:  79 02 04 02 04 81 f5 04 81 f2 00 f0 00 76 00 12  y............v..
    [00:01:26.778,076] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 0c40:  f1 4e 34 bd 53 72 4c 84 06 19 c3 8f 3f 7a 13 f8  .N4.SrL.....?z..
    [00:01:26.795,562] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 0c50:  e7 b5 62 87 88 9c 6d 30 05 84 eb e5 86 26 3a 00  ..b...m0.....&:.
    [00:01:26.813,018] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 0c60:  00 01 96 c3 e0 5c f7 00 00 04 03 00 47 30 45 02  .....\......G0E.
    [00:01:26.830,505] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 0c70:  20 1c e0 9b 52 a9 80 66 96 5d 3c ac 95 5f 89 00   ...R..f.]<.._..
    [00:01:26.847,961] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 0c80:  56 ee ff 83 af d8 57 81 cb e1 c4 4d 54 bb 98 49  V.....W....MT..I
    [00:01:26.865,447] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 0c90:  61 02 21 00 e9 6c 7d ed 74 7d 27 7d 77 1a 50 49  a.!..l}.t}'}w.PI
    [00:01:26.882,934] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 0ca0:  71 9a be fd 48 96 d2 26 08 d1 cb 0a 61 a9 d8 19  q...H..&....a...
    [00:01:26.900,390] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 0cb0:  a9 f4 1b 3c 00 76 00 cc fb 0f 6a 85 71 09 65 fe  ...<.v....j.q.e.
    [00:01:26.917,846] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 0cc0:  95 9b 53 ce e9 b2 7c 22 e9 85 5c 0d 97 8d b6 a9  ..S...|"..\.....
    [00:01:26.935,333] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 0cd0:  7e 54 c0 fe 4c 0d b0 00 00 01 96 c3 e0 61 73 00  ~T..L........as.
    [00:01:26.952,789] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 0ce0:  00 04 03 00 47 30 45 02 21 00 a5 49 83 b5 26 2f  ....G0E.!..I..&/
    [00:01:26.970,275] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 0cf0:  0b db a4 e4 3a eb 5b 00 de 0c 11 33 0d 3a 18 5a  ....:.[....3.:.Z
    [00:01:26.987,762] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 0d00:  04 d9 d9 3e 3b 09 6e f6 f5 eb 02 20 27 dc ba ac  ...>;.n.... '...
    [00:01:27.005,249] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 0d10:  81 f1 f9 aa ce d2 ac eb 49 d4 dc 0a 69 8a 27 73  ........I...i.'s
    [00:01:27.022,705] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 0d20:  92 f0 cd b3 bf 68 08 7b 87 cc 73 19 30 0d 06 09  .....h.{..s.0...
    [00:01:27.040,191] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 0d30:  2a 86 48 86 f7 0d 01 01 0b 05 00 03 82 01 01 00  *.H.............
    [00:01:27.057,678] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 0d40:  26 13 af 72 da b9 21 65 71 d4 c0 0f 3e 95 5f 24  &..r..!eq...>._$
    [00:01:27.075,134] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 0d50:  ac 98 6f 3b 55 ac 27 0e 1b b5 a1 21 6e 77 ba dc  ..o;U.'....!nw..
    [00:01:27.092,620] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 0d60:  f6 73 1a 2c e9 93 62 bf 99 6f e1 3c 66 a6 da 60  .s.,..b..o.<f..`
    [00:01:27.110,076] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 0d70:  97 fd c9 a1 1d 8c 3e ab 60 c1 1f 87 09 ea 9d 33  ......>.`......3
    [00:01:27.127,532] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 0d80:  54 03 69 39 76 1b db 91 d1 d7 97 1a 36 3a 6c 9f  T.i9v.......6:l.
    [00:01:27.145,019] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 0d90:  01 dd 47 59 5c 47 ee 6f 12 b3 bb bd 48 da b9 4e  ..GY\G.o....H..N
    [00:01:27.162,475] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 0da0:  85 6c 62 54 a1 5e b9 2f 64 21 0b c8 30 24 1f e1  .lbT.^./d!..0$..
    [00:01:27.179,962] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 0db0:  b1 8e 0e 9f 5f d8 ed e3 72 e1 27 81 33 7f 68 ef  ...._...r.'.3.h.
    [00:01:27.197,418] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 0dc0:  6b 81 de cf 5c cd 87 7f 68 b5 af a3 7f 4a 4c 1e  k...\...h....JL.
    [00:01:27.214,874] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 0dd0:  61 74 a9 7c 35 f9 e0 35 b3 9e 91 b4 86 b1 f4 45  at.|5..5.......E
    [00:01:27.232,360] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 0de0:  4f 27 9b 5f 16 49 fe 59 e7 ac bb c3 e7 1e 73 3b  O'._.I.Y......s;
    [00:01:27.249,816] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 0df0:  af 92 17 46 15 f7 4e 44 f4 94 a8 30 f5 c1 dd f8  ...F..ND...0....
    [00:01:27.267,303] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 0e00:  62 29 26 1e a7 7f f6 d2 8c 27 22 10 40 0d ea 21  b)&......'".@..!
    [00:01:27.284,759] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 0e10:  4b f2 f1 82 2d e3 51 0d 45 a8 df 38 52 56 ba b2  K...-.Q.E..8RV..
    [00:01:27.302,246] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 0e20:  57 a5 8f 66 c4 08 4f 81 67 08 27 5e 4a 8e 2b 65  W..f..O.g.'^J.+e
    [00:01:27.319,702] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 0e30:  90 0a d4 70 e3 34 56 b9 6f 4e 43 4f 3c 5b 89 05  ...p.4V.oNCO<[..
    [00:01:27.337,188] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 0e40:  00 05 0f 30 82 05 0b 30 82 02 f3 a0 03 02 01 02  ...0...0........
    [00:01:27.354,644] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 0e50:  02 10 7f f0 05 a0 7c 4c de d1 00 ad 9d 66 a5 10  ......|L.....f..
    [00:01:27.372,131] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 0e60:  7b 98 30 0d 06 09 2a 86 48 86 f7 0d 01 01 0b 05  {.0...*.H.......
    [00:01:27.389,617] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 0e70:  00 30 47 31 0b 30 09 06 03 55 04 06 13 02 55 53  .0G1.0...U....US
    [00:01:27.407,073] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 0e80:  31 22 30 20 06 03 55 04 0a 13 19 47 6f 6f 67 6c  1"0 ..U....Googl
    [00:01:27.424,560] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 0e90:  65 20 54 72 75 73 74 20 53 65 72 76 69 63 65 73  e Trust Services
    [00:01:27.442,016] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 0ea0:  20 4c 4c 43 31 14 30 12 06 03 55 04 03 13 0b 47   LLC1.0...U....G
    [00:01:27.459,503] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 0eb0:  54 53 20 52 6f 6f 74 20 52 31 30 1e 17 0d 32 33  TS Root R10...23
    [00:01:27.476,959] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 0ec0:  31 32 31 33 30 39 30 30 30 30 5a 17 0d 32 39 30  1213090000Z..290
    [00:01:27.494,445] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 0ed0:  32 32 30 31 34 30 30 30 30 5a 30 3b 31 0b 30 09  220140000Z0;1.0.
    [00:01:27.511,932] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 0ee0:  06 03 55 04 06 13 02 55 53 31 1e 30 1c 06 03 55  ..U....US1.0...U
    [00:01:27.529,418] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 0ef0:  04 0a 13 15 47 6f 6f 67 6c 65 20 54 72 75 73 74  ....Google Trust
    [00:01:27.546,875] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 0f00:  20 53 65 72 76 69 63 65 73 31 0c 30 0a 06 03 55   Services1.0...U
    [00:01:27.564,361] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 0f10:  04 03 13 03 57 52 32 30 82 01 22 30 0d 06 09 2a  ....WR20.."0...*
    [00:01:27.581,848] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 0f20:  86 48 86 f7 0d 01 01 01 05 00 03 82 01 0f 00 30  .H.............0
    [00:01:27.599,334] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 0f30:  82 01 0a 02 82 01 01 00 a9 ff 9c 7f 45 1e 70 a8  ............E.p.
    [00:01:27.616,821] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 0f40:  53 9f ca d9 e5 0d de 46 57 57 7d bc 8f 9a 5a ac  S......FWW}...Z.
    [00:01:27.634,277] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 0f50:  46 f1 84 9a bb 91 db c9 fb 2f 01 fb 92 09 00 16  F......../......
    [00:01:27.651,763] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 0f60:  5e a0 1c f8 c1 ab f9 78 2f 4a cc d8 85 a2 d8 59  ^......x/J.....Y
    [00:01:27.669,219] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 0f70:  3c 0e d3 18 fb b1 f5 24 0d 26 ee b6 5b 64 76 7c  <......$.&..[dv|
    [00:01:27.686,676] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 0f80:  14 c7 2f 7a ce a8 4c b7 f4 d9 08 fc df 87 23 35  ../z..L.......#5
    [00:01:27.704,162] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 0f90:  20 a8 e2 69 e2 8c 4e 3f b1 59 fa 60 a2 1e b3 c9   ..i..N?.Y.`....
    [00:01:27.721,618] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 0fa0:  20 53 19 82 ca 36 53 6d 60 4d e9 00 91 fc 76 8d   S...6Sm`M....v.
    [00:01:27.739,105] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 0fb0:  5c 08 0f 0a c2 dc f1 73 6b c5 13 6e 0a 4f 7a c2  \......sk..n.Oz.
    [00:01:27.756,561] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 0fc0:  f2 02 1c 2e b4 63 83 da 31 f6 2d 75 30 b2 fb ab  .....c..1.-u0...
    [00:01:27.774,047] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 0fd0:  c2 6e db a9 c0 0e b9 f9 67 d4 c3 25 57 74 eb 05  .n......g..%Wt..
    [00:01:27.791,503] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 0fe0:  b4 e9 8e b5 de 28 cd cc 7a 14 e4 71 03 cb 4d 61  .....(..z..q..Ma
    [00:01:27.808,990] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 0ff0:  2e 61 57 c5 19 a9 0b 98 84 1a e8 79 29 d9 b2 8d  .aW........y)...
    [00:01:27.831,390] <wrn> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4370: <= read record
    [00:01:27.849,212] <inf> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_tls.c:9961: Use configuration-specific verification callback
    Dead here...56. ret value = -9984
    [00:01:27.977,752] <err> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_tls.c:10020: x509_verify_cert() returned -9984 (-0x2700)
    Dead here...66. cert_failed = 1
    [00:01:27.993,713] <wrn> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:5294: => send alert message
    [00:01:28.004,852] <inf> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:5295: send alert level=2 message=48
    [00:01:28.016,387] <wrn> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:2944: => write record
    [00:01:28.027,038] <inf> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3028: output record: msgtype = 21, version = [3:3], msglen = 2
    [00:01:28.040,954] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3033: dumping 'output record sent to network' (7 bytes)
    [00:01:28.056,335] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3033: 0000:  15 03 03 00 02 02 30                             ......0
    [00:01:28.072,723] <wrn> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:2354: => flush output
    [00:01:28.083,343] <wrn> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:2368: message length: 7, out_left: 7
    [00:01:28.095,764] <wrn> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:2375: ssl->f_send() returned 7 (-0xfffffff9)
    [00:01:28.108,337] <wrn> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:2402: <= flush output
    [00:01:28.118,896] <wrn> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3081: <= write record
    [00:01:28.129,486] <wrn> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:5306: <= send alert message
    [00:01:28.140,655] <inf> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_tls.c:10130: ! Certificate verification flags 00000008
    [00:01:28.156,494] <wrn> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_tls.c:4672: <= handshake
    [00:01:28.166,778] <err> net_sock_tls: TLS handshake error: -0x2700
      File "<stdin>", line 1, in <module>
      File "sock_test.py", line 69, in step_1
    OSError: [Errno 113] ECONNABORTED
    >>> [00:01:29.144,348] <dbg> net_sock: zsock_received_cb: (rx_q[0]): ctx=0x2000abb0, pkt=(nil), st=-104, user_data=(nil)
    [00:01:29.155,334] <dbg> net_sock: zsock_received_cb: (rx_q[0]): Set EOF flag on pkt 0x2005ebd0
    [00:01:30.786,193] <dbg> net_sock: zsock_received_cb: (tcp_work): ctx=0x2000abb0, pkt=(nil), st=-116, user_data=(nil)
    [00:01:30.797,271] <dbg> net_sock: zsock_received_cb: (tcp_work): Set EOF flag on pkt 0x2005ebd0
    In order to recreate the issue, I need to be able to apply your patches cleanly.
    The .diff that was provided has other dependencies, as you seem to have committed files on several commits:
    (pyvenv) ➜  /opt/repos git apply zephyr_diff.txt
    error: micropython_nRF/ports/Zephyr/.DS_Store: No such file or directory
    error: patch failed: micropython_nRF/ports/Zephyr/CMakeLists.txt:41
    error: micropython_nRF/ports/Zephyr/CMakeLists.txt: patch does not apply
    error: patch failed: micropython_nRF/ports/Zephyr/Kconfig:40
    error: micropython_nRF/ports/Zephyr/Kconfig: patch does not apply
    error: patch failed: micropython_nRF/ports/Zephyr/README.md:4
    error: micropython_nRF/ports/Zephyr/README.md: patch does not apply
    error: micropython_nRF/ports/Zephyr/boards/.DS_Store: No such file or directory
    error: micropython_nRF/ports/Zephyr/boards/manifest.py: No such file or directory
    error: micropython_nRF/ports/Zephyr/boards/nrf52840dk_nrf52840.conf: No such file or directory
    error: micropython_nRF/ports/Zephyr/boards/nrf52840dk_nrf52840.overlay: No such file or directory
    error: micropython_nRF/ports/Zephyr/boards/nrf5340dk_nrf5340_cpuapp.conf: No such file or directory
    error: micropython_nRF/ports/Zephyr/boards/nrf5340dk_nrf5340_cpuapp.overlay: No such file or directory
    error: micropython_nRF/ports/Zephyr/boards/nrf5340dk_nrf5340_cpuapp_ns.conf: No such file or directory
    error: micropython_nRF/ports/Zephyr/boards/nrf5340dk_nrf5340_cpuapp_ns.overlay: No such file or directory
    error: micropython_nRF/ports/Zephyr/boards/nrf7002dk_nrf5340_cpuapp_ns.conf: No such file or directory
    error: micropython_nRF/ports/Zephyr/boards/nrf7002dk_nrf5340_cpuapp_ns.overlay: No such file or directory
    error: micropython_nRF/ports/Zephyr/boards/nrf7002dk_nrf5340_cpuapp_ns_almost good.conf: No such file or directory
    error: micropython_nRF/ports/Zephyr/boards/nrf7002dk_nrf5340_cpuapp_ns_handshake works, cypher not.conf: No such file or directory
    error: micropython_nRF/ports/Zephyr/boards/nrf7002dk_nrf5340_cpuapp_ns_sockets_work!.conf: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/.ninja_log: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/CMakeCache.txt: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/CMakeFiles/4.0.2/CMakeSystem.cmake: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/CMakeFiles/CMakeConfigureLog.yaml: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/CMakeFiles/InstallScripts.json: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/CMakeFiles/TargetDirectories.txt: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/CMakeFiles/cmake.check_cache: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/CMakeFiles/rules.ninja: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/Kconfig/Kconfig.modules: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/Kconfig/Kconfig.shield: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/Kconfig/Kconfig.shield.defconfig: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/Kconfig/Kconfig.sysbuild.modules: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/Kconfig/arch/Kconfig: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/Kconfig/boards/Kconfig: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/Kconfig/boards/Kconfig.defconfig: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/Kconfig/boards/Kconfig.nrf7002dk: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/Kconfig/boards/Kconfig.sysbuild: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/Kconfig/soc/Kconfig: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/Kconfig/soc/Kconfig.defconfig: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/Kconfig/soc/Kconfig.soc: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/Kconfig/soc/Kconfig.sysbuild: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/_sysbuild/autoconf.h: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/_sysbuild/cmake_install.cmake: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/_sysbuild/empty.conf: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/_sysbuild/sysbuild/images/CMakeFiles/zephyr-complete: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/_sysbuild/sysbuild/images/CMakeFiles/zephyr.dir/Labels.json: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/_sysbuild/sysbuild/images/CMakeFiles/zephyr.dir/Labels.txt: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/_sysbuild/sysbuild/images/boards/cmake_install.cmake: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/_sysbuild/sysbuild/images/bootloader/cmake_install.cmake: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/_sysbuild/sysbuild/images/cmake_install.cmake: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/_sysbuild/sysbuild/images/soc/cmake_install.cmake: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/_sysbuild/sysbuild/images/zephyr-prefix/src/zephyr-stamp/zephyr-configure: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/_sysbuild/sysbuild/images/zephyr-prefix/src/zephyr-stamp/zephyr-done: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/_sysbuild/sysbuild/images/zephyr-prefix/src/zephyr-stamp/zephyr-download: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/_sysbuild/sysbuild/images/zephyr-prefix/src/zephyr-stamp/zephyr-mkdir: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/_sysbuild/sysbuild/images/zephyr-prefix/src/zephyr-stamp/zephyr-patch: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/_sysbuild/sysbuild/images/zephyr-prefix/src/zephyr-stamp/zephyr-patch-info.txt: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/_sysbuild/sysbuild/images/zephyr-prefix/src/zephyr-stamp/zephyr-source_dirinfo.txt: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/_sysbuild/sysbuild/images/zephyr-prefix/src/zephyr-stamp/zephyr-update: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/_sysbuild/sysbuild/images/zephyr-prefix/src/zephyr-stamp/zephyr-update-info.txt: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/_sysbuild/sysbuild/images/zephyr-prefix/tmp/zephyr-cfgcmd.txt: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/_sysbuild/sysbuild/images/zephyr-prefix/tmp/zephyr-mkdirs.cmake: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/build.ninja: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/build_info.yml: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/build_info.yml.bak: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/cmake_install.cmake: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/domains.yaml: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/generated_nrfutil_batch.json: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/merged.hex: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/modules/mcuboot/cmake_install.cmake: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/modules/nrf/cmake_install.cmake: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/partitions.yml: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/pm.config: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/regions.yml: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/sysbuild_modules.txt: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/.cmake.dotconfig.checksum: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/.config: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/.ninja_deps: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/.ninja_log: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/CMakeCache.tmp: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/CMakeCache.txt: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/CMakeCache.txt.tmp: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/CMakeFiles/4.0.2/CMakeASMCompiler.cmake: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/CMakeFiles/4.0.2/CMakeCCompiler.cmake: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/CMakeFiles/4.0.2/CMakeCXXCompiler.cmake: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/CMakeFiles/4.0.2/CMakeSystem.cmake: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/CMakeFiles/4.0.2/CompilerIdC/CMakeCCompilerId.c: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/CMakeFiles/4.0.2/CompilerIdC/CMakeCCompilerId.o: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/CMakeFiles/4.0.2/CompilerIdCXX/CMakeCXXCompilerId.cpp: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/CMakeFiles/4.0.2/CompilerIdCXX/CMakeCXXCompilerId.o: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/CMakeFiles/CMakeConfigureLog.yaml: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/CMakeFiles/InstallScripts.json: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/CMakeFiles/TargetDirectories.txt: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/CMakeFiles/app.dir/src/zephyr_getchar.c.obj: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/CMakeFiles/app.dir/src/zephyr_start.c.obj: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/CMakeFiles/clean_additional.cmake: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/CMakeFiles/cmake.check_cache: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/CMakeFiles/micropython.dir/Users/tudor/Documents/GitHub/micropython_nRF/extmod/btstack/modbluetooth_btstack.c.obj: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/CMakeFiles/micropython.dir/Users/tudor/Documents/GitHub/micropython_nRF/extmod/machine_adc.c.obj: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/CMakeFiles/micropython.dir/Users/tudor/Documents/GitHub/micropython_nRF/extmod/machine_adc_block.c.obj: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/CMakeFiles/micropython.dir/Users/tudor/Documents/GitHub/micropython_nRF/extmod/machine_bitstream.c.obj: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/CMakeFiles/micropython.dir/Users/tudor/Documents/GitHub/micropython_nRF/extmod/machine_i2c.c.obj: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/CMakeFiles/micropython.dir/Users/tudor/Documents/GitHub/micropython_nRF/extmod/machine_i2s.c.obj: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/CMakeFiles/micropython.dir/Users/tudor/Documents/GitHub/micropython_nRF/extmod/machine_mem.c.obj: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/CMakeFiles/micropython.dir/Users/tudor/Documents/GitHub/micropython_nRF/extmod/machine_pulse.c.obj: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/CMakeFiles/micropython.dir/Users/tudor/Documents/GitHub/micropython_nRF/extmod/machine_pwm.c.obj: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/CMakeFiles/micropython.dir/Users/tudor/Documents/GitHub/micropython_nRF/extmod/machine_signal.c.obj: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/CMakeFiles/micropython.dir/Users/tudor/Documents/GitHub/micropython_nRF/extmod/machine_spi.c.obj: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/CMakeFiles/micropython.dir/Users/tudor/Documents/GitHub/micropython_nRF/extmod/machine_uart.c.obj: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/CMakeFiles/micropython.dir/Users/tudor/Documents/GitHub/micropython_nRF/extmod/machine_usb_device.c.obj: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/CMakeFiles/micropython.dir/Users/tudor/Documents/GitHub/micropython_nRF/extmod/machine_wdt.c.obj: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/CMakeFiles/micropython.dir/Users/tudor/Documents/GitHub/micropython_nRF/extmod/modasyncio.c.obj: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/CMakeFiles/micropython.dir/Users/tudor/Documents/GitHub/micropython_nRF/extmod/modbinascii.c.obj: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/CMakeFiles/micropython.dir/Users/tudor/Documents/GitHub/micropython_nRF/extmod/modbluetooth.c.obj: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/CMakeFiles/micropython.dir/Users/tudor/Documents/GitHub/micropython_nRF/extmod/modcryptolib.c.obj: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/CMakeFiles/micropython.dir/Users/tudor/Documents/GitHub/micropython_nRF/extmod/moddeflate.c.obj: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/CMakeFiles/micropython.dir/Users/tudor/Documents/GitHub/micropython_nRF/extmod/modframebuf.c.obj: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/CMakeFiles/micropython.dir/Users/tudor/Documents/GitHub/micropython_nRF/extmod/modhashlib.c.obj: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/CMakeFiles/micropython.dir/Users/tudor/Documents/GitHub/micropython_nRF/extmod/modheapq.c.obj: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/CMakeFiles/micropython.dir/Users/tudor/Documents/GitHub/micropython_nRF/extmod/modjson.c.obj: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/CMakeFiles/micropython.dir/Users/tudor/Documents/GitHub/micropython_nRF/extmod/modlwip.c.obj: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/CMakeFiles/micropython.dir/Users/tudor/Documents/GitHub/micropython_nRF/extmod/modmachine.c.obj: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/CMakeFiles/micropython.dir/Users/tudor/Documents/GitHub/micropython_nRF/extmod/modnetwork.c.obj: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/CMakeFiles/micropython.dir/Users/tudor/Documents/GitHub/micropython_nRF/extmod/modonewire.c.obj: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/CMakeFiles/micropython.dir/Users/tudor/Documents/GitHub/micropython_nRF/extmod/modos.c.obj: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/CMakeFiles/micropython.dir/Users/tudor/Documents/GitHub/micropython_nRF/extmod/modplatform.c.obj: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/CMakeFiles/micropython.dir/Users/tudor/Documents/GitHub/micropython_nRF/extmod/modrandom.c.obj: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/CMakeFiles/micropython.dir/Users/tudor/Documents/GitHub/micropython_nRF/extmod/modre.c.obj: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/CMakeFiles/micropython.dir/Users/tudor/Documents/GitHub/micropython_nRF/extmod/modselect.c.obj: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/CMakeFiles/micropython.dir/Users/tudor/Documents/GitHub/micropython_nRF/extmod/modsocket.c.obj: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/CMakeFiles/micropython.dir/Users/tudor/Documents/GitHub/micropython_nRF/extmod/modtime.c.obj: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/CMakeFiles/micropython.dir/Users/tudor/Documents/GitHub/micropython_nRF/extmod/modtls_axtls.c.obj: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/CMakeFiles/micropython.dir/Users/tudor/Documents/GitHub/micropython_nRF/extmod/modtls_mbedtls.c.obj: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/CMakeFiles/micropython.dir/Users/tudor/Documents/GitHub/micropython_nRF/extmod/moductypes.c.obj: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/CMakeFiles/micropython.dir/Users/tudor/Documents/GitHub/micropython_nRF/extmod/modvfs.c.obj: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/CMakeFiles/micropython.dir/Users/tudor/Documents/GitHub/micropython_nRF/extmod/modwebrepl.c.obj: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/CMakeFiles/micropython.dir/Users/tudor/Documents/GitHub/micropython_nRF/extmod/modwebsocket.c.obj: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/CMakeFiles/micropython.dir/Users/tudor/Documents/GitHub/micropython_nRF/extmod/network_cyw43.c.obj: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/CMakeFiles/micropython.dir/Users/tudor/Documents/GitHub/micropython_nRF/extmod/network_lwip.c.obj: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/CMakeFiles/micropython.dir/Users/tudor/Documents/GitHub/micropython_nRF/extmod/network_ninaw10.c.obj: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/CMakeFiles/micropython.dir/Users/tudor/Documents/GitHub/micropython_nRF/extmod/network_ppp_lwip.c.obj: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/CMakeFiles/micropython.dir/Users/tudor/Documents/GitHub/micropython_nRF/extmod/network_wiznet5k.c.obj: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/CMakeFiles/micropython.dir/Users/tudor/Documents/GitHub/micropython_nRF/extmod/nimble/modbluetooth_nimble.c.obj: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/CMakeFiles/micropython.dir/Users/tudor/Documents/GitHub/micropython_nRF/extmod/os_dupterm.c.obj: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/CMakeFiles/micropython.dir/Users/tudor/Documents/GitHub/micropython_nRF/extmod/vfs.c.obj: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/CMakeFiles/micropython.dir/Users/tudor/Documents/GitHub/micropython_nRF/extmod/vfs_blockdev.c.obj: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/CMakeFiles/micropython.dir/Users/tudor/Documents/GitHub/micropython_nRF/extmod/vfs_fat.c.obj: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/CMakeFiles/micropython.dir/Users/tudor/Documents/GitHub/micropython_nRF/extmod/vfs_fat_diskio.c.obj: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/CMakeFiles/micropython.dir/Users/tudor/Documents/GitHub/micropython_nRF/extmod/vfs_fat_file.c.obj: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/CMakeFiles/micropython.dir/Users/tudor/Documents/GitHub/micropython_nRF/extmod/vfs_lfs.c.obj: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/CMakeFiles/micropython.dir/Users/tudor/Documents/GitHub/micropython_nRF/extmod/vfs_posix.c.obj: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/CMakeFiles/micropython.dir/Users/tudor/Documents/GitHub/micropython_nRF/extmod/vfs_posix_file.c.obj: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/CMakeFiles/micropython.dir/Users/tudor/Documents/GitHub/micropython_nRF/extmod/vfs_reader.c.obj: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/CMakeFiles/micropython.dir/Users/tudor/Documents/GitHub/micropython_nRF/extmod/virtpin.c.obj: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/CMakeFiles/micropython.dir/Users/tudor/Documents/GitHub/micropython_nRF/lib/littlefs/lfs1.c.obj: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/CMakeFiles/micropython.dir/Users/tudor/Documents/GitHub/micropython_nRF/lib/littlefs/lfs1_util.c.obj: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/CMakeFiles/micropython.dir/Users/tudor/Documents/GitHub/micropython_nRF/lib/littlefs/lfs2.c.obj: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/CMakeFiles/micropython.dir/Users/tudor/Documents/GitHub/micropython_nRF/lib/littlefs/lfs2_util.c.obj: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/CMakeFiles/micropython.dir/Users/tudor/Documents/GitHub/micropython_nRF/lib/oofatfs/ff.c.obj: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/CMakeFiles/micropython.dir/Users/tudor/Documents/GitHub/micropython_nRF/lib/oofatfs/ffunicode.c.obj: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/CMakeFiles/micropython.dir/Users/tudor/Documents/GitHub/micropython_nRF/py/argcheck.c.obj: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/CMakeFiles/micropython.dir/Users/tudor/Documents/GitHub/micropython_nRF/py/asmarm.c.obj: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/CMakeFiles/micropython.dir/Users/tudor/Documents/GitHub/micropython_nRF/py/asmbase.c.obj: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/CMakeFiles/micropython.dir/Users/tudor/Documents/GitHub/micropython_nRF/py/asmrv32.c.obj: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/CMakeFiles/micropython.dir/Users/tudor/Documents/GitHub/micropython_nRF/py/asmthumb.c.obj: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/CMakeFiles/micropython.dir/Users/tudor/Documents/GitHub/micropython_nRF/py/asmx64.c.obj: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/CMakeFiles/micropython.dir/Users/tudor/Documents/GitHub/micropython_nRF/py/asmx86.c.obj: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/CMakeFiles/micropython.dir/Users/tudor/Documents/GitHub/micropython_nRF/py/asmxtensa.c.obj: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/CMakeFiles/micropython.dir/Users/tudor/Documents/GitHub/micropython_nRF/py/bc.c.obj: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/CMakeFiles/micropython.dir/Users/tudor/Documents/GitHub/micropython_nRF/py/binary.c.obj: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/CMakeFiles/micropython.dir/Users/tudor/Documents/GitHub/micropython_nRF/py/builtinevex.c.obj: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/CMakeFiles/micropython.dir/Users/tudor/Documents/GitHub/micropython_nRF/py/builtinhelp.c.obj: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/CMakeFiles/micropython.dir/Users/tudor/Documents/GitHub/micropython_nRF/py/builtinimport.c.obj: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/CMakeFiles/micropython.dir/Users/tudor/Documents/GitHub/micropython_nRF/py/compile.c.obj: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/CMakeFiles/micropython.dir/Users/tudor/Documents/GitHub/micropython_nRF/py/cstack.c.obj: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/CMakeFiles/micropython.dir/Users/tudor/Documents/GitHub/micropython_nRF/py/emitbc.c.obj: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/CMakeFiles/micropython.dir/Users/tudor/Documents/GitHub/micropython_nRF/py/emitcommon.c.obj: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/CMakeFiles/micropython.dir/Users/tudor/Documents/GitHub/micropython_nRF/py/emitglue.c.obj: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/CMakeFiles/micropython.dir/Users/tudor/Documents/GitHub/micropython_nRF/py/emitinlinethumb.c.obj: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/CMakeFiles/micropython.dir/Users/tudor/Documents/GitHub/micropython_nRF/py/emitinlinextensa.c.obj: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/CMakeFiles/micropython.dir/Users/tudor/Documents/GitHub/micropython_nRF/py/emitnarm.c.obj: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/CMakeFiles/micropython.dir/Users/tudor/Documents/GitHub/micropython_nRF/py/emitndebug.c.obj: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/CMakeFiles/micropython.dir/Users/tudor/Documents/GitHub/micropython_nRF/py/emitnrv32.c.obj: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/CMakeFiles/micropython.dir/Users/tudor/Documents/GitHub/micropython_nRF/py/emitnthumb.c.obj: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/CMakeFiles/micropython.dir/Users/tudor/Documents/GitHub/micropython_nRF/py/emitnx64.c.obj: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/CMakeFiles/micropython.dir/Users/tudor/Documents/GitHub/micropython_nRF/py/emitnx86.c.obj: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/CMakeFiles/micropython.dir/Users/tudor/Documents/GitHub/micropython_nRF/py/emitnxtensa.c.obj: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/CMakeFiles/micropython.dir/Users/tudor/Documents/GitHub/micropython_nRF/py/emitnxtensawin.c.obj: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/CMakeFiles/micropython.dir/Users/tudor/Documents/GitHub/micropython_nRF/py/formatfloat.c.obj: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/CMakeFiles/micropython.dir/Users/tudor/Documents/GitHub/micropython_nRF/py/frozenmod.c.obj: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/CMakeFiles/micropython.dir/Users/tudor/Documents/GitHub/micropython_nRF/py/gc.c.obj: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/CMakeFiles/micropython.dir/Users/tudor/Documents/GitHub/micropython_nRF/py/lexer.c.obj: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/CMakeFiles/micropython.dir/Users/tudor/Documents/GitHub/micropython_nRF/py/malloc.c.obj: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/CMakeFiles/micropython.dir/Users/tudor/Documents/GitHub/micropython_nRF/py/map.c.obj: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/CMakeFiles/micropython.dir/Users/tudor/Documents/GitHub/micropython_nRF/py/modarray.c.obj: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/CMakeFiles/micropython.dir/Users/tudor/Documents/GitHub/micropython_nRF/py/modbuiltins.c.obj: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/CMakeFiles/micropython.dir/Users/tudor/Documents/GitHub/micropython_nRF/py/modcmath.c.obj: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/CMakeFiles/micropython.dir/Users/tudor/Documents/GitHub/micropython_nRF/py/modcollections.c.obj: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/CMakeFiles/micropython.dir/Users/tudor/Documents/GitHub/micropython_nRF/py/moderrno.c.obj: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/CMakeFiles/micropython.dir/Users/tudor/Documents/GitHub/micropython_nRF/py/modgc.c.obj: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/CMakeFiles/micropython.dir/Users/tudor/Documents/GitHub/micropython_nRF/py/modio.c.obj: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/CMakeFiles/micropython.dir/Users/tudor/Documents/GitHub/micropython_nRF/py/modmath.c.obj: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/CMakeFiles/micropython.dir/Users/tudor/Documents/GitHub/micropython_nRF/py/modmicropython.c.obj: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/CMakeFiles/micropython.dir/Users/tudor/Documents/GitHub/micropython_nRF/py/modstruct.c.obj: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/CMakeFiles/micropython.dir/Users/tudor/Documents/GitHub/micropython_nRF/py/modsys.c.obj: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/CMakeFiles/micropython.dir/Users/tudor/Documents/GitHub/micropython_nRF/py/modthread.c.obj: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/CMakeFiles/micropython.dir/Users/tudor/Documents/GitHub/micropython_nRF/py/mpprint.c.obj: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/CMakeFiles/micropython.dir/Users/tudor/Documents/GitHub/micropython_nRF/py/mpstate.c.obj: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/CMakeFiles/micropython.dir/Users/tudor/Documents/GitHub/micropython_nRF/py/mpz.c.obj: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/CMakeFiles/micropython.dir/Users/tudor/Documents/GitHub/micropython_nRF/py/nativeglue.c.obj: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/CMakeFiles/micropython.dir/Users/tudor/Documents/GitHub/micropython_nRF/py/nlr.c.obj: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/CMakeFiles/micropython.dir/Users/tudor/Documents/GitHub/micropython_nRF/py/nlrmips.c.obj: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/CMakeFiles/micropython.dir/Users/tudor/Documents/GitHub/micropython_nRF/py/nlrpowerpc.c.obj: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/CMakeFiles/micropython.dir/Users/tudor/Documents/GitHub/micropython_nRF/py/nlrrv32.c.obj: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/CMakeFiles/micropython.dir/Users/tudor/Documents/GitHub/micropython_nRF/py/nlrrv64.c.obj: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/CMakeFiles/micropython.dir/Users/tudor/Documents/GitHub/micropython_nRF/py/nlrsetjmp.c.obj: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/CMakeFiles/micropython.dir/Users/tudor/Documents/GitHub/micropython_nRF/py/nlrthumb.c.obj: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/CMakeFiles/micropython.dir/Users/tudor/Documents/GitHub/micropython_nRF/py/nlrx64.c.obj: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/CMakeFiles/micropython.dir/Users/tudor/Documents/GitHub/micropython_nRF/py/nlrx86.c.obj: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/CMakeFiles/micropython.dir/Users/tudor/Documents/GitHub/micropython_nRF/py/nlrxtensa.c.obj: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/CMakeFiles/micropython.dir/Users/tudor/Documents/GitHub/micropython_nRF/py/obj.c.obj: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/CMakeFiles/micropython.dir/Users/tudor/Documents/GitHub/micropython_nRF/py/objarray.c.obj: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/CMakeFiles/micropython.dir/Users/tudor/Documents/GitHub/micropython_nRF/py/objattrtuple.c.obj: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/CMakeFiles/micropython.dir/Users/tudor/Documents/GitHub/micropython_nRF/py/objbool.c.obj: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/CMakeFiles/micropython.dir/Users/tudor/Documents/GitHub/micropython_nRF/py/objboundmeth.c.obj: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/CMakeFiles/micropython.dir/Users/tudor/Documents/GitHub/micropython_nRF/py/objcell.c.obj: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/CMakeFiles/micropython.dir/Users/tudor/Documents/GitHub/micropython_nRF/py/objclosure.c.obj: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/CMakeFiles/micropython.dir/Users/tudor/Documents/GitHub/micropython_nRF/py/objcomplex.c.obj: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/CMakeFiles/micropython.dir/Users/tudor/Documents/GitHub/micropython_nRF/py/objdeque.c.obj: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/CMakeFiles/micropython.dir/Users/tudor/Documents/GitHub/micropython_nRF/py/objdict.c.obj: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/CMakeFiles/micropython.dir/Users/tudor/Documents/GitHub/micropython_nRF/py/objenumerate.c.obj: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/CMakeFiles/micropython.dir/Users/tudor/Documents/GitHub/micropython_nRF/py/objexcept.c.obj: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/CMakeFiles/micropython.dir/Users/tudor/Documents/GitHub/micropython_nRF/py/objfilter.c.obj: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/CMakeFiles/micropython.dir/Users/tudor/Documents/GitHub/micropython_nRF/py/objfloat.c.obj: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/CMakeFiles/micropython.dir/Users/tudor/Documents/GitHub/micropython_nRF/py/objfun.c.obj: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/CMakeFiles/micropython.dir/Users/tudor/Documents/GitHub/micropython_nRF/py/objgenerator.c.obj: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/CMakeFiles/micropython.dir/Users/tudor/Documents/GitHub/micropython_nRF/py/objgetitemiter.c.obj: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/CMakeFiles/micropython.dir/Users/tudor/Documents/GitHub/micropython_nRF/py/objint.c.obj: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/CMakeFiles/micropython.dir/Users/tudor/Documents/GitHub/micropython_nRF/py/objint_longlong.c.obj: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/CMakeFiles/micropython.dir/Users/tudor/Documents/GitHub/micropython_nRF/py/objint_mpz.c.obj: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/CMakeFiles/micropython.dir/Users/tudor/Documents/GitHub/micropython_nRF/py/objlist.c.obj: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/CMakeFiles/micropython.dir/Users/tudor/Documents/GitHub/micropython_nRF/py/objmap.c.obj: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/CMakeFiles/micropython.dir/Users/tudor/Documents/GitHub/micropython_nRF/py/objmodule.c.obj: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/CMakeFiles/micropython.dir/Users/tudor/Documents/GitHub/micropython_nRF/py/objnamedtuple.c.obj: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/CMakeFiles/micropython.dir/Users/tudor/Documents/GitHub/micropython_nRF/py/objnone.c.obj: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/CMakeFiles/micropython.dir/Users/tudor/Documents/GitHub/micropython_nRF/py/objobject.c.obj: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/CMakeFiles/micropython.dir/Users/tudor/Documents/GitHub/micropython_nRF/py/objpolyiter.c.obj: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/CMakeFiles/micropython.dir/Users/tudor/Documents/GitHub/micropython_nRF/py/objproperty.c.obj: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/CMakeFiles/micropython.dir/Users/tudor/Documents/GitHub/micropython_nRF/py/objrange.c.obj: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/CMakeFiles/micropython.dir/Users/tudor/Documents/GitHub/micropython_nRF/py/objreversed.c.obj: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/CMakeFiles/micropython.dir/Users/tudor/Documents/GitHub/micropython_nRF/py/objringio.c.obj: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/CMakeFiles/micropython.dir/Users/tudor/Documents/GitHub/micropython_nRF/py/objset.c.obj: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/CMakeFiles/micropython.dir/Users/tudor/Documents/GitHub/micropython_nRF/py/objsingleton.c.obj: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/CMakeFiles/micropython.dir/Users/tudor/Documents/GitHub/micropython_nRF/py/objslice.c.obj: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/CMakeFiles/micropython.dir/Users/tudor/Documents/GitHub/micropython_nRF/py/objstr.c.obj: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/CMakeFiles/micropython.dir/Users/tudor/Documents/GitHub/micropython_nRF/py/objstringio.c.obj: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/CMakeFiles/micropython.dir/Users/tudor/Documents/GitHub/micropython_nRF/py/objstrunicode.c.obj: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/CMakeFiles/micropython.dir/Users/tudor/Documents/GitHub/micropython_nRF/py/objtuple.c.obj: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/CMakeFiles/micropython.dir/Users/tudor/Documents/GitHub/micropython_nRF/py/objtype.c.obj: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/CMakeFiles/micropython.dir/Users/tudor/Documents/GitHub/micropython_nRF/py/objzip.c.obj: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/CMakeFiles/micropython.dir/Users/tudor/Documents/GitHub/micropython_nRF/py/opmethods.c.obj: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/CMakeFiles/micropython.dir/Users/tudor/Documents/GitHub/micropython_nRF/py/pairheap.c.obj: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/CMakeFiles/micropython.dir/Users/tudor/Documents/GitHub/micropython_nRF/py/parse.c.obj: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/CMakeFiles/micropython.dir/Users/tudor/Documents/GitHub/micropython_nRF/py/parsenum.c.obj: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/CMakeFiles/micropython.dir/Users/tudor/Documents/GitHub/micropython_nRF/py/parsenumbase.c.obj: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/CMakeFiles/micropython.dir/Users/tudor/Documents/GitHub/micropython_nRF/py/persistentcode.c.obj: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/CMakeFiles/micropython.dir/Users/tudor/Documents/GitHub/micropython_nRF/py/profile.c.obj: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/CMakeFiles/micropython.dir/Users/tudor/Documents/GitHub/micropython_nRF/py/pystack.c.obj: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/CMakeFiles/micropython.dir/Users/tudor/Documents/GitHub/micropython_nRF/py/qstr.c.obj: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/CMakeFiles/micropython.dir/Users/tudor/Documents/GitHub/micropython_nRF/py/reader.c.obj: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/CMakeFiles/micropython.dir/Users/tudor/Documents/GitHub/micropython_nRF/py/repl.c.obj: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/CMakeFiles/micropython.dir/Users/tudor/Documents/GitHub/micropython_nRF/py/ringbuf.c.obj: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/CMakeFiles/micropython.dir/Users/tudor/Documents/GitHub/micropython_nRF/py/runtime.c.obj: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/CMakeFiles/micropython.dir/Users/tudor/Documents/GitHub/micropython_nRF/py/runtime_utils.c.obj: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/CMakeFiles/micropython.dir/Users/tudor/Documents/GitHub/micropython_nRF/py/scheduler.c.obj: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/CMakeFiles/micropython.dir/Users/tudor/Documents/GitHub/micropython_nRF/py/scope.c.obj: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/CMakeFiles/micropython.dir/Users/tudor/Documents/GitHub/micropython_nRF/py/sequence.c.obj: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/CMakeFiles/micropython.dir/Users/tudor/Documents/GitHub/micropython_nRF/py/showbc.c.obj: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/CMakeFiles/micropython.dir/Users/tudor/Documents/GitHub/micropython_nRF/py/smallint.c.obj: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/CMakeFiles/micropython.dir/Users/tudor/Documents/GitHub/micropython_nRF/py/stackctrl.c.obj: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/CMakeFiles/micropython.dir/Users/tudor/Documents/GitHub/micropython_nRF/py/stream.c.obj: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/CMakeFiles/micropython.dir/Users/tudor/Documents/GitHub/micropython_nRF/py/unicode.c.obj: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/CMakeFiles/micropython.dir/Users/tudor/Documents/GitHub/micropython_nRF/py/vm.c.obj: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/CMakeFiles/micropython.dir/Users/tudor/Documents/GitHub/micropython_nRF/py/vstr.c.obj: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/CMakeFiles/micropython.dir/Users/tudor/Documents/GitHub/micropython_nRF/py/warning.c.obj: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/CMakeFiles/micropython.dir/Users/tudor/Documents/GitHub/micropython_nRF/shared/libc/abort_.c.obj: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/CMakeFiles/micropython.dir/Users/tudor/Documents/GitHub/micropython_nRF/shared/libc/printf.c.obj: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/CMakeFiles/micropython.dir/Users/tudor/Documents/GitHub/micropython_nRF/shared/readline/readline.c.obj: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/CMakeFiles/micropython.dir/Users/tudor/Documents/GitHub/micropython_nRF/shared/runtime/gchelper_generic.c.obj: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/CMakeFiles/micropython.dir/Users/tudor/Documents/GitHub/micropython_nRF/shared/runtime/interrupt_char.c.obj: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/CMakeFiles/micropython.dir/Users/tudor/Documents/GitHub/micropython_nRF/shared/runtime/mpirq.c.obj: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/CMakeFiles/micropython.dir/Users/tudor/Documents/GitHub/micropython_nRF/shared/runtime/pyexec.c.obj: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/CMakeFiles/micropython.dir/Users/tudor/Documents/GitHub/micropython_nRF/shared/runtime/stdout_helpers.c.obj: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/CMakeFiles/micropython.dir/Users/tudor/Documents/GitHub/micropython_nRF/shared/timeutils/timeutils.c.obj: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/CMakeFiles/micropython.dir/frozen_content.c.obj: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/CMakeFiles/micropython.dir/help.c.obj: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/CMakeFiles/micropython.dir/machine_i2c.c.obj: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/CMakeFiles/micropython.dir/machine_pin.c.obj: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/CMakeFiles/micropython.dir/machine_rtc.c.obj: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/CMakeFiles/micropython.dir/machine_spi.c.obj: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/CMakeFiles/micropython.dir/machine_timer.c.obj: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/CMakeFiles/micropython.dir/main.c.obj: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/CMakeFiles/micropython.dir/modbluetooth_zephyr.c.obj: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/CMakeFiles/micropython.dir/modnfc.c.obj: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/CMakeFiles/micropython.dir/modsocket.c.obj: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/CMakeFiles/micropython.dir/modzephyr.c.obj: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/CMakeFiles/micropython.dir/modzsensor.c.obj: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/CMakeFiles/micropython.dir/mphalport.c.obj: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/CMakeFiles/micropython.dir/mpthreadport.c.obj: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/CMakeFiles/micropython.dir/network_wlan.c.obj: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/CMakeFiles/micropython.dir/nvmc.c.obj: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/CMakeFiles/micropython.dir/uart_core.c.obj: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/CMakeFiles/micropython.dir/zephyr_device.c.obj: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/CMakeFiles/micropython.dir/zephyr_storage.c.obj: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/CMakeFiles/rules.ninja: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/app/libapp.a: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/build.ninja: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/build_info.yml: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/certs/r1.pem.inc: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/cmake_install.cmake: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/compile_commands.json: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/frozen_content.c: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/frozen_mpy/iotcore.mpy: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/frozen_mpy/main.mpy: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/frozen_mpy/ntptime.mpy: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/frozen_mpy/probe.mpy: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/frozen_mpy/probe_protocol.mpy: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/frozen_mpy/sock_test.mpy: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/frozen_mpy/version.mpy: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/frozen_mpy/watchdog.mpy: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/frozen_mpy/wifi.mpy: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/generated/interface_nrf_security_psa/nrf-config.h: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/generated/interface_nrf_security_psa/nrf-psa-crypto-config.h: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/generated/library_nrf_security_psa/nrf-config.h: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/generated/library_nrf_security_psa/nrf-psa-crypto-config.h: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/generated/library_nrf_security_psa/nrf-psa-crypto-user-config.h: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/genhdr/module/__Users__tudor__Documents__GitHub__micropython_nRF__ports__zephyr__@@__@@__extmod__modbinascii.c.module: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/genhdr/module/__Users__tudor__Documents__GitHub__micropython_nRF__ports__zephyr__@@__@@__extmod__modhashlib.c.module: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/genhdr/module/__Users__tudor__Documents__GitHub__micropython_nRF__ports__zephyr__@@__@@__extmod__modmachine.c.module: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/genhdr/module/__Users__tudor__Documents__GitHub__micropython_nRF__ports__zephyr__@@__@@__extmod__modnetwork.c.module: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/genhdr/module/__Users__tudor__Documents__GitHub__micropython_nRF__ports__zephyr__@@__@@__extmod__modos.c.module: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/genhdr/module/__Users__tudor__Documents__GitHub__micropython_nRF__ports__zephyr__@@__@@__extmod__modrandom.c.module: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/genhdr/module/__Users__tudor__Documents__GitHub__micropython_nRF__ports__zephyr__@@__@@__extmod__modtime.c.module: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/genhdr/module/__Users__tudor__Documents__GitHub__micropython_nRF__ports__zephyr__@@__@@__extmod__modvfs.c.module: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/genhdr/module/__Users__tudor__Documents__GitHub__micropython_nRF__ports__zephyr__@@__@@__py__modarray.c.module: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/genhdr/module/__Users__tudor__Documents__GitHub__micropython_nRF__ports__zephyr__@@__@@__py__modbuiltins.c.module: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/genhdr/module/__Users__tudor__Documents__GitHub__micropython_nRF__ports__zephyr__@@__@@__py__modcmath.c.module: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/genhdr/module/__Users__tudor__Documents__GitHub__micropython_nRF__ports__zephyr__@@__@@__py__modcollections.c.module: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/genhdr/module/__Users__tudor__Documents__GitHub__micropython_nRF__ports__zephyr__@@__@@__py__moderrno.c.module: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/genhdr/module/__Users__tudor__Documents__GitHub__micropython_nRF__ports__zephyr__@@__@@__py__modgc.c.module: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/genhdr/module/__Users__tudor__Documents__GitHub__micropython_nRF__ports__zephyr__@@__@@__py__modio.c.module: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/genhdr/module/__Users__tudor__Documents__GitHub__micropython_nRF__ports__zephyr__@@__@@__py__modmath.c.module: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/genhdr/module/__Users__tudor__Documents__GitHub__micropython_nRF__ports__zephyr__@@__@@__py__modmicropython.c.module: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/genhdr/module/__Users__tudor__Documents__GitHub__micropython_nRF__ports__zephyr__@@__@@__py__modstruct.c.module: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/genhdr/module/__Users__tudor__Documents__GitHub__micropython_nRF__ports__zephyr__@@__@@__py__modsys.c.module: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/genhdr/module/__Users__tudor__Documents__GitHub__micropython_nRF__ports__zephyr__@@__@@__py__modthread.c.module: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/genhdr/module/__Users__tudor__Documents__GitHub__micropython_nRF__ports__zephyr__@@__@@__py__runtime.c.module: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/genhdr/module/__Users__tudor__Documents__GitHub__micropython_nRF__ports__zephyr__modsocket.c.module: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/genhdr/module/__Users__tudor__Documents__GitHub__micropython_nRF__ports__zephyr__modzephyr.c.module: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/genhdr/module/__Users__tudor__Documents__GitHub__micropython_nRF__ports__zephyr__modzsensor.c.module: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/genhdr/moduledefs.collected: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/genhdr/moduledefs.collected.hash: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/genhdr/moduledefs.h: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/genhdr/moduledefs.split: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/genhdr/mpversion.h: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/genhdr/qstr/__Users__tudor__Documents__GitHub__micropython_nRF__ports__zephyr__@@__@@__extmod__machine_i2c.c.qstr: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/genhdr/qstr/__Users__tudor__Documents__GitHub__micropython_nRF__ports__zephyr__@@__@@__extmod__machine_mem.c.qstr: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/genhdr/qstr/__Users__tudor__Documents__GitHub__micropython_nRF__ports__zephyr__@@__@@__extmod__machine_pwm.c.qstr: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/genhdr/qstr/__Users__tudor__Documents__GitHub__micropython_nRF__ports__zephyr__@@__@@__extmod__machine_signal.c.qstr: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/genhdr/qstr/__Users__tudor__Documents__GitHub__micropython_nRF__ports__zephyr__@@__@@__extmod__machine_spi.c.qstr: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/genhdr/qstr/__Users__tudor__Documents__GitHub__micropython_nRF__ports__zephyr__@@__@@__extmod__machine_uart.c.qstr: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/genhdr/qstr/__Users__tudor__Documents__GitHub__micropython_nRF__ports__zephyr__@@__@@__extmod__machine_wdt.c.qstr: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/genhdr/qstr/__Users__tudor__Documents__GitHub__micropython_nRF__ports__zephyr__@@__@@__extmod__modbinascii.c.qstr: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/genhdr/qstr/__Users__tudor__Documents__GitHub__micropython_nRF__ports__zephyr__@@__@@__extmod__modhashlib.c.qstr: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/genhdr/qstr/__Users__tudor__Documents__GitHub__micropython_nRF__ports__zephyr__@@__@@__extmod__modmachine.c.qstr: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/genhdr/qstr/__Users__tudor__Documents__GitHub__micropython_nRF__ports__zephyr__@@__@@__extmod__modnetwork.c.qstr: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/genhdr/qstr/__Users__tudor__Documents__GitHub__micropython_nRF__ports__zephyr__@@__@@__extmod__modos.c.qstr: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/genhdr/qstr/__Users__tudor__Documents__GitHub__micropython_nRF__ports__zephyr__@@__@@__extmod__modrandom.c.qstr: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/genhdr/qstr/__Users__tudor__Documents__GitHub__micropython_nRF__ports__zephyr__@@__@@__extmod__modtime.c.qstr: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/genhdr/qstr/__Users__tudor__Documents__GitHub__micropython_nRF__ports__zephyr__@@__@@__extmod__modvfs.c.qstr: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/genhdr/qstr/__Users__tudor__Documents__GitHub__micropython_nRF__ports__zephyr__@@__@@__extmod__vfs.c.qstr: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/genhdr/qstr/__Users__tudor__Documents__GitHub__micropython_nRF__ports__zephyr__@@__@@__extmod__vfs_blockdev.c.qstr: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/genhdr/qstr/__Users__tudor__Documents__GitHub__micropython_nRF__ports__zephyr__@@__@@__extmod__vfs_fat.c.qstr: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/genhdr/qstr/__Users__tudor__Documents__GitHub__micropython_nRF__ports__zephyr__@@__@@__extmod__vfs_fat_file.c.qstr: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/genhdr/qstr/__Users__tudor__Documents__GitHub__micropython_nRF__ports__zephyr__@@__@@__extmod__vfs_lfs.c.qstr: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/genhdr/qstr/__Users__tudor__Documents__GitHub__micropython_nRF__ports__zephyr__@@__@@__extmod__vfs_lfsx.c.qstr: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/genhdr/qstr/__Users__tudor__Documents__GitHub__micropython_nRF__ports__zephyr__@@__@@__extmod__vfs_lfsx_file.c.qstr: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/genhdr/qstr/__Users__tudor__Documents__GitHub__micropython_nRF__ports__zephyr__@@__@@__extmod__vfs_reader.c.qstr: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/genhdr/qstr/__Users__tudor__Documents__GitHub__micropython_nRF__ports__zephyr__@@__@@__ports__zephyr__machine_pwm.c.qstr: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/genhdr/qstr/__Users__tudor__Documents__GitHub__micropython_nRF__ports__zephyr__@@__@@__ports__zephyr__machine_uart.c.qstr: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/genhdr/qstr/__Users__tudor__Documents__GitHub__micropython_nRF__ports__zephyr__@@__@@__ports__zephyr__network_wlan.c.qstr: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/genhdr/qstr/__Users__tudor__Documents__GitHub__micropython_nRF__ports__zephyr__@@__@@__py__builtinevex.c.qstr: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/genhdr/qstr/__Users__tudor__Documents__GitHub__micropython_nRF__ports__zephyr__@@__@@__py__builtinimport.c.qstr: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/genhdr/qstr/__Users__tudor__Documents__GitHub__micropython_nRF__ports__zephyr__@@__@@__py__compile.c.qstr: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/genhdr/qstr/__Users__tudor__Documents__GitHub__micropython_nRF__ports__zephyr__@@__@@__py__emitbc.c.qstr: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/genhdr/qstr/__Users__tudor__Documents__GitHub__micropython_nRF__ports__zephyr__@@__@@__py__gc.c.qstr: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/genhdr/qstr/__Users__tudor__Documents__GitHub__micropython_nRF__ports__zephyr__@@__@@__py__modarray.c.qstr: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/genhdr/qstr/__Users__tudor__Documents__GitHub__micropython_nRF__ports__zephyr__@@__@@__py__modbuiltins.c.qstr: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/genhdr/qstr/__Users__tudor__Documents__GitHub__micropython_nRF__ports__zephyr__@@__@@__py__modcmath.c.qstr: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/genhdr/qstr/__Users__tudor__Documents__GitHub__micropython_nRF__ports__zephyr__@@__@@__py__modcollections.c.qstr: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/genhdr/qstr/__Users__tudor__Documents__GitHub__micropython_nRF__ports__zephyr__@@__@@__py__moderrno.c.qstr: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/genhdr/qstr/__Users__tudor__Documents__GitHub__micropython_nRF__ports__zephyr__@@__@@__py__modgc.c.qstr: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/genhdr/qstr/__Users__tudor__Documents__GitHub__micropython_nRF__ports__zephyr__@@__@@__py__modio.c.qstr: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/genhdr/qstr/__Users__tudor__Documents__GitHub__micropython_nRF__ports__zephyr__@@__@@__py__modmath.c.qstr: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/genhdr/qstr/__Users__tudor__Documents__GitHub__micropython_nRF__ports__zephyr__@@__@@__py__modmicropython.c.qstr: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/genhdr/qstr/__Users__tudor__Documents__GitHub__micropython_nRF__ports__zephyr__@@__@@__py__modstruct.c.qstr: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/genhdr/qstr/__Users__tudor__Documents__GitHub__micropython_nRF__ports__zephyr__@@__@@__py__modsys.c.qstr: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/genhdr/qstr/__Users__tudor__Documents__GitHub__micropython_nRF__ports__zephyr__@@__@@__py__modthread.c.qstr: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/genhdr/qstr/__Users__tudor__Documents__GitHub__micropython_nRF__ports__zephyr__@@__@@__py__objarray.c.qstr: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/genhdr/qstr/__Users__tudor__Documents__GitHub__micropython_nRF__ports__zephyr__@@__@@__py__objattrtuple.c.qstr: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/genhdr/qstr/__Users__tudor__Documents__GitHub__micropython_nRF__ports__zephyr__@@__@@__py__objbool.c.qstr: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/genhdr/qstr/__Users__tudor__Documents__GitHub__micropython_nRF__ports__zephyr__@@__@@__py__objboundmeth.c.qstr: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/genhdr/qstr/__Users__tudor__Documents__GitHub__micropython_nRF__ports__zephyr__@@__@@__py__objclosure.c.qstr: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/genhdr/qstr/__Users__tudor__Documents__GitHub__micropython_nRF__ports__zephyr__@@__@@__py__objcomplex.c.qstr: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/genhdr/qstr/__Users__tudor__Documents__GitHub__micropython_nRF__ports__zephyr__@@__@@__py__objdict.c.qstr: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/genhdr/qstr/__Users__tudor__Documents__GitHub__micropython_nRF__ports__zephyr__@@__@@__py__objenumerate.c.qstr: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/genhdr/qstr/__Users__tudor__Documents__GitHub__micropython_nRF__ports__zephyr__@@__@@__py__objexcept.c.qstr: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/genhdr/qstr/__Users__tudor__Documents__GitHub__micropython_nRF__ports__zephyr__@@__@@__py__objfilter.c.qstr: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/genhdr/qstr/__Users__tudor__Documents__GitHub__micropython_nRF__ports__zephyr__@@__@@__py__objfloat.c.qstr: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/genhdr/qstr/__Users__tudor__Documents__GitHub__micropython_nRF__ports__zephyr__@@__@@__py__objfun.c.qstr: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/genhdr/qstr/__Users__tudor__Documents__GitHub__micropython_nRF__ports__zephyr__@@__@@__py__objgenerator.c.qstr: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/genhdr/qstr/__Users__tudor__Documents__GitHub__micropython_nRF__ports__zephyr__@@__@@__py__objgetitemiter.c.qstr: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/genhdr/qstr/__Users__tudor__Documents__GitHub__micropython_nRF__ports__zephyr__@@__@@__py__objint.c.qstr: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/genhdr/qstr/__Users__tudor__Documents__GitHub__micropython_nRF__ports__zephyr__@@__@@__py__objlist.c.qstr: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/genhdr/qstr/__Users__tudor__Documents__GitHub__micropython_nRF__ports__zephyr__@@__@@__py__objmap.c.qstr: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/genhdr/qstr/__Users__tudor__Documents__GitHub__micropython_nRF__ports__zephyr__@@__@@__py__objmodule.c.qstr: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/genhdr/qstr/__Users__tudor__Documents__GitHub__micropython_nRF__ports__zephyr__@@__@@__py__objnone.c.qstr: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/genhdr/qstr/__Users__tudor__Documents__GitHub__micropython_nRF__ports__zephyr__@@__@@__py__objobject.c.qstr: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/genhdr/qstr/__Users__tudor__Documents__GitHub__micropython_nRF__ports__zephyr__@@__@@__py__objpolyiter.c.qstr: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/genhdr/qstr/__Users__tudor__Documents__GitHub__micropython_nRF__ports__zephyr__@@__@@__py__objproperty.c.qstr: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/genhdr/qstr/__Users__tudor__Documents__GitHub__micropython_nRF__ports__zephyr__@@__@@__py__objrange.c.qstr: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/genhdr/qstr/__Users__tudor__Documents__GitHub__micropython_nRF__ports__zephyr__@@__@@__py__objreversed.c.qstr: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/genhdr/qstr/__Users__tudor__Documents__GitHub__micropython_nRF__ports__zephyr__@@__@@__py__objset.c.qstr: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/genhdr/qstr/__Users__tudor__Documents__GitHub__micropython_nRF__ports__zephyr__@@__@@__py__objsingleton.c.qstr: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/genhdr/qstr/__Users__tudor__Documents__GitHub__micropython_nRF__ports__zephyr__@@__@@__py__objslice.c.qstr: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/genhdr/qstr/__Users__tudor__Documents__GitHub__micropython_nRF__ports__zephyr__@@__@@__py__objstr.c.qstr: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/genhdr/qstr/__Users__tudor__Documents__GitHub__micropython_nRF__ports__zephyr__@@__@@__py__objstringio.c.qstr: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/genhdr/qstr/__Users__tudor__Documents__GitHub__micropython_nRF__ports__zephyr__@@__@@__py__objtuple.c.qstr: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/genhdr/qstr/__Users__tudor__Documents__GitHub__micropython_nRF__ports__zephyr__@@__@@__py__objtype.c.qstr: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/genhdr/qstr/__Users__tudor__Documents__GitHub__micropython_nRF__ports__zephyr__@@__@@__py__objzip.c.qstr: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/genhdr/qstr/__Users__tudor__Documents__GitHub__micropython_nRF__ports__zephyr__@@__@@__py__parse.c.qstr: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/genhdr/qstr/__Users__tudor__Documents__GitHub__micropython_nRF__ports__zephyr__@@__@@__py__runtime.c.qstr: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/genhdr/qstr/__Users__tudor__Documents__GitHub__micropython_nRF__ports__zephyr__@@__@@__py__scope.c.qstr: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/genhdr/qstr/__Users__tudor__Documents__GitHub__micropython_nRF__ports__zephyr__@@__@@__py__vm.c.qstr: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/genhdr/qstr/__Users__tudor__Documents__GitHub__micropython_nRF__ports__zephyr__@@__@@__shared__runtime__mpirq.c.qstr: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/genhdr/qstr/__Users__tudor__Documents__GitHub__micropython_nRF__ports__zephyr__@@__@@__shared__runtime__pyexec.c.qstr: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/genhdr/qstr/__Users__tudor__Documents__GitHub__micropython_nRF__ports__zephyr__machine_i2c.c.qstr: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/genhdr/qstr/__Users__tudor__Documents__GitHub__micropython_nRF__ports__zephyr__machine_pin.c.qstr: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/genhdr/qstr/__Users__tudor__Documents__GitHub__micropython_nRF__ports__zephyr__machine_rtc.c.qstr: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/genhdr/qstr/__Users__tudor__Documents__GitHub__micropython_nRF__ports__zephyr__machine_spi.c.qstr: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/genhdr/qstr/__Users__tudor__Documents__GitHub__micropython_nRF__ports__zephyr__machine_timer.c.qstr: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/genhdr/qstr/__Users__tudor__Documents__GitHub__micropython_nRF__ports__zephyr__modsocket.c.qstr: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/genhdr/qstr/__Users__tudor__Documents__GitHub__micropython_nRF__ports__zephyr__modzephyr.c.qstr: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/genhdr/qstr/__Users__tudor__Documents__GitHub__micropython_nRF__ports__zephyr__modzsensor.c.qstr: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/genhdr/qstr/__Users__tudor__Documents__GitHub__micropython_nRF__ports__zephyr__network_wlan.c.qstr: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/genhdr/qstr.i.last: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/genhdr/qstr.split: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/genhdr/qstrdefs.collected.h: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/genhdr/qstrdefs.collected.h.hash: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/genhdr/qstrdefs.generated.h: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/genhdr/qstrdefs.preprocessed.h: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/genhdr/root_pointer/__Users__tudor__Documents__GitHub__micropython_nRF__ports__zephyr__@@__@@__extmod__vfs.c.root_pointer: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/genhdr/root_pointer/__Users__tudor__Documents__GitHub__micropython_nRF__ports__zephyr__@@__@@__py__modsys.c.root_pointer: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/genhdr/root_pointer/__Users__tudor__Documents__GitHub__micropython_nRF__ports__zephyr__@@__@@__py__scheduler.c.root_pointer: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/genhdr/root_pointer/__Users__tudor__Documents__GitHub__micropython_nRF__ports__zephyr__@@__@@__shared__readline__readline.c.root_pointer: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/genhdr/root_pointer/__Users__tudor__Documents__GitHub__micropython_nRF__ports__zephyr__machine_pin.c.root_pointer: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/genhdr/root_pointer/__Users__tudor__Documents__GitHub__micropython_nRF__ports__zephyr__machine_timer.c.root_pointer: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/genhdr/root_pointers.collected: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/genhdr/root_pointers.collected.hash: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/genhdr/root_pointers.h: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/genhdr/root_pointers.split: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/kconfig/Kconfig.dts: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/kconfig/Kconfig.modules: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/kconfig/Kconfig.shield: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/kconfig/Kconfig.shield.defconfig: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/kconfig/Kconfig.sysbuild.modules: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/kconfig/arch/Kconfig: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/kconfig/boards/Kconfig: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/kconfig/boards/Kconfig.defconfig: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/kconfig/boards/Kconfig.nrf7002dk: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/kconfig/boards/Kconfig.sysbuild: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/kconfig/soc/Kconfig: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/kconfig/soc/Kconfig.defconfig: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/kconfig/soc/Kconfig.soc: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/kconfig/soc/Kconfig.sysbuild: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/kconfig/sources.txt: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/libmicropython.a: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/modules/azure-sdk-for-c/cmake_install.cmake: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/modules/canopennode/cmake_install.cmake: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/modules/chre/cmake_install.cmake: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/modules/cirrus-logic/cmake_install.cmake: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/modules/cjson/cmake_install.cmake: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/modules/cmsis/cmake_install.cmake: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/modules/cmsis/cmsis/CMSIS/Core/cmake_install.cmake: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/modules/cmsis/cmsis/CMSIS/cmake_install.cmake: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/modules/cmsis/cmsis/cmake_install.cmake: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/modules/cmsis-dsp/cmake_install.cmake: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/modules/cmsis-nn/cmake_install.cmake: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/modules/connectedhomeip/cmake_install.cmake: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/modules/fatfs/cmake_install.cmake: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/modules/hal_nordic/cmake_install.cmake: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/modules/hal_nordic/modules/hal_nordic/cmake_install.cmake: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/modules/hal_nordic/modules/hal_nordic/nrfx/CMakeFiles/modules__hal_nordic__nrfx.dir/nrfx_glue.c.obj: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/modules/hal_nordic/modules/hal_nordic/nrfx/CMakeFiles/modules__hal_nordic__nrfx.dir/opt/nordic/ncs/v3.0.0/modules/hal/nordic/nrfx/drivers/src/nrfx_clock.c.obj: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/modules/hal_nordic/modules/hal_nordic/nrfx/CMakeFiles/modules__hal_nordic__nrfx.dir/opt/nordic/ncs/v3.0.0/modules/hal/nordic/nrfx/drivers/src/nrfx_dppi.c.obj: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/modules/hal_nordic/modules/hal_nordic/nrfx/CMakeFiles/modules__hal_nordic__nrfx.dir/opt/nordic/ncs/v3.0.0/modules/hal/nordic/nrfx/drivers/src/nrfx_gpiote.c.obj: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/modules/hal_nordic/modules/hal_nordic/nrfx/CMakeFiles/modules__hal_nordic__nrfx.dir/opt/nordic/ncs/v3.0.0/modules/hal/nordic/nrfx/drivers/src/nrfx_nvmc.c.obj: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/modules/hal_nordic/modules/hal_nordic/nrfx/CMakeFiles/modules__hal_nordic__nrfx.dir/opt/nordic/ncs/v3.0.0/modules/hal/nordic/nrfx/drivers/src/nrfx_pwm.c.obj: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/modules/hal_nordic/modules/hal_nordic/nrfx/CMakeFiles/modules__hal_nordic__nrfx.dir/opt/nordic/ncs/v3.0.0/modules/hal/nordic/nrfx/drivers/src/nrfx_qspi.c.obj: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/modules/hal_nordic/modules/hal_nordic/nrfx/CMakeFiles/modules__hal_nordic__nrfx.dir/opt/nordic/ncs/v3.0.0/modules/hal/nordic/nrfx/drivers/src/nrfx_spim.c.obj: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/modules/hal_nordic/modules/hal_nordic/nrfx/CMakeFiles/modules__hal_nordic__nrfx.dir/opt/nordic/ncs/v3.0.0/modules/hal/nordic/nrfx/drivers/src/nrfx_wdt.c.obj: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/modules/hal_nordic/modules/hal_nordic/nrfx/CMakeFiles/modules__hal_nordic__nrfx.dir/opt/nordic/ncs/v3.0.0/modules/hal/nordic/nrfx/helpers/nrfx_flag32_allocator.c.obj: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/modules/hal_nordic/modules/hal_nordic/nrfx/CMakeFiles/modules__hal_nordic__nrfx.dir/opt/nordic/ncs/v3.0.0/modules/hal/nordic/nrfx/helpers/nrfx_gppi_dppi.c.obj: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/modules/hal_nordic/modules/hal_nordic/nrfx/CMakeFiles/modules__hal_nordic__nrfx.dir/opt/nordic/ncs/v3.0.0/modules/hal/nordic/nrfx/helpers/nrfx_gppi_ppi.c.obj: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/modules/hal_nordic/modules/hal_nordic/nrfx/CMakeFiles/modules__hal_nordic__nrfx.dir/opt/nordic/ncs/v3.0.0/modules/hal/nordic/nrfx/helpers/nrfx_ram_ctrl.c.obj: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/modules/hal_nordic/modules/hal_nordic/nrfx/CMakeFiles/modules__hal_nordic__nrfx.dir/opt/nordic/ncs/v3.0.0/modules/hal/nordic/nrfx/mdk/system_nrf5340_application.c.obj: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/modules/hal_nordic/modules/hal_nordic/nrfx/cmake_install.cmake: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/modules/hal_nordic/modules/hal_nordic/nrfx/libmodules__hal_nordic__nrfx.a: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/modules/hal_nordic/nrfx/cmake_install.cmake: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/modules/hal_st/cmake_install.cmake: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/modules/hal_tdk/cmake_install.cmake: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/modules/hal_wurthelektronik/cmake_install.cmake: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/modules/hostap/cmake_install.cmake: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/modules/liblc3/cmake_install.cmake: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/modules/libmetal/cmake_install.cmake: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/modules/littlefs/cmake_install.cmake: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/modules/loramac-node/cmake_install.cmake: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/modules/lvgl/cmake_install.cmake: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/modules/lz4/cmake_install.cmake: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/modules/mbedtls/cmake_install.cmake: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/modules/mcuboot/boot/bootutil/zephyr/cmake_install.cmake: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/modules/mcuboot/cmake_install.cmake: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/modules/memfault-firmware-sdk/cmake_install.cmake: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/modules/mipi-sys-t/cmake_install.cmake: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/modules/nanopb/cmake_install.cmake: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/modules/nrf/cmake_install.cmake: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/modules/nrf/drivers/cmake_install.cmake: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/modules/nrf/drivers/entropy/cmake_install.cmake: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/modules/nrf/drivers/flash/cmake_install.cmake: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/modules/nrf/drivers/gpio/cmake_install.cmake: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/modules/nrf/drivers/hw_cc3xx/cmake_install.cmake: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/modules/nrf/drivers/mpsl/cmake_install.cmake: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/modules/nrf/drivers/mpsl/flash_sync/cmake_install.cmake: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/modules/nrf/drivers/net/cmake_install.cmake: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/modules/nrf/drivers/sensor/cmake_install.cmake: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/modules/nrf/drivers/serial/cmake_install.cmake: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/modules/nrf/ext/cmake_install.cmake: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/modules/nrf/lib/bin/cmake_install.cmake: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/modules/nrf/lib/boot_banner/cmake_install.cmake: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/modules/nrf/lib/cmake_install.cmake: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/modules/nrf/lib/date_time/CMakeFiles/..__nrf__lib__date_time.dir/date_time.c.obj: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/modules/nrf/lib/date_time/CMakeFiles/..__nrf__lib__date_time.dir/date_time_core.c.obj: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/modules/nrf/lib/date_time/CMakeFiles/..__nrf__lib__date_time.dir/date_time_ntp.c.obj: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/modules/nrf/lib/date_time/cmake_install.cmake: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/modules/nrf/lib/date_time/lib..__nrf__lib__date_time.a: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/modules/nrf/lib/fatal_error/cmake_install.cmake: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/modules/nrf/lib/flash_patch/cmake_install.cmake: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/modules/nrf/modules/cmake_install.cmake: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/modules/nrf/modules/trusted-firmware-m/CMakeFiles/..__nrf__modules__trusted-firmware-m.dir/fault.c.obj: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/modules/nrf/modules/trusted-firmware-m/CMakeFiles/tfm_api_nrf.dir/tfm_boards/src/tfm_ioctl_ns_api.c.obj: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/modules/nrf/modules/trusted-firmware-m/cmake_install.cmake: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/modules/nrf/modules/trusted-firmware-m/config_extra.cmake: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/modules/nrf/modules/trusted-firmware-m/lib..__nrf__modules__trusted-firmware-m.a: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/modules/nrf/modules/trusted-firmware-m/libtfm_api_nrf.a: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/modules/nrf/modules/trusted-firmware-m/tfm_config.h: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/modules/nrf/modules/wfa-qt/cmake_install.cmake: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/modules/nrf/samples/cmake_install.cmake: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/modules/nrf/samples/common/cmake_install.cmake: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/modules/nrf/samples/common/mcumgr_bt_ota_dfu/cmake_install.cmake: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/modules/nrf/subsys/cmake_install.cmake: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/modules/nrf/subsys/debug/cmake_install.cmake: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/modules/nrf/subsys/dfu/cmake_install.cmake: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/modules/nrf/subsys/logging/cmake_install.cmake: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/modules/nrf/subsys/mgmt/mcumgr/cmake_install.cmake: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/modules/nrf/subsys/mgmt/mcumgr/grp/cmake_install.cmake: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/modules/nrf/subsys/mpsl/cmake_install.cmake: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/modules/nrf/subsys/mpsl/cx/cmake_install.cmake: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/modules/nrf/subsys/net/cmake_install.cmake: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/modules/nrf/subsys/net/lib/cmake_install.cmake: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/modules/nrf/subsys/net/lib/hostap_crypto/cmake_install.cmake: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/modules/nrf/subsys/net/lib/nrf70_fw_ext/cmake_install.cmake: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/modules/nrf/subsys/net/lib/tls_credentials/cmake_install.cmake: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/modules/nrf/subsys/net/lib/wifi_ready/CMakeFiles/WIFI_READY_LIB.dir/wifi_ready.c.obj: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/modules/nrf/subsys/net/lib/wifi_ready/cmake_install.cmake: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/modules/nrf/subsys/net/lib/wifi_ready/libWIFI_READY_LIB.a: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/modules/nrf/subsys/nrf_security/cmake/config_extra.cmake: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/modules/nrf/subsys/nrf_security/cmake_install.cmake: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/modules/nrf/subsys/nrf_security/crypto_copy/cmake_install.cmake: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/modules/nrf/subsys/nrf_security/src/CMakeFiles/mbedcrypto.dir/legacy/ecdsa_oberon.c.obj: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/modules/nrf/subsys/nrf_security/src/CMakeFiles/mbedcrypto.dir/legacy/ecjpake_oberon.c.obj: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/modules/nrf/subsys/nrf_security/src/CMakeFiles/mbedcrypto.dir/legacy/md_ext.c.obj: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/modules/nrf/subsys/nrf_security/src/CMakeFiles/mbedcrypto.dir/opt/nordic/ncs/v3.0.0/modules/crypto/mbedtls/library/aes.c.obj: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/modules/nrf/subsys/nrf_security/src/CMakeFiles/mbedcrypto.dir/opt/nordic/ncs/v3.0.0/modules/crypto/mbedtls/library/aesce.c.obj: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/modules/nrf/subsys/nrf_security/src/CMakeFiles/mbedcrypto.dir/opt/nordic/ncs/v3.0.0/modules/crypto/mbedtls/library/aesni.c.obj: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/modules/nrf/subsys/nrf_security/src/CMakeFiles/mbedcrypto.dir/opt/nordic/ncs/v3.0.0/modules/crypto/mbedtls/library/ccm.c.obj: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/modules/nrf/subsys/nrf_security/src/CMakeFiles/mbedcrypto.dir/opt/nordic/ncs/v3.0.0/modules/crypto/mbedtls/library/chachapoly.c.obj: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/modules/nrf/subsys/nrf_security/src/CMakeFiles/mbedcrypto.dir/opt/nordic/ncs/v3.0.0/modules/crypto/mbedtls/library/cipher.c.obj: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/modules/nrf/subsys/nrf_security/src/CMakeFiles/mbedcrypto.dir/opt/nordic/ncs/v3.0.0/modules/crypto/mbedtls/library/cipher_wrap.c.obj: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/modules/nrf/subsys/nrf_security/src/CMakeFiles/mbedcrypto.dir/opt/nordic/ncs/v3.0.0/modules/crypto/mbedtls/library/cmac.c.obj: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/modules/nrf/subsys/nrf_security/src/CMakeFiles/mbedcrypto.dir/opt/nordic/ncs/v3.0.0/modules/crypto/mbedtls/library/ctr_drbg.c.obj: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/modules/nrf/subsys/nrf_security/src/CMakeFiles/mbedcrypto.dir/opt/nordic/ncs/v3.0.0/modules/crypto/mbedtls/library/dhm.c.obj: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/modules/nrf/subsys/nrf_security/src/CMakeFiles/mbedcrypto.dir/opt/nordic/ncs/v3.0.0/modules/crypto/mbedtls/library/ecdh.c.obj: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/modules/nrf/subsys/nrf_security/src/CMakeFiles/mbedcrypto.dir/opt/nordic/ncs/v3.0.0/modules/crypto/mbedtls/library/ecp.c.obj: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/modules/nrf/subsys/nrf_security/src/CMakeFiles/mbedcrypto.dir/opt/nordic/ncs/v3.0.0/modules/crypto/mbedtls/library/ecp_curves.c.obj: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/modules/nrf/subsys/nrf_security/src/CMakeFiles/mbedcrypto.dir/opt/nordic/ncs/v3.0.0/modules/crypto/mbedtls/library/ecp_curves_new.c.obj: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/modules/nrf/subsys/nrf_security/src/CMakeFiles/mbedcrypto.dir/opt/nordic/ncs/v3.0.0/modules/crypto/mbedtls/library/entropy.c.obj: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/modules/nrf/subsys/nrf_security/src/CMakeFiles/mbedcrypto.dir/opt/nordic/ncs/v3.0.0/modules/crypto/mbedtls/library/gcm.c.obj: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/modules/nrf/subsys/nrf_security/src/CMakeFiles/mbedcrypto.dir/opt/nordic/ncs/v3.0.0/modules/crypto/mbedtls/library/hkdf.c.obj: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/modules/nrf/subsys/nrf_security/src/CMakeFiles/mbedcrypto.dir/opt/nordic/ncs/v3.0.0/modules/crypto/mbedtls/library/hmac_drbg.c.obj: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/modules/nrf/subsys/nrf_security/src/CMakeFiles/mbedcrypto.dir/opt/nordic/ncs/v3.0.0/modules/crypto/mbedtls/library/md.c.obj: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/modules/nrf/subsys/nrf_security/src/CMakeFiles/mbedcrypto.dir/opt/nordic/ncs/v3.0.0/modules/crypto/mbedtls/library/md5.c.obj: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/modules/nrf/subsys/nrf_security/src/CMakeFiles/mbedcrypto.dir/opt/nordic/ncs/v3.0.0/modules/crypto/mbedtls/library/pem.c.obj: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/modules/nrf/subsys/nrf_security/src/CMakeFiles/mbedcrypto.dir/opt/nordic/ncs/v3.0.0/modules/crypto/mbedtls/library/pk_ecc.c.obj: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/modules/nrf/subsys/nrf_security/src/CMakeFiles/mbedcrypto.dir/opt/nordic/ncs/v3.0.0/modules/crypto/mbedtls/library/pk_wrap.c.obj: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/modules/nrf/subsys/nrf_security/src/CMakeFiles/mbedcrypto.dir/opt/nordic/ncs/v3.0.0/modules/crypto/mbedtls/library/pkcs12.c.obj: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/modules/nrf/subsys/nrf_security/src/CMakeFiles/mbedcrypto.dir/opt/nordic/ncs/v3.0.0/modules/crypto/mbedtls/library/pkcs5.c.obj: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/modules/nrf/subsys/nrf_security/src/CMakeFiles/mbedcrypto.dir/opt/nordic/ncs/v3.0.0/modules/crypto/mbedtls/library/pkparse.c.obj: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/modules/nrf/subsys/nrf_security/src/CMakeFiles/mbedcrypto.dir/opt/nordic/ncs/v3.0.0/modules/crypto/mbedtls/library/pkwrite.c.obj: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/modules/nrf/subsys/nrf_security/src/CMakeFiles/mbedcrypto.dir/opt/nordic/ncs/v3.0.0/modules/crypto/mbedtls/library/psa_util.c.obj: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/modules/nrf/subsys/nrf_security/src/CMakeFiles/mbedcrypto.dir/opt/nordic/ncs/v3.0.0/modules/crypto/mbedtls/library/rsa.c.obj: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/modules/nrf/subsys/nrf_security/src/CMakeFiles/mbedcrypto.dir/opt/nordic/ncs/v3.0.0/modules/crypto/mbedtls/library/rsa_alt_helpers.c.obj: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/modules/nrf/subsys/nrf_security/src/CMakeFiles/mbedcrypto.dir/opt/nordic/ncs/v3.0.0/modules/crypto/mbedtls/library/sha1.c.obj: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/modules/nrf/subsys/nrf_security/src/CMakeFiles/mbedcrypto.dir/opt/nordic/ncs/v3.0.0/modules/crypto/mbedtls/library/sha256.c.obj: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/modules/nrf/subsys/nrf_security/src/CMakeFiles/mbedcrypto.dir/opt/nordic/ncs/v3.0.0/modules/crypto/mbedtls/library/sha3.c.obj: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/modules/nrf/subsys/nrf_security/src/CMakeFiles/mbedcrypto.dir/opt/nordic/ncs/v3.0.0/modules/crypto/mbedtls/library/sha512.c.obj: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/modules/nrf/subsys/nrf_security/src/CMakeFiles/mbedcrypto.dir/opt/nordic/ncs/v3.0.0/modules/crypto/oberon-psa-crypto/programs/ssl/library/pk.c.obj: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/modules/nrf/subsys/nrf_security/src/CMakeFiles/mbedcrypto_base.dir/opt/nordic/ncs/v3.0.0/modules/crypto/mbedtls/library/asn1parse.c.obj: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/modules/nrf/subsys/nrf_security/src/CMakeFiles/mbedcrypto_base.dir/opt/nordic/ncs/v3.0.0/modules/crypto/mbedtls/library/asn1write.c.obj: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/modules/nrf/subsys/nrf_security/src/CMakeFiles/mbedcrypto_base.dir/opt/nordic/ncs/v3.0.0/modules/crypto/mbedtls/library/base64.c.obj: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/modules/nrf/subsys/nrf_security/src/CMakeFiles/mbedcrypto_base.dir/opt/nordic/ncs/v3.0.0/modules/crypto/mbedtls/library/bignum.c.obj: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/modules/nrf/subsys/nrf_security/src/CMakeFiles/mbedcrypto_base.dir/opt/nordic/ncs/v3.0.0/modules/crypto/mbedtls/library/bignum_core.c.obj: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/modules/nrf/subsys/nrf_security/src/CMakeFiles/mbedcrypto_base.dir/opt/nordic/ncs/v3.0.0/modules/crypto/mbedtls/library/block_cipher.c.obj: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/modules/nrf/subsys/nrf_security/src/CMakeFiles/mbedcrypto_base.dir/opt/nordic/ncs/v3.0.0/modules/crypto/mbedtls/library/constant_time.c.obj: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/modules/nrf/subsys/nrf_security/src/CMakeFiles/mbedcrypto_base.dir/opt/nordic/ncs/v3.0.0/modules/crypto/mbedtls/library/nist_kw.c.obj: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/modules/nrf/subsys/nrf_security/src/CMakeFiles/mbedcrypto_base.dir/opt/nordic/ncs/v3.0.0/modules/crypto/mbedtls/library/oid.c.obj: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/modules/nrf/subsys/nrf_security/src/CMakeFiles/mbedcrypto_base.dir/opt/nordic/ncs/v3.0.0/modules/crypto/mbedtls/library/padlock.c.obj: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/modules/nrf/subsys/nrf_security/src/CMakeFiles/mbedcrypto_base.dir/opt/nordic/ncs/v3.0.0/modules/crypto/mbedtls/library/version.c.obj: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/modules/nrf/subsys/nrf_security/src/CMakeFiles/mbedcrypto_base.dir/opt/nordic/ncs/v3.0.0/modules/crypto/oberon-psa-crypto/library/platform.c.obj: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/modules/nrf/subsys/nrf_security/src/CMakeFiles/mbedcrypto_base.dir/opt/nordic/ncs/v3.0.0/modules/crypto/oberon-psa-crypto/library/platform_util.c.obj: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/modules/nrf/subsys/nrf_security/src/CMakeFiles/mbedtls.dir/opt/nordic/ncs/v3.0.0/modules/crypto/mbedtls/library/debug.c.obj: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/modules/nrf/subsys/nrf_security/src/CMakeFiles/mbedtls.dir/opt/nordic/ncs/v3.0.0/modules/crypto/mbedtls/library/net_sockets.c.obj: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/modules/nrf/subsys/nrf_security/src/CMakeFiles/mbedtls.dir/opt/nordic/ncs/v3.0.0/modules/crypto/mbedtls/library/ssl_cache.c.obj: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/modules/nrf/subsys/nrf_security/src/CMakeFiles/mbedtls.dir/opt/nordic/ncs/v3.0.0/modules/crypto/mbedtls/library/ssl_ciphersuites.c.obj: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/modules/nrf/subsys/nrf_security/src/CMakeFiles/mbedtls.dir/opt/nordic/ncs/v3.0.0/modules/crypto/mbedtls/library/ssl_client.c.obj: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/modules/nrf/subsys/nrf_security/src/CMakeFiles/mbedtls.dir/opt/nordic/ncs/v3.0.0/modules/crypto/mbedtls/library/ssl_cookie.c.obj: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/modules/nrf/subsys/nrf_security/src/CMakeFiles/mbedtls.dir/opt/nordic/ncs/v3.0.0/modules/crypto/mbedtls/library/ssl_debug_helpers_generated.c.obj: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/modules/nrf/subsys/nrf_security/src/CMakeFiles/mbedtls.dir/opt/nordic/ncs/v3.0.0/modules/crypto/mbedtls/library/ssl_msg.c.obj: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/modules/nrf/subsys/nrf_security/src/CMakeFiles/mbedtls.dir/opt/nordic/ncs/v3.0.0/modules/crypto/mbedtls/library/ssl_ticket.c.obj: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/modules/nrf/subsys/nrf_security/src/CMakeFiles/mbedtls.dir/opt/nordic/ncs/v3.0.0/modules/crypto/mbedtls/library/ssl_tls.c.obj: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/modules/nrf/subsys/nrf_security/src/CMakeFiles/mbedtls.dir/opt/nordic/ncs/v3.0.0/modules/crypto/mbedtls/library/ssl_tls12_client.c.obj: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/modules/nrf/subsys/nrf_security/src/CMakeFiles/mbedtls.dir/opt/nordic/ncs/v3.0.0/modules/crypto/mbedtls/library/ssl_tls12_server.c.obj: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/modules/nrf/subsys/nrf_security/src/CMakeFiles/mbedtls.dir/opt/nordic/ncs/v3.0.0/modules/crypto/mbedtls/library/ssl_tls13_client.c.obj: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/modules/nrf/subsys/nrf_security/src/CMakeFiles/mbedtls.dir/opt/nordic/ncs/v3.0.0/modules/crypto/mbedtls/library/ssl_tls13_generic.c.obj: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/modules/nrf/subsys/nrf_security/src/CMakeFiles/mbedtls.dir/opt/nordic/ncs/v3.0.0/modules/crypto/mbedtls/library/ssl_tls13_keys.c.obj: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/modules/nrf/subsys/nrf_security/src/CMakeFiles/mbedtls.dir/opt/nordic/ncs/v3.0.0/modules/crypto/mbedtls/library/ssl_tls13_server.c.obj: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/modules/nrf/subsys/nrf_security/src/CMakeFiles/mbedx509.dir/opt/nordic/ncs/v3.0.0/modules/crypto/mbedtls/library/x509.c.obj: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/modules/nrf/subsys/nrf_security/src/CMakeFiles/mbedx509.dir/opt/nordic/ncs/v3.0.0/modules/crypto/mbedtls/library/x509_create.c.obj: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/modules/nrf/subsys/nrf_security/src/CMakeFiles/mbedx509.dir/opt/nordic/ncs/v3.0.0/modules/crypto/mbedtls/library/x509_crl.c.obj: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/modules/nrf/subsys/nrf_security/src/CMakeFiles/mbedx509.dir/opt/nordic/ncs/v3.0.0/modules/crypto/mbedtls/library/x509_crt.c.obj: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/modules/nrf/subsys/nrf_security/src/CMakeFiles/mbedx509.dir/opt/nordic/ncs/v3.0.0/modules/crypto/mbedtls/library/x509_csr.c.obj: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/modules/nrf/subsys/nrf_security/src/CMakeFiles/mbedx509.dir/opt/nordic/ncs/v3.0.0/modules/crypto/mbedtls/library/x509write.c.obj: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/modules/nrf/subsys/nrf_security/src/CMakeFiles/mbedx509.dir/opt/nordic/ncs/v3.0.0/modules/crypto/mbedtls/library/x509write_crt.c.obj: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/modules/nrf/subsys/nrf_security/src/CMakeFiles/mbedx509.dir/opt/nordic/ncs/v3.0.0/modules/crypto/mbedtls/library/x509write_csr.c.obj: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/modules/nrf/subsys/nrf_security/src/CMakeFiles/nrf_security_utils.dir/utils/nrf_security_events.c.obj: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/modules/nrf/subsys/nrf_security/src/CMakeFiles/nrf_security_utils.dir/utils/nrf_security_mutexes.c.obj: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/modules/nrf/subsys/nrf_security/src/cmake_install.cmake: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/modules/nrf/subsys/nrf_security/src/drivers/cmake_install.cmake: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/modules/nrf/subsys/nrf_security/src/drivers/legacy/cmake_install.cmake: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/modules/nrf/subsys/nrf_security/src/legacy/cmake_install.cmake: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/modules/nrf/subsys/nrf_security/src/libmbedcrypto.a: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/modules/nrf/subsys/nrf_security/src/libmbedcrypto_base.a: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/modules/nrf/subsys/nrf_security/src/libmbedtls.a: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/modules/nrf/subsys/nrf_security/src/libmbedx509.a: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/modules/nrf/subsys/nrf_security/src/libnrf_security_utils.a: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/modules/nrf/subsys/nrf_security/src/zephyr/CMakeFiles/mbedtls_zephyr.dir/opt/nordic/ncs/v3.0.0/modules/crypto/mbedtls/library/platform.c.obj: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/modules/nrf/subsys/nrf_security/src/zephyr/CMakeFiles/mbedtls_zephyr.dir/psa_crypto_init.c.obj: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/modules/nrf/subsys/nrf_security/src/zephyr/cmake_install.cmake: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/modules/nrf/subsys/nrf_security/src/zephyr/libmbedtls_zephyr.a: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/modules/nrf/subsys/partition_manager/cmake_install.cmake: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/modules/nrf/subsys/partition_manager/pm.yml.nvs: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/modules/nrf/subsys/partition_manager/pm.yml.rpmsg_nrf53: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/modules/nrf/subsys/partition_manager/pm.yml.tfm: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/modules/nrf/subsys/partition_manager/pm.yml.trustzone: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/modules/nrf/subsys/shell/cmake_install.cmake: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/modules/nrf/subsys/suit/app_tools/cmake_install.cmake: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/modules/nrf/subsys/suit/cmake_install.cmake: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/modules/nrf/tests/cmake_install.cmake: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/modules/nrf/tests/mocks/cmake_install.cmake: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/modules/nrf_hw_models/cmake_install.cmake: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/modules/nrf_wifi/bus/CMakeFiles/nrf70-buslib.dir/device.c.obj: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/modules/nrf_wifi/bus/CMakeFiles/nrf70-buslib.dir/qspi_if.c.obj: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/modules/nrf_wifi/bus/CMakeFiles/nrf70-buslib.dir/rpu_hw_if.c.obj: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/modules/nrf_wifi/bus/cmake_install.cmake: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/modules/nrf_wifi/bus/libnrf70-buslib.a: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/modules/nrf_wifi/cmake_install.cmake: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/modules/nrf_wifi/os/CMakeFiles/nrf-wifi-shim.dir/shim.c.obj: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/modules/nrf_wifi/os/CMakeFiles/nrf-wifi-shim.dir/timer.c.obj: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/modules/nrf_wifi/os/CMakeFiles/nrf-wifi-shim.dir/work.c.obj: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/modules/nrf_wifi/os/cmake_install.cmake: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/modules/nrf_wifi/os/libnrf-wifi-shim.a: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/modules/nrf_wifi/os/nrf_wifi_osal/CMakeFiles/nrf-wifi-osal.dir/bus_if/bal/src/bal.c.obj: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/modules/nrf_wifi/os/nrf_wifi_osal/CMakeFiles/nrf-wifi-osal.dir/bus_if/bus/qspi/src/qspi.c.obj: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/modules/nrf_wifi/os/nrf_wifi_osal/CMakeFiles/nrf-wifi-osal.dir/fw_if/umac_if/src/common/fmac_api_common.c.obj: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/modules/nrf_wifi/os/nrf_wifi_osal/CMakeFiles/nrf-wifi-osal.dir/fw_if/umac_if/src/common/fmac_cmd_common.c.obj: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/modules/nrf_wifi/os/nrf_wifi_osal/CMakeFiles/nrf-wifi-osal.dir/fw_if/umac_if/src/common/fmac_util.c.obj: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/modules/nrf_wifi/os/nrf_wifi_osal/CMakeFiles/nrf-wifi-osal.dir/fw_if/umac_if/src/system/fmac_api.c.obj: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/modules/nrf_wifi/os/nrf_wifi_osal/CMakeFiles/nrf-wifi-osal.dir/fw_if/umac_if/src/system/fmac_cmd.c.obj: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/modules/nrf_wifi/os/nrf_wifi_osal/CMakeFiles/nrf-wifi-osal.dir/fw_if/umac_if/src/system/fmac_event.c.obj: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/modules/nrf_wifi/os/nrf_wifi_osal/CMakeFiles/nrf-wifi-osal.dir/fw_if/umac_if/src/system/fmac_peer.c.obj: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/modules/nrf_wifi/os/nrf_wifi_osal/CMakeFiles/nrf-wifi-osal.dir/fw_if/umac_if/src/system/fmac_vif.c.obj: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/modules/nrf_wifi/os/nrf_wifi_osal/CMakeFiles/nrf-wifi-osal.dir/fw_if/umac_if/src/system/rx.c.obj: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/modules/nrf_wifi/os/nrf_wifi_osal/CMakeFiles/nrf-wifi-osal.dir/fw_if/umac_if/src/system/tx.c.obj: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/modules/nrf_wifi/os/nrf_wifi_osal/CMakeFiles/nrf-wifi-osal.dir/hw_if/hal/src/common/hal_api_common.c.obj: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/modules/nrf_wifi/os/nrf_wifi_osal/CMakeFiles/nrf-wifi-osal.dir/hw_if/hal/src/common/hal_fw_patch_loader.c.obj: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/modules/nrf_wifi/os/nrf_wifi_osal/CMakeFiles/nrf-wifi-osal.dir/hw_if/hal/src/common/hal_interrupt.c.obj: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/modules/nrf_wifi/os/nrf_wifi_osal/CMakeFiles/nrf-wifi-osal.dir/hw_if/hal/src/common/hal_mem.c.obj: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/modules/nrf_wifi/os/nrf_wifi_osal/CMakeFiles/nrf-wifi-osal.dir/hw_if/hal/src/common/hal_reg.c.obj: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/modules/nrf_wifi/os/nrf_wifi_osal/CMakeFiles/nrf-wifi-osal.dir/hw_if/hal/src/common/hpqm.c.obj: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/modules/nrf_wifi/os/nrf_wifi_osal/CMakeFiles/nrf-wifi-osal.dir/hw_if/hal/src/common/pal.c.obj: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/modules/nrf_wifi/os/nrf_wifi_osal/CMakeFiles/nrf-wifi-osal.dir/hw_if/hal/src/system/hal_api.c.obj: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/modules/nrf_wifi/os/nrf_wifi_osal/CMakeFiles/nrf-wifi-osal.dir/os_if/src/osal.c.obj: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/modules/nrf_wifi/os/nrf_wifi_osal/CMakeFiles/nrf-wifi-osal.dir/utils/src/list.c.obj: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/modules/nrf_wifi/os/nrf_wifi_osal/CMakeFiles/nrf-wifi-osal.dir/utils/src/queue.c.obj: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/modules/nrf_wifi/os/nrf_wifi_osal/CMakeFiles/nrf-wifi-osal.dir/utils/src/util.c.obj: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/modules/nrf_wifi/os/nrf_wifi_osal/cmake_install.cmake: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/modules/nrf_wifi/os/nrf_wifi_osal/libnrf-wifi-osal.a: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/modules/nrfxlib/cmake_install.cmake: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/modules/nrfxlib/nrf_802154/cmake_install.cmake: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/modules/nrfxlib/nrfxlib/cmake_install.cmake: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/modules/open-amp/cmake_install.cmake: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/modules/openthread/cmake_install.cmake: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/modules/percepio/cmake_install.cmake: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/modules/picolibc/cmake_install.cmake: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/modules/segger/cmake_install.cmake: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/modules/suit-processor/cmake_install.cmake: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/modules/tinycrypt/cmake_install.cmake: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/modules/trusted-firmware-m/CMakeFiles/tfm-complete: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/modules/trusted-firmware-m/CMakeFiles/tfm.dir/Labels.json: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/modules/trusted-firmware-m/CMakeFiles/tfm.dir/Labels.txt: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/modules/trusted-firmware-m/CMakeFiles/tfm_api.dir/__/__/tfm/api_ns/interface/src/tfm_crypto_api.c.obj: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/modules/trusted-firmware-m/CMakeFiles/tfm_api.dir/__/__/tfm/api_ns/interface/src/tfm_ioctl_core_ns_api.c.obj: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/modules/trusted-firmware-m/CMakeFiles/tfm_api.dir/__/__/tfm/api_ns/interface/src/tfm_platform_api.c.obj: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/modules/trusted-firmware-m/CMakeFiles/tfm_api.dir/__/__/tfm/api_ns/interface/src/tfm_tz_psa_ns_api.c.obj: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/modules/trusted-firmware-m/CMakeFiles/tfm_api.dir/interface/interface.c.obj: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/modules/trusted-firmware-m/CMakeFiles/tfm_api.dir/src/zephyr_tfm_log.c.obj: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/modules/trusted-firmware-m/cmake_install.cmake: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/modules/trusted-firmware-m/libtfm_api.a: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/modules/trusted-firmware-m/tfm-prefix/src/tfm-stamp/tfm-configure: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/modules/trusted-firmware-m/tfm-prefix/src/tfm-stamp/tfm-done: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/modules/trusted-firmware-m/tfm-prefix/src/tfm-stamp/tfm-download: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/modules/trusted-firmware-m/tfm-prefix/src/tfm-stamp/tfm-mkdir: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/modules/trusted-firmware-m/tfm-prefix/src/tfm-stamp/tfm-patch: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/modules/trusted-firmware-m/tfm-prefix/src/tfm-stamp/tfm-patch-info.txt: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/modules/trusted-firmware-m/tfm-prefix/src/tfm-stamp/tfm-source_dirinfo.txt: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/modules/trusted-firmware-m/tfm-prefix/src/tfm-stamp/tfm-update: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/modules/trusted-firmware-m/tfm-prefix/src/tfm-stamp/tfm-update-info.txt: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/modules/trusted-firmware-m/tfm-prefix/tmp/tfm-cfgcmd.txt: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/modules/trusted-firmware-m/tfm-prefix/tmp/tfm-mkdirs.cmake: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/modules/uoscore-uedhoc/cmake_install.cmake: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/modules/zcbor/cmake_install.cmake: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/modules/zscilib/cmake_install.cmake: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/snippets_generated.cmake: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/sysbuild_modules.txt: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/tfm/.ninja_deps: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/tfm/.ninja_log: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/tfm/CMakeCache.txt: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/tfm/CMakeFiles/4.0.2/CMakeASMCompiler.cmake: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/tfm/CMakeFiles/4.0.2/CMakeCCompiler.cmake: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/tfm/CMakeFiles/4.0.2/CMakeCXXCompiler.cmake: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/tfm/CMakeFiles/4.0.2/CMakeSystem.cmake: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/tfm/CMakeFiles/4.0.2/CompilerIdC/CMakeCCompilerId.c: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/tfm/CMakeFiles/4.0.2/CompilerIdC/CMakeCCompilerId.o: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/tfm/CMakeFiles/4.0.2/CompilerIdCXX/CMakeCXXCompilerId.cpp: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/tfm/CMakeFiles/4.0.2/CompilerIdCXX/CMakeCXXCompilerId.o: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/tfm/CMakeFiles/CMakeConfigureLog.yaml: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/tfm/CMakeFiles/Export/1172117e00be505bcb5d9c698f0b106e/spe_export.cmake: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/tfm/CMakeFiles/InstallScripts.json: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/tfm/CMakeFiles/TargetDirectories.txt: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/tfm/CMakeFiles/cmake.check_cache: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/tfm/CMakeFiles/rules.ninja: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/tfm/api_ns/CMakeLists.txt: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/tfm/api_ns/bin/tfm_s.axf: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/tfm/api_ns/bin/tfm_s.bin: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/tfm/api_ns/bin/tfm_s.elf: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/tfm/api_ns/bin/tfm_s.hex: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/tfm/api_ns/bin/tfm_s.map: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/tfm/api_ns/cmake/set_extensions.cmake: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/tfm/api_ns/cmake/spe_config.cmake: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/tfm/api_ns/cmake/spe_export.cmake: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/tfm/api_ns/cmake/toolchain_ns_ARMCLANG.cmake: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/tfm/api_ns/cmake/toolchain_ns_GNUARM.cmake: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/tfm/api_ns/cmake/toolchain_ns_IARARM.cmake: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/tfm/api_ns/common/config.cmake: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/tfm/api_ns/config/cp_check.cmake: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/tfm/api_ns/interface/include/RTE_Device.h: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/tfm/api_ns/interface/include/config_base.h: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/tfm/api_ns/interface/include/config_impl.h: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/tfm/api_ns/interface/include/config_tfm.h: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/tfm/api_ns/interface/include/device_cfg.h: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/tfm/api_ns/interface/include/mbedtls/build_info.h: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/tfm/api_ns/interface/include/mbedtls/config_psa.h: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/tfm/api_ns/interface/include/nrf-config.h: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/tfm/api_ns/interface/include/nrf-psa-crypto-config.h: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/tfm/api_ns/interface/include/os_wrapper/common.h: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/tfm/api_ns/interface/include/os_wrapper/mutex.h: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/tfm/api_ns/interface/include/psa/build_info.h: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/tfm/api_ns/interface/include/psa/client.h: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/tfm/api_ns/interface/include/psa/crypto.h: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/tfm/api_ns/interface/include/psa/crypto_adjust_auto_enabled.h: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/tfm/api_ns/interface/include/psa/crypto_adjust_config_key_pair_types.h: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/tfm/api_ns/interface/include/psa/crypto_adjust_config_synonyms.h: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/tfm/api_ns/interface/include/psa/crypto_compat.h: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/tfm/api_ns/interface/include/psa/crypto_driver_common.h: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/tfm/api_ns/interface/include/psa/crypto_driver_contexts_composites.h: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/tfm/api_ns/interface/include/psa/crypto_driver_contexts_key_derivation.h: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/tfm/api_ns/interface/include/psa/crypto_driver_contexts_primitives.h: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/tfm/api_ns/interface/include/psa/crypto_extra.h: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/tfm/api_ns/interface/include/psa/crypto_legacy.h: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/tfm/api_ns/interface/include/psa/crypto_platform.h: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/tfm/api_ns/interface/include/psa/crypto_se_driver.h: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/tfm/api_ns/interface/include/psa/crypto_sizes.h: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/tfm/api_ns/interface/include/psa/crypto_struct.h: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/tfm/api_ns/interface/include/psa/crypto_types.h: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/tfm/api_ns/interface/include/psa/crypto_values.h: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/tfm/api_ns/interface/include/psa/error.h: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/tfm/api_ns/interface/include/psa/framework_feature.h: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/tfm/api_ns/interface/include/psa_manifest/sid.h: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/tfm/api_ns/interface/include/tfm_ioctl_core_api.h: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/tfm/api_ns/interface/include/tfm_ns_client_ext.h: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/tfm/api_ns/interface/include/tfm_ns_interface.h: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/tfm/api_ns/interface/include/tfm_platform_api.h: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/tfm/api_ns/interface/include/tfm_psa_call_pack.h: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/tfm/api_ns/interface/include/tfm_veneers.h: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/tfm/api_ns/interface/lib/s_veneers.o: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/tfm/api_ns/interface/src/os_wrapper/tfm_ns_interface_bare_metal.c: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/tfm/api_ns/interface/src/os_wrapper/tfm_ns_interface_rtos.c: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/tfm/api_ns/interface/src/tfm_crypto_api.c: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/tfm/api_ns/interface/src/tfm_ioctl_core_ns_api.c: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/tfm/api_ns/interface/src/tfm_platform_api.c: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/tfm/api_ns/interface/src/tfm_tz_psa_ns_api.c: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/tfm/api_ns/platform/CMakeLists.txt: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/tfm/api_ns/platform/common/assert.c: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/tfm/api_ns/platform/common/attest_hal.c: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/tfm/api_ns/platform/common/config.cmake: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/tfm/api_ns/platform/common/core/CMakeLists.txt: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/tfm/api_ns/platform/common/core/cmsis_drivers/Driver_Flash.c: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/tfm/api_ns/platform/common/core/cmsis_drivers/Driver_USART.c: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/tfm/api_ns/platform/common/core/common/cmsis.h: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/tfm/api_ns/platform/common/core/common/nrf-pinctrl.h: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/tfm/api_ns/platform/common/core/common/nrfx_glue.h: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/tfm/api_ns/platform/common/core/common/nrfx_log.h: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/tfm/api_ns/platform/common/core/common/tfm_hal_platform_common.h: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/tfm/api_ns/platform/common/core/config.cmake: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/tfm/api_ns/platform/common/core/config_nordic_nrf_spe.cmake: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/tfm/api_ns/platform/common/core/native_drivers/mpu_armv8m_drv.c: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/tfm/api_ns/platform/common/core/native_drivers/mpu_armv8m_drv.h: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/tfm/api_ns/platform/common/core/native_drivers/spu.c: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/tfm/api_ns/platform/common/core/native_drivers/spu.h: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/tfm/api_ns/platform/common/core/nrfx/nrfx.h: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/tfm/api_ns/platform/common/core/nrfx_config.h: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/tfm/api_ns/platform/common/core/nrfx_glue.c: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/tfm/api_ns/platform/common/core/pal_plat_test.c: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/tfm/api_ns/platform/common/core/pal_plat_test.h: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/tfm/api_ns/platform/common/core/services/include/tfm_ioctl_core_api.h: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/tfm/api_ns/platform/common/core/services/include/tfm_platform_hal_ioctl.h: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/tfm/api_ns/platform/common/core/services/src/tfm_ioctl_core_ns_api.c: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/tfm/api_ns/platform/common/core/services/src/tfm_ioctl_core_s_api.c: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/tfm/api_ns/platform/common/core/services/src/tfm_platform_hal_ioctl.c: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/tfm/api_ns/platform/common/core/startup.c: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/tfm/api_ns/platform/common/core/startup.h: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/tfm/api_ns/platform/common/core/startup_nrf5340.c: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/tfm/api_ns/platform/common/core/target_cfg.h: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/tfm/api_ns/platform/common/core/tests/tfm_tests_config.cmake: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/tfm/api_ns/platform/common/crypto_keys.c: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/tfm/api_ns/platform/common/dummy_otp.c: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/tfm/api_ns/platform/common/dummy_provisioning.c: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/tfm/api_ns/platform/common/dummy_tfm_sp_log_raw.c: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/tfm/api_ns/platform/common/dummy_uart_stdout.c: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/tfm/api_ns/platform/common/nrf5340/CMakeLists.txt: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/tfm/api_ns/platform/common/nrf5340/config.cmake: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/tfm/api_ns/platform/common/nrf5340/cpuarch.cmake: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/tfm/api_ns/platform/common/nrf5340/nrfx_config_nrf5340_application.h: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/tfm/api_ns/platform/common/nrf5340/partition/flash_layout.h: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/tfm/api_ns/platform/common/nrf5340/partition/region_defs.h: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/tfm/api_ns/platform/common/nrf5340/tests/psa_arch_tests_config.cmake: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/tfm/api_ns/platform/common/nrf_provisioning.c: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/tfm/api_ns/platform/common/nrf_provisioning.h: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/tfm/api_ns/platform/common/ns_fault_service.c: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/tfm/api_ns/platform/common/tfm_hal_platform.c: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/tfm/api_ns/platform/common/tfm_hal_reset_halt.c: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/tfm/api_ns/platform/config.cmake: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/tfm/api_ns/platform/cpuarch.cmake: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/tfm/api_ns/platform/ext/cmsis/Include/a-profile/cmsis_armclang_a.h: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/tfm/api_ns/platform/ext/cmsis/Include/a-profile/cmsis_clang_a.h: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/tfm/api_ns/platform/ext/cmsis/Include/a-profile/cmsis_cp15.h: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/tfm/api_ns/platform/ext/cmsis/Include/a-profile/cmsis_gcc_a.h: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/tfm/api_ns/platform/ext/cmsis/Include/a-profile/cmsis_iccarm_a.h: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/tfm/api_ns/platform/ext/cmsis/Include/a-profile/irq_ctrl.h: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/tfm/api_ns/platform/ext/cmsis/Include/cmsis_compiler.h: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/tfm/api_ns/platform/ext/cmsis/Include/cmsis_version.h: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/tfm/api_ns/platform/ext/cmsis/Include/core_ca.h: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/tfm/api_ns/platform/ext/cmsis/Include/core_cm0.h: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/tfm/api_ns/platform/ext/cmsis/Include/core_cm0plus.h: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/tfm/api_ns/platform/ext/cmsis/Include/core_cm1.h: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/tfm/api_ns/platform/ext/cmsis/Include/core_cm23.h: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/tfm/api_ns/platform/ext/cmsis/Include/core_cm3.h: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/tfm/api_ns/platform/ext/cmsis/Include/core_cm33.h: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/tfm/api_ns/platform/ext/cmsis/Include/core_cm35p.h: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/tfm/api_ns/platform/ext/cmsis/Include/core_cm4.h: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/tfm/api_ns/platform/ext/cmsis/Include/core_cm52.h: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/tfm/api_ns/platform/ext/cmsis/Include/core_cm55.h: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/tfm/api_ns/platform/ext/cmsis/Include/core_cm7.h: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/tfm/api_ns/platform/ext/cmsis/Include/core_cm85.h: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/tfm/api_ns/platform/ext/cmsis/Include/core_sc000.h: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/tfm/api_ns/platform/ext/cmsis/Include/core_sc300.h: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/tfm/api_ns/platform/ext/cmsis/Include/core_starmc1.h: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/tfm/api_ns/platform/ext/cmsis/Include/m-profile/armv7m_cachel1.h: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/tfm/api_ns/platform/ext/cmsis/Include/m-profile/armv7m_mpu.h: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/tfm/api_ns/platform/ext/cmsis/Include/m-profile/armv81m_pac.h: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/tfm/api_ns/platform/ext/cmsis/Include/m-profile/armv8m_mpu.h: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/tfm/api_ns/platform/ext/cmsis/Include/m-profile/armv8m_pmu.h: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/tfm/api_ns/platform/ext/cmsis/Include/m-profile/cmsis_armclang_m.h: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/tfm/api_ns/platform/ext/cmsis/Include/m-profile/cmsis_clang_m.h: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/tfm/api_ns/platform/ext/cmsis/Include/m-profile/cmsis_gcc_m.h: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/tfm/api_ns/platform/ext/cmsis/Include/m-profile/cmsis_iccarm_m.h: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/tfm/api_ns/platform/ext/cmsis/Include/m-profile/cmsis_tiarmclang_m.h: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/tfm/api_ns/platform/ext/cmsis/Include/tz_context.h: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/tfm/api_ns/platform/ext/common/uart_stdout.c: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/tfm/api_ns/platform/ext/common/uart_stdout.h: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/tfm/api_ns/platform/ext/driver/Driver_Common.h: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/tfm/api_ns/platform/ext/driver/Driver_Flash.h: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/tfm/api_ns/platform/ext/driver/Driver_USART.h: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/tfm/api_ns/platform/include/boot_hal.h: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/tfm/api_ns/platform/include/cmsis_override.h: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/tfm/api_ns/platform/include/exception_info.h: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/tfm/api_ns/platform/include/fatal_error.h: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/tfm/api_ns/platform/include/fih.h: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/tfm/api_ns/platform/include/mbedtls_entropy_nv_seed_config.h: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/tfm/api_ns/platform/include/region.h: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/tfm/api_ns/platform/include/tfm_attest_hal.h: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/tfm/api_ns/platform/include/tfm_hal_defs.h: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/tfm/api_ns/platform/include/tfm_hal_device_header.h: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/tfm/api_ns/platform/include/tfm_hal_interrupt.h: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/tfm/api_ns/platform/include/tfm_hal_isolation.h: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/tfm/api_ns/platform/include/tfm_hal_its.h: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/tfm/api_ns/platform/include/tfm_hal_its_encryption.h: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/tfm/api_ns/platform/include/tfm_hal_mailbox.h: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/tfm/api_ns/platform/include/tfm_hal_multi_core.h: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/tfm/api_ns/platform/include/tfm_hal_platform.h: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/tfm/api_ns/platform/include/tfm_hal_ps.h: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/tfm/api_ns/platform/include/tfm_plat_boot_seed.h: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/tfm/api_ns/platform/include/tfm_plat_config.h: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/tfm/api_ns/platform/include/tfm_plat_crypto_keys.h: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/tfm/api_ns/platform/include/tfm_plat_crypto_nv_seed.h: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/tfm/api_ns/platform/include/tfm_plat_defs.h: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/tfm/api_ns/platform/include/tfm_plat_device_id.h: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/tfm/api_ns/platform/include/tfm_plat_ns.h: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/tfm/api_ns/platform/include/tfm_plat_nv_counters.h: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/tfm/api_ns/platform/include/tfm_plat_otp.h: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/tfm/api_ns/platform/include/tfm_plat_provisioning.h: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/tfm/api_ns/platform/include/tfm_plat_rotpk.h: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/tfm/api_ns/platform/include/tfm_plat_test.h: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/tfm/api_ns/platform/include/tfm_platform_system.h: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/tfm/api_ns/platform/linker_scripts/tfm_common_ns.ld: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/tfm/api_ns/platform/tests/psa_arch_tests_config.cmake: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/tfm/api_ns/platform/tests/tfm_tests_config.cmake: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/tfm/bin/tfm_s.axf: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/tfm/bin/tfm_s.bin: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/tfm/bin/tfm_s.elf: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/tfm/bin/tfm_s.hex: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/tfm/bin/tfm_s.map: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/tfm/build.ninja: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/tfm/cmake_install.cmake: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/tfm/config_nordic_nrf_spe.cmake: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/tfm/generated/interface/include/config_impl.h: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/tfm/generated/interface/include/psa/framework_feature.h: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/tfm/generated/interface/include/psa_manifest/pid.h: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/tfm/generated/interface/include/psa_manifest/sid.h: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/tfm/generated/secure_fw/partitions/crypto/auto_generated/intermedia_tfm_crypto.c: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/tfm/generated/secure_fw/partitions/crypto/auto_generated/load_info_tfm_crypto.c: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/tfm/generated/secure_fw/partitions/crypto/psa_manifest/tfm_crypto.h: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/tfm/generated/secure_fw/partitions/platform/auto_generated/intermedia_tfm_platform.c: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/tfm/generated/secure_fw/partitions/platform/auto_generated/load_info_tfm_platform.c: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/tfm/generated/secure_fw/partitions/platform/psa_manifest/tfm_platform.h: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/tfm/generated/secure_fw/spm/include/tfm_version.h: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/tfm/generated/tools/config_impl.cmake: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/tfm/install_manifest.txt: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/tfm/interface/cmake_install.cmake: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/tfm/lib/ext/cmake_install.cmake: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/tfm/lib/ext/cmsis/cmake_install.cmake: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/tfm/lib/ext/mbedcrypto/cmake_install.cmake: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/tfm/lib/ext/tf-m-extras/cmake_install.cmake: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/tfm/lib/fih/CMakeFiles/tfm_fih.dir/src/fih.o: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/tfm/lib/fih/cmake_install.cmake: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/tfm/lib/fih/libtfm_fih.a: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/tfm/platform/CMakeFiles/platform_crypto_keys.dir/ext/common/syscalls_stub.o: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/tfm/platform/CMakeFiles/platform_s.dir/ext/common/exception_info.o: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/tfm/platform/CMakeFiles/platform_s.dir/ext/common/syscalls_stub.o: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/tfm/platform/CMakeFiles/platform_s.dir/ext/common/tfm_fatal_error.o: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/tfm/platform/CMakeFiles/platform_s.dir/ext/common/tfm_hal_spm_logdev_peripheral.o: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/tfm/platform/CMakeFiles/platform_s.dir/ext/common/uart_stdout.o: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/tfm/platform/CMakeFiles/platform_s.dir/ext/target/nordic_nrf/common/core/cmsis_drivers/Driver_USART.o: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/tfm/platform/CMakeFiles/platform_s.dir/ext/target/nordic_nrf/common/core/native_drivers/mpu_armv8m_drv.o: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/tfm/platform/CMakeFiles/platform_s.dir/ext/target/nordic_nrf/common/core/native_drivers/spu.o: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/tfm/platform/CMakeFiles/platform_s.dir/ext/target/nordic_nrf/common/core/nrf_exception_info.o: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/tfm/platform/CMakeFiles/platform_s.dir/ext/target/nordic_nrf/common/core/nrfx_glue.o: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/tfm/platform/CMakeFiles/platform_s.dir/ext/target/nordic_nrf/common/core/services/src/tfm_ioctl_core_s_api.o: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/tfm/platform/CMakeFiles/platform_s.dir/ext/target/nordic_nrf/common/core/services/src/tfm_platform_hal_ioctl.o: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/tfm/platform/CMakeFiles/platform_s.dir/opt/nordic/ncs/v3.0.0/modules/hal/nordic/nrfx/drivers/src/nrfx_nvmc.o: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/tfm/platform/CMakeFiles/platform_s.dir/opt/nordic/ncs/v3.0.0/modules/hal/nordic/nrfx/drivers/src/nrfx_uarte.o: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/tfm/platform/CMakeFiles/platform_s.dir/opt/nordic/ncs/v3.0.0/modules/hal/nordic/nrfx/mdk/system_nrf5340_application.o: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/tfm/platform/CMakeFiles/platform_s.dir/opt/nordic/ncs/v3.0.0/nrf/modules/trusted-firmware-m/tfm_boards/common/assert.o: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/tfm/platform/CMakeFiles/platform_s.dir/opt/nordic/ncs/v3.0.0/nrf/modules/trusted-firmware-m/tfm_boards/common/dummy_otp.o: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/tfm/platform/CMakeFiles/platform_s.dir/opt/nordic/ncs/v3.0.0/nrf/modules/trusted-firmware-m/tfm_boards/common/dummy_provisioning.o: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/tfm/platform/CMakeFiles/platform_s.dir/opt/nordic/ncs/v3.0.0/nrf/modules/trusted-firmware-m/tfm_boards/common/ns_fault_service.o: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/tfm/platform/CMakeFiles/platform_s.dir/opt/nordic/ncs/v3.0.0/nrf/modules/trusted-firmware-m/tfm_boards/common/tfm_hal_platform.o: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/tfm/platform/CMakeFiles/platform_s.dir/opt/nordic/ncs/v3.0.0/nrf/modules/trusted-firmware-m/tfm_boards/common/tfm_hal_reset_halt.o: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/tfm/platform/CMakeFiles/platform_s.dir/opt/nordic/ncs/v3.0.0/nrf/modules/trusted-firmware-m/tfm_boards/src/tfm_ioctl_s_api.o: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/tfm/platform/CMakeFiles/platform_s.dir/opt/nordic/ncs/v3.0.0/nrf/modules/trusted-firmware-m/tfm_boards/src/tfm_platform_system.o: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/tfm/platform/cmake_install.cmake: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/tfm/platform/ext/accelerator/cmake_install.cmake: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/tfm/platform/libplatform_crypto_keys.a: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/tfm/platform/libplatform_s.a: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/tfm/platform/target/cmake_install.cmake: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/tfm/platform/target/nrf5340/cmake_install.cmake: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/tfm/platform/target/nrf5340/nrf_common/CMakeFiles/tfm_s_scatter.dir/__/__/__/__/common/gcc/tfm_common_s.ld: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/tfm/platform/target/nrf5340/nrf_common/cmake_install.cmake: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/tfm/platform/target/tfm_board/cmake_install.cmake: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/tfm/secure_fw/CMakeFiles/tfm_s.dir/__/generated/secure_fw/partitions/crypto/auto_generated/load_info_tfm_crypto.o: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/tfm/secure_fw/CMakeFiles/tfm_s.dir/__/generated/secure_fw/partitions/platform/auto_generated/load_info_tfm_platform.o: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/tfm/secure_fw/CMakeFiles/tfm_s.dir/__/platform/ext/common/faults.o: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/tfm/secure_fw/CMakeFiles/tfm_s.dir/__/platform/ext/common/syscalls_stub.o: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/tfm/secure_fw/CMakeFiles/tfm_s.dir/__/platform/ext/target/nordic_nrf/common/core/startup.o: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/tfm/secure_fw/CMakeFiles/tfm_s.dir/__/platform/ext/target/nordic_nrf/common/core/startup_nrf5340.o: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/tfm/secure_fw/CMakeFiles/tfm_s.dir/partitions/ns_agent_tz/load_info_ns_agent_tz.o: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/tfm/secure_fw/CMakeFiles/tfm_s.dir/partitions/ns_agent_tz/psa_api_veneers_v80m.o: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/tfm/secure_fw/cmake_install.cmake: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/tfm/secure_fw/libtfm_s_veneers.a: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/tfm/secure_fw/partitions/cmake_install.cmake: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/tfm/secure_fw/partitions/crypto/CMakeFiles/tfm_psa_rot_partition_crypto.dir/__/__/__/generated/secure_fw/partitions/crypto/auto_generated/intermedia_tfm_crypto.o: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/tfm/secure_fw/partitions/crypto/CMakeFiles/tfm_psa_rot_partition_crypto.dir/crypto_aead.o: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/tfm/secure_fw/partitions/crypto/CMakeFiles/tfm_psa_rot_partition_crypto.dir/crypto_alloc.o: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/tfm/secure_fw/partitions/crypto/CMakeFiles/tfm_psa_rot_partition_crypto.dir/crypto_asymmetric.o: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/tfm/secure_fw/partitions/crypto/CMakeFiles/tfm_psa_rot_partition_crypto.dir/crypto_cipher.o: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/tfm/secure_fw/partitions/crypto/CMakeFiles/tfm_psa_rot_partition_crypto.dir/crypto_hash.o: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/tfm/secure_fw/partitions/crypto/CMakeFiles/tfm_psa_rot_partition_crypto.dir/crypto_init.o: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/tfm/secure_fw/partitions/crypto/CMakeFiles/tfm_psa_rot_partition_crypto.dir/crypto_key_derivation.o: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/tfm/secure_fw/partitions/crypto/CMakeFiles/tfm_psa_rot_partition_crypto.dir/crypto_key_management.o: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/tfm/secure_fw/partitions/crypto/CMakeFiles/tfm_psa_rot_partition_crypto.dir/crypto_library.o: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/tfm/secure_fw/partitions/crypto/CMakeFiles/tfm_psa_rot_partition_crypto.dir/crypto_mac.o: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/tfm/secure_fw/partitions/crypto/CMakeFiles/tfm_psa_rot_partition_crypto.dir/crypto_pake.o: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/tfm/secure_fw/partitions/crypto/CMakeFiles/tfm_psa_rot_partition_crypto.dir/crypto_rng.o: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/tfm/secure_fw/partitions/crypto/cmake_install.cmake: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/tfm/secure_fw/partitions/crypto/libtfm_psa_rot_partition_crypto.a: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/tfm/secure_fw/partitions/crypto/mbedcrypto/cmake_install.cmake: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/tfm/secure_fw/partitions/crypto/mbedcrypto/nrf_security_crypto/cmake_install.cmake: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/tfm/secure_fw/partitions/crypto/mbedcrypto/nrf_security_src/CMakeFiles/crypto_service_mbedcrypto.dir/opt/nordic/ncs/v3.0.0/modules/crypto/mbedtls/library/memory_buffer_alloc.o: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/tfm/secure_fw/partitions/crypto/mbedcrypto/nrf_security_src/CMakeFiles/mbedcrypto_base.dir/opt/nordic/ncs/v3.0.0/modules/crypto/mbedtls/library/asn1parse.o: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/tfm/secure_fw/partitions/crypto/mbedcrypto/nrf_security_src/CMakeFiles/mbedcrypto_base.dir/opt/nordic/ncs/v3.0.0/modules/crypto/mbedtls/library/asn1write.o: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/tfm/secure_fw/partitions/crypto/mbedcrypto/nrf_security_src/CMakeFiles/mbedcrypto_base.dir/opt/nordic/ncs/v3.0.0/modules/crypto/mbedtls/library/base64.o: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/tfm/secure_fw/partitions/crypto/mbedcrypto/nrf_security_src/CMakeFiles/mbedcrypto_base.dir/opt/nordic/ncs/v3.0.0/modules/crypto/mbedtls/library/bignum.o: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/tfm/secure_fw/partitions/crypto/mbedcrypto/nrf_security_src/CMakeFiles/mbedcrypto_base.dir/opt/nordic/ncs/v3.0.0/modules/crypto/mbedtls/library/bignum_core.o: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/tfm/secure_fw/partitions/crypto/mbedcrypto/nrf_security_src/CMakeFiles/mbedcrypto_base.dir/opt/nordic/ncs/v3.0.0/modules/crypto/mbedtls/library/block_cipher.o: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/tfm/secure_fw/partitions/crypto/mbedcrypto/nrf_security_src/CMakeFiles/mbedcrypto_base.dir/opt/nordic/ncs/v3.0.0/modules/crypto/mbedtls/library/constant_time.o: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/tfm/secure_fw/partitions/crypto/mbedcrypto/nrf_security_src/CMakeFiles/mbedcrypto_base.dir/opt/nordic/ncs/v3.0.0/modules/crypto/mbedtls/library/nist_kw.o: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/tfm/secure_fw/partitions/crypto/mbedcrypto/nrf_security_src/CMakeFiles/mbedcrypto_base.dir/opt/nordic/ncs/v3.0.0/modules/crypto/mbedtls/library/oid.o: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/tfm/secure_fw/partitions/crypto/mbedcrypto/nrf_security_src/CMakeFiles/mbedcrypto_base.dir/opt/nordic/ncs/v3.0.0/modules/crypto/mbedtls/library/padlock.o: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/tfm/secure_fw/partitions/crypto/mbedcrypto/nrf_security_src/CMakeFiles/mbedcrypto_base.dir/opt/nordic/ncs/v3.0.0/modules/crypto/mbedtls/library/version.o: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/tfm/secure_fw/partitions/crypto/mbedcrypto/nrf_security_src/CMakeFiles/nrf_security_utils.dir/utils/nrf_security_events.o: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/tfm/secure_fw/partitions/crypto/mbedcrypto/nrf_security_src/CMakeFiles/nrf_security_utils.dir/utils/nrf_security_mutexes.o: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/tfm/secure_fw/partitions/crypto/mbedcrypto/nrf_security_src/cmake_install.cmake: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/tfm/secure_fw/partitions/crypto/mbedcrypto/nrf_security_src/core/cmake_install.cmake: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/tfm/secure_fw/partitions/crypto/mbedcrypto/nrf_security_src/core/nrf_oberon/CMakeFiles/oberon_psa_core.dir/opt/nordic/ncs/v3.0.0/modules/crypto/oberon-psa-crypto/library/platform.o: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/tfm/secure_fw/partitions/crypto/mbedcrypto/nrf_security_src/core/nrf_oberon/CMakeFiles/oberon_psa_core.dir/opt/nordic/ncs/v3.0.0/modules/crypto/oberon-psa-crypto/library/platform_util.o: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/tfm/secure_fw/partitions/crypto/mbedcrypto/nrf_security_src/core/nrf_oberon/CMakeFiles/oberon_psa_core.dir/opt/nordic/ncs/v3.0.0/modules/crypto/oberon-psa-crypto/library/psa_crypto.o: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/tfm/secure_fw/partitions/crypto/mbedcrypto/nrf_security_src/core/nrf_oberon/CMakeFiles/oberon_psa_core.dir/opt/nordic/ncs/v3.0.0/modules/crypto/oberon-psa-crypto/library/psa_crypto_client.o: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/tfm/secure_fw/partitions/crypto/mbedcrypto/nrf_security_src/core/nrf_oberon/CMakeFiles/oberon_psa_core.dir/opt/nordic/ncs/v3.0.0/modules/crypto/oberon-psa-crypto/library/psa_crypto_slot_management.o: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/tfm/secure_fw/partitions/crypto/mbedcrypto/nrf_security_src/core/nrf_oberon/CMakeFiles/oberon_psa_core.dir/opt/nordic/ncs/v3.0.0/modules/crypto/oberon-psa-crypto/library/psa_crypto_storage.o: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/tfm/secure_fw/partitions/crypto/mbedcrypto/nrf_security_src/core/nrf_oberon/CMakeFiles/oberon_psa_core.dir/opt/nordic/ncs/v3.0.0/nrf/subsys/nrf_security/src/psa_crypto_driver_wrappers.o: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/tfm/secure_fw/partitions/crypto/mbedcrypto/nrf_security_src/core/nrf_oberon/cmake_install.cmake: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/tfm/secure_fw/partitions/crypto/mbedcrypto/nrf_security_src/core/nrf_oberon/liboberon_psa_core.a: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/tfm/secure_fw/partitions/crypto/mbedcrypto/nrf_security_src/drivers/cmake_install.cmake: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/tfm/secure_fw/partitions/crypto/mbedcrypto/nrf_security_src/drivers/nrf_cc3xx_platform/cmake_install.cmake: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/tfm/secure_fw/partitions/crypto/mbedcrypto/nrf_security_src/drivers/nrf_oberon/CMakeFiles/oberon_psa_driver.dir/opt/nordic/ncs/v3.0.0/modules/crypto/oberon-psa-crypto/oberon/drivers/oberon_asymmetric_encrypt.o: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/tfm/secure_fw/partitions/crypto/mbedcrypto/nrf_security_src/drivers/nrf_oberon/CMakeFiles/oberon_psa_driver.dir/opt/nordic/ncs/v3.0.0/modules/crypto/oberon-psa-crypto/oberon/drivers/oberon_asymmetric_signature.o: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/tfm/secure_fw/partitions/crypto/mbedcrypto/nrf_security_src/drivers/nrf_oberon/CMakeFiles/oberon_psa_driver.dir/opt/nordic/ncs/v3.0.0/modules/crypto/oberon-psa-crypto/oberon/drivers/oberon_cipher.o: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/tfm/secure_fw/partitions/crypto/mbedcrypto/nrf_security_src/drivers/nrf_oberon/CMakeFiles/oberon_psa_driver.dir/opt/nordic/ncs/v3.0.0/modules/crypto/oberon-psa-crypto/oberon/drivers/oberon_ec_keys.o: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/tfm/secure_fw/partitions/crypto/mbedcrypto/nrf_security_src/drivers/nrf_oberon/CMakeFiles/oberon_psa_driver.dir/opt/nordic/ncs/v3.0.0/modules/crypto/oberon-psa-crypto/oberon/drivers/oberon_ecdh.o: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/tfm/secure_fw/partitions/crypto/mbedcrypto/nrf_security_src/drivers/nrf_oberon/CMakeFiles/oberon_psa_driver.dir/opt/nordic/ncs/v3.0.0/modules/crypto/oberon-psa-crypto/oberon/drivers/oberon_ecdsa.o: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/tfm/secure_fw/partitions/crypto/mbedcrypto/nrf_security_src/drivers/nrf_oberon/CMakeFiles/oberon_psa_driver.dir/opt/nordic/ncs/v3.0.0/modules/crypto/oberon-psa-crypto/oberon/drivers/oberon_hash.o: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/tfm/secure_fw/partitions/crypto/mbedcrypto/nrf_security_src/drivers/nrf_oberon/CMakeFiles/oberon_psa_driver.dir/opt/nordic/ncs/v3.0.0/modules/crypto/oberon-psa-crypto/oberon/drivers/oberon_helpers.o: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/tfm/secure_fw/partitions/crypto/mbedcrypto/nrf_security_src/drivers/nrf_oberon/CMakeFiles/oberon_psa_driver.dir/opt/nordic/ncs/v3.0.0/modules/crypto/oberon-psa-crypto/oberon/drivers/oberon_jpake.o: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/tfm/secure_fw/partitions/crypto/mbedcrypto/nrf_security_src/drivers/nrf_oberon/CMakeFiles/oberon_psa_driver.dir/opt/nordic/ncs/v3.0.0/modules/crypto/oberon-psa-crypto/oberon/drivers/oberon_key_agreement.o: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/tfm/secure_fw/partitions/crypto/mbedcrypto/nrf_security_src/drivers/nrf_oberon/CMakeFiles/oberon_psa_driver.dir/opt/nordic/ncs/v3.0.0/modules/crypto/oberon-psa-crypto/oberon/drivers/oberon_key_derivation.o: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/tfm/secure_fw/partitions/crypto/mbedcrypto/nrf_security_src/drivers/nrf_oberon/CMakeFiles/oberon_psa_driver.dir/opt/nordic/ncs/v3.0.0/modules/crypto/oberon-psa-crypto/oberon/drivers/oberon_key_management.o: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/tfm/secure_fw/partitions/crypto/mbedcrypto/nrf_security_src/drivers/nrf_oberon/CMakeFiles/oberon_psa_driver.dir/opt/nordic/ncs/v3.0.0/modules/crypto/oberon-psa-crypto/oberon/drivers/oberon_mac.o: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/tfm/secure_fw/partitions/crypto/mbedcrypto/nrf_security_src/drivers/nrf_oberon/CMakeFiles/oberon_psa_driver.dir/opt/nordic/ncs/v3.0.0/modules/crypto/oberon-psa-crypto/oberon/drivers/oberon_rsa.o: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/tfm/secure_fw/partitions/crypto/mbedcrypto/nrf_security_src/drivers/nrf_oberon/CMakeFiles/oberon_psa_driver.dir/opt/nordic/ncs/v3.0.0/modules/crypto/oberon-psa-crypto/oberon/drivers/oberon_spake2p.o: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/tfm/secure_fw/partitions/crypto/mbedcrypto/nrf_security_src/drivers/nrf_oberon/CMakeFiles/oberon_psa_driver.dir/opt/nordic/ncs/v3.0.0/modules/crypto/oberon-psa-crypto/oberon/drivers/oberon_srp.o: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/tfm/secure_fw/partitions/crypto/mbedcrypto/nrf_security_src/drivers/nrf_oberon/CMakeFiles/oberon_psa_driver.dir/opt/nordic/ncs/v3.0.0/modules/crypto/oberon-psa-crypto/oberon/drivers/oberon_wpa3_sae.o: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/tfm/secure_fw/partitions/crypto/mbedcrypto/nrf_security_src/drivers/nrf_oberon/cmake_install.cmake: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/tfm/secure_fw/partitions/crypto/mbedcrypto/nrf_security_src/drivers/nrf_oberon/liboberon_psa_driver.a: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/tfm/secure_fw/partitions/crypto/mbedcrypto/nrf_security_src/drivers/zephyr/cmake_install.cmake: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/tfm/secure_fw/partitions/crypto/mbedcrypto/nrf_security_src/libcrypto_service_mbedcrypto.a: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/tfm/secure_fw/partitions/crypto/mbedcrypto/nrf_security_src/libmbedcrypto_base.a: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/tfm/secure_fw/partitions/crypto/mbedcrypto/nrf_security_src/libnrf_security_utils.a: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/tfm/secure_fw/partitions/firmware_update/cmake_install.cmake: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/tfm/secure_fw/partitions/initial_attestation/cmake_install.cmake: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/tfm/secure_fw/partitions/internal_trusted_storage/cmake_install.cmake: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/tfm/secure_fw/partitions/lib/runtime/CMakeFiles/tfm_sp_log.dir/__/__/__/__/platform/ext/common/tfm_hal_sp_logdev_periph.o: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/tfm/secure_fw/partitions/lib/runtime/CMakeFiles/tfm_sp_log.dir/tfm_sp_log_raw.o: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/tfm/secure_fw/partitions/lib/runtime/CMakeFiles/tfm_sprt.dir/__/__/__/__/interface/src/tfm_crypto_api.o: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/tfm/secure_fw/partitions/lib/runtime/CMakeFiles/tfm_sprt.dir/__/__/__/__/interface/src/tfm_platform_api.o: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/tfm/secure_fw/partitions/lib/runtime/CMakeFiles/tfm_sprt.dir/__/__/__/__/interface/src/tfm_psa_call.o: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/tfm/secure_fw/partitions/lib/runtime/CMakeFiles/tfm_sprt.dir/__/__/__/__/platform/ext/common/syscalls_stub.o: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/tfm/secure_fw/partitions/lib/runtime/CMakeFiles/tfm_sprt.dir/__/__/__/shared/crt_memcpy.o: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/tfm/secure_fw/partitions/lib/runtime/CMakeFiles/tfm_sprt.dir/__/__/__/shared/crt_memset.o: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/tfm/secure_fw/partitions/lib/runtime/CMakeFiles/tfm_sprt.dir/__/__/__/spm/core/psa_interface_sfn.o: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/tfm/secure_fw/partitions/lib/runtime/CMakeFiles/tfm_sprt.dir/crt_memcmp.o: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/tfm/secure_fw/partitions/lib/runtime/CMakeFiles/tfm_sprt.dir/crt_memmove.o: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/tfm/secure_fw/partitions/lib/runtime/CMakeFiles/tfm_sprt.dir/crt_strnlen.o: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/tfm/secure_fw/partitions/lib/runtime/CMakeFiles/tfm_sprt.dir/opt/nordic/ncs/v3.0.0/nrf/modules/trusted-firmware-m/tfm_boards/common/dummy_tfm_sp_log_raw.o: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/tfm/secure_fw/partitions/lib/runtime/CMakeFiles/tfm_sprt.dir/service_api.o: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/tfm/secure_fw/partitions/lib/runtime/cmake_install.cmake: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/tfm/secure_fw/partitions/lib/runtime/libtfm_sp_log.a: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/tfm/secure_fw/partitions/lib/runtime/libtfm_sprt.a: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/tfm/secure_fw/partitions/ns_agent_mailbox/cmake_install.cmake: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/tfm/secure_fw/partitions/ns_agent_tz/cmake_install.cmake: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/tfm/secure_fw/partitions/platform/CMakeFiles/tfm_psa_rot_partition_platform.dir/__/__/__/generated/secure_fw/partitions/platform/auto_generated/intermedia_tfm_platform.o: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/tfm/secure_fw/partitions/platform/CMakeFiles/tfm_psa_rot_partition_platform.dir/__/__/__/platform/ext/common/syscalls_stub.o: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/tfm/secure_fw/partitions/platform/CMakeFiles/tfm_psa_rot_partition_platform.dir/platform_sp.o: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/tfm/secure_fw/partitions/platform/cmake_install.cmake: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/tfm/secure_fw/partitions/platform/libtfm_psa_rot_partition_platform.a: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/tfm/secure_fw/partitions/protected_storage/cmake_install.cmake: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/tfm/secure_fw/s_veneers.o: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/tfm/secure_fw/spm/CMakeFiles/tfm_spm.dir/__/__/generated/secure_fw/partitions/crypto/auto_generated/load_info_tfm_crypto.o: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/tfm/secure_fw/spm/CMakeFiles/tfm_spm.dir/__/__/generated/secure_fw/partitions/platform/auto_generated/load_info_tfm_platform.o: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/tfm/secure_fw/spm/CMakeFiles/tfm_spm.dir/__/__/platform/ext/common/syscalls_stub.o: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/tfm/secure_fw/spm/CMakeFiles/tfm_spm.dir/__/__/platform/ext/common/tfm_hal_nvic.o: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/tfm/secure_fw/spm/CMakeFiles/tfm_spm.dir/__/__/platform/ext/target/nordic_nrf/common/core/faults.o: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/tfm/secure_fw/spm/CMakeFiles/tfm_spm.dir/__/__/platform/ext/target/nordic_nrf/common/core/target_cfg.o: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/tfm/secure_fw/spm/CMakeFiles/tfm_spm.dir/__/__/platform/ext/target/nordic_nrf/common/core/tfm_hal_isolation.o: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/tfm/secure_fw/spm/CMakeFiles/tfm_spm.dir/__/__/platform/ext/target/nordic_nrf/common/core/tfm_hal_platform_common.o: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/tfm/secure_fw/spm/CMakeFiles/tfm_spm.dir/__/partitions/ns_agent_tz/load_info_ns_agent_tz.o: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/tfm/secure_fw/spm/CMakeFiles/tfm_spm.dir/__/partitions/ns_agent_tz/ns_agent_tz_v80m.o: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/tfm/secure_fw/spm/CMakeFiles/tfm_spm.dir/core/arch/tfm_arch.o: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/tfm/secure_fw/spm/CMakeFiles/tfm_spm.dir/core/arch/tfm_arch_v8m_main.o: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/tfm/secure_fw/spm/CMakeFiles/tfm_spm.dir/core/backend_sfn.o: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/tfm/secure_fw/spm/CMakeFiles/tfm_spm.dir/core/main.o: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/tfm/secure_fw/spm/CMakeFiles/tfm_spm.dir/core/psa_api.o: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/tfm/secure_fw/spm/CMakeFiles/tfm_spm.dir/core/psa_call_api.o: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/tfm/secure_fw/spm/CMakeFiles/tfm_spm.dir/core/psa_read_write_skip_api.o: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/tfm/secure_fw/spm/CMakeFiles/tfm_spm.dir/core/psa_version_api.o: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/tfm/secure_fw/spm/CMakeFiles/tfm_spm.dir/core/rom_loader.o: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/tfm/secure_fw/spm/CMakeFiles/tfm_spm.dir/core/spm_ipc.o: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/tfm/secure_fw/spm/CMakeFiles/tfm_spm.dir/core/spm_local_connection.o: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/tfm/secure_fw/spm/CMakeFiles/tfm_spm.dir/core/spm_log.o: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/tfm/secure_fw/spm/CMakeFiles/tfm_spm.dir/core/tfm_boot_data.o: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/tfm/secure_fw/spm/CMakeFiles/tfm_spm.dir/core/tfm_pools.o: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/tfm/secure_fw/spm/CMakeFiles/tfm_spm.dir/core/tfm_svcalls.o: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/tfm/secure_fw/spm/CMakeFiles/tfm_spm.dir/core/utilities.o: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/tfm/secure_fw/spm/CMakeFiles/tfm_spm.dir/ns_client_ext/tfm_spm_ns_ctx.o: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/tfm/secure_fw/spm/cmake_install.cmake: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/tfm/secure_fw/spm/libtfm_spm.a: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/tfm/tools/cmake_install.cmake: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/tfm/tools/manifest_config.h: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/tfm/tools/manifest_config.h.in: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/zephyr/.cmake.dotconfig.checksum: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/zephyr/.config: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/zephyr/.config.sysbuild: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/zephyr/CMakeFiles/offsets.dir/arch/arm/core/offsets/offsets.c.obj: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/zephyr/CMakeFiles/zephyr.dir/drivers/flash/flash_util.c.obj: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/zephyr/CMakeFiles/zephyr.dir/drivers/wifi/nrf_wifi/src/fw_load.c.obj: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/zephyr/CMakeFiles/zephyr.dir/lib/crc/crc16_sw.c.obj: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/zephyr/CMakeFiles/zephyr.dir/lib/crc/crc24_sw.c.obj: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/zephyr/CMakeFiles/zephyr.dir/lib/crc/crc32_sw.c.obj: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/zephyr/CMakeFiles/zephyr.dir/lib/crc/crc32c_sw.c.obj: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/zephyr/CMakeFiles/zephyr.dir/lib/crc/crc4_sw.c.obj: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/zephyr/CMakeFiles/zephyr.dir/lib/crc/crc7_sw.c.obj: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/zephyr/CMakeFiles/zephyr.dir/lib/crc/crc8_sw.c.obj: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/zephyr/CMakeFiles/zephyr.dir/lib/heap/heap.c.obj: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/zephyr/CMakeFiles/zephyr.dir/lib/os/assert.c.obj: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/zephyr/CMakeFiles/zephyr.dir/lib/os/cbprintf.c.obj: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/zephyr/CMakeFiles/zephyr.dir/lib/os/cbprintf_complete.c.obj: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/zephyr/CMakeFiles/zephyr.dir/lib/os/cbprintf_packaged.c.obj: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/zephyr/CMakeFiles/zephyr.dir/lib/os/fdtable.c.obj: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/zephyr/CMakeFiles/zephyr.dir/lib/os/mpsc_pbuf.c.obj: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/zephyr/CMakeFiles/zephyr.dir/lib/os/printk.c.obj: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/zephyr/CMakeFiles/zephyr.dir/lib/os/reboot.c.obj: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/zephyr/CMakeFiles/zephyr.dir/lib/os/sem.c.obj: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/zephyr/CMakeFiles/zephyr.dir/lib/os/thread_entry.c.obj: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/zephyr/CMakeFiles/zephyr.dir/lib/utils/bitarray.c.obj: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/zephyr/CMakeFiles/zephyr.dir/lib/utils/dec.c.obj: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/zephyr/CMakeFiles/zephyr.dir/lib/utils/hex.c.obj: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/zephyr/CMakeFiles/zephyr.dir/lib/utils/last_section_id.c.obj: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/zephyr/CMakeFiles/zephyr.dir/lib/utils/notify.c.obj: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/zephyr/CMakeFiles/zephyr.dir/lib/utils/onoff.c.obj: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/zephyr/CMakeFiles/zephyr.dir/lib/utils/rb.c.obj: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/zephyr/CMakeFiles/zephyr.dir/lib/utils/timeutil.c.obj: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/zephyr/CMakeFiles/zephyr.dir/misc/generated/configs.c.obj: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/zephyr/CMakeFiles/zephyr.dir/modules/hostap/src/supp_api.c.obj: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/zephyr/CMakeFiles/zephyr.dir/modules/hostap/src/supp_events.c.obj: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/zephyr/CMakeFiles/zephyr.dir/modules/hostap/src/supp_main.c.obj: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/zephyr/CMakeFiles/zephyr.dir/modules/mbedtls/debug.c.obj: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/zephyr/CMakeFiles/zephyr.dir/opt/nordic/ncs/v3.0.0/modules/lib/hostap/src/common/cli.c.obj: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/zephyr/CMakeFiles/zephyr.dir/opt/nordic/ncs/v3.0.0/modules/lib/hostap/src/common/dragonfly.c.obj: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/zephyr/CMakeFiles/zephyr.dir/opt/nordic/ncs/v3.0.0/modules/lib/hostap/src/common/hw_features_common.c.obj: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/zephyr/CMakeFiles/zephyr.dir/opt/nordic/ncs/v3.0.0/modules/lib/hostap/src/common/ieee802_11_common.c.obj: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/zephyr/CMakeFiles/zephyr.dir/opt/nordic/ncs/v3.0.0/modules/lib/hostap/src/common/ptksa_cache.c.obj: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/zephyr/CMakeFiles/zephyr.dir/opt/nordic/ncs/v3.0.0/modules/lib/hostap/src/common/sae.c.obj: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/zephyr/CMakeFiles/zephyr.dir/opt/nordic/ncs/v3.0.0/modules/lib/hostap/src/common/wpa_common.c.obj: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/zephyr/CMakeFiles/zephyr.dir/opt/nordic/ncs/v3.0.0/modules/lib/hostap/src/common/wpa_ctrl.c.obj: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/zephyr/CMakeFiles/zephyr.dir/opt/nordic/ncs/v3.0.0/modules/lib/hostap/src/crypto/aes-internal-dec.c.obj: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/zephyr/CMakeFiles/zephyr.dir/opt/nordic/ncs/v3.0.0/modules/lib/hostap/src/crypto/aes-internal-enc.c.obj: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/zephyr/CMakeFiles/zephyr.dir/opt/nordic/ncs/v3.0.0/modules/lib/hostap/src/crypto/aes-internal.c.obj: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/zephyr/CMakeFiles/zephyr.dir/opt/nordic/ncs/v3.0.0/modules/lib/hostap/src/crypto/aes-unwrap.c.obj: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/zephyr/CMakeFiles/zephyr.dir/opt/nordic/ncs/v3.0.0/modules/lib/hostap/src/crypto/aes-wrap.c.obj: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/zephyr/CMakeFiles/zephyr.dir/opt/nordic/ncs/v3.0.0/modules/lib/hostap/src/crypto/crypto_mbedtls_alt.c.obj: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/zephyr/CMakeFiles/zephyr.dir/opt/nordic/ncs/v3.0.0/modules/lib/hostap/src/crypto/dh_groups.c.obj: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/zephyr/CMakeFiles/zephyr.dir/opt/nordic/ncs/v3.0.0/modules/lib/hostap/src/crypto/rc4.c.obj: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/zephyr/CMakeFiles/zephyr.dir/opt/nordic/ncs/v3.0.0/modules/lib/hostap/src/crypto/tls_none.c.obj: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/zephyr/CMakeFiles/zephyr.dir/opt/nordic/ncs/v3.0.0/modules/lib/hostap/src/drivers/driver_common.c.obj: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/zephyr/CMakeFiles/zephyr.dir/opt/nordic/ncs/v3.0.0/modules/lib/hostap/src/drivers/driver_zephyr.c.obj: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/zephyr/CMakeFiles/zephyr.dir/opt/nordic/ncs/v3.0.0/modules/lib/hostap/src/drivers/drivers.c.obj: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/zephyr/CMakeFiles/zephyr.dir/opt/nordic/ncs/v3.0.0/modules/lib/hostap/src/l2_packet/l2_packet_zephyr.c.obj: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/zephyr/CMakeFiles/zephyr.dir/opt/nordic/ncs/v3.0.0/modules/lib/hostap/src/rsn_supp/pmksa_cache.c.obj: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/zephyr/CMakeFiles/zephyr.dir/opt/nordic/ncs/v3.0.0/modules/lib/hostap/src/rsn_supp/preauth.c.obj: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/zephyr/CMakeFiles/zephyr.dir/opt/nordic/ncs/v3.0.0/modules/lib/hostap/src/rsn_supp/wpa.c.obj: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/zephyr/CMakeFiles/zephyr.dir/opt/nordic/ncs/v3.0.0/modules/lib/hostap/src/rsn_supp/wpa_ie.c.obj: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/zephyr/CMakeFiles/zephyr.dir/opt/nordic/ncs/v3.0.0/modules/lib/hostap/src/utils/base64.c.obj: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/zephyr/CMakeFiles/zephyr.dir/opt/nordic/ncs/v3.0.0/modules/lib/hostap/src/utils/bitfield.c.obj: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/zephyr/CMakeFiles/zephyr.dir/opt/nordic/ncs/v3.0.0/modules/lib/hostap/src/utils/common.c.obj: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/zephyr/CMakeFiles/zephyr.dir/opt/nordic/ncs/v3.0.0/modules/lib/hostap/src/utils/crc32.c.obj: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/zephyr/CMakeFiles/zephyr.dir/opt/nordic/ncs/v3.0.0/modules/lib/hostap/src/utils/eloop.c.obj: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/zephyr/CMakeFiles/zephyr.dir/opt/nordic/ncs/v3.0.0/modules/lib/hostap/src/utils/os_zephyr.c.obj: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/zephyr/CMakeFiles/zephyr.dir/opt/nordic/ncs/v3.0.0/modules/lib/hostap/src/utils/wpa_debug_zephyr.c.obj: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/zephyr/CMakeFiles/zephyr.dir/opt/nordic/ncs/v3.0.0/modules/lib/hostap/src/utils/wpabuf.c.obj: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/zephyr/CMakeFiles/zephyr.dir/opt/nordic/ncs/v3.0.0/modules/lib/hostap/wpa_supplicant/bss.c.obj: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/zephyr/CMakeFiles/zephyr.dir/opt/nordic/ncs/v3.0.0/modules/lib/hostap/wpa_supplicant/bssid_ignore.c.obj: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/zephyr/CMakeFiles/zephyr.dir/opt/nordic/ncs/v3.0.0/modules/lib/hostap/wpa_supplicant/config.c.obj: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/zephyr/CMakeFiles/zephyr.dir/opt/nordic/ncs/v3.0.0/modules/lib/hostap/wpa_supplicant/config_none.c.obj: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/zephyr/CMakeFiles/zephyr.dir/opt/nordic/ncs/v3.0.0/modules/lib/hostap/wpa_supplicant/ctrl_iface.c.obj: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/zephyr/CMakeFiles/zephyr.dir/opt/nordic/ncs/v3.0.0/modules/lib/hostap/wpa_supplicant/ctrl_iface_zephyr.c.obj: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/zephyr/CMakeFiles/zephyr.dir/opt/nordic/ncs/v3.0.0/modules/lib/hostap/wpa_supplicant/eap_register.c.obj: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/zephyr/CMakeFiles/zephyr.dir/opt/nordic/ncs/v3.0.0/modules/lib/hostap/wpa_supplicant/events.c.obj: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/zephyr/CMakeFiles/zephyr.dir/opt/nordic/ncs/v3.0.0/modules/lib/hostap/wpa_supplicant/notify.c.obj: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/zephyr/CMakeFiles/zephyr.dir/opt/nordic/ncs/v3.0.0/modules/lib/hostap/wpa_supplicant/scan.c.obj: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/zephyr/CMakeFiles/zephyr.dir/opt/nordic/ncs/v3.0.0/modules/lib/hostap/wpa_supplicant/sme.c.obj: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/zephyr/CMakeFiles/zephyr.dir/opt/nordic/ncs/v3.0.0/modules/lib/hostap/wpa_supplicant/wpa_cli_cmds.c.obj: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/zephyr/CMakeFiles/zephyr.dir/opt/nordic/ncs/v3.0.0/modules/lib/hostap/wpa_supplicant/wpa_cli_zephyr.c.obj: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/zephyr/CMakeFiles/zephyr.dir/opt/nordic/ncs/v3.0.0/modules/lib/hostap/wpa_supplicant/wpa_supplicant.c.obj: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/zephyr/CMakeFiles/zephyr.dir/opt/nordic/ncs/v3.0.0/modules/lib/hostap/wpa_supplicant/wpas_glue.c.obj: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/zephyr/CMakeFiles/zephyr.dir/opt/nordic/ncs/v3.0.0/nrf/lib/boot_banner/banner.c.obj: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/zephyr/CMakeFiles/zephyr.dir/opt/nordic/ncs/v3.0.0/nrf/subsys/nrf_security/src/zephyr/debug_init.c.obj: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/zephyr/CMakeFiles/zephyr.dir/opt/nordic/ncs/v3.0.0/nrf/subsys/partition_manager/flash_map_partition_manager.c.obj: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/zephyr/CMakeFiles/zephyr.dir/subsys/console/getchar.c.obj: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/zephyr/CMakeFiles/zephyr.dir/subsys/console/tty.c.obj: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/zephyr/CMakeFiles/zephyr.dir/subsys/debug/thread_analyzer.c.obj: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/zephyr/CMakeFiles/zephyr.dir/subsys/fs/nvs/nvs.c.obj: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/zephyr/CMakeFiles/zephyr.dir/subsys/logging/backends/log_backend_uart.c.obj: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/zephyr/CMakeFiles/zephyr.dir/subsys/logging/log_cache.c.obj: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/zephyr/CMakeFiles/zephyr.dir/subsys/logging/log_core.c.obj: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/zephyr/CMakeFiles/zephyr.dir/subsys/logging/log_mgmt.c.obj: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/zephyr/CMakeFiles/zephyr.dir/subsys/logging/log_msg.c.obj: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/zephyr/CMakeFiles/zephyr.dir/subsys/logging/log_output.c.obj: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/zephyr/CMakeFiles/zephyr.dir/subsys/mem_mgmt/mem_attr.c.obj: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/zephyr/CMakeFiles/zephyr.dir/subsys/net/lib/sntp/sntp.c.obj: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/zephyr/CMakeFiles/zephyr.dir/subsys/net/lib/sntp/sntp_simple.c.obj: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/zephyr/CMakeFiles/zephyr.dir/subsys/net/lib/utils/addr_utils.c.obj: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/zephyr/CMakeFiles/zephyr.dir/subsys/tracing/tracing_none.c.obj: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/zephyr/CMakeFiles/zephyr_final.dir/isr_tables.c.obj: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/zephyr/CMakeFiles/zephyr_final.dir/misc/empty_file.c.obj: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/zephyr/CMakeFiles/zephyr_pre0.dir/misc/empty_file.c.obj: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/zephyr/arch/arch/arm/cmake_install.cmake: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/zephyr/arch/arch/arm/core/CMakeFiles/arch__arm__core.dir/fatal.c.obj: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/zephyr/arch/arch/arm/core/CMakeFiles/arch__arm__core.dir/nmi.c.obj: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/zephyr/arch/arch/arm/core/CMakeFiles/arch__arm__core.dir/nmi_on_reset.S.obj: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/zephyr/arch/arch/arm/core/cmake_install.cmake: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/zephyr/arch/arch/arm/core/cortex_m/CMakeFiles/arch__arm__core__cortex_m.dir/cpu_idle.c.obj: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/zephyr/arch/arch/arm/core/cortex_m/CMakeFiles/arch__arm__core__cortex_m.dir/exc_exit.c.obj: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/zephyr/arch/arch/arm/core/cortex_m/CMakeFiles/arch__arm__core__cortex_m.dir/fault.c.obj: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/zephyr/arch/arch/arm/core/cortex_m/CMakeFiles/arch__arm__core__cortex_m.dir/fault_s.S.obj: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/zephyr/arch/arch/arm/core/cortex_m/CMakeFiles/arch__arm__core__cortex_m.dir/fpu.c.obj: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/zephyr/arch/arch/arm/core/cortex_m/CMakeFiles/arch__arm__core__cortex_m.dir/irq_init.c.obj: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/zephyr/arch/arch/arm/core/cortex_m/CMakeFiles/arch__arm__core__cortex_m.dir/irq_manage.c.obj: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/zephyr/arch/arch/arm/core/cortex_m/CMakeFiles/arch__arm__core__cortex_m.dir/isr_wrapper.c.obj: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/zephyr/arch/arch/arm/core/cortex_m/CMakeFiles/arch__arm__core__cortex_m.dir/prep_c.c.obj: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/zephyr/arch/arch/arm/core/cortex_m/CMakeFiles/arch__arm__core__cortex_m.dir/reset.S.obj: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/zephyr/arch/arch/arm/core/cortex_m/CMakeFiles/arch__arm__core__cortex_m.dir/scb.c.obj: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/zephyr/arch/arch/arm/core/cortex_m/CMakeFiles/arch__arm__core__cortex_m.dir/swap_helper.S.obj: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/zephyr/arch/arch/arm/core/cortex_m/CMakeFiles/arch__arm__core__cortex_m.dir/thread.c.obj: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/zephyr/arch/arch/arm/core/cortex_m/CMakeFiles/arch__arm__core__cortex_m.dir/thread_abort.c.obj: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/zephyr/arch/arch/arm/core/cortex_m/CMakeFiles/arch__arm__core__cortex_m.dir/vector_table.S.obj: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/zephyr/arch/arch/arm/core/cortex_m/cmake_install.cmake: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/zephyr/arch/arch/arm/core/cortex_m/cmse/CMakeFiles/arch__arm__core__cortex_m__cmse.dir/arm_core_cmse.c.obj: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/zephyr/arch/arch/arm/core/cortex_m/cmse/cmake_install.cmake: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/zephyr/arch/arch/arm/core/cortex_m/cmse/libarch__arm__core__cortex_m__cmse.a: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/zephyr/arch/arch/arm/core/cortex_m/libarch__arm__core__cortex_m.a: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/zephyr/arch/arch/arm/core/cortex_m/tz/cmake_install.cmake: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/zephyr/arch/arch/arm/core/libarch__arm__core.a: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/zephyr/arch/arch/arm/core/mpu/CMakeFiles/arch__arm__core__mpu.dir/arm_core_mpu.c.obj: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/zephyr/arch/arch/arm/core/mpu/CMakeFiles/arch__arm__core__mpu.dir/arm_mpu.c.obj: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/zephyr/arch/arch/arm/core/mpu/CMakeFiles/arch__arm__core__mpu.dir/arm_mpu_regions.c.obj: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/zephyr/arch/arch/arm/core/mpu/cmake_install.cmake: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/zephyr/arch/arch/arm/core/mpu/libarch__arm__core__mpu.a: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/zephyr/arch/cmake_install.cmake: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/zephyr/arch/common/CMakeFiles/arch__common.dir/sw_isr_common.c.obj: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/zephyr/arch/common/CMakeFiles/isr_tables.dir/isr_tables.c.obj: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/zephyr/arch/common/cmake_install.cmake: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/zephyr/arch/common/libarch__common.a: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/zephyr/arch/common/libisr_tables.a: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/zephyr/boards/cmake_install.cmake: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/zephyr/boards/nordic/nrf7002dk/cmake_install.cmake: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/zephyr/boards/shields/cmake_install.cmake: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/zephyr/cmake/flash/cmake_install.cmake: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/zephyr/cmake/reports/cmake_install.cmake: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/zephyr/cmake/usage/cmake_install.cmake: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/zephyr/cmake_install.cmake: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/zephyr/drivers/clock_control/CMakeFiles/drivers__clock_control.dir/clock_control_nrf.c.obj: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/zephyr/drivers/clock_control/cmake_install.cmake: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/zephyr/drivers/clock_control/libdrivers__clock_control.a: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/zephyr/drivers/cmake_install.cmake: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/zephyr/drivers/console/CMakeFiles/drivers__console.dir/uart_console.c.obj: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/zephyr/drivers/console/cmake_install.cmake: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/zephyr/drivers/console/libdrivers__console.a: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/zephyr/drivers/counter/CMakeFiles/drivers__counter.dir/counter_nrfx_rtc.c.obj: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/zephyr/drivers/counter/cmake_install.cmake: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/zephyr/drivers/counter/libdrivers__counter.a: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/zephyr/drivers/disk/cmake_install.cmake: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/zephyr/drivers/entropy/CMakeFiles/drivers__entropy.dir/entropy_psa_crypto.c.obj: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/zephyr/drivers/entropy/cmake_install.cmake: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/zephyr/drivers/entropy/libdrivers__entropy.a: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/zephyr/drivers/ethernet/cmake_install.cmake: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/zephyr/drivers/ethernet/dwc_xgmac/cmake_install.cmake: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/zephyr/drivers/ethernet/eth_nxp_enet_qos/cmake_install.cmake: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/zephyr/drivers/ethernet/nxp_enet/cmake_install.cmake: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/zephyr/drivers/ethernet/phy/cmake_install.cmake: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/zephyr/drivers/firmware/cmake_install.cmake: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/zephyr/drivers/flash/CMakeFiles/drivers__flash.dir/flash_page_layout.c.obj: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/zephyr/drivers/flash/CMakeFiles/drivers__flash.dir/jesd216.c.obj: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/zephyr/drivers/flash/CMakeFiles/drivers__flash.dir/soc_flash_nrf.c.obj: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/zephyr/drivers/flash/CMakeFiles/drivers__flash.dir/spi_nor.c.obj: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/zephyr/drivers/flash/cmake_install.cmake: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/zephyr/drivers/flash/libdrivers__flash.a: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/zephyr/drivers/gpio/CMakeFiles/drivers__gpio.dir/gpio_nrfx.c.obj: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/zephyr/drivers/gpio/cmake_install.cmake: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/zephyr/drivers/gpio/libdrivers__gpio.a: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/zephyr/drivers/interrupt_controller/cmake_install.cmake: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/zephyr/drivers/misc/cmake_install.cmake: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/zephyr/drivers/misc/coresight/cmake_install.cmake: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/zephyr/drivers/pcie/cmake_install.cmake: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/zephyr/drivers/pinctrl/CMakeFiles/drivers__pinctrl.dir/common.c.obj: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/zephyr/drivers/pinctrl/CMakeFiles/drivers__pinctrl.dir/pinctrl_nrf.c.obj: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/zephyr/drivers/pinctrl/cmake_install.cmake: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/zephyr/drivers/pinctrl/libdrivers__pinctrl.a: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/zephyr/drivers/pinctrl/renesas/cmake_install.cmake: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/zephyr/drivers/pwm/CMakeFiles/drivers__pwm.dir/pwm_nrfx.c.obj: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/zephyr/drivers/pwm/cmake_install.cmake: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/zephyr/drivers/pwm/libdrivers__pwm.a: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/zephyr/drivers/sensor/adi/cmake_install.cmake: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/zephyr/drivers/sensor/ams/cmake_install.cmake: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/zephyr/drivers/sensor/aosong/cmake_install.cmake: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/zephyr/drivers/sensor/asahi_kasei/cmake_install.cmake: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/zephyr/drivers/sensor/bosch/cmake_install.cmake: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/zephyr/drivers/sensor/cmake_install.cmake: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/zephyr/drivers/sensor/espressif/cmake_install.cmake: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/zephyr/drivers/sensor/honeywell/cmake_install.cmake: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/zephyr/drivers/sensor/infineon/cmake_install.cmake: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/zephyr/drivers/sensor/ite/cmake_install.cmake: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/zephyr/drivers/sensor/jedec/cmake_install.cmake: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/zephyr/drivers/sensor/maxim/cmake_install.cmake: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/zephyr/drivers/sensor/meas/cmake_install.cmake: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/zephyr/drivers/sensor/memsic/cmake_install.cmake: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/zephyr/drivers/sensor/microchip/cmake_install.cmake: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/zephyr/drivers/sensor/nordic/cmake_install.cmake: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/zephyr/drivers/sensor/nordic/temp/cmake_install.cmake: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/zephyr/drivers/sensor/nuvoton/cmake_install.cmake: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/zephyr/drivers/sensor/nxp/cmake_install.cmake: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/zephyr/drivers/sensor/renesas/cmake_install.cmake: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/zephyr/drivers/sensor/rohm/cmake_install.cmake: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/zephyr/drivers/sensor/seeed/cmake_install.cmake: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/zephyr/drivers/sensor/sensirion/cmake_install.cmake: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/zephyr/drivers/sensor/silabs/cmake_install.cmake: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/zephyr/drivers/sensor/st/cmake_install.cmake: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/zephyr/drivers/sensor/tdk/cmake_install.cmake: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/zephyr/drivers/sensor/ti/cmake_install.cmake: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/zephyr/drivers/sensor/vishay/cmake_install.cmake: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/zephyr/drivers/sensor/wsen/cmake_install.cmake: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/zephyr/drivers/serial/CMakeFiles/drivers__serial.dir/uart_nrfx_uarte.c.obj: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/zephyr/drivers/serial/cmake_install.cmake: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/zephyr/drivers/serial/libdrivers__serial.a: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/zephyr/drivers/spi/CMakeFiles/drivers__spi.dir/spi_nrfx_common.c.obj: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/zephyr/drivers/spi/CMakeFiles/drivers__spi.dir/spi_nrfx_spim.c.obj: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/zephyr/drivers/spi/cmake_install.cmake: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/zephyr/drivers/spi/libdrivers__spi.a: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/zephyr/drivers/timer/CMakeFiles/drivers__timer.dir/nrf_rtc_timer.c.obj: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/zephyr/drivers/timer/CMakeFiles/drivers__timer.dir/sys_clock_init.c.obj: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/zephyr/drivers/timer/cmake_install.cmake: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/zephyr/drivers/timer/libdrivers__timer.a: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/zephyr/drivers/usb/cmake_install.cmake: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/zephyr/drivers/usb/common/cmake_install.cmake: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/zephyr/drivers/usb/common/nrf_usbd_common/cmake_install.cmake: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/zephyr/drivers/usb_c/cmake_install.cmake: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/zephyr/drivers/watchdog/CMakeFiles/drivers__watchdog.dir/wdt_nrfx.c.obj: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/zephyr/drivers/watchdog/cmake_install.cmake: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/zephyr/drivers/watchdog/libdrivers__watchdog.a: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/zephyr/drivers/wifi/cmake_install.cmake: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/zephyr/drivers/wifi/nrf_wifi/CMakeFiles/nrf_wifi.dir/src/fmac_main.c.obj: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/zephyr/drivers/wifi/nrf_wifi/CMakeFiles/nrf_wifi.dir/src/net_if.c.obj: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/zephyr/drivers/wifi/nrf_wifi/CMakeFiles/nrf_wifi.dir/src/wifi_mgmt.c.obj: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/zephyr/drivers/wifi/nrf_wifi/CMakeFiles/nrf_wifi.dir/src/wifi_mgmt_scan.c.obj: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/zephyr/drivers/wifi/nrf_wifi/CMakeFiles/nrf_wifi.dir/src/wpa_supp_if.c.obj: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/zephyr/drivers/wifi/nrf_wifi/cmake_install.cmake: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/zephyr/drivers/wifi/nrf_wifi/libnrf_wifi.a: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/zephyr/dts.cmake: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/zephyr/edt.pickle: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/zephyr/include/generated/app_data_alignment.ld: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/zephyr/include/generated/app_smem.ld: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/zephyr/include/generated/app_smem_aligned.ld: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/zephyr/include/generated/app_smem_unaligned.ld: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/zephyr/include/generated/device-api-sections.cmake: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/zephyr/include/generated/device-api-sections.ld: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/zephyr/include/generated/ncs_commit.h: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/zephyr/include/generated/ncs_version.h: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/zephyr/include/generated/pm_config.h: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/zephyr/include/generated/posix/strsignal_table.h: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/zephyr/include/generated/snippets-data-sections.ld: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/zephyr/include/generated/snippets-dtcm-section.ld: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/zephyr/include/generated/snippets-itcm-section.ld: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/zephyr/include/generated/snippets-nocache-section.ld: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/zephyr/include/generated/snippets-noinit.ld: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/zephyr/include/generated/snippets-pinned-data-sections.ld: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/zephyr/include/generated/snippets-pinned-ram-sections.ld: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/zephyr/include/generated/snippets-pinned-rodata.ld: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/zephyr/include/generated/snippets-ram-sections.ld: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/zephyr/include/generated/snippets-ramfunc-section.ld: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/zephyr/include/generated/snippets-rodata.ld: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/zephyr/include/generated/snippets-rom-sections.ld: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/zephyr/include/generated/snippets-rom-start.ld: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/zephyr/include/generated/snippets-rwdata.ld: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/zephyr/include/generated/snippets-sections.ld: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/zephyr/include/generated/syscall_list.h: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/zephyr/include/generated/zephyr/autoconf.h: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/zephyr/include/generated/zephyr/devicetree_generated.h: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/zephyr/include/generated/zephyr/driver-validation.h: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/zephyr/include/generated/zephyr/kobj-types-enum.h: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/zephyr/include/generated/zephyr/offsets.h: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/zephyr/include/generated/zephyr/otype-to-size.h: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/zephyr/include/generated/zephyr/otype-to-str.h: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/zephyr/include/generated/zephyr/syscall_dispatch.c: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/zephyr/include/generated/zephyr/syscall_exports_llext.c: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/zephyr/include/generated/zephyr/syscall_list.h: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/zephyr/include/generated/zephyr/syscalls/adc.h: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/zephyr/include/generated/zephyr/syscalls/arch.h: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/zephyr/include/generated/zephyr/syscalls/atomic_c.h: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/zephyr/include/generated/zephyr/syscalls/auxdisplay.h: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/zephyr/include/generated/zephyr/syscalls/bbram.h: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/zephyr/include/generated/zephyr/syscalls/cache.h: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/zephyr/include/generated/zephyr/syscalls/can.h: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/zephyr/include/generated/zephyr/syscalls/charger.h: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/zephyr/include/generated/zephyr/syscalls/comparator.h: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/zephyr/include/generated/zephyr/syscalls/counter.h: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/zephyr/include/generated/zephyr/syscalls/dac.h: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/zephyr/include/generated/zephyr/syscalls/demand_paging.h: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/zephyr/include/generated/zephyr/syscalls/device.h: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/zephyr/include/generated/zephyr/syscalls/devmux.h: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/zephyr/include/generated/zephyr/syscalls/dma.h: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/zephyr/include/generated/zephyr/syscalls/eeprom.h: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/zephyr/include/generated/zephyr/syscalls/emul_fuel_gauge.h: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/zephyr/include/generated/zephyr/syscalls/entropy.h: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/zephyr/include/generated/zephyr/syscalls/errno_private.h: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/zephyr/include/generated/zephyr/syscalls/error.h: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/zephyr/include/generated/zephyr/syscalls/espi.h: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/zephyr/include/generated/zephyr/syscalls/espi_saf.h: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/zephyr/include/generated/zephyr/syscalls/ethernet.h: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/zephyr/include/generated/zephyr/syscalls/fdtable.h: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/zephyr/include/generated/zephyr/syscalls/flash.h: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/zephyr/include/generated/zephyr/syscalls/flash_simulator.h: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/zephyr/include/generated/zephyr/syscalls/fuel_gauge.h: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/zephyr/include/generated/zephyr/syscalls/gnss.h: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/zephyr/include/generated/zephyr/syscalls/gpio.h: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/zephyr/include/generated/zephyr/syscalls/haptics.h: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/zephyr/include/generated/zephyr/syscalls/hwinfo.h: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/zephyr/include/generated/zephyr/syscalls/hwspinlock.h: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/zephyr/include/generated/zephyr/syscalls/i2c.h: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/zephyr/include/generated/zephyr/syscalls/i2s.h: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/zephyr/include/generated/zephyr/syscalls/i3c.h: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/zephyr/include/generated/zephyr/syscalls/ipm.h: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/zephyr/include/generated/zephyr/syscalls/ivshmem.h: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/zephyr/include/generated/zephyr/syscalls/kernel.h: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/zephyr/include/generated/zephyr/syscalls/kobject.h: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/zephyr/include/generated/zephyr/syscalls/kscan.h: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/zephyr/include/generated/zephyr/syscalls/led.h: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/zephyr/include/generated/zephyr/syscalls/libc-hooks.h: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/zephyr/include/generated/zephyr/syscalls/llext.h: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/zephyr/include/generated/zephyr/syscalls/log_ctrl.h: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/zephyr/include/generated/zephyr/syscalls/log_msg.h: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/zephyr/include/generated/zephyr/syscalls/maxim_ds3231.h: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/zephyr/include/generated/zephyr/syscalls/mbox.h: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/zephyr/include/generated/zephyr/syscalls/mdio.h: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/zephyr/include/generated/zephyr/syscalls/mspi.h: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/zephyr/include/generated/zephyr/syscalls/mutex.h: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/zephyr/include/generated/zephyr/syscalls/net_if.h: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/zephyr/include/generated/zephyr/syscalls/net_ip.h: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/zephyr/include/generated/zephyr/syscalls/nrf_qspi_nor.h: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/zephyr/include/generated/zephyr/syscalls/peci.h: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/zephyr/include/generated/zephyr/syscalls/posix_clock.h: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/zephyr/include/generated/zephyr/syscalls/ps2.h: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/zephyr/include/generated/zephyr/syscalls/ptp_clock.h: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/zephyr/include/generated/zephyr/syscalls/pwm.h: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/zephyr/include/generated/zephyr/syscalls/random.h: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/zephyr/include/generated/zephyr/syscalls/reset.h: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/zephyr/include/generated/zephyr/syscalls/retained_mem.h: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/zephyr/include/generated/zephyr/syscalls/rtc.h: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/zephyr/include/generated/zephyr/syscalls/rtio.h: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/zephyr/include/generated/zephyr/syscalls/sdhc.h: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/zephyr/include/generated/zephyr/syscalls/sensor.h: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/zephyr/include/generated/zephyr/syscalls/sip_svc_driver.h: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/zephyr/include/generated/zephyr/syscalls/smbus.h: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/zephyr/include/generated/zephyr/syscalls/socket.h: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/zephyr/include/generated/zephyr/syscalls/socket_service.h: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/zephyr/include/generated/zephyr/syscalls/spi.h: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/zephyr/include/generated/zephyr/syscalls/stepper.h: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/zephyr/include/generated/zephyr/syscalls/syscon.h: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/zephyr/include/generated/zephyr/syscalls/tee.h: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/zephyr/include/generated/zephyr/syscalls/time_units.h: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/zephyr/include/generated/zephyr/syscalls/timeaware_gpio.h: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/zephyr/include/generated/zephyr/syscalls/uart.h: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/zephyr/include/generated/zephyr/syscalls/updatehub.h: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/zephyr/include/generated/zephyr/syscalls/usb_bc12.h: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/zephyr/include/generated/zephyr/syscalls/w1.h: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/zephyr/include/generated/zephyr/syscalls/watchdog.h: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/zephyr/include/generated/zephyr/version.h: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/zephyr/include/generated/zephyr_commit.h: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/zephyr/isr_tables.c: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/zephyr/isr_tables_swi.ld: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/zephyr/isr_tables_vt.ld: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/zephyr/kconfig/sources.txt: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/zephyr/kernel/CMakeFiles/kernel.dir/banner.c.obj: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/zephyr/kernel/CMakeFiles/kernel.dir/busy_wait.c.obj: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/zephyr/kernel/CMakeFiles/kernel.dir/condvar.c.obj: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/zephyr/kernel/CMakeFiles/kernel.dir/device.c.obj: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/zephyr/kernel/CMakeFiles/kernel.dir/dynamic_disabled.c.obj: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/zephyr/kernel/CMakeFiles/kernel.dir/errno.c.obj: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/zephyr/kernel/CMakeFiles/kernel.dir/fatal.c.obj: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/zephyr/kernel/CMakeFiles/kernel.dir/float.c.obj: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/zephyr/kernel/CMakeFiles/kernel.dir/idle.c.obj: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/zephyr/kernel/CMakeFiles/kernel.dir/init.c.obj: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/zephyr/kernel/CMakeFiles/kernel.dir/init_static.c.obj: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/zephyr/kernel/CMakeFiles/kernel.dir/kheap.c.obj: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/zephyr/kernel/CMakeFiles/kernel.dir/mailbox.c.obj: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/zephyr/kernel/CMakeFiles/kernel.dir/main_weak.c.obj: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/zephyr/kernel/CMakeFiles/kernel.dir/mem_slab.c.obj: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/zephyr/kernel/CMakeFiles/kernel.dir/mempool.c.obj: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/zephyr/kernel/CMakeFiles/kernel.dir/msg_q.c.obj: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/zephyr/kernel/CMakeFiles/kernel.dir/mutex.c.obj: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/zephyr/kernel/CMakeFiles/kernel.dir/pipes.c.obj: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/zephyr/kernel/CMakeFiles/kernel.dir/poll.c.obj: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/zephyr/kernel/CMakeFiles/kernel.dir/priority_queues.c.obj: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/zephyr/kernel/CMakeFiles/kernel.dir/queue.c.obj: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/zephyr/kernel/CMakeFiles/kernel.dir/sched.c.obj: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/zephyr/kernel/CMakeFiles/kernel.dir/sem.c.obj: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/zephyr/kernel/CMakeFiles/kernel.dir/stack.c.obj: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/zephyr/kernel/CMakeFiles/kernel.dir/system_work_q.c.obj: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/zephyr/kernel/CMakeFiles/kernel.dir/thread.c.obj: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/zephyr/kernel/CMakeFiles/kernel.dir/thread_monitor.c.obj: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/zephyr/kernel/CMakeFiles/kernel.dir/timeout.c.obj: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/zephyr/kernel/CMakeFiles/kernel.dir/timer.c.obj: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/zephyr/kernel/CMakeFiles/kernel.dir/timeslicing.c.obj: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/zephyr/kernel/CMakeFiles/kernel.dir/usage.c.obj: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/zephyr/kernel/CMakeFiles/kernel.dir/version.c.obj: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/zephyr/kernel/CMakeFiles/kernel.dir/work.c.obj: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/zephyr/kernel/CMakeFiles/kernel.dir/xip.c.obj: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/zephyr/kernel/cmake_install.cmake: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/zephyr/kernel/libkernel.a: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/zephyr/lib/cmake_install.cmake: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/zephyr/lib/crc/cmake_install.cmake: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/zephyr/lib/hash/cmake_install.cmake: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/zephyr/lib/heap/cmake_install.cmake: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/zephyr/lib/libc/cmake_install.cmake: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/zephyr/lib/libc/common/CMakeFiles/lib__libc__common.dir/source/stdio/remove.c.obj: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/zephyr/lib/libc/common/CMakeFiles/lib__libc__common.dir/source/stdlib/abort.c.obj: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/zephyr/lib/libc/common/CMakeFiles/lib__libc__common.dir/source/stdlib/malloc.c.obj: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/zephyr/lib/libc/common/cmake_install.cmake: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/zephyr/lib/libc/common/liblib__libc__common.a: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/zephyr/lib/libc/newlib/CMakeFiles/lib__libc__newlib.dir/libc-hooks.c.obj: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/zephyr/lib/libc/newlib/cmake_install.cmake: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/zephyr/lib/libc/newlib/liblib__libc__newlib.a: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/zephyr/lib/mem_blocks/cmake_install.cmake: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/zephyr/lib/net_buf/CMakeFiles/lib__net_buf.dir/buf.c.obj: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/zephyr/lib/net_buf/CMakeFiles/lib__net_buf.dir/buf_simple.c.obj: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/zephyr/lib/net_buf/cmake_install.cmake: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/zephyr/lib/net_buf/liblib__net_buf.a: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/zephyr/lib/os/cmake_install.cmake: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/zephyr/lib/os/zvfs/CMakeFiles/lib__os__zvfs.dir/zvfs_eventfd.c.obj: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/zephyr/lib/os/zvfs/CMakeFiles/lib__os__zvfs.dir/zvfs_poll.c.obj: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/zephyr/lib/os/zvfs/CMakeFiles/lib__os__zvfs.dir/zvfs_select.c.obj: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/zephyr/lib/os/zvfs/cmake_install.cmake: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/zephyr/lib/os/zvfs/liblib__os__zvfs.a: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/zephyr/lib/posix/cmake_install.cmake: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/zephyr/lib/posix/options/CMakeFiles/lib__posix__options.dir/aio.c.obj: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/zephyr/lib/posix/options/CMakeFiles/lib__posix__options.dir/barrier.c.obj: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/zephyr/lib/posix/options/CMakeFiles/lib__posix__options.dir/clock.c.obj: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/zephyr/lib/posix/options/CMakeFiles/lib__posix__options.dir/cond.c.obj: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/zephyr/lib/posix/options/CMakeFiles/lib__posix__options.dir/confstr.c.obj: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/zephyr/lib/posix/options/CMakeFiles/lib__posix__options.dir/device_io.c.obj: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/zephyr/lib/posix/options/CMakeFiles/lib__posix__options.dir/env.c.obj: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/zephyr/lib/posix/options/CMakeFiles/lib__posix__options.dir/eventfd.c.obj: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/zephyr/lib/posix/options/CMakeFiles/lib__posix__options.dir/fd_mgmt.c.obj: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/zephyr/lib/posix/options/CMakeFiles/lib__posix__options.dir/file_system_r.c.obj: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/zephyr/lib/posix/options/CMakeFiles/lib__posix__options.dir/fs.c.obj: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/zephyr/lib/posix/options/CMakeFiles/lib__posix__options.dir/fsync.c.obj: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/zephyr/lib/posix/options/CMakeFiles/lib__posix__options.dir/grp.c.obj: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/zephyr/lib/posix/options/CMakeFiles/lib__posix__options.dir/key.c.obj: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/zephyr/lib/posix/options/CMakeFiles/lib__posix__options.dir/mqueue.c.obj: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/zephyr/lib/posix/options/CMakeFiles/lib__posix__options.dir/multi_process.c.obj: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/zephyr/lib/posix/options/CMakeFiles/lib__posix__options.dir/mutex.c.obj: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/zephyr/lib/posix/options/CMakeFiles/lib__posix__options.dir/net.c.obj: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/zephyr/lib/posix/options/CMakeFiles/lib__posix__options.dir/perror.c.obj: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/zephyr/lib/posix/options/CMakeFiles/lib__posix__options.dir/pthread.c.obj: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/zephyr/lib/posix/options/CMakeFiles/lib__posix__options.dir/pwd.c.obj: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/zephyr/lib/posix/options/CMakeFiles/lib__posix__options.dir/rwlock.c.obj: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/zephyr/lib/posix/options/CMakeFiles/lib__posix__options.dir/semaphore.c.obj: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/zephyr/lib/posix/options/CMakeFiles/lib__posix__options.dir/signal.c.obj: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/zephyr/lib/posix/options/CMakeFiles/lib__posix__options.dir/sleep.c.obj: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/zephyr/lib/posix/options/CMakeFiles/lib__posix__options.dir/spinlock.c.obj: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/zephyr/lib/posix/options/CMakeFiles/lib__posix__options.dir/sysconf.c.obj: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/zephyr/lib/posix/options/CMakeFiles/lib__posix__options.dir/timer.c.obj: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/zephyr/lib/posix/options/CMakeFiles/lib__posix__options.dir/timespec_to_timeout.c.obj: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/zephyr/lib/posix/options/CMakeFiles/lib__posix__options.dir/uname.c.obj: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/zephyr/lib/posix/options/cmake_install.cmake: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/zephyr/lib/posix/options/liblib__posix__options.a: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/zephyr/lib/utils/cmake_install.cmake: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/zephyr/libzephyr.a: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/zephyr/linker.cmd: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/zephyr/linker.cmd.dep: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/zephyr/linker_zephyr_pre0.cmd: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/zephyr/linker_zephyr_pre0.cmd.dep: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/zephyr/misc/generated/configs.c: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/zephyr/misc/generated/nrf70_fw_patch/nrf70.bin.inc: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/zephyr/misc/generated/struct_tags.json: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/zephyr/misc/generated/syscalls.json: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/zephyr/misc/generated/syscalls_file_list.txt: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/zephyr/misc/generated/syscalls_links/include: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/zephyr/misc/generated/syscalls_links/include_zephyr: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/zephyr/misc/generated/syscalls_links/include_zephyr_acpi: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/zephyr/misc/generated/syscalls_links/include_zephyr_app_memory: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/zephyr/misc/generated/syscalls_links/include_zephyr_arch: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/zephyr/misc/generated/syscalls_links/include_zephyr_arch_arc: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/zephyr/misc/generated/syscalls_links/include_zephyr_arch_arc_asm-compat: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/zephyr/misc/generated/syscalls_links/include_zephyr_arch_arc_v2: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/zephyr/misc/generated/syscalls_links/include_zephyr_arch_arc_v2_dsp: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/zephyr/misc/generated/syscalls_links/include_zephyr_arch_arc_v2_mpu: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/zephyr/misc/generated/syscalls_links/include_zephyr_arch_arc_v2_secureshield: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/zephyr/misc/generated/syscalls_links/include_zephyr_arch_arc_v2_vpx: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/zephyr/misc/generated/syscalls_links/include_zephyr_arch_arm: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/zephyr/misc/generated/syscalls_links/include_zephyr_arch_arm64: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/zephyr/misc/generated/syscalls_links/include_zephyr_arch_arm64_cortex_r: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/zephyr/misc/generated/syscalls_links/include_zephyr_arch_arm64_scripts: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/zephyr/misc/generated/syscalls_links/include_zephyr_arch_arm_cortex_a_r: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/zephyr/misc/generated/syscalls_links/include_zephyr_arch_arm_cortex_a_r_scripts: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/zephyr/misc/generated/syscalls_links/include_zephyr_arch_arm_cortex_m: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/zephyr/misc/generated/syscalls_links/include_zephyr_arch_arm_cortex_m_scripts: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/zephyr/misc/generated/syscalls_links/include_zephyr_arch_arm_cortex_r: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/zephyr/misc/generated/syscalls_links/include_zephyr_arch_arm_cortex_r_scripts: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/zephyr/misc/generated/syscalls_links/include_zephyr_arch_arm_mmu: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/zephyr/misc/generated/syscalls_links/include_zephyr_arch_arm_mpu: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/zephyr/misc/generated/syscalls_links/include_zephyr_arch_common: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/zephyr/misc/generated/syscalls_links/include_zephyr_arch_mips: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/zephyr/misc/generated/syscalls_links/include_zephyr_arch_nios2: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/zephyr/misc/generated/syscalls_links/include_zephyr_arch_posix: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/zephyr/misc/generated/syscalls_links/include_zephyr_arch_riscv: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/zephyr/misc/generated/syscalls_links/include_zephyr_arch_riscv_common: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/zephyr/misc/generated/syscalls_links/include_zephyr_arch_riscv_riscv-privileged: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/zephyr/misc/generated/syscalls_links/include_zephyr_arch_sparc: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/zephyr/misc/generated/syscalls_links/include_zephyr_arch_x86: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/zephyr/misc/generated/syscalls_links/include_zephyr_arch_x86_ia32: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/zephyr/misc/generated/syscalls_links/include_zephyr_arch_x86_ia32_scripts: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/zephyr/misc/generated/syscalls_links/include_zephyr_arch_x86_intel64: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/zephyr/misc/generated/syscalls_links/include_zephyr_arch_xtensa: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/zephyr/misc/generated/syscalls_links/include_zephyr_audio: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/zephyr/misc/generated/syscalls_links/include_zephyr_bluetooth: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/zephyr/misc/generated/syscalls_links/include_zephyr_bluetooth_audio: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/zephyr/misc/generated/syscalls_links/include_zephyr_bluetooth_classic: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/zephyr/misc/generated/syscalls_links/include_zephyr_bluetooth_mesh: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/zephyr/misc/generated/syscalls_links/include_zephyr_bluetooth_services: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/zephyr/misc/generated/syscalls_links/include_zephyr_bluetooth_services_nus: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/zephyr/misc/generated/syscalls_links/include_zephyr_canbus: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/zephyr/misc/generated/syscalls_links/include_zephyr_console: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/zephyr/misc/generated/syscalls_links/include_zephyr_crypto: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/zephyr/misc/generated/syscalls_links/include_zephyr_data: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/zephyr/misc/generated/syscalls_links/include_zephyr_debug: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/zephyr/misc/generated/syscalls_links/include_zephyr_debug_coresight: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/zephyr/misc/generated/syscalls_links/include_zephyr_devicetree: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/zephyr/misc/generated/syscalls_links/include_zephyr_dfu: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/zephyr/misc/generated/syscalls_links/include_zephyr_display: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/zephyr/misc/generated/syscalls_links/include_zephyr_drivers: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/zephyr/misc/generated/syscalls_links/include_zephyr_drivers_adc: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/zephyr/misc/generated/syscalls_links/include_zephyr_drivers_bluetooth: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/zephyr/misc/generated/syscalls_links/include_zephyr_drivers_can: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/zephyr/misc/generated/syscalls_links/include_zephyr_drivers_clock_control: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/zephyr/misc/generated/syscalls_links/include_zephyr_drivers_comparator: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/zephyr/misc/generated/syscalls_links/include_zephyr_drivers_console: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/zephyr/misc/generated/syscalls_links/include_zephyr_drivers_dma: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/zephyr/misc/generated/syscalls_links/include_zephyr_drivers_eeprom: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/zephyr/misc/generated/syscalls_links/include_zephyr_drivers_ethernet: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/zephyr/misc/generated/syscalls_links/include_zephyr_drivers_firmware: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/zephyr/misc/generated/syscalls_links/include_zephyr_drivers_firmware_scmi: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/zephyr/misc/generated/syscalls_links/include_zephyr_drivers_flash: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/zephyr/misc/generated/syscalls_links/include_zephyr_drivers_gnss: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/zephyr/misc/generated/syscalls_links/include_zephyr_drivers_gpio: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/zephyr/misc/generated/syscalls_links/include_zephyr_drivers_haptics: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/zephyr/misc/generated/syscalls_links/include_zephyr_drivers_i2c: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/zephyr/misc/generated/syscalls_links/include_zephyr_drivers_i2c_target: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/zephyr/misc/generated/syscalls_links/include_zephyr_drivers_i3c: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/zephyr/misc/generated/syscalls_links/include_zephyr_drivers_ieee802154: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/zephyr/misc/generated/syscalls_links/include_zephyr_drivers_interrupt_controller: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/zephyr/misc/generated/syscalls_links/include_zephyr_drivers_led: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/zephyr/misc/generated/syscalls_links/include_zephyr_drivers_led_strip: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/zephyr/misc/generated/syscalls_links/include_zephyr_drivers_mfd: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/zephyr/misc/generated/syscalls_links/include_zephyr_drivers_mipi_dsi: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/zephyr/misc/generated/syscalls_links/include_zephyr_drivers_misc: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/zephyr/misc/generated/syscalls_links/include_zephyr_drivers_misc_coresight: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/zephyr/misc/generated/syscalls_links/include_zephyr_drivers_misc_devmux: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/zephyr/misc/generated/syscalls_links/include_zephyr_drivers_misc_ft8xx: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/zephyr/misc/generated/syscalls_links/include_zephyr_drivers_misc_grove_lcd: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/zephyr/misc/generated/syscalls_links/include_zephyr_drivers_misc_nxp_flexio: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/zephyr/misc/generated/syscalls_links/include_zephyr_drivers_misc_pio_rpi_pico: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/zephyr/misc/generated/syscalls_links/include_zephyr_drivers_misc_renesas_ra_external_interrupt: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/zephyr/misc/generated/syscalls_links/include_zephyr_drivers_misc_stm32_wkup_pins: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/zephyr/misc/generated/syscalls_links/include_zephyr_drivers_misc_timeaware_gpio: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/zephyr/misc/generated/syscalls_links/include_zephyr_drivers_mm: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/zephyr/misc/generated/syscalls_links/include_zephyr_drivers_modem: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/zephyr/misc/generated/syscalls_links/include_zephyr_drivers_mspi: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/zephyr/misc/generated/syscalls_links/include_zephyr_drivers_pcie: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/zephyr/misc/generated/syscalls_links/include_zephyr_drivers_pcie_endpoint: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/zephyr/misc/generated/syscalls_links/include_zephyr_drivers_pinctrl: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/zephyr/misc/generated/syscalls_links/include_zephyr_drivers_pm_cpu_ops: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/zephyr/misc/generated/syscalls_links/include_zephyr_drivers_power: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/zephyr/misc/generated/syscalls_links/include_zephyr_drivers_pwm: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/zephyr/misc/generated/syscalls_links/include_zephyr_drivers_regulator: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/zephyr/misc/generated/syscalls_links/include_zephyr_drivers_retained_mem: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/zephyr/misc/generated/syscalls_links/include_zephyr_drivers_rtc: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/zephyr/misc/generated/syscalls_links/include_zephyr_drivers_sensor: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/zephyr/misc/generated/syscalls_links/include_zephyr_drivers_serial: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/zephyr/misc/generated/syscalls_links/include_zephyr_drivers_sip_svc: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/zephyr/misc/generated/syscalls_links/include_zephyr_drivers_spi: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/zephyr/misc/generated/syscalls_links/include_zephyr_drivers_stepper: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/zephyr/misc/generated/syscalls_links/include_zephyr_drivers_timer: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/zephyr/misc/generated/syscalls_links/include_zephyr_drivers_uart: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/zephyr/misc/generated/syscalls_links/include_zephyr_drivers_usb: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/zephyr/misc/generated/syscalls_links/include_zephyr_drivers_usb_c: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/zephyr/misc/generated/syscalls_links/include_zephyr_drivers_virtualization: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/zephyr/misc/generated/syscalls_links/include_zephyr_drivers_wifi: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/zephyr/misc/generated/syscalls_links/include_zephyr_drivers_wifi_nrf_wifi: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/zephyr/misc/generated/syscalls_links/include_zephyr_drivers_wifi_nrf_wifi_bus: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/zephyr/misc/generated/syscalls_links/include_zephyr_drivers_wifi_nrf_wifi_off_raw_tx: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/zephyr/misc/generated/syscalls_links/include_zephyr_dsp: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/zephyr/misc/generated/syscalls_links/include_zephyr_dt-bindings: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/zephyr/misc/generated/syscalls_links/include_zephyr_dt-bindings_acpi: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/zephyr/misc/generated/syscalls_links/include_zephyr_dt-bindings_adc: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/zephyr/misc/generated/syscalls_links/include_zephyr_dt-bindings_battery: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/zephyr/misc/generated/syscalls_links/include_zephyr_dt-bindings_clock: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/zephyr/misc/generated/syscalls_links/include_zephyr_dt-bindings_clock_silabs: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/zephyr/misc/generated/syscalls_links/include_zephyr_dt-bindings_dac: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/zephyr/misc/generated/syscalls_links/include_zephyr_dt-bindings_dai: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/zephyr/misc/generated/syscalls_links/include_zephyr_dt-bindings_display: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/zephyr/misc/generated/syscalls_links/include_zephyr_dt-bindings_dma: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/zephyr/misc/generated/syscalls_links/include_zephyr_dt-bindings_espi: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/zephyr/misc/generated/syscalls_links/include_zephyr_dt-bindings_ethernet: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/zephyr/misc/generated/syscalls_links/include_zephyr_dt-bindings_flash_controller: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/zephyr/misc/generated/syscalls_links/include_zephyr_dt-bindings_gnss: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/zephyr/misc/generated/syscalls_links/include_zephyr_dt-bindings_gpio: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/zephyr/misc/generated/syscalls_links/include_zephyr_dt-bindings_i2c: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/zephyr/misc/generated/syscalls_links/include_zephyr_dt-bindings_input: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/zephyr/misc/generated/syscalls_links/include_zephyr_dt-bindings_inputmux: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/zephyr/misc/generated/syscalls_links/include_zephyr_dt-bindings_interrupt-controller: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/zephyr/misc/generated/syscalls_links/include_zephyr_dt-bindings_ipc_service: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/zephyr/misc/generated/syscalls_links/include_zephyr_dt-bindings_led: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/zephyr/misc/generated/syscalls_links/include_zephyr_dt-bindings_lora: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/zephyr/misc/generated/syscalls_links/include_zephyr_dt-bindings_lvgl: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/zephyr/misc/generated/syscalls_links/include_zephyr_dt-bindings_memory-attr: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/zephyr/misc/generated/syscalls_links/include_zephyr_dt-bindings_memory-controller: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/zephyr/misc/generated/syscalls_links/include_zephyr_dt-bindings_mfd: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/zephyr/misc/generated/syscalls_links/include_zephyr_dt-bindings_mipi_dbi: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/zephyr/misc/generated/syscalls_links/include_zephyr_dt-bindings_mipi_dsi: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/zephyr/misc/generated/syscalls_links/include_zephyr_dt-bindings_misc: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/zephyr/misc/generated/syscalls_links/include_zephyr_dt-bindings_pcie: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/zephyr/misc/generated/syscalls_links/include_zephyr_dt-bindings_pinctrl: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/zephyr/misc/generated/syscalls_links/include_zephyr_dt-bindings_pinctrl_renesas: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/zephyr/misc/generated/syscalls_links/include_zephyr_dt-bindings_pinctrl_silabs: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/zephyr/misc/generated/syscalls_links/include_zephyr_dt-bindings_power: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/zephyr/misc/generated/syscalls_links/include_zephyr_dt-bindings_pwm: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/zephyr/misc/generated/syscalls_links/include_zephyr_dt-bindings_rdc: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/zephyr/misc/generated/syscalls_links/include_zephyr_dt-bindings_regulator: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/zephyr/misc/generated/syscalls_links/include_zephyr_dt-bindings_reserved-memory: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/zephyr/misc/generated/syscalls_links/include_zephyr_dt-bindings_reset: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/zephyr/misc/generated/syscalls_links/include_zephyr_dt-bindings_sensor: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/zephyr/misc/generated/syscalls_links/include_zephyr_dt-bindings_spi: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/zephyr/misc/generated/syscalls_links/include_zephyr_dt-bindings_timer: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/zephyr/misc/generated/syscalls_links/include_zephyr_dt-bindings_usb: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/zephyr/misc/generated/syscalls_links/include_zephyr_dt-bindings_usb-c: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/zephyr/misc/generated/syscalls_links/include_zephyr_dt-bindings_video: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/zephyr/misc/generated/syscalls_links/include_zephyr_fs: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/zephyr/misc/generated/syscalls_links/include_zephyr_input: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/zephyr/misc/generated/syscalls_links/include_zephyr_internal: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/zephyr/misc/generated/syscalls_links/include_zephyr_ipc: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/zephyr/misc/generated/syscalls_links/include_zephyr_kernel: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/zephyr/misc/generated/syscalls_links/include_zephyr_kernel_internal: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/zephyr/misc/generated/syscalls_links/include_zephyr_kernel_mm: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/zephyr/misc/generated/syscalls_links/include_zephyr_linker: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/zephyr/misc/generated/syscalls_links/include_zephyr_linker_common-rom: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/zephyr/misc/generated/syscalls_links/include_zephyr_llext: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/zephyr/misc/generated/syscalls_links/include_zephyr_logging: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/zephyr/misc/generated/syscalls_links/include_zephyr_lorawan: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/zephyr/misc/generated/syscalls_links/include_zephyr_math: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/zephyr/misc/generated/syscalls_links/include_zephyr_mem_mgmt: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/zephyr/misc/generated/syscalls_links/include_zephyr_mgmt: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/zephyr/misc/generated/syscalls_links/include_zephyr_mgmt_ec_host_cmd: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/zephyr/misc/generated/syscalls_links/include_zephyr_mgmt_hawkbit: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/zephyr/misc/generated/syscalls_links/include_zephyr_mgmt_mcumgr: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/zephyr/misc/generated/syscalls_links/include_zephyr_mgmt_mcumgr_grp: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/zephyr/misc/generated/syscalls_links/include_zephyr_mgmt_mcumgr_grp_enum_mgmt: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/zephyr/misc/generated/syscalls_links/include_zephyr_mgmt_mcumgr_grp_fs_mgmt: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/zephyr/misc/generated/syscalls_links/include_zephyr_mgmt_mcumgr_grp_img_mgmt: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/zephyr/misc/generated/syscalls_links/include_zephyr_mgmt_mcumgr_grp_os_mgmt: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/zephyr/misc/generated/syscalls_links/include_zephyr_mgmt_mcumgr_grp_settings_mgmt: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/zephyr/misc/generated/syscalls_links/include_zephyr_mgmt_mcumgr_grp_shell_mgmt: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/zephyr/misc/generated/syscalls_links/include_zephyr_mgmt_mcumgr_grp_stat_mgmt: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/zephyr/misc/generated/syscalls_links/include_zephyr_mgmt_mcumgr_grp_zephyr: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/zephyr/misc/generated/syscalls_links/include_zephyr_mgmt_mcumgr_mgmt: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/zephyr/misc/generated/syscalls_links/include_zephyr_mgmt_mcumgr_smp: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/zephyr/misc/generated/syscalls_links/include_zephyr_mgmt_mcumgr_transport: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/zephyr/misc/generated/syscalls_links/include_zephyr_misc: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/zephyr/misc/generated/syscalls_links/include_zephyr_modbus: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/zephyr/misc/generated/syscalls_links/include_zephyr_modem: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/zephyr/misc/generated/syscalls_links/include_zephyr_modem_backend: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/zephyr/misc/generated/syscalls_links/include_zephyr_multi_heap: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/zephyr/misc/generated/syscalls_links/include_zephyr_net: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/zephyr/misc/generated/syscalls_links/include_zephyr_net_conn_mgr: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/zephyr/misc/generated/syscalls_links/include_zephyr_net_hdlc_rcp_if: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/zephyr/misc/generated/syscalls_links/include_zephyr_net_http: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/zephyr/misc/generated/syscalls_links/include_zephyr_net_prometheus: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/zephyr/misc/generated/syscalls_links/include_zephyr_platform: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/zephyr/misc/generated/syscalls_links/include_zephyr_pm: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/zephyr/misc/generated/syscalls_links/include_zephyr_portability: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/zephyr/misc/generated/syscalls_links/include_zephyr_posix: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/zephyr/misc/generated/syscalls_links/include_zephyr_posix_arpa: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/zephyr/misc/generated/syscalls_links/include_zephyr_posix_net: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/zephyr/misc/generated/syscalls_links/include_zephyr_posix_netinet: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/zephyr/misc/generated/syscalls_links/include_zephyr_posix_sys: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/zephyr/misc/generated/syscalls_links/include_zephyr_psa: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/zephyr/misc/generated/syscalls_links/include_zephyr_random: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/zephyr/misc/generated/syscalls_links/include_zephyr_retention: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/zephyr/misc/generated/syscalls_links/include_zephyr_rtio: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/zephyr/misc/generated/syscalls_links/include_zephyr_sd: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/zephyr/misc/generated/syscalls_links/include_zephyr_sensing: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/zephyr/misc/generated/syscalls_links/include_zephyr_settings: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/zephyr/misc/generated/syscalls_links/include_zephyr_shell: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/zephyr/misc/generated/syscalls_links/include_zephyr_sip_svc: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/zephyr/misc/generated/syscalls_links/include_zephyr_stats: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/zephyr/misc/generated/syscalls_links/include_zephyr_storage: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/zephyr/misc/generated/syscalls_links/include_zephyr_sys: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/zephyr/misc/generated/syscalls_links/include_zephyr_sys_internal: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/zephyr/misc/generated/syscalls_links/include_zephyr_task_wdt: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/zephyr/misc/generated/syscalls_links/include_zephyr_timing: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/zephyr/misc/generated/syscalls_links/include_zephyr_toolchain: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/zephyr/misc/generated/syscalls_links/include_zephyr_tracing: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/zephyr/misc/generated/syscalls_links/include_zephyr_usb: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/zephyr/misc/generated/syscalls_links/include_zephyr_usb_c: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/zephyr/misc/generated/syscalls_links/include_zephyr_usb_class: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/zephyr/misc/generated/syscalls_links/include_zephyr_xen: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/zephyr/misc/generated/syscalls_links/include_zephyr_xen_dom0: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/zephyr/misc/generated/syscalls_links/include_zephyr_xen_public: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/zephyr/misc/generated/syscalls_links/include_zephyr_xen_public_hvm: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/zephyr/misc/generated/syscalls_links/include_zephyr_xen_public_io: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/zephyr/misc/generated/syscalls_links/include_zephyr_zbus: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/zephyr/misc/generated/syscalls_links/include_zephyr_zvfs: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/zephyr/misc/generated/syscalls_subdirs.trigger: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/zephyr/misc/generated/syscalls_subdirs.txt: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/zephyr/runners.yaml: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/zephyr/snippets_generated.cmake: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/zephyr/soc/cmake_install.cmake: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/zephyr/soc/common/cmake_install.cmake: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/zephyr/soc/soc/nrf5340/CMakeFiles/soc__nordic.dir/common/soc_secure.c.obj: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/zephyr/soc/soc/nrf5340/CMakeFiles/soc__nordic.dir/nrf53/nrf53_cpunet_mgmt.c.obj: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/zephyr/soc/soc/nrf5340/CMakeFiles/soc__nordic.dir/nrf53/soc.c.obj: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/zephyr/soc/soc/nrf5340/CMakeFiles/soc__nordic.dir/validate_base_addresses.c.obj: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/zephyr/soc/soc/nrf5340/CMakeFiles/soc__nordic.dir/validate_binding_headers.c.obj: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/zephyr/soc/soc/nrf5340/CMakeFiles/soc__nordic.dir/validate_enabled_instances.c.obj: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/zephyr/soc/soc/nrf5340/cmake_install.cmake: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/zephyr/soc/soc/nrf5340/common/cmake_install.cmake: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/zephyr/soc/soc/nrf5340/libsoc__nordic.a: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/zephyr/soc/soc/nrf5340/nrf53/cmake_install.cmake: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/zephyr/subsys/canbus/cmake_install.cmake: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/zephyr/subsys/cmake_install.cmake: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/zephyr/subsys/console/cmake_install.cmake: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/zephyr/subsys/debug/cmake_install.cmake: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/zephyr/subsys/fb/cmake_install.cmake: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/zephyr/subsys/fs/CMakeFiles/subsys__fs.dir/fs.c.obj: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/zephyr/subsys/fs/CMakeFiles/subsys__fs.dir/fs_impl.c.obj: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/zephyr/subsys/fs/cmake_install.cmake: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/zephyr/subsys/fs/libsubsys__fs.a: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/zephyr/subsys/fs/nvs/cmake_install.cmake: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/zephyr/subsys/ipc/cmake_install.cmake: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/zephyr/subsys/logging/backends/cmake_install.cmake: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/zephyr/subsys/logging/cmake_install.cmake: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/zephyr/subsys/logging/frontends/cmake_install.cmake: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/zephyr/subsys/mem_mgmt/cmake_install.cmake: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/zephyr/subsys/mgmt/cmake_install.cmake: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/zephyr/subsys/modbus/cmake_install.cmake: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/zephyr/subsys/net/CMakeFiles/subsys__net.dir/hostname.c.obj: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/zephyr/subsys/net/CMakeFiles/subsys__net.dir/lib/sockets/getaddrinfo.c.obj: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/zephyr/subsys/net/CMakeFiles/subsys__net.dir/lib/sockets/getnameinfo.c.obj: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/zephyr/subsys/net/CMakeFiles/subsys__net.dir/lib/sockets/socketpair.c.obj: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/zephyr/subsys/net/CMakeFiles/subsys__net.dir/lib/sockets/sockets.c.obj: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/zephyr/subsys/net/CMakeFiles/subsys__net.dir/lib/sockets/sockets_inet.c.obj: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/zephyr/subsys/net/CMakeFiles/subsys__net.dir/lib/sockets/sockets_misc.c.obj: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/zephyr/subsys/net/CMakeFiles/subsys__net.dir/lib/sockets/sockets_packet.c.obj: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/zephyr/subsys/net/CMakeFiles/subsys__net.dir/lib/sockets/sockets_service.c.obj: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/zephyr/subsys/net/CMakeFiles/subsys__net.dir/lib/sockets/sockets_tls.c.obj: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/zephyr/subsys/net/CMakeFiles/subsys__net.dir/lib/tls_credentials/tls_credentials.c.obj: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/zephyr/subsys/net/CMakeFiles/subsys__net.dir/lib/tls_credentials/tls_credentials_digest_raw.c.obj: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/zephyr/subsys/net/cmake_install.cmake: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/zephyr/subsys/net/conn_mgr/CMakeFiles/subsys__net__conn_mgr.dir/conn_mgr_connectivity.c.obj: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/zephyr/subsys/net/conn_mgr/CMakeFiles/subsys__net__conn_mgr.dir/conn_mgr_monitor.c.obj: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/zephyr/subsys/net/conn_mgr/CMakeFiles/subsys__net__conn_mgr.dir/events_handler.c.obj: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/zephyr/subsys/net/conn_mgr/cmake_install.cmake: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/zephyr/subsys/net/conn_mgr/libsubsys__net__conn_mgr.a: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/zephyr/subsys/net/ip/CMakeFiles/subsys__net__ip.dir/connection.c.obj: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/zephyr/subsys/net/ip/CMakeFiles/subsys__net__ip.dir/icmp.c.obj: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/zephyr/subsys/net/ip/CMakeFiles/subsys__net__ip.dir/icmpv4.c.obj: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/zephyr/subsys/net/ip/CMakeFiles/subsys__net__ip.dir/ipv4.c.obj: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/zephyr/subsys/net/ip/CMakeFiles/subsys__net__ip.dir/net_context.c.obj: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/zephyr/subsys/net/ip/CMakeFiles/subsys__net__ip.dir/net_core.c.obj: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/zephyr/subsys/net/ip/CMakeFiles/subsys__net__ip.dir/net_if.c.obj: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/zephyr/subsys/net/ip/CMakeFiles/subsys__net__ip.dir/net_mgmt.c.obj: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/zephyr/subsys/net/ip/CMakeFiles/subsys__net__ip.dir/net_pkt.c.obj: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/zephyr/subsys/net/ip/CMakeFiles/subsys__net__ip.dir/net_tc.c.obj: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/zephyr/subsys/net/ip/CMakeFiles/subsys__net__ip.dir/net_timeout.c.obj: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/zephyr/subsys/net/ip/CMakeFiles/subsys__net__ip.dir/packet_socket.c.obj: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/zephyr/subsys/net/ip/CMakeFiles/subsys__net__ip.dir/tcp.c.obj: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/zephyr/subsys/net/ip/CMakeFiles/subsys__net__ip.dir/udp.c.obj: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/zephyr/subsys/net/ip/CMakeFiles/subsys__net__ip.dir/utils.c.obj: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/zephyr/subsys/net/ip/cmake_install.cmake: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/zephyr/subsys/net/ip/libsubsys__net__ip.a: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/zephyr/subsys/net/l2/cmake_install.cmake: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/zephyr/subsys/net/l2/ethernet/CMakeFiles/subsys__net__l2__ethernet.dir/arp.c.obj: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/zephyr/subsys/net/l2/ethernet/CMakeFiles/subsys__net__l2__ethernet.dir/ethernet.c.obj: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/zephyr/subsys/net/l2/ethernet/CMakeFiles/subsys__net__l2__ethernet.dir/ethernet_mgmt.c.obj: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/zephyr/subsys/net/l2/ethernet/cmake_install.cmake: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/zephyr/subsys/net/l2/ethernet/libsubsys__net__l2__ethernet.a: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/zephyr/subsys/net/l2/wifi/CMakeFiles/subsys__net__l2__wifi.dir/wifi_mgmt.c.obj: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/zephyr/subsys/net/l2/wifi/CMakeFiles/subsys__net__l2__wifi.dir/wifi_nm.c.obj: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/zephyr/subsys/net/l2/wifi/CMakeFiles/subsys__net__l2__wifi.dir/wifi_utils.c.obj: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/zephyr/subsys/net/l2/wifi/cmake_install.cmake: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/zephyr/subsys/net/l2/wifi/libsubsys__net__l2__wifi.a: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/zephyr/subsys/net/lib/cmake_install.cmake: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/zephyr/subsys/net/lib/config/CMakeFiles/subsys__net__lib__config.dir/init.c.obj: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/zephyr/subsys/net/lib/config/cmake_install.cmake: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/zephyr/subsys/net/lib/config/libsubsys__net__lib__config.a: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/zephyr/subsys/net/lib/dhcpv4/CMakeFiles/subsys__net__lib__dhcpv4.dir/dhcpv4.c.obj: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/zephyr/subsys/net/lib/dhcpv4/CMakeFiles/subsys__net__lib__dhcpv4.dir/dhcpv4_server.c.obj: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/zephyr/subsys/net/lib/dhcpv4/cmake_install.cmake: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/zephyr/subsys/net/lib/dhcpv4/libsubsys__net__lib__dhcpv4.a: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/zephyr/subsys/net/lib/dns/CMakeFiles/subsys__net__lib__dns.dir/dispatcher.c.obj: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/zephyr/subsys/net/lib/dns/CMakeFiles/subsys__net__lib__dns.dir/dns_pack.c.obj: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/zephyr/subsys/net/lib/dns/CMakeFiles/subsys__net__lib__dns.dir/resolve.c.obj: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/zephyr/subsys/net/lib/dns/cmake_install.cmake: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/zephyr/subsys/net/lib/dns/libsubsys__net__lib__dns.a: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/zephyr/subsys/net/lib/sntp/cmake_install.cmake: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/zephyr/subsys/net/lib/sockets/cmake_install.cmake: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/zephyr/subsys/net/lib/tls_credentials/cmake_install.cmake: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/zephyr/subsys/net/lib/utils/cmake_install.cmake: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/zephyr/subsys/net/libsubsys__net.a: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/zephyr/subsys/net/pkt_filter/cmake_install.cmake: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/zephyr/subsys/pm/cmake_install.cmake: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/zephyr/subsys/pm/policy/cmake_install.cmake: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/zephyr/subsys/portability/cmake_install.cmake: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/zephyr/subsys/random/CMakeFiles/subsys__random.dir/random_entropy_device.c.obj: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/zephyr/subsys/random/cmake_install.cmake: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/zephyr/subsys/random/libsubsys__random.a: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/zephyr/subsys/rtio/cmake_install.cmake: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/zephyr/subsys/sd/cmake_install.cmake: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/zephyr/subsys/stats/cmake_install.cmake: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/zephyr/subsys/storage/cmake_install.cmake: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/zephyr/subsys/task_wdt/cmake_install.cmake: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/zephyr/subsys/testsuite/cmake_install.cmake: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/zephyr/subsys/tracing/cmake_install.cmake: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/zephyr/subsys/usb/cmake_install.cmake: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/zephyr/syscall_weakdefs_llext.c: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/zephyr/tfm_merged.hex: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/zephyr/zephyr.bin: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/zephyr/zephyr.dts: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/zephyr/zephyr.dts.d: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/zephyr/zephyr.dts.pre: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/zephyr/zephyr.elf: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/zephyr/zephyr.hex: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/zephyr/zephyr.map: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/zephyr/zephyr.stat: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/zephyr/zephyr_final.map: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/zephyr/zephyr_pre0.elf: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/zephyr/zephyr_pre0.map: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/zephyr_modules.txt: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr/zephyr_settings.txt: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr_modules.txt: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr_settings.txt: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr_sysbuild_cache.txt: No such file or directory
    error: micropython_nRF/ports/Zephyr/build/zephyr_sysbuild_cache.txt.tmp: No such file or directory
    error: micropython_nRF/ports/Zephyr/cert/.DS_Store: No such file or directory
    error: micropython_nRF/ports/Zephyr/cert/e5 (sw.io).pem: No such file or directory
    error: micropython_nRF/ports/Zephyr/cert/r1.pem: No such file or directory
    error: micropython_nRF/ports/Zephyr/cert/r1_(sw.io).pem: No such file or directory
    error: micropython_nRF/ports/Zephyr/cert/r1_google.pem: No such file or directory
    error: micropython_nRF/ports/Zephyr/lfs2.c: No such file or directory
    error: patch failed: micropython_nRF/ports/Zephyr/machine_pin.c:63
    error: micropython_nRF/ports/Zephyr/machine_pin.c: patch does not apply
    error: micropython_nRF/ports/Zephyr/machine_pwm.c: No such file or directory
    error: micropython_nRF/ports/Zephyr/machine_rtc.c: No such file or directory
    error: micropython_nRF/ports/Zephyr/machine_timer.c: No such file or directory
    error: micropython_nRF/ports/Zephyr/machine_wdt.c: No such file or directory
    error: patch failed: micropython_nRF/ports/Zephyr/main.c:30
    error: micropython_nRF/ports/Zephyr/main.c: patch does not apply
    error: patch failed: micropython_nRF/ports/Zephyr/modbluetooth_zephyr.c:29
    error: micropython_nRF/ports/Zephyr/modbluetooth_zephyr.c: patch does not apply
    error: micropython_nRF/ports/Zephyr/modlorawan.c: No such file or directory
    error: patch failed: micropython_nRF/ports/Zephyr/modmachine.c:45
    error: micropython_nRF/ports/Zephyr/modmachine.c: patch does not apply
    error: patch failed: micropython_nRF/ports/Zephyr/modmachine.h:11
    error: micropython_nRF/ports/Zephyr/modmachine.h: patch does not apply
    error: micropython_nRF/ports/Zephyr/modnetwork.h: No such file or directory
    error: micropython_nRF/ports/Zephyr/modnetwork_globals.h: No such file or directory
    error: micropython_nRF/ports/Zephyr/modnfc.c: No such file or directory
    error: micropython_nRF/ports/Zephyr/modos.c: No such file or directory
    error: micropython_nRF/ports/Zephyr/modprovisioning.c: No such file or directory
    error: patch failed: micropython_nRF/ports/Zephyr/modsocket.c:3
    error: micropython_nRF/ports/Zephyr/modsocket.c: patch does not apply
    error: patch failed: micropython_nRF/ports/Zephyr/modtime.c:25
    error: micropython_nRF/ports/Zephyr/modtime.c: patch does not apply
    error: micropython_nRF/ports/Zephyr/modules/iotcore.py: No such file or directory
    error: micropython_nRF/ports/Zephyr/modules/main.py: No such file or directory
    error: micropython_nRF/ports/Zephyr/modules/probe.py: No such file or directory
    error: micropython_nRF/ports/Zephyr/modules/probe_protocol.py: No such file or directory
    error: micropython_nRF/ports/Zephyr/modules/sock_test.py: No such file or directory
    error: micropython_nRF/ports/Zephyr/modules/version.py: No such file or directory
    error: micropython_nRF/ports/Zephyr/modules/watchdog.py: No such file or directory
    error: micropython_nRF/ports/Zephyr/modules/wifi.py: No such file or directory
    error: patch failed: micropython_nRF/ports/Zephyr/modzephyr.c:30
    error: micropython_nRF/ports/Zephyr/modzephyr.c: patch does not apply
    error: patch failed: micropython_nRF/ports/Zephyr/mpconfigport.h:68
    error: micropython_nRF/ports/Zephyr/mpconfigport.h: patch does not apply
    error: micropython_nRF/ports/Zephyr/mpconfigport_full.h: No such file or directory
    error: micropython_nRF/ports/Zephyr/network_wlan.c: No such file or directory
    error: micropython_nRF/ports/Zephyr/nrf7002dk/nrf5340/cpuapp/ns/CMakeCache.txt: No such file or directory
    error: micropython_nRF/ports/Zephyr/nrf7002dk/nrf5340/cpuapp/ns/CMakeFiles/3.31.6/CMakeSystem.cmake: No such file or directory
    error: micropython_nRF/ports/Zephyr/nrf7002dk/nrf5340/cpuapp/ns/CMakeFiles/CMakeConfigureLog.yaml: No such file or directory
    error: micropython_nRF/ports/Zephyr/nrf7002dk/nrf5340/cpuapp/ns/CMakeFiles/cmake.check_cache: No such file or directory
    error: micropython_nRF/ports/Zephyr/nrf7002dk/nrf5340/cpuapp/ns/Kconfig/Kconfig.modules: No such file or directory
    error: micropython_nRF/ports/Zephyr/nrf7002dk/nrf5340/cpuapp/ns/Kconfig/Kconfig.sysbuild.modules: No such file or directory
    error: micropython_nRF/ports/Zephyr/nrf7002dk/nrf5340/cpuapp/ns/build_info.yml: No such file or directory
    error: micropython_nRF/ports/Zephyr/nrf7002dk/nrf5340/cpuapp/ns/sysbuild_modules.txt: No such file or directory
    error: micropython_nRF/ports/Zephyr/nrf7002dk/nrf5340/cpuapp/ns/zephyr_modules.txt: No such file or directory
    error: micropython_nRF/ports/Zephyr/nrf7002dk/nrf5340/cpuapp/ns/zephyr_settings.txt: No such file or directory
    error: micropython_nRF/ports/Zephyr/nvmc.c: No such file or directory
    error: micropython_nRF/ports/Zephyr/nvmc.h: No such file or directory
    error: patch failed: micropython_nRF/ports/Zephyr/prj.conf:18
    error: micropython_nRF/ports/Zephyr/prj.conf: patch does not apply
    error: micropython_nRF/ports/Zephyr/samples/wifi/sta/CMakeCache.txt: No such file or directory
    error: micropython_nRF/ports/Zephyr/samples/wifi/sta/CMakeFiles/3.31.6/CMakeSystem.cmake: No such file or directory
    error: micropython_nRF/ports/Zephyr/samples/wifi/sta/CMakeFiles/CMakeConfigureLog.yaml: No such file or directory
    error: micropython_nRF/ports/Zephyr/samples/wifi/sta/CMakeFiles/cmake.check_cache: No such file or directory
    error: micropython_nRF/ports/Zephyr/samples/wifi/sta/Kconfig/Kconfig.modules: No such file or directory
    error: micropython_nRF/ports/Zephyr/samples/wifi/sta/Kconfig/Kconfig.sysbuild.modules: No such file or directory
    error: micropython_nRF/ports/Zephyr/samples/wifi/sta/build_info.yml: No such file or directory
    error: micropython_nRF/ports/Zephyr/samples/wifi/sta/sysbuild_modules.txt: No such file or directory
    error: micropython_nRF/ports/Zephyr/samples/wifi/sta/zephyr_modules.txt: No such file or directory
    error: micropython_nRF/ports/Zephyr/samples/wifi/sta/zephyr_settings.txt: No such file or directory
    error: micropython_nRF/ports/Zephyr/sysbuild.conf: No such file or directory
    error: patch failed: micropython_nRF/ports/Zephyr/zephyr_storage.c:244
    error: micropython_nRF/ports/Zephyr/zephyr_storage.c: patch does not apply
    You shouldn't commit build folders either. Most of the >2k lines of errors are due to the build-folder.
    In order to recreate the issue, I need to know which git hash/commit that you initially used in the upstream micropython project:
    https://github.com/micropython/micropython
    You can test your .diff file by manually checking out micropython and try to apply it to ensure it applies cleanly.
    Can you please provide this?
    Håkon
