Low power mode on NRF52832 with LSM6DSO trigger based wakeup and Bluetooth
I'm working on a project that involves using an NRF52832. Basically, I want to collect data, send it over bluetooth, and then have the device enter system_off mode. If the IMU feels a certain acceleration threshold, the device will power on, and once again collect/send data before powering off. I've talked more about some issues I was having here, but things currently work (for the most part). The issue that I am now having is that although my device seems to go in system_off mode, it still seems to draw about 10.5mA (normal operation before power down occurs at 13.5mA). Obviously something is working since the current reduces, but it's still very high. I do use 1 IMU to trigger wakeup, but it shouldn't be drawing this much power on its own. I need help figuring out what might still be enabled that is causing the current draw to stay high even when my device should be in system_off mode. I'll share my code below as well as my devicetree and config files. Thank you for the help!
//connor shannon wrote this, be careful changing stuff or it might break
//necessary include statements here
#include <uart_async_adapter.h>
#include <zephyr/types.h>
#include <zephyr/kernel.h>
#include <zephyr/drivers/uart.h>
#include <zephyr/usb/usb_device.h>
#include <zephyr/device.h>
#include <soc.h>
#include <zephyr/bluetooth/uuid.h>
#include <zephyr/bluetooth/gatt.h>
#include <zephyr/bluetooth/hci.h>
#include <bluetooth/services/nus.h>
#include <dk_buttons_and_leds.h>
#include <zephyr/settings/settings.h>
#include <stdio.h>
#include <string.h>
#include <stdint.h>
#include <zephyr/drivers/sensor.h>
#include <zephyr/sys/ring_buffer.h>
#include <zephyr/drivers/adc.h>
#include <zephyr/drivers/i2c.h>
#include <hal/nrf_gpio.h>
#include <nrfx_power.h>
#include <hal/nrf_power.h>
//and define statments
#define STACKSIZE CONFIG_BT_NUS_THREAD_STACK_SIZE
#define PRIORITY 7
#define DEVICE_NAME CONFIG_BT_DEVICE_NAME
#define DEVICE_NAME_LEN	(sizeof(DEVICE_NAME) - 1)
#define RUN_STATUS_LED DK_LED1
#define RUN_LED_BLINK_INTERVAL 1000
#define CON_STATUS_LED DK_LED2
#define KEY_PASSKEY_ACCEPT DK_BTN1_MSK
#define KEY_PASSKEY_REJECT DK_BTN2_MSK
#define UART_BUF_SIZE CONFIG_BT_NUS_UART_BUFFER_SIZE
#define UART_WAIT_FOR_BUF_DELAY K_MSEC(50)
#define UART_WAIT_FOR_RX CONFIG_BT_NUS_UART_RX_WAIT_TIME
#define RAD_TO_DEGREE 57.2958
#define GRAVITY 9.80665
#define DECIMAL_SHIFT 1000
#define SAMPLING_FREQUENCY 104 //set sampling freq
#define ACTIVE_MODE 1 //set mode. Active mode should be 1 if using device normallyy
#define BUFFER_SIZE 8000  // size of ring buffer, as in number of elements
#define RING_BUF_SIZE (BUFFER_SIZE * sizeof(int32_t))  // Total size in bytes
RING_BUF_DECLARE(my_ring_buffer, RING_BUF_SIZE); //declaration of ring bfufer
#define ADC_BUFFER_SIZE 100  // size of adc buffer, as in number of elements
#define ADC_RING_BUF_SIZE (ADC_BUFFER_SIZE * sizeof(int32_t))  // Total size in bytes
RING_BUF_DECLARE(adc_ring_buffer, ADC_RING_BUF_SIZE);  //declaration of adc ring buffer
uint16_t time_ms = 0; //define a global variable to track time
#define TESTING_MODE 0 //more testing stuff
#define ADC_MODE 1
#define GPIO_NODE DT_NODELABEL(gpio0)
//lines below added for low power implementation and trigger mode
#define INT1_NODE DT_ALIAS(lsm6dso_int1)
#if DT_NODE_HAS_STATUS(INT1_NODE, okay)
static const struct gpio_dt_spec int1_gpio = GPIO_DT_SPEC_GET(INT1_NODE, irq_gpios);
#else
#error "INT1_NODE is not defined or not okay in the device tree"
static struct gpio_callback int1_cb_data;
// Replace with correct label from your board's devicetree if needed
#define I2C_BUS DT_NODELABEL(i2c0)
#define LSM6DSO_I2C_ADDR 0x6B
static const struct device *i2c_dev = DEVICE_DT_GET(I2C_BUS);
static int lsm6dso_write_reg(uint8_t reg, uint8_t val) {
	return i2c_reg_write_byte(i2c_dev, LSM6DSO_I2C_ADDR, reg, val);
static int lsm6dso_read_reg(uint8_t reg, uint8_t *val) {
	return i2c_reg_read_byte(i2c_dev, LSM6DSO_I2C_ADDR, reg, val);
void scl_toggle(void) {
    const struct device *scl_port = DEVICE_DT_GET(DT_NODELABEL(gpio0));
    const uint8_t scl_pin = 20;
    gpio_pin_configure(scl_port, scl_pin, GPIO_OUTPUT);
    for (int i = 0; i < 9; i++) {
        gpio_pin_set(scl_port, scl_pin, 1);
        k_busy_wait(5);
        gpio_pin_set(scl_port, scl_pin, 0);
        k_busy_wait(5);
    gpio_pin_configure(scl_port, scl_pin, GPIO_INPUT); // optional reset
//all necessary random and initialization-type functions here (these functions should not need edits)
static inline float out_ev(struct sensor_value *val)
	return (val->val1 + (float)val->val2 / 1000000);
static int set_sampling_freq(const struct device *dev)
	int ret = 0;
	struct sensor_value odr_attr;
	/* set accel/gyro sampling frequency to 12.5 Hz */
	odr_attr.val1 = SAMPLING_FREQUENCY;
	//odr_attr.val1 = 12.5;
	odr_attr.val2 = 0;
	ret = sensor_attr_set(dev, SENSOR_CHAN_ACCEL_XYZ,
			SENSOR_ATTR_SAMPLING_FREQUENCY, &odr_attr);
	if (ret != 0) {
		printf("Cannot set sampling frequency for accelerometer.\n");
		return ret;
	ret = sensor_attr_set(dev, SENSOR_CHAN_GYRO_XYZ,
	if (ret != 0) {
		printf("Cannot set sampling frequency for gyro.\n");
		return ret;
	return 0;
static K_SEM_DEFINE(ble_init_ok, 0, 1);
static struct bt_conn *current_conn;
static struct bt_conn *auth_conn;
static const struct device *uart = DEVICE_DT_GET(DT_CHOSEN(nordic_nus_uart));
static struct k_work_delayable uart_work;
struct uart_data_t {
	void *fifo_reserved;
	uint8_t data[UART_BUF_SIZE];
	uint16_t len;
static K_FIFO_DEFINE(fifo_uart_tx_data);
static K_FIFO_DEFINE(fifo_uart_rx_data);
static const struct bt_data ad[] = {
	BT_DATA_BYTES(BT_DATA_FLAGS, (BT_LE_AD_GENERAL | BT_LE_AD_NO_BREDR)),
	BT_DATA(BT_DATA_NAME_COMPLETE, DEVICE_NAME, DEVICE_NAME_LEN),
static const struct bt_data sd[] = {
	BT_DATA_BYTES(BT_DATA_UUID128_ALL, BT_UUID_NUS_VAL),
#ifdef CONFIG_UART_ASYNC_ADAPTER
UART_ASYNC_ADAPTER_INST_DEFINE(async_adapter);
#else
#define async_adapter NULL
static void uart_cb(const struct device *dev, struct uart_event *evt, void *user_data)
	ARG_UNUSED(dev);
	static size_t aborted_len;
	struct uart_data_t *buf;
	static uint8_t *aborted_buf;
	static bool disable_req;
	switch (evt->type) {
	case UART_TX_DONE:
		//LOG_DBG("UART_TX_DONE");
		if ((evt->data.tx.len == 0) ||
		    (!evt->data.tx.buf)) {
			return;
		if (aborted_buf) {
			buf = CONTAINER_OF(aborted_buf, struct uart_data_t,
					   data[0]);
			aborted_buf = NULL;
			aborted_len = 0;
		} else {
			buf = CONTAINER_OF(evt->data.tx.buf, struct uart_data_t,
					   data[0]);
		k_free(buf);
		buf = k_fifo_get(&fifo_uart_tx_data, K_NO_WAIT);
		if (!buf) {
			return;
		if (uart_tx(uart, buf->data, buf->len, SYS_FOREVER_MS)) {
			//LOG_WRN("Failed to send data over UART");
	case UART_RX_RDY:
		//LOG_DBG("UART_RX_RDY");
		buf = CONTAINER_OF(evt->data.rx.buf, struct uart_data_t, data[0]);
		buf->len += evt->data.rx.len;
		if (disable_req) {
			return;
		if ((evt->data.rx.buf[buf->len - 1] == '\n') ||
		    (evt->data.rx.buf[buf->len - 1] == '\r')) {
			disable_req = true;
			uart_rx_disable(uart);
	case UART_RX_DISABLED:
		//LOG_DBG("UART_RX_DISABLED");
		disable_req = false;
		buf = k_malloc(sizeof(*buf));
		if (buf) {
			buf->len = 0;
		} else {
			//LOG_WRN("Not able to allocate UART receive buffer");
			k_work_reschedule(&uart_work, UART_WAIT_FOR_BUF_DELAY);
			return;
		uart_rx_enable(uart, buf->data, sizeof(buf->data),
			       UART_WAIT_FOR_RX);
	case UART_RX_BUF_REQUEST:
		//LOG_DBG("UART_RX_BUF_REQUEST");
		if (buf) {
			buf->len = 0;
			uart_rx_buf_rsp(uart, buf->data, sizeof(buf->data));
		} else {
	case UART_RX_BUF_RELEASED:
		//LOG_DBG("UART_RX_BUF_RELEASED");
		buf = CONTAINER_OF(evt->data.rx_buf.buf, struct uart_data_t,
				   data[0]);
		if (buf->len > 0) {
			k_fifo_put(&fifo_uart_rx_data, buf);
		} else {
			k_free(buf);
	case UART_TX_ABORTED:
		//LOG_DBG("UART_TX_ABORTED");
		if (!aborted_buf) {
			aborted_buf = (uint8_t *)evt->data.tx.buf;
		aborted_len += evt->data.tx.len;
		buf = CONTAINER_OF((void *)aborted_buf, struct uart_data_t,
				   data);
		uart_tx(uart, &buf->data[aborted_len],
			buf->len - aborted_len, SYS_FOREVER_MS);
static void uart_work_handler(struct k_work *item)
	if (buf) {
		buf->len = 0;
	} else {
		return;
	uart_rx_enable(uart, buf->data, sizeof(buf->data), UART_WAIT_FOR_RX);
static bool uart_test_async_api(const struct device *dev)
	const struct uart_driver_api *api =
			(const struct uart_driver_api *)dev->api;
	return (api->callback_set != NULL);
static int uart_init(void)
	int err;
	int pos;
	struct uart_data_t *rx;
	struct uart_data_t *tx;
	if (!device_is_ready(uart)) {
		return -ENODEV;
	if (IS_ENABLED(CONFIG_USB_DEVICE_STACK)) {
		err = usb_enable(NULL);
		if (err && (err != -EALREADY)) {
			printf("Failed to enable USB");
			return err;
	rx = k_malloc(sizeof(*rx));
	if (rx) {
		rx->len = 0;
	} else {
		return -ENOMEM;
	k_work_init_delayable(&uart_work, uart_work_handler);
	if (IS_ENABLED(CONFIG_UART_ASYNC_ADAPTER) && !uart_test_async_api(uart)) {
		/* Implement API adapter */
		uart_async_adapter_init(async_adapter, uart);
		uart = async_adapter;
	err = uart_callback_set(uart, uart_cb, NULL);
	if (err) {
		k_free(rx);
		printf("Cannot initialize UART callback");
		return err;
	if (IS_ENABLED(CONFIG_UART_LINE_CTRL)) {
		//LOG_INF("Wait for DTR");
		while (true) {
			uint32_t dtr = 0;
			uart_line_ctrl_get(uart, UART_LINE_CTRL_DTR, &dtr);
			if (dtr) {
			/* Give CPU resources to low priority threads. */
			k_sleep(K_MSEC(100));
		//LOG_INF("DTR set");
		err = uart_line_ctrl_set(uart, UART_LINE_CTRL_DCD, 1);
		if (err) {
			//LOG_WRN("Failed to set DCD, ret code %d", err);
		err = uart_line_ctrl_set(uart, UART_LINE_CTRL_DSR, 1);
		if (err) {
			//LOG_WRN("Failed to set DSR, ret code %d", err);
	tx = k_malloc(sizeof(*tx));
	if (tx) {
		pos = snprintf(tx->data, sizeof(tx->data),
			       "Code written by Connor Shannon\r\n");
		if ((pos < 0) || (pos >= sizeof(tx->data))) {
			k_free(rx);
			k_free(tx);
			printf("snprintf returned %d", pos);
			return -ENOMEM;
		tx->len = pos;
	} else {
		k_free(rx);
		return -ENOMEM;
	err = uart_tx(uart, tx->data, tx->len, SYS_FOREVER_MS);
	if (err) {
		k_free(rx);
		k_free(tx);
		printf("Cannot display welcome message (err: %d)", err);
		return err;
	err = uart_rx_enable(uart, rx->data, sizeof(rx->data), UART_WAIT_FOR_RX);
	if (err) {
		printf("Cannot enable uart reception (err: %d)", err);
		/* Free the rx buffer only because the tx buffer will be handled in the callback */
		k_free(rx);
	return err;
static void connected(struct bt_conn *conn, uint8_t err)
	if (err) {
		printf("Connection failed (err %u)", err);
		return;
	//LOG_INF("Connected %s", addr);
	current_conn = bt_conn_ref(conn);
	dk_set_led_on(CON_STATUS_LED);
	//LOG_INF("Disconnected: %s (reason %u)", addr, reason);
	if (auth_conn) {
		bt_conn_unref(auth_conn);
		auth_conn = NULL;
	if (current_conn) {
		bt_conn_unref(current_conn);
		current_conn = NULL;
		dk_set_led_off(CON_STATUS_LED);
#ifdef CONFIG_BT_NUS_SECURITY_ENABLED
static void security_changed(struct bt_conn *conn, bt_security_t level,
			     enum bt_security_err err)
	if (!err) {
		//LOG_INF("Security changed: %s level %u", addr, level);
	} else {
		//LOG_WRN("Security failed: %s level %u err %d", addr,
		//	level, err);
BT_CONN_CB_DEFINE(conn_callbacks) = {
	.connected    = connected,
	.disconnected = disconnected,
	.security_changed = security_changed,
#if defined(CONFIG_BT_NUS_SECURITY_ENABLED)
static void auth_passkey_display(struct bt_conn *conn, unsigned int passkey)
	//LOG_INF("Passkey for %s: %06u", addr, passkey);
static void auth_passkey_confirm(struct bt_conn *conn, unsigned int passkey)
	auth_conn = bt_conn_ref(conn);
	//LOG_INF("Press Button 1 to confirm, Button 2 to reject.");
static void auth_cancel(struct bt_conn *conn)
	//LOG_INF("Pairing cancelled: %s", addr);
static void pairing_complete(struct bt_conn *conn, bool bonded)
	//LOG_INF("Pairing completed: %s, bonded: %d", addr, bonded);
static void pairing_failed(struct bt_conn *conn, enum bt_security_err reason)
	//LOG_INF("Pairing failed conn: %s, reason %d", addr, reason);
static struct bt_conn_auth_cb conn_auth_callbacks = {
	.passkey_display = auth_passkey_display,
	.passkey_confirm = auth_passkey_confirm,
	.cancel = auth_cancel,
static struct bt_conn_auth_info_cb conn_auth_info_callbacks = {
	.pairing_complete = pairing_complete,
	.pairing_failed = pairing_failed
#else
static struct bt_conn_auth_cb conn_auth_callbacks;
static struct bt_conn_auth_info_cb conn_auth_info_callbacks;
static void bt_receive_cb(struct bt_conn *conn, const uint8_t *const data,
			  uint16_t len)
	int err;
	char addr[BT_ADDR_LE_STR_LEN] = {0};
	bt_addr_le_to_str(bt_conn_get_dst(conn), addr, ARRAY_SIZE(addr));
	//LOG_INF("Received data from: %s", addr);
	for (uint16_t pos = 0; pos != len;) {
		struct uart_data_t *tx = k_malloc(sizeof(*tx));
		if (!tx) {
			//LOG_WRN("Not able to allocate UART send data buffer");
			return;
		/* Keep the last byte of TX buffer for potential LF char. */
		size_t tx_data_size = sizeof(tx->data) - 1;
		if ((len - pos) > tx_data_size) {
			tx->len = tx_data_size;
		} else {
			tx->len = (len - pos);
		memcpy(tx->data, &data[pos], tx->len);
		pos += tx->len;
		/* Append the LF character when the CR character triggered
		 * transmission from the peer.
		if ((pos == len) && (data[len - 1] == '\r')) {
			tx->data[tx->len] = '\n';
			tx->len++;
		if (err) {
			k_fifo_put(&fifo_uart_tx_data, tx);
static struct bt_nus_cb nus_cb = {
	.received = bt_receive_cb,
void error(void)
	dk_set_leds_state(DK_ALL_LEDS_MSK, DK_NO_LEDS_MSK);
	while (true) {
		/* Spin for ever */
		k_sleep(K_MSEC(1000));
static void num_comp_reply(bool accept)
	if (accept) {
		bt_conn_auth_passkey_confirm(auth_conn);
		//LOG_INF("Numeric Match, conn %p", (void *)auth_conn);
	} else {
		bt_conn_auth_cancel(auth_conn);
		//LOG_INF("Numeric Reject, conn %p", (void *)auth_conn);
	auth_conn = NULL;
void button_changed(uint32_t button_state, uint32_t has_changed)
	uint32_t buttons = button_state & has_changed;
	if (auth_conn) {
		if (buttons & KEY_PASSKEY_ACCEPT) {
			num_comp_reply(true);
		if (buttons & KEY_PASSKEY_REJECT) {
			num_comp_reply(false);
#endif /* CONFIG_BT_NUS_SECURITY_ENABLED */
static void configure_gpio(void)
	int err;
	err = dk_buttons_init(button_changed);
	if (err) {
		printf("Cannot init buttons (err: %d)", err);
	err = dk_leds_init();
	if (err) {
		printf("Cannot init LEDs (err: %d)", err);
//____________________________________________________________________________________________________________________________________________________________
//all functions above this should not need editing, while all functions below this are more important and may require editing
 * Combines two 16-bit integers into a single 32-bit integer.
 * @param value1 The first 16-bit integer (to be placed in the upper 16 bits).
 * @param value2 The second 16-bit integer (to be placed in the lower 16 bits).
 * @return A 32-bit integer containing both input values.
uint32_t pack_16bit_to_32bit(int16_t value1, int16_t value2) {
    return ((uint32_t)(uint16_t)value1 << 16) | (uint16_t)value2;
 * Extracts the first (upper) 16-bit integer from a 32-bit integer.
 * @param packed_value The 32-bit integer containing two 16-bit integers.
 * @return The first (upper) 16-bit integer.
int16_t extract_first_16bit(uint32_t packed_value) {
    return (int16_t)(packed_value >> 16);  // Ensure sign extension
 * Extracts the second (lower) 16-bit integer from a 32-bit integer.
 * @return The second (lower) 16-bit integer.
int16_t extract_second_16bit(uint32_t packed_value) {
    return (int16_t)(packed_value & 0xFFFF);  // Implicitly sign-extended
// Add a 32-bit integer to the ring buffer
int add_to_ring_buffer(struct ring_buf *rb, uint32_t data) {
    int ret = ring_buf_put(rb, (uint8_t *)&data, sizeof(data));
    return (ret == sizeof(data)) ? 1 : 0; // Return 1 if all bytes were written, 0 otherwise
// Check if the ring buffer is full
int is_ring_buffer_full(struct ring_buf *rb) {
    return ring_buf_space_get(rb) == 0 ? 1 : 0; // Return 1 if full, 0 if not
// Get a 32-bit integer from the ring buffer
int get_from_ring_buffer(struct ring_buf *rb, uint32_t *data) {
    // Attempt to retrieve the first 32-bit value (4 bytes) from the ring buffer
    int ret = ring_buf_get(rb, (uint8_t *)data, sizeof(uint32_t));
    if (ret == sizeof(uint32_t)) {
        return 1; // Successfully retrieved the first value
    } else {
        return 0; // Failed to retrieve (buffer might be empty)
// Check if the ring buffer is empty
int is_ring_buffer_empty(struct ring_buf *rb) {
    return ring_buf_is_empty(rb) ? 1 : 0; // Return 1 if empty, 0 if not
//check if bluetooth is connected
bool is_bt_connected(void)
    return (current_conn != NULL);
static int64_t time_reset_reference = 0;
void reset_time_reference(void) { //resets time value every time data collection begins
    time_reset_reference = k_uptime_get();
int16_t get_elapsed_time_ms(void) { //uses the reference time to get elapsed time since start of data collection
    int64_t current_time = k_uptime_get();
    int64_t elapsed_time = current_time - time_reset_reference;
    // Safely cast to uint16_t
    return (int16_t)(elapsed_time & 0xFFFF); // Wrap around at 16 bits
void check_ring_buffer_progress(size_t total_elements) {
    static uint32_t call_count = 0;  // Tracks how many times the function is called
	//uint16_t time;
    // Increment the call count
    call_count++;
    // Only print every 100 calls
    if (call_count % 100 == 0) {
        // Get the current used space in bytes
        size_t used_space = ring_buf_size_get(&my_ring_buffer);
        // Convert used space (in bytes) to number of elements
        size_t used_elements = used_space / sizeof(uint32_t);  // Assuming uint32_t (4 bytes each)
        // Calculate the percentage of the buffer that is full
        uint8_t current_percent = (used_elements * 100) / total_elements;
        // Print the buffer percentage
        printf("Ring buffer is %d%% full\n", current_percent);
		//time = get_elapsed_time_ms();
		//printf("Elapsed time: %d\n", time);
void get_LSM6DSO_data(const struct device *dev){ //this function gets and stores 6 values from the sensor
	struct sensor_value x, y, z;
	int16_t pack1;
	int16_t pack2;
	uint32_t data_to_store;
	int full;
	sensor_sample_fetch_chan(dev, SENSOR_CHAN_GYRO_XYZ);
	sensor_channel_get(dev, SENSOR_CHAN_GYRO_X, &x);
	sensor_channel_get(dev, SENSOR_CHAN_GYRO_Y, &y);
	sensor_channel_get(dev, SENSOR_CHAN_GYRO_Z, &z);
	if (TESTING_MODE == 1){
		printf("Raw gyro X: %d, %d\n", x.val1, x.val2);
    	printf("Raw gyro Y: %d, %d\n", y.val1, y.val2);
    	printf("Raw gyro Z: %d, %d\n", z.val1, z.val2);
		k_sleep(K_MSEC(500));
	//package x and y gyro, store
	pack1 = (int16_t)(out_ev(&x)*(float)DECIMAL_SHIFT*(float)RAD_TO_DEGREE);
	pack2 = (int16_t)(out_ev(&y)*(float)DECIMAL_SHIFT*(float)RAD_TO_DEGREE);
	data_to_store = pack_16bit_to_32bit(pack1, pack2);
	full = add_to_ring_buffer(&my_ring_buffer, data_to_store);
		printf("X gyro: %d\n", pack1);
		printf("Y gyro: %d\n", pack2);
	//package z gyro and x accel, store
	pack1 = (int16_t)(out_ev(&z)*(float)DECIMAL_SHIFT*(float)RAD_TO_DEGREE);
	sensor_sample_fetch_chan(dev, SENSOR_CHAN_ACCEL_XYZ);
	sensor_channel_get(dev, SENSOR_CHAN_ACCEL_X, &x);
	sensor_channel_get(dev, SENSOR_CHAN_ACCEL_Y, &y);
	sensor_channel_get(dev, SENSOR_CHAN_ACCEL_Z, &z);
		printf("Raw accel X: %d, %d\n", x.val1, x.val2);
    	printf("Raw accel Y: %d, %d\n", y.val1, y.val2);
    	printf("Raw accel Z: %d, %d\n", z.val1, z.val2);
	pack2 = (int16_t)(out_ev(&x)*(float)DECIMAL_SHIFT/(float)GRAVITY);
		printf("Z gyro: %d\n", pack1);
		printf("X accel: %d\n", pack2);
	//package y accel and z accel, store
	pack1 = (int16_t)(out_ev(&y)*(float)DECIMAL_SHIFT/(float)GRAVITY);
	pack2 = (int16_t)(out_ev(&z)*(float)DECIMAL_SHIFT/(float)GRAVITY);
		printf("Y accel: %d\n", pack1);
		printf("Z accel: %d\n", pack2);
int16_t get_adc(const struct adc_dt_spec *adc_channel, struct adc_sequence *sequence, int16_t *buf) {
    int32_t val_mv32;
    int err;
    /* STEP 5 - Read a sample from the ADC */
    err = adc_read(adc_channel->dev, sequence);
    if (err < 0) {
        printf("Could not read (%d)\n", err);
        return -1; // Return error indicator
    val_mv32 = (int32_t)*buf;
    /* STEP 6 - Convert raw value to mV */
    err = adc_raw_to_millivolts_dt(adc_channel, &val_mv32);
    if (err < 0) {
        printf("Could not convert to millivolts (%d)\n", err);
    //printf("%d\n", (int16_t)val_mv32);
    return (int16_t)val_mv32;
int gather_data_no_adc(const struct device *dev){ //this function gets IMU data, and adds it to the larger ring buffer. It returns a 0 if the ring buffer is full
	int16_t pack1;
	int16_t pack2;
	int full;
	pack1 = 0; //0 value tracks breaks between samples
	pack2 = get_elapsed_time_ms();
	get_LSM6DSO_data(dev); //note that this function packs and stores values automatically
    if (is_ring_buffer_full(&my_ring_buffer)){
        return 0;
    return 1;
//functions below added for low power
static struct k_work lsm6dso_work;
// This function is safe to run outside ISR context
static void lsm6dso_work_handler(struct k_work *work)
	gpio_pin_interrupt_configure_dt(&int1_gpio, GPIO_INT_DISABLE);
    // const struct device *const dev = DEVICE_DT_GET_ONE(st_lsm6dso);
    // if (!device_is_ready(dev)) {
    //     printk("LSM6DSO device not ready\n");
    //     return;
	uint8_t wake_src, tap_src, status;
	lsm6dso_read_reg(0x1B, &wake_src);
	lsm6dso_read_reg(0x1C, &tap_src);
	lsm6dso_read_reg(0x1E, &status);
    printk("Wake-up SRC: 0x%02X\n", wake_src);
    printk("callback triggered.\n");
    //fetch_and_display(dev);  // Whatever your normal logic is
	gpio_pin_interrupt_configure_dt(&int1_gpio, GPIO_INT_EDGE_TO_ACTIVE);
static void lsm6dso_int1_callback(const struct device *port, struct gpio_callback *cb, uint32_t pins)
	k_work_submit(&lsm6dso_work);
static void setup_int1_gpio(void)
	//gpio_pin_configure_dt(&int1_gpio, GPIO_INPUT | GPIO_PULL_UP);
	nrf_gpio_cfg_sense_input(int1_gpio.pin, NRF_GPIO_PIN_PULLUP, NRF_GPIO_PIN_SENSE_LOW);
    gpio_init_callback(&int1_cb_data, lsm6dso_int1_callback, BIT(int1_gpio.pin));
    gpio_add_callback(int1_gpio.port, &int1_cb_data);
static void reset_registers(void){
	// 1. Reset device (optional but good practice)
	lsm6dso_write_reg(0x12, 0x01);  // CTRL3_C: SW_RESET
	k_sleep(K_MSEC(100));            // Delay to allow reset
	// 2. Disable all interrupts on INT1 and INT2
	lsm6dso_write_reg(0x5E, 0x00);  // MD1_CFG: no interrupt routed
	lsm6dso_write_reg(0x5F, 0x00);  // MD2_CFG: no interrupt routed
	// 3. Disable embedded functions, just basic accelerometer on 104 Hz, ±2g
	lsm6dso_write_reg(0x10, 0x40);  // CTRL1_XL: 104 Hz, ±2g
	lsm6dso_write_reg(0x11, 0x00);  // CTRL2_G: gyroscope off
	lsm6dso_write_reg(0x12, 0x44);  // CTRL3_C: BDU + auto-increment enabled
	// 4. Disable embedded functions access
	lsm6dso_write_reg(0x19, 0x00);  // FUNC_CFG_ACCESS: disable
	// 5. Read INT1 pin voltage level with logic analyzer or voltmeter
static void lsm6dso_config_motion_interrupt(void)
	reset_registers();
	// 1. Enable BDU and auto-increment
	// 2. Enable accelerometer: ODR = 104 Hz, FS = ±4g
	lsm6dso_write_reg(0x10, 0x50);  // CTRL1_XL
	// 3. Enable access to embedded functions
	lsm6dso_write_reg(0x01A, 0x80); // FUNC_CFG_ACCESS = enable embedded reg access
	// 4. Enable embedded functions
	lsm6dso_write_reg(0x04, 0x01);  // EMB_FUNC_EN_A = enable wake-up
	lsm6dso_write_reg(0x05, 0x00);  // EMB_FUNC_EN_B = (optional)
	// 5. Enable embedded function interrupt
	lsm6dso_write_reg(0x58, 0x80);  // TAP_CFG0: enable interrupts
	lsm6dso_write_reg(0x59, 0x0C);  // TAP_CFG2: route wake-up to INTs
	// 6. Set wake-up threshold and duration
	lsm6dso_write_reg(0x5B, 0x02);  // WAKE_UP_THS = ~2g
	lsm6dso_write_reg(0x5C, 0x00);  // WAKE_UP_DUR = min duration
	// 7. Route wake-up interrupt to INT2
	lsm6dso_write_reg(0x5F, 0x20);  // MD2_CFG: bit 5 = wake-up INT2
	// 7b. Route core wake-up interrupt to INT2 (not just embedded wake-up)
	//lsm6dso_write_reg(0x5E, 0x20);
	//lsm6dso_write_reg(0x0F, 0x20);  // INT2_CTRL: Wake-up to INT2
	// 8. (Optional) Enable HPF for reliable wake-up
	lsm6dso_write_reg(0x17, 0x09);  // CTRL8_XL: no HPF
	// 9. Exit embedded access mode
	lsm6dso_write_reg(0x1A, 0x00);  // FUNC_CFG_ACCESS = user bank
	// 10. Enable Wake-Up in CTRL10_C
	lsm6dso_write_reg(0x19, 0x24);  // CTRL10_C: FUNC_EN | WAKE_EN
	// 11. Configure INT2: push-pull, active high
	lsm6dso_write_reg(0x13, 0x00);  // CTRL4_C: default push-pull
	// 12. Enable interrupt latch
	lsm6dso_write_reg(0x0B, 0x40);  // CTRL6_C: LIR = 1
	// Explicitly disable wake-up on INT1
	lsm6dso_write_reg(0x5E, 0x00);  // MD1_CFG: clear wake-up routing on INT1
	// Route wake-up interrupt to INT2
	lsm6dso_write_reg(0x5F, 0x20);  // MD2_CFG: wake-up INT2
	// Explicitly route wake-up interrupt on INT2 control register
	lsm6dso_write_reg(0x0F, 0x20);  // INT2_CTRL: wake-up interrupt to INT2
	// Disable wake-up on INT1 control register
	lsm6dso_write_reg(0x0E, 0x00);  // INT1_CTRL
	// Optional: configure INT2 pin type
	lsm6dso_write_reg(0x13, 0x00);  // or try 0x02 for open-drain
	//enable int1 code below
	// Disable INT2
	lsm6dso_write_reg(0x0F, 0x00);  // INT2_CTRL
	// Enable INT1 for wake-up
	lsm6dso_write_reg(0x5E, 0x20);  // MD1_CFG: route wake-up to INT1
	lsm6dso_write_reg(0x0E, 0x20);  // INT1_CTRL: route core wake-up to INT1
	// Enable full accelerometer (e.g., 104 Hz) and gyroscope (e.g., 104 Hz)
	//lsm6dso_write_reg(0x11, 0x40); // CTRL2_G = 0x40 for 104 Hz
	//lsm6dso_write_reg(0x10, 0x40); // CTRL1_XL = 0x40 for 104 Hz
static void powerup(void){
	k_msleep(3000);
	lsm6dso_write_reg(0x11, 0x20);  // CTRL2_G: enable gyro at 26 Hz
	k_msleep(10);  // small delay for internal clocks to stabilize
	k_work_init(&lsm6dso_work, lsm6dso_work_handler);
static void int_setup(void){
	lsm6dso_config_motion_interrupt();  // <--- manually configure 2g motion INT
	k_msleep(100);
	setup_int1_gpio();
static void powerdown_prep(void){
	bt_disable();
	//disable uart
	const struct device *uart_dev = device_get_binding("UART_0");
	if (uart_dev) {
		uart_irq_rx_disable(uart_dev);
		uart_irq_tx_disable(uart_dev);
	//disable gpio
	// for (int pin = 0; pin < 32; pin++) {
	// 	if (pin == 15 || pin == 19 || pin == 20) {
	// 		continue;  // don't touch interrupt pin
	// 	nrf_gpio_cfg_input(pin, NRF_GPIO_PIN_PULLDOWN);
static void powerdown(){
	int_setup();
	powerdown_prep();
	lsm6dso_write_reg(0x11, 0x00);  // CTRL2_G = 0x00 disables gyro
	lsm6dso_write_reg(0x10, 0x58);  // CTRL1_XL: ODR=52Hz, FS=±4g
	k_msleep(50);
	nrf_power_system_off(NRF_POWER);
	printk("This should NEVER print!\n");
//functions above added for low power
//this function takes a ring buffer as an input, and extracts two values from it which it then sends over bluetooth
//note that this is one of the functions that takes a ring buffer input, so sometimes it operates on data from the large ring buffer and sometimes the adc ring buffer
int send_data(struct ring_buf *rb) {
    uint32_t buffer_value;
    int full;
    int16_t extract1;
    int16_t extract2;
    int send_success = 0; // Flag to track if both sends succeed
    // Get data from the buffer
    full = get_from_ring_buffer(rb, &buffer_value);
    extract1 = extract_first_16bit(buffer_value);
    extract2 = extract_second_16bit(buffer_value);
	//the lines below are a fix that convert to a string before sending
	char buffer1[10];  // Enough space for "-32768" and null terminator
	char buffer2[10];  // Enough space for "-32768" and null terminator
	snprintf(buffer1, sizeof(buffer1), "%d\n", extract1);
	snprintf(buffer2, sizeof(buffer2), "%d\n", extract2);
	int counter = 0;
    while (1) {
        // Check if Bluetooth is connected
        if (!is_bt_connected()) {
            printf("Bluetooth not connected. Waiting for connection...\n");
            k_sleep(K_MSEC(3000)); // Wait for 1 second before checking again
			counter++;
			if (counter==1){
				printf("Waited too long, powering down.\n");
            continue; // Skip the sending attempt until Bluetooth is connected
        // Attempt to send the first part of the data
        //if (bt_nus_send(NULL, (uint8_t *)&extract1, sizeof(extract1))) {
		if (bt_nus_send(NULL, (uint8_t *)buffer1, strlen(buffer1))){
            //printf("Failed to send first part of data over BLE connection\n");
        } else {
            send_success |= 1; // Mark the first send as successful
        // Attempt to send the second part of the data
        //if (bt_nus_send(NULL, (uint8_t *)&extract2, sizeof(extract2))) {
		if (bt_nus_send(NULL, (uint8_t *)buffer2, strlen(buffer2))){
            printf("Failed to send data.. Please make sure your device is ready to receive BLE.\n");
        } else {
            send_success |= 2; // Mark the second send as successful
        // If both parts were successfully sent, break the loop
        if (send_success == 3) {
        // If any part failed, retry after waiting for 1 second
	return counter;
int store_adc_data(int16_t adc1, int16_t adc2, int16_t adc3){ //this function takes three inputs, which it stores as well as the time at which the function is called
	int16_t time;
	uint32_t packed;
	int err;
	printf("Time: %d\n",time);
	packed = pack_16bit_to_32bit(time, adc1);
	err = add_to_ring_buffer(&adc_ring_buffer, packed);
	if (err == 0){
		return err;
	packed = pack_16bit_to_32bit(adc2, adc3);
	return err;
static void reset_sensor(){
	i2c_recover_bus(i2c_dev);
	reset_registers();
//main function here, this is what calls other functions and runs code.
int main(void){
	ring_buf_reset(&my_ring_buffer);
	ring_buf_reset(&adc_ring_buffer);
    //all necessary initialization here
	int err = 0;
	uint8_t last_printed_percent;
	int sensor_ready = 1;
	int16_t adc1;
	int16_t adc2;
	int16_t adc3;
	const char* msg;
	configure_gpio();
	err = uart_init();
	if (err) {
		error();
	if (IS_ENABLED(CONFIG_BT_NUS_SECURITY_ENABLED)) {
		err = bt_conn_auth_cb_register(&conn_auth_callbacks);
		if (err) {
			printk("Failed to register authorization callbacks.\n");
			return 0;
		err = bt_conn_auth_info_cb_register(&conn_auth_info_callbacks);
		if (err) {
			printk("Failed to register authorization info callbacks.\n");
			return 0;
	err = bt_enable(NULL);
	if (err) {
		error();
	//LOG_INF("Bluetooth initialized");
	k_sem_give(&ble_init_ok);
	if (IS_ENABLED(CONFIG_SETTINGS)) {
		settings_load();
	err = bt_nus_init(&nus_cb);
	if (err) {
		printf("Failed to initialize UART service (err: %d)", err);
		return 0;
	err = bt_le_adv_start(BT_LE_ADV_CONN, ad, ARRAY_SIZE(ad), sd,
			      ARRAY_SIZE(sd));
	if (err) {
		printf("Advertising failed to start (err %d)", err);
		return 0;
	//add sensor code below
	reset_sensor();
	while (sensor_ready == 1){
			printf("I2C device not ready.\n");
			k_msleep(3000);
		} else {
			printf("I2C device is ready!\n");
			sensor_ready = 0;
		sensor_ready = set_sampling_freq(dev);
	//sensor code above
	/* Define three ADC channels */
	static const struct adc_dt_spec adc_channel1 = ADC_DT_SPEC_GET_BY_IDX(DT_PATH(zephyr_user), 0);
	static const struct adc_dt_spec adc_channel2 = ADC_DT_SPEC_GET_BY_IDX(DT_PATH(zephyr_user), 1);
	static const struct adc_dt_spec adc_channel3 = ADC_DT_SPEC_GET_BY_IDX(DT_PATH(zephyr_user), 2);
	/* Define three buffers */
	int16_t buf1, buf2, buf3;
	/* Define three ADC sequences */
	struct adc_sequence sequence1 = { .buffer = &buf1, .buffer_size = sizeof(buf1) };
	struct adc_sequence sequence2 = { .buffer = &buf2, .buffer_size = sizeof(buf2) };
	struct adc_sequence sequence3 = { .buffer = &buf3, .buffer_size = sizeof(buf3) };
	//uint32_t count = 0;
	/* Check which ADC devices are ready and initialize only those */
	// Note that I think this code is unnecessary, and always sets up the channels. However, I don't want to risk removing it.
	if (adc_is_ready_dt(&adc_channel1)) {
		err = adc_channel_setup_dt(&adc_channel1);
		if (err < 0) {
			printf("Could not setup channel 1 (%d)\n", err);
		} else {
			err = adc_sequence_init_dt(&adc_channel1, &sequence1);
			if (err < 0) {
				printf("Could not initialize sequence 1\n");
	} else {
		printf("ADC1 not ready\n");
	if (adc_is_ready_dt(&adc_channel2)) {
		err = adc_channel_setup_dt(&adc_channel2);
		if (err < 0) {
			printf("Could not setup channel 2 (%d)\n", err);
		} else {
			err = adc_sequence_init_dt(&adc_channel2, &sequence2);
			if (err < 0) {
				printf("Could not initialize sequence 2\n");
	} else {
		printf("ADC2 not ready\n");
	if (adc_is_ready_dt(&adc_channel3)) {
		err = adc_channel_setup_dt(&adc_channel3);
		if (err < 0) {
			printf("Could not setup channel 3 (%d)\n", err);
		} else {
			err = adc_sequence_init_dt(&adc_channel3, &sequence3);
			if (err < 0) {
				printf("Could not initialize sequence 3\n");
	} else {
		printf("ADC3 not ready\n");
	//ADC initialization above ===================================================================================================================================
	powerup();
	int powercheck;
	//more powerup stuff above
    if (ACTIVE_MODE == 1){ //if the device is in its fully active mode, recording and sending data over bluetooth
        int BLUETOOTH_MODE = 0; //assume storage starts empty
        for (;;){ //infinite loop
            if (BLUETOOTH_MODE == 0){ //function occurs if storage has just been emptied (or starts empty)
				reset_time_reference();
				while (gather_data_no_adc(dev)){
                //while (gather_data(dev, &adc_channel, &sequence, &buf)){ //goes until buffer is filled
					check_ring_buffer_progress(BUFFER_SIZE);
					k_sleep(K_MSEC(10)); //pause for 10ms
					static int counter = 0;
					if (++counter % 100 == 0) { // Code to run every 100th call
						adc1 = get_adc(&adc_channel1, &sequence1, &buf1);
						adc2 = get_adc(&adc_channel2, &sequence2, &buf2);
						adc3 = get_adc(&adc_channel3, &sequence3, &buf3);
						err = store_adc_data(adc1, adc2, adc3);
						if (err == 0){
							printf("ADC data could not be stored.\n");
				printf("Ring buffer is full. Ready to send data over Bluetooth.\n");
                BLUETOOTH_MODE = 1;
            if (BLUETOOTH_MODE == 1){ //function occurs once storage is full and ready to send data
                while (!is_ring_buffer_empty(&my_ring_buffer)){ //this line starts a loop that sends all imu data over bluetooth
                    powercheck = send_data(&my_ring_buffer);
					if (powercheck > 0){
						powerdown();
				printf("Ring buffer is empty. Sending ADC data now.\n");
				msg = "Sending ADC data\n";
				bt_nus_send(NULL, (uint8_t *)msg, strlen(msg));
				while (!is_ring_buffer_empty(&adc_ring_buffer)){  //this line sends ADC data over bluetooth
                    send_data(&adc_ring_buffer);
                BLUETOOTH_MODE = 0; //change back to data collection mode once all data is sent
				last_printed_percent = 0; //reset buffer storage tracker
				printf("All data sent. Powering down\n");
				msg = "All data sent: Powering down.\n";
				//k_sleep(K_MSEC(20000));
				powerdown();
    if (ACTIVE_MODE == 0){ //this situation would occur if we didn't want the device to be active. Likely, this mode would be to test something, perhaps to print the data to console
Devicetree overlay:
 * Copyright (c) 2022 Nordic Semiconductor ASA
    chosen {
        nordic,nus-uart = &uart0;
//lines after this added for sensor
// arduino_i2c: &i2c0 {
//  lsm6dso@6b {
//      compatible = "st,lsm6dso";
//      label = "LSM6DSO";
//      reg = <0x6b>;
//two blocks below this testing
&i2c0 {
    lsm6dso: lsm6dso@6b {
        reg = <0x6b>;
        label = "LSM6DSO";
        irq-gpios = <&gpio0 15 GPIO_ACTIVE_HIGH>;
        int-pin = <1>;
        status = "okay";
&{/aliases} {
    lsm6dso-int1 = &lsm6dso;
//  zephyr,user {
//      io-channels = <&adc 0>;
// &adc {
//  #address-cells = <1>;
//  #size-cells = <0>;
//  status = "okay";
//  channel@0 {
//      reg = <0>;
//      zephyr,gain = "ADC_GAIN_1_6";
//      zephyr,reference = "ADC_REF_INTERNAL";
//      zephyr,acquisition-time = <ADC_ACQ_TIME_DEFAULT>;
//      zephyr,input-positive = <NRF_SAADC_AIN0>; /* P0.02 for nRF52xx, P0.04 for nRF53xx */
//      zephyr,resolution = <12>;
    zephyr,user {
        io-channels = <&adc 0>, <&adc 1>, <&adc 2>;
&adc {
    #size-cells = <0>;
    status = "okay";
    channel@0 {
        reg = <0>;
        zephyr,input-positive = <NRF_SAADC_AIN0>; /* P0.02 */
    channel@1 {
        reg = <1>;
        zephyr,input-positive = <NRF_SAADC_AIN1>; /* P0.03 */
    channel@2 {
        reg = <2>;
        zephyr,input-positive = <NRF_SAADC_AIN2>; /* P0.04 */
Config file:
# Copyright (c) 2018 Nordic Semiconductor
# Enable the UART driver
CONFIG_UART_ASYNC_API=y
CONFIG_NRFX_UARTE0=y
#CONFIG_SERIAL=y
#CONFIG_GPIO=y
# Make sure printk is printing to the UART console
#CONFIG_CONSOLE=y
#CONFIG_UART_CONSOLE=y
CONFIG_HEAP_MEM_POOL_SIZE=2048
CONFIG_BT=y
CONFIG_BT_PERIPHERAL=y
CONFIG_BT_DEVICE_NAME="Hello Sangwoo"
CONFIG_BT_MAX_CONN=1
CONFIG_BT_MAX_PAIRED=1
# Enable the NUS service
CONFIG_BT_NUS=y
# Enable bonding
CONFIG_BT_SETTINGS=y
CONFIG_FLASH=y
CONFIG_FLASH_PAGE_LAYOUT=y
CONFIG_FLASH_MAP=y
CONFIG_NVS=y
CONFIG_SETTINGS=y
# Enable DK LED and Buttons library
CONFIG_DK_LIBRARY=y
# This example requires more stack
CONFIG_MAIN_STACK_SIZE=1152
# Config logger
CONFIG_LOG=n
#CONFIG_USE_SEGGER_RTT=y
#CONFIG_LOG_BACKEND_RTT=y
#CONFIG_LOG_BACKEND_UART=n
#CONFIG_LOG_PRINTK=n
#CONFIG_LOG_DEFAULT_LEVEL=0
CONFIG_ASSERT=y
#adding the sensor code
CONFIG_I2C=y
CONFIG_SENSOR=y
#CONFIG_LSM6DSO_TRIGGER_GLOBAL_THREAD=n
CONFIG_CBPRINTF_FP_SUPPORT=y
CONFIG_RING_BUFFER=y
CONFIG_ADC=y
#added code below
CONFIG_STDOUT_CONSOLE=y
CONFIG_GPIO=y
CONFIG_LSM6DSO=y
CONFIG_LSM6DSO_TRIGGER_GLOBAL_THREAD=y
# CONFIG_UART_CONSOLE=n
# CONFIG_LOG=n
# CONFIG_PRINTK=n
# CONFIG_USE_SEGGER_RTT=n
