nRF7002 cannot connect to SSID after a while
As the title states, after a while, the nRF7002 fails to connect SSID after a while. It happens either we perform net_if_up/down or not. I suspect the nRF7002 to be in a bad state because when I measure the consumption with the ppk2, I have around 750µA instead of around 80µA idle on my system, or ~150µA when interface is Up but IDLE
During connect attemp, I have several mA spikes, but not even close to the  ~200mA spikes and ~60mA floor I am supposed to have when connecting/transmitting.
I am sorry I did not captured the trace as I wasn't expecting to post the issue here at first. As it happend after several days of working, I did not managed to attach a debug session to it yet.
Maybe you have some insight on what is going on, or what could be the issue.
Thank you for your help
  • I will try to follow the event loop, but I have some remarks.
    1)
    then start using Wi-Fi on successful connection
    I am not sure to understand this. To have a successful connection, one have to use Wi-Fi first right?
    1 (bis)
    Wi-Fi not ready event, it has to stop using Wi-Fi (don't send any traffic)
    Do you mean I have to stop AS SOON as I receive the event? What if I was already sending something? In the sample, this case is not showed.
    2) the sta event loop is a bit unclear to me. Is there any particular reason to repeat the instructions
    ret = k_sem_take(&wifi_ready_state_changed_sem, K_FOREVER);
    			if (ret) {
    				LOG_ERR("Failed to take semaphore: %d", ret);
    				return ret;
    from lines 325 to 329 and then goto check_wifi_ready while check_wifi_ready could also perform the k_sem_wait? A bit like following :
    check_wifi_ready:
    		LOG_INF("Waiting for Wi-Fi to be ready");
    		if (ret) {
    			return ret;
    		if (!wifi_ready_status) {
    			LOG_INF("Wi-Fi is not ready");
    			/* Perform any cleanup and stop using Wi-Fi and wait for
    			 * Wi-Fi to be ready
    			continue;
    #ifdef CONFIG_WIFI_READY_LIB
    			goto check_wifi_ready;
    #else
    This would avoid to have 2 k_sem_wait.
    I keep you in touch about my tests, thank you for your answers
    Of course we need to trigger a Wi-Fi connection once Wi-Fi is ready, using Wi-Fi in this context here means sending data (after connection)
    Even if the application doesn't stop sending, those packets will fail once Wi-Fi is unready. It really depends on the application design on how best to handle this.
    Your suggestion makes sense, we can improve this.
    EDIT: Could you also give me the schematics and potentially layout for your board, so that I can confirm that everything is in order there? I can make the case private so that only you and Nordic personell can see the case, if that is preferable to you.
    Elfving
    I put 5 devices on a long test. I am following the event loop now. After 10 days. One of them stopped to communicate, which is significantly better than before, but still not working perfectly. I give you a ppk2 trace where we can see 150mA spikes and 50mA plateau every 100ms. The radio module seems to try to do things without succeeding to do so
    radio_crash.ppk2
    Sorry for the schematic, I skipped that part. Yes please put my ticket private so I can give you a schematic and more code so you can check my event loop is correct.
    I see someone has the same issue, and gave you a code that reproduce the issue, did you make any progress?
    Best regards
  • After investigation, it appears that the one that stopped communicate was expected to do so due to other factors. The 4 that are supposed to communicate are still doing so. So I would say that with wifi_ready lib + RPU recovery mechanism, it is okay, thank you for your help
  • Glad to hear it! Let us know if there is anything else!
    Elfving
